I’ve been trying to flash the TX2 devkit using Jetpack 3.2 with no luck. The download and install steps on the host machine are completed correctly but the problem arises when I try to flash the os to DevKit.
I’ve gone through other threads relating to this issue, but I could not find any thread which was closed with a proper solution.
The same devkit can be flashed with another machine so I am thinking that the problem is with this host machine itself rather than Jetson Devkit.
Also please note that, I am able to put the devkit in Recovery Mode and can verify that running
lsusb
is showing the device detected.
While flashing I receive the following error
# L4T BSP Information:
# R28 (release), REVISION: 2.0, GCID: 10567845, BOARD: t186ref, EABI: aarch64,
# DATE: Fri Mar 2 04:57:01 UTC 2018
Error: probing the target board failed.
Make sure the target board is connected through
micro-B USB port and is in recovery mode.
even though I can clearly see it in the output of lsusb
Kindly help me resolve this issue.
With regards,
Vedant
