hi all and linuxdev
I tried to run your command
sudo tail -f /var/log/Xorg.0.log
what I got is the following
I ran a dmesg command from ssh.
this is the result… anyone can help
[code]ubuntu@tegra-ubuntu:~$ dmesg
[ 0.046345] Tegra Revision: A02p SKU: 0xdc CPU Process: 0 SoC Process: 0
[ 0.046985] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.4/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.047005] DTB Build time: Jul 20 2017 00:50:45
[ 0.062598] CPU1: Booted secondary processor [4e0f0030]
[ 0.074092] CPU2: Booted secondary processor [4e0f0030]
[ 0.085803] CPU3: Booted secondary processor [411fd073]
[ 0.097816] CPU4: Booted secondary processor [411fd073]
[ 0.109818] CPU5: Booted secondary processor [411fd073]
[ 0.109879] Brought up 6 CPUs
[ 0.109930] SMP: Total of 6 processors activated.
[ 0.109941] CPU: All CPU(s) started at EL2
[ 0.110360] devtmpfs: initialized
[ 0.137087] Initilizing CustomIPI irq domain
[ 0.137292] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.138186] pinctrl core: initialized pinctrl subsystem
[ 0.138360] OS set in device tree is L4T.
[ 0.138560] regulator-dummy: no parameters
[ 0.138664] Initializing plugin-manager
[ 0.138716] Plugin module not found
[ 0.139134] node /plugin-manager/soc-prod-a02-fragment match with chip-id A02P
[ 0.139480] node /plugin-manager/fragement@0 match with odm-data enable-denver-wdt
[ 0.140104] node /plugin-manager/fragement@4 match with odm-data enable-denver-wdt
[ 0.141292] node /plugin-manager/fragment-sdwake-p3310-1000-300 match with board >=3310-1000-300
[ 0.141676] node /plugin-manager/fragement-pmon-p3310-1000-300 match with board >=3310-1000-300
[ 0.141938] node /plugin-manager/fragement-pmon-p3310-1000-800 match with board >=3310-1000-800
[ 0.142165] node /plugin-manager/fragment-devslp@0 match with board >=3310-1000-200
[ 0.142585] node /plugin-manager/fragment-500-pcie-config match with board >=3310-1000-500
[ 0.143017] node /plugin-manager/fragment-500-xusb-config match with board >=3310-1000-500
[ 0.143293] node /plugin-manager/fragment-500-e3325-pcie match with board >=3310-1000-500
[ 0.143667] node /plugin-manager/fragment-p3310-c00-comm match with board >=3310-1000-800
[ 0.143913] node /plugin-manager/fragment-p3310-c00-pmic match with board >=3310-1000-800
[ 0.144130] node /plugin-manager/fragment-p3310-c01 match with board >=3310-1000-900
[ 0.144382] node /plugin-manager/fragment-p3310-c03 match with board >=3310-1000-B00
[ 0.145940] node /plugin-manager/fragment-e3326@0 match with board 3326-*
[ 0.147025] node /plugin-manager/fragment-p3310-c00-camera match with board >=3310-1000-800
[ 0.148801] Adding domain adsp-pd to PM domain ape-pd
[ 0.151186] NET: Registered protocol family 16
[ 0.151861] console [pstore-1] enabled
[ 0.151872] pstore: Registered ramoops as persistent store backend
[ 0.151885] ramoops: attached 0x200000@0x96080000, ecc: 0/0
[ 0.161361] cpuidle: using governor ladder
[ 0.165803] cpuidle: using governor menu
[ 0.166963] bpmp: waiting for handshake
[ 0.166976] bpmp: handshake completed
[ 0.167016] bpmp: synchronizing channels
[ 0.167046] bpmp: channels synchronized
[ 0.167056] bpmp: mail init ok
[ 0.167376] vdso: 2 pages (1 code @ ffffffc001219000, 1 data @ ffffffc001218000)
[ 0.167406] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.168328] atomic_pool_init():526: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.169792] tegra_powergate_init: DONE
[ 0.169820] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.4/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.169844] DTB Build time: Jul 20 2017 00:50:45
[ 0.170741] Tegra reboot handler registered.
[ 0.171804] Registering Tegra186 clocks (this may take a while)…done
[ 0.173947] arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.173963] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.173975] arm-smmu 12000000.iommu: stage 1 translation
[ 0.173987] arm-smmu 12000000.iommu: stage 2 translation
[ 0.173997] arm-smmu 12000000.iommu: nested translation
[ 0.174009] arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.174027] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.174044] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.174057] arm-smmu 12000000.iommu: Stage-1: 39-bit VA → 48-bit IPA
[ 0.174069] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA → 48-bit PA
[ 0.222230] arm-smmu 12000000.iommu: registered 67 master devices
[ 0.227654] iommu: Adding device 3460000.sdhci to group 0
[ 0.228501] iommu: Adding device 3400000.sdhci to group 1
[ 0.231920] iommu: Adding device 3507000.ahci-sata to group 2
[ 0.232395] iommu: Adding device 3160000.i2c to group 3
[ 0.232786] iommu: Adding device c240000.i2c to group 4
[ 0.233464] iommu: Adding device 3180000.i2c to group 5
[ 0.233807] iommu: Adding device 3190000.i2c to group 6
[ 0.234243] iommu: Adding device 31b0000.i2c to group 7
[ 0.234573] iommu: Adding device 31c0000.i2c to group 8
[ 0.234890] iommu: Adding device c250000.i2c to group 9
[ 0.235223] iommu: Adding device 31e0000.i2c to group 10
[ 0.237172] iommu: Adding device 3210000.spi to group 11
[ 0.237489] iommu: Adding device c260000.spi to group 12
[ 0.237821] iommu: Adding device 3240000.spi to group 13
[ 0.238548] iommu: Adding device 3100000.serial to group 14
[ 0.238900] iommu: Adding device 3110000.serial to group 15
[ 0.239190] iommu: Adding device c280000.serial to group 16
[ 0.239532] iommu: Adding device 3130000.serial to group 17
[ 0.240753] iommu: Adding device 2490000.ether_qos to group 18
[ 0.241330] iommu: Adding device b000000.rtcpu to group 19
[ 0.241757] iommu: Adding device c1a0000.aon to group 20
[ 0.242584] Wake73 for irq=42
[ 0.242921] iommu: Adding device smmu_test to group 21
[ 0.243398] mc: mapped MMIO address: 0xffffff8000560000 → 0x2c10000
[ 0.243435] mc: mapped MMIO address: 0xffffff8000640000 → 0x2c20000
[ 0.243487] mc: mapped MMIO address: 0xffffff8000660000 → 0x2c30000
[ 0.243520] mc: mapped MMIO address: 0xffffff8000fa0000 → 0x2c40000
[ 0.243551] mc: mapped MMIO address: 0xffffff8000fc0000 → 0x2c50000
[ 0.243583] mc-err: Set intmask: 0xf3140
[ 0.243846] dram-ecc: DRAM ECC disabled-MC_ECC_CONTROL:0x0000000c
[ 0.244617] Wake76 for irq=199
[ 0.244638] Wake77 for irq=199
[ 0.244665] Wake78 for irq=199
[ 0.244702] Wake79 for irq=199
[ 0.244718] Wake80 for irq=199
[ 0.244734] Wake81 for irq=199
[ 0.244750] Wake82 for irq=199
[ 0.244902] iommu: Adding device 3530000.xhci to group 22
[ 0.245245] iommu: Adding device 3550000.xudc to group 23
[ 0.246049] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.246076] tegra-pmc: ### PMC reset source: Power on reset
[ 0.246097] tegra-pmc: ### PMC reset level: L0
[ 0.246116] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.246404] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.246441] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.246633] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.246660] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 320
[ 0.247146] iommu: Adding device 13e10000.host1x to group 24
[ 0.247387] iommu: Adding device 13e10000.host1x:ctx0 to group 25
[ 0.247596] iommu: Adding device 13e10000.host1x:ctx1 to group 26
[ 0.247859] iommu: Adding device 13e10000.host1x:ctx2 to group 27
[ 0.248093] iommu: Adding device 13e10000.host1x:ctx3 to group 28
[ 0.248296] iommu: Adding device 13e10000.host1x:ctx4 to group 29
[ 0.248522] iommu: Adding device 13e10000.host1x:ctx5 to group 30
[ 0.248736] iommu: Adding device 13e10000.host1x:ctx6 to group 31
[ 0.248943] iommu: Adding device 13e10000.host1x:ctx7 to group 32
[ 0.249404] iommu: Adding device 150c0000.nvcsi to group 33
[ 0.249897] iommu: Adding device 15700000.vi to group 34
[ 0.250291] iommu: Adding device 15600000.isp to group 35
[ 0.250656] iommu: Adding device 15210000.nvdisplay to group 36
[ 0.250855] iommu: Adding device 15340000.vic to group 37
[ 0.251062] iommu: Adding device 154c0000.nvenc to group 38
[ 0.251287] iommu: Adding device 15480000.nvdec to group 39
[ 0.251586] iommu: Adding device 15380000.nvjpg to group 40
[ 0.251818] iommu: Adding device 15500000.tsec to group 41
[ 0.252001] iommu: Adding device 15100000.tsecb to group 42
[ 0.252653] iommu: Adding device 15810000.se to group 43
[ 0.252871] iommu: Adding device 15820000.se to group 44
[ 0.253065] iommu: Adding device 15830000.se to group 45
[ 0.253273] iommu: Adding device 15840000.se to group 46
[ 0.253737] iommu: Adding device 17000000.gp10b to group 47
[ 0.255102] tegra-reset 5000000.clock: registered 193 resets.
[ 0.257046] iommu: Adding device d000000.bpmp to group 48
[ 0.257291] bpmp: ping status is 0
[ 0.257465] bpmp d000000.bpmp: firmware tag is 0705d30e2bb4ef1fcf63b70c5fc3deef
[ 0.257869] bpmp d000000.bpmp: probe ok
[ 0.260914] iommu: Adding device 2600000.dma to group 49
[ 0.261774] GPIO line 461 (cam0-rst) hogged as output/low
[ 0.261826] GPIO line 456 (cam0-pwdn) hogged as output/low
[ 0.261875] GPIO line 457 (cam1-rst) hogged as output/low
[ 0.261937] GPIO line 426 (cam1-pwdn) hogged as output/low
[ 0.261985] GPIO line 424 (wifi-enable) hogged as output/high
[ 0.262031] GPIO line 445 (sdmmc-wake-input) hogged as input
[ 0.262076] GPIO line 446 (sdmmc-wake-output) hogged as output/low
[ 0.262182] gpiochip_add_data: registered GPIOs 320 to 511 on device: tegra-gpio
[ 0.264188] GPIO line 315 (wifi-wake-ap) hogged as input
[ 0.264286] gpiochip_add_data: registered GPIOs 256 to 319 on device: tegra-gpio-aon
[ 0.265229] iommu: Adding device 10003000.pcie-controller to group 50
[ 0.265525] iommu: Adding device sound to group 51
[ 0.267269] iommu: Adding device 3510000.hda to group 52
[ 0.268398] iommu: Adding device adsp_audio to group 53
[ 0.269773] iommu: Adding device 2993000.adsp to group 54
[ 0.279109] vdd-ac-bat: 5000 mV
[ 0.281247] vdd-1v8-ap: 1800 mV
[ 0.282403] gpio tegra-gpio-aon wake30 for gpio=60(FF:4)
[ 0.282771] gpio tegra-gpio-aon wake69 for gpio=59(FF:3)
[ 0.300634] SCSI subsystem initialized
[ 0.300833] libata version 3.00 loaded.
[ 0.301004] usbcore: registered new interface driver usbfs
[ 0.301065] usbcore: registered new interface driver hub
[ 0.301178] usbcore: registered new device driver usb
[ 0.305153] GPIO line 241 (touch-rail-1) hogged as output/high
[ 0.305593] GPIO line 242 (touch-rail-2) hogged as output/high
[ 0.305697] gpiochip_add_data: registered GPIOs 240 to 255 on device: tca9539
[ 0.307085] GPIO line 228 (lcd-bias-en-rail) hogged as output/high
[ 0.307187] gpiochip_add_data: registered GPIOs 224 to 239 on device: tca9539
[ 0.319475] media: Linux media interface: v0.10
[ 0.319548] Linux video capture interface: v2.00
[ 0.323507] pps_core: LinuxPPS API ver. 1 registered
[ 0.323539] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.323585] PTP clock support registered
[ 0.324497] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.324539] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.326040] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[ 0.327994] GPIO line 221 (spmic_gpio_input_5) hogged as input
[ 0.328203] GPIO line 222 (spmic_gpio_input_6) hogged as input
[ 0.328333] gpiochip_add_data: registered GPIOs 216 to 223 on device: max77620-gpio
[ 0.334779] vddio-ddr: at 1125 mV
[ 0.338613] avdd_dsi_csi: 1200 mV
[ 0.342614] vdd-1v8: 1800 mV
[ 0.346613] vdd-3v3-sys: 3300 mV
[ 0.347733] spmic-ldo0: at 1800 mV
[ 0.348531] spmic-ldo1: at 800 mV
[ 0.354612] vddio-3v3: 3300 mV
[ 0.355224] vddio-sdmmc1: 1800 <–> 3300 mV at 3300 mV
[ 0.357359] vdd-rtc: at 800 mV
[ 0.358047] avdd-ts-hv: 1800 <–> 3300 mV at 1800 mV
[ 0.361357] spmic-ldo6: at 1500 mV
[ 0.365356] vdd-pex-1v05: 1000 mV
[ 0.365898] dvdd-pex: 1000 mV
[ 0.366173] max77620 4-003c: max77620 probe successful
[ 0.366427] Advanced Linux Sound Architecture Driver Initialized.
[ 0.367418] en-vdd-sd: 3300 mV
[ 0.368048] en-vdd-cam: 1800 mV
[ 0.369806] vdd-hdmi: 5000 mV
[ 0.369994] vdd-usb0-5v: 5000 mV
[ 0.370167] vdd-usb1-5v: 5000 mV
[ 0.373807] en-vdd-ts-1v8: 1800 mV
[ 0.377806] en-vdd-ts-hv-3v3: 3300 mV
[ 0.378321] en-vdd-disp-3v3: 3300 mV
[ 0.378826] en-mdm-pwr-3v7: 3700 mV
[ 0.379346] en-vdd-disp-1v8: 1800 mV
[ 0.379864] en-vdd-cam-hv-2v8: 2800 mV
[ 0.380383] en-vdd-cam-1v2: 1200 mV
[ 0.380899] vdd-fan: 5000 mV
[ 0.381009] vdd-3v3: 3300 mV
[ 0.381737] dis-vdd-1v2: 1200 mV
[ 0.381866] en-vdd-vcm-2v8: 2800 mV
[ 0.382385] vdd-usb2-5v: 5000 mV
[ 0.382491] vdd-sys-bl: 3300 mV
[ 0.383013] en-vdd-sys: 1200 mV
[ 0.384714] gpio tegra-gpio wake53 for gpio=159(X:7)
[ 0.386388] extcon-gpio-states external-connection:extcon@1: Cable state 0
[ 0.386745] clocksource: Switched to clocksource arch_sys_counter
[ 0.406080] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.406396] nvmap: nvmap_override_cache_ops() set roc flush ops to replace cache ops by set/ways
[ 0.406896] nvmap_page_pool_init: Total RAM pages: 2009466
[ 0.406913] nvmap_page_pool_init: nvmap page pool size: 251183 pages (981 MB)
[ 0.407059] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.411623] Wake76 for irq=199
[ 0.411635] Wake77 for irq=199
[ 0.411645] Wake78 for irq=199
[ 0.411655] Wake79 for irq=199
[ 0.411664] Wake80 for irq=199
[ 0.411673] Wake81 for irq=199
[ 0.411681] Wake82 for irq=199
[ 0.412433] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[ 0.412633] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 0.412751] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.412826] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.413219] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type AO-therm
[ 0.413364] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tboard_tegra
[ 0.413507] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tdiode_tegra
[ 0.413656] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type PMIC-Die
[ 0.413951] isomgr_init(): iso emc max clk=1866000KHz
[ 0.413963] isomgr_init(): max_iso_bw=26870400KB
[ 0.414043] NET: Registered protocol family 2
[ 0.414350] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.414574] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.414898] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.414956] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.415008] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.415164] NET: Registered protocol family 1
[ 0.415338] RPC: Registered named UNIX socket transport module.
[ 0.415351] RPC: Registered udp transport module.
[ 0.415362] RPC: Registered tcp transport module.
[ 0.415372] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.415390] PCI: CLS 0 bytes, default 128
[ 0.415485] Trying to unpack rootfs image as initramfs…
[ 0.429437] host1x 13e10000.host1x: initialized
[ 0.430245] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.432373] futex hash table entries: 2048 (order: 6, 262144 bytes)
[ 0.432466] audit: initializing netlink subsys (disabled)
[ 0.432495] audit: type=2000 audit(0.420:1): initialized
[ 0.438933] io scheduler noop registered (default)
[ 0.441876] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 0.443063] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 0.444135] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 0.445200] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 0.448735] tsec 15500000.tsec: initialized
[ 0.449868] tsec 15100000.tsecb: initialized
[ 0.452217] nvdec 15480000.nvdec: initialized
[ 0.455864] falcon 15340000.vic: initialized
[ 0.456867] falcon 154c0000.nvenc: initialized
[ 0.457845] falcon 15380000.nvjpg: initialized
[ 0.458640] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 0.459154] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 0.459658] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 0.460157] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 0.460661] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 0.461158] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 0.461653] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 0.462144] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 0.464801] DC OR NODE connected to /host1x/sor1
[ 0.464949] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.465014] tegradc 15210000.nvdisplay: DT parsed successfully
[ 0.465045] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 0.465058] tegradc 15210000.nvdisplay: Display dc.ffffff8002320000 registered with id=0
[ 0.465076] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=1500000, max_bw=4687500
[ 0.472403] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 16727000 KB/s
[ 0.472422] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 665600000 Hz
[ 0.472438] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 357620000 Hz
[ 0.472482] tegradc 15210000.nvdisplay: vblank syncpt # 7 for dc 1
[ 0.472497] tegradc 15210000.nvdisplay: vpulse3 syncpt # 8 for dc 1
[ 0.472622] tegra-adma 2930000.adma: Tegra ADMA driver register 10 channels
[ 0.474905] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 0.475099] tegradc 15210000.nvdisplay: hdmi: no prod_list_hdmi_board, use default range
[ 0.475119] PD DISP0 index2 UP
[ 0.476004] PD DISP1 index3 UP
[ 0.476018] kfuse 3830000.kfuse: initialized
[ 0.476161] PD DISP2 index4 UP
[ 0.477279] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.477685] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.479567] console [ttyS0] disabled
[ 0.479611] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 37, base_baud = 25500000) is a Tegra
[ 0.502424] Unsupported HDMI VIC 15, ignoring
[ 0.502425] Unsupported HDMI VIC 29, ignoring
[ 0.502427] Unsupported HDMI VIC 114, ignoring
[ 0.502428] Unsupported HDMI VIC 81, ignoring
[ 0.502436] PD DISP2 index4 DOWN
[ 0.502603] PD DISP1 index3 DOWN
[ 0.502754] PD DISP0 index2 DOWN
[ 0.504708] tegradc 15210000.nvdisplay: probed
[ 2.583602] console [ttyS0] enabled
[ 2.585636] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 38, base_baud = 0) is a TEGRA_UART
[ 2.586724] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 39, base_baud = 0) is a TEGRA_UART
[ 2.587003] serial-tegra 3130000.serial: RX in PIO mode
[ 2.587903] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 40, base_baud = 0) is a TEGRA_UART
[ 2.588871] Console: switching to colour frame buffer device 128x48
[ 2.598356] brd: module loaded
[ 2.602645] loop: module loaded
[ 2.602900] gpio tegra-gpio-aon wake35 for gpio=16(V:0)
[ 2.602921] nct1008_nct72 7-004c: find device tree node, parsing dt
[ 2.602924] nct1008_nct72 7-004c: starting parse dt
[ 2.603012] nct1008_nct72 7-004c: success parsing dt
[ 2.603149] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ 2.615751] gk20a 17000000.gp10b: failed to allocate secure buffer -12
[ 2.639821] tmp451: Enabled overheat logging at 104.00C
[ 2.639941] gpio tegra-gpio-aon wake35 for gpio=16(V:0)
[ 2.639984] nct1008_nct72 7-004c: nct1008_probe: initialized
[ 2.642438] THERMAL EST: found 3 subdevs
[ 2.642442] THERMAL EST num_resources: 0
[ 2.642446] [THERMAL EST subdev 0]
[ 2.642456] [THERMAL EST subdev 1]
[ 2.642460] [THERMAL EST subdev 2]
[ 2.642847] thermal thermal_zone8: Registering thermal zone thermal_zone8 for type thermal-fan-est
[ 2.642849] THERMAL EST: thz register success.
[ 2.642981] THERMAL EST: end of probe, return err: 0
[ 2.643220] tegra_profiler: Branch: Dev
[ 2.643222] tegra_profiler: Version: 1.109
[ 2.643224] tegra_profiler: Samples version: 37
[ 2.643226] tegra_profiler: IO version: 21
[ 2.643233] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.643238] armv8_pmu: [0] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.643241] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.643245] armv8_pmu: [1] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2
[ 2.643248] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.643251] armv8_pmu: [2] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2
[ 2.643254] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.643257] armv8_pmu: [3] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.643261] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.643264] armv8_pmu: [4] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.643267] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.643270] armv8_pmu: [5] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.643417] tegra_profiler: auth: init
[ 2.646968] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 2.646979] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 2.648016] scsi host0: tegra_ahci
[ 2.648408] scsi host1: tegra_ahci
[ 2.648551] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 25
[ 2.648554] ata2: DUMMY
[ 2.649468] spi-tegra114 3210000.spi: Static pin configuration used
[ 2.649920] spi-tegra114 c260000.spi: Static pin configuration used
[ 2.650345] spi-tegra114 3240000.spi: Static pin configuration used
[ 2.651185] tun: Universal TUN/TAP device driver, 1.6
[ 2.651187] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 2.651410] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 2.651413] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.651451] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.3.0-k
[ 2.651453] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.652541] PPP generic driver version 2.4.2
[ 2.652660] PPP BSD Compression module registered
[ 2.652667] PPP Deflate Compression module registered
[ 2.652686] PPP MPPE Compression module registered
[ 2.652698] NET: Registered protocol family 24
[ 2.652809] usbcore: registered new interface driver r8152
[ 2.652843] usbcore: registered new interface driver asix
[ 2.652869] usbcore: registered new interface driver ax88179_178a
[ 2.652894] usbcore: registered new interface driver cdc_ether
[ 2.652932] usbcore: registered new interface driver smsc95xx
[ 2.652962] usbcore: registered new interface driver net1080
[ 2.652988] usbcore: registered new interface driver cdc_subset
[ 2.653015] usbcore: registered new interface driver zaurus
[ 2.653059] usbcore: registered new interface driver cdc_ncm
[ 2.653366] Wake76 for irq=199
[ 2.653369] Wake77 for irq=199
[ 2.653371] Wake78 for irq=199
[ 2.653373] Wake79 for irq=199
[ 2.653375] Wake80 for irq=199
[ 2.653377] Wake81 for irq=199
[ 2.653379] Wake82 for irq=199
[ 2.653437] tegra-xotg xotg: usb2 phy is not available yet
[ 2.654195] usbcore: registered new interface driver usb-storage
[ 2.654273] usbcore: registered new interface driver usbserial
[ 2.654312] usbcore: registered new interface driver ftdi_sio
[ 2.654339] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 2.654378] usbcore: registered new interface driver option
[ 2.654402] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.654440] usbcore: registered new interface driver pl2303
[ 2.654464] usbserial: USB Serial support registered for pl2303
[ 2.654675] tegra-usb-cd usb_cd: otg phy is not available yet
[ 2.655657] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b 8c 47 5b
[ 2.656193] libphy: dwc_phy: probed
[ 2.657063] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 2.719786] gpio tegra-gpio wake18 for gpio=101(M:5)
[ 2.719938] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 2.784082] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 2.786245] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 2.786259] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 2.786397] i2c /dev entries driver
[ 2.787143] [OV5693]: probing v4l2 sensor.
[ 2.966781] ata1: SATA link down (SStatus 0 SControl 300)
[ 3.221183] tegradc 15210000.nvdisplay: fb registered
[ 3.227364] gpio tegra-gpio wake21 for gpio=121(P:1)
[ 3.233273] PD DISP0 index2 UP
[ 3.238214] PD DISP1 index3 UP
[ 3.242352] PD DISP2 index4 UP
[ 3.255194] Parent Clock set for DC plld2
[ 3.264331] tegradc 15210000.nvdisplay: hdmi: pclk:64995K, set prod-setting:prod_c_75M
[ 3.412731] Unsupported HDMI VIC 15, ignoring
[ 3.418019] Unsupported HDMI VIC 29, ignoring
[ 3.423306] Unsupported HDMI VIC 114, ignoring
[ 3.428651] Unsupported HDMI VIC 81, ignoring
[ 3.589187] gspca_main: v2.14.0 registered
[ 3.589234] usbcore: registered new interface driver gspca_zc3xx
[ 3.589552] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 3.591447] FAN dev name: pwm-fan
[ 3.591496] FAN:gpio request success.
[ 3.591502] FAN: can’t find tach_gpio
[ 3.591526] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 3.591674] pwm_fan_driver pwm-fan: unable to request PWM, trying legacy API
[ 3.591678] pwm_fan_driver pwm-fan: got pwm for fan
[ 3.591682] pwm_fan_driver pwm-fan: tach period: 1000
[ 3.591975] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 3.591978] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 3.591982] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 3.591985] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 3.591988] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 3.591991] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 3.591994] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 3.591997] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 3.592000] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 3.592003] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 3.592751] device-mapper: uevent: version 1.0.3
[ 3.592932] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 3.593286] sdhci: Secure Digital Host Controller Interface driver
[ 3.593287] sdhci: Copyright(c) Pierre Ossman
[ 3.593290] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.593613] sdhci-tegra 3460000.sdhci: Parent select= pll_p rate=408000000
[ 3.593905] sdhci-tegra 3460000.sdhci: Parent select= pll_c4_out0 rate=196249804
[ 3.594139] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 3.595310] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 3.595432] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.596902] usbcore: registered new interface driver usbhid
[ 3.596903] usbhid: USB HID core driver
[ 3.599948] nvadsp 2993000.adsp: in probe()…
[ 3.601798] nvadsp 2993000.adsp: Registering AMC Error Interrupt
[ 3.601824] nvadsp 2993000.adsp: AMC/ARAM initialized.
[ 3.602017] nvadsp 2993000.adsp: nvadsp_app_module_probe
[ 3.602731] Denver: backdoor interface is NOT available.
[ 3.604437] coresight-tmc 8030000.etf: TMC initialized
[ 3.605474] coresight-tmc 8050000.etr: TMC initialized
[ 3.605809] coresight-tpiu 8060000.tpiu: TPIU initialized
[ 3.606252] coresight-funnel 9010000.funnel_bccplex: FUNNEL initialized
[ 3.606651] coresight-funnel 8010000.funnel_major: FUNNEL initialized
[ 3.607068] coresight-funnel 8820000.funnel_minor: FUNNEL initialized
[ 3.607495] coresight-replicator 8040000.replicator: REPLICATOR initialized
[ 3.608081] coresight-etm4x 9840000.ptm: ETM 4.0 initialized
[ 3.608612] coresight-etm4x 9940000.ptm: ETM 4.0 initialized
[ 3.609134] coresight-etm4x 9a40000.ptm: ETM 4.0 initialized
[ 3.609656] coresight-etm4x 9b40000.ptm: ETM 4.0 initialized
[ 3.609681] Module initialized successfully
[ 3.612953] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xa0000000
[ 3.614159] tegra186-cam-rtcpu b000000.rtcpu: already unhalted
[ 3.614431] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xa0110000-0xa011957f size=38272
[ 3.614843] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 3.614889] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x1900-0x3980 TX[64x128]=0x3980-0x5a00
[ 3.614926] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x5a00-0x5ac0 TX[1x64]=0x5ac0-0x5b80
[ 3.614966] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x5b80-0x7000 TX[16x320]=0x7000-0x8480
[ 3.615006] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8480-0x8900 TX[16x64]=0x8900-0x8d80
[ 3.615043] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x8d80-0x8f80 TX[1x384]=0x8f80-0x9180
[ 3.615082] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x384]=0x9180-0x9380 TX[1x384]=0x9380-0x9580
[ 3.615236] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (52)
[ 3.615239] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[ 3.616208] tegra-ivc ivc-b000000.rtcpu:echo@0: ivc channel driver missing
[ 3.616211] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: ivc channel driver missing
[ 3.616214] tegra-ivc ivc-b000000.rtcpu:mods@32c0: ivc channel driver missing
[ 3.616216] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivc channel driver missing
[ 3.616219] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivc channel driver missing
[ 3.616221] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: ivc channel driver missing
[ 3.616224] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: ivc channel driver missing
[ 3.616249] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=4 sha1=a8b1ecdd9615cd817a56df035be363fce3b0b88f
[ 3.620076] tegra-ivc-cdev ivc-b000000.rtcpu:echo@0: probing /dev/camchar-echo
[ 3.620817] tegra-ivc-cdev ivc-b000000.rtcpu:dbg@7c00: probing /dev/camchar-dbg
[ 3.620926] camchar: rtcpu character device driver loaded
[ 3.624371] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 3.624605] register_ari_mca_banks: Registered MCA ROC:IOB
[ 3.624691] register_ari_mca_banks: Registered MCA ROC:CCE
[ 3.625019] tegra18-bridge 2390000.axi2apb: bridge probed OK
[ 3.625048] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[ 3.625072] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[ 3.625095] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[ 3.625120] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[ 3.625145] tegra18-bridge 2100000.axip2p: bridge probed OK
[ 3.625168] tegra18-bridge 2110000.axip2p: bridge probed OK
[ 3.625190] tegra18-bridge 2120000.axip2p: bridge probed OK
[ 3.625212] tegra18-bridge 2130000.axip2p: bridge probed OK
[ 3.625236] tegra18-bridge 2140000.axip2p: bridge probed OK
[ 3.625259] tegra18-bridge 2150000.axip2p: bridge probed OK
[ 3.625282] tegra18-bridge 2160000.axip2p: bridge probed OK
[ 3.625305] tegra18-bridge 2170000.axip2p: bridge probed OK
[ 3.625330] tegra18-bridge 2180000.axip2p: bridge probed OK
[ 3.625352] tegra18-bridge 2190000.axip2p: bridge probed OK
[ 3.625400] **** A57 ECC: Enabled
[ 3.625402] tegra18_a57_serr_init: on CPU 4 a A57 Core
[ 3.625535] parse_throttle_dt_data: Num cap clks = 4
[ 3.625538] parse_throttle_dt_data: clk=mcpu type=1
[ 3.625540] parse_throttle_dt_data: clk=bcpu type=2
[ 3.625545] parse_throttle_dt_data: clk=gpu type=4
[ 3.625547] parse_throttle_dt_data: clk=emc type=3
[ 3.625999] tegra_throttle_probe: probe successful. #cdevs=4
[ 3.626086] tegra18x_actmon d230000.actmon: in actmon_register()…
[ 3.628548] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 3.628842] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[ 3.630774] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.630975] tegra-se-nvhost 15810000.se: initialized
[ 3.631029] sdhci-tegra 3440000.sdhci: Parent select= pll_p rate=408000000
[ 3.631325] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 3.631632] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 3.632402] tegra-se-nvhost 15820000.se: initialized
[ 3.632877] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 3.633174] tegra-se-nvhost 15830000.se: initialized
[ 3.633280] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 3.633560] tegra-se-nvhost 15840000.se: initialized
[ 3.633970] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 3.638160] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 3.641513] cpufreq: platform driver Initialization: pass
[ 3.641658] tegra_cluster_clk e090000.cluster_clk_priv: in probe()…
[ 3.641712] tegra_cluster_clk e090000.cluster_clk_priv: passed
[ 3.641897] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 3.641901] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 3.641936] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x2eb095
[ 3.641939] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x8
[ 3.643148] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 3.643676] tegra186-padctl 3520000.pinctrl: VBUS over-current detection enabled
[ 3.644232] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 0 not supported
[ 3.646125] cpuidle: Initializing cpuidle driver init for Denver cluster
[ 3.646232] cpuidle: Initializing cpuidle driver init for A57 cluster
[ 3.647145] tachometer tegra-tachometer: Tachometer driver tegra-tachometer registered
[ 3.647149] Tachometer driver initialized with pulse_per_rev: 2 and win_len: 2
[ 3.649882] tegra210_adsp_audio_platform_probe: platform probe started
[ 3.650414] tegra210-adsp adsp_audio: Default param-type to BYTE for mp3-dec1
[ 3.650632] tegra210-adsp adsp_audio: Default param-type to BYTE for spkprot
[ 3.650946] tegra210-adsp adsp_audio: Default param-type to BYTE for src
[ 3.651192] tegra210-adsp adsp_audio: Default param-type to BYTE for aac-dec1
[ 3.651488] tegra210-adsp adsp_audio: Default param-type to BYTE for aec
[ 3.651492] tegra210-adsp adsp_audio: adma channel page address dt entry not found
[ 3.651493] tegra210-adsp adsp_audio: using adma channel page 0
[ 3.662030] tegra210_adsp_audio_platform_probe probe successfull.
[ 3.662030] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 3.662154] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 3.665185] OPE platform probe
[ 3.665245] OPE platform probe successful
[ 3.666765] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.666997] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 3.667038] sdhci-tegra 3400000.sdhci: Got WP GPIO
[ 3.667094] sdhci-tegra 3400000.sdhci: Parent select= pll_p rate=408000000
[ 3.667119] sdhci-tegra 3400000.sdhci: wakeup init done, cd_irq: 256
[ 3.667317] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 3.672555] tegra-snd-t186ref-mobile-rt565x sound: Failed to get HP Det GPIO, should be handled by codec
[ 3.684780] mmc0: MAN_BKOPS_EN bit is not set
[ 3.692064] mmc0: Skipping tuning since strobe enabled
[ 3.699534] mmc0: periodic cache flush enabled
[ 3.699543] mmc0: new HS400 MMC card at address 0001
[ 3.699912] mmcblk0: mmc0:0001 032G34 29.1 GiB
[ 3.700064] mmcblk0boot0: mmc0:0001 032G34 partition 1 4.00 MiB
[ 3.700207] mmcblk0boot1: mmc0:0001 032G34 partition 2 4.00 MiB
[ 3.700335] mmcblk0rpmb: mmc0:0001 032G34 partition 3 4.00 MiB
[ 3.701479] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17
[ 3.710834] gpio tegra-gpio wake71 for gpio=125(P:5)
[ 3.710868] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.724662] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 3.724731] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 3.724803] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 3.724867] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 3.724939] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 3.725006] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 3.725075] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 3.725139] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 3.725203] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 3.725270] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 3.725335] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 3.725403] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 3.725469] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 3.725537] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 3.725603] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 3.725673] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 3.725743] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 3.725808] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 3.725877] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 3.725942] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 3.728859] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE1 <-> ADSP PCM1 mapping ok
[ 3.728928] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE2 <-> ADSP PCM2 mapping ok
[ 3.728955] compress asoc: ADSP-FE3 <-> ADSP COMPR1 mapping ok
[ 3.728975] compress asoc: ADSP-FE4 <-> ADSP COMPR2 mapping ok
[ 3.739236] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 3.760168] input: tegra-snd-t186ref-mobile-rt565x Headphone Jack as /devices/sound/sound/card1/input2
[ 3.760989] tegra-snd-t186ref-mobile-rt565x sound: codec-dai “dit-hifi” registered
[ 3.760992] tegra-snd-t186ref-mobile-rt565x sound: This is a dummy codec
[ 3.761595] GACT probability NOT on
[ 3.761604] Mirror/redirect action on
[ 3.761616] u32 classifier
[ 3.761617] Actions configured
[ 3.761639] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[ 3.762357] ipip: IPv4 over IPv4 tunneling driver
[ 3.762672] Initializing XFRM netlink socket
[ 3.763071] NET: Registered protocol family 10
[ 3.763795] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 3.763851] NET: Registered protocol family 17
[ 3.763865] NET: Registered protocol family 15
[ 3.763903] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 3.763909] 8021q: 802.1Q VLAN Support v1.8
[ 3.764195] Registered cp15_barrier emulation handler
[ 3.764211] Registered setend emulation handler
[ 3.765568] registered taskstats version 1
[ 3.769618] isp 15600000.isp: initialized
[ 3.774018] nvcsi 150c0000.nvcsi: initialized
[ 3.775196] Wake76 for irq=199
[ 3.775198] Wake77 for irq=199
[ 3.775198] Wake78 for irq=199
[ 3.775199] Wake79 for irq=199
[ 3.775200] Wake80 for irq=199
[ 3.775200] Wake81 for irq=199
[ 3.775201] Wake82 for irq=199
[ 3.775502] xhci-tegra 3530000.xhci: UTMI port 0 has OTG_CAP
[ 3.775503] xhci-tegra 3530000.xhci: No USB3 port has OTG_CAP
[ 3.799077] spi-tegra114 3210000.spi: Static pin configuration used
[ 3.799227] xhci-tegra 3530000.xhci: Direct firmware load for tegra18x_xusb_firmware failed with error -2
[ 3.799229] xhci-tegra 3530000.xhci: Falling back to user helper
[ 3.799756] spi-tegra114 c260000.spi: Static pin configuration used
[ 3.800458] spi-tegra114 3240000.spi: Static pin configuration used
[ 3.801200] tegra-xotg xotg: OTG rev:0200, ADP:0, SRP:1, HNP:1, RSP:0
[ 3.801237] tegra-xotg xotg: update_id_state: ID floating
[ 3.801242] tegra-xotg xotg: update_vbus_state: VBUS not detected
[ 3.801254] tegra-xotg xotg: Nvidia XUSB OTG Controller
[ 3.802985] tegra-xotg xotg: otg: gadget gadget registered
[ 3.802987] tegra-xotg xotg: set gadget otg_caps from OTG controller
[ 3.802989] tegra-xotg xotg: otg: host not registered yet
[ 3.802990] tegra-xotg xotg: otg: start OTG finite state machine
[ 3.803029] tegra-xudc-new 3550000.xudc: entering ELPG
[ 3.803520] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 3.803734] gpio tegra-gpio-aon wake29 for gpio=56(FF:0)
[ 3.803806] gpio tegra-gpio-aon wake67 for gpio=57(FF:1)
[ 3.803875] gpio tegra-gpio-aon wake68 for gpio=58(FF:2)
[ 3.804002] input: gpio-keys as /devices/gpio-keys/input/input3
[ 3.838607] tegra_rtc c2a0000.rtc: setting system clock to 2000-01-01 01:00:19 UTC (946688419)
[ 3.868367] bpmp: mounted debugfs mirror
[ 3.868849] [dram-timers] DRAM derating cdev registered.
[ 3.872777] spmic-ldo0: disabling
[ 3.872948] spmic-ldo1: disabling
[ 3.873091] en-vdd-cam: disabling
[ 3.873093] vdd-usb0-5v: disabling
[ 3.873095] vdd-usb1-5v: disabling
[ 3.873098] en-vdd-disp-3v3: disabling
[ 3.873099] en-mdm-pwr-3v7: disabling
[ 3.873101] en-vdd-disp-1v8: disabling
[ 3.873102] en-vdd-cam-hv-2v8: disabling
[ 3.873104] en-vdd-cam-1v2: disabling
[ 3.873105] vdd-fan: disabling
[ 3.873107] vdd-3v3: disabling
[ 3.873108] en-vdd-vcm-2v8: disabling
[ 3.873110] vdd-usb2-5v: disabling
[ 3.873111] vdd-sys-bl: disabling
[ 3.873113] en-vdd-sys: disabling
[ 3.880062] ALSA device list:
[ 3.880064] #0: tegra-hda at 0x3518000 irq 400
[ 3.880065] #1: tegra-snd-t186ref-mobile-rt565x
[ 3.881272] tegra-vi4 15700000.vi: initialized
[ 3.936522] mmc1 tuning done saved tap delay=63
[ 3.936524] mmc1: hw tuning done …
[ 3.936531] mmc1: tuning_window[0]: 0xffffffff
[ 3.936536] mmc1: tuning_window[1]: 0xfffff8ff
[ 3.936541] mmc1: tuning_window[2]: 0xff8fffff
[ 3.936546] mmc1: tuning_window[3]: 0x7fffffff
[ 3.936550] mmc1: tuning_window[4]: 0x0
[ 3.936554] mmc1: tuning_window[5]: 0x0
[ 3.936559] mmc1: tuning_window[6]: 0x0
[ 3.936563] mmc1: tuning_window[7]: 0x0
[ 3.936566] sdhci: Tap value: 63 | Trim value: 5
[ 3.936568] sdhci: SDMMC_VENDOR_INTR_STATUS[0x108]: 0x40000
[ 3.942093] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 3.942134] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 11.740353] random: nonblocking pool is initialized
[ 12.272810] tegradc 15210000.nvdisplay: hdmi: plugged
[ 12.702204] EXT4-fs (mmcblk0p1): 4 orphan inodes deleted
[ 12.708466] EXT4-fs (mmcblk0p1): recovery complete
[ 12.718389] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 12.727403] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 12.735592] devtmpfs: mounted
[ 12.739729] Freeing unused kernel memory: 1164K (ffffffc0010cd000 - ffffffc0011f0000)
[ 12.748548] Freeing alternatives memory: 96K (ffffffc0011f0000 - ffffffc001208000)
[ 12.792621] systemd[1]: System time before build time, advancing clock.
[ 12.808656] systemd[1]: Configuration file /etc/systemd/system.conf is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 12.824169] systemd[1]: Configuration file /etc/systemd/system.conf is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 12.842690] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[ 12.864041] systemd[1]: Detected architecture arm64.
[ 12.875854] systemd[1]: Set hostname to .
[ 12.904592] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/networking.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 12.924326] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/networking.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 12.947502] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/anacron.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 12.966689] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/anacron.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 12.988958] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/rc-local.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 13.007432] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/rc-local.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 13.028633] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/dbus.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 13.046835] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/dbus.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 13.067462] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/dns-clean.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 13.086369] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/dns-clean.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 13.107608] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/brltty.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 13.126535] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/brltty.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 13.148010] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/rpcbind.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 13.167369] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/rpcbind.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 13.189164] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/plymouth-read-write.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 13.209614] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/plymouth-read-write.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 13.232442] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/systemd-sysctl.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 13.252616] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/systemd-sysctl.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 13.279498] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/avahi-daemon.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 13.299558] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/avahi-daemon.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 13.321988] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/NetworkManager.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 13.342197] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/NetworkManager.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 13.364830] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/console-setup.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 13.385108] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/console-setup.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 13.407677] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/pppd-dns.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 13.427617] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/pppd-dns.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 13.449813] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/kerneloops.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 13.469902] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/kerneloops.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 13.492336] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/bluetooth.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 13.512347] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/bluetooth.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 13.538942] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/gpsd.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 13.558544] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/gpsd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 13.580373] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/rsyslog.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 13.600200] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/rsyslog.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 13.622292] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/plymouth-quit.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 13.642642] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/plymouth-quit.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 13.665303] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/lvm2-lvmpolld.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 13.685664] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/lvm2-lvmpolld.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 13.708236] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/cron.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 13.727867] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/cron.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 13.749904] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/systemd-udevd.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 13.770343] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/systemd-udevd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 13.793152] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/unattended-upgrades.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 13.818411] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/unattended-upgrades.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 13.841690] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/systemd-modules-load.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 13.862713] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/systemd-modules-load.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 13.886068] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/lightdm.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 13.905949] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/lightdm.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 13.928046] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/whoopsie.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 13.947989] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/whoopsie.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 13.970190] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/cups-browsed.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 13.990455] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/cups-browsed.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 14.013147] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/systemd-random-seed.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 14.034052] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/systemd-random-seed.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 14.057279] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/cups.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 14.076863] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/cups.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 14.103149] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/lvm2-lvmetad.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 14.123442] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/lvm2-lvmetad.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 14.146300] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/ssh.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 14.165806] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/ssh.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 14.187543] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/rsync.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 14.207243] systemd-sysv-generator[251]: Configuration file /lib/systemd/system/rsync.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 14.234723] systemd-sysv-generator[251]: Overwriting existing symlink /run/systemd/generator.late/skeleton.service with real service.
[ 14.257036] systemd[1]: Configuration file /lib/systemd/system/local-fs.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 14.278231] systemd[1]: Configuration file /lib/systemd/system/local-fs.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 14.302273] systemd[1]: Configuration file /lib/systemd/system/systemd-remount-fs.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 14.324446] systemd[1]: Configuration file /lib/systemd/system/systemd-remount-fs.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 14.349081] systemd[1]: Configuration file /lib/systemd/system/system.slice is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 14.367232] systemd[1]: Configuration file /lib/systemd/system/system.slice is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 14.387584] systemd[1]: Configuration file /lib/systemd/system/-.slice is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 14.405215] systemd[1]: Configuration file /lib/systemd/system/-.slice is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 14.425180] systemd[1]: Configuration file /lib/systemd/system/slices.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 14.443340] systemd[1]: Configuration file /lib/systemd/system/slices.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 14.463879] systemd[1]: Configuration file /lib/systemd/system/systemd-journald.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 14.482946] systemd[1]: Configuration file /lib/systemd/system/systemd-journald.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 14.504687] systemd[1]: Configuration file /lib/systemd/system/systemd-journald.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 14.523815] systemd[1]: Configuration file /lib/systemd/system/systemd-journald.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 14.545543] systemd[1]: Configuration file /lib/systemd/system/sysinit.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 14.563813] systemd[1]: Configuration file /lib/systemd/system/sysinit.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 14.586462] systemd[1]: Configuration file /lib/systemd/system/systemd-sysctl.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 14.605483] systemd[1]: Configuration file /lib/systemd/system/systemd-sysctl.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 14.625630] systemd[1]: Configuration file /lib/systemd/system/systemd-ask-password-console.path is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 14.645552] systemd[1]: Configuration file /lib/systemd/system/systemd-ask-password-console.path is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 14.667986] systemd[1]: Configuration file /lib/systemd/system/systemd-ask-password-console.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 14.688196] systemd[1]: Configuration file /lib/systemd/system/systemd-ask-password-console.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 14.710715] systemd[1]: Configuration file /lib/systemd/system/paths.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 14.728804] systemd[1]: Configuration file /lib/systemd/system/paths.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 14.749146] systemd[1]: Configuration file /lib/systemd/system/systemd-binfmt.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 14.768100] systemd[1]: Configuration file /lib/systemd/system/systemd-binfmt.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 14.789402] systemd[1]: Configuration file /lib/systemd/system/systemd-hwdb-update.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 14.808807] systemd[1]: Configuration file /lib/systemd/system/systemd-hwdb-update.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 14.830610] systemd[1]: Configuration file /lib/systemd/system/systemd-modules-load.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 14.850094] systemd[1]: Configuration file /lib/systemd/system/systemd-modules-load.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 14.870862] systemd[1]: Configuration file /lib/systemd/system/sys-fs-fuse-connections.mount is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 14.890621] systemd[1]: Configuration file /lib/systemd/system/sys-fs-fuse-connections.mount is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 14.912880] systemd[1]: Configuration file /lib/systemd/system/systemd-tmpfiles-setup.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 14.932683] systemd[1]: Configuration file /lib/systemd/system/systemd-tmpfiles-setup.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 14.954998] systemd[1]: Configuration file /lib/systemd/system/systemd-update-utmp.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 14.974331] systemd[1]: Configuration file /lib/systemd/system/systemd-update-utmp.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 14.996172] systemd[1]: Configuration file /lib/systemd/system/systemd-machine-id-commit.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 15.016016] systemd[1]: Configuration file /lib/systemd/system/systemd-machine-id-commit.service is marked world-writable. Please remove world writability permission bits. Proceeding
