Trying to install Jetpack 4.4 on the Tx2. The flash OS task fails at 0%. Can somebody direct me to which logs should I check and debug this issue?
Flash Jetson TX2: Failed to execute commands with GenericInstaller
- 10:23:50 INFO: null
- 10:23:55 INFO: Automatic trying to flash the target device with Manual Flash option…
- 10:23:56 INFO: CUDA Toolkit for L4T: start to download h.ttps://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.4-ga/JETPACK_44_b186/cuda-repo-l4t-10-2-local-10.2.89_1.0-1_arm64.deb to /home/sakethk98/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-10-2-local-10.2.89_1.0-1_arm64.deb
- 10:23:56 INFO: OpenCV on Target: start to download h.ttps://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.4-ga/JETPACK_44_b186/OpenCV-4.1.1-2-gd5a58aa75-aarch64-libs.deb to /home/sakethk98/Downloads/nvidia/sdkm_downloads/OpenCV-4.1.1-2-gd5a58aa75-aarch64-libs.deb
- 10:23:56 INFO: OpenCV on Target: start to download h.ttps://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.4-ga/JETPACK_44_b186/OpenCV-4.1.1-2-gd5a58aa75-aarch64-dev.deb to /home/sakethk98/Downloads/nvidia/sdkm_downloads/OpenCV-4.1.1-2-gd5a58aa75-aarch64-dev.deb
- 10:23:56 INFO: OpenCV on Target: start to download h.ttps://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.4-ga/JETPACK_44_b186/OpenCV-4.1.1-2-gd5a58aa75-aarch64-licenses.deb to /home/sakethk98/Downloads/nvidia/sdkm_downloads/OpenCV-4.1.1-2-gd5a58aa75-aarch64-licenses.deb
- 10:23:56 INFO: OpenCV on Target: start to download h.ttps://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.4-ga/JETPACK_44_b186/OpenCV-4.1.1-2-gd5a58aa75-aarch64-python.deb to /home/sakethk98/Downloads/nvidia/sdkm_downloads/OpenCV-4.1.1-2-gd5a58aa75-aarch64-python.deb
- 10:23:56 INFO: OpenCV on Target: start to download h.ttps://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.4-ga/JETPACK_44_b186/OpenCV-4.1.1-2-gd5a58aa75-aarch64-samples.deb to /home/sakethk98/Downloads/nvidia/sdkm_downloads/OpenCV-4.1.1-2-gd5a58aa75-aarch64-samples.deb
- 10:23:56 INFO: Only one NVIDIA device detected, as expected.
- 10:23:56 INFO: Jetson device is in recovery mode.
- 10:23:56 INFO: Bus 001 Device 009: ID 0955:7c18 NVidia Corp.
- 10:23:56 INFO: command finished successfully
- 10:23:56 INFO: Verified, 0955:7c18 detected in recovery mode.
- 10:23:56 INFO: Device Mode Host Setup in Flash: [ Disk Avail:166.31 GB ]
- 10:23:56 INFO: Device Mode Host Setup in Flash: Using GenericInstaller to Install NV_DEVICE_MODE_SETUP_IMAGE_COMP
- 10:23:56 INFO: Device Mode Host Setup in Flash: change working directory to /home/sakethk98/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_TX2
- 10:23:56 INFO: Device Mode Host Setup in Flash: [ Component Install Started ]
- 10:23:56 INFO: Device Mode Host Setup in Flash: current working directory is /home/sakethk98/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_TX2
- 10:23:56 INFO: Device Mode Host Setup in Flash: exec_command [host]:
- 10:23:56 INFO: Device Mode Host Setup in Flash: **********************
- 10:23:56 INFO: Device Mode Host Setup in Flash: #!/bin/bash
- 10:23:56 INFO: Device Mode Host Setup in Flash: set -e
- 10:23:56 INFO: Device Mode Host Setup in Flash: set +e
- 10:23:56 INFO: Device Mode Host Setup in Flash: eth_port_name=$(ip route show default | awk ‘/default via/ {print $5; exit}’)
- 10:23:56 INFO: Device Mode Host Setup in Flash: if [[ $eth_port_name == ‘’ ]]; then
- 10:23:56 INFO: Device Mode Host Setup in Flash: echo ‘Can not found route default $eth_port_name, device mode setup failed!’
- 10:23:56 INFO: Device Mode Host Setup in Flash: exit 0
- 10:23:56 INFO: Device Mode Host Setup in Flash: fi
- 10:23:56 INFO: Device Mode Host Setup in Flash: echo ‘Found route default’ $eth_port_name’, setting up device mode’
- 10:23:56 INFO: Device Mode Host Setup in Flash: setup_t=‘192.168.55.0/24’
- 10:23:56 INFO: Device Mode Host Setup in Flash: sudo iptables -t nat -A POSTROUTING -s $setup_t -o $eth_port_name -j MASQUERADE
- 10:23:56 INFO: Device Mode Host Setup in Flash: sudo iptables -A FORWARD -s $setup_t -o $eth_port_name -j ACCEPT
- 10:23:56 INFO: Device Mode Host Setup in Flash: sudo iptables -A FORWARD -d $setup_t -m state --state ESTABLISHED,RELATED -i $eth_port_name -j ACCEPT
- 10:23:56 INFO: Device Mode Host Setup in Flash: sudo sysctl -w net.ipv4.ip_forward=1
- 10:23:56 INFO: Device Mode Host Setup in Flash: check_google_dns=$(dig @8.8.8.8 nvidia.com || true)
- 10:23:56 INFO: Device Mode Host Setup in Flash: if [[ $check_google_dns == ‘Got answer’ ]]; then
- 10:23:56 INFO: Device Mode Host Setup in Flash: echo ‘Device mode on host successfuly set with DNS 8.8.8.8!’
- 10:23:56 INFO: Device Mode Host Setup in Flash: else
- 10:23:56 INFO: Device Mode Host Setup in Flash: echo ‘Default google DNS is not working, trying to find a valid server in local host settings!’
- 10:23:56 INFO: Device Mode Host Setup in Flash: dns_list=$(nmcli -t device show $eth_port_name | grep ‘DNS’ | grep -o ‘[^:]*$’)
- 10:23:56 INFO: Device Mode Host Setup in Flash: for dns in $dns_list; do
- 10:23:56 INFO: Device Mode Host Setup in Flash: check_dns=$(dig @$dns nvidia.com || true)
- 10:23:56 INFO: Device Mode Host Setup in Flash: if [[ $check_dns == ‘Got answer’ ]]; then
- 10:23:56 INFO: Device Mode Host Setup in Flash: sudo iptables -t nat -A PREROUTING -p tcp -d 8.8.8.8 --dport 53 -j DNAT --to-destination $dns
- 10:23:56 INFO: Device Mode Host Setup in Flash: sudo iptables -t nat -A PREROUTING -p udp -d 8.8.8.8 --dport 53 -j DNAT --to-destination $dns
- 10:23:56 INFO: Device Mode Host Setup in Flash: echo ‘Device mode on host successfuly set with DNS’ $dns’!’
- 10:23:56 INFO: Device Mode Host Setup in Flash: done
- 10:23:56 INFO: Device Mode Host Setup in Flash: echo ‘Can not found a valid DNS server, device mode setup failed!’
- 10:23:56 INFO: Device Mode Host Setup in Flash: echo ‘If needed to use device mode, please change the target default dns to a valid server by following the steps in release note.’
- 10:23:56 INFO: Device Mode Host Setup in Flash: exec_command: /tmp/tmp_NV_DEVICE_MODE_SETUP_IMAGE_COMP.sh
- 10:23:56 INFO: Device Mode Host Setup in Flash: Found route default wlp3s0, setting up device mode
- 10:23:56 INFO: Device Mode Host Setup in Flash: [host] [sudo] password for sakethk98:
- 10:23:56 INFO: Device Mode Host Setup in Flash: net.ipv4.ip_forward = 1
- 10:23:56 INFO: Device Mode Host Setup in Flash: Device mode on host successfuly set with DNS 8.8.8.8!
- 10:23:56 INFO: Device Mode Host Setup in Flash: [ Component Install Finished Successfully ]
- 10:23:56 INFO: Device Mode Host Setup in Flash: [ 8.00 KB released. Disk Avail: 166.31 GB ]
- 10:23:56 INFO: Device Mode Host Setup in Flash: [ NV_DEVICE_MODE_SETUP_IMAGE_COMP Install took 0s ]
- 10:23:56 INFO: Device Mode Host Setup in Flash: command finished successfully
- 10:23:56 INFO: Flash Jetson TX2: [ Disk Avail:166.31 GB ]
- 10:23:56 INFO: Flash Jetson TX2: Using GenericInstaller to Install NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP
- 10:23:56 INFO: Flash Jetson TX2: change working directory to /home/sakethk98/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_TX2/Linux_for_Tegra
- 10:23:56 INFO: Flash Jetson TX2: [ Component Install Started ]
- 10:23:56 INFO: Flash Jetson TX2: current working directory is /home/sakethk98/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_TX2/Linux_for_Tegra
- 10:23:56 INFO: Flash Jetson TX2: exec_command [host]:
- 10:23:56 INFO: Flash Jetson TX2: **********************
- 10:23:56 INFO: Flash Jetson TX2: #!/bin/bash
- 10:23:56 INFO: Flash Jetson TX2: set -e
- 10:23:56 INFO: Flash Jetson TX2: if [ -e ./bootloader/system.img ]; then
- 10:23:56 INFO: Flash Jetson TX2: echo sudo ./flash.sh --no-systemimg jetson-tx2 mmcblk0p1
- 10:23:56 INFO: Flash Jetson TX2: sudo ./flash.sh --no-systemimg jetson-tx2 mmcblk0p1
- 10:23:56 INFO: Flash Jetson TX2: else
- 10:23:56 INFO: Flash Jetson TX2: echo sudo ./flash.sh jetson-tx2 mmcblk0p1
- 10:23:56 INFO: Flash Jetson TX2: sudo ./flash.sh jetson-tx2 mmcblk0p1
- 10:23:56 INFO: Flash Jetson TX2: fi
- 10:23:56 INFO: Flash Jetson TX2: sleep 20
- 10:23:56 INFO: Flash Jetson TX2: exec_command: /tmp/tmp_NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP.sh
- 10:23:56 INFO: Flash Jetson TX2: [ Component Install Finished with Error ]
- 10:23:56 INFO: Flash Jetson TX2: [ 8.00 KB used. Disk Avail: 166.31 GB ]
- 10:23:56 INFO: Flash Jetson TX2: [ NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP Install took 0s ]
- 10:24:27 INFO: OpenCV on Target: stopped downloading h.ttps://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.4-ga/JETPACK_44_b186/OpenCV-4.1.1-2-gd5a58aa75-aarch64-libs.deb
- 10:24:27 INFO: CUDA Toolkit for L4T: stopped downloading h.ttps://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.4-ga/JETPACK_44_b186/cuda-repo-l4t-10-2-local-10.2.89_1.0-1_arm64.deb
- 10:24:32 INFO: OpenCV on Target: stopped downloading h.ttps://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.4-ga/JETPACK_44_b186/OpenCV-4.1.1-2-gd5a58aa75-aarch64-dev.deb
- 10:24:32 INFO: OpenCV on Target: stopped downloading h.ttps://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.4-ga/JETPACK_44_b186/OpenCV-4.1.1-2-gd5a58aa75-aarch64-licenses.deb
- 10:24:37 INFO: OpenCV on Target: stopped downloading h.ttps://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.4-ga/JETPACK_44_b186/OpenCV-4.1.1-2-gd5a58aa75-aarch64-python.deb
- 10:24:37 INFO: OpenCV on Target: stopped downloading h.ttps://developer.nvidia.com/assets/embedded/secure/tools/files/jetpack-sdks/jetpack-4.4-ga/JETPACK_44_b186/OpenCV-4.1.1-2-gd5a58aa75-aarch64-samples.deb
*added ‘.’ in https cause new users can’t post links
