Your idea with USB devices give me some hopes !
Here are the results of my last tests :
TEST 1 : with my laptop with UBUNTU on a external USB disk (/dev/sdb) :
lsblk -f
NAME FSTYPE LABEL MOUNTPOINT
sda
├─sda1
├─sda2
└─sda3
sdb
├─sdb1 /
├─sdb2
├─sdb5 [SWAP]
└─sdb6 /home
sr0
No FSTYPE but i format “/” and “/home” as ext4
lsusb -t
/: Bus 05.Port 1: Dev 1, Class=root_hub, Driver=uhci_hcd/2p, 12M
/: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=uhci_hcd/2p, 12M
/: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=uhci_hcd/2p, 12M
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=uhci_hcd/2p, 12M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=ehci-pci/8p, 480M
|__ Port 1: Dev 2, If 0, Class=Mass Storage, Driver=usb-storage, 480M
|__ Port 3: Dev 10, If 0, Class=Vendor Specific Class, Driver=, 480M
|__ Port 4: Dev 3, If 0, Class=Imaging, Driver=, 480M
Devices (USB drive and Jetson in recovery mode) always go on the same root_hub. Maybe because my laptop have only one USB2 controller
Unsurprisingly : “Error: Return value 4”
TEST 2 : I found 51GiB on my internal hard drive (/dev/sda) to install UBUNTU
lsblk -f
sda
├─sda1
├─sda2
├─sda3
├─sda4
├─sda5 /home
├─sda6 [SWAP]
└─sda7 /
sr0
I have some free space
df -H -k
Filesystem 1K-blocks Used Available Use% Mounted on
udev 496292 4 496288 1% /dev
tmpfs 101484 1112 100372 2% /run
/dev/sda7 12318640 9666412 2003424 83% /
none 4 0 4 0% /sys/fs/cgroup
none 5120 0 5120 0% /run/lock
none 507404 156 507248 1% /run/shm
none 102400 40 102360 1% /run/user
/dev/sda5 36394704 16087660 18435224 47% /home
I have only Jetson in recovery mode connected to USB :
lsusb -t (after flashing)
|__ Port 3: Dev 8, If 0, Class=Vendor Specific Class, Driver=, 480M
|__ Port 4: Dev 2, If 0, Class=Imaging, Driver=, 480M
Unfortunately “Error: Return value 4”. All my hopes are gone. Do you have any other idea ?
