I’m having this exact same problem!How I can fix it? I use a PC.
U-Boot 2016.07-g45dfa3dff4 (Apr 08 2020 - 18:06:40 -0700)
TEGRA186
Model: NVIDIA P2771-0000-500
DRAM: 7.8 GiB
MC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: eth0: ethernet@2490000
Hit any key to stop autoboot: 0
Card did not respond to voltage select!
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1…
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
733 bytes read in 101 ms (6.8 KiB/s)
1: primary kernel
Retrieving file: /boot/initrd
5565583 bytes read in 204 ms (26 MiB/s)
Retrieving file: /boot/Image
34265096 bytes read in 859 ms (38 MiB/s)
append: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 isolcpus=1-2 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x2772e0000 gpt usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2031647.1 bl_prof_dataptr=0x10000@0x275840000 sdhci_tegra.en_boot_part_access=1 quiet
Flattened Device Tree blob at 80000000
Booting using the fdt blob at 0x80000000
reserving fdt memory region: addr=80000000 size=10000
Using Device Tree in place at 0000000080000000, end 000000008004662b
Starting kernel …
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-3193) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Wed Apr 8 18:15:20 PDT 2020
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 16416,
[ 0.000000] OF: fdt: - 80000000 , 70000000
[ 0.000000] OF: fdt: - f0200000 , 185600000
[ 0.000000] OF: fdt: - 275e00000 , 200000
[ 0.000000] OF: fdt: - 276600000 , 200000
[ 0.000000] OF: fdt: - 277000000 , 200000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000003100000 (options ‘’)
[ 0.000000] bootconsole [uart8250] enabled
[ 0.475133] pca953x 0-0074: failed reading register
[ 0.475523] pca953x 0-0077: failed reading register
[ 0.790078] falcon 15340000.vic: failed to get IRQ
[ 0.793027] iommu_context_dev 13e10000.host1x:ctx0: iommu is not enabled for context device. aborting.
[ 0.793066] iommu_context_dev 13e10000.host1x:ctx1: iommu is not enabled for context device. aborting.
[ 0.793100] iommu_context_dev 13e10000.host1x:ctx2: iommu is not enabled for context device. aborting.
[ 0.793131] iommu_context_dev 13e10000.host1x:ctx3: iommu is not enabled for context device. aborting.
[ 0.793163] iommu_context_dev 13e10000.host1x:ctx4: iommu is not enabled for context device. aborting.
[ 0.793195] iommu_context_dev 13e10000.host1x:ctx5: iommu is not enabled for context device. aborting.
[ 0.793226] iommu_context_dev 13e10000.host1x:ctx6: iommu is not enabled for context device. aborting.
[ 0.793256] iommu_context_dev 13e10000.host1x:ctx7: iommu is not enabled for context device. aborting.
[ 1.921221] tegra-ahci 3507000.ahci-sata: controller reset failed (0xffffffff)
[ 2.098076] FAN: coudln’t get the regulator
[ 2.103844] arm-smmu 12000000.iommu: Unexpected {global,context} fault, this could be serious
[ 2.112369] arm-smmu 12000000.iommu: GFSR 0x80000002, GFSYNR0 0x00000000, GFSYNR1 0x00001432, GFSYNR2 0x00000000
[ 2.122672] mc-err: vpr base=0:0, size=0, ctrl=1, override:(e01a8341, 1dc10c1, 2a800000, 2)
[ 2.131039] mc-err: (255) csw_bpmpw: MC request violates VPR requirements
[ 2.137901] mc-err: status = 0x00337094; addr = 0x3ffffffc0
[ 2.143654] mc-err: secure: yes, access-type: write
[ 2.148718] mc-err: unknown mcerr fault, int_status=0x00000000, ch_int_status=0x00000000, hubc_int_status=0x00000000
[ 2.159244] mc-err: unknown mcerr fault, int_status=0x00000000, ch_int_status=0x00000000, hubc_int_status=0x00000000
[ 2.169772] mc-err: unknown mcerr fault, int_status=0x00000000, ch_int_status=0x00000000, hubc_int_status=0x00000000
[ 2.180296] mc-err: Too many MC errors; throttling prints
[ 2.185808] arm-smmu 12000000.iommu: Unexpected {global,context} fault, this could be serious
[ 2.194333] arm-smmu 12000000.iommu: GFSR 0x80000002, GFSYNR0 0x00000000, GFSYNR1 0x00001c32, GFSYNR2 0x00000000
[ 2.206982] Unable to handle kernel paging request at virtual address ffffff800a36e020
[ 2.214926] Mem abort info:
[ 2.217724] ESR = 0x96000047
[ 2.220792] Exception class = DABT (current EL), IL = 32 bits
[ 2.226721] SET = 0, FnV = 0
[ 2.229776] EA = 0, S1PTW = 0
[ 2.232927] Data abort info:
[ 2.235819] ISV = 0, ISS = 0x00000047
[ 2.239665] CM = 0, WnR = 1
[ 2.242644] swapper pgtable: 4k pages, 39-bit VAs, pgd = ffffff800a1c9000
[ 2.249437] [ffffff800a36e020] *pgd=00000002771fe003, *pud=00000002771fe003, *pmd=000000026c9d7003, *pte=0000000000000000
[ 2.260470] Internal error: Oops: 96000047 [#1] PREEMPT SMP
[ 2.266041] Modules linked in:
[ 2.269112] CPU: 5 PID: 1 Comm: swapper/0 Not tainted 4.9.140-tegra #1
[ 2.275636] Hardware name: quill (DT)
[ 2.279299] task: ffffffc1ecb30000 task.stack: ffffffc1ecb38000
[ 2.285229] PC is at tegra_update_cpu_speed+0x140/0x178
[ 2.290454] LR is at tegra_update_cpu_speed+0x11c/0x178
[ 2.295677] pc : [] lr : [] pstate: 60400045
[ 2.303070] sp : ffffffc1ecb3b9a0
[ 2.306385] x29: ffffffc1ecb3b9a0 x28: 00000000024000c0
[ 2.311721] x27: 0000000000000000 x26: ffffff8009e57f74
[ 2.317056] x25: ffffff800a19a4c8 x24: ffffff800a36e020
[ 2.322392] x23: ffffff800a19a4c8 x22: 0000000000000000
[ 2.327726] x21: ffffff800a19a530 x20: ffffffc1f6776a98
[ 2.333058] x19: 0000000000000000 x18: 0000000000000000
[ 2.338392] x17: 0000000000000000 x16: 0000000000000000
[ 2.343725] x15: 0000000000000000 x14: 0000000000000001
[ 2.349058] x13: 0000000000000030 x12: 0000000000000038
[ 2.354392] x11: 000000000000000b x10: 0101010101010101
[ 2.359723] x9 : fffffffffffffffd x8 : ffffffc1e9fd9400
[ 2.365056] x7 : 0000000000000000 x6 : 0000000000000000
[ 2.370389] x5 : 0000000000000001 x4 : 0000000000000000
[ 2.375722] x3 : ffffff8009821a98 x2 : 0000000000000000
[ 2.381055] x1 : 0000000000000000 x0 : ffffff800a36e000
[ 2.386388]
[ 2.387882] Process swapper/0 (pid: 1, stack limit = 0xffffffc1ecb38000)
[ 2.394579] Call trace:
[ 2.397030] [] tegra_update_cpu_speed+0x140/0x178
[ 2.403299] [] tegra186_cpufreq_set_target+0x198/0x228
[ 2.409996] [] __cpufreq_driver_target+0x1d0/0x610
[ 2.416348] [] cpufreq_online+0x654/0x748
[ 2.421920] [] cpufreq_add_dev+0x84/0xc8
[ 2.427408] [] subsys_interface_register+0x90/0xd8
[ 2.433757] [] cpufreq_register_driver+0x190/0x278
[ 2.440115] [] tegra186_cpufreq_probe+0xa20/0xa90
[ 2.446381] [] platform_drv_probe+0x60/0xc0
[ 2.452126] [] driver_probe_device+0xd8/0x408
[ 2.458043] [] __driver_attach+0xdc/0x128
[ 2.463612] [] bus_for_each_dev+0x5c/0xa8
[ 2.469182] [] driver_attach+0x30/0x40
[ 2.474492] [] bus_add_driver+0x20c/0x2a8
[ 2.480062] [] driver_register+0x6c/0x110
[ 2.485633] [] __platform_driver_register+0x5c/0x68
[ 2.492072] [] tegra186_cpufreq_platform_driver_init+0x18/0x20
[ 2.499471] [] do_one_initcall+0x44/0x130
[ 2.505045] [] kernel_init_freeable+0x1a0/0x244
[ 2.511140] [] kernel_init+0x18/0x108
[ 2.516365] [] ret_from_fork+0x10/0x30
[ 2.521683] —[ end trace 2a7ba90ed388d28a ]—
[ 2.530481] note: swapper/0[1] exited with preempt_count 1
[ 2.535990] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[ 2.535990]
[ 2.545130] SMP: stopping secondary CPUs
[ 2.549067] Kernel Offset: disabled
[ 2.552555] Memory Limit: none
[ 2.559756] Rebooting in 5 seconds..
[0000.187] I> Welcome to MB2(TBoot-BPMP)(version: 01.00.160913-t186-M-00.00-mobile-050b21a4)
[0000.195] I> bit @ 0xd480000
[0000.198] I> Boot-device: eMMC
[0000.206] I> sdmmc bdev is already initialized
[0000.210] I> pmic: reset reason (nverc) : 0x0
[0000.242] I> Found 18 partitions in SDMMC_BOOT (instance 3)
[0000.261] I> Found 33 partitions in SDMMC_USER (instance 3)
[0000.267] W> No valid slot number is found in scratch register
[0000.272] W> Return default slot: _a
[0000.276] I> A/B: bin_type (16) slot 0
[0000.279] I> Loading partition bpmp-fw at 0xd7800000
[0000.284] I> Reading two headers - addr:0xd7800000 blocks:1
[0000.290] I> Addr: 0xd7800000, start-block: 58777608, num_blocks: 1
[0000.314] I> Binary(16) of size 533504 is loaded @ 0xd7800000
[0000.320] W> No valid slot number is found in scratch register
[0000.326] W> Return default slot: _a
[0000.329] I> A/B: bin_type (17) slot 0
[0000.333] I> Loading partition bpmp-fw-dtb at 0xd79f0000
[0000.338] I> Reading two headers - addr:0xd79f0000 blocks:1
[0000.343] I> Addr: 0xd79f0000, start-block: 58780024, num_blocks: 1
[0000.369] I> Binary(17) of size 604720 is loaded @ 0xd796c400
[0000.595] I> Loading SCE-FW …
[0000.598] W> No valid slot number is found in scratch register
[0000.604] W> Return default slot: _a
[0000.607] I> A/B: bin_type (12) slot 0
[0000.611] I> Loading partition sce-fw at 0xd7300000
[0000.615] I> Reading two headers - addr:0xd7300000 blocks:1
[0000.621] I> Addr: 0xd7300000, start-block: 58784120, num_blocks: 1
[0000.640] I> Binary(12) of size 125168 is loaded @ 0xd7300000
[0000.646] I> Init SCE
[0000.648] I> Loading APE-FW …
[0000.651] W> No valid slot number is found in scratch register
[0000.657] W> Return default slot: _a
[0000.660] I> A/B: bin_type (11) slot 0
[0000.664] I> Loading partition adsp-fw at 0xd7400000
[0000.669] I> Reading two headers - addr:0xd7400000 blocks:1
[0000.674] I> Addr: 0xd7400000, start-block: 58761224, num_blocks: 1
[0000.693] I> Binary(11) of size 107808 is loaded @ 0xd7400000
[0000.699] I> Copy BTCM section
[0000.702] W> No valid slot number is found in scratch register
[0000.708] W> Return default slot: _a
[0000.711] I> A/B: bin_type (13) slot 0
[0000.715] I> Loading partition cpu-bootloader at 0x96000000
[0000.720] I> Reading two headers - addr:0x96000000 blocks:1
[0000.726] I> Addr: 0x96000000, start-block: 58740744, num_blocks: 1
[0000.747] I> Binary(13) of size 284288 is loaded @ 0x96000000
[0000.752] W> No valid slot number is found in scratch register
[0000.758] W> Return default slot: _a
[0000.761] I> A/B: bin_type (20) slot 0
[0000.765] I> Loading partition bootloader-dtb at 0x8520f400
[0000.771] I> Reading two headers - addr:0x8520f400 blocks:1
[0000.776] I> Addr: 0x8520f400, start-block: 58742792, num_blocks: 1
[0000.797] I> Binary(20) of size 267920 is loaded @ 0x8520f400
[0000.803] W> No valid slot number is found in scratch register
[0000.808] W> Return default slot: _a
[0000.812] I> A/B: bin_type (14) slot 0
[0000.815] I> Loading partition secure-os at 0x8530f600
[0000.820] I> Reading two headers - addr:0x8530f600 blocks:1
[0000.826] I> Addr: 0x8530f600, start-block: 58744840, num_blocks: 1
[0000.848] I> Binary(14) of size 366000 is loaded @ 0x8530f600
[0000.856] I> TOS boot-params @ 0x85000000
[0000.860] I> TOS params prepared
[0000.863] I> Loading EKS …
[0000.865] I> A/B: bin_type (15) slot 0
[0000.869] I> Loading partition eks at 0x8590f800
[0000.874] I> Reading two headers - addr:0x8590f800 blocks:1
[0000.879] I> Addr: 0x8590f800, start-block: 58757128, num_blocks: 1
[0000.898] I> Binary(15) of size 1040 is loaded @ 0x8590f800
[0000.903] I> EKB detected (length: 0x400) @ 0x8590f800
[0000.908] I> Copied encrypted keys
[0000.912] I> boot profiler @ 0x275844000
[0000.916] I> boot profiler for TOS @ 0x275844000
[0000.921] I> Unhalting SCE
[0000.923] I> Primary Memory Start:80000000 Size:70000000
[0000.929] I> Extended Memory Start:f0110000 Size:1856f0000
[0000.935] I> MB2(TBoot-BPMP) done
NOTICE: BL31: v1.3(release):fe06da916
NOTICE: BL31: Built : 18:07:10, Apr 8 2020
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
hwkey-agent: 40: hwkey-agent is running!!
hwkey-agent: 182: key_mgnt_processing …
hwkey-agent: 157: Init hweky-agent services!!
platform_bootstrap_epilog: trusty bootstrap complete
[0001.308] I> Welcome to Cboot
[0001.310] I> Cboot Version: t186-da7af280
[0001.314] I> CPU-BL Params @ 0x275800000
[0001.318] I> 0) Base:0x00000000 Size:0x00000000
[0001.322] I> 1) Base:0x277f00000 Size:0x00100000
[0001.327] I> 2) Base:0x277e00000 Size:0x00100000
[0001.331] I> 3) Base:0x277d00000 Size:0x00100000
[0001.336] I> 4) Base:0x277c00000 Size:0x00100000
[0001.340] I> 5) Base:0x277b00000 Size:0x00100000
[0001.345] I> 6) Base:0x277800000 Size:0x00200000
[0001.349] I> 7) Base:0x277400000 Size:0x00400000
[0001.354] I> 8) Base:0x277a00000 Size:0x00100000
[0001.359] I> 9) Base:0x277300000 Size:0x00100000
[0001.363] I> 10) Base:0x276800000 Size:0x00800000
[0001.368] I> 11) Base:0x30000000 Size:0x00040000
[0001.372] I> 12) Base:0xf0000000 Size:0x00100000
[0001.376] I> 13) Base:0x30040000 Size:0x00001000
[0001.381] I> 14) Base:0x30048000 Size:0x00001000
[0001.385] I> 15) Base:0x30049000 Size:0x00001000
[0001.390] I> 16) Base:0x3004a000 Size:0x00001000
[0001.394] I> 17) Base:0x3004b000 Size:0x00001000
[0001.399] I> 18) Base:0x3004c000 Size:0x00001000
[0001.403] I> 19) Base:0x3004d000 Size:0x00001000
[0001.407] I> 20) Base:0x3004e000 Size:0x00001000
[0001.412] I> 21) Base:0x3004f000 Size:0x00001000
[0001.416] I> 22) Base:0x00000000 Size:0x00000000
[0001.421] I> 23) Base:0xf0100000 Size:0x00010000
[0001.425] I> 24) Base:0x00000000 Size:0x00000000
[0001.430] I> 25) Base:0x00000000 Size:0x00000000
[0001.434] I> 26) Base:0x00000000 Size:0x00000000
[0001.438] I> 27) Base:0x00000000 Size:0x00000000
[0001.443] I> 28) Base:0x84400000 Size:0x00400000
[0001.447] I> 29) Base:0x30000000 Size:0x00010000
[0001.452] I> 30) Base:0x278000000 Size:0x08000000
[0001.456] I> 31) Base:0x00000000 Size:0x00000000
[0001.461] I> 32) Base:0x276000000 Size:0x00600000
[0001.465] I> 33) Base:0x80000000 Size:0x70000000
[0001.470] I> 34) Base:0xf0110000 Size:0x1856f0000
[0001.474] I> 35) Base:0x00000000 Size:0x00000000
[0001.479] I> 36) Base:0x00000000 Size:0x00000000
[0001.483] I> 37) Base:0x2772e0000 Size:0x00020000
[0001.488] I> 38) Base:0x84000000 Size:0x00400000
[0001.492] I> 39) Base:0x96000000 Size:0x02000000
[0001.496] I> 40) Base:0x85000000 Size:0x01200000
[0001.501] I> 41) Base:0x275800000 Size:0x00500000
[0001.505] I> 42) Base:0x00000000 Size:0x00000000
[0001.510] I> 43) Base:0x00000000 Size:0x00000000
[0001.514] GIC-SPI Target CPU: 4
[0001.517] Interrupts Init done
[0001.521] calling constructors
[0001.524] initializing heap
[0001.527] initializing threads
[0001.530] initializing timers
[0001.533] creating bootstrap completion thread
[0001.538] top of bootstrap2()
[0001.541] CPU: ARM Cortex A57
[0001.544] CPU: MIDR: 0x411FD073, MPIDR: 0x80000100
[0001.549] initializing platform
[0001.552] I> Bl_dtb @0x8520f400
[0001.555] I> gpio framework initialized
[0001.561] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra186-gpio’ driver
[0001.570] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra186-gpio-aon’ driver
[0001.578] I> GPIO framework and drivers are initialized.
[0001.583] I> Boot-device: eMMC
[0001.590] I> sdmmc bdev is already initialized
[0001.620] I> Found 18 partitions in SDMMC_BOOT (instance 3)
[0001.638] I> Found 33 partitions in SDMMC_USER (instance 3)
[0001.643] W> opt-in fuse is not set, skip fuse_burning
[0001.648] I> Reserved memory at 0xfbe00000 for U-Boot relocation
[0001.654] W> No valid slot number is found in scratch register
[0001.660] W> Return default slot: _a
[0001.663] I> A/B: bin_type (21) slot 0
[0001.667] I> Loading kernel-dtb from partition
[0001.671] I> Loading partition kernel-dtb at 0x80000000 from device(0x1)
[0001.688] I> Kernel_dtb @0x80000000
[0001.691] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xee
[0001.699] E> I2C: slave not found in slaves.
[0001.703] E> I2C: Could not write 0 bytes to slave: 0x00ee with repeat start false.
[0001.711] E> I2C_DEV: Failed to send register address 0x00000004.
[0001.717] E> I2C_DEV: Could not write 1 registers of size 1 to slave 0xee at 0x00000004 via instance 0.
[0001.726] E> tca9539_device_init: failed to write polar reg
[0001.731] E> tegrabl_tca9539_init: failed to init device!
[0001.737] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xe8
[0001.743] E> I2C: slave not found in slaves.
[0001.747] E> I2C: Could not write 0 bytes to slave: 0x00e8 with repeat start false.
[0001.755] E> I2C_DEV: Failed to send register address 0x00000004.
[0001.761] E> I2C_DEV: Could not write 1 registers of size 1 to slave 0xe8 at 0x00000004 via instance 0.
[0001.770] E> tca9539_device_init: failed to write polar reg
[0001.776] E> tegrabl_tca9539_init: failed to init device!
[0001.783] I> fixed regulator driver initialized
[0001.811] I> register ‘maxim’ power off handle
[0001.816] I> virtual i2c enabled
[0001.819] I> registered ‘maxim,max77620’ pmic
[0001.824] I> tegrabl_gpio_driver_register: register ‘max77620-gpio’ driver
[0001.835] I> Find /i2c@c250000’s alias i2c7
[0001.839] I> Reading eeprom i2c=7 address=0x50
[0001.868] I> Device at /i2c@c250000:0x50
[0001.872] I> Reading eeprom i2c=7 address=0x57
[0001.877] E> I2C: slave not found in slaves.
[0001.881] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0001.888] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.894] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 7.
[0001.904] E> eeprom: Failed to read I2C slave device
[0001.909] I> Eeprom read failed 0x3526070d
[0001.913] I> Find /i2c@c240000’s alias i2c1
[0001.917] I> Reading eeprom i2c=1 address=0x51
[0001.922] E> I2C: slave not found in slaves.
[0001.926] E> I2C: Could not write 0 bytes to slave: 0x00a2 with repeat start true.
[0001.934] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.940] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa2 at 0x00000000 via instance 1.
[0001.949] E> eeprom: Retry to read I2C slave device.
[0001.954] E> I2C: slave not found in slaves.
[0001.958] E> I2C: Could not write 0 bytes to slave: 0x00a2 with repeat start true.
[0001.966] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.972] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa2 at 0x00000000 via instance 1.
[0001.981] E> eeprom: Failed to read I2C slave device
[0001.986] I> Eeprom read failed 0x3526070d
[0001.991] I> Find /i2c@3160000’s alias i2c0
[0001.995] I> Reading eeprom i2c=0 address=0x50
[0001.999] E> I2C: slave not found in slaves.
[0002.003] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0002.011] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.017] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 0.
[0002.026] E> eeprom: Failed to read I2C slave device
[0002.031] I> Eeprom read failed 0x3526070d
[0002.036] I> Find /i2c@3180000’s alias i2c2
[0002.040] I> Reading eeprom i2c=2 address=0x54
[0002.044] I> Enabling gpio chip_id = 2, gpio pin = 9
[0002.049] C> GPIO driver for chip_id 0x2 could not be found
[0002.054] E> cam_eeprom_read: Can’t get gpio driver
[0002.059] I> Eeprom read failed 0x4d4d000d
[0002.063] I> create_pm_ids: id: 3310-1000-B02-C, len: 15
[0002.068] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0002.083] E> invalid phandle for nvidia,dc-connector
[0002.090] E> cannot find any other nvdisp nodes
[0002.094] E> no valid display unit config found in dtb
[0002.100] W> display init failed
[0002.103] initializing target
[0002.106] calling apps_init()
[0002.109] starting app kernel_boot_app
[0002.132] I> found decompressor handler: lz4-legacy
[0002.136] I> decompressing BMP blob …
[0002.146] I> Kernel type = Normal
[0002.149] I> Loading kernel-bootctrl from partition
[0002.154] I> Loading partition kernel-bootctrl at 0xa8000000 from device(0x1)
[0002.169] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0002.176] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0002.182] I> ########## Fixed storage boot ##########
[0002.187] W> No valid slot number is found in scratch register
[0002.193] W> Return default slot: _a
[0002.196] I> A/B: bin_type (24) slot 0
[0002.212] I> Boot image size read from image header: 74aba
[0002.217] I> Boot image load address: 0x80400000
[0002.222] I> Loading kernel from partition
[0002.226] I> Loading partition kernel at 0x80400000 from device(0x1)
[0003.185] I> Validate kernel …
[0003.188] I> T18x: Authenticate kernel (bin_type 24), max size 0x4000000
[0003.196] I> kernel-dtb is already loaded
[0003.200] I> Validate kernel-dtb …
[0003.203] I> T18x: Authenticate kernel-dtb (bin_type 21), max size 0x100000
[0003.210] I> Checking boot.img header magic … [0003.215] I> [OK]
[0003.216] I> Kernel hdr @0x80400000
[0003.220] I> Kernel dtb @0x80000000
[0003.223] I> decompressor handler not found
[0003.227] I> Copying kernel image (477882 bytes) from 0x80400800 to 0x80600000 … [0003.235] I> Done
[0003.236] I> Move ramdisk (len: 0) from 0x80475800 to 0x947b0000
[0003.243] I> Updated bpmp info to DTB
[0003.249] I> Ramdisk: Base: 0x947b0000; Size: 0x0
[0003.253] I> Updated initrd info to DTB
[0003.257] W> WARN: Fail to override “console=none” in commandline
[0003.263] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0003.270] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0003.277] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0003.284] I> disabled_core_mask: 0xffffff0c
[0003.288] W> No valid slot number is found in scratch register
[0003.294] W> Return default slot: _a
[0003.297] I> Active slot suffix:
[0003.300] I> add_boot_slot_suffix: slot_suffix =
[0003.305] I> Linux Cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 isolcpus=1-2 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x2772e0000 gpt usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2031647.1 bl_prof_dataptr=0x10000@0x275840000 sdhci_tegra.en_boot_part_access=1
[0003.343] I> Updated bootarg info to DTB
[0003.346] I> eeprom_get_mac_addr: MAC (type: 0): 00:04:4b:a5:5f:b4
[0003.352] I> eeprom_get_mac_addr: MAC (type: 1): 00:04:4b:a5:5f:b5
[0003.359] I> eeprom_get_mac_addr: MAC (type: 2): 00:04:4b:a5:5f:b6
[0003.365] E> Found no plugin manager ids in source DT
[0003.370] W> Add plugin manager ids from board info
[0003.374] E> “plugin-manager” doesn’t exist, creating
[0003.379] E> “ids” doesn’t exist, creating
[0003.383] E> “connection” doesn’t exist, creating
[0003.388] E> “configs” doesn’t exist, creating
[0003.392] I> create_pm_ids: id: 3310-1000-B02-C, len: 15
[0003.397] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0003.408] I> Adding plugin-manager/ids/3310-1000-B02=/i2c@c250000:module@0x50
[0003.415] E> “i2c@c250000” doesn’t exist, creating
[0003.420] E> “module@0x50” doesn’t exist, creating
[0003.426] I> Adding plugin-manager/ids/3310-1000-B02-C
[0003.432] I> Adding plugin-manager/configs/3310-mem-type 00
[0003.438] I> Adding plugin-manager/configs/3310-power-config 00
[0003.444] I> Adding plugin-manager/configs/3310-misc-config 00
[0003.450] I> Adding plugin-manager/configs/3310-modem-config 00
[0003.455] I> Adding plugin-manager/configs/3310-touch-config 00
[0003.461] I> Adding plugin-manager/configs/3310-display-config 00
[0003.467] I> Adding plugin-manager/cvm
[0003.471] E> “chip-id” doesn’t exist, creating
[0003.475] I> Adding plugin-manager/chip-id/A02P
[0003.480] E> “odm-data” doesn’t exist, creating
[0003.484] I> Adding /chosen/plugin-manager/odm-data
[0003.492] I> added [base:0x80000000, size:0x70000000] to /memory
[0003.498] I> added [base:0xf0200000, size:0x185600000] to /memory
[0003.504] I> added [base:0x275e00000, size:0x200000] to /memory
[0003.510] I> added [base:0x276600000, size:0x200000] to /memory
[0003.515] I> added [base:0x277000000, size:0x200000] to /memory
[0003.521] I> Updated memory info to DTB
[0003.525] E> add_disp_param: failed to get display params for du=0
[0003.533] E> “reset” doesn’t exist, creating
[0003.537] E> “pmc-reset-reason” doesn’t exist, creating
[0003.542] E> “pmic-reset-reason” doesn’t exist, creating
[0003.548] I> Adding ecid(000000016441b74918000000160202c0) to DT
[0003.554] I> disabled_core_mask: 0xffffff0c
[0003.565] I> Add serial number:0421518033540 as DT property
[0003.573] I> Plugin-manager override starting
[0003.578] I> node /plugin-manager/soc-prod-a02-fragment matches
[0003.588] I> node /plugin-manager/fragement@0 matches
[0003.597] I> node /plugin-manager/fragement@4 matches
[0003.608] I> node /plugin-manager/fragment-sdwake-p3310-1000-300 matches
[0003.624] I> node /plugin-manager/fragement-pmon-p3310-1000-300 matches
[0003.633] I> node /plugin-manager/fragement-pmon-p3310-1000-800 matches
[0003.642] I> node /plugin-manager/fragment-devslp@0 matches
[0003.652] I> node /plugin-manager/fragment-500-pcie-config matches
[0003.665] I> node /plugin-manager/fragment-500-xusb-config matches
[0003.683] I> node /plugin-manager/fragment-p3310-c00-comm matches
[0003.695] I> node /plugin-manager/fragment-p3310-c00-pmic matches
[0003.704] I> node /plugin-manager/fragment-p3310-c01 matches
[0003.714] I> node /plugin-manager/fragment-p3310-c03 matches
[0003.743] I> node /plugin-manager/fragment-p3310-c00-camera matches
[0003.762] I> Disable plugin-manager status in FDT
[0003.766] I> Plugin-manager override finished successfully
[0003.771] I> tegrabl_load_kernel_and_dtb: Done
[0003.776] E> tegrabl_display_clear: display is not initialized
[0003.781] W> Boot logo display failed…
[0003.785] I> Kernel EP: 0x80600000, DTB: 0x80000000
