I am using Jetson TX2 4GB varient (model:3489) for one of my project. while doing the bringup of TX2 SOM, i am getting below error while flashing the images using flash.sh script under Linux_for_Tegra(R32.4.3).
Host System : Ubuntu 18.04.4 LTS
L4T BSP Information:
R32 , REVISION: 4.3
Target Board Information:
Name: jetson-tx2, Board Family: t186ref, SoC: Tegra 186,
OpMode: production, Boot Authentication: NS,
./tegraflash.py --chip 0x18 --applet “/home/vvdn/projects/ntdi_bag2/Code_chekout/ntdi_bag2/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin” --skipuid --cmd “dump eeprom boardinfo cvm.bin”
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0075 ] Generating RCM messages
[ 0.0093 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 0 --download rcm /home/vvdn/projects/ntdi_bag2/Code_chekout/ntdi_bag2/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin 0 0
[ 0.0111 ] RCM 0 is saved as rcm_0.rcm
[ 0.0121 ] RCM 1 is saved as rcm_1.rcm
[ 0.0121 ] List of rcm files are saved in rcm_list.xml
[ 0.0121 ]
[ 0.0122 ] Signing RCM messages
[ 0.0140 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0157 ] Assuming zero filled SBK key
[ 0.0235 ]
[ 0.0236 ] Copying signature to RCM mesages
[ 0.0267 ] tegrarcm_v2 --chip 0x18 0 --updatesig rcm_list_signed.xml
[ 0.0291 ]
[ 0.0292 ] Boot Rom communication
[ 0.0309 ] tegrarcm_v2 --chip 0x18 0 --rcm rcm_list_signed.xml --skipuid
[ 0.0326 ] RCM version 0X180001
[ 0.0339 ] Boot Rom communication completed
[ 1.0402 ]
[ 2.0452 ] tegrarcm_v2 --isapplet
[ 2.0485 ] Applet version 01.00.0000
[ 2.0715 ]
[ 2.0758 ] Retrieving EEPROM data
[ 2.0764 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/vvdn/projects/ntdi_bag2/Code_chekout/ntdi_bag2/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/cvm.bin
[ 2.0812 ] Applet version 01.00.0000
[ 2.1034 ] Saved platform info in /home/vvdn/projects/ntdi_bag2/Code_chekout/ntdi_bag2/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/cvm.bin
[ 2.1763 ]
Board ID(3489) version(300) sku(0888) revision(H.0)
Copy /home/vvdn/projects/ntdi_bag2/Code_chekout/ntdi_bag2/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-a00-00-base.dtb to /home/vvdn/projects/ntdi_bag2/Code_chekout/ntdi_bag2/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-a00-00-base.dtb.rec
copying bctfile(/home/vvdn/projects/ntdi_bag2/Code_chekout/ntdi_bag2/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/P3310_A00_8GB_lpddr4_A02_l4t.cfg)… done.
copying misc_config(/home/vvdn/projects/ntdi_bag2/Code_chekout/ntdi_bag2/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-misc-si-l4t.cfg)… done.
copying pinmux_config(/home/vvdn/projects/ntdi_bag2/Code_chekout/ntdi_bag2/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pinmux-quill-p3310-1000-a00.cfg)… done.
copying pmic_config(/home/vvdn/projects/ntdi_bag2/Code_chekout/ntdi_bag2/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pmic-quill-p3310-1000-a00.cfg)… done.
copying pmc_config(/home/vvdn/projects/ntdi_bag2/Code_chekout/ntdi_bag2/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pad-quill-p3310-1000-a00.cfg)… done.
copying prod_config(/home/vvdn/projects/ntdi_bag2/Code_chekout/ntdi_bag2/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-prod-quill-p3310-1000-a00.cfg)… done.
copying scr_config(/home/vvdn/projects/ntdi_bag2/Code_chekout/ntdi_bag2/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/minimal_scr.cfg)… done.
copying scr_cold_boot_config(/home/vvdn/projects/ntdi_bag2/Code_chekout/ntdi_bag2/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/mobile_scr.cfg)… done.
copying bootrom_config(/home/vvdn/projects/ntdi_bag2/Code_chekout/ntdi_bag2/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-bootrom-quill-p3310-1000-a00.cfg)… done.
copying dev_params(/home/vvdn/projects/ntdi_bag2/Code_chekout/ntdi_bag2/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/emmc.cfg)… done.
Existing bootloader(/home/vvdn/projects/ntdi_bag2/Code_chekout/ntdi_bag2/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
copying initrd(/home/vvdn/projects/ntdi_bag2/Code_chekout/ntdi_bag2/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/l4t_initrd.img)… done.
populating kernel to rootfs… done.
populating initrd to rootfs… done.
populating /home/vvdn/projects/ntdi_bag2/Code_chekout/ntdi_bag2/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-a00-00-base.dtb to rootfs… done.
Making Boot image… done.
20+0 records in
20+0 records out
20 bytes copied, 0.00033127 s, 60.4 kB/s
Existing sosfile(/home/vvdn/projects/ntdi_bag2/Code_chekout/ntdi_bag2/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin) reused.
copying tegraboot(/home/vvdn/projects/ntdi_bag2/Code_chekout/ntdi_bag2/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/t186ref/nvtboot.bin)… done.
Existing cpu_bootloader(/home/vvdn/projects/ntdi_bag2/Code_chekout/ntdi_bag2/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
Existing mb2blfile(/home/vvdn/projects/ntdi_bag2/Code_chekout/ntdi_bag2/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
Existing mtspreboot(/home/vvdn/projects/ntdi_bag2/Code_chekout/ntdi_bag2/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/preboot_d15_prod_cr.bin) reused.
Existing mts(/home/vvdn/projects/ntdi_bag2/Code_chekout/ntdi_bag2/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/mce_mts_d15_prod_cr.bin) reused.
Existing mb1file(/home/vvdn/projects/ntdi_bag2/Code_chekout/ntdi_bag2/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/mb1_prod.bin) reused.
Existing bpffile(/home/vvdn/projects/ntdi_bag2/Code_chekout/ntdi_bag2/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/bpmp.bin) reused.
copying bpfdtbfile(/home/vvdn/projects/ntdi_bag2/Code_chekout/ntdi_bag2/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/t186ref/tegra186-a02-bpmp-quill-p3310-1000-a00-00-te770d-ucm2.dtb)… done.
Existing scefile(/home/vvdn/projects/ntdi_bag2/Code_chekout/ntdi_bag2/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
Existing spefile(/home/vvdn/projects/ntdi_bag2/Code_chekout/ntdi_bag2/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/spe.bin) reused.
Existing drameccfile(/home/vvdn/projects/ntdi_bag2/Code_chekout/ntdi_bag2/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/dram-ecc.bin) reused.
Existing badpagefile(/home/vvdn/projects/ntdi_bag2/Code_chekout/ntdi_bag2/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/badpage.bin) reused.
copying wb0boot(/home/vvdn/projects/ntdi_bag2/Code_chekout/ntdi_bag2/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/t186ref/warmboot.bin)… done.
Existing tosfile(/home/vvdn/projects/ntdi_bag2/Code_chekout/ntdi_bag2/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/tos-trusty.img) reused.
Existing eksfile(/home/vvdn/projects/ntdi_bag2/Code_chekout/ntdi_bag2/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/vvdn/projects/ntdi_bag2/Code_chekout/ntdi_bag2/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-a00-00-base.dtb)… done.
Copying nv_boot_control.conf to rootfs
Making system.img…
populating rootfs from /home/vvdn/projects/ntdi_bag2/Code_chekout/ntdi_bag2/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/rootfs … done.
populating /boot/extlinux/extlinux.conf … done.
Sync’ing system.img … done.
Converting RAW image to Sparse image… done.
system.img built successfully.
Existing tbcfile(/home/vvdn/projects/ntdi_bag2/Code_chekout/ntdi_bag2/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/cboot.bin) reused.
copying tbcdtbfile(/home/vvdn/projects/ntdi_bag2/Code_chekout/ntdi_bag2/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-a00-00-base.dtb)… done.
copying cfgfile(/home/vvdn/projects/ntdi_bag2/Code_chekout/ntdi_bag2/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/t186ref/cfg/flash_l4t_t186.xml) to flash.xml… done.
Existing flasher(/home/vvdn/projects/ntdi_bag2/Code_chekout/ntdi_bag2/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/nvtboot_recovery_cpu.bin) reused.
Existing flashapp(/home/vvdn/projects/ntdi_bag2/Code_chekout/ntdi_bag2/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/tegraflash.py) reused.
./tegraflash.py --bl nvtboot_recovery_cpu.bin --sdram_config P3310_A00_8GB_lpddr4_A02_l4t.cfg --odmdata 0x1090000 --applet mb1_recovery_prod.bin --cmd “flash; reboot” --cfg flash.xml --chip 0x18 --misc_config tegra186-mb1-bct-misc-si-l4t.cfg --pinmux_config tegra186-mb1-bct-pinmux-quill-p3310-1000-a00.cfg --pmic_config tegra186-mb1-bct-pmic-quill-p3310-1000-a00.cfg --pmc_config tegra186-mb1-bct-pad-quill-p3310-1000-a00.cfg --prod_config tegra186-mb1-bct-prod-quill-p3310-1000-a00.cfg --scr_config minimal_scr.cfg --scr_cold_boot_config mobile_scr.cfg --br_cmd_config tegra186-mb1-bct-bootrom-quill-p3310-1000-a00.cfg --dev_params emmc.cfg --bins “mb2_bootloader nvtboot_recovery.bin; mts_preboot preboot_d15_prod_cr.bin; mts_bootpack mce_mts_d15_prod_cr.bin; bpmp_fw bpmp.bin; bpmp_fw_dtb tegra186-a02-bpmp-quill-p3310-1000-a00-00-te770d-ucm2.dtb; tlk tos-trusty.img; eks eks.img; bootloader_dtb tegra186-quill-p3310-1000-a00-00-base.dtb”
saving flash command in /home/vvdn/projects/ntdi_bag2/Code_chekout/ntdi_bag2/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /home/vvdn/projects/ntdi_bag2/Code_chekout/ntdi_bag2/Tegra186_Linux_R32.4.3_aarch64/Linux_for_Tegra/bootloader/flash_win.bat
*** Flashing target device started. ***
version 1.0.0
[ 0.1105 ] tegrasign_v2 --key None --getmode mode.txt
[ 0.1130 ] Assuming zero filled SBK key
[ 0.2196 ]
[ 0.2197 ] Generating RCM messages
[ 0.2834 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 0 --download rcm mb1_recovery_prod.bin 0 0
[ 0.2869 ] RCM 0 is saved as rcm_0.rcm
[ 0.7865 ] RCM 1 is saved as rcm_1.rcm
[ 0.7865 ] List of rcm files are saved in rcm_list.xml
[ 0.7865 ]
[ 0.7865 ] Signing RCM messages
[ 0.7884 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.7910 ] Assuming zero filled SBK key
[ 0.8059 ]
[ 0.8060 ] Copying signature to RCM mesages
[ 0.8103 ] tegrarcm_v2 --chip 0x18 0 --updatesig rcm_list_signed.xml
[ 0.8184 ]
[ 0.8185 ] Parsing partition layout
[ 0.8753 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.9080 ]
[ 0.9081 ] Creating list of images to be signed
[ 1.1094 ] tegrahost_v2 --chip 0x18 0 --partitionlayout flash.xml.bin --list images_list.xml zerosbk
[ 2.5467 ]
[ 2.5468 ] Generating signatures
[ 2.5486 ] tegrasign_v2 --key None --list images_list.xml --pubkeyhash pub_key.key
[ 2.5502 ] Assuming zero filled SBK key
[ 3.2145 ]
[ 3.2146 ] Generating br-bct
[ 3.2596 ] Updating dev and MSS params in BR BCT
[ 3.2598 ] tegrabct_v2 --dev_param emmc.cfg --sdram P3310_A00_8GB_lpddr4_A02_l4t.cfg --brbct br_bct.cfg --chip 0x18 0
[ 3.4125 ]
[ 3.4126 ] Updating bl info
[ 3.4145 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 3.4182 ]
[ 3.4182 ] Updating smd info
[ 3.4199 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --updatesmdinfo flash.xml.bin
[ 3.4221 ]
[ 3.4222 ] Updating Odmdata
[ 3.4244 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --updatefields Odmdata =0x1090000
[ 3.4277 ]
[ 3.4278 ] Get Signed section of bct
[ 3.4302 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --listbct bct_list.xml
[ 3.4333 ]
[ 3.4351 ] tegrasign_v2 --key None --list bct_list.xml --pubkeyhash pub_key.key
[ 3.4367 ] Assuming zero filled SBK key
[ 3.4372 ]
[ 3.4372 ] Updating BCT with signature
[ 3.4389 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --updatesig bct_list_signed.xml
[ 3.4415 ]
[ 3.4415 ] Generating coldboot mb1-bct
[ 3.4441 ] tegrabct_v2 --chip 0x18 0 --mb1bct mb1_cold_boot_bct.cfg --sdram P3310_A00_8GB_lpddr4_A02_l4t.cfg --misc tegra186-mb1-bct-misc-si-l4t.cfg --scr mobile_scr.cfg --pinmux tegra186-mb1-bct-pinmux-quill-p3310-1000-a00.cfg --pmc tegra186-mb1-bct-pad-quill-p3310-1000-a00.cfg --pmic tegra186-mb1-bct-pmic-quill-p3310-1000-a00.cfg --brcommand tegra186-mb1-bct-bootrom-quill-p3310-1000-a00.cfg --prod tegra186-mb1-bct-prod-quill-p3310-1000-a00.cfg
[ 3.4481 ] MB1-BCT version: 0xf
[ 3.4490 ] Packing sdram param for instance[0]
[ 3.4994 ] Packing sdram param for instance[1]
[ 3.5000 ] Packing sdram param for instance[2]
[ 3.5006 ] Packing sdram param for instance[3]
[ 3.5110 ] Parsing config file :tegra186-mb1-bct-pinmux-quill-p3310-1000-a00.cfg
[ 3.5126 ] Appending platform config data of size :- 2952
[ 3.5231 ] Parsing config file :mobile_scr.cfg
[ 3.5241 ] Appending platform config data of size :- 12240
[ 3.5559 ] Parsing config file :tegra186-mb1-bct-pad-quill-p3310-1000-a00.cfg
[ 3.5567 ] Appending platform config data of size :- 24
[ 3.5573 ]
[ 3.5573 ] Parsing config file :tegra186-mb1-bct-pmic-quill-p3310-1000-a00.cfg
[ 3.5574 ] Appending platform config data of size :- 468
[ 3.5574 ]
[ 3.5574 ] Parsing config file :tegra186-mb1-bct-bootrom-quill-p3310-1000-a00.cfg
[ 3.5575 ] Appending platform config data of size :- 64
[ 3.5575 ]
[ 3.5575 ] Parsing config file :tegra186-mb1-bct-prod-quill-p3310-1000-a00.cfg
[ 3.5575 ] Appending platform config data of size :- 1628
[ 3.5575 ]
[ 3.5576 ] Updating mb1-bct with firmware information
[ 3.5598 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 3.5616 ] MB1-BCT version: 0xf
[ 3.5624 ]
[ 3.5624 ] Updating mb1-bct with storage information
[ 3.5644 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 3.5666 ] MB1-BCT version: 0xf
[ 3.5675 ]
[ 3.5720 ] tegrahost_v2 --chip 0x18 --align mb1_cold_boot_bct_MB1.bct
[ 3.5748 ]
[ 3.5776 ] tegrahost_v2 --appendsigheader mb1_cold_boot_bct_MB1.bct zerosbk
[ 3.5822 ]
[ 3.5850 ] tegrasign_v2 --key None --list mb1_cold_boot_bct_MB1_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 3.5867 ] Assuming zero filled SBK key
[ 3.5904 ]
[ 3.5939 ] tegrahost_v2 --updatesigheader mb1_cold_boot_bct_MB1_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_sigheader.bct.hash zerosbk
[ 3.5965 ]
[ 3.5966 ] Generating recovery mb1-bct
[ 3.5986 ] tegrabct_v2 --chip 0x18 0 --mb1bct mb1_bct.cfg --sdram P3310_A00_8GB_lpddr4_A02_l4t.cfg --misc tegra186-mb1-bct-misc-si-l4t.cfg --scr minimal_scr.cfg --pinmux tegra186-mb1-bct-pinmux-quill-p3310-1000-a00.cfg --pmc tegra186-mb1-bct-pad-quill-p3310-1000-a00.cfg --pmic tegra186-mb1-bct-pmic-quill-p3310-1000-a00.cfg --brcommand tegra186-mb1-bct-bootrom-quill-p3310-1000-a00.cfg --prod tegra186-mb1-bct-prod-quill-p3310-1000-a00.cfg
[ 3.6007 ] MB1-BCT version: 0xf
[ 3.6013 ] Packing sdram param for instance[0]
[ 3.6505 ] Packing sdram param for instance[1]
[ 3.6512 ] Packing sdram param for instance[2]
[ 3.6518 ] Packing sdram param for instance[3]
[ 3.6523 ] Parsing config file :tegra186-mb1-bct-pinmux-quill-p3310-1000-a00.cfg
[ 3.6534 ] Appending platform config data of size :- 2952
[ 3.6541 ] Parsing config file :minimal_scr.cfg
[ 3.6547 ] Appending platform config data of size :- 12240
[ 3.6827 ]
[ 3.6828 ] Parsing config file :tegra186-mb1-bct-pad-quill-p3310-1000-a00.cfg
[ 3.6828 ] Appending platform config data of size :- 24
[ 3.6828 ]
[ 3.6828 ] Parsing config file :tegra186-mb1-bct-pmic-quill-p3310-1000-a00.cfg
[ 3.6828 ] Appending platform config data of size :- 468
[ 3.6828 ]
[ 3.6828 ] Parsing config file :tegra186-mb1-bct-bootrom-quill-p3310-1000-a00.cfg
[ 3.6828 ] Appending platform config data of size :- 64
[ 3.6829 ]
[ 3.6829 ] Parsing config file :tegra186-mb1-bct-prod-quill-p3310-1000-a00.cfg
[ 3.6829 ] Appending platform config data of size :- 1628
[ 3.6829 ]
[ 3.6830 ] Updating mb1-bct with firmware information
[ 3.6854 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 3.6878 ] MB1-BCT version: 0xf
[ 3.6889 ]
[ 3.6890 ] Updating mb1-bct with storage information
[ 3.6916 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 3.6937 ] MB1-BCT version: 0xf
[ 3.6946 ]
[ 3.6966 ] tegrahost_v2 --chip 0x18 --align mb1_bct_MB1.bct
[ 3.6990 ]
[ 3.7014 ] tegrahost_v2 --appendsigheader mb1_bct_MB1.bct zerosbk
[ 3.7037 ]
[ 3.7061 ] tegrasign_v2 --key None --list mb1_bct_MB1_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 3.7083 ] Assuming zero filled SBK key
[ 3.7127 ]
[ 3.7165 ] tegrahost_v2 --updatesigheader mb1_bct_MB1_sigheader.bct.encrypt mb1_bct_MB1_sigheader.bct.hash zerosbk
[ 3.7188 ]
[ 3.7189 ] Copying signatures
[ 3.7208 ] tegrahost_v2 --chip 0x18 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 3.7743 ]
[ 3.7745 ] Boot Rom communication
[ 3.7767 ] tegrarcm_v2 --chip 0x18 0 --rcm rcm_list_signed.xml
[ 3.7788 ] BootRom is not running
[ 8.8106 ]
[ 9.8143 ] tegrarcm_v2 --isapplet
[ 9.8172 ] Applet version 01.00.0000
[ 9.8323 ]
[ 9.8324 ] Sending BCTs
[ 9.8363 ] tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 9.8395 ] Applet version 01.00.0000
[ 9.8733 ] Sending bct_bootrom
[ 9.8740 ] […] 100%
[ 9.8773 ] Sending bct_mb1
[ 9.8786 ] […] 100%
[ 9.8869 ]
Error: Return value 8
Command tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
Failed flashing t186ref.
Please suggest how to proceed further on this.
