Hi all,
I would like to flash L4T R28.2.1 to eMMC on JetsonTX2, but it failed by return code 4.
I have to use this version for our development, not latest version.
My environment is,
- PC : VirtualBox 6.0.14 r133895
- OS : Ubuntu 16.04.6 LTS
And I operated flash command according to URL in below.
https://docs.nvidia.com/jetson/archives/l4t-archived/l4t-282/index.html#page/Tegra%2520Linux%2520Driver%2520Package%2520Development%2520Guide%2Fflashing.html
Actually, I have done following,
mkdir -p /opt/l4t
cd /opt/l4t
sudo tar xpf Tegra186_Linux_R28.2.1_aarch64.tbz2
cd Linux_for_Tegra/rootfs
sudo tar xpf Tegra_Linux_Sample-Root-Filesystem_R28.2.1_aarch64.tbz2
cd ..
sudo ./apply_binaries.sh
sudo ./flash.sh jetson-tx2 mmcblk0p1
But the result is failed by return code 4.
How to flash R28.2.1 to JetsonTX2 successfully ?
JetsonTX2 cannot be flashed through VirtualBox ?
‘flash.sh’ log is below,
# L4T BSP Information:
# R28 (release), REVISION: 2.1, GCID: 11272647, BOARD: t186ref, EABI: aarch64,
# DATE: Thu May 17 07:29:06 UTC 2018
# Target Board Information:
# Name: jetson-tx2, Board Family: t186ref, SoC: Tegra 186,
# OpMode: production, Boot Authentication: ,
./tegraflash.py --chip 0x18 --applet "/opt/l4t/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin" --cmd "dump eeprom boardinfo cvm.bin" --skipuid
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0027 ] Generating RCM messages
[ 0.0041 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 --download rcm /opt/l4t/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin 0 0
[ 0.0052 ] RCM 0 is saved as rcm_0.rcm
[ 0.0061 ] RCM 1 is saved as rcm_1.rcm
[ 0.0061 ] List of rcm files are saved in rcm_list.xml
[ 0.0061 ]
[ 0.0061 ] Signing RCM messages
[ 0.0079 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0091 ] Assuming zero filled SBK key
[ 0.0125 ]
[ 0.0126 ] Copying signature to RCM mesages
[ 0.0140 ] tegrarcm_v2 --chip 0x18 --updatesig rcm_list_signed.xml
[ 0.0158 ]
[ 0.0159 ] Boot Rom communication
[ 0.0168 ] tegrarcm_v2 --chip 0x18 --rcm rcm_list_signed.xml --skipuid
[ 0.0177 ] RCM version 0X180001
[ 0.0190 ] Boot Rom communication completed
[ 1.0353 ]
[ 1.0364 ] tegrarcm_v2 --isapplet
[ 1.0372 ] USB communication failed.Check if device is in recovery
[ 1.8039 ]
[ 1.8049 ] tegradevflash_v2 --iscpubl
[ 1.8057 ] CPU Bootloader is not running on device.
[ 1.8231 ]
[ 2.8339 ] Retrieving EEPROM data
[ 2.8340 ] tegrarcm_v2 --oem platformdetails eeprom cvm /opt/l4t/Linux_for_Tegra/bootloader/cvm.bin
[ 2.8349 ] Applet version 01.00.0000
[ 2.8402 ] Saved platform info in /opt/l4t/Linux_for_Tegra/bootloader/cvm.bin
[ 2.9307 ]
Board ID(3310) version(B02)
copying bctfile(/opt/l4t/Linux_for_Tegra/bootloader/t186ref/BCT/P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg)... done.
copying misc_config(/opt/l4t/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-misc-si-l4t.cfg)... done.
copying pinmux_config(/opt/l4t/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg)... done.
copying pmic_config(/opt/l4t/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg)... done.
copying pmc_config(/opt/l4t/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg)... done.
copying prod_config(/opt/l4t/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg)... done.
copying scr_config(/opt/l4t/Linux_for_Tegra/bootloader/t186ref/BCT/minimal_scr.cfg)... done.
copying scr_cold_boot_config(/opt/l4t/Linux_for_Tegra/bootloader/t186ref/BCT/mobile_scr.cfg)... done.
copying bootrom_config(/opt/l4t/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg)... done.
copying dev_params(/opt/l4t/Linux_for_Tegra/bootloader/t186ref/BCT/emmc.cfg)... done.
Existing bootloader(/opt/l4t/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
populating kernel to rootfs... done.
populating initrd to rootfs... done.
populating extlinux.conf.emmc to rootfs... done.
populating /opt/l4t/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb to rootfs... done.
done.
Making Boot image... done.
Existing sosfile(/opt/l4t/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin) reused.
copying tegraboot(/opt/l4t/Linux_for_Tegra/bootloader/t186ref/nvtboot.bin)... done.
Existing mb2blfile(/opt/l4t/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
Existing mtspreboot(/opt/l4t/Linux_for_Tegra/bootloader/preboot_d15_prod_cr.bin) reused.
Existing mts(/opt/l4t/Linux_for_Tegra/bootloader/mce_mts_d15_prod_cr.bin) reused.
Existing mb1file(/opt/l4t/Linux_for_Tegra/bootloader/mb1_prod.bin) reused.
Existing bpffile(/opt/l4t/Linux_for_Tegra/bootloader/bpmp.bin) reused.
copying bpfdtbfile(/opt/l4t/Linux_for_Tegra/bootloader/t186ref/tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb)... done.
Existing scefile(/opt/l4t/Linux_for_Tegra/bootloader/camera-rtcpu-sce.bin) reused.
Existing spefile(/opt/l4t/Linux_for_Tegra/bootloader/spe.bin) reused.
copying wb0boot(/opt/l4t/Linux_for_Tegra/bootloader/t186ref/warmboot.bin)... done.
Existing tosfile(/opt/l4t/Linux_for_Tegra/bootloader/tos.img) reused.
Existing eksfile(/opt/l4t/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/opt/l4t/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb)... done.
Making system.img...
populating rootfs from /opt/l4t/Linux_for_Tegra/rootfs ... done.
Sync'ing system.img ... done.
Converting RAW image to Sparse image...
---- Raw to Sparse Image Converter v1.0 ----------------------------
0: RAW: 4239360( 1035 blks) ==> 28:4239372
1: SKP: 24576( 6 blks) ==> 4239400:12
2: RAW: 4096( 1 blks) ==> 4239412:4108
2932: RAW: 10485760( 2560 blks) ==> 3487869324:10485772
2933: SKP: 1902116864( 464384 blks) ==> 3498355096:12
-- Total: ---------------------------------------------------
2934 CHUNK 30064771072(7340032 blks) ==> 3498355108(854082 blks)
done.
system.img built successfully.
Existing tbcfile(/opt/l4t/Linux_for_Tegra/bootloader/cboot.bin) reused.
copying tbcdtbfile(/opt/l4t/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb)... done.
copying cfgfile(/opt/l4t/Linux_for_Tegra/bootloader/t186ref/cfg/flash_l4t_t186.xml) to flash.xml... done.
Existing flasher(/opt/l4t/Linux_for_Tegra/bootloader/nvtboot_recovery_cpu.bin) reused.
Existing flashapp(/opt/l4t/Linux_for_Tegra/bootloader/tegraflash.py) reused.
./tegraflash.py --bl nvtboot_recovery_cpu.bin --sdram_config P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --odmdata 0x1090000 --applet mb1_recovery_prod.bin --cmd "flash; reboot" --cfg flash.xml --chip 0x18 --misc_config tegra186-mb1-bct-misc-si-l4t.cfg --pinmux_config tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmic_config tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg --pmc_config tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --prod_config tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg --scr_config minimal_scr.cfg --scr_cold_boot_config mobile_scr.cfg --br_cmd_config tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --dev_params emmc.cfg --bins "mb2_bootloader nvtboot_recovery.bin; mts_preboot preboot_d15_prod_cr.bin; mts_bootpack mce_mts_d15_prod_cr.bin; bpmp_fw bpmp.bin; bpmp_fw_dtb tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb; tlk tos.img; eks eks.img; bootloader_dtb tegra186-quill-p3310-1000-c03-00-base.dtb"
saving flash command in /opt/l4t/Linux_for_Tegra/bootloader/flashcmd.txt
copying boot image (boot.img.sb)... done.
copying partition layout (flash.xml.sb)... done.
copying kernel dtb (tegra186-quill-p3310-1000-c03-00-base.dtb.sb)... done.
saving flash parameters in /opt/l4t/Linux_for_Tegra/bootloader/flash_parameters.txt
*** Flashing target device started. ***
version 1.0.0
[ 0.0021 ] tegrasign_v2 --key None --getmode mode.txt
[ 0.0040 ] Assuming zero filled SBK key
[ 0.0054 ]
[ 0.0055 ] Generating RCM messages
[ 0.0079 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 --download rcm mb1_recovery_prod.bin 0 0
[ 0.0088 ] RCM 0 is saved as rcm_0.rcm
[ 0.0121 ] RCM 1 is saved as rcm_1.rcm
[ 0.0121 ] List of rcm files are saved in rcm_list.xml
[ 0.0121 ]
[ 0.0121 ] Signing RCM messages
[ 0.0129 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0136 ] Assuming zero filled SBK key
[ 0.0170 ]
[ 0.0170 ] Copying signature to RCM mesages
[ 0.0179 ] tegrarcm_v2 --chip 0x18 --updatesig rcm_list_signed.xml
[ 0.0191 ]
[ 0.0191 ] Parsing partition layout
[ 0.0211 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.0249 ]
[ 0.0249 ] Creating list of images to be signed
[ 0.0273 ] tegrahost_v2 --chip 0x18 --partitionlayout flash.xml.bin --list images_list.xml zerosbk
[ 0.0837 ]
[ 0.0837 ] Generating signatures
[ 0.0850 ] tegrasign_v2 --key None --list images_list.xml --pubkeyhash pub_key.key
[ 0.0859 ] Assuming zero filled SBK key
[ 0.3268 ]
[ 0.3269 ] Generating br-bct
[ 0.3303 ] Updating dev and MSS params in BR BCT
[ 0.3303 ] tegrabct_v2 --dev_param emmc.cfg --sdram P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --brbct br_bct.cfg --chip 0x18
[ 0.3706 ]
[ 0.3707 ] Updating bl info
[ 0.3716 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 0.3745 ]
[ 0.3745 ] Updating smd info
[ 0.3755 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --updatesmdinfo flash.xml.bin
[ 0.3772 ]
[ 0.3772 ] Updating Odmdata
[ 0.3782 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --updatefields Odmdata =0x1090000
[ 0.3800 ]
[ 0.3800 ] Get Signed section bct
[ 0.3815 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --listbct bct_list.xml
[ 0.3826 ]
[ 0.3826 ] Signing BCT
[ 0.3843 ] tegrasign_v2 --key None --list bct_list.xml --pubkeyhash pub_key.key
[ 0.3851 ] Assuming zero filled SBK key
[ 0.3960 ]
[ 0.3960 ] Updating BCT with signature
[ 0.3970 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --updatesig bct_list_signed.xml
[ 0.3985 ]
[ 0.3985 ] Generating coldboot mb1-bct
[ 0.3995 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct.cfg --sdram P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --misc tegra186-mb1-bct-misc-si-l4t.cfg --scr mobile_scr.cfg --pinmux tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmc tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --pmic tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg --brcommand tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --prod tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 0.4005 ] MB1-BCT version: 0xe
[ 0.4007 ] Copying Sdram info from 2 to 3 set
[ 0.4243 ] Packing sdram param for instance[0]
[ 0.4246 ] Packing sdram param for instance[1]
[ 0.4250 ] Packing sdram param for instance[2]
[ 0.4253 ] Packing sdram param for instance[3]
[ 0.4256 ] Parsing config file :tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg
[ 0.4263 ] Appending platform config data of size :- 2904
[ 0.4268 ] Parsing config file :mobile_scr.cfg
[ 0.4271 ] Appending platform config data of size :- 12240
[ 0.4288 ] Parsing config file :tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg
[ 0.4296 ] Appending platform config data of size :- 24
[ 0.4302 ]
[ 0.4302 ] Parsing config file :tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg
[ 0.4302 ] Appending platform config data of size :- 708
[ 0.4302 ]
[ 0.4302 ] Parsing config file :tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg
[ 0.4302 ] Appending platform config data of size :- 64
[ 0.4302 ]
[ 0.4302 ] Parsing config file :tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 0.4302 ] Appending platform config data of size :- 1652
[ 0.4302 ]
[ 0.4303 ] Updating mb1-bct with firmware information
[ 0.4313 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 0.4322 ] MB1-BCT version: 0xe
[ 0.4328 ]
[ 0.4328 ] Updating mb1-bct with storage information
[ 0.4336 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 0.4345 ] MB1-BCT version: 0xe
[ 0.4349 ]
[ 0.4359 ] tegrahost_v2 --align mb1_cold_boot_bct_MB1.bct
[ 0.4368 ]
[ 0.4377 ] tegrahost_v2 --appendsigheader mb1_cold_boot_bct_MB1.bct zerosbk
[ 0.4388 ]
[ 0.4400 ] tegrasign_v2 --key None --list mb1_cold_boot_bct_MB1_sigheader.bct_list.xml
[ 0.4408 ] Assuming zero filled SBK key
[ 0.4423 ]
[ 0.4437 ] tegrahost_v2 --updatesigheader mb1_cold_boot_bct_MB1_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_sigheader.bct.hash zerosbk
[ 0.4448 ]
[ 0.4448 ] Generating recovery mb1-bct
[ 0.4457 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct.cfg --sdram P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --misc tegra186-mb1-bct-misc-si-l4t.cfg --scr minimal_scr.cfg --pinmux tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmc tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --pmic tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg --brcommand tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --prod tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 0.4466 ] MB1-BCT version: 0xe
[ 0.4468 ] Copying Sdram info from 2 to 3 set
[ 0.4708 ] Packing sdram param for instance[0]
[ 0.4712 ] Packing sdram param for instance[1]
[ 0.4716 ] Packing sdram param for instance[2]
[ 0.4719 ] Packing sdram param for instance[3]
[ 0.4723 ] Parsing config file :tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg
[ 0.4729 ] Appending platform config data of size :- 2904
[ 0.4734 ] Parsing config file :minimal_scr.cfg
[ 0.4737 ] Appending platform config data of size :- 12240
[ 0.4745 ]
[ 0.4745 ] Parsing config file :tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg
[ 0.4745 ] Appending platform config data of size :- 24
[ 0.4745 ]
[ 0.4745 ] Parsing config file :tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg
[ 0.4745 ] Appending platform config data of size :- 708
[ 0.4745 ]
[ 0.4745 ] Parsing config file :tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg
[ 0.4745 ] Appending platform config data of size :- 64
[ 0.4745 ]
[ 0.4745 ] Parsing config file :tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 0.4745 ] Appending platform config data of size :- 1652
[ 0.4745 ]
[ 0.4746 ] Updating mb1-bct with firmware information
[ 0.4756 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 0.4764 ] MB1-BCT version: 0xe
[ 0.4771 ]
[ 0.4771 ] Updating mb1-bct with storage information
[ 0.4780 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 0.4789 ] MB1-BCT version: 0xe
[ 0.4793 ]
[ 0.4803 ] tegrahost_v2 --align mb1_bct_MB1.bct
[ 0.4816 ]
[ 0.4826 ] tegrahost_v2 --appendsigheader mb1_bct_MB1.bct zerosbk
[ 0.4839 ]
[ 0.4851 ] tegrasign_v2 --key None --list mb1_bct_MB1_sigheader.bct_list.xml
[ 0.4859 ] Assuming zero filled SBK key
[ 0.4873 ]
[ 0.4885 ] tegrahost_v2 --updatesigheader mb1_bct_MB1_sigheader.bct.encrypt mb1_bct_MB1_sigheader.bct.hash zerosbk
[ 0.4896 ]
[ 0.4896 ] Copying signatures
[ 0.4905 ] tegrahost_v2 --chip 0x18 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 0.5435 ]
[ 0.5436 ] Boot Rom communication
[ 0.5449 ] tegrarcm_v2 --chip 0x18 --rcm rcm_list_signed.xml
[ 0.5470 ] BootRom is not running
[ 1.5692 ]
[ 1.5701 ] tegrarcm_v2 --isapplet
[ 1.5709 ] Applet version 01.00.0000
[ 1.5798 ]
[ 1.5798 ] Retrieving board information
[ 1.5806 ] tegrarcm_v2 --oem platformdetails chip chip_info.bin
[ 1.5814 ] Applet version 01.00.0000
[ 1.5913 ] Saved platform info in chip_info.bin
[ 1.5955 ] Chip minor revision: 2
[ 1.5968 ]
[ 1.5969 ] Sending BCTs
[ 1.5979 ] tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 1.6007 ] Applet version 01.00.0000
[ 1.6109 ] Sending bct_bootrom
[ 1.6114 ] [................................................] 100%
[ 1.6244 ] Sending bct_mb1
[ 1.6321 ] [................................................] 100%
[ 1.9882 ]
[ 1.9883 ] Generating blob
[ 1.9892 ] tegrahost_v2 --align blob_nvtboot_recovery_cpu.bin
[ 1.9899 ]
[ 1.9907 ] tegrahost_v2 --appendsigheader blob_nvtboot_recovery_cpu.bin zerosbk
[ 1.9918 ]
[ 1.9928 ] tegrasign_v2 --key None --list blob_nvtboot_recovery_cpu_sigheader.bin_list.xml
[ 1.9935 ] Assuming zero filled SBK key
[ 1.9980 ]
[ 1.9991 ] tegrahost_v2 --updatesigheader blob_nvtboot_recovery_cpu_sigheader.bin.encrypt blob_nvtboot_recovery_cpu_sigheader.bin.hash zerosbk
[ 2.0003 ]
[ 2.0013 ] tegrahost_v2 --align blob_nvtboot_recovery.bin
[ 2.0021 ]
[ 2.0030 ] tegrahost_v2 --appendsigheader blob_nvtboot_recovery.bin zerosbk
[ 2.0107 ]
[ 2.0121 ] tegrasign_v2 --key None --list blob_nvtboot_recovery_sigheader.bin_list.xml
[ 2.0131 ] Assuming zero filled SBK key
[ 2.0150 ]
[ 2.0163 ] tegrahost_v2 --updatesigheader blob_nvtboot_recovery_sigheader.bin.encrypt blob_nvtboot_recovery_sigheader.bin.hash zerosbk
[ 2.0175 ]
[ 2.0187 ] tegrahost_v2 --align blob_preboot_d15_prod_cr.bin
[ 2.0196 ]
[ 2.0205 ] tegrahost_v2 --appendsigheader blob_preboot_d15_prod_cr.bin zerosbk
[ 2.0216 ]
[ 2.0228 ] tegrasign_v2 --key None --list blob_preboot_d15_prod_cr_sigheader.bin_list.xml
[ 2.0237 ] Assuming zero filled SBK key
[ 2.0255 ]
[ 2.0268 ] tegrahost_v2 --updatesigheader blob_preboot_d15_prod_cr_sigheader.bin.encrypt blob_preboot_d15_prod_cr_sigheader.bin.hash zerosbk
[ 2.0281 ]
[ 2.0293 ] tegrahost_v2 --align blob_mce_mts_d15_prod_cr.bin
[ 2.0302 ]
[ 2.0322 ] tegrahost_v2 --appendsigheader blob_mce_mts_d15_prod_cr.bin zerosbk
[ 2.0368 ]
[ 2.0382 ] tegrasign_v2 --key None --list blob_mce_mts_d15_prod_cr_sigheader.bin_list.xml
[ 2.0390 ] Assuming zero filled SBK key
[ 2.0856 ]
[ 2.0869 ] tegrahost_v2 --updatesigheader blob_mce_mts_d15_prod_cr_sigheader.bin.encrypt blob_mce_mts_d15_prod_cr_sigheader.bin.hash zerosbk
[ 2.0906 ]
[ 2.0921 ] tegrahost_v2 --align blob_bpmp.bin
[ 2.0930 ]
[ 2.0940 ] tegrahost_v2 --appendsigheader blob_bpmp.bin zerosbk
[ 2.0960 ]
[ 2.0971 ] tegrasign_v2 --key None --list blob_bpmp_sigheader.bin_list.xml
[ 2.0979 ] Assuming zero filled SBK key
[ 2.1110 ]
[ 2.1127 ] tegrahost_v2 --updatesigheader blob_bpmp_sigheader.bin.encrypt blob_bpmp_sigheader.bin.hash zerosbk
[ 2.1147 ]
[ 2.1168 ] tegrahost_v2 --align blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb
[ 2.1178 ]
[ 2.1190 ] tegrahost_v2 --appendsigheader blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb zerosbk
[ 2.1209 ]
[ 2.1221 ] tegrasign_v2 --key None --list blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb_list.xml
[ 2.1230 ] Assuming zero filled SBK key
[ 2.1338 ]
[ 2.1350 ] tegrahost_v2 --updatesigheader blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.encrypt blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.hash zerosbk
[ 2.1363 ]
[ 2.1373 ] tegrahost_v2 --align blob_tos.img
[ 2.1380 ]
[ 2.1388 ] tegrahost_v2 --appendsigheader blob_tos.img zerosbk
[ 2.1399 ]
[ 2.1413 ] tegrasign_v2 --key None --list blob_tos_sigheader.img_list.xml
[ 2.1423 ] Assuming zero filled SBK key
[ 2.1439 ]
[ 2.1452 ] tegrahost_v2 --updatesigheader blob_tos_sigheader.img.encrypt blob_tos_sigheader.img.hash zerosbk
[ 2.1462 ]
[ 2.1470 ] tegrahost_v2 --align blob_eks.img
[ 2.1479 ]
[ 2.1487 ] tegrahost_v2 --appendsigheader blob_eks.img zerosbk
[ 2.1495 ]
[ 2.1505 ] tegrasign_v2 --key None --list blob_eks_sigheader.img_list.xml
[ 2.1514 ] Assuming zero filled SBK key
[ 2.1515 ]
[ 2.1530 ] tegrahost_v2 --updatesigheader blob_eks_sigheader.img.encrypt blob_eks_sigheader.img.hash zerosbk
[ 2.1542 ]
[ 2.1554 ] tegrahost_v2 --align blob_tegra186-quill-p3310-1000-c03-00-base.dtb
[ 2.1573 ]
[ 2.1587 ] tegrahost_v2 --appendsigheader blob_tegra186-quill-p3310-1000-c03-00-base.dtb zerosbk
[ 2.1604 ]
[ 2.1615 ] tegrasign_v2 --key None --list blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb_list.xml
[ 2.1625 ] Assuming zero filled SBK key
[ 2.1690 ]
[ 2.1702 ] tegrahost_v2 --updatesigheader blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.hash zerosbk
[ 2.1716 ]
[ 2.1728 ] tegrahost_v2 --generateblob blob.xml blob.bin
[ 2.1737 ] number of images in blob are 9
[ 2.1741 ] blobsize is 3749384
[ 2.1743 ] Added binary blob_nvtboot_recovery_cpu_sigheader.bin.encrypt of size 190048
[ 2.1762 ] Added binary blob_nvtboot_recovery_sigheader.bin.encrypt of size 79600
[ 2.1768 ] Added binary blob_preboot_d15_prod_cr_sigheader.bin.encrypt of size 63024
[ 2.1775 ] Added binary blob_mce_mts_d15_prod_cr_sigheader.bin.encrypt of size 2076832
[ 2.1781 ] Added binary blob_bpmp_sigheader.bin.encrypt of size 529440
[ 2.1786 ] Added binary blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.encrypt of size 466160
[ 2.1795 ] Added binary blob_tos_sigheader.img.encrypt of size 62976
[ 2.1795 ] Added binary blob_eks_sigheader.img.encrypt of size 1488
[ 2.1795 ] Added binary blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt of size 279664
[ 2.1795 ]
[ 2.1796 ] Sending bootloader and pre-requisite binaries
[ 2.1805 ] tegrarcm_v2 --download blob blob.bin
[ 2.1812 ] Applet version 01.00.0000
[ 2.1871 ] Sending blob
[ 2.1873 ] [................................................] 100%
[ 2.6700 ]
[ 2.6709 ] tegrarcm_v2 --boot recovery
[ 2.6715 ] Applet version 01.00.0000
[ 2.6798 ]
[ 2.6807 ] tegrarcm_v2 --isapplet
[ 3.3803 ]
[ 3.3846 ] tegradevflash_v2 --iscpubl
[ 3.3856 ] CPU Bootloader is not running on device.
[ 4.1485 ]
[ 34.5332 ] Retrieving storage infomation
[ 34.5343 ] tegrarcm_v2 --oem platformdetails storage storage_info.bin
[ 34.5353 ] Applet is not running on device. Continue with Bootloader
[ 34.5358 ]
[ 34.5366 ] tegradevflash_v2 --oem platformdetails storage storage_info.bin
[ 34.5374 ] CPU Bootloader is not running on device.
[ 34.5378 ]
Error: Return value 4
Command tegradevflash_v2 --oem platformdetails storage storage_info.bin
Failed flashing t186ref.
