when I flash the dtb on my cunstom carrier board,it can not work,but it can work well through the development kit.The message as follows:
is there any suggestion?
L4T BSP Information:
R28 (release), REVISION: 2.0, GCID: 10567845, BOARD: t186ref, EABI: aarch64,
DATE: Fri Mar 2 04:57:01 UTC 2018
Target Board Information:
Name: jetson-tx2, Board Family: t186ref, SoC: Tegra 186,
OpMode: production, Boot Authentication: ,
./tegraflash.py --chip 0x18 --applet “/home/quicktron/tx2_img_linux1604/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin” --cmd “dump eeprom boardinfo cvm.bin” --skipuid
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0037 ] Generating RCM messages
[ 0.0051 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 --download rcm /home/quicktron/tx2_img_linux1604/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin 0 0
[ 0.0061 ] RCM 0 is saved as rcm_0.rcm
[ 0.0079 ] RCM 1 is saved as rcm_1.rcm
[ 0.0087 ] List of rcm files are saved in rcm_list.xml
[ 0.0155 ]
[ 0.0156 ] Signing RCM messages
[ 0.0168 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0184 ] Assuming zero filled SBK key
[ 0.0295 ]
[ 0.0296 ] Copying signature to RCM mesages
[ 0.0311 ] tegrarcm_v2 --chip 0x18 --updatesig rcm_list_signed.xml
[ 0.0396 ]
[ 0.0397 ] Boot Rom communication
[ 0.0408 ] tegrarcm_v2 --chip 0x18 --rcm rcm_list_signed.xml --skipuid
[ 0.0417 ] RCM version 0X180001
[ 0.1487 ] Boot Rom communication completed
[ 1.2950 ]
[ 1.2963 ] tegrarcm_v2 --isapplet
[ 1.2972 ] USB communication failed.Check if device is in recovery
[ 1.4671 ]
[ 1.4683 ] tegradevflash_v2 --iscpubl
[ 1.4727 ] CPU Bootloader is not running on device.
[ 1.6348 ]
[ 2.9218 ] Retrieving EEPROM data
[ 2.9220 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/quicktron/tx2_img_linux1604/Linux_for_Tegra/bootloader/cvm.bin
[ 2.9230 ] Applet version 01.00.0000
[ 3.2061 ] Saved platform info in /home/quicktron/tx2_img_linux1604/Linux_for_Tegra/bootloader/cvm.bin
[ 3.3581 ]
Board ID(3310) version(D01)
copying bctfile(/home/quicktron/tx2_img_linux1604/Linux_for_Tegra/bootloader/t186ref/BCT/P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg)… done.
copying misc_config(/home/quicktron/tx2_img_linux1604/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-misc-si-l4t.cfg)… done.
copying pinmux_config(/home/quicktron/tx2_img_linux1604/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg)… done.
copying pmic_config(/home/quicktron/tx2_img_linux1604/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg)… done.
copying pmc_config(/home/quicktron/tx2_img_linux1604/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg)… done.
copying prod_config(/home/quicktron/tx2_img_linux1604/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg)… done.
copying scr_config(/home/quicktron/tx2_img_linux1604/Linux_for_Tegra/bootloader/t186ref/BCT/minimal_scr.cfg)… done.
copying scr_cold_boot_config(/home/quicktron/tx2_img_linux1604/Linux_for_Tegra/bootloader/t186ref/BCT/mobile_scr.cfg)… done.
copying bootrom_config(/home/quicktron/tx2_img_linux1604/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg)… done.
copying dev_params(/home/quicktron/tx2_img_linux1604/Linux_for_Tegra/bootloader/t186ref/BCT/emmc.cfg)… done.
Existing bootloader(/home/quicktron/tx2_img_linux1604/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
populating kernel to rootfs… done.
populating initrd to rootfs… done.
populating extlinux.conf.emmc to rootfs… done.
populating /home/quicktron/tx2_img_linux1604/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb to rootfs… done.
done.
Making Boot image… done.
Existing sosfile(/home/quicktron/tx2_img_linux1604/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin) reused.
copying tegraboot(/home/quicktron/tx2_img_linux1604/Linux_for_Tegra/bootloader/t186ref/nvtboot.bin)… done.
Existing mb2blfile(/home/quicktron/tx2_img_linux1604/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
Existing mtspreboot(/home/quicktron/tx2_img_linux1604/Linux_for_Tegra/bootloader/preboot_d15_prod_cr.bin) reused.
Existing mts(/home/quicktron/tx2_img_linux1604/Linux_for_Tegra/bootloader/mce_mts_d15_prod_cr.bin) reused.
Existing mb1file(/home/quicktron/tx2_img_linux1604/Linux_for_Tegra/bootloader/mb1_prod.bin) reused.
Existing bpffile(/home/quicktron/tx2_img_linux1604/Linux_for_Tegra/bootloader/bpmp.bin) reused.
copying bpfdtbfile(/home/quicktron/tx2_img_linux1604/Linux_for_Tegra/bootloader/t186ref/tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb)… done.
Existing scefile(/home/quicktron/tx2_img_linux1604/Linux_for_Tegra/bootloader/camera-rtcpu-sce.bin) reused.
Existing spefile(/home/quicktron/tx2_img_linux1604/Linux_for_Tegra/bootloader/spe.bin) reused.
copying wb0boot(/home/quicktron/tx2_img_linux1604/Linux_for_Tegra/bootloader/t186ref/warmboot.bin)… done.
Existing tosfile(/home/quicktron/tx2_img_linux1604/Linux_for_Tegra/bootloader/tos.img) reused.
Existing eksfile(/home/quicktron/tx2_img_linux1604/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/quicktron/tx2_img_linux1604/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb)… done.
Reusing existing system.img…
done.
Existing tbcfile(/home/quicktron/tx2_img_linux1604/Linux_for_Tegra/bootloader/cboot.bin) reused.
copying tbcdtbfile(/home/quicktron/tx2_img_linux1604/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb)… done.
copying cfgfile(/home/quicktron/tx2_img_linux1604/Linux_for_Tegra/bootloader/t186ref/cfg/flash_l4t_t186.xml) to flash.xml… done.
Existing flasher(/home/quicktron/tx2_img_linux1604/Linux_for_Tegra/bootloader/nvtboot_recovery_cpu.bin) reused.
Existing flashapp(/home/quicktron/tx2_img_linux1604/Linux_for_Tegra/bootloader/tegraflash.py) reused.
*** Updating [kernel-dtb] with tegra186-quill-p3310-1000-c03-00-base.dtb ***
./tegraflash.py --bl nvtboot_recovery_cpu.bin --chip 0x18 --applet mb1_recovery_prod.bin --cfg flash.xml --sdram_config P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --sdram_config P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --misc_config tegra186-mb1-bct-misc-si-l4t.cfg --pinmux_config tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmic_config tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg --pmc_config tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --prod_config tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg --scr_config minimal_scr.cfg --scr_cold_boot_config mobile_scr.cfg --br_cmd_config tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --dev_params emmc.cfg --cfg flash.xml --bins “mb2_bootloader nvtboot_recovery.bin; mts_preboot preboot_d15_prod_cr.bin; mts_bootpack mce_mts_d15_prod_cr.bin; bpmp_fw bpmp.bin; bpmp_fw_dtb tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb; tlk tos.img; eks eks.img; bootloader_dtb tegra186-quill-p3310-1000-c03-00-base.dtb” --cmd “sign; write kernel-dtb ./signed/tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt; reboot”
version 1.0.0
[ 0.0147 ] tegrasign_v2 --key None --getmode mode.txt
[ 0.0159 ] Assuming zero filled SBK key
[ 0.0214 ]
[ 0.0215 ] Generating RCM messages
[ 0.0225 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 --download rcm mb1_recovery_prod.bin 0 0
[ 0.0235 ] RCM 0 is saved as rcm_0.rcm
[ 0.0242 ] RCM 1 is saved as rcm_1.rcm
[ 0.0248 ] List of rcm files are saved in rcm_list.xml
[ 0.0294 ]
[ 0.0295 ] Signing RCM messages
[ 0.0305 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0314 ] Assuming zero filled SBK key
[ 0.0422 ]
[ 0.0423 ] Copying signature to RCM mesages
[ 0.0448 ] tegrarcm_v2 --chip 0x18 --updatesig rcm_list_signed.xml
[ 0.0535 ]
[ 0.0536 ] Parsing partition layout
[ 0.0547 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.0615 ]
[ 0.0615 ] Creating list of images to be signed
[ 0.0626 ] tegrahost_v2 --chip 0x18 --partitionlayout flash.xml.bin --list images_list.xml zerosbk
[ 0.0976 ]
[ 0.0977 ] Generating signatures
[ 0.0987 ] tegrasign_v2 --key None --list images_list.xml --pubkeyhash pub_key.key
[ 0.0995 ] Assuming zero filled SBK key
[ 0.3533 ]
[ 0.3534 ] Generating br-bct
[ 0.3544 ] Updating dev and MSS params in BR BCT
[ 0.3545 ] tegrabct_v2 --dev_param emmc.cfg --sdram P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --brbct br_bct.cfg --chip 0x18
[ 0.3773 ]
[ 0.3774 ] Updating bl info
[ 0.3784 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 0.3894 ]
[ 0.3896 ] Updating smd info
[ 0.3906 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --updatesmdinfo flash.xml.bin
[ 0.3973 ]
[ 0.3974 ] Get Signed section bct
[ 0.3983 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --listbct bct_list.xml
[ 0.4054 ]
[ 0.4055 ] Signing BCT
[ 0.4072 ] tegrasign_v2 --key None --list bct_list.xml --pubkeyhash pub_key.key
[ 0.4082 ] Assuming zero filled SBK key
[ 0.4160 ]
[ 0.4160 ] Updating BCT with signature
[ 0.4172 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --updatesig bct_list_signed.xml
[ 0.4245 ]
[ 0.4246 ] Generating coldboot mb1-bct
[ 0.4257 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct.cfg --sdram P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --misc tegra186-mb1-bct-misc-si-l4t.cfg --scr mobile_scr.cfg --pinmux tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmc tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --pmic tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg --brcommand tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --prod tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 0.4267 ] MB1-BCT version: 0xe
[ 0.4272 ] Copying Sdram info from 2 to 3 set
[ 0.4425 ] Packing sdram param for instance[0]
[ 0.4432 ] Packing sdram param for instance[1]
[ 0.4440 ] Packing sdram param for instance[2]
[ 0.4447 ] Packing sdram param for instance[3]
[ 0.4456 ] Parsing config file :tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg
[ 0.4493 ] Appending platform config data of size :- 2904
[ 0.4522 ] Parsing config file :mobile_scr.cfg
[ 0.4531 ] Appending platform config data of size :- 12240
[ 0.4558 ] Parsing config file :tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg
[ 0.4571 ] Appending platform config data of size :- 24
[ 0.4580 ] Parsing config file :tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg
[ 0.4593 ] Appending platform config data of size :- 708
[ 0.4599 ]
[ 0.4599 ] Parsing config file :tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg
[ 0.4600 ] Appending platform config data of size :- 64
[ 0.4600 ]
[ 0.4600 ] Parsing config file :tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 0.4601 ] Appending platform config data of size :- 1652
[ 0.4601 ]
[ 0.4601 ] Updating mb1-bct with firmware information
[ 0.4611 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 0.4622 ] MB1-BCT version: 0xe
[ 0.4696 ]
[ 0.4697 ] Updating mb1-bct with storage information
[ 0.4707 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 0.4717 ] MB1-BCT version: 0xe
[ 0.4776 ]
[ 0.4785 ] tegrahost_v2 --align mb1_cold_boot_bct_MB1.bct
[ 0.4896 ]
[ 0.4908 ] tegrahost_v2 --appendsigheader mb1_cold_boot_bct_MB1.bct zerosbk
[ 0.4976 ]
[ 0.4989 ] tegrasign_v2 --key None --list mb1_cold_boot_bct_MB1_sigheader.bct_list.xml
[ 0.4997 ] Assuming zero filled SBK key
[ 0.5057 ]
[ 0.5072 ] tegrahost_v2 --updatesigheader mb1_cold_boot_bct_MB1_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_sigheader.bct.hash zerosbk
[ 0.5137 ]
[ 0.5164 ] Generating recovery mb1-bct
[ 0.5189 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct.cfg --sdram P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --misc tegra186-mb1-bct-misc-si-l4t.cfg --scr minimal_scr.cfg --pinmux tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmc tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --pmic tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg --brcommand tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --prod tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 0.5205 ] MB1-BCT version: 0xe
[ 0.5212 ] Copying Sdram info from 2 to 3 set
[ 0.5370 ] Packing sdram param for instance[0]
[ 0.5377 ] Packing sdram param for instance[1]
[ 0.5384 ] Packing sdram param for instance[2]
[ 0.5391 ] Packing sdram param for instance[3]
[ 0.5400 ] Parsing config file :tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg
[ 0.5413 ] Appending platform config data of size :- 2904
[ 0.5445 ] Parsing config file :minimal_scr.cfg
[ 0.5445 ] Appending platform config data of size :- 12240
[ 0.5446 ]
[ 0.5446 ] Parsing config file :tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg
[ 0.5446 ] Appending platform config data of size :- 24
[ 0.5447 ]
[ 0.5447 ] Parsing config file :tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg
[ 0.5447 ] Appending platform config data of size :- 708
[ 0.5448 ]
[ 0.5448 ] Parsing config file :tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg
[ 0.5448 ] Appending platform config data of size :- 64
[ 0.5449 ]
[ 0.5449 ] Parsing config file :tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 0.5449 ] Appending platform config data of size :- 1652
[ 0.5449 ]
[ 0.5450 ] Updating mb1-bct with firmware information
[ 0.5463 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 0.5506 ] MB1-BCT version: 0xe
[ 0.5579 ]
[ 0.5580 ] Updating mb1-bct with storage information
[ 0.5592 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 0.5603 ] MB1-BCT version: 0xe
[ 0.5658 ]
[ 0.5666 ] tegrahost_v2 --align mb1_bct_MB1.bct
[ 0.5738 ]
[ 0.5749 ] tegrahost_v2 --appendsigheader mb1_bct_MB1.bct zerosbk
[ 0.5835 ]
[ 0.5862 ] tegrasign_v2 --key None --list mb1_bct_MB1_sigheader.bct_list.xml
[ 0.5876 ] Assuming zero filled SBK key
[ 0.5939 ]
[ 0.5956 ] tegrahost_v2 --updatesigheader mb1_bct_MB1_sigheader.bct.encrypt mb1_bct_MB1_sigheader.bct.hash zerosbk
[ 0.6019 ]
[ 0.6020 ] Copying signatures
[ 0.6028 ] tegrahost_v2 --chip 0x18 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 0.7173 ]
[ 0.7185 ] tegrahost_v2 --align nvtboot_recovery.bin
[ 0.7253 ]
[ 0.7262 ] tegrahost_v2 --appendsigheader nvtboot_recovery.bin zerosbk
[ 0.7329 ]
[ 0.7347 ] tegrasign_v2 --key None --list nvtboot_recovery_sigheader.bin_list.xml
[ 0.7363 ] Assuming zero filled SBK key
[ 0.7475 ]
[ 0.7489 ] tegrahost_v2 --updatesigheader nvtboot_recovery_sigheader.bin.encrypt nvtboot_recovery_sigheader.bin.hash zerosbk
[ 0.7574 ]
[ 0.7586 ] tegrahost_v2 --align preboot_d15_prod_cr.bin
[ 0.7653 ]
[ 0.7661 ] tegrahost_v2 --appendsigheader preboot_d15_prod_cr.bin zerosbk
[ 0.7734 ]
[ 0.7746 ] tegrasign_v2 --key None --list preboot_d15_prod_cr_sigheader.bin_list.xml
[ 0.7755 ] Assuming zero filled SBK key
[ 0.7853 ]
[ 0.7869 ] tegrahost_v2 --updatesigheader preboot_d15_prod_cr_sigheader.bin.encrypt preboot_d15_prod_cr_sigheader.bin.hash zerosbk
[ 0.7934 ]
[ 0.7946 ] tegrahost_v2 --align mce_mts_d15_prod_cr.bin
[ 0.8015 ]
[ 0.8026 ] tegrahost_v2 --appendsigheader mce_mts_d15_prod_cr.bin zerosbk
[ 0.8152 ]
[ 0.8179 ] tegrasign_v2 --key None --list mce_mts_d15_prod_cr_sigheader.bin_list.xml
[ 0.8195 ] Assuming zero filled SBK key
[ 0.8797 ]
[ 0.8810 ] tegrahost_v2 --updatesigheader mce_mts_d15_prod_cr_sigheader.bin.encrypt mce_mts_d15_prod_cr_sigheader.bin.hash zerosbk
[ 0.8897 ]
[ 0.8921 ] tegrahost_v2 --align bpmp.bin
[ 0.8977 ]
[ 0.8988 ] tegrahost_v2 --appendsigheader bpmp.bin zerosbk
[ 0.9084 ]
[ 0.9111 ] tegrasign_v2 --key None --list bpmp_sigheader.bin_list.xml
[ 0.9124 ] Assuming zero filled SBK key
[ 0.9338 ]
[ 0.9351 ] tegrahost_v2 --updatesigheader bpmp_sigheader.bin.encrypt bpmp_sigheader.bin.hash zerosbk
[ 0.9447 ]
[ 0.9462 ] tegrahost_v2 --align tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb
[ 0.9538 ]
[ 0.9550 ] tegrahost_v2 --appendsigheader tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb zerosbk
[ 0.9619 ]
[ 0.9631 ] tegrasign_v2 --key None --list tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb_list.xml
[ 0.9640 ] Assuming zero filled SBK key
[ 0.9860 ]
[ 0.9875 ] tegrahost_v2 --updatesigheader tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.encrypt tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.hash zerosbk
[ 0.9939 ]
[ 0.9949 ] tegrahost_v2 --align tos.img
[ 1.0020 ]
[ 1.0030 ] tegrahost_v2 --appendsigheader tos.img zerosbk
[ 1.0122 ]
[ 1.0140 ] tegrasign_v2 --key None --list tos_sigheader.img_list.xml
[ 1.0152 ] Assuming zero filled SBK key
[ 1.0220 ]
[ 1.0234 ] tegrahost_v2 --updatesigheader tos_sigheader.img.encrypt tos_sigheader.img.hash zerosbk
[ 1.0301 ]
[ 1.0312 ] tegrahost_v2 --align eks.img
[ 1.0380 ]
[ 1.0388 ] tegrahost_v2 --appendsigheader eks.img zerosbk
[ 1.0502 ]
[ 1.0515 ] tegrasign_v2 --key None --list eks_sigheader.img_list.xml
[ 1.0524 ] Assuming zero filled SBK key
[ 1.0581 ]
[ 1.0594 ] tegrahost_v2 --updatesigheader eks_sigheader.img.encrypt eks_sigheader.img.hash zerosbk
[ 1.0661 ]
[ 1.0670 ] tegrahost_v2 --align tegra186-quill-p3310-1000-c03-00-base.dtb
[ 1.0732 ]
[ 1.0742 ] tegrahost_v2 --appendsigheader tegra186-quill-p3310-1000-c03-00-base.dtb zerosbk
[ 1.0853 ]
[ 1.0865 ] tegrasign_v2 --key None --list tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb_list.xml
[ 1.0874 ] Assuming zero filled SBK key
[ 1.0972 ]
[ 1.0985 ] tegrahost_v2 --updatesigheader tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.hash zerosbk
[ 1.1034 ]
[ 1.1043 ] tegrahost_v2 --align nvtboot_recovery_cpu.bin
[ 1.1123 ]
[ 1.1146 ] tegrahost_v2 --appendsigheader nvtboot_recovery_cpu.bin zerosbk
[ 1.1213 ]
[ 1.1226 ] tegrasign_v2 --key None --list nvtboot_recovery_cpu_sigheader.bin_list.xml
[ 1.1235 ] Assuming zero filled SBK key
[ 1.1333 ]
[ 1.1349 ] tegrahost_v2 --updatesigheader nvtboot_recovery_cpu_sigheader.bin.encrypt nvtboot_recovery_cpu_sigheader.bin.hash zerosbk
[ 1.1413 ]
[ 1.1415 ] Copying signed file in /home/quicktron/tx2_img_linux1604/Linux_for_Tegra/bootloader/signed
[ 1.1945 ] Generating RCM messages
[ 1.1967 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 --download rcm mb1_recovery_prod.bin 0 0
[ 1.1978 ] RCM 0 is saved as rcm_0.rcm
[ 1.1987 ] RCM 1 is saved as rcm_1.rcm
[ 1.1995 ] List of rcm files are saved in rcm_list.xml
[ 1.2057 ]
[ 1.2058 ] Signing RCM messages
[ 1.2069 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 1.2079 ] Assuming zero filled SBK key
[ 1.2218 ]
[ 1.2219 ] Copying signature to RCM mesages
[ 1.2230 ] tegrarcm_v2 --chip 0x18 --updatesig rcm_list_signed.xml
[ 1.2297 ]
[ 1.2298 ] Boot Rom communication
[ 1.2308 ] tegrarcm_v2 --chip 0x18 --rcm rcm_list_signed.xml
[ 1.2317 ] BootRom is not running
[ 2.4453 ]
[ 2.4465 ] tegrarcm_v2 --isapplet
[ 2.4474 ] Applet version 01.00.0000
[ 2.7257 ]
[ 2.7268 ] tegrasign_v2 --key None --getmode mode.txt
[ 2.7278 ] Assuming zero filled SBK key
[ 2.7367 ]
[ 2.7369 ] Parsing partition layout
[ 2.7380 ] tegraparser_v2 --pt flash.xml.tmp
[ 2.7427 ]
[ 2.7428 ] Creating list of images to be signed
[ 2.7437 ] tegrahost_v2 --chip 0x18 --partitionlayout flash.xml.bin --list images_list.xml zerosbk
[ 2.7858 ]
[ 2.7859 ] Generating signatures
[ 2.7869 ] tegrasign_v2 --key None --list images_list.xml --pubkeyhash pub_key.key
[ 2.7878 ] Assuming zero filled SBK key
[ 3.0415 ]
[ 3.0416 ] Reading BCT from device for further operations
[ 3.0417 ] Generating blob
[ 3.0430 ] tegrahost_v2 --align blob_nvtboot_recovery_cpu.bin
[ 3.0495 ]
[ 3.0507 ] tegrahost_v2 --appendsigheader blob_nvtboot_recovery_cpu.bin zerosbk
[ 3.0576 ]
[ 3.0591 ] tegrasign_v2 --key None --list blob_nvtboot_recovery_cpu_sigheader.bin_list.xml
[ 3.0601 ] Assuming zero filled SBK key
[ 3.0737 ]
[ 3.0762 ] tegrahost_v2 --updatesigheader blob_nvtboot_recovery_cpu_sigheader.bin.encrypt blob_nvtboot_recovery_cpu_sigheader.bin.hash zerosbk
[ 3.0816 ]
[ 3.0828 ] tegrahost_v2 --align blob_nvtboot_recovery.bin
[ 3.0896 ]
[ 3.0910 ] tegrahost_v2 --appendsigheader blob_nvtboot_recovery.bin zerosbk
[ 3.0977 ]
[ 3.0988 ] tegrasign_v2 --key None --list blob_nvtboot_recovery_sigheader.bin_list.xml
[ 3.0997 ] Assuming zero filled SBK key
[ 3.1137 ]
[ 3.1151 ] tegrahost_v2 --updatesigheader blob_nvtboot_recovery_sigheader.bin.encrypt blob_nvtboot_recovery_sigheader.bin.hash zerosbk
[ 3.1217 ]
[ 3.1229 ] tegrahost_v2 --align blob_preboot_d15_prod_cr.bin
[ 3.1297 ]
[ 3.1307 ] tegrahost_v2 --appendsigheader blob_preboot_d15_prod_cr.bin zerosbk
[ 3.1384 ]
[ 3.1410 ] tegrasign_v2 --key None --list blob_preboot_d15_prod_cr_sigheader.bin_list.xml
[ 3.1429 ] Assuming zero filled SBK key
[ 3.1498 ]
[ 3.1512 ] tegrahost_v2 --updatesigheader blob_preboot_d15_prod_cr_sigheader.bin.encrypt blob_preboot_d15_prod_cr_sigheader.bin.hash zerosbk
[ 3.1578 ]
[ 3.1591 ] tegrahost_v2 --align blob_mce_mts_d15_prod_cr.bin
[ 3.1658 ]
[ 3.1667 ] tegrahost_v2 --appendsigheader blob_mce_mts_d15_prod_cr.bin zerosbk
[ 3.1859 ]
[ 3.1873 ] tegrasign_v2 --key None --list blob_mce_mts_d15_prod_cr_sigheader.bin_list.xml
[ 3.1882 ] Assuming zero filled SBK key
[ 3.2461 ]
[ 3.2475 ] tegrahost_v2 --updatesigheader blob_mce_mts_d15_prod_cr_sigheader.bin.encrypt blob_mce_mts_d15_prod_cr_sigheader.bin.hash zerosbk
[ 3.2585 ]
[ 3.2597 ] tegrahost_v2 --align blob_bpmp.bin
[ 3.2661 ]
[ 3.2672 ] tegrahost_v2 --appendsigheader blob_bpmp.bin zerosbk
[ 3.2760 ]
[ 3.2792 ] tegrasign_v2 --key None --list blob_bpmp_sigheader.bin_list.xml
[ 3.2812 ] Assuming zero filled SBK key
[ 3.2982 ]
[ 3.2996 ] tegrahost_v2 --updatesigheader blob_bpmp_sigheader.bin.encrypt blob_bpmp_sigheader.bin.hash zerosbk
[ 3.3052 ]
[ 3.3063 ] tegrahost_v2 --align blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb
[ 3.3173 ]
[ 3.3185 ] tegrahost_v2 --appendsigheader blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb zerosbk
[ 3.3253 ]
[ 3.3266 ] tegrasign_v2 --key None --list blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb_list.xml
[ 3.3276 ] Assuming zero filled SBK key
[ 3.3493 ]
[ 3.3511 ] tegrahost_v2 --updatesigheader blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.encrypt blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.hash zerosbk
[ 3.3615 ]
[ 3.3631 ] tegrahost_v2 --align blob_tos.img
[ 3.3693 ]
[ 3.3704 ] tegrahost_v2 --appendsigheader blob_tos.img zerosbk
[ 3.3778 ]
[ 3.3806 ] tegrasign_v2 --key None --list blob_tos_sigheader.img_list.xml
[ 3.3822 ] Assuming zero filled SBK key
[ 3.3894 ]
[ 3.3908 ] tegrahost_v2 --updatesigheader blob_tos_sigheader.img.encrypt blob_tos_sigheader.img.hash zerosbk
[ 3.3974 ]
[ 3.3987 ] tegrahost_v2 --align blob_eks.img
[ 3.4055 ]
[ 3.4066 ] tegrahost_v2 --appendsigheader blob_eks.img zerosbk
[ 3.4146 ]
[ 3.4162 ] tegrasign_v2 --key None --list blob_eks_sigheader.img_list.xml
[ 3.4173 ] Assuming zero filled SBK key
[ 3.4215 ]
[ 3.4233 ] tegrahost_v2 --updatesigheader blob_eks_sigheader.img.encrypt blob_eks_sigheader.img.hash zerosbk
[ 3.4303 ]
[ 3.4316 ] tegrahost_v2 --align blob_tegra186-quill-p3310-1000-c03-00-base.dtb
[ 3.4376 ]
[ 3.4387 ] tegrahost_v2 --appendsigheader blob_tegra186-quill-p3310-1000-c03-00-base.dtb zerosbk
[ 3.4466 ]
[ 3.4491 ] tegrasign_v2 --key None --list blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb_list.xml
[ 3.4506 ] Assuming zero filled SBK key
[ 3.4616 ]
[ 3.4632 ] tegrahost_v2 --updatesigheader blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.hash zerosbk
[ 3.4697 ]
[ 3.4711 ] tegrahost_v2 --generateblob blob.xml blob.bin
[ 3.4719 ] number of images in blob are 9
[ 3.4726 ] blobsize is 3684664
[ 3.4730 ] Added binary blob_nvtboot_recovery_cpu_sigheader.bin.encrypt of size 189824
[ 3.4792 ] Added binary blob_nvtboot_recovery_sigheader.bin.encrypt of size 79440
[ 3.4798 ] Added binary blob_preboot_d15_prod_cr_sigheader.bin.encrypt of size 63024
[ 3.4828 ] Added binary blob_mce_mts_d15_prod_cr_sigheader.bin.encrypt of size 2076832
[ 3.4888 ] Added binary blob_bpmp_sigheader.bin.encrypt of size 529440
[ 3.4905 ] Added binary blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.encrypt of size 466160
[ 3.4929 ] Added binary blob_tos_sigheader.img.encrypt of size 62976
[ 3.4941 ] Added binary blob_eks_sigheader.img.encrypt of size 1488
[ 3.4951 ] Added binary blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt of size 215328
[ 3.5128 ]
[ 3.5129 ] Sending bootloader and pre-requisite binaries
[ 3.5152 ] tegrarcm_v2 --download blob blob.bin
[ 3.5167 ] Applet version 01.00.0000
[ 3.6564 ] Sending blob
[ 3.6567 ] […] 100%
[ 4.9932 ]
[ 4.9945 ] tegrarcm_v2 --boot recovery
[ 4.9959 ] Applet version 01.00.0000
[ 5.2927 ]
[ 5.2942 ] tegrarcm_v2 --isapplet
[ 6.7696 ]
[ 6.7708 ] tegradevflash_v2 --iscpubl
[ 6.7717 ] CPU Bootloader is not running on device.
[ 6.9332 ]
[ 56.7683 ] Writing partition
[ 56.7696 ] tegradevflash_v2 --write kernel-dtb /home/quicktron/tx2_img_linux1604/Linux_for_Tegra/bootloader/signed/tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt
[ 56.7707 ] Cannot Open USB
[ 57.0816 ]
Error: Return value 8
Command tegradevflash_v2 --write kernel-dtb /home/quicktron/tx2_img_linux1604/Linux_for_Tegra/bootloader/signed/tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt
Failed to flash/read t186ref.
