We are currently facing an issue while flashing a custom Jetpack image into the Jetson Tx2 Soc. When we are running the flash.sh script after putting the TX2 in recovery mode, The script gets halted in the command
12:50:23 INFO: Flash Jetson TX2 - flash: [ 11.1350 ] tegrarcm_v2 --boot recovery
12:50:23 INFO: Flash Jetson TX2 - flash: [ 11.1365 ] Applet version 01.00.0000
and then it gets timed out .
We tried flashing the base Jetpack Image using the Nvidia SDK manager also, but the issue remains the same. I am attaching the logs of flash script. Can you please let us know what could be the root cause of this issue?
The complete logs of SDK manager is attached below:
12:49:51 INFO: Start to check if only one device connected...
12:49:51 DEBUG: running command < true >
12:49:51 INFO: command finished successfully
12:49:51 DEBUG: running command < [ lsusb | grep -c "0955:"
-ne 1 ] >
12:49:51 DEBUG: command terminated with error
12:49:51 INFO: Only one NVIDIA device detected, as expected.
12:49:51 INFO: Start to check if in device recovery mode…
12:49:51 DEBUG: running command < lsusb | grep 0955:7020 >
12:49:51 INFO: Jetson device is in recovery mode.
12:49:51 INFO: Start to check if the right device connected…
12:49:51 DEBUG: running command < lsusb | grep -E ‘0955:7c18’ >
12:49:51 INFO: Bus 003 Device 003: ID 0955:7c18 NVidia Corp.
12:49:51 INFO: Verified, 0955:7c18 detected in recovery mode.
12:49:52 INFO: command finished successfully
12:49:52 DEBUG: Device Mode Host Setup in Flash - flash: using adapter to install NV_DEVICE_MODE_SETUP_IMAGE_COMP@JETSON_TX2 to /home/gor/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX2
12:49:52 INFO: Device Mode Host Setup in Flash - flash: Installing component ‘Device Mode Host Setup in Flash’ (NV_DEVICE_MODE_SETUP_IMAGE_COMP)
12:49:52 INFO: Device Mode Host Setup in Flash - flash: exec_command: /tmp/tmp_NV_DEVICE_MODE_SETUP_IMAGE_COMP.sh
12:49:52 INFO: Device Mode Host Setup in Flash - flash: [host] [sudo] password for gor:
12:49:52 INFO: Device Mode Host Setup in Flash - flash: net.ipv4.ip_forward = 1
12:49:52 INFO: Device Mode Host Setup in Flash - flash: Device mode on host successfuly set with DNS 8.8.8.8!
12:49:52 INFO: Device Mode Host Setup in Flash - flash: command finished successfully
12:49:52 SUMMARY: Device Mode Host Setup in Flash - flash: Install completed successfully.
12:49:52 DEBUG: running command < true >
12:49:52 DEBUG: Flash Jetson TX2 - flash: using adapter to install NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP@JETSON_TX2 to /home/gor/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX2
12:49:52 INFO: Flash Jetson TX2 - flash: [host] [ Disk Avail:388.98 GB ]
12:49:52 INFO: Flash Jetson TX2 - flash: exec_command: /tmp/tmp_NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP.sh
12:49:52 INFO: Flash Jetson TX2 - flash: sudo ./nvautoflash.sh --no-systemimg
12:49:52 INFO: Flash Jetson TX2 - flash: *** Checking ONLINE mode … OK.
12:49:52 INFO: Flash Jetson TX2 - flash: *** Checking target board connection … 1 connections found.
12:49:52 INFO: Flash Jetson TX2 - flash: *** Finding configuration … jetson-tx2-devkit found.
12:49:52 INFO: Flash Jetson TX2 - flash: /home/gor/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX2/Linux_for_Tegra/flash.sh --no-systemimg jetson-tx2-devkit mmcblk0p1
12:49:53 INFO: Flash Jetson TX2 - flash: # L4T BSP Information:
12:49:53 INFO: Flash Jetson TX2 - flash: ###############################################################################
12:49:53 INFO: Flash Jetson TX2 - flash: ./tegraflash.py --chip 0x18 --applet “/home/gor/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin” --skipuid --cmd “dump eeprom boardinfo cvm.bin”
12:49:53 INFO: Flash Jetson TX2 - flash: [ 0.0538 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 0 --download rcm /home/gor/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin 0 0
12:49:53 INFO: Flash Jetson TX2 - flash: [ 0.0838 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
12:49:53 INFO: Flash Jetson TX2 - flash: [ 0.1283 ] tegrarcm_v2 --chip 0x18 0 --updatesig rcm_list_signed.xml
12:49:53 INFO: Flash Jetson TX2 - flash: [ 0.1353 ] RCM version 0X180001
12:49:55 INFO: Flash Jetson TX2 - flash: [ 2.1505 ] tegrarcm_v2 --isapplet
12:49:55 INFO: Flash Jetson TX2 - flash: [ 2.1740 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/gor/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/cvm.bin
12:49:55 INFO: Flash Jetson TX2 - flash: [ 2.2675 ]
12:49:55 ERROR: Flash Jetson TX2 - flash: Board ID(3310) version(D00) sku(1000) revision(M.0)
12:49:55 INFO: Flash Jetson TX2 - flash: Copy /home/gor/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX2/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb to /home/gor/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX2/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb.rec
12:49:55 INFO: Flash Jetson TX2 - flash: copying bctfile(/home/gor/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/P3310_A00_8GB_lpddr4_A02_l4t.cfg)… done.
12:49:55 INFO: Flash Jetson TX2 - flash: copying misc_config(/home/gor/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-misc-si-l4t.cfg)… done.
12:49:55 INFO: Flash Jetson TX2 - flash: copying pinmux_config(/home/gor/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg)… done.
12:49:55 INFO: Flash Jetson TX2 - flash: copying prod_config(/home/gor/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg)… done.
12:49:55 INFO: Flash Jetson TX2 - flash: copying scr_cold_boot_config(/home/gor/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/mobile_scr.cfg)… done.
12:49:55 INFO: Flash Jetson TX2 - flash: copying bootrom_config(/home/gor/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg)… done.
12:49:55 INFO: Flash Jetson TX2 - flash: copying dev_params(/home/gor/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/emmc.cfg)… done.
12:49:56 INFO: Flash Jetson TX2 - flash: Existing bootloader(/home/gor/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
12:49:56 INFO: Flash Jetson TX2 - flash: copying initrd(/home/gor/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/l4t_initrd.img)… done.
12:49:57 INFO: Flash Jetson TX2 - flash: populating kernel to rootfs… done.
12:49:57 INFO: Flash Jetson TX2 - flash: populating initrd to rootfs… done.
12:49:57 INFO: Flash Jetson TX2 - flash: populating /home/gor/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX2/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb to rootfs… done.
12:49:57 INFO: Flash Jetson TX2 - flash: Making Boot image… done.
12:49:57 INFO: Flash Jetson TX2 - flash: /home/gor/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x18 --key --cmd sign boot.img
12:49:57 INFO: Flash Jetson TX2 - flash: [ 0.0029 ] tegrasign_v2 --key --getmode mode.txt
12:49:58 INFO: Flash Jetson TX2 - flash: [ 0.1101 ] Signed file: /home/gor/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/temp_user_dir/boot_sigheader.img.encrypt
12:49:58 INFO: Flash Jetson TX2 - flash: l4t_sign_image.sh: Generate 16-byte-size-aligned base file for boot_sigheader.img.encrypt
12:49:58 INFO: Flash Jetson TX2 - flash: done.
12:49:58 INFO: Flash Jetson TX2 - flash: Re-generating recovery ramdisk for recovery image…
12:49:58 INFO: Flash Jetson TX2 - flash: ~/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/ramdisk_tmp ~/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader ~/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX2/Linux_for_Tegra
12:49:58 ERROR: Flash Jetson TX2 - flash: 30402 blocks
12:49:59 INFO: Flash Jetson TX2 - flash: _BASE_KERNEL_VERSION=4.9.201-tegra
12:50:01 INFO: Flash Jetson TX2 - flash: ~/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/ramdisk_tmp/lib ~/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/ramdisk_tmp ~/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader ~/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX2/Linux_for_Tegra
12:50:09 ERROR: Flash Jetson TX2 - flash: 65752 blocks
12:50:10 INFO: Flash Jetson TX2 - flash: Making Recovery image…
12:50:11 INFO: Flash Jetson TX2 - flash: copying recdtbfile(/home/gor/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX2/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb.rec)… done.
12:50:11 INFO: Flash Jetson TX2 - flash: 20 bytes copied, 0.000443267 s, 45.1 kB/s
12:50:11 INFO: Flash Jetson TX2 - flash: Existing sosfile(/home/gor/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin) reused.
12:50:11 INFO: Flash Jetson TX2 - flash: Existing mtspreboot(/home/gor/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/preboot_d15_prod_cr.bin) reused.
12:50:11 INFO: Flash Jetson TX2 - flash: Existing bpffile(/home/gor/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/bpmp.bin) reused.
12:50:11 INFO: Flash Jetson TX2 - flash: copying bpfdtbfile(/home/gor/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/t186ref/tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb)… done.
12:50:11 INFO: Flash Jetson TX2 - flash: copying wb0boot(/home/gor/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/t186ref/warmboot.bin)… done.
12:50:11 INFO: Flash Jetson TX2 - flash: Copying nv_boot_control.conf to rootfs
12:50:11 INFO: Flash Jetson TX2 - flash: /home/gor/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x18 --key --cmd sign kernel_tegra186-quill-p3310-1000-c03-00-base.dtb
12:50:12 INFO: Flash Jetson TX2 - flash: [ 0.0020 ] tegrasign_v2 --key --getmode mode.txt
12:50:12 INFO: Flash Jetson TX2 - flash: [ 0.0107 ] tegrahost_v2 --appendsigheader 1_kernel_tegra186-quill-p3310-1000-c03-00-base.dtb zerosbk
12:50:12 INFO: Flash Jetson TX2 - flash: [ 0.0480 ] tegrahost_v2 --updatesigheader 1_kernel_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt 1_kernel_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.hash zerosbk
12:50:12 INFO: Flash Jetson TX2 - flash: [ 0.0520 ] Signed file: /home/gor/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/temp_user_dir/kernel_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt
12:50:12 INFO: Flash Jetson TX2 - flash: copying tbcdtbfile(/home/gor/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX2/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb)… done.
12:50:12 INFO: Flash Jetson TX2 - flash: *** Flashing target device started. ***
12:50:12 INFO: Flash Jetson TX2 - flash: [ 0.0015 ] tegrasign_v2 --key None --getmode mode.txt
12:50:12 INFO: Flash Jetson TX2 - flash: [ 0.0089 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
12:50:12 INFO: Flash Jetson TX2 - flash: [ 0.0569 ] tegraparser_v2 --pt flash.xml.tmp
12:50:12 INFO: Flash Jetson TX2 - flash: [ 0.0679 ] tegrahost_v2 --chip 0x18 0 --partitionlayout flash.xml.bin --list images_list.xml zerosbk
12:50:12 INFO: Flash Jetson TX2 - flash: [ 0.2535 ] Assuming zero filled SBK key
12:50:15 INFO: Flash Jetson TX2 - flash: [ 2.9395 ] tegrabct_v2 --dev_param emmc.cfg --sdram P3310_A00_8GB_lpddr4_A02_l4t.cfg --brbct br_bct.cfg --chip 0x18 0
12:50:15 INFO: Flash Jetson TX2 - flash: [ 3.0676 ] MB1-BCT version: 0xf
12:50:15 INFO: Flash Jetson TX2 - flash: [ 3.1462 ] MB1-BCT version: 0xf
12:50:15 INFO: Flash Jetson TX2 - flash: [ 3.1468 ] Packing sdram param for instance[0]
12:50:15 INFO: Flash Jetson TX2 - flash: [ 3.2323 ] tegrahost_v2 --updatesigheader mb1_bct_MB1_sigheader.bct.encrypt mb1_bct_MB1_sigheader.bct.hash zerosbk
12:50:16 INFO: Flash Jetson TX2 - flash: [ 3.2372 ] tegrahost_v2 --chip 0x18 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
12:50:21 INFO: Flash Jetson TX2 - flash: [ 4.0827 ] tegrarcm_v2 --chip 0x18 0 --rcm rcm_list_signed.xml
12:50:22 INFO: Flash Jetson TX2 - flash: [ 10.1213 ] tegrarcm_v2 --isapplet
12:50:22 INFO: Flash Jetson TX2 - flash: [ 10.1858 ] […] 100%
12:50:22 INFO: Flash Jetson TX2 - flash: [ 10.2037 ] tegrahost_v2 --chip 0x18 --align blob_nvtboot_recovery_cpu.bin
12:50:22 INFO: Flash Jetson TX2 - flash: [ 10.2627 ] tegrahost_v2 --chip 0x18 --align blob_preboot_d15_prod_cr.bin
12:50:22 INFO: Flash Jetson TX2 - flash: [ 10.2856 ] tegrahost_v2 --chip 0x18 --align blob_mce_mts_d15_prod_cr.bin
12:50:22 INFO: Flash Jetson TX2 - flash: [ 10.3042 ] Assuming zero filled SBK key
12:50:22 INFO: Flash Jetson TX2 - flash: [ 10.4137 ] tegrahost_v2 --updatesigheader blob_mce_mts_d15_prod_cr_sigheader.bin.encrypt blob_mce_mts_d15_prod_cr_sigheader.bin.hash zerosbk
12:50:22 INFO: Flash Jetson TX2 - flash: [ 10.4218 ] tegrahost_v2 --chip 0x18 --align blob_bpmp.bin
12:50:22 INFO: Flash Jetson TX2 - flash: [ 10.4331 ] Assuming zero filled SBK key
12:50:22 INFO: Flash Jetson TX2 - flash: [ 10.4771 ] Assuming zero filled SBK key
12:50:22 INFO: Flash Jetson TX2 - flash: [ 10.5203 ] Assuming zero filled SBK key
12:50:22 INFO: Flash Jetson TX2 - flash: [ 10.5438 ] tegrahost_v2 --updatesigheader blob_tos-trusty_sigheader.img.encrypt blob_tos-trusty_sigheader.img.hash zerosbk
12:50:23 INFO: Flash Jetson TX2 - flash: [ 10.6105 ] tegrahost_v2 --updatesigheader blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.hash zerosbk
12:50:23 INFO: Flash Jetson TX2 - flash: [ 10.6290 ] Added binary blob_mce_mts_d15_prod_cr_sigheader.bin.encrypt of size 2082144
12:50:23 INFO: Flash Jetson TX2 - flash: [ 10.6557 ] Sending blob
