Hello Edward,
I tried setting the device to recover mode manually and i see the error below . I also replaced the usb cable .
3:26:13 INFO: command finished successfully
********************************************************************************Terminal error *********************************
13:26:13 DEBUG: Device Mode Host Setup in Flash: using adapter to install NV_DEVICE_MODE_SETUP_IMAGE_COMP@JETSON_TX2 to /home/gsinnapolu/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_TX2
13:26:13 INFO: Device Mode Host Setup in Flash: current working directory is /home/gsinnapolu/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_TX2
13:26:13 INFO: Device Mode Host Setup in Flash: Found route default wlp2s0, setting up device mode
13:26:14 INFO: Device Mode Host Setup in Flash: net.ipv4.ip_forward = 1
13:26:14 INFO: Device Mode Host Setup in Flash: Device mode on host successfuly set with DNS 8.8.8.8!
13:26:14 INFO: Device Mode Host Setup in Flash: command finished successfully
13:26:14 SUMMARY: Device Mode Host Setup in Flash: Install completed successfully.
13:26:14 DEBUG: running command < true >
13:26:14 INFO: command finished successfully
13:26:14 DEBUG: Flash Jetson TX2: using adapter to install NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP@JETSON_TX2 to /home/gsinnapolu/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_TX2
13:26:14 INFO: Flash Jetson TX2: change working directory to /home/gsinnapolu/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_TX2/Linux_for_Tegra
13:26:14 INFO: Flash Jetson TX2: sudo ./flash.sh jetson-tx2 mmcblk0p1
13:26:14 INFO: Flash Jetson TX2: # L4T BSP Information:
13:26:14 INFO: Flash Jetson TX2: ###############################################################################
13:26:19 INFO: Flash Jetson TX2: USB port and is in recovery mode.
13:26:19 ERROR: Flash Jetson TX2: command terminated with error
13:26:21 SUMMARY: VPI on Target: Depends on failed component
