Description:
1.We are using tx2 in jetpack3.2.1 environment.
2.In p2771-0000.conf.common our default ODMDATA is 0x7090000,by using devmem2 we check the lane owner infromation as follows:
/dev/mem opened.
Memory mapped at address 0x7fb4738000.
Value at address 0x2520284 (0x7fb4738284): 0x0
/dev/mem opened.
Memory mapped at address 0x7fb0cf7000.
Value at address 0x2530284 (0x7fb0cf7284): 0x0
/dev/mem opened.
Memory mapped at address 0x7f89637000.
Value at address 0x2540284 (0x7f89637284): 0x0
/dev/mem opened.
Memory mapped at address 0x7f8eb82000.
Value at address 0x2550284 (0x7f8eb82284): 0x1
/dev/mem opened.
Memory mapped at address 0x7f7b837000.
Value at address 0x2560284 (0x7f7b837284): 0x1
/dev/mem opened.
Memory mapped at address 0x7f9fe18000.
Value at address 0x2570284 (0x7f9fe18284): 0x2
3.We change the ODMDATA=0x6090000 in p2771-0000.conf.common
4.We change the device tree file and compile,copy the dtb to Linux_for_Tegra/kernel/dtb/
5.Exectue command: ./flash.sh -r -k kernel-dtb jetson-tx2 mmcblk0p1, the log as follows:
ubuntu@ubuntu:~/work/jetpack3.2.1/64_TX2/Linux_for_Tegra$ sudo ./flash.sh -r -k kernel-dtb jetson-tx2 mmcblk0p1
[sudo] password for ubuntu:
# L4T BSP Information:
# R28 (release), REVISION: 2.1, GCID: 11272647, BOARD: t186ref, EABI: aarch64,
# DATE: Thu May 17 07:29:06 UTC 2018
# Target Board Information:
# Name: jetson-tx2, Board Family: t186ref, SoC: Tegra 186,
# OpMode: production, Boot Authentication: ,
./tegraflash.py --chip 0x18 --applet "/home/ubuntu/work/jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin" --cmd "dump eeprom boardinfo cvm.bin" --skipuid
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0052 ] Generating RCM messages
[ 0.0100 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 --download rcm /home/ubuntu/work/jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin 0 0
[ 0.0115 ] RCM 0 is saved as rcm_0.rcm
[ 0.0132 ] RCM 1 is saved as rcm_1.rcm
[ 0.0144 ] List of rcm files are saved in rcm_list.xml
[ 0.0260 ]
[ 0.0260 ] Signing RCM messages
[ 0.0311 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0321 ] Assuming zero filled SBK key
[ 0.0423 ]
[ 0.0429 ] Copying signature to RCM mesages
[ 0.0450 ] tegrarcm_v2 --chip 0x18 --updatesig rcm_list_signed.xml
[ 0.0498 ]
[ 0.0500 ] Boot Rom communication
[ 0.0508 ] tegrarcm_v2 --chip 0x18 --rcm rcm_list_signed.xml --skipuid
[ 0.0591 ] RCM version 0X180001
[ 0.0622 ] Boot Rom communication completed
[ 1.2420 ]
[ 1.2433 ] tegrarcm_v2 --isapplet
[ 1.2442 ] USB communication failed.Check if device is in recovery
[ 1.5467 ]
[ 1.5492 ] tegradevflash_v2 --iscpubl
[ 1.5514 ] CPU Bootloader is not running on device.
[ 1.5731 ]
[ 2.5960 ] Retrieving EEPROM data
[ 2.5965 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/ubuntu/work/jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/cvm.bin
[ 2.5999 ] Applet version 01.00.0000
[ 2.6178 ] Saved platform info in /home/ubuntu/work/jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/cvm.bin
[ 2.7220 ]
Board ID(3310) version(B02)
copying bctfile(/home/ubuntu/work/jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg)... done.
copying misc_config(/home/ubuntu/work/jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-misc-si-l4t.cfg)... done.
copying pinmux_config(/home/ubuntu/work/jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg)... done.
copying pmic_config(/home/ubuntu/work/jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg)... done.
copying pmc_config(/home/ubuntu/work/jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg)... done.
copying prod_config(/home/ubuntu/work/jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg)... done.
copying scr_config(/home/ubuntu/work/jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/minimal_scr.cfg)... done.
copying scr_cold_boot_config(/home/ubuntu/work/jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/mobile_scr.cfg)... done.
copying bootrom_config(/home/ubuntu/work/jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg)... done.
copying dev_params(/home/ubuntu/work/jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/emmc.cfg)... done.
Existing bootloader(/home/ubuntu/work/jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
populating kernel to rootfs... done.
populating initrd to rootfs... done.
populating extlinux.conf.emmc to rootfs... done.
populating /home/ubuntu/work/jetpack3.2.1/64_TX2/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb to rootfs... done.
done.
Making Boot image... done.
Existing sosfile(/home/ubuntu/work/jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin) reused.
copying tegraboot(/home/ubuntu/work/jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/t186ref/nvtboot.bin)... done.
Existing mb2blfile(/home/ubuntu/work/jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
Existing mtspreboot(/home/ubuntu/work/jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/preboot_d15_prod_cr.bin) reused.
Existing mts(/home/ubuntu/work/jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/mce_mts_d15_prod_cr.bin) reused.
Existing mb1file(/home/ubuntu/work/jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/mb1_prod.bin) reused.
Existing bpffile(/home/ubuntu/work/jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/bpmp.bin) reused.
copying bpfdtbfile(/home/ubuntu/work/jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/t186ref/tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb)... done.
Existing scefile(/home/ubuntu/work/jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/camera-rtcpu-sce.bin) reused.
Existing spefile(/home/ubuntu/work/jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/spe.bin) reused.
copying wb0boot(/home/ubuntu/work/jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/t186ref/warmboot.bin)... done.
Existing tosfile(/home/ubuntu/work/jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/tos.img) reused.
Existing eksfile(/home/ubuntu/work/jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/ubuntu/work/jetpack3.2.1/64_TX2/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb)... done.
Reusing existing system.img...
done.
Existing tbcfile(/home/ubuntu/work/jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/cboot.bin) reused.
copying tbcdtbfile(/home/ubuntu/work/jetpack3.2.1/64_TX2/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb)... done.
copying cfgfile(/home/ubuntu/work/jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/t186ref/cfg/flash_l4t_t186.xml) to flash.xml... done.
Existing flasher(/home/ubuntu/work/jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/nvtboot_recovery_cpu.bin) reused.
Existing flashapp(/home/ubuntu/work/jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/tegraflash.py) reused.
*** Updating [kernel-dtb] with tegra186-quill-p3310-1000-c03-00-base.dtb ***
./tegraflash.py --bl nvtboot_recovery_cpu.bin --chip 0x18 --applet mb1_recovery_prod.bin --cfg flash.xml --sdram_config P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --sdram_config P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --misc_config tegra186-mb1-bct-misc-si-l4t.cfg --pinmux_config tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmic_config tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg --pmc_config tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --prod_config tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg --scr_config minimal_scr.cfg --scr_cold_boot_config mobile_scr.cfg --br_cmd_config tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --dev_params emmc.cfg --cfg flash.xml --bins "mb2_bootloader nvtboot_recovery.bin; mts_preboot preboot_d15_prod_cr.bin; mts_bootpack mce_mts_d15_prod_cr.bin; bpmp_fw bpmp.bin; bpmp_fw_dtb tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb; tlk tos.img; eks eks.img; bootloader_dtb tegra186-quill-p3310-1000-c03-00-base.dtb" --cmd "sign; write kernel-dtb ./signed/tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt; reboot"
version 1.0.0
[ 0.0256 ] tegrasign_v2 --key None --getmode mode.txt
[ 0.0270 ] Assuming zero filled SBK key
[ 0.0329 ]
[ 0.0331 ] Generating RCM messages
[ 0.0341 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 --download rcm mb1_recovery_prod.bin 0 0
[ 0.0351 ] RCM 0 is saved as rcm_0.rcm
[ 0.0364 ] RCM 1 is saved as rcm_1.rcm
[ 0.0376 ] List of rcm files are saved in rcm_list.xml
[ 0.0445 ]
[ 0.0448 ] Signing RCM messages
[ 0.0465 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0583 ] Assuming zero filled SBK key
[ 0.0731 ]
[ 0.0737 ] Copying signature to RCM mesages
[ 0.0765 ] tegrarcm_v2 --chip 0x18 --updatesig rcm_list_signed.xml
[ 0.0950 ]
[ 0.0951 ] Parsing partition layout
[ 0.0982 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.1049 ]
[ 0.1052 ] Creating list of images to be signed
[ 0.1067 ] tegrahost_v2 --chip 0x18 --partitionlayout flash.xml.bin --list images_list.xml zerosbk
[ 0.1803 ]
[ 0.1806 ] Generating signatures
[ 0.1819 ] tegrasign_v2 --key None --list images_list.xml --pubkeyhash pub_key.key
[ 0.1830 ] Assuming zero filled SBK key
[ 0.4970 ]
[ 0.4973 ] Generating br-bct
[ 0.4987 ] Updating dev and MSS params in BR BCT
[ 0.4988 ] tegrabct_v2 --dev_param emmc.cfg --sdram P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --brbct br_bct.cfg --chip 0x18
[ 0.5229 ]
[ 0.5231 ] Updating bl info
[ 0.5336 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 0.5851 ]
[ 0.5890 ] Updating smd info
[ 0.5920 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --updatesmdinfo flash.xml.bin
[ 0.6131 ]
[ 0.6131 ] Get Signed section bct
[ 0.6145 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --listbct bct_list.xml
[ 0.6251 ]
[ 0.6253 ] Signing BCT
[ 0.6317 ] tegrasign_v2 --key None --list bct_list.xml --pubkeyhash pub_key.key
[ 0.6328 ] Assuming zero filled SBK key
[ 0.6470 ]
[ 0.6470 ] Updating BCT with signature
[ 0.6481 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --updatesig bct_list_signed.xml
[ 0.6568 ]
[ 0.6576 ] Generating coldboot mb1-bct
[ 0.6600 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct.cfg --sdram P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --misc tegra186-mb1-bct-misc-si-l4t.cfg --scr mobile_scr.cfg --pinmux tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmc tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --pmic tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg --brcommand tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --prod tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 0.6611 ] MB1-BCT version: 0xe
[ 0.6621 ] Copying Sdram info from 2 to 3 set
[ 0.6942 ] Packing sdram param for instance[0]
[ 0.6959 ] Packing sdram param for instance[1]
[ 0.6996 ] Packing sdram param for instance[2]
[ 0.7002 ] Packing sdram param for instance[3]
[ 0.7007 ] Parsing config file :tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg
[ 0.7087 ] Appending platform config data of size :- 2904
[ 0.7094 ] Parsing config file :mobile_scr.cfg
[ 0.7096 ] Appending platform config data of size :- 12240
[ 0.7125 ] Parsing config file :tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg
[ 0.7129 ] Appending platform config data of size :- 24
[ 0.7162 ] Parsing config file :tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg
[ 0.7199 ] Appending platform config data of size :- 708
[ 0.7234 ] Parsing config file :tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg
[ 0.7236 ] Appending platform config data of size :- 64
[ 0.7237 ]
[ 0.7238 ] Parsing config file :tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 0.7239 ] Appending platform config data of size :- 1652
[ 0.7240 ]
[ 0.7243 ] Updating mb1-bct with firmware information
[ 0.7281 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 0.7386 ] MB1-BCT version: 0xe
[ 0.7471 ]
[ 0.7475 ] Updating mb1-bct with storage information
[ 0.7495 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 0.7506 ] MB1-BCT version: 0xe
[ 0.7571 ]
[ 0.7585 ] tegrahost_v2 --align mb1_cold_boot_bct_MB1.bct
[ 0.7732 ]
[ 0.7762 ] tegrahost_v2 --appendsigheader mb1_cold_boot_bct_MB1.bct zerosbk
[ 0.7850 ]
[ 0.7864 ] tegrasign_v2 --key None --list mb1_cold_boot_bct_MB1_sigheader.bct_list.xml
[ 0.7873 ] Assuming zero filled SBK key
[ 0.8035 ]
[ 0.8065 ] tegrahost_v2 --updatesigheader mb1_cold_boot_bct_MB1_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_sigheader.bct.hash zerosbk
[ 0.8163 ]
[ 0.8165 ] Generating recovery mb1-bct
[ 0.8176 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct.cfg --sdram P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --misc tegra186-mb1-bct-misc-si-l4t.cfg --scr minimal_scr.cfg --pinmux tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmc tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --pmic tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg --brcommand tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --prod tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 0.8187 ] MB1-BCT version: 0xe
[ 0.8197 ] Copying Sdram info from 2 to 3 set
[ 0.8498 ] Packing sdram param for instance[0]
[ 0.8575 ] Packing sdram param for instance[1]
[ 0.8578 ] Packing sdram param for instance[2]
[ 0.8580 ] Packing sdram param for instance[3]
[ 0.8584 ] Parsing config file :tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg
[ 0.8613 ] Appending platform config data of size :- 2904
[ 0.8618 ] Parsing config file :minimal_scr.cfg
[ 0.8620 ] Appending platform config data of size :- 12240
[ 0.8640 ] Parsing config file :tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg
[ 0.8672 ] Appending platform config data of size :- 24
[ 0.8697 ] Parsing config file :tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg
[ 0.8720 ] Appending platform config data of size :- 708
[ 0.8728 ] Parsing config file :tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg
[ 0.8741 ] Appending platform config data of size :- 64
[ 0.8750 ]
[ 0.8750 ] Parsing config file :tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 0.8751 ] Appending platform config data of size :- 1652
[ 0.8751 ]
[ 0.8752 ] Updating mb1-bct with firmware information
[ 0.8766 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 0.8778 ] MB1-BCT version: 0xe
[ 0.8974 ]
[ 0.8975 ] Updating mb1-bct with storage information
[ 0.8997 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 0.9026 ] MB1-BCT version: 0xe
[ 0.9286 ]
[ 0.9314 ] tegrahost_v2 --align mb1_bct_MB1.bct
[ 0.9411 ]
[ 0.9425 ] tegrahost_v2 --appendsigheader mb1_bct_MB1.bct zerosbk
[ 0.9555 ]
[ 0.9583 ] tegrasign_v2 --key None --list mb1_bct_MB1_sigheader.bct_list.xml
[ 0.9607 ] Assuming zero filled SBK key
[ 0.9689 ]
[ 0.9703 ] tegrahost_v2 --updatesigheader mb1_bct_MB1_sigheader.bct.encrypt mb1_bct_MB1_sigheader.bct.hash zerosbk
[ 0.9873 ]
[ 0.9876 ] Copying signatures
[ 0.9898 ] tegrahost_v2 --chip 0x18 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 1.0610 ]
[ 1.0623 ] tegrahost_v2 --align nvtboot_recovery.bin
[ 1.0686 ]
[ 1.0696 ] tegrahost_v2 --appendsigheader nvtboot_recovery.bin zerosbk
[ 1.0770 ]
[ 1.0784 ] tegrasign_v2 --key None --list nvtboot_recovery_sigheader.bin_list.xml
[ 1.0794 ] Assuming zero filled SBK key
[ 1.0971 ]
[ 1.0984 ] tegrahost_v2 --updatesigheader nvtboot_recovery_sigheader.bin.encrypt nvtboot_recovery_sigheader.bin.hash zerosbk
[ 1.1049 ]
[ 1.1091 ] tegrahost_v2 --align preboot_d15_prod_cr.bin
[ 1.1171 ]
[ 1.1188 ] tegrahost_v2 --appendsigheader preboot_d15_prod_cr.bin zerosbk
[ 1.1250 ]
[ 1.1262 ] tegrasign_v2 --key None --list preboot_d15_prod_cr_sigheader.bin_list.xml
[ 1.1272 ] Assuming zero filled SBK key
[ 1.1464 ]
[ 1.1494 ] tegrahost_v2 --updatesigheader preboot_d15_prod_cr_sigheader.bin.encrypt preboot_d15_prod_cr_sigheader.bin.hash zerosbk
[ 1.1572 ]
[ 1.1592 ] tegrahost_v2 --align mce_mts_d15_prod_cr.bin
[ 1.1761 ]
[ 1.1789 ] tegrahost_v2 --appendsigheader mce_mts_d15_prod_cr.bin zerosbk
[ 1.1926 ]
[ 1.2012 ] tegrasign_v2 --key None --list mce_mts_d15_prod_cr_sigheader.bin_list.xml
[ 1.2022 ] Assuming zero filled SBK key
[ 1.2804 ]
[ 1.2821 ] tegrahost_v2 --updatesigheader mce_mts_d15_prod_cr_sigheader.bin.encrypt mce_mts_d15_prod_cr_sigheader.bin.hash zerosbk
[ 1.2934 ]
[ 1.2954 ] tegrahost_v2 --align bpmp.bin
[ 1.3009 ]
[ 1.3018 ] tegrahost_v2 --appendsigheader bpmp.bin zerosbk
[ 1.3131 ]
[ 1.3193 ] tegrasign_v2 --key None --list bpmp_sigheader.bin_list.xml
[ 1.3224 ] Assuming zero filled SBK key
[ 1.3450 ]
[ 1.3468 ] tegrahost_v2 --updatesigheader bpmp_sigheader.bin.encrypt bpmp_sigheader.bin.hash zerosbk
[ 1.3611 ]
[ 1.3622 ] tegrahost_v2 --align tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb
[ 1.3694 ]
[ 1.3745 ] tegrahost_v2 --appendsigheader tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb zerosbk
[ 1.3810 ]
[ 1.3822 ] tegrasign_v2 --key None --list tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb_list.xml
[ 1.3832 ] Assuming zero filled SBK key
[ 1.4130 ]
[ 1.4145 ] tegrahost_v2 --updatesigheader tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.encrypt tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.hash zerosbk
[ 1.4291 ]
[ 1.4316 ] tegrahost_v2 --align tos.img
[ 1.4411 ]
[ 1.4423 ] tegrahost_v2 --appendsigheader tos.img zerosbk
[ 1.4530 ]
[ 1.4571 ] tegrasign_v2 --key None --list tos_sigheader.img_list.xml
[ 1.4580 ] Assuming zero filled SBK key
[ 1.4652 ]
[ 1.4672 ] tegrahost_v2 --updatesigheader tos_sigheader.img.encrypt tos_sigheader.img.hash zerosbk
[ 1.4721 ]
[ 1.4732 ] tegrahost_v2 --align eks.img
[ 1.4907 ]
[ 1.4929 ] tegrahost_v2 --appendsigheader eks.img zerosbk
[ 1.5004 ]
[ 1.5017 ] tegrasign_v2 --key None --list eks_sigheader.img_list.xml
[ 1.5027 ] Assuming zero filled SBK key
[ 1.5171 ]
[ 1.5189 ] tegrahost_v2 --updatesigheader eks_sigheader.img.encrypt eks_sigheader.img.hash zerosbk
[ 1.5251 ]
[ 1.5280 ] tegrahost_v2 --align tegra186-quill-p3310-1000-c03-00-base.dtb
[ 1.5370 ]
[ 1.5380 ] tegrahost_v2 --appendsigheader tegra186-quill-p3310-1000-c03-00-base.dtb zerosbk
[ 1.5552 ]
[ 1.5585 ] tegrasign_v2 --key None --list tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb_list.xml
[ 1.5621 ] Assuming zero filled SBK key
[ 1.5891 ]
[ 1.5916 ] tegrahost_v2 --updatesigheader tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.hash zerosbk
[ 1.6087 ]
[ 1.6102 ] tegrahost_v2 --align nvtboot_recovery_cpu.bin
[ 1.6174 ]
[ 1.6212 ] tegrahost_v2 --appendsigheader nvtboot_recovery_cpu.bin zerosbk
[ 1.6290 ]
[ 1.6303 ] tegrasign_v2 --key None --list nvtboot_recovery_cpu_sigheader.bin_list.xml
[ 1.6313 ] Assuming zero filled SBK key
[ 1.6527 ]
[ 1.6545 ] tegrahost_v2 --updatesigheader nvtboot_recovery_cpu_sigheader.bin.encrypt nvtboot_recovery_cpu_sigheader.bin.hash zerosbk
[ 1.6610 ]
[ 1.6612 ] Copying signed file in /home/ubuntu/work/jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/signed
[ 1.7536 ] Generating RCM messages
[ 1.7556 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 --download rcm mb1_recovery_prod.bin 0 0
[ 1.7579 ] RCM 0 is saved as rcm_0.rcm
[ 1.7605 ] RCM 1 is saved as rcm_1.rcm
[ 1.7667 ] List of rcm files are saved in rcm_list.xml
[ 1.7723 ]
[ 1.7724 ] Signing RCM messages
[ 1.7744 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 1.7766 ] Assuming zero filled SBK key
[ 1.8012 ]
[ 1.8015 ] Copying signature to RCM mesages
[ 1.8052 ] tegrarcm_v2 --chip 0x18 --updatesig rcm_list_signed.xml
[ 1.8130 ]
[ 1.8132 ] Boot Rom communication
[ 1.8142 ] tegrarcm_v2 --chip 0x18 --rcm rcm_list_signed.xml
[ 1.8153 ] BootRom is not running
[ 2.8245 ]
[ 2.8321 ] tegrarcm_v2 --isapplet
[ 2.8347 ] Applet version 01.00.0000
[ 2.8604 ]
[ 2.8618 ] tegrasign_v2 --key None --getmode mode.txt
[ 2.8629 ] Assuming zero filled SBK key
[ 2.8689 ]
[ 2.8700 ] Parsing partition layout
[ 2.8721 ] tegraparser_v2 --pt flash.xml.tmp
[ 2.8804 ]
[ 2.8807 ] Creating list of images to be signed
[ 2.8824 ] tegrahost_v2 --chip 0x18 --partitionlayout flash.xml.bin --list images_list.xml zerosbk
[ 2.9569 ]
[ 2.9572 ] Generating signatures
[ 2.9589 ] tegrasign_v2 --key None --list images_list.xml --pubkeyhash pub_key.key
[ 2.9600 ] Assuming zero filled SBK key
[ 3.4531 ]
[ 3.4532 ] Reading BCT from device for further operations
[ 3.4533 ] Generating blob
[ 3.4545 ] tegrahost_v2 --align blob_nvtboot_recovery_cpu.bin
[ 3.4611 ]
[ 3.4619 ] tegrahost_v2 --appendsigheader blob_nvtboot_recovery_cpu.bin zerosbk
[ 3.4691 ]
[ 3.4705 ] tegrasign_v2 --key None --list blob_nvtboot_recovery_cpu_sigheader.bin_list.xml
[ 3.4714 ] Assuming zero filled SBK key
[ 3.4950 ]
[ 3.4966 ] tegrahost_v2 --updatesigheader blob_nvtboot_recovery_cpu_sigheader.bin.encrypt blob_nvtboot_recovery_cpu_sigheader.bin.hash zerosbk
[ 3.5052 ]
[ 3.5066 ] tegrahost_v2 --align blob_nvtboot_recovery.bin
[ 3.5131 ]
[ 3.5140 ] tegrahost_v2 --appendsigheader blob_nvtboot_recovery.bin zerosbk
[ 3.5205 ]
[ 3.5216 ] tegrasign_v2 --key None --list blob_nvtboot_recovery_sigheader.bin_list.xml
[ 3.5226 ] Assuming zero filled SBK key
[ 3.5406 ]
[ 3.5435 ] tegrahost_v2 --updatesigheader blob_nvtboot_recovery_sigheader.bin.encrypt blob_nvtboot_recovery_sigheader.bin.hash zerosbk
[ 3.5491 ]
[ 3.5504 ] tegrahost_v2 --align blob_preboot_d15_prod_cr.bin
[ 3.5621 ]
[ 3.5634 ] tegrahost_v2 --appendsigheader blob_preboot_d15_prod_cr.bin zerosbk
[ 3.5727 ]
[ 3.5780 ] tegrasign_v2 --key None --list blob_preboot_d15_prod_cr_sigheader.bin_list.xml
[ 3.5791 ] Assuming zero filled SBK key
[ 3.5926 ]
[ 3.5942 ] tegrahost_v2 --updatesigheader blob_preboot_d15_prod_cr_sigheader.bin.encrypt blob_preboot_d15_prod_cr_sigheader.bin.hash zerosbk
[ 3.6017 ]
[ 3.6063 ] tegrahost_v2 --align blob_mce_mts_d15_prod_cr.bin
[ 3.6131 ]
[ 3.6142 ] tegrahost_v2 --appendsigheader blob_mce_mts_d15_prod_cr.bin zerosbk
[ 3.6366 ]
[ 3.6382 ] tegrasign_v2 --key None --list blob_mce_mts_d15_prod_cr_sigheader.bin_list.xml
[ 3.6392 ] Assuming zero filled SBK key
[ 3.7171 ]
[ 3.7187 ] tegrahost_v2 --updatesigheader blob_mce_mts_d15_prod_cr_sigheader.bin.encrypt blob_mce_mts_d15_prod_cr_sigheader.bin.hash zerosbk
[ 3.7308 ]
[ 3.7331 ] tegrahost_v2 --align blob_bpmp.bin
[ 3.7413 ]
[ 3.7425 ] tegrahost_v2 --appendsigheader blob_bpmp.bin zerosbk
[ 3.7569 ]
[ 3.7595 ] tegrasign_v2 --key None --list blob_bpmp_sigheader.bin_list.xml
[ 3.7617 ] Assuming zero filled SBK key
[ 3.7851 ]
[ 3.7866 ] tegrahost_v2 --updatesigheader blob_bpmp_sigheader.bin.encrypt blob_bpmp_sigheader.bin.hash zerosbk
[ 3.8033 ]
[ 3.8072 ] tegrahost_v2 --align blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb
[ 3.8171 ]
[ 3.8183 ] tegrahost_v2 --appendsigheader blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb zerosbk
[ 3.8347 ]
[ 3.8369 ] tegrasign_v2 --key None --list blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb_list.xml
[ 3.8380 ] Assuming zero filled SBK key
[ 3.8697 ]
[ 3.8736 ] tegrahost_v2 --updatesigheader blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.encrypt blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.hash zerosbk
[ 3.8811 ]
[ 3.8823 ] tegrahost_v2 --align blob_tos.img
[ 3.8991 ]
[ 3.9017 ] tegrahost_v2 --appendsigheader blob_tos.img zerosbk
[ 3.9123 ]
[ 3.9197 ] tegrasign_v2 --key None --list blob_tos_sigheader.img_list.xml
[ 3.9257 ] Assuming zero filled SBK key
[ 3.9344 ]
[ 3.9378 ] tegrahost_v2 --updatesigheader blob_tos_sigheader.img.encrypt blob_tos_sigheader.img.hash zerosbk
[ 3.9532 ]
[ 3.9546 ] tegrahost_v2 --align blob_eks.img
[ 3.9660 ]
[ 3.9678 ] tegrahost_v2 --appendsigheader blob_eks.img zerosbk
[ 3.9731 ]
[ 3.9744 ] tegrasign_v2 --key None --list blob_eks_sigheader.img_list.xml
[ 3.9845 ] Assuming zero filled SBK key
[ 3.9938 ]
[ 3.9983 ] tegrahost_v2 --updatesigheader blob_eks_sigheader.img.encrypt blob_eks_sigheader.img.hash zerosbk
[ 4.0051 ]
[ 4.0146 ] tegrahost_v2 --align blob_tegra186-quill-p3310-1000-c03-00-base.dtb
[ 4.0219 ]
[ 4.0232 ] tegrahost_v2 --appendsigheader blob_tegra186-quill-p3310-1000-c03-00-base.dtb zerosbk
[ 4.0331 ]
[ 4.0346 ] tegrasign_v2 --key None --list blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb_list.xml
[ 4.0356 ] Assuming zero filled SBK key
[ 4.0611 ]
[ 4.0628 ] tegrahost_v2 --updatesigheader blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.hash zerosbk
[ 4.0809 ]
[ 4.0831 ] tegrahost_v2 --generateblob blob.xml blob.bin
[ 4.0847 ] number of images in blob are 9
[ 4.0879 ] blobsize is 3748120
[ 4.0889 ] Added binary blob_nvtboot_recovery_cpu_sigheader.bin.encrypt of size 190048
[ 4.1044 ] Added binary blob_nvtboot_recovery_sigheader.bin.encrypt of size 79600
[ 4.1054 ] Added binary blob_preboot_d15_prod_cr_sigheader.bin.encrypt of size 63024
[ 4.1064 ] Added binary blob_mce_mts_d15_prod_cr_sigheader.bin.encrypt of size 2076832
[ 4.1180 ] Added binary blob_bpmp_sigheader.bin.encrypt of size 529440
[ 4.1214 ] Added binary blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.encrypt of size 466160
[ 4.1247 ] Added binary blob_tos_sigheader.img.encrypt of size 62976
[ 4.1269 ] Added binary blob_eks_sigheader.img.encrypt of size 1488
[ 4.1272 ] Added binary blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt of size 278400
[ 4.1494 ]
[ 4.1504 ] Sending bootloader and pre-requisite binaries
[ 4.1518 ] tegrarcm_v2 --download blob blob.bin
[ 4.1528 ] Applet version 01.00.0000
[ 4.1622 ] Sending blob
[ 4.1623 ] [................................................] 100%
[ 5.0974 ]
[ 5.0993 ] tegrarcm_v2 --boot recovery
[ 5.1007 ] Applet version 01.00.0000
[ 5.1292 ]
[ 5.1303 ] tegrarcm_v2 --isapplet
[ 5.7844 ]
[ 5.7883 ] tegradevflash_v2 --iscpubl
[ 5.7912 ] CPU Bootloader is not running on device.
[ 5.8045 ]
[ 7.8649 ] Writing partition
[ 7.8692 ] tegradevflash_v2 --write kernel-dtb /home/ubuntu/work/jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/signed/tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt
[ 7.8731 ] Bootloader version 01.00.0000
[ 7.9035 ] Writing partition kernel-dtb with /home/ubuntu/work/jetpack3.2.1/64_TX2/Linux_for_Tegra/bootloader/signed/tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt
[ 7.9049 ] [................................................] 100%
[ 7.9524 ]
[ 7.9524 ] Coldbooting the device
[ 7.9536 ] tegradevflash_v2 --reboot coldboot
[ 7.9545 ] Bootloader version 01.00.0000
[ 7.9845 ]
*** The [kernel-dtb] has been updated successfully. ***
6.Check the lane owner information, we found it's not changed
/dev/mem opened.
Memory mapped at address 0x7fa133c000.
Value at address 0x2520284 (0x7fa133c284): 0x0
/dev/mem opened.
Memory mapped at address 0x7fb7309000.
Value at address 0x2530284 (0x7fb7309284): 0x0
/dev/mem opened.
Memory mapped at address 0x7f85c6a000.
Value at address 0x2540284 (0x7f85c6a284): 0x0
/dev/mem opened.
Memory mapped at address 0x7fa5834000.
Value at address 0x2550284 (0x7fa5834284): 0x1
/dev/mem opened.
Memory mapped at address 0x7fa7351000.
Value at address 0x2560284 (0x7fa7351284): 0x1
/dev/mem opened.
Memory mapped at address 0x7f87d4d000.
Value at address 0x2570284 (0x7f87d4d284): 0x2
7.We use dtc -I fs -O dts -o extracted.dts /proc/device-tree to check the device tree,and it's already changed.
xhci@3530000 {
reg = <0x0 0x3530000 0x0 0x8000 0x0 0x3538000 0x0 0x1000>;
phys = <0x94 0x10 0x94 0x11 0x94 0x12 0x94 0x1 0x94 0x2>;
interrupts = <0x0 0xa3 0x4 0x0 0xa7 0x4>;
avddio_usb-supply = <0xf>;
otg-controller = <0x97>;
compatible = "nvidia,tegra186-xhci";
clock-names = "host", "falcon_src", "ss", "ss_src", "hs_src", "fs_src", "pll_u_480M", "clk_m", "pll_e";
nvidia,boost_cpu_freq = <0x320>;
phy-names = "utmi-0", "utmi-1", "utmi-2", "usb3-1", "usb3-2";
clocks = <0xd 0x71 0xd 0xf4 0xd 0x72 0xd 0xf2 0xd 0x27c 0xd 0xf5 0xd 0x215 0xd 0x261 0xd 0x200>;
mboxes = <0x96>;
status = "okay";
phandle = <0x70>;
avdd_pll_utmip-supply = <0xe>;
#stream-id-cells = <0x1>;
hvdd_usb-supply = <0xe>;
mbox-names = "xusb";
linux,phandle = <0x70>;
interrupt-parent = <0x2b>;
pinmux {
phandle = <0x9b>;
linux,phandle = <0x9b>;
usb2-std-A-port2 {
nvidia,function = "xusb";
nvidia,lanes = "otg-1";
nvidia,port-cap = <0x1>;
nvidia,oc-pin = <0x1>;
usb3-std-A-port2 {
nvidia,lanes = "usb3-1";
status = "okay";
usb3-std-A-port3 {
nvidia,lanes = "usb3-2";
status = "okay";
e3325-usb3-std-A-HS {
nvidia,lanes = "otg-2";
status = "okay";
e3325-usb3-std-A-SS {
nvidia,lanes = "usb3-0";
status = "disabled";
usb2-micro-AB {
nvidia,lanes = "otg-0";
nvidia,port-cap = <0x3>;
nvidia,oc-pin = <0x0>;
8.We use command: ./flash.sh -r jetson-tx2 mmcblk0p1,found that everythig is ok.
nvidia@tegra-ubuntu:~/work$ sudo ./show_usb_phy.sh
/dev/mem opened.
Memory mapped at address 0x7f93944000.
Value at address 0x2520284 (0x7f93944284): 0x1
/dev/mem opened.
Memory mapped at address 0x7fa5930000.
Value at address 0x2530284 (0x7fa5930284): 0x0
/dev/mem opened.
Memory mapped at address 0x7f85ec1000.
Value at address 0x2540284 (0x7f85ec1284): 0x0
/dev/mem opened.
Memory mapped at address 0x7f7dca3000.
Value at address 0x2550284 (0x7f7dca3284): 0x1
/dev/mem opened.
Memory mapped at address 0x7fadd41000.
Value at address 0x2560284 (0x7fadd41284): 0x1
/dev/mem opened.
Memory mapped at address 0x7fa9092000.
Value at address 0x2570284 (0x7fa9092284): 0x2
Questions:
1.Do we need to flash the whole filesystem to change the usb lane mapping ?
2.The ./flash.sh -r jetson-tx2 mmcblk0p1 command consume too much time,is there any other ways to change the usb lane mapping?
