Board ID(3310) version(C03) sku() revision()
Copy /home/fdl/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra_4.6.5/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb to /home/fdl/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra_4.6.5/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb.rec
copying bctfile(/home/fdl/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra_4.6.5/bootloader/t186ref/BCT/P3310_A00_8GB_lpddr4_A02_l4t.cfg)… done.
copying misc_config(/home/fdl/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra_4.6.5/bootloader/t186ref/BCT/tegra186-mb1-bct-misc-si-l4t.cfg)… done.
copying pinmux_config(/home/fdl/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra_4.6.5/bootloader/t186ref/BCT/tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg)… done.
copying pmic_config(/home/fdl/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra_4.6.5/bootloader/t186ref/BCT/tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg)… done.
copying pmc_config(/home/fdl/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra_4.6.5/bootloader/t186ref/BCT/tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg)… done.
copying prod_config(/home/fdl/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra_4.6.5/bootloader/t186ref/BCT/tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg)… done.
copying scr_config(/home/fdl/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra_4.6.5/bootloader/t186ref/BCT/minimal_scr.cfg)… done.
copying scr_cold_boot_config(/home/fdl/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra_4.6.5/bootloader/t186ref/BCT/mobile_scr.cfg)… done.
copying bootrom_config(/home/fdl/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra_4.6.5/bootloader/t186ref/BCT/tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg)… done.
copying dev_params(/home/fdl/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra_4.6.5/bootloader/t186ref/BCT/emmc.cfg)… done.
Existing bootloader(/home/fdl/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra_4.6.5/bootloader/nvtboot_cpu.bin) reused.
copying initrd(/home/fdl/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra_4.6.5/bootloader/l4t_initrd.img)… done.
Making Boot image… done.
/home/fdl/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra_4.6.5/bootloader/tegraflash.py --chip 0x18 --key --cmd sign boot.img kernel
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0003 ] Generating signature
[ 0.0025 ] tegrasign_v3.py --getmode mode.txt --key
[ 0.0026 ] Assuming zero filled SBK key : not reading
[ 0.0026 ] sign_type : 0
[ 0.0026 ] header_magic: 414e4452
[ 0.0044 ] tegrahost_v2 --chip 0x18 --align 1_boot.img
[ 0.0051 ]
[ 0.0071 ] tegrahost_v2 --chip 0x18 0 --appendsigheader 1_boot.img zerosbk
[ 0.0087 ]
[ 0.0114 ] tegrasign_v3.py --key --list 1_boot_sigheader.img_list.xml --pubkeyhash pub_key.key
[ 0.0114 ] Assuming zero filled SBK key : not reading
[ 0.0239 ] tegrahost_v2 --chip 0x18 0 --updatesigheader 1_boot_sigheader.img.encrypt 1_boot_sigheader.img.hash zerosbk
[ 0.0253 ]
[ 0.0259 ] Signed file: /home/fdl/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra_4.6.5/bootloader/temp_user_dir/boot_sigheader.img.encrypt
l4t_sign_image.sh: Generate header for boot_sigheader.img.encrypt
l4t_sign_image.sh: chip 0x18: Don’t need to do anything
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for boot_sigheader.img.encrypt
l4t_sign_image.sh: the signed file is /home/fdl/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra_4.6.5/bootloader/temp_user_dir/boot_sigheader.img.encrypt
done.
Making recovery ramdisk for recovery image…
Re-generating recovery ramdisk for recovery image…
~/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra_4.6.5/bootloader/ramdisk_tmp ~/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra_4.6.5/bootloader ~/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra_4.6.5
30412 blocks
_BASE_KERNEL_VERSION=4.9.337-tegra
~/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra_4.6.5/bootloader/ramdisk_tmp/lib ~/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra_4.6.5/bootloader/ramdisk_tmp ~/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra_4.6.5/bootloader ~/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra_4.6.5
66034 blocks
Making Recovery image…
copying recdtbfile(/home/fdl/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra_4.6.5/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb.rec)… done.
20+0 records in
20+0 records out
20 bytes copied, 0.000396222 s, 50.5 kB/s
Existing sosfile(/home/fdl/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra_4.6.5/bootloader/mb1_recovery_prod.bin) reused.
copying tegraboot(/home/fdl/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra_4.6.5/bootloader/t186ref/nvtboot.bin)… done.
Existing cpu_bootloader(/home/fdl/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra_4.6.5/bootloader/nvtboot_cpu.bin) reused.
Existing mb2blfile(/home/fdl/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra_4.6.5/bootloader/nvtboot_recovery.bin) reused.
Existing mtspreboot(/home/fdl/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra_4.6.5/bootloader/preboot_d15_prod_cr.bin) reused.
Existing mts(/home/fdl/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra_4.6.5/bootloader/mce_mts_d15_prod_cr.bin) reused.
Existing mb1file(/home/fdl/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra_4.6.5/bootloader/mb1_prod.bin) reused.
Existing bpffile(/home/fdl/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra_4.6.5/bootloader/bpmp.bin) reused.
copying bpfdtbfile(/home/fdl/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra_4.6.5/bootloader/t186ref/tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb)… done.
Existing scefile(/home/fdl/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra_4.6.5/bootloader/camera-rtcpu-sce.img) reused.
Existing spefile(/home/fdl/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra_4.6.5/bootloader/spe.bin) reused.
copying wb0boot(/home/fdl/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra_4.6.5/bootloader/t186ref/warmboot.bin)… done.
Existing tosfile(/home/fdl/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra_4.6.5/bootloader/tos-trusty.img) reused.
Existing eksfile(/home/fdl/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra_4.6.5/bootloader/eks.img) reused.
./flash.sh: line 2663: [: : integer expression expected
copying dtbfile(/home/fdl/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra_4.6.5/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb)… done.
Copying nv_boot_control.conf to rootfs
/home/fdl/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra_4.6.5/bootloader/tegraflash.py --chip 0x18 --key --cmd sign kernel_tegra186-quill-p3310-1000-c03-00-base.dtb kernel_dtb
version 1.0.0
[ 0.0005 ] Generating signature
[ 0.0028 ] tegrasign_v3.py --getmode mode.txt --key
[ 0.0029 ] Assuming zero filled SBK key : not reading
[ 0.0028 ] sign_type : 808464433
[ 0.0028 ] header_magic: d00dfeed
[ 0.0047 ] tegrahost_v2 --chip 0x18 --align 1_kernel_tegra186-quill-p3310-1000-c03-00-base.dtb
[ 0.0054 ]
[ 0.0073 ] tegrahost_v2 --chip 0x18 0 --appendsigheader 1_kernel_tegra186-quill-p3310-1000-c03-00-base.dtb zerosbk
[ 0.0085 ]
[ 0.0113 ] tegrasign_v3.py --key --list 1_kernel_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 0.0197 ] tegrahost_v2 --chip 0x18 0 --updatesigheader 1_kernel_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt 1_kernel_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.hash zerosbk
[ 0.0211 ]
[ 0.0216 ] Signed file: /home/fdl/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra_4.6.5/bootloader/temp_user_dir/kernel_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt
l4t_sign_image.sh: Generate header for kernel_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for kernel_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt
l4t_sign_image.sh: the signed file is /home/fdl/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra_4.6.5/bootloader/temp_user_dir/kernel_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt
done.
Reusing existing system.img…
done.
Existing tbcfile(/home/fdl/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra_4.6.5/bootloader/cboot.bin) reused.
copying tbcdtbfile(/home/fdl/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra_4.6.5/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb)… done.
copying cfgfile(/home/fdl/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra_4.6.5/bootloader/t186ref/cfg/flash_l4t_t186.xml) to flash.xml… done.
Existing flasher(/home/fdl/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra_4.6.5/bootloader/nvtboot_recovery_cpu.bin) reused.
Existing flashapp(/home/fdl/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra_4.6.5/bootloader/tegraflash.py) reused.
./tegraflash.py --bl nvtboot_recovery_cpu.bin --sdram_config P3310_A00_8GB_lpddr4_A02_l4t.cfg --odmdata 0x1090000 --applet mb1_recovery_prod.bin --cmd “flash; reboot” --cfg flash.xml --chip 0x18 --misc_config tegra186-mb1-bct-misc-si-l4t.cfg --pinmux_config tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmic_config tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg --pmc_config tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --prod_config tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg --scr_config minimal_scr.cfg --scr_cold_boot_config mobile_scr.cfg --br_cmd_config tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --dev_params emmc.cfg --bins “mb2_bootloader nvtboot_recovery.bin; mts_preboot preboot_d15_prod_cr.bin; mts_bootpack mce_mts_d15_prod_cr.bin; bpmp_fw bpmp.bin; bpmp_fw_dtb tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb; tlk tos-trusty.img; eks eks.img; bootloader_dtb tegra186-quill-p3310-1000-c03-00-base.dtb” --skipuid
saving flash command in /home/fdl/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra_4.6.5/bootloader/flashcmd.txt
saving Windows flash command to /home/fdl/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra_4.6.5/bootloader/flash_win.bat
*** Flashing target device started. ***
version 1.0.0
[ 0.0078 ] tegrasign_v3.py --getmode mode.txt --key None
[ 0.0078 ] Assuming zero filled SBK key
[ 0.0023 ] Generating RCM messages
[ 0.0042 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 0 --download rcm mb1_recovery_prod.bin 0 0
[ 0.0049 ] RCM 0 is saved as rcm_0.rcm
[ 0.0052 ] RCM 1 is saved as rcm_1.rcm
[ 0.0052 ] List of rcm files are saved in rcm_list.xml
[ 0.0052 ]
[ 0.0052 ] Signing RCM messages
[ 0.0128 ] tegrasign_v3.py --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0129 ] Assuming zero filled SBK key
[ 0.0128 ] Copying signature to RCM mesages
[ 0.0150 ] tegrarcm_v2 --chip 0x18 0 --updatesig rcm_list_signed.xml
[ 0.0160 ]
[ 0.0160 ] Parsing partition layout
[ 0.0179 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.0190 ]
[ 0.0192 ] Using default ramcode: 0
[ 0.0192 ] Disable BPMP dtb trim, using default dtb
[ 0.0192 ]
[ 0.0192 ] Creating list of images to be signed
[ 0.0211 ] tegrahost_v2 --chip 0x18 0 --partitionlayout flash.xml.bin --list images_list.xml zerosbk
[ 0.1135 ]
[ 0.1136 ] Generating signatures
[ 0.1215 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key
[ 0.1217 ] Assuming zero filled SBK key
[ 0.9517 ] Generating br-bct
[ 0.9537 ] Updating dev and MSS params in BR BCT
[ 0.9538 ] tegrabct_v2 --dev_param emmc.cfg --sdram P3310_A00_8GB_lpddr4_A02_l4t.cfg --brbct br_bct.cfg --chip 0x18 0
[ 0.9767 ]
[ 0.9767 ] Updating bl info
[ 0.9789 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 0.9807 ]
[ 0.9808 ] Updating smd info
[ 0.9829 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --updatesmdinfo flash.xml.bin
[ 0.9847 ]
[ 0.9847 ] Updating Odmdata
[ 0.9896 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --updatefields Odmdata =0x1090000
[ 0.9911 ]
[ 0.9912 ] Get Signed section of bct
[ 0.9932 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --listbct bct_list.xml
[ 0.9941 ]
[ 0.9961 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key
[ 0.9968 ] Assuming zero filled SBK key
[ 1.0202 ]
[ 1.0202 ] Updating BCT with signature
[ 1.0220 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --updatesig bct_list_signed.xml
[ 1.0234 ]
[ 1.0234 ] Generating coldboot mb1-bct
[ 1.0255 ] tegrabct_v2 --chip 0x18 0 --mb1bct mb1_cold_boot_bct.cfg --sdram P3310_A00_8GB_lpddr4_A02_l4t.cfg --misc tegra186-mb1-bct-misc-si-l4t.cfg --scr mobile_scr.cfg --pinmux tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmc tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --pmic tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg --brcommand tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --prod tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 1.0262 ] MB1-BCT version: 0xf
[ 1.0264 ] Packing sdram param for instance[0]
[ 1.0513 ] Packing sdram param for instance[1]
[ 1.0517 ] Packing sdram param for instance[2]
[ 1.0520 ] Packing sdram param for instance[3]
[ 1.0524 ] Parsing config file :tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg
[ 1.0532 ] Appending platform config data of size :- 3032
[ 1.0535 ]
[ 1.0535 ] Parsing config file :mobile_scr.cfg
[ 1.0535 ] Appending platform config data of size :- 12240
[ 1.0535 ]
[ 1.0535 ] Parsing config file :tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg
[ 1.0535 ] Appending platform config data of size :- 24
[ 1.0536 ]
[ 1.0536 ] Parsing config file :tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg
[ 1.0536 ] Appending platform config data of size :- 672
[ 1.0536 ]
[ 1.0536 ] Parsing config file :tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg
[ 1.0536 ] Appending platform config data of size :- 64
[ 1.0536 ]
[ 1.0536 ] Parsing config file :tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 1.0536 ] Appending platform config data of size :- 1628
[ 1.0536 ]
[ 1.0537 ] Updating mb1-bct with firmware information
[ 1.0560 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 1.0567 ] MB1-BCT version: 0xf
[ 1.0571 ]
[ 1.0571 ] Updating mb1-bct with storage information
[ 1.0591 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 1.0598 ] MB1-BCT version: 0xf
[ 1.0601 ]
[ 1.0619 ] tegrahost_v2 --chip 0x18 --align mb1_cold_boot_bct_MB1.bct
[ 1.0627 ]
[ 1.0647 ] tegrahost_v2 --chip 0x18 0 --appendsigheader mb1_cold_boot_bct_MB1.bct zerosbk
[ 1.0655 ]
[ 1.0733 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 1.0734 ] Assuming zero filled SBK key
[ 1.0723 ] tegrahost_v2 --chip 0x18 0 --updatesigheader mb1_cold_boot_bct_MB1_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_sigheader.bct.hash zerosbk
[ 1.0733 ]
[ 1.0735 ] Generating recovery mb1-bct
[ 1.0761 ] tegrabct_v2 --chip 0x18 0 --mb1bct mb1_bct.cfg --sdram P3310_A00_8GB_lpddr4_A02_l4t.cfg --misc tegra186-mb1-bct-misc-si-l4t.cfg --scr minimal_scr.cfg --pinmux tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmc tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --pmic tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg --brcommand tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --prod tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 1.0775 ] MB1-BCT version: 0xf
[ 1.0777 ] Packing sdram param for instance[0]
[ 1.1022 ] Packing sdram param for instance[1]
[ 1.1024 ] Packing sdram param for instance[2]
[ 1.1026 ] Packing sdram param for instance[3]
[ 1.1027 ] Parsing config file :tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg
[ 1.1031 ] Appending platform config data of size :- 3032
[ 1.1033 ] Parsing config file :minimal_scr.cfg
[ 1.1035 ] Appending platform config data of size :- 12240
[ 1.1041 ] Parsing config file :tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg
[ 1.1043 ] Appending platform config data of size :- 24
[ 1.1043 ]
[ 1.1043 ] Parsing config file :tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg
[ 1.1043 ] Appending platform config data of size :- 672
[ 1.1043 ]
[ 1.1044 ] Parsing config file :tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg
[ 1.1044 ] Appending platform config data of size :- 64
[ 1.1044 ]
[ 1.1044 ] Parsing config file :tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 1.1044 ] Appending platform config data of size :- 1628
[ 1.1044 ]
[ 1.1044 ] Updating mb1-bct with firmware information
[ 1.1066 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 1.1074 ] MB1-BCT version: 0xf
[ 1.1078 ]
[ 1.1078 ] Updating mb1-bct with storage information
[ 1.1097 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 1.1103 ] MB1-BCT version: 0xf
[ 1.1106 ]
[ 1.1125 ] tegrahost_v2 --chip 0x18 --align mb1_bct_MB1.bct
[ 1.1132 ]
[ 1.1151 ] tegrahost_v2 --chip 0x18 0 --appendsigheader mb1_bct_MB1.bct zerosbk
[ 1.1159 ]
[ 1.1237 ] tegrasign_v3.py --key None --list mb1_bct_MB1_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 1.1238 ] Assuming zero filled SBK key
[ 1.1264 ] tegrahost_v2 --chip 0x18 0 --updatesigheader mb1_bct_MB1_sigheader.bct.encrypt mb1_bct_MB1_sigheader.bct.hash zerosbk
[ 1.1278 ]
[ 1.1279 ] Copying signatures
[ 1.1299 ] tegrahost_v2 --chip 0x18 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 1.4494 ]
[ 1.4495 ] Boot Rom communication
[ 1.4543 ] tegrarcm_v2 --chip 0x18 0 --rcm rcm_list_signed.xml --skipuid
[ 1.4571 ] RCM version 0X180001
[ 1.4590 ] Boot Rom communication completed
[ 2.4655 ]
[ 3.4715 ] tegrarcm_v2 --isapplet
[ 3.4743 ] Applet version 01.00.0000
[ 3.4775 ]
[ 3.4777 ] Sending BCTs
[ 3.4821 ] tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 3.4852 ] Applet version 01.00.0000
[ 3.5024 ] Sending bct_bootrom
[ 3.5030 ] […] 100%
[ 3.5048 ] Sending bct_mb1
[ 3.5054 ] […] 100%
[ 3.5218 ]
[ 3.5220 ] Generating blob
[ 3.5310 ] tegrahost_v2 --chip 0x18 --align blob_nvtboot_recovery_cpu.bin
[ 3.5339 ]
[ 3.5375 ] tegrahost_v2 --chip 0x18 0 --appendsigheader blob_nvtboot_recovery_cpu.bin zerosbk
[ 3.5404 ]
[ 3.5493 ] tegrasign_v3.py --key None --list blob_nvtboot_recovery_cpu_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 3.5494 ] Assuming zero filled SBK key
[ 3.5570 ] tegrahost_v2 --chip 0x18 0 --updatesigheader blob_nvtboot_recovery_cpu_sigheader.bin.encrypt blob_nvtboot_recovery_cpu_sigheader.bin.hash zerosbk
[ 3.5582 ]
[ 3.5603 ] tegrahost_v2 --chip 0x18 --align blob_nvtboot_recovery.bin
[ 3.5610 ]
[ 3.5629 ] tegrahost_v2 --chip 0x18 0 --appendsigheader blob_nvtboot_recovery.bin zerosbk
[ 3.5642 ]
[ 3.5723 ] tegrasign_v3.py --key None --list blob_nvtboot_recovery_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 3.5725 ] Assuming zero filled SBK key
[ 3.5751 ] tegrahost_v2 --chip 0x18 0 --updatesigheader blob_nvtboot_recovery_sigheader.bin.encrypt blob_nvtboot_recovery_sigheader.bin.hash zerosbk
[ 3.5763 ]
[ 3.5787 ] tegrahost_v2 --chip 0x18 --align blob_preboot_d15_prod_cr.bin
[ 3.5794 ]
[ 3.5814 ] tegrahost_v2 --chip 0x18 0 --appendsigheader blob_preboot_d15_prod_cr.bin zerosbk
[ 3.5823 ]
[ 3.5902 ] tegrasign_v3.py --key None --list blob_preboot_d15_prod_cr_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 3.5903 ] Assuming zero filled SBK key
[ 3.5896 ] tegrahost_v2 --chip 0x18 0 --updatesigheader blob_preboot_d15_prod_cr_sigheader.bin.encrypt blob_preboot_d15_prod_cr_sigheader.bin.hash zerosbk
[ 3.5904 ]
[ 3.5925 ] tegrahost_v2 --chip 0x18 --align blob_mce_mts_d15_prod_cr.bin
[ 3.5932 ]
[ 3.5955 ] tegrahost_v2 --chip 0x18 0 --appendsigheader blob_mce_mts_d15_prod_cr.bin zerosbk
[ 3.6005 ]
[ 3.6091 ] tegrasign_v3.py --key None --list blob_mce_mts_d15_prod_cr_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 3.6092 ] Assuming zero filled SBK key
[ 3.6399 ] tegrahost_v2 --chip 0x18 0 --updatesigheader blob_mce_mts_d15_prod_cr_sigheader.bin.encrypt blob_mce_mts_d15_prod_cr_sigheader.bin.hash zerosbk
[ 3.6429 ]
[ 3.6451 ] tegrahost_v2 --chip 0x18 --align blob_bpmp.bin
[ 3.6457 ]
[ 3.6476 ] tegrahost_v2 --chip 0x18 0 --appendsigheader blob_bpmp.bin zerosbk
[ 3.6490 ]
[ 3.6568 ] tegrasign_v3.py --key None --list blob_bpmp_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 3.6569 ] Assuming zero filled SBK key
[ 3.6656 ] tegrahost_v2 --chip 0x18 0 --updatesigheader blob_bpmp_sigheader.bin.encrypt blob_bpmp_sigheader.bin.hash zerosbk
[ 3.6680 ]
[ 3.6704 ] tegrahost_v2 --chip 0x18 --align blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb
[ 3.6711 ]
[ 3.6731 ] tegrahost_v2 --chip 0x18 0 --appendsigheader blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb zerosbk
[ 3.6746 ]
[ 3.6825 ] tegrasign_v3.py --key None --list blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 3.6826 ] Assuming zero filled SBK key
[ 3.6876 ] tegrahost_v2 --chip 0x18 0 --updatesigheader blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.encrypt blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.hash zerosbk
[ 3.6896 ]
[ 3.6923 ] tegrahost_v2 --chip 0x18 --align blob_tos-trusty.img
[ 3.6936 ]
[ 3.6949 ] tegrahost_v2 --chip 0x18 0 --appendsigheader blob_tos-trusty.img zerosbk
[ 3.6966 ]
[ 3.7049 ] tegrasign_v3.py --key None --list blob_tos-trusty_sigheader.img_list.xml --pubkeyhash pub_key.key
[ 3.7049 ] Assuming zero filled SBK key
[ 3.7086 ] tegrahost_v2 --chip 0x18 0 --updatesigheader blob_tos-trusty_sigheader.img.encrypt blob_tos-trusty_sigheader.img.hash zerosbk
[ 3.7098 ]
[ 3.7119 ] tegrahost_v2 --chip 0x18 --align blob_eks.img
[ 3.7126 ]
[ 3.7146 ] tegrahost_v2 --chip 0x18 0 --appendsigheader blob_eks.img zerosbk
[ 3.7153 ]
[ 3.7231 ] tegrasign_v3.py --key None --list blob_eks_sigheader.img_list.xml --pubkeyhash pub_key.key
[ 3.7232 ] Assuming zero filled SBK key
[ 3.7222 ] tegrahost_v2 --chip 0x18 0 --updatesigheader blob_eks_sigheader.img.encrypt blob_eks_sigheader.img.hash zerosbk
[ 3.7237 ]
[ 3.7260 ] tegrahost_v2 --chip 0x18 --align blob_tegra186-quill-p3310-1000-c03-00-base.dtb
[ 3.7280 ]
[ 3.7302 ] tegrahost_v2 --chip 0x18 0 --appendsigheader blob_tegra186-quill-p3310-1000-c03-00-base.dtb zerosbk
[ 3.7318 ]
[ 3.7397 ] tegrasign_v3.py --key None --list blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 3.7398 ] Assuming zero filled SBK key
[ 3.7427 ] tegrahost_v2 --chip 0x18 0 --updatesigheader blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.hash zerosbk
[ 3.7439 ]
[ 3.7460 ] tegrahost_v2 --chip 0x18 --generateblob blob.xml blob.bin
[ 3.7467 ] number of images in blob are 9
[ 3.7469 ] blobsize is 4541416
[ 3.7470 ] Added binary blob_nvtboot_recovery_cpu_sigheader.bin.encrypt of size 225392
[ 3.7490 ] Added binary blob_nvtboot_recovery_sigheader.bin.encrypt of size 122272
[ 3.7492 ] Added binary blob_preboot_d15_prod_cr_sigheader.bin.encrypt of size 58256
[ 3.7495 ] Added binary blob_mce_mts_d15_prod_cr_sigheader.bin.encrypt of size 2197920
[ 3.7504 ] Added binary blob_bpmp_sigheader.bin.encrypt of size 534816
[ 3.7509 ] Added binary blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.encrypt of size 617920
[ 3.7515 ] Added binary blob_tos-trusty_sigheader.img.encrypt of size 407360
[ 3.7519 ] Added binary blob_eks_sigheader.img.encrypt of size 1440
[ 3.7522 ] Added binary blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt of size 375888
[ 3.7537 ]
[ 3.7538 ] Sending bootloader and pre-requisite binaries
[ 3.7560 ] tegrarcm_v2 --download blob blob.bin
[ 3.7567 ] Applet version 01.00.0000
[ 3.7738 ] Sending blob
[ 3.7739 ] […] 100%
[ 4.2776 ]
[ 4.2823 ] tegrarcm_v2 --boot recovery
[ 4.2851 ] Applet version 01.00.0000
[ 4.2892 ]
[ 5.2937 ] tegrarcm_v2 --isapplet
[ 5.7409 ]
[ 5.7459 ] tegradevflash_v2 --iscpubl
[ 5.7499 ] Cannot Open USB
[ 6.2012 ]
[ 7.2072 ] tegrarcm_v2 --isapplet
[ 7.2126 ]
[ 7.2174 ] tegradevflash_v2 --iscpubl
[ 7.2203 ] Bootloader version 01.00.0000
[ 7.2422 ] Bootloader version 01.00.0000
[ 7.2423 ]
[ 7.2425 ] Retrieving storage infomation
[ 7.2481 ] tegrarcm_v2 --oem platformdetails storage storage_info.bin
[ 7.2529 ] Applet is not running on device. Continue with Bootloader
[ 7.2702 ]
[ 7.2745 ] tegradevflash_v2 --oem platformdetails storage storage_info.bin
[ 7.2762 ] Bootloader version 01.00.0000
[ 7.2924 ] Saved platform info in storage_info.bin
[ 7.2968 ]
[ 7.2968 ] Flashing the device
[ 7.2995 ] tegraparser_v2 --storageinfo storage_info.bin --generategpt --pt flash.xml.bin
[ 7.3009 ]
[ 7.3031 ] tegradevflash_v2 --pt flash.xml.bin --create
[ 7.3038 ] Bootloader version 01.00.0000
[ 7.3059 ] Erasing sdmmc_boot: 3 … [Done]
[ 7.3172 ] Writing partition secondary_gpt with gpt_secondary_0_3.bin
[ 7.3175 ] […] 100%
[ 7.3303 ] Erasing sdmmc_user: 3 … [Done]
[ 8.0161 ] Writing partition master_boot_record with mbr_1_3.bin
[ 8.0175 ] […] 100%
[ 8.0212 ] Writing partition primary_gpt with gpt_primary_1_3.bin
[ 8.0231 ] […] 100%
[ 8.0274 ] Writing partition secondary_gpt with gpt_secondary_1_3.bin
[ 8.0408 ] […] 100%
[ 8.0525 ] Writing partition mb1 with mb1_prod.bin.encrypt
[ 8.0537 ] […] 100%
[ 8.0609 ] Writing partition mb1_b with mb1_prod.bin.encrypt
[ 8.0668 ] […] 100%
[ 8.0746 ] Writing partition spe-fw with spe_sigheader.bin.encrypt
[ 8.0789 ] […] 100%
[ 8.0850 ] Writing partition spe-fw_b with spe_sigheader.bin.encrypt
[ 8.0905 ] […] 100%
[ 8.0970 ] Writing partition mb2 with nvtboot_sigheader.bin.encrypt
[ 8.1030 ] […] 100%
[ 8.1100 ] Writing partition mb2_b with nvtboot_sigheader.bin.encrypt
[ 8.1157 ] […] 100%
[ 8.1231 ] Writing partition mts-preboot with preboot_d15_prod_cr_sigheader.bin.encrypt
[ 8.1289 ] […] 100%
[ 8.1348 ] Writing partition mts-preboot_b with preboot_d15_prod_cr_sigheader.bin.encrypt
[ 8.1400 ] […] 100%
[ 8.1463 ] Writing partition SMD with slot_metadata.bin
[ 8.1511 ] […] 100%
[ 8.1551 ] Writing partition SMD_b with slot_metadata.bin
[ 8.1571 ] […] 100%
[ 8.1614 ] Writing partition VER_b with emmc_bootblob_ver.txt
[ 8.1634 ] […] 100%
[ 8.1677 ] Writing partition VER with emmc_bootblob_ver.txt
[ 8.1696 ] […] 100%
[ 8.1738 ] Writing partition master_boot_record with mbr_1_3.bin
[ 8.1758 ] […] 100%
[ 8.1797 ] Writing partition APP with system.img
[ 8.1814 ] […] 100%090%
[ 239.0562 ] Writing partition mts-bootpack with mce_mts_d15_prod_cr_sigheader.bin.encrypt
[ 239.0844 ] […] 100%
[ 239.1800 ] Writing partition mts-bootpack_b with mce_mts_d15_prod_cr_sigheader.bin.encrypt
[ 239.1874 ] […] 100%
[ 239.2951 ] Writing partition cpu-bootloader with cboot_sigheader.bin.encrypt
[ 239.3014 ] […] 100%
[ 239.3157 ] Writing partition cpu-bootloader_b with cboot_sigheader.bin.encrypt
[ 239.3237 ] […] 100%
[ 239.3368 ] Writing partition bootloader-dtb with tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt
[ 239.3443 ] […] 100%
[ 239.3584 ] Writing partition bootloader-dtb_b with tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt
[ 239.3687 ] […] 100%
[ 239.3846 ] Writing partition secure-os with tos-trusty_sigheader.img.encrypt
[ 239.3945 ] […] 100%
[ 239.4098 ] Writing partition secure-os_b with tos-trusty_sigheader.img.encrypt
[ 239.4196 ] […] 100%
[ 239.4384 ] Writing partition eks with eks_sigheader.img.encrypt
[ 239.4484 ] […] 100%
[ 239.4527 ] Writing partition adsp-fw with adsp-fw_sigheader.bin.encrypt
[ 239.4562 ] […] 100%
[ 239.4623 ] Writing partition adsp-fw_b with adsp-fw_sigheader.bin.encrypt
[ 239.4677 ] […] 100%
[ 239.4744 ] Writing partition bpmp-fw with bpmp_sigheader.bin.encrypt
[ 239.4798 ] […] 100%
[ 239.4998 ] Writing partition bpmp-fw_b with bpmp_sigheader.bin.encrypt
[ 239.5124 ] […] 100%
[ 239.5345 ] Writing partition bpmp-fw-dtb with tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.encrypt
[ 239.5476 ] […] 100%
[ 239.5692 ] Writing partition bpmp-fw-dtb_b with tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.encrypt
[ 239.5840 ] […] 100%
[ 239.6045 ] Writing partition sce-fw with camera-rtcpu-sce_sigheader.img.encrypt
[ 239.6169 ] […] 100%
[ 239.6244 ] Writing partition sce-fw_b with camera-rtcpu-sce_sigheader.img.encrypt
[ 239.6306 ] […] 100%
[ 239.6381 ] Writing partition sc7 with warmboot_wbheader.bin.encrypt
[ 239.6448 ] […] 100%
[ 239.6493 ] Writing partition sc7_b with warmboot_wbheader.bin.encrypt
[ 239.6538 ] […] 100%
[ 239.6585 ] Writing partition BMP with bmp.blob
[ 239.6631 ] […] 100%
[ 239.6712 ] Writing partition BMP_b with bmp.blob
[ 239.6778 ] […] 100%
[ 239.6861 ] Writing partition recovery with recovery_sigheader.img.encrypt
[ 239.6936 ] […] 100%
[ 241.9553 ] Writing partition recovery-dtb with tegra186-quill-p3310-1000-c03-00-base.dtb_sigheader.rec.encrypt
[ 241.9654 ] […] 100%
[ 241.9803 ] Writing partition kernel-bootctrl with kernel_bootctrl.bin
[ 241.9907 ] […] 100%
[ 241.9953 ] Writing partition kernel-bootctrl_b with kernel_bootctrl.bin
[ 241.9974 ] […] 100%
[ 242.0025 ] Writing partition kernel with boot_sigheader.img.encrypt
[ 242.0045 ] […] 100%
[ 242.0254 ] Writing partition kernel_b with boot_sigheader.img.encrypt
[ 242.0372 ] […] 100%
[ 242.0582 ] Writing partition kernel-dtb with kernel_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt
[ 242.0701 ] […] 100%
[ 242.0832 ] Writing partition kernel-dtb_b with kernel_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt
[ 242.0954 ] […] 100%
[ 242.1196 ]
[ 242.1218 ] tegradevflash_v2 --write BCT br_bct_BR.bct
[ 242.1225 ] Bootloader version 01.00.0000
[ 242.1243 ] Writing partition BCT with br_bct_BR.bct
[ 242.1247 ] […] 100%
[ 242.1336 ]
[ 242.1369 ] tegradevflash_v2 --write MB1_BCT mb1_cold_boot_bct_MB1_sigheader.bct.encrypt
[ 242.1378 ] Bootloader version 01.00.0000
[ 242.1396 ] Writing partition MB1_BCT with mb1_cold_boot_bct_MB1_sigheader.bct.encrypt
[ 242.1404 ] […] 100%
[ 242.1503 ]
[ 242.1536 ] tegradevflash_v2 --write MB1_BCT_b mb1_cold_boot_bct_MB1_sigheader.bct.encrypt
[ 242.1564 ] Bootloader version 01.00.0000
[ 242.1599 ] Writing partition MB1_BCT_b with mb1_cold_boot_bct_MB1_sigheader.bct.encrypt
[ 242.1616 ] […] 100%
[ 242.1692 ]
[ 242.1694 ] Flashing completed
[ 242.1695 ] Coldbooting the device
[ 242.1740 ] tegradevflash_v2 --reboot coldboot
[ 242.1779 ] Bootloader version 01.00.0000
[ 242.1807 ]
*** The target t186ref has been flashed successfully. ***
Reset the board to boot from internal eMMC.
and i found [FAILED] Failed to start Configure USB flashing port for device mode during jetson boot. other people suffer same thing said there’s problem in sdk version…
