TX2 BootRom is not running issue
Currently I am using an Elroy board to communicate via USB-USB from the TX2 to my host machine which is running ubuntu 18.
I have tried following the connect tech instructions ( ./flash.sh cti/tx2/elroy-revF+ mmcblk0p1) , I have tried doing the most basic flash of L4T by building out the kernel ect., and just about everything in-between. I even tried using USB3 vs USB2 since a post referenced that, even though it was talking about VM’s and I am not using a VM.
No matter I keep getting stuck at a single point, BootRom is not running. I have posted the full output of what is being printed out but I believe that the issue is from the BootRom, yet I am not sure how to confirm that. Is this something I am doing wrong/can fix or do I just need to get a new TX2 and try again?
Full flash.sh output
Target Board Information:
Name: cti/tx2/elroy-revF+, Board Family: t186ref, SoC: Tegra 186,
OpMode: production, Boot Authentication: NS,
./tegraflash.py --chip 0x18 --applet “/home/jake/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin” --skipuid --cmd “dump eeprom boardinfo cvm.bin”
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0021 ] Generating RCM messages
[ 0.0026 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 0 --download rcm /home/jake/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin 0 0
[ 0.0031 ] RCM 0 is saved as rcm_0.rcm
[ 0.0034 ] RCM 1 is saved as rcm_1.rcm
[ 0.0034 ] List of rcm files are saved in rcm_list.xml
[ 0.0034 ]
[ 0.0034 ] Signing RCM messages
[ 0.0039 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0044 ] Assuming zero filled SBK key
[ 0.0064 ]
[ 0.0064 ] Copying signature to RCM mesages
[ 0.0069 ] tegrarcm_v2 --chip 0x18 0 --updatesig rcm_list_signed.xml
[ 0.0076 ]
[ 0.0076 ] Boot Rom communication
[ 0.0081 ] tegrarcm_v2 --chip 0x18 0 --rcm rcm_list_signed.xml --skipuid
[ 0.0085 ] RCM version 0X180001
[ 0.0096 ] Boot Rom communication completed
[ 1.0173 ]
[ 2.0192 ] tegrarcm_v2 --isapplet
[ 2.0198 ] Applet version 01.00.0000
[ 2.0371 ]
[ 2.0381 ] Retrieving EEPROM data
[ 2.0381 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/jake/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/cvm.bin
[ 2.0389 ] Applet version 01.00.0000
[ 2.0770 ] Saved platform info in /home/jake/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/cvm.bin
[ 2.1511 ]
Copy /home/jake/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2/Linux_for_Tegra/kernel/dtb/tegra186-tx2-cti-ASG002-revF+.dtb to /home/jake/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2/Linux_for_Tegra/kernel/dtb/tegra186-tx2-cti-ASG002-revF+.dtb.rec
copying bctfile(/home/jake/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/P3310_A00_8GB_lpddr4_A02_l4t.cfg)… done.
copying misc_config(/home/jake/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-misc-si-l4t.cfg)… done.
copying pinmux_config(/home/jake/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg)… done.
copying pmic_config(/home/jake/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg)… done.
copying pmc_config(/home/jake/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg)… done.
copying prod_config(/home/jake/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg)… done.
copying scr_config(/home/jake/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/minimal_scr.cfg)… done.
copying scr_cold_boot_config(/home/jake/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/mobile_scr.cfg)… done.
copying bootrom_config(/home/jake/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg)… done.
copying dev_params(/home/jake/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/emmc.cfg)… done.
Existing bootloader(/home/jake/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
copying initrd(/home/jake/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/l4t_initrd.img)… done.
populating kernel to rootfs… done.
populating initrd to rootfs… done.
populating /home/jake/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2/Linux_for_Tegra/kernel/dtb/tegra186-tx2-cti-ASG002-revF+.dtb to rootfs… done.
Making Boot image… done.
Existing sosfile(/home/jake/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin) reused.
copying tegraboot(/home/jake/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/t186ref/nvtboot.bin)… done.
Existing cpu_bootloader(/home/jake/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
Existing mb2blfile(/home/jake/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
Existing mtspreboot(/home/jake/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/preboot_d15_prod_cr.bin) reused.
Existing mts(/home/jake/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/mce_mts_d15_prod_cr.bin) reused.
Existing mb1file(/home/jake/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/mb1_prod.bin) reused.
Existing bpffile(/home/jake/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/bpmp.bin) reused.
copying bpfdtbfile(/home/jake/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/t186ref/tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb)… done.
Existing scefile(/home/jake/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
Existing spefile(/home/jake/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/spe.bin) reused.
Existing drameccfile(/home/jake/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/dram-ecc.bin) reused.
Existing badpagefile(/home/jake/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/badpage.bin) reused.
copying wb0boot(/home/jake/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/t186ref/warmboot.bin)… done.
Existing tosfile(/home/jake/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/tos-trusty.img) reused.
Existing eksfile(/home/jake/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/jake/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2/Linux_for_Tegra/kernel/dtb/tegra186-tx2-cti-ASG002-revF+.dtb)… done.
Copying nv_boot_control.conf to rootfs
Making system.img…
populating rootfs from /home/jake/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2/Linux_for_Tegra/rootfs … done.
populating /boot/extlinux/extlinux.conf … done.
Sync’ing system.img … done.
Converting RAW image to Sparse image… done.
system.img built successfully.
Existing tbcfile(/home/jake/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/cboot.bin) reused.
copying tbcdtbfile(/home/jake/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2/Linux_for_Tegra/kernel/dtb/tegra186-tx2-cti-ASG002-revF+.dtb)… done.
copying cfgfile(/home/jake/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/t186ref/cfg/flash_l4t_t186.xml) to flash.xml… done.
Existing flasher(/home/jake/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/nvtboot_recovery_cpu.bin) reused.
Existing flashapp(/home/jake/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/tegraflash.py) reused.
./tegraflash.py --bl nvtboot_recovery_cpu.bin --sdram_config P3310_A00_8GB_lpddr4_A02_l4t.cfg --odmdata 0x6090000 --applet mb1_recovery_prod.bin --cmd “flash; reboot” --cfg flash.xml --chip 0x18 --misc_config tegra186-mb1-bct-misc-si-l4t.cfg --pinmux_config tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmic_config tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg --pmc_config tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --prod_config tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg --scr_config minimal_scr.cfg --scr_cold_boot_config mobile_scr.cfg --br_cmd_config tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --dev_params emmc.cfg --bins “mb2_bootloader nvtboot_recovery.bin; mts_preboot preboot_d15_prod_cr.bin; mts_bootpack mce_mts_d15_prod_cr.bin; bpmp_fw bpmp.bin; bpmp_fw_dtb tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb; tlk tos-trusty.img; eks eks.img; bootloader_dtb tegra186-tx2-cti-ASG002-revF+.dtb”
saving flash command in /home/jake/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /home/jake/nvidia/nvidia_sdk/JetPack_4.4.1_Linux_JETSON_TX2/Linux_for_Tegra/bootloader/flash_win.bat
*** Flashing target device started. ***
version 1.0.0
[ 0.0052 ] tegrasign_v2 --key None --getmode mode.txt
[ 0.0063 ] Assuming zero filled SBK key
[ 0.0133 ]
[ 0.0134 ] Generating RCM messages
[ 0.0183 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 0 --download rcm mb1_recovery_prod.bin 0 0
[ 0.0193 ] RCM 0 is saved as rcm_0.rcm
[ 0.0290 ] RCM 1 is saved as rcm_1.rcm
[ 0.0290 ] List of rcm files are saved in rcm_list.xml
[ 0.0290 ]
[ 0.0290 ] Signing RCM messages
[ 0.0311 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0328 ] Assuming zero filled SBK key
[ 0.0429 ]
[ 0.0429 ] Copying signature to RCM mesages
[ 0.0453 ] tegrarcm_v2 --chip 0x18 0 --updatesig rcm_list_signed.xml
[ 0.0485 ]
[ 0.0486 ] Parsing partition layout
[ 0.0534 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.0611 ]
[ 0.0612 ] Creating list of images to be signed
[ 0.0653 ] tegrahost_v2 --chip 0x18 0 --partitionlayout flash.xml.bin --list images_list.xml zerosbk
[ 0.1527 ]
[ 0.1527 ] Generating signatures
[ 0.1536 ] tegrasign_v2 --key None --list images_list.xml --pubkeyhash pub_key.key
[ 0.1542 ] Assuming zero filled SBK key
[ 0.3384 ]
[ 0.3384 ] Generating br-bct
[ 0.3455 ] Updating dev and MSS params in BR BCT
[ 0.3455 ] tegrabct_v2 --dev_param emmc.cfg --sdram P3310_A00_8GB_lpddr4_A02_l4t.cfg --brbct br_bct.cfg --chip 0x18 0
[ 0.3968 ]
[ 0.3968 ] Updating bl info
[ 0.3974 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 0.4048 ]
[ 0.4049 ] Updating smd info
[ 0.4056 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --updatesmdinfo flash.xml.bin
[ 0.4116 ]
[ 0.4117 ] Updating Odmdata
[ 0.4123 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --updatefields Odmdata =0x6090000
[ 0.4186 ]
[ 0.4186 ] Get Signed section of bct
[ 0.4193 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --listbct bct_list.xml
[ 0.4221 ]
[ 0.4229 ] tegrasign_v2 --key None --list bct_list.xml --pubkeyhash pub_key.key
[ 0.4234 ] Assuming zero filled SBK key
[ 0.4235 ]
[ 0.4236 ] Updating BCT with signature
[ 0.4241 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --updatesig bct_list_signed.xml
[ 0.4293 ]
[ 0.4294 ] Generating coldboot mb1-bct
[ 0.4302 ] tegrabct_v2 --chip 0x18 0 --mb1bct mb1_cold_boot_bct.cfg --sdram P3310_A00_8GB_lpddr4_A02_l4t.cfg --misc tegra186-mb1-bct-misc-si-l4t.cfg --scr mobile_scr.cfg --pinmux tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmc tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --pmic tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg --brcommand tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --prod tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 0.4309 ] MB1-BCT version: 0xf
[ 0.4310 ] Packing sdram param for instance[0]
[ 0.4544 ] Packing sdram param for instance[1]
[ 0.4546 ] Packing sdram param for instance[2]
[ 0.4547 ] Packing sdram param for instance[3]
[ 0.4573 ] Parsing config file :tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg
[ 0.4576 ] Appending platform config data of size :- 3032
[ 0.4609 ] Parsing config file :mobile_scr.cfg
[ 0.4611 ] Appending platform config data of size :- 12240
[ 0.4661 ] Parsing config file :tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg
[ 0.4664 ] Appending platform config data of size :- 24
[ 0.4676 ] Parsing config file :tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg
[ 0.4679 ] Appending platform config data of size :- 672
[ 0.4714 ] Parsing config file :tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg
[ 0.4716 ] Appending platform config data of size :- 64
[ 0.4750 ] Parsing config file :tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 0.4752 ] Appending platform config data of size :- 1628
[ 0.4784 ]
[ 0.4784 ] Updating mb1-bct with firmware information
[ 0.4792 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 0.4799 ] MB1-BCT version: 0xf
[ 0.4816 ]
[ 0.4817 ] Updating mb1-bct with storage information
[ 0.4825 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 0.4832 ] MB1-BCT version: 0xf
[ 0.4887 ]
[ 0.4896 ] tegrahost_v2 --chip 0x18 --align mb1_cold_boot_bct_MB1.bct
[ 0.4904 ]
[ 0.4912 ] tegrahost_v2 --appendsigheader mb1_cold_boot_bct_MB1.bct zerosbk
[ 0.4921 ]
[ 0.4930 ] tegrasign_v2 --key None --list mb1_cold_boot_bct_MB1_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 0.4937 ] Assuming zero filled SBK key
[ 0.4953 ]
[ 0.4965 ] tegrahost_v2 --updatesigheader mb1_cold_boot_bct_MB1_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_sigheader.bct.hash zerosbk
[ 0.4975 ]
[ 0.4975 ] Generating recovery mb1-bct
[ 0.4983 ] tegrabct_v2 --chip 0x18 0 --mb1bct mb1_bct.cfg --sdram P3310_A00_8GB_lpddr4_A02_l4t.cfg --misc tegra186-mb1-bct-misc-si-l4t.cfg --scr minimal_scr.cfg --pinmux tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmc tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --pmic tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg --brcommand tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --prod tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 0.4992 ] MB1-BCT version: 0xf
[ 0.4993 ] Packing sdram param for instance[0]
[ 0.5304 ] Packing sdram param for instance[1]
[ 0.5305 ] Packing sdram param for instance[2]
[ 0.5307 ] Packing sdram param for instance[3]
[ 0.5308 ] Parsing config file :tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg
[ 0.5311 ] Appending platform config data of size :- 3032
[ 0.5313 ] Parsing config file :minimal_scr.cfg
[ 0.5315 ] Appending platform config data of size :- 12240
[ 0.5351 ] Parsing config file :tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg
[ 0.5352 ] Appending platform config data of size :- 24
[ 0.5352 ]
[ 0.5352 ] Parsing config file :tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg
[ 0.5352 ] Appending platform config data of size :- 672
[ 0.5352 ]
[ 0.5352 ] Parsing config file :tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg
[ 0.5352 ] Appending platform config data of size :- 64
[ 0.5352 ]
[ 0.5352 ] Parsing config file :tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 0.5353 ] Appending platform config data of size :- 1628
[ 0.5353 ]
[ 0.5353 ] Updating mb1-bct with firmware information
[ 0.5360 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 0.5366 ] MB1-BCT version: 0xf
[ 0.5370 ]
[ 0.5370 ] Updating mb1-bct with storage information
[ 0.5376 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 0.5382 ] MB1-BCT version: 0xf
[ 0.5385 ]
[ 0.5391 ] tegrahost_v2 --chip 0x18 --align mb1_bct_MB1.bct
[ 0.5396 ]
[ 0.5402 ] tegrahost_v2 --appendsigheader mb1_bct_MB1.bct zerosbk
[ 0.5408 ]
[ 0.5416 ] tegrasign_v2 --key None --list mb1_bct_MB1_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 0.5421 ] Assuming zero filled SBK key
[ 0.5432 ]
[ 0.5439 ] tegrahost_v2 --updatesigheader mb1_bct_MB1_sigheader.bct.encrypt mb1_bct_MB1_sigheader.bct.hash zerosbk
[ 0.5445 ]
[ 0.5446 ] Copying signatures
[ 0.5451 ] tegrahost_v2 --chip 0x18 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 0.5681 ]
[ 0.5682 ] Boot Rom communication
[ 0.5688 ] tegrarcm_v2 --chip 0x18 0 --rcm rcm_list_signed.xml
[ 0.5693 ] BootRom is not running
[ 5.8596 ]
[ 6.8617 ] tegrarcm_v2 --isapplet
[ 1020.6438 ]
[ 1020.6487 ] tegradevflash_v2 --iscpubl
[ 1020.6509 ] CPU Bootloader is not running on device.
[ 2036.4515 ]
[ 2037.4557 ] tegrarcm_v2 --isapplet
[ 3052.2591 ]
[ 3052.2598 ] tegradevflash_v2 --iscpubl
[ 3052.2608 ] CPU Bootloader is not running on device.
[ 4068.0672 ]
[ 4069.0717 ] tegrarcm_v2 --isapplet
Thank you,
-Jake
Hi Jake!
Have you contacted our Tech Support team? If you fill out our support form, our Tech Team will quickly respond and help get you up and running. You can find the form here: Customer Support Form - Connect Tech Inc.
Let me know if you have any questions :)
Jacki
Yes ma’am, I have been talking with someone from your support team and have solved a few other issues with his help.
I figured I would post this issue here as well, however, since the more I have probed into the issue the more it seems related to the TX2 more so than the Elroy. I am far from an expert though so I could be way off base.
I can close this post and continue to work with you guys directly, if you wish.
How did you resolve this issue? I am getting the same output.
Honestly I was never able to resolve the issue in a meaningful way. After a few back and forth with several people I ended up getting a different computer and putting a fresh install of Ubuntu 18.04. On that computer everything worked as I would have expected. Had it up and working in a matter of an hour give or take. So if you want to count the brute force hammer approach as a “resolve” then yes, yes I did. Not an intelligent solution though.
Thank you. I resolved this by switching to a native installation of Ubuntu (18.04 server) instead of a virtual machine with USB passthrough.
