When I try to use SDK Manager 1.4.0.7363 on an Ubuntu 16.04 physical (not virtual) machine to flash a Tx2, the process hangs at this line:
12:18:17 INFO: Flash Jetson TX2: [ 4.3160 ] tegradevflash_v2 --iscpubl
12:20:17 INFO: Flash Jetson TX2: [ 4.3174 ] C
Attached are the complete logs from the SDK Manager Export Logs buttonSDKM_logs_2021-01-06_12-35-16.zip (2.9 MB) .
Before you ask if I can use Jetpack 3.3.3 instead, I can and it flashes successfully, but it uses L4T 28.4 and I need L4T 28.3
I also tried Jetpack 3.3.1, but it has a separate error (it cannot find USB). I can post about that separately if that would be helpful.
What is the issue and how is it fixed?
