Here is the terminal display after another attempt
11:12:23 INFO: File System and OS - target_image: command finished successfully
11:12:24 SUMMARY: File System and OS - target_image: Install completed successfully.
11:12:24 INFO: Start to check if only one device connected…
11:12:24 DEBUG: running command < true >
11:12:24 INFO: command finished successfully
11:12:24 DEBUG: running command < [ lsusb | grep -c "0955:" -ne 1 ] >
11:12:24 DEBUG: command terminated with error
11:12:24 INFO: Only one NVIDIA device detected, as expected.
11:12:24 INFO: Start to check if in device recovery mode…
11:12:24 DEBUG: running command < lsusb | grep 0955:7020 >
11:12:24 INFO: Jetson device is in recovery mode.
11:12:24 INFO: Start to check if the right device connected…
11:12:24 DEBUG: running command < lsusb | grep -E ‘0955:7c18’ >
11:12:25 INFO: Bus 001 Device 008: ID 0955:7c18 NVidia Corp.
11:12:25 INFO: command finished successfully
11:12:25 INFO: Verified, 0955:7c18 detected in recovery mode.
11:12:25 DEBUG: running command < true >
11:12:25 DEBUG: Device Mode Host Setup in Flash - flash: using adapter to install NV_DEVICE_MODE_SETUP_IMAGE_COMP@JETSON_TX2 to /home/srinath/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_TX2
11:12:27 INFO: Device Mode Host Setup in Flash - flash: Installing component ‘Device Mode Host Setup in Flash’ (NV_DEVICE_MODE_SETUP_IMAGE_COMP)
11:12:27 INFO: Device Mode Host Setup in Flash - flash: exec_command: /tmp/tmp_NV_DEVICE_MODE_SETUP_IMAGE_COMP.sh
11:12:27 INFO: Device Mode Host Setup in Flash - flash: Found route default wlp1s0, setting up device mode
11:12:27 INFO: Device Mode Host Setup in Flash - flash: net.ipv4.ip_forward = 1
11:12:28 INFO: Device Mode Host Setup in Flash - flash: Device mode on host successfuly set with DNS 8.8.8.8!
11:12:28 INFO: Device Mode Host Setup in Flash - flash: command finished successfully
11:12:28 SUMMARY: Device Mode Host Setup in Flash - flash: Install completed successfully.
11:12:28 DEBUG: running command < true >
11:12:28 INFO: command finished successfully
11:12:28 DEBUG: Flash Jetson TX2 - flash: using adapter to install NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP@JETSON_TX2 to /home/srinath/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_TX2
11:12:28 INFO: Flash Jetson TX2 - flash: exec_command: /tmp/tmp_NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP.sh
11:12:28 INFO: Flash Jetson TX2 - flash: sudo ./flash.sh jetson-tx2 mmcblk0p1
11:12:28 INFO: Flash Jetson TX2 - flash: # L4T BSP Information:
11:12:28 INFO: Flash Jetson TX2 - flash: ###############################################################################
11:12:34 INFO: Flash Jetson TX2 - flash: USB port and is in recovery mode.
11:12:34 INFO: Flash Jetson TX2 - flash: [ Component Install Finished with Error ]
11:12:34 ERROR: Flash Jetson TX2 - flash: command terminated with error
11:12:35 SUMMARY: VPI on Target - target: Depends on failed component
Error log remains the same
