I want to create an image of TX2_4GB which is installed by sdkmanager.In Recovery mode,I run the following code.
cd /home/wxr/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3489-0080/Linux_for_Tegra
lsusb
sudo ./flash.sh -r -k APP -G system.img jetson-tx2 mmcblk0p1
But I got Error as follows.What should I do for it? Thank you.
# L4T BSP Information:
# R32 , REVISION: 2.1
# Target Board Information:
# Name: jetson-tx2, Board Family: t186ref, SoC: Tegra 186,
# OpMode: production, Boot Authentication: NS,
./tegraflash.py --chip 0x18 --applet "/home/wxr/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3489-0080/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin" --skipuid --cmd "dump eeprom boardinfo cvm.bin"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0025 ] Generating RCM messages
[ 0.0033 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 0 --download rcm /home/wxr/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3489-0080/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin 0 0
[ 0.0040 ] RCM 0 is saved as rcm_0.rcm
[ 0.0043 ] RCM 1 is saved as rcm_1.rcm
[ 0.0043 ] List of rcm files are saved in rcm_list.xml
[ 0.0044 ]
[ 0.0044 ] Signing RCM messages
[ 0.0050 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0057 ] Assuming zero filled SBK key
[ 0.0082 ]
[ 0.0082 ] Copying signature to RCM mesages
[ 0.0089 ] tegrarcm_v2 --chip 0x18 0 --updatesig rcm_list_signed.xml
[ 0.0098 ]
[ 0.0098 ] Boot Rom communication
[ 0.0104 ] tegrarcm_v2 --chip 0x18 0 --rcm rcm_list_signed.xml --skipuid
[ 0.0110 ] RCM version 0X180001
[ 0.0119 ] Boot Rom communication completed
[ 1.0185 ]
[ 2.0216 ] tegrarcm_v2 --isapplet
[ 2.0234 ] Applet version 01.00.0000
[ 2.0263 ]
[ 2.0282 ] Retrieving EEPROM data
[ 2.0285 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/wxr/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3489-0080/Linux_for_Tegra/bootloader/cvm.bin
[ 2.0303 ] Applet version 01.00.0000
[ 2.0537 ] Saved platform info in /home/wxr/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3489-0080/Linux_for_Tegra/bootloader/cvm.bin
[ 2.1266 ]
Board ID(3489) version(300) sku(0888) revision(H.0)
copying bctfile(/home/wxr/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3489-0080/Linux_for_Tegra/bootloader/t186ref/BCT/P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg)... done.
copying misc_config(/home/wxr/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3489-0080/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-misc-si-l4t.cfg)... done.
copying pinmux_config(/home/wxr/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3489-0080/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pinmux-quill-p3310-1000-a00.cfg)... done.
copying pmic_config(/home/wxr/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3489-0080/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pmic-quill-p3310-1000-a00.cfg)... done.
copying pmc_config(/home/wxr/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3489-0080/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pad-quill-p3310-1000-a00.cfg)... done.
copying prod_config(/home/wxr/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3489-0080/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-prod-quill-p3310-1000-a00.cfg)... done.
copying scr_config(/home/wxr/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3489-0080/Linux_for_Tegra/bootloader/t186ref/BCT/minimal_scr.cfg)... done.
copying scr_cold_boot_config(/home/wxr/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3489-0080/Linux_for_Tegra/bootloader/t186ref/BCT/mobile_scr.cfg)... done.
copying bootrom_config(/home/wxr/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3489-0080/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-bootrom-quill-p3310-1000-a00.cfg)... done.
copying dev_params(/home/wxr/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3489-0080/Linux_for_Tegra/bootloader/t186ref/BCT/emmc.cfg)... done.
Existing bootloader(/home/wxr/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3489-0080/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
copying initrd(/home/wxr/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3489-0080/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
populating kernel to rootfs... done.
populating initrd to rootfs... done.
populating /home/wxr/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3489-0080/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-a00-00-base.dtb to rootfs... done.
Making Boot image... done.
Existing sosfile(/home/wxr/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3489-0080/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin) reused.
copying tegraboot(/home/wxr/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3489-0080/Linux_for_Tegra/bootloader/t186ref/nvtboot.bin)... done.
Existing cpu_bootloader(/home/wxr/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3489-0080/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
Existing mb2blfile(/home/wxr/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3489-0080/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
Existing mtspreboot(/home/wxr/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3489-0080/Linux_for_Tegra/bootloader/preboot_d15_prod_cr.bin) reused.
Existing mts(/home/wxr/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3489-0080/Linux_for_Tegra/bootloader/mce_mts_d15_prod_cr.bin) reused.
Existing mb1file(/home/wxr/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3489-0080/Linux_for_Tegra/bootloader/mb1_prod.bin) reused.
Existing bpffile(/home/wxr/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3489-0080/Linux_for_Tegra/bootloader/bpmp.bin) reused.
copying bpfdtbfile(/home/wxr/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3489-0080/Linux_for_Tegra/bootloader/t186ref/tegra186-a02-bpmp-quill-p3310-1000-a00-00-te770d-ucm2.dtb)... done.
Existing scefile(/home/wxr/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3489-0080/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
Existing spefile(/home/wxr/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3489-0080/Linux_for_Tegra/bootloader/spe.bin) reused.
Existing drameccfile(/home/wxr/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3489-0080/Linux_for_Tegra/bootloader/dram-ecc.bin) reused.
Existing badpagefile(/home/wxr/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3489-0080/Linux_for_Tegra/bootloader/badpage.bin) reused.
copying wb0boot(/home/wxr/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3489-0080/Linux_for_Tegra/bootloader/t186ref/warmboot.bin)... done.
Existing tosfile(/home/wxr/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3489-0080/Linux_for_Tegra/bootloader/tos-trusty.img) reused.
Existing eksfile(/home/wxr/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3489-0080/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/wxr/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3489-0080/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-a00-00-base.dtb)... done.
Copying nv_boot_control.conf to rootfs
Skip generating system.img
Existing tbcfile(/home/wxr/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3489-0080/Linux_for_Tegra/bootloader/cboot.bin) reused.
copying tbcdtbfile(/home/wxr/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3489-0080/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-a00-00-base.dtb)... done.
copying cfgfile(/home/wxr/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3489-0080/Linux_for_Tegra/bootloader/t186ref/cfg/flash_l4t_t186.xml) to flash.xml... done.
Existing flasher(/home/wxr/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3489-0080/Linux_for_Tegra/bootloader/nvtboot_recovery_cpu.bin) reused.
Existing flashapp(/home/wxr/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3489-0080/Linux_for_Tegra/bootloader/tegraflash.py) reused.
*** Reading [APP] and storing to /home/wxr/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3489-0080/Linux_for_Tegra/system.img ***
./tegraflash.py --bl nvtboot_recovery_cpu.bin --chip 0x18 --applet mb1_recovery_prod.bin --sdram_config P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --misc_config tegra186-mb1-bct-misc-si-l4t.cfg --pinmux_config tegra186-mb1-bct-pinmux-quill-p3310-1000-a00.cfg --pmic_config tegra186-mb1-bct-pmic-quill-p3310-1000-a00.cfg --pmc_config tegra186-mb1-bct-pad-quill-p3310-1000-a00.cfg --prod_config tegra186-mb1-bct-prod-quill-p3310-1000-a00.cfg --scr_config minimal_scr.cfg --scr_cold_boot_config mobile_scr.cfg --br_cmd_config tegra186-mb1-bct-bootrom-quill-p3310-1000-a00.cfg --dev_params emmc.cfg --cfg flash.xml --bins "mb2_bootloader nvtboot_recovery.bin; mts_preboot preboot_d15_prod_cr.bin; mts_bootpack mce_mts_d15_prod_cr.bin; bpmp_fw bpmp.bin; bpmp_fw_dtb tegra186-a02-bpmp-quill-p3310-1000-a00-00-te770d-ucm2.dtb; tlk tos-trusty.img; eks eks.img; bootloader_dtb tegra186-quill-p3310-1000-a00-00-base.dtb" --cmd "read APP /home/wxr/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3489-0080/Linux_for_Tegra/system.img"
version 1.0.0
[ 0.0071 ] Generating RCM messages
[ 0.0078 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 0 --download rcm mb1_recovery_prod.bin 0 0
[ 0.0085 ] RCM 0 is saved as rcm_0.rcm
[ 0.0087 ] RCM 1 is saved as rcm_1.rcm
[ 0.0087 ] List of rcm files are saved in rcm_list.xml
[ 0.0087 ]
[ 0.0087 ] Signing RCM messages
[ 0.0094 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0100 ] Assuming zero filled SBK key
[ 0.0125 ]
[ 0.0125 ] Copying signature to RCM mesages
[ 0.0133 ] tegrarcm_v2 --chip 0x18 0 --updatesig rcm_list_signed.xml
[ 0.0142 ]
[ 0.0143 ] Boot Rom communication
[ 0.0149 ] tegrarcm_v2 --chip 0x18 0 --rcm rcm_list_signed.xml
[ 0.0156 ] BootRom is not running
[ 5.0126 ]
[ 6.0157 ] tegrarcm_v2 --isapplet
[ 6.0175 ] Applet version 01.00.0000
[ 6.0202 ]
[ 6.0222 ] tegrasign_v2 --key None --getmode mode.txt
[ 6.0239 ] Assuming zero filled SBK key
[ 6.0242 ]
[ 6.0243 ] Parsing partition layout
[ 6.0261 ] tegraparser_v2 --pt flash.xml.tmp
[ 6.0290 ]
[ 6.0291 ] Creating list of images to be signed
[ 6.0309 ] tegrahost_v2 --chip 0x18 0 --partitionlayout flash.xml.bin --list images_list.xml zerosbk
[ 6.0695 ]
[ 6.0695 ] Generating signatures
[ 6.0706 ] tegrasign_v2 --key None --list images_list.xml --pubkeyhash pub_key.key
[ 6.0716 ] Assuming zero filled SBK key
[ 6.2947 ]
[ 6.2947 ] Reading BCT from device for further operations
[ 6.2947 ] Generating blob
[ 6.2956 ] tegrahost_v2 --chip 0x18 --align blob_nvtboot_recovery_cpu.bin
[ 6.2963 ]
[ 6.2969 ] tegrahost_v2 --appendsigheader blob_nvtboot_recovery_cpu.bin zerosbk
[ 6.2978 ]
[ 6.2987 ] tegrasign_v2 --key None --list blob_nvtboot_recovery_cpu_sigheader.bin_list.xml
[ 6.2993 ] Assuming zero filled SBK key
[ 6.3034 ]
[ 6.3043 ] tegrahost_v2 --updatesigheader blob_nvtboot_recovery_cpu_sigheader.bin.encrypt blob_nvtboot_recovery_cpu_sigheader.bin.hash zerosbk
[ 6.3052 ]
[ 6.3059 ] tegrahost_v2 --chip 0x18 --align blob_nvtboot_recovery.bin
[ 6.3066 ]
[ 6.3072 ] tegrahost_v2 --appendsigheader blob_nvtboot_recovery.bin zerosbk
[ 6.3080 ]
[ 6.3089 ] tegrasign_v2 --key None --list blob_nvtboot_recovery_sigheader.bin_list.xml
[ 6.3095 ] Assuming zero filled SBK key
[ 6.3114 ]
[ 6.3123 ] tegrahost_v2 --updatesigheader blob_nvtboot_recovery_sigheader.bin.encrypt blob_nvtboot_recovery_sigheader.bin.hash zerosbk
[ 6.3131 ]
[ 6.3138 ] tegrahost_v2 --chip 0x18 --align blob_preboot_d15_prod_cr.bin
[ 6.3145 ]
[ 6.3151 ] tegrahost_v2 --appendsigheader blob_preboot_d15_prod_cr.bin zerosbk
[ 6.3159 ]
[ 6.3167 ] tegrasign_v2 --key None --list blob_preboot_d15_prod_cr_sigheader.bin_list.xml
[ 6.3173 ] Assuming zero filled SBK key
[ 6.3188 ]
[ 6.3196 ] tegrahost_v2 --updatesigheader blob_preboot_d15_prod_cr_sigheader.bin.encrypt blob_preboot_d15_prod_cr_sigheader.bin.hash zerosbk
[ 6.3204 ]
[ 6.3211 ] tegrahost_v2 --chip 0x18 --align blob_mce_mts_d15_prod_cr.bin
[ 6.3219 ]
[ 6.3225 ] tegrahost_v2 --appendsigheader blob_mce_mts_d15_prod_cr.bin zerosbk
[ 6.3256 ]
[ 6.3265 ] tegrasign_v2 --key None --list blob_mce_mts_d15_prod_cr_sigheader.bin_list.xml
[ 6.3271 ] Assuming zero filled SBK key
[ 6.3703 ]
[ 6.3714 ] tegrahost_v2 --updatesigheader blob_mce_mts_d15_prod_cr_sigheader.bin.encrypt blob_mce_mts_d15_prod_cr_sigheader.bin.hash zerosbk
[ 6.3739 ]
[ 6.3747 ] tegrahost_v2 --chip 0x18 --align blob_bpmp.bin
[ 6.3754 ]
[ 6.3760 ] tegrahost_v2 --appendsigheader blob_bpmp.bin zerosbk
[ 6.3773 ]
[ 6.3782 ] tegrasign_v2 --key None --list blob_bpmp_sigheader.bin_list.xml
[ 6.3788 ] Assuming zero filled SBK key
[ 6.3899 ]
[ 6.3909 ] tegrahost_v2 --updatesigheader blob_bpmp_sigheader.bin.encrypt blob_bpmp_sigheader.bin.hash zerosbk
[ 6.3922 ]
[ 6.3929 ] tegrahost_v2 --chip 0x18 --align blob_tegra186-a02-bpmp-quill-p3310-1000-a00-00-te770d-ucm2.dtb
[ 6.3936 ]
[ 6.3942 ] tegrahost_v2 --appendsigheader blob_tegra186-a02-bpmp-quill-p3310-1000-a00-00-te770d-ucm2.dtb zerosbk
[ 6.3954 ]
[ 6.3962 ] tegrasign_v2 --key None --list blob_tegra186-a02-bpmp-quill-p3310-1000-a00-00-te770d-ucm2_sigheader.dtb_list.xml
[ 6.3968 ] Assuming zero filled SBK key
[ 6.4067 ]
[ 6.4076 ] tegrahost_v2 --updatesigheader blob_tegra186-a02-bpmp-quill-p3310-1000-a00-00-te770d-ucm2_sigheader.dtb.encrypt blob_tegra186-a02-bpmp-quill-p3310-1000-a00-00-te770d-ucm2_sigheader.dtb.hash zerosbk
[ 6.4088 ]
[ 6.4095 ] tegrahost_v2 --chip 0x18 --align blob_tos-trusty.img
[ 6.4102 ]
[ 6.4109 ] tegrahost_v2 --appendsigheader blob_tos-trusty.img zerosbk
[ 6.4119 ]
[ 6.4128 ] tegrasign_v2 --key None --list blob_tos-trusty_sigheader.img_list.xml
[ 6.4134 ] Assuming zero filled SBK key
[ 6.4201 ]
[ 6.4212 ] tegrahost_v2 --updatesigheader blob_tos-trusty_sigheader.img.encrypt blob_tos-trusty_sigheader.img.hash zerosbk
[ 6.4222 ]
[ 6.4230 ] tegrahost_v2 --chip 0x18 --align blob_eks.img
[ 6.4237 ]
[ 6.4244 ] tegrahost_v2 --appendsigheader blob_eks.img zerosbk
[ 6.4251 ]
[ 6.4259 ] tegrasign_v2 --key None --list blob_eks_sigheader.img_list.xml
[ 6.4266 ] Assuming zero filled SBK key
[ 6.4267 ]
[ 6.4276 ] tegrahost_v2 --updatesigheader blob_eks_sigheader.img.encrypt blob_eks_sigheader.img.hash zerosbk
[ 6.4283 ]
[ 6.4290 ] tegrahost_v2 --chip 0x18 --align blob_tegra186-quill-p3310-1000-a00-00-base.dtb
[ 6.4297 ]
[ 6.4304 ] tegrahost_v2 --appendsigheader blob_tegra186-quill-p3310-1000-a00-00-base.dtb zerosbk
[ 6.4314 ]
[ 6.4322 ] tegrasign_v2 --key None --list blob_tegra186-quill-p3310-1000-a00-00-base_sigheader.dtb_list.xml
[ 6.4329 ] Assuming zero filled SBK key
[ 6.4402 ]
[ 6.4411 ] tegrahost_v2 --updatesigheader blob_tegra186-quill-p3310-1000-a00-00-base_sigheader.dtb.encrypt blob_tegra186-quill-p3310-1000-a00-00-base_sigheader.dtb.hash zerosbk
[ 6.4422 ]
[ 6.4430 ] tegrahost_v2 --chip 0x18 --generateblob blob.xml blob.bin
[ 6.4436 ] number of images in blob are 9
[ 6.4438 ] blobsize is 4096808
[ 6.4438 ] Added binary blob_nvtboot_recovery_cpu_sigheader.bin.encrypt of size 203312
[ 6.4453 ] Added binary blob_nvtboot_recovery_sigheader.bin.encrypt of size 89360
[ 6.4455 ] Added binary blob_preboot_d15_prod_cr_sigheader.bin.encrypt of size 63104
[ 6.4458 ] Added binary blob_mce_mts_d15_prod_cr_sigheader.bin.encrypt of size 2082144
[ 6.4462 ] Added binary blob_bpmp_sigheader.bin.encrypt of size 533904
[ 6.4465 ] Added binary blob_tegra186-a02-bpmp-quill-p3310-1000-a00-00-te770d-ucm2_sigheader.dtb.encrypt of size 466128
[ 6.4469 ] Added binary blob_tos-trusty_sigheader.img.encrypt of size 313152
[ 6.4472 ] Added binary blob_eks_sigheader.img.encrypt of size 1440
[ 6.4474 ] Added binary blob_tegra186-quill-p3310-1000-a00-00-base_sigheader.dtb.encrypt of size 344112
[ 6.4485 ]
[ 6.4486 ] Sending bootloader and pre-requisite binaries
[ 6.4494 ] tegrarcm_v2 --download blob blob.bin
[ 6.4500 ] Applet version 01.00.0000
[ 6.4623 ] Sending blob
[ 6.4624 ] [................................................] 100%
[ 7.0009 ]
[ 7.0030 ] tegrarcm_v2 --boot recovery
[ 7.0049 ] Applet version 01.00.0000
[ 7.0200 ]
[ 8.0231 ] tegrarcm_v2 --isapplet
[ 8.0368 ]
[ 8.0388 ] tegradevflash_v2 --iscpubl
[ 8.0409 ] CPU Bootloader is not running on device.
[ 8.0528 ]
[ 9.0559 ] tegrarcm_v2 --isapplet
[ 9.0585 ]
[ 9.0605 ] tegradevflash_v2 --iscpubl
[ 9.0624 ] CPU Bootloader is not running on device.
[ 9.0727 ]
[ 10.0759 ] tegrarcm_v2 --isapplet
[ 10.0783 ]
[ 10.0802 ] tegradevflash_v2 --iscpubl
[ 10.0819 ] CPU Bootloader is not running on device.
[ 10.0927 ]
[ 11.0959 ] tegrarcm_v2 --isapplet
[ 11.1128 ]
[ 11.1149 ] tegradevflash_v2 --iscpubl
[ 11.1167 ] CPU Bootloader is not running on device.
[ 11.1288 ]
[ 12.1319 ] tegrarcm_v2 --isapplet
[ 12.1447 ]
[ 12.1465 ] tegradevflash_v2 --iscpubl
[ 12.1481 ] CPU Bootloader is not running on device.
[ 12.1568 ]
[ 13.1598 ] tegrarcm_v2 --isapplet
[ 13.1767 ]
[ 13.1788 ] tegradevflash_v2 --iscpubl
[ 13.1807 ] CPU Bootloader is not running on device.
[ 13.1926 ]
[ 14.1957 ] tegrarcm_v2 --isapplet
[ 14.1982 ]
[ 14.2000 ] tegradevflash_v2 --iscpubl
[ 14.2018 ] CPU Bootloader is not running on device.
[ 14.2128 ]
[ 15.2158 ] tegrarcm_v2 --isapplet
[ 15.2183 ]
[ 15.2203 ] tegradevflash_v2 --iscpubl
[ 15.2221 ] CPU Bootloader is not running on device.
[ 15.2328 ]
[ 16.2348 ] tegrarcm_v2 --isapplet
[ 16.2372 ]
[ 16.2390 ] tegradevflash_v2 --iscpubl
[ 16.2407 ] CPU Bootloader is not running on device.
[ 16.2528 ]
[ 17.2559 ] tegrarcm_v2 --isapplet
[ 17.2584 ]
[ 17.2603 ] tegradevflash_v2 --iscpubl
[ 17.2620 ] CPU Bootloader is not running on device.
[ 17.2728 ]
[ 18.2759 ] tegrarcm_v2 --isapplet
[ 18.2785 ]
[ 18.2803 ] tegradevflash_v2 --iscpubl
[ 18.2821 ] CPU Bootloader is not running on device.
[ 18.2927 ]
[ 19.2959 ] tegrarcm_v2 --isapplet
[ 19.2985 ]
[ 19.3006 ] tegradevflash_v2 --iscpubl
[ 19.3025 ] CPU Bootloader is not running on device.
[ 19.3128 ]
[ 20.3162 ] tegrarcm_v2 --isapplet
[ 20.3287 ]
[ 20.3306 ] tegradevflash_v2 --iscpubl
[ 20.3324 ] CPU Bootloader is not running on device.
[ 20.3447 ]
[ 21.3478 ] tegrarcm_v2 --isapplet
[ 21.3608 ]
[ 21.3629 ] tegradevflash_v2 --iscpubl
[ 21.3648 ] CPU Bootloader is not running on device.
[ 21.3807 ]
[ 22.3838 ] tegrarcm_v2 --isapplet
[ 22.3863 ]
[ 22.3882 ] tegradevflash_v2 --iscpubl
[ 22.3899 ] CPU Bootloader is not running on device.
[ 22.4007 ]
[ 23.4039 ] tegrarcm_v2 --isapplet
[ 23.4064 ]
[ 23.4083 ] tegradevflash_v2 --iscpubl
[ 23.4100 ] CPU Bootloader is not running on device.
[ 23.4247 ]
[ 24.4278 ] tegrarcm_v2 --isapplet
[ 24.4407 ]
[ 24.4425 ] tegradevflash_v2 --iscpubl
[ 24.4441 ] CPU Bootloader is not running on device.
[ 24.4527 ]
[ 25.4557 ] tegrarcm_v2 --isapplet
[ 25.4582 ]
[ 25.4601 ] tegradevflash_v2 --iscpubl
[ 25.4620 ] CPU Bootloader is not running on device.
[ 25.4728 ]
[ 26.4758 ] tegrarcm_v2 --isapplet
[ 26.4783 ]
[ 26.4802 ] tegradevflash_v2 --iscpubl
[ 26.4819 ] CPU Bootloader is not running on device.
[ 26.4929 ]
[ 27.4959 ] tegrarcm_v2 --isapplet
[ 27.4982 ]
[ 27.5000 ] tegradevflash_v2 --iscpubl
[ 27.5020 ] CPU Bootloader is not running on device.
[ 27.5168 ]
[ 28.5198 ] tegrarcm_v2 --isapplet
[ 28.5223 ]
[ 28.5242 ] tegradevflash_v2 --iscpubl
[ 28.5258 ] CPU Bootloader is not running on device.
[ 28.5368 ]
[ 29.5398 ] tegrarcm_v2 --isapplet
[ 29.5423 ]
[ 29.5442 ] tegradevflash_v2 --iscpubl
[ 29.5460 ] CPU Bootloader is not running on device.
[ 29.5569 ]
[ 30.5601 ] tegrarcm_v2 --isapplet
[ 30.5626 ]
[ 30.5645 ] tegradevflash_v2 --iscpubl
[ 30.5662 ] CPU Bootloader is not running on device.
[ 30.5767 ]
[ 31.5799 ] tegrarcm_v2 --isapplet
[ 31.5824 ]
[ 31.5843 ] tegradevflash_v2 --iscpubl
[ 31.5861 ] CPU Bootloader is not running on device.
[ 31.5967 ]
[ 32.6001 ] tegrarcm_v2 --isapplet
[ 32.6028 ]
[ 32.6048 ] tegradevflash_v2 --iscpubl
[ 32.6066 ] CPU Bootloader is not running on device.
[ 32.6168 ]
[ 33.6189 ] tegrarcm_v2 --isapplet
[ 33.6203 ]
[ 33.6213 ] tegradevflash_v2 --iscpubl
[ 33.6222 ] CPU Bootloader is not running on device.
[ 33.6328 ]
[ 34.6359 ] tegrarcm_v2 --isapplet
[ 34.6384 ]
[ 34.6403 ] tegradevflash_v2 --iscpubl
[ 34.6420 ] CPU Bootloader is not running on device.
[ 34.6529 ]
[ 35.6560 ] tegrarcm_v2 --isapplet
[ 35.6585 ]
[ 35.6604 ] tegradevflash_v2 --iscpubl
[ 35.6621 ] CPU Bootloader is not running on device.
[ 35.6728 ]
[ 36.6761 ] tegrarcm_v2 --isapplet
[ 36.6788 ]
[ 36.6808 ] tegradevflash_v2 --iscpubl
[ 36.6827 ] CPU Bootloader is not running on device.
[ 36.6928 ]
[ 37.6961 ] tegrarcm_v2 --isapplet
[ 37.6988 ]
[ 37.7008 ] tegradevflash_v2 --iscpubl
[ 37.7026 ] CPU Bootloader is not running on device.
[ 37.7128 ]
Error: None of the bootloaders are running on device. Check the UART log.
*** The [APP] has been read successfully. ***
Converting RAW image to Sparse image...
mv: cannot stat '/home/wxr/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3489-0080/Linux_for_Tegra/system.img': No such file or directory
open input file /home/wxr/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3489-0080/Linux_for_Tegra/system.img.raw failed.
hello wang.xiangru,
these failure should caused by unsuccessful communication between Jetson platform and host machine.
may I know what’s your environment setups, for example, did you use a laptop to flash Jetson platform?
thanks
hello JerryChang,
Thank you very much.
I use a desktop computer which is in Ubuntu 16.04.Not a laptop,neither a virtual machine.
JerryChang:
hello wang.xiangru,
thanks
hello JerryChang,
I noticed something which might actually be a simple issue. Note this error:
Earlier you had created system.img through a clone, but the clone was run in the same directory as “flash.sh”. The location where the clone must be placed to be able to use it is not that directory. Instead:
cd /home/wxr/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3489-0080/Linux_for_Tegra/
# I suggest "cp" so you can't overwrite this, but this takes a lot of disk space and time
# to copy such a large file...so for the example I am using "mv":
sudo chown wxr.wxr ./system.*
mv ./system.img ./bootloader/
# Now flash like usual, making sure the "-r" option is there...
sudo ./flash.sh <b>-r</b> jetson-tx2 mmcblk0p1
Is your system.img just in need of moving?
Thanks a lot.
At the begining, the falsh.sh file was in the Linux_for_Tegra folder,while an system.img file was in the bootloader folder.Then I did not move any file,just changed the owner of system.img.Then I flashed it and got the error as follows.
sudo ./flash.sh -r jetson-tx2 mmcblk0p1
version 1.0.0
[ 0.0038 ] Generating RCM messages
[ 0.0302 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 0 --download rcm /home/wxr/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3489-0080/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin 0 0
[ 0.0313 ] RCM 0 is saved as rcm_0.rcm
[ 0.0698 ] RCM 1 is saved as rcm_1.rcm
[ 0.0698 ] List of rcm files are saved in rcm_list.xml
[ 0.0698 ]
[ 0.0698 ] Signing RCM messages
[ 0.0859 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0869 ] Assuming zero filled SBK key
[ 0.1167 ]
[ 0.1167 ] Copying signature to RCM mesages
[ 0.1179 ] tegrarcm_v2 --chip 0x18 0 --updatesig rcm_list_signed.xml
[ 0.1192 ]
[ 0.1192 ] Boot Rom communication
[ 0.1201 ] tegrarcm_v2 --chip 0x18 0 --rcm rcm_list_signed.xml --skipuid
[ 0.1210 ] RCM version 0X180001
[ 0.1220 ] Boot Rom communication completed
[ 1.1282 ]
[ 2.1304 ] tegrarcm_v2 --isapplet
[ 2.1314 ] Applet version 01.00.0000
[ 2.1338 ]
[ 2.1347 ] Retrieving EEPROM data
[ 2.1349 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/wxr/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3489-0080/Linux_for_Tegra/bootloader/cvm.bin
[ 2.1358 ] Applet version 01.00.0000
[ 2.1613 ] Saved platform info in /home/wxr/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3489-0080/Linux_for_Tegra/bootloader/cvm.bin
[ 2.2339 ]
Reusing existing system.img...
done.
./tegraflash.py --bl nvtboot_recovery_cpu.bin --sdram_config P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --odmdata 0x1090000 --applet mb1_recovery_prod.bin --cmd "flash; reboot" --cfg flash.xml --chip 0x18 --misc_config tegra186-mb1-bct-misc-si-l4t.cfg --pinmux_config tegra186-mb1-bct-pinmux-quill-p3310-1000-a00.cfg --pmic_config tegra186-mb1-bct-pmic-quill-p3310-1000-a00.cfg --pmc_config tegra186-mb1-bct-pad-quill-p3310-1000-a00.cfg --prod_config tegra186-mb1-bct-prod-quill-p3310-1000-a00.cfg --scr_config minimal_scr.cfg --scr_cold_boot_config mobile_scr.cfg --br_cmd_config tegra186-mb1-bct-bootrom-quill-p3310-1000-a00.cfg --dev_params emmc.cfg --bins "mb2_bootloader nvtboot_recovery.bin; mts_preboot preboot_d15_prod_cr.bin; mts_bootpack mce_mts_d15_prod_cr.bin; bpmp_fw bpmp.bin; bpmp_fw_dtb tegra186-a02-bpmp-quill-p3310-1000-a00-00-te770d-ucm2.dtb; tlk tos-trusty.img; eks eks.img; bootloader_dtb tegra186-quill-p3310-1000-a00-00-base.dtb"
saving flash command in /home/wxr/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3489-0080/Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /home/wxr/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3489-0080/Linux_for_Tegra/bootloader/flash_win.bat
*** Flashing target device started. ***
version 1.0.0
[ 0.0010 ] tegrasign_v2 --key None --getmode mode.txt
[ 0.0019 ] Assuming zero filled SBK key
[ 0.0021 ]
[ 0.0021 ] Generating RCM messages
[ 0.0030 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 0 --download rcm mb1_recovery_prod.bin 0 0
[ 0.0043 ]
[ 0.0043 ] Signing RCM messages
[ 0.0052 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0063 ] Assuming zero filled SBK key
[ 0.0100 ]
[ 0.0100 ] Copying signature to RCM mesages
[ 0.0110 ] tegrarcm_v2 --chip 0x18 0 --updatesig rcm_list_signed.xml
[ 0.0123 ]
[ 0.0123 ] Parsing partition layout
[ 0.0391 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.0471 ]
[ 0.0471 ] Creating list of images to be signed
[ 0.0543 ] tegrahost_v2 --chip 0x18 0 --partitionlayout flash.xml.bin --list images_list.xml zerosbk
[ 0.0839 ]
[ 0.0839 ] Generating signatures
[ 0.0850 ] tegrasign_v2 --key None --list images_list.xml --pubkeyhash pub_key.key
[ 0.0859 ] Assuming zero filled SBK key
[ 0.3701 ]
[ 0.3701 ] Generating br-bct
[ 0.3874 ] Updating dev and MSS params in BR BCT
[ 0.3875 ] tegrabct_v2 --dev_param emmc.cfg --sdram P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --brbct br_bct.cfg --chip 0x18 0
[ 0.4218 ]
[ 0.4218 ] Updating bl info
[ 0.4229 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 0.4248 ]
[ 0.4248 ] Updating smd info
[ 0.4258 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --updatesmdinfo flash.xml.bin
[ 0.4271 ]
[ 0.4271 ] Updating Odmdata
[ 0.4281 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --updatefields Odmdata =0x1090000
[ 0.4295 ]
[ 0.4295 ] Get Signed section of bct
[ 0.4305 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --listbct bct_list.xml
[ 0.4317 ]
[ 0.4326 ] tegrasign_v2 --key None --list bct_list.xml --pubkeyhash pub_key.key
[ 0.4335 ] Assuming zero filled SBK key
[ 0.4337 ]
[ 0.4337 ] Updating BCT with signature
[ 0.4347 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --updatesig bct_list_signed.xml
[ 0.4357 ]
[ 0.4358 ] Generating coldboot mb1-bct
[ 0.4367 ] tegrabct_v2 --chip 0x18 0 --mb1bct mb1_cold_boot_bct.cfg --sdram P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --misc tegra186-mb1-bct-misc-si-l4t.cfg --scr mobile_scr.cfg --pinmux tegra186-mb1-bct-pinmux-quill-p3310-1000-a00.cfg --pmc tegra186-mb1-bct-pad-quill-p3310-1000-a00.cfg --pmic tegra186-mb1-bct-pmic-quill-p3310-1000-a00.cfg --brcommand tegra186-mb1-bct-bootrom-quill-p3310-1000-a00.cfg --prod tegra186-mb1-bct-prod-quill-p3310-1000-a00.cfg
[ 0.4376 ] MB1-BCT version: 0xf
[ 0.4378 ] Copying Sdram info from 2 to 3 set
[ 0.4554 ] Packing sdram param for instance[0]
[ 0.4556 ] Packing sdram param for instance[1]
[ 0.4558 ] Packing sdram param for instance[2]
[ 0.4560 ] Packing sdram param for instance[3]
[ 0.4562 ] Parsing config file :tegra186-mb1-bct-pinmux-quill-p3310-1000-a00.cfg
[ 0.4566 ] Appending platform config data of size :- 2952
[ 0.4569 ] Parsing config file :mobile_scr.cfg
[ 0.4572 ] Appending platform config data of size :- 12240
[ 0.4578 ] Parsing config file :tegra186-mb1-bct-pad-quill-p3310-1000-a00.cfg
[ 0.4580 ] Appending platform config data of size :- 24
[ 0.4580 ]
[ 0.4580 ] Parsing config file :tegra186-mb1-bct-pmic-quill-p3310-1000-a00.cfg
[ 0.4580 ] Appending platform config data of size :- 468
[ 0.4580 ]
[ 0.4580 ] Parsing config file :tegra186-mb1-bct-bootrom-quill-p3310-1000-a00.cfg
[ 0.4580 ] Appending platform config data of size :- 64
[ 0.4580 ]
[ 0.4580 ] Parsing config file :tegra186-mb1-bct-prod-quill-p3310-1000-a00.cfg
[ 0.4580 ] Appending platform config data of size :- 1628
[ 0.4580 ]
[ 0.4580 ] Updating mb1-bct with firmware information
[ 0.4590 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 0.4600 ] MB1-BCT version: 0xf
[ 0.4605 ]
[ 0.4605 ] Updating mb1-bct with storage information
[ 0.4614 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 0.4623 ] MB1-BCT version: 0xf
[ 0.4627 ]
[ 0.4637 ] tegrahost_v2 --chip 0x18 --align mb1_cold_boot_bct_MB1.bct
[ 0.4646 ]
[ 0.4655 ] tegrahost_v2 --appendsigheader mb1_cold_boot_bct_MB1.bct zerosbk
[ 0.4665 ]
[ 0.4676 ] tegrasign_v2 --key None --list mb1_cold_boot_bct_MB1_sigheader.bct_list.xml
[ 0.4684 ] Assuming zero filled SBK key
[ 0.4699 ]
[ 0.4710 ] tegrahost_v2 --updatesigheader mb1_cold_boot_bct_MB1_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_sigheader.bct.hash zerosbk
[ 0.4719 ]
[ 0.4720 ] Generating recovery mb1-bct
[ 0.4728 ] tegrabct_v2 --chip 0x18 0 --mb1bct mb1_bct.cfg --sdram P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --misc tegra186-mb1-bct-misc-si-l4t.cfg --scr minimal_scr.cfg --pinmux tegra186-mb1-bct-pinmux-quill-p3310-1000-a00.cfg --pmc tegra186-mb1-bct-pad-quill-p3310-1000-a00.cfg --pmic tegra186-mb1-bct-pmic-quill-p3310-1000-a00.cfg --brcommand tegra186-mb1-bct-bootrom-quill-p3310-1000-a00.cfg --prod tegra186-mb1-bct-prod-quill-p3310-1000-a00.cfg
[ 0.4736 ] MB1-BCT version: 0xf
[ 0.4737 ] Copying Sdram info from 2 to 3 set
[ 0.4900 ] Packing sdram param for instance[0]
[ 0.4902 ] Packing sdram param for instance[1]
[ 0.4905 ] Packing sdram param for instance[2]
[ 0.4908 ] Packing sdram param for instance[3]
[ 0.4910 ] Parsing config file :tegra186-mb1-bct-pinmux-quill-p3310-1000-a00.cfg
[ 0.4914 ] Appending platform config data of size :- 2952
[ 0.4916 ] Parsing config file :minimal_scr.cfg
[ 0.4918 ] Appending platform config data of size :- 12240
[ 0.4921 ] Parsing config file :tegra186-mb1-bct-pad-quill-p3310-1000-a00.cfg
[ 0.4924 ] Appending platform config data of size :- 24
[ 0.4925 ]
[ 0.4925 ] Parsing config file :tegra186-mb1-bct-pmic-quill-p3310-1000-a00.cfg
[ 0.4925 ] Appending platform config data of size :- 468
[ 0.4925 ]
[ 0.4925 ] Parsing config file :tegra186-mb1-bct-bootrom-quill-p3310-1000-a00.cfg
[ 0.4925 ] Appending platform config data of size :- 64
[ 0.4925 ]
[ 0.4925 ] Parsing config file :tegra186-mb1-bct-prod-quill-p3310-1000-a00.cfg
[ 0.4925 ] Appending platform config data of size :- 1628
[ 0.4925 ]
[ 0.4925 ] Updating mb1-bct with firmware information
[ 0.4934 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 0.4944 ] MB1-BCT version: 0xf
[ 0.4948 ]
[ 0.4948 ] Updating mb1-bct with storage information
[ 0.4957 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 0.4964 ] MB1-BCT version: 0xf
[ 0.4968 ]
[ 0.4975 ] tegrahost_v2 --chip 0x18 --align mb1_bct_MB1.bct
[ 0.4983 ]
[ 0.4991 ] tegrahost_v2 --appendsigheader mb1_bct_MB1.bct zerosbk
[ 0.5000 ]
[ 0.5012 ] tegrasign_v2 --key None --list mb1_bct_MB1_sigheader.bct_list.xml
[ 0.5020 ] Assuming zero filled SBK key
[ 0.5034 ]
[ 0.5046 ] tegrahost_v2 --updatesigheader mb1_bct_MB1_sigheader.bct.encrypt mb1_bct_MB1_sigheader.bct.hash zerosbk
[ 0.5056 ]
[ 0.5056 ] Copying signatures
[ 0.5066 ] tegrahost_v2 --chip 0x18 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 0.6086 ]
[ 0.6086 ] Boot Rom communication
[ 0.6096 ] tegrarcm_v2 --chip 0x18 0 --rcm rcm_list_signed.xml
[ 0.6106 ] BootRom is not running
[ 5.6091 ]
[ 6.6114 ] tegrarcm_v2 --isapplet
[ 6.6123 ] Applet version 01.00.0000
[ 6.6232 ]
[ 6.6232 ] Sending BCTs
[ 6.6242 ] tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 6.6250 ] Applet version 01.00.0000
[ 6.6512 ] Sending bct_bootrom
[ 6.6513 ] [................................................] 100%
[ 6.6527 ] Sending bct_mb1
[ 6.6538 ] [................................................] 100%
[ 6.6796 ]
[ 6.6796 ] Generating blob
[ 6.6808 ] tegrahost_v2 --chip 0x18 --align blob_nvtboot_recovery_cpu.bin
[ 6.6817 ]
[ 6.6826 ] tegrahost_v2 --appendsigheader blob_nvtboot_recovery_cpu.bin zerosbk
[ 6.6839 ]
[ 6.6852 ] tegrasign_v2 --key None --list blob_nvtboot_recovery_cpu_sigheader.bin_list.xml
[ 6.6861 ] Assuming zero filled SBK key
[ 6.6925 ]
[ 6.6939 ] tegrahost_v2 --updatesigheader blob_nvtboot_recovery_cpu_sigheader.bin.encrypt blob_nvtboot_recovery_cpu_sigheader.bin.hash zerosbk
[ 6.6951 ]
[ 6.6961 ] tegrahost_v2 --chip 0x18 --align blob_nvtboot_recovery.bin
[ 6.6970 ]
[ 6.6979 ] tegrahost_v2 --appendsigheader blob_nvtboot_recovery.bin zerosbk
[ 6.6990 ]
[ 6.7001 ] tegrasign_v2 --key None --list blob_nvtboot_recovery_sigheader.bin_list.xml
[ 6.7010 ] Assuming zero filled SBK key
[ 6.7039 ]
[ 6.7053 ] tegrahost_v2 --updatesigheader blob_nvtboot_recovery_sigheader.bin.encrypt blob_nvtboot_recovery_sigheader.bin.hash zerosbk
[ 6.7064 ]
[ 6.7075 ] tegrahost_v2 --chip 0x18 --align blob_preboot_d15_prod_cr.bin
[ 6.7085 ]
[ 6.7095 ] tegrahost_v2 --appendsigheader blob_preboot_d15_prod_cr.bin zerosbk
[ 6.7107 ]
[ 6.7120 ] tegrasign_v2 --key None --list blob_preboot_d15_prod_cr_sigheader.bin_list.xml
[ 6.7128 ] Assuming zero filled SBK key
[ 6.7151 ]
[ 6.7165 ] tegrahost_v2 --updatesigheader blob_preboot_d15_prod_cr_sigheader.bin.encrypt blob_preboot_d15_prod_cr_sigheader.bin.hash zerosbk
[ 6.7176 ]
[ 6.7187 ] tegrahost_v2 --chip 0x18 --align blob_mce_mts_d15_prod_cr.bin
[ 6.7196 ]
[ 6.7206 ] tegrahost_v2 --appendsigheader blob_mce_mts_d15_prod_cr.bin zerosbk
[ 6.7248 ]
[ 6.7261 ] tegrasign_v2 --key None --list blob_mce_mts_d15_prod_cr_sigheader.bin_list.xml
[ 6.7269 ] Assuming zero filled SBK key
[ 6.7818 ]
[ 6.7830 ] tegrahost_v2 --updatesigheader blob_mce_mts_d15_prod_cr_sigheader.bin.encrypt blob_mce_mts_d15_prod_cr_sigheader.bin.hash zerosbk
[ 6.7862 ]
[ 6.7873 ] tegrahost_v2 --chip 0x18 --align blob_bpmp.bin
[ 6.7882 ]
[ 6.7891 ] tegrahost_v2 --appendsigheader blob_bpmp.bin zerosbk
[ 6.7909 ]
[ 6.7922 ] tegrasign_v2 --key None --list blob_bpmp_sigheader.bin_list.xml
[ 6.7931 ] Assuming zero filled SBK key
[ 6.8077 ]
[ 6.8091 ] tegrahost_v2 --updatesigheader blob_bpmp_sigheader.bin.encrypt blob_bpmp_sigheader.bin.hash zerosbk
[ 6.8107 ]
[ 6.8118 ] tegrahost_v2 --chip 0x18 --align blob_tegra186-a02-bpmp-quill-p3310-1000-a00-00-te770d-ucm2.dtb
[ 6.8127 ]
[ 6.8136 ] tegrahost_v2 --appendsigheader blob_tegra186-a02-bpmp-quill-p3310-1000-a00-00-te770d-ucm2.dtb zerosbk
[ 6.8152 ]
[ 6.8165 ] tegrasign_v2 --key None --list blob_tegra186-a02-bpmp-quill-p3310-1000-a00-00-te770d-ucm2_sigheader.dtb_list.xml
[ 6.8174 ] Assuming zero filled SBK key
[ 6.8304 ]
[ 6.8317 ] tegrahost_v2 --updatesigheader blob_tegra186-a02-bpmp-quill-p3310-1000-a00-00-te770d-ucm2_sigheader.dtb.encrypt blob_tegra186-a02-bpmp-quill-p3310-1000-a00-00-te770d-ucm2_sigheader.dtb.hash zerosbk
[ 6.8332 ]
[ 6.8342 ] tegrahost_v2 --chip 0x18 --align blob_tos-trusty.img
[ 6.8350 ]
[ 6.8358 ] tegrahost_v2 --appendsigheader blob_tos-trusty.img zerosbk
[ 6.8372 ]
[ 6.8383 ] tegrasign_v2 --key None --list blob_tos-trusty_sigheader.img_list.xml
[ 6.8392 ] Assuming zero filled SBK key
[ 6.8481 ]
[ 6.8494 ] tegrahost_v2 --updatesigheader blob_tos-trusty_sigheader.img.encrypt blob_tos-trusty_sigheader.img.hash zerosbk
[ 6.8509 ]
[ 6.8519 ] tegrahost_v2 --chip 0x18 --align blob_eks.img
[ 6.8527 ]
[ 6.8536 ] tegrahost_v2 --appendsigheader blob_eks.img zerosbk
[ 6.8544 ]
[ 6.8555 ] tegrasign_v2 --key None --list blob_eks_sigheader.img_list.xml
[ 6.8563 ] Assuming zero filled SBK key
[ 6.8565 ]
[ 6.8576 ] tegrahost_v2 --updatesigheader blob_eks_sigheader.img.encrypt blob_eks_sigheader.img.hash zerosbk
[ 6.8584 ]
[ 6.8594 ] tegrahost_v2 --chip 0x18 --align blob_tegra186-quill-p3310-1000-a00-00-base.dtb
[ 6.8602 ]
[ 6.8610 ] tegrahost_v2 --appendsigheader blob_tegra186-quill-p3310-1000-a00-00-base.dtb zerosbk
[ 6.8623 ]
[ 6.8633 ] tegrasign_v2 --key None --list blob_tegra186-quill-p3310-1000-a00-00-base_sigheader.dtb_list.xml
[ 6.8641 ] Assuming zero filled SBK key
[ 6.8735 ]
[ 6.8749 ] tegrahost_v2 --updatesigheader blob_tegra186-quill-p3310-1000-a00-00-base_sigheader.dtb.encrypt blob_tegra186-quill-p3310-1000-a00-00-base_sigheader.dtb.hash zerosbk
[ 6.8766 ]
[ 6.8778 ] tegrahost_v2 --chip 0x18 --generateblob blob.xml blob.bin
[ 6.8787 ] number of images in blob are 9
[ 6.8790 ] blobsize is 4096808
[ 6.8791 ] Added binary blob_nvtboot_recovery_cpu_sigheader.bin.encrypt of size 203312
[ 6.8810 ] Added binary blob_nvtboot_recovery_sigheader.bin.encrypt of size 89360
[ 6.8815 ] Added binary blob_preboot_d15_prod_cr_sigheader.bin.encrypt of size 63104
[ 6.8820 ] Added binary blob_mce_mts_d15_prod_cr_sigheader.bin.encrypt of size 2082144
[ 6.8825 ] Added binary blob_bpmp_sigheader.bin.encrypt of size 533904
[ 6.8830 ] Added binary blob_tegra186-a02-bpmp-quill-p3310-1000-a00-00-te770d-ucm2_sigheader.dtb.encrypt of size 466128
[ 6.8837 ] Added binary blob_tos-trusty_sigheader.img.encrypt of size 313152
[ 6.8842 ] Added binary blob_eks_sigheader.img.encrypt of size 1440
[ 6.8846 ] Added binary blob_tegra186-quill-p3310-1000-a00-00-base_sigheader.dtb.encrypt of size 344112
[ 6.8853 ]
[ 6.8854 ] Sending bootloader and pre-requisite binaries
[ 6.8862 ] tegrarcm_v2 --download blob blob.bin
[ 6.8869 ] Applet version 01.00.0000
[ 6.8997 ] Sending blob
[ 7.0211 ]
Error: Return value 1
Command tegrarcm_v2 --download blob blob.bin
hello wang.xiangru,
“-r” options would skip building and reuse existing system.img.
could you please have a try to make system image locally by exclude -r options.
thanks
hello JerryChang,
I have had a try as you told me.I got this error.Could you please help me to analyze it?
sudo ./flash.sh system.img jetson-tx2 mmcblk0p1
version 1.0.0
[ 0.0077 ] Generating RCM messages
[ 0.0319 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 0 --download rcm /home/wxr/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3489-0080/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin 0 0
[ 0.0340 ] RCM 0 is saved as rcm_0.rcm
[ 0.0712 ] RCM 1 is saved as rcm_1.rcm
[ 0.0712 ] List of rcm files are saved in rcm_list.xml
[ 0.0712 ]
[ 0.0713 ] Signing RCM messages
[ 0.0955 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0975 ] Assuming zero filled SBK key
[ 0.1058 ]
[ 0.1058 ] Copying signature to RCM mesages
[ 0.1079 ] tegrarcm_v2 --chip 0x18 0 --updatesig rcm_list_signed.xml
[ 0.1107 ]
[ 0.1107 ] Boot Rom communication
[ 0.1126 ] tegrarcm_v2 --chip 0x18 0 --rcm rcm_list_signed.xml --skipuid
[ 0.1144 ] RCM version 0X180001
[ 0.1157 ] Boot Rom communication completed
[ 1.1220 ]
[ 2.1251 ] tegrarcm_v2 --isapplet
[ 2.1271 ] Applet version 01.00.0000
[ 2.1399 ]
[ 2.1422 ] Retrieving EEPROM data
[ 2.1424 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/wxr/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3489-0080/Linux_for_Tegra/bootloader/cvm.bin
[ 2.1442 ] Applet version 01.00.0000
[ 2.1676 ] Saved platform info in /home/wxr/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3489-0080/Linux_for_Tegra/bootloader/cvm.bin
[ 2.2405 ]
Making system.img...
populating rootfs from /home/wxr/nvidia/nvidia_sdk/JetPack_4.2.2_Linux_GA_P3489-0080/Linux_for_Tegra/rootfs ... done.
Sync'ing system.img ... done.
---- Raw to Sparse Image Converter v1.0 ----------------------------
0: RAW: 4255744( 1039 blks) ==> 28:4255756
1: SKP: 8192( 2 blks) ==> 4255784:12
2: RAW: 4096( 1 blks) ==> 4255796:4108
3: SKP: 61440( 15 blks) ==> 4259904:12
4: RAW: 1495040( 365 blks) ==> 4259916:1495052
5: SKP: 32059392( 7827 blks) ==> 5754968:12
#the information from 6 to 4912 are omitted by me
4913: SKP: 24137728( 5893 blks) ==> 4626904680:12
4914: RAW: 14921728( 3643 blks) ==> 4626904692:14921740
4915: SKP: 12288( 3 blks) ==> 4641826432:12
4916: RAW: 1843200( 450 blks) ==> 4641826444:1843212
4917: SKP: 1929379840( 471040 blks) ==> 4643669656:12
-- Total: ---------------------------------------------------
4918 CHUNK 30064771072(7340032 blks) ==> 4643669668(1133694 blks)
done.
system.img built successfully.
version 1.0.0
[ 0.0371 ] tegrasign_v2 --key None --getmode mode.txt
[ 0.0393 ] Assuming zero filled SBK key
[ 0.0401 ]
[ 0.0403 ] Generating RCM messages
[ 0.0545 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 0 --download rcm mb1_recovery_prod.bin 0 0
[ 0.0566 ] RCM 0 is saved as rcm_0.rcm
[ 0.0610 ] RCM 1 is saved as rcm_1.rcm
[ 0.0610 ] List of rcm files are saved in rcm_list.xml
[ 0.0610 ]
[ 0.0610 ] Signing RCM messages
[ 0.0631 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0650 ] Assuming zero filled SBK key
[ 0.0729 ]
[ 0.0730 ] Copying signature to RCM mesages
[ 0.0750 ] tegrarcm_v2 --chip 0x18 0 --updatesig rcm_list_signed.xml
[ 0.0777 ]
[ 0.0778 ] Parsing partition layout
[ 0.0911 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.0944 ]
[ 0.0944 ] Creating list of images to be signed
[ 0.1064 ] tegrahost_v2 --chip 0x18 0 --partitionlayout flash.xml.bin --list images_list.xml zerosbk
[ 0.3248 ]
[ 0.3249 ] Generating signatures
[ 0.3271 ] tegrasign_v2 --key None --list images_list.xml --pubkeyhash pub_key.key
[ 0.3289 ] Assuming zero filled SBK key
[ 0.5797 ]
[ 0.5797 ] Generating br-bct
[ 0.6059 ] Updating dev and MSS params in BR BCT
[ 0.6060 ] tegrabct_v2 --dev_param emmc.cfg --sdram P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --brbct br_bct.cfg --chip 0x18 0
[ 0.6470 ]
[ 0.6470 ] Updating bl info
[ 0.6479 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 0.6494 ]
[ 0.6494 ] Updating smd info
[ 0.6501 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --updatesmdinfo flash.xml.bin
[ 0.6509 ]
[ 0.6510 ] Updating Odmdata
[ 0.6516 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --updatefields Odmdata =0x1090000
[ 0.6525 ]
[ 0.6526 ] Get Signed section of bct
[ 0.6532 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --listbct bct_list.xml
[ 0.6540 ]
[ 0.6547 ] tegrasign_v2 --key None --list bct_list.xml --pubkeyhash pub_key.key
[ 0.6553 ] Assuming zero filled SBK key
[ 0.6554 ]
[ 0.6554 ] Updating BCT with signature
[ 0.6561 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --updatesig bct_list_signed.xml
[ 0.6570 ]
[ 0.6570 ] Generating coldboot mb1-bct
[ 0.6577 ] tegrabct_v2 --chip 0x18 0 --mb1bct mb1_cold_boot_bct.cfg --sdram P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --misc tegra186-mb1-bct-misc-si-l4t.cfg --scr mobile_scr.cfg --pinmux tegra186-mb1-bct-pinmux-quill-p3310-1000-a00.cfg --pmc tegra186-mb1-bct-pad-quill-p3310-1000-a00.cfg --pmic tegra186-mb1-bct-pmic-quill-p3310-1000-a00.cfg --brcommand tegra186-mb1-bct-bootrom-quill-p3310-1000-a00.cfg --prod tegra186-mb1-bct-prod-quill-p3310-1000-a00.cfg
[ 0.6584 ] MB1-BCT version: 0xf
[ 0.6585 ] Copying Sdram info from 2 to 3 set
[ 0.6710 ] Packing sdram param for instance[0]
[ 0.6712 ] Packing sdram param for instance[1]
[ 0.6713 ] Packing sdram param for instance[2]
[ 0.6715 ] Packing sdram param for instance[3]
[ 0.6716 ] Parsing config file :tegra186-mb1-bct-pinmux-quill-p3310-1000-a00.cfg
[ 0.6720 ] Appending platform config data of size :- 2952
[ 0.6722 ] Parsing config file :mobile_scr.cfg
[ 0.6724 ] Appending platform config data of size :- 12240
[ 0.6734 ] Parsing config file :tegra186-mb1-bct-pad-quill-p3310-1000-a00.cfg
[ 0.6737 ] Appending platform config data of size :- 24
[ 0.6739 ] Parsing config file :tegra186-mb1-bct-pmic-quill-p3310-1000-a00.cfg
[ 0.6743 ] Appending platform config data of size :- 468
[ 0.6892 ] Parsing config file :tegra186-mb1-bct-bootrom-quill-p3310-1000-a00.cfg
[ 0.6894 ] Appending platform config data of size :- 64
[ 0.6895 ]
[ 0.6895 ] Parsing config file :tegra186-mb1-bct-prod-quill-p3310-1000-a00.cfg
[ 0.6895 ] Appending platform config data of size :- 1628
[ 0.6895 ]
[ 0.6895 ] Updating mb1-bct with firmware information
[ 0.6902 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 0.6908 ] MB1-BCT version: 0xf
[ 0.6912 ]
[ 0.6912 ] Updating mb1-bct with storage information
[ 0.6918 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 0.6924 ] MB1-BCT version: 0xf
[ 0.6927 ]
[ 0.6934 ] tegrahost_v2 --chip 0x18 --align mb1_cold_boot_bct_MB1.bct
[ 0.6940 ]
[ 0.6947 ] tegrahost_v2 --appendsigheader mb1_cold_boot_bct_MB1.bct zerosbk
[ 0.6954 ]
[ 0.6963 ] tegrasign_v2 --key None --list mb1_cold_boot_bct_MB1_sigheader.bct_list.xml
[ 0.6969 ] Assuming zero filled SBK key
[ 0.6980 ]
[ 0.6988 ] tegrahost_v2 --updatesigheader mb1_cold_boot_bct_MB1_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_sigheader.bct.hash zerosbk
[ 0.6998 ]
[ 0.6999 ] Generating recovery mb1-bct
[ 0.7006 ] tegrabct_v2 --chip 0x18 0 --mb1bct mb1_bct.cfg --sdram P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --misc tegra186-mb1-bct-misc-si-l4t.cfg --scr minimal_scr.cfg --pinmux tegra186-mb1-bct-pinmux-quill-p3310-1000-a00.cfg --pmc tegra186-mb1-bct-pad-quill-p3310-1000-a00.cfg --pmic tegra186-mb1-bct-pmic-quill-p3310-1000-a00.cfg --brcommand tegra186-mb1-bct-bootrom-quill-p3310-1000-a00.cfg --prod tegra186-mb1-bct-prod-quill-p3310-1000-a00.cfg
[ 0.7013 ] MB1-BCT version: 0xf
[ 0.7014 ] Copying Sdram info from 2 to 3 set
[ 0.7136 ] Packing sdram param for instance[0]
[ 0.7138 ] Packing sdram param for instance[1]
[ 0.7139 ] Packing sdram param for instance[2]
[ 0.7141 ] Packing sdram param for instance[3]
[ 0.7143 ] Parsing config file :tegra186-mb1-bct-pinmux-quill-p3310-1000-a00.cfg
[ 0.7147 ] Appending platform config data of size :- 2952
[ 0.7149 ] Parsing config file :minimal_scr.cfg
[ 0.7151 ] Appending platform config data of size :- 12240
[ 0.7157 ] Parsing config file :tegra186-mb1-bct-pad-quill-p3310-1000-a00.cfg
[ 0.7159 ] Appending platform config data of size :- 24
[ 0.7159 ]
[ 0.7159 ] Parsing config file :tegra186-mb1-bct-pmic-quill-p3310-1000-a00.cfg
[ 0.7159 ] Appending platform config data of size :- 468
[ 0.7159 ]
[ 0.7159 ] Parsing config file :tegra186-mb1-bct-bootrom-quill-p3310-1000-a00.cfg
[ 0.7159 ] Appending platform config data of size :- 64
[ 0.7160 ]
[ 0.7160 ] Parsing config file :tegra186-mb1-bct-prod-quill-p3310-1000-a00.cfg
[ 0.7160 ] Appending platform config data of size :- 1628
[ 0.7160 ]
[ 0.7160 ] Updating mb1-bct with firmware information
[ 0.7167 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 0.7172 ] MB1-BCT version: 0xf
[ 0.7176 ]
[ 0.7176 ] Updating mb1-bct with storage information
[ 0.7182 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 0.7187 ] MB1-BCT version: 0xf
[ 0.7191 ]
[ 0.7197 ] tegrahost_v2 --chip 0x18 --align mb1_bct_MB1.bct
[ 0.7204 ]
[ 0.7211 ] tegrahost_v2 --appendsigheader mb1_bct_MB1.bct zerosbk
[ 0.7218 ]
[ 0.7227 ] tegrasign_v2 --key None --list mb1_bct_MB1_sigheader.bct_list.xml
[ 0.7234 ] Assuming zero filled SBK key
[ 0.7246 ]
[ 0.7254 ] tegrahost_v2 --updatesigheader mb1_bct_MB1_sigheader.bct.encrypt mb1_bct_MB1_sigheader.bct.hash zerosbk
[ 0.7262 ]
[ 0.7263 ] Copying signatures
[ 0.7269 ] tegrahost_v2 --chip 0x18 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 0.8020 ]
[ 0.8021 ] Boot Rom communication
[ 0.8040 ] tegrarcm_v2 --chip 0x18 0 --rcm rcm_list_signed.xml
[ 0.8057 ] BootRom is not running
[ 5.8039 ]
[ 6.8069 ] tegrarcm_v2 --isapplet
[ 6.8086 ] Applet version 01.00.0000
[ 6.8115 ]
[ 6.8115 ] Sending BCTs
[ 6.8134 ] tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 6.8153 ] Applet version 01.00.0000
[ 6.8384 ] Sending bct_bootrom
[ 6.8387 ] [................................................] 100%
[ 6.8402 ] Sending bct_mb1
[ 6.8410 ] [................................................] 100%
[ 6.8667 ]
[ 6.8668 ] Generating blob
[ 6.8692 ] tegrahost_v2 --chip 0x18 --align blob_nvtboot_recovery_cpu.bin
[ 6.8712 ]
[ 6.8732 ] tegrahost_v2 --appendsigheader blob_nvtboot_recovery_cpu.bin zerosbk
[ 6.8760 ]
[ 6.8786 ] tegrasign_v2 --key None --list blob_nvtboot_recovery_cpu_sigheader.bin_list.xml
[ 6.8804 ] Assuming zero filled SBK key
[ 6.8931 ]
[ 6.8958 ] tegrahost_v2 --updatesigheader blob_nvtboot_recovery_cpu_sigheader.bin.encrypt blob_nvtboot_recovery_cpu_sigheader.bin.hash zerosbk
[ 6.8990 ]
[ 6.9017 ] tegrahost_v2 --chip 0x18 --align blob_nvtboot_recovery.bin
[ 6.9035 ]
[ 6.9053 ] tegrahost_v2 --appendsigheader blob_nvtboot_recovery.bin zerosbk
[ 6.9254 ]
[ 6.9281 ] tegrasign_v2 --key None --list blob_nvtboot_recovery_sigheader.bin_list.xml
[ 6.9301 ] Assuming zero filled SBK key
[ 6.9365 ]
[ 6.9394 ] tegrahost_v2 --updatesigheader blob_nvtboot_recovery_sigheader.bin.encrypt blob_nvtboot_recovery_sigheader.bin.hash zerosbk
[ 6.9419 ]
[ 6.9442 ] tegrahost_v2 --chip 0x18 --align blob_preboot_d15_prod_cr.bin
[ 6.9463 ]
[ 6.9484 ] tegrahost_v2 --appendsigheader blob_preboot_d15_prod_cr.bin zerosbk
[ 6.9507 ]
[ 6.9533 ] tegrasign_v2 --key None --list blob_preboot_d15_prod_cr_sigheader.bin_list.xml
[ 6.9552 ] Assuming zero filled SBK key
[ 6.9595 ]
[ 6.9622 ] tegrahost_v2 --updatesigheader blob_preboot_d15_prod_cr_sigheader.bin.encrypt blob_preboot_d15_prod_cr_sigheader.bin.hash zerosbk
[ 6.9648 ]
[ 6.9671 ] tegrahost_v2 --chip 0x18 --align blob_mce_mts_d15_prod_cr.bin
[ 6.9692 ]
[ 6.9713 ] tegrahost_v2 --appendsigheader blob_mce_mts_d15_prod_cr.bin zerosbk
[ 6.9805 ]
[ 6.9833 ] tegrasign_v2 --key None --list blob_mce_mts_d15_prod_cr_sigheader.bin_list.xml
[ 6.9852 ] Assuming zero filled SBK key
[ 7.0523 ]
[ 7.0535 ] tegrahost_v2 --updatesigheader blob_mce_mts_d15_prod_cr_sigheader.bin.encrypt blob_mce_mts_d15_prod_cr_sigheader.bin.hash zerosbk
[ 7.0562 ]
[ 7.0571 ] tegrahost_v2 --chip 0x18 --align blob_bpmp.bin
[ 7.0577 ]
[ 7.0585 ] tegrahost_v2 --appendsigheader blob_bpmp.bin zerosbk
[ 7.0598 ]
[ 7.0606 ] tegrasign_v2 --key None --list blob_bpmp_sigheader.bin_list.xml
[ 7.0613 ] Assuming zero filled SBK key
[ 7.0723 ]
[ 7.0733 ] tegrahost_v2 --updatesigheader blob_bpmp_sigheader.bin.encrypt blob_bpmp_sigheader.bin.hash zerosbk
[ 7.0745 ]
[ 7.0753 ] tegrahost_v2 --chip 0x18 --align blob_tegra186-a02-bpmp-quill-p3310-1000-a00-00-te770d-ucm2.dtb
[ 7.0760 ]
[ 7.0767 ] tegrahost_v2 --appendsigheader blob_tegra186-a02-bpmp-quill-p3310-1000-a00-00-te770d-ucm2.dtb zerosbk
[ 7.0779 ]
[ 7.0788 ] tegrasign_v2 --key None --list blob_tegra186-a02-bpmp-quill-p3310-1000-a00-00-te770d-ucm2_sigheader.dtb_list.xml
[ 7.0795 ] Assuming zero filled SBK key
[ 7.0892 ]
[ 7.0903 ] tegrahost_v2 --updatesigheader blob_tegra186-a02-bpmp-quill-p3310-1000-a00-00-te770d-ucm2_sigheader.dtb.encrypt blob_tegra186-a02-bpmp-quill-p3310-1000-a00-00-te770d-ucm2_sigheader.dtb.hash zerosbk
[ 7.0918 ]
[ 7.0929 ] tegrahost_v2 --chip 0x18 --align blob_tos-trusty.img
[ 7.0936 ]
[ 7.0944 ] tegrahost_v2 --appendsigheader blob_tos-trusty.img zerosbk
[ 7.0954 ]
[ 7.0963 ] tegrasign_v2 --key None --list blob_tos-trusty_sigheader.img_list.xml
[ 7.0969 ] Assuming zero filled SBK key
[ 7.1035 ]
[ 7.1044 ] tegrahost_v2 --updatesigheader blob_tos-trusty_sigheader.img.encrypt blob_tos-trusty_sigheader.img.hash zerosbk
[ 7.1054 ]
[ 7.1062 ] tegrahost_v2 --chip 0x18 --align blob_eks.img
[ 7.1068 ]
[ 7.1075 ] tegrahost_v2 --appendsigheader blob_eks.img zerosbk
[ 7.1082 ]
[ 7.1091 ] tegrasign_v2 --key None --list blob_eks_sigheader.img_list.xml
[ 7.1097 ] Assuming zero filled SBK key
[ 7.1098 ]
[ 7.1108 ] tegrahost_v2 --updatesigheader blob_eks_sigheader.img.encrypt blob_eks_sigheader.img.hash zerosbk
[ 7.1115 ]
[ 7.1123 ] tegrahost_v2 --chip 0x18 --align blob_tegra186-quill-p3310-1000-a00-00-base.dtb
[ 7.1130 ]
[ 7.1137 ] tegrahost_v2 --appendsigheader blob_tegra186-quill-p3310-1000-a00-00-base.dtb zerosbk
[ 7.1148 ]
[ 7.1157 ] tegrasign_v2 --key None --list blob_tegra186-quill-p3310-1000-a00-00-base_sigheader.dtb_list.xml
[ 7.1164 ] Assuming zero filled SBK key
[ 7.1235 ]
[ 7.1244 ] tegrahost_v2 --updatesigheader blob_tegra186-quill-p3310-1000-a00-00-base_sigheader.dtb.encrypt blob_tegra186-quill-p3310-1000-a00-00-base_sigheader.dtb.hash zerosbk
[ 7.1255 ]
[ 7.1263 ] tegrahost_v2 --chip 0x18 --generateblob blob.xml blob.bin
[ 7.1270 ] number of images in blob are 9
[ 7.1271 ] blobsize is 4096808
[ 7.1272 ] Added binary blob_nvtboot_recovery_cpu_sigheader.bin.encrypt of size 203312
[ 7.1287 ] Added binary blob_nvtboot_recovery_sigheader.bin.encrypt of size 89360
[ 7.1290 ] Added binary blob_preboot_d15_prod_cr_sigheader.bin.encrypt of size 63104
[ 7.1293 ] Added binary blob_mce_mts_d15_prod_cr_sigheader.bin.encrypt of size 2082144
[ 7.1297 ] Added binary blob_bpmp_sigheader.bin.encrypt of size 533904
[ 7.1300 ] Added binary blob_tegra186-a02-bpmp-quill-p3310-1000-a00-00-te770d-ucm2_sigheader.dtb.encrypt of size 466128
[ 7.1304 ] Added binary blob_tos-trusty_sigheader.img.encrypt of size 313152
[ 7.1307 ] Added binary blob_eks_sigheader.img.encrypt of size 1440
[ 7.1309 ] Added binary blob_tegra186-quill-p3310-1000-a00-00-base_sigheader.dtb.encrypt of size 344112
[ 7.1318 ]
[ 7.1319 ] Sending bootloader and pre-requisite binaries
[ 7.1327 ] tegrarcm_v2 --download blob blob.bin
[ 7.1333 ] Applet version 01.00.0000
[ 7.1462 ] Sending blob
[ 7.2687 ]
Failed flashing t186ref.
hello wang.xiangru,
you should exclude system.img from your command line.
please also refer to documentation, Flashing and Booting the Target Device for reference.
for example,
$ sudo ./flash.sh
according to your board information, and also refer to Jetson Modules and SoCs .
assume you’re working with Jetson-TX2i or Jetson-TX2-4GB.
you should note that there’re different board configuration files.
please specify correct configurations for verification.
thanks
