I have trouble Flashing Jetson Tx2 with Jetpack 3.3.
The process is trouble free till Target ip is identified by the host and after the target boots up, it becomes unresponsive
I am fairly new to Jetson Tx2, not sure how to debug to resolve this issue
I am not pretty sure your error. Why do you know the system becomes unresponsive after IP determined?
Do you have UART debugger? Please describe more about your case and how it happened.
I tried with 3.2.1 the same happened. But with Jetpack 3.0 the system was responsive after flashing. I have a USB keyboard attached to jetson tx2, after flashing with Jetpack 3.3 and 3.2.1 i can see my keyboard not responding after the host gets to know my jetson tx2.
Host gets my Jetson tx2’s ip address and does some ssh stuff and logsout, after which my jetson tx2 is not responding
But with jetpack 3.0, after i flash i am able to login and use the system.
I dont have a UART debugger. But if some logs are required i can get them.
Could you find a HDMI monitor and connect it to your device?
Does “not responding” mean there is no ssh connection?
HDMI monitor and keyboard was connected to the Jetson tx2 system and i could not see any response when i tried logging into the system using the keyboard at the ubuntu prompt after flashing using 3.3 and 3.2.1. I remember i was able to ssh from host after flashing with 3.3 and 3.2.1
So below is the current status…
HDMI → no response
SSH → able to connect
Is it correct…?
Do you have any way to check that TX2 really boots up?
HDMI → No response. SSH → Able to ssh from host, but remember getting permission denied error lot, some error stated systemctl was down too. I tried rebooting after it was not responding for 30 mins, i could see ubuntu log in screen in HDMI and my Jetson tx2 was not responding to keyboard.
After this i have flashed the system now with Jetson 3.0 where i did not run into this issue.
I can flash it again with 3.3 to collect logs if needed.
What are the exact situation here?
Why did you say HDMI have no response but also say you could see ubuntu log on HDMI screen?
Could you share log with us?
HDMI shows output, till-> ubuntu login screen , but system not responding to keyboard that is plugged in directly to the device.
This is what i see in Jetpack.log
11-20 15:14:14.3 N: GoogleAnalytics enabled
11-20 15:14:14.3 E: fopen failed with file local.db, errno = 2
11-20 15:14:15.8 W: One invalid entry
11-20 15:14:40.7 N: Install com.nvidia.l4t.driver4os_64_tx2 28.2.1; Install com.nvidia.l4t.filesystem_64_tx2 28.2.1; Install com.nvidia.l4t.flash_64_tx2 28.2.1;
11-20 15:14:47.8 N: /media/myntra/Data/jetpack3.3//InstallUtil setup /media/myntra/Data/jetpack3.3/ 18883
11-20 15:14:47.8 N: InstallUtil setup return code0
11-20 15:16:13.0 N: Installing Drivers 28.2.1 succeeded.
11-20 15:18:56.2 N: Installing File System and OS 28.2.1 succeeded.
11-20 15:18:56.3 N: Installing Flash OS Image to Target 28.2.1 succeeded.
on ssh from host, i see the below
nvidia@tegra-ubuntu:~$ uname -a
Linux tegra-ubuntu 4.4.38-tegra #1 SMP PREEMPT Thu May 17 00:15:19 PDT 2018 aarch64 aarch64 aarch64 GNU/Linux
Could you share the result of “dmesg”?
Below is jetpack_debug.log after flashing with 3.3PageAction: Tue Nov 20 15:14:08 IST 2018: /media/myntra/Data/jetpack3.3/_installer/PageAction installation install . /media/myntra/Data/jetpack3.3 Launcher 18834 /media/myntra/Data/jetpack3.3/jetpack_download
PageAction: Tue Nov 20 15:14:12 IST 2018: /media/myntra/Data/jetpack3.3/_installer/PageAction installation miscellaneous . /media/myntra/Data/jetpack3.3 Launcher 18834 /media/myntra/Data/jetpack3.3/jetpack_download
InstallUtils: Tue Nov 20 15:14:40 IST 2018: /media/myntra/Data/jetpack3.3/_installer/InstallUtil setup /media/myntra/Data/jetpack3.3/ 18883
InstallUtils: Tue Nov 20 15:16:06 IST 2018: ./InstallUtil install com.nvidia.l4t.driver4os_64_tx2 28.2.1 /media/myntra/Data/jetpack3.3/jetpack_download/Tegra186_Linux_R28.2.1_aarch64.tbz2 /media/myntra/Data/jetpack3.3/ /media/myntra/Data/jetpack3.3/jetpack_download/repository.json 18834
InstallUtils: Tue Nov 20 15:16:13 IST 2018: ./InstallUtil install com.nvidia.l4t.filesystem_64_tx2 28.2.1 /media/myntra/Data/jetpack3.3/jetpack_download/Tegra_Linux_Sample-Root-Filesystem_R28.2.1_aarch64.tbz2 /media/myntra/Data/jetpack3.3/ /media/myntra/Data/jetpack3.3/jetpack_download/repository.json 18834
InstallUtils: Tue Nov 20 15:18:56 IST 2018: ./InstallUtil install com.nvidia.l4t.flash_64_tx2 28.2.1 /media/myntra/Data/jetpack3.3/jetpack_download/ /media/myntra/Data/jetpack3.3/ /media/myntra/Data/jetpack3.3/jetpack_download/repository.json 18834
PageAction: Tue Nov 20 15:18:57 IST 2018: /media/myntra/Data/jetpack3.3/_installer/PageAction finished create_shortcut
PageAction: Tue Nov 20 15:18:57 IST 2018: /media/myntra/Data/jetpack3.3/_installer/PageAction query eclipse
PageAction: Tue Nov 20 15:18:57 IST 2018: /media/myntra/Data/jetpack3.3/_installer/PageAction installation nextpage . /media/myntra/Data/jetpack3.3 Launcher 18834
PageAction: Tue Nov 20 15:18:57 IST 2018: /media/myntra/Data/jetpack3.3/_installer/PageAction query incredibuild
PageAction: Tue Nov 20 15:19:13 IST 2018: /media/myntra/Data/jetpack3.3/_installer/PageAction query post_installation_info
PageAction: Tue Nov 20 15:19:19 IST 2018: ./PageAction jetpack_deploy_samples install /media/myntra/Data/jetpack3.3 2.3
InstallUtils: Tue Nov 20 15:19:19 IST 2018: /media/myntra/Data/jetpack3.3/_installer/InstallUtil install flash_post_64_tx2 28.2.1 fake_bin /media/myntra/Data/jetpack3.3 jetpack_repository.json fake_installer_pid
PageAction: Tue Nov 20 15:30:09 IST 2018: /media/myntra/Data/jetpack3.3/_installer/PageAction jetpack_deploy_samples nextpage
PageAction: Tue Nov 20 15:30:38 IST 2018: /media/myntra/Data/jetpack3.3/_installer/PageAction finished remove_downloads
PageAction: Tue Nov 20 15:30:38 IST 2018: /media/myntra/Data/jetpack3.3/_installer/PageAction finished create_workspace
InstallUtils: Tue Nov 20 15:38:38 IST 2018: /media/myntra/Data/jetpack3.3/_installer/InstallUtil setup /media/myntra/Data/jetpack3.3/ 18567
InstallUtils: Tue Nov 20 15:39:10 IST 2018: ./InstallUtil install com.nvidia.l4t.flash_64_tx2 28.2.1 /media/myntra/Data/jetpack3.3/jetpack_download/ /media/myntra/Data/jetpack3.3/ /media/myntra/Data/jetpack3.3/jetpack_download/repository.json 18516
InstallUtils: Tue Nov 20 15:39:18 IST 2018: ./InstallUtil install com.nvidia.l4t.flash_64_tx2 28.2.1 /media/myntra/Data/jetpack3.3/jetpack_download/ /media/myntra/Data/jetpack3.3/ /media/myntra/Data/jetpack3.3/jetpack_download/repository.json 18516
InstallUtils: Tue Nov 20 15:39:42 IST 2018: ./InstallUtil install com.nvidia.l4t.flash_64_tx2 28.2.1 /media/myntra/Data/jetpack3.3/jetpack_download/ /media/myntra/Data/jetpack3.3/ /media/myntra/Data/jetpack3.3/jetpack_download/repository.json 18516
InstallUtils: Tue Nov 20 15:39:51 IST 2018: ./InstallUtil install com.nvidia.cuda.l4t_64_tx2 9.0 /media/myntra/Data/jetpack3.3/jetpack_download/cuda-repo-l4t-9-0-local_9.0.252-1_arm64.deb /media/myntra/Data/jetpack3.3/ /media/myntra/Data/jetpack3.3/jetpack_download/repository.json 18516
So the true error synopsis is → keyboard is not working. Others seem good.
Please share the kernel log (dmesg) with us. Thanks.
nvidia@tegra-ubuntu:~$ dmesg
[ 0.109778] CPU5: Booted secondary processor [411fd073]
[ 0.109842] Brought up 6 CPUs
[ 0.109900] SMP: Total of 6 processors activated.
[ 0.109912] CPU: All CPU(s) started at EL2
[ 0.110333] devtmpfs: initialized
[ 0.137437] Initilizing CustomIPI irq domain
[ 0.137632] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.138379] pinctrl core: initialized pinctrl subsystem
[ 0.138553] OS set in device tree is not L4T.
[ 0.138744] regulator-dummy: no parameters
[ 0.138847] Initializing plugin-manager
[ 0.138900] Plugin module not found
[ 0.139302] node /plugin-manager/soc-prod-a02-fragment match with chip-id A02P
[ 0.139633] node /plugin-manager/fragement@0 match with odm-data enable-denver-wdt
[ 0.140231] node /plugin-manager/fragement@4 match with odm-data enable-denver-wdt
[ 0.141395] node /plugin-manager/fragment-sdwake-p3310-1000-300 match with board >=3310-1000-300
[ 0.141754] node /plugin-manager/fragement-pmon-p3310-1000-300 match with board >=3310-1000-300
[ 0.142010] node /plugin-manager/fragement-pmon-p3310-1000-800 match with board >=3310-1000-800
[ 0.142232] node /plugin-manager/fragment-devslp@0 match with board >=3310-1000-200
[ 0.142660] node /plugin-manager/fragment-500-pcie-config match with board >=3310-1000-500
[ 0.143108] node /plugin-manager/fragment-500-xusb-config match with board >=3310-1000-500
[ 0.143387] node /plugin-manager/fragment-500-e3325-pcie match with board >=3310-1000-500
[ 0.143771] node /plugin-manager/fragment-p3310-c00-comm match with board >=3310-1000-800
[ 0.144019] node /plugin-manager/fragment-p3310-c00-pmic match with board >=3310-1000-800
[ 0.144242] node /plugin-manager/fragment-p3310-c01 match with board >=3310-1000-900
[ 0.144503] node /plugin-manager/fragment-p3310-c03 match with board >=3310-1000-B00
[ 0.146087] node /plugin-manager/fragment-e3326@0 match with board 3326-*
[ 0.147174] node /plugin-manager/fragment-p3310-c00-camera match with board >=3310-1000-800
[ 0.148947] Adding domain adsp-pd to PM domain ape-pd
[ 0.151242] NET: Registered protocol family 16
[ 0.152092] console [pstore-1] enabled
[ 0.152105] pstore: Registered ramoops as persistent store backend
[ 0.152117] ramoops: attached 0x200000@0x277080000, ecc: 0/0
[ 0.161315] cpuidle: using governor ladder
[ 0.165753] cpuidle: using governor menu
[ 0.166878] bpmp: waiting for handshake
[ 0.166892] bpmp: handshake completed
[ 0.166933] bpmp: synchronizing channels
[ 0.166960] bpmp: channels synchronized
[ 0.166971] bpmp: mail init ok
[ 0.167338] vdso: 2 pages (1 code @ ffffffc00127d000, 1 data @ ffffffc00127c000)
[ 0.167372] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.168317] atomic_pool_init():526: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.169756] tegra_powergate_init: DONE
[ 0.169777] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.4/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.169804] DTB Build time: May 17 2018 00:17:47
[ 0.170727] Tegra reboot handler registered.
[ 0.171777] Registering Tegra186 clocks (this may take a while)…done
[ 0.173905] arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.173925] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.173938] arm-smmu 12000000.iommu: stage 1 translation
[ 0.173951] arm-smmu 12000000.iommu: stage 2 translation
[ 0.173963] arm-smmu 12000000.iommu: nested translation
[ 0.173978] arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.173996] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.174015] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.174029] arm-smmu 12000000.iommu: Stage-1: 39-bit VA → 48-bit IPA
[ 0.174042] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA → 48-bit PA
[ 0.222239] arm-smmu 12000000.iommu: registered 67 master devices
[ 0.227817] iommu: Adding device 3460000.sdhci to group 0
[ 0.228662] iommu: Adding device 3400000.sdhci to group 1
[ 0.232353] iommu: Adding device 3507000.ahci-sata to group 2
[ 0.232820] iommu: Adding device 3160000.i2c to group 3
[ 0.233222] iommu: Adding device c240000.i2c to group 4
[ 0.233573] iommu: Adding device 3180000.i2c to group 5
[ 0.233954] iommu: Adding device 3190000.i2c to group 6
[ 0.234398] iommu: Adding device 31b0000.i2c to group 7
[ 0.234769] iommu: Adding device 31c0000.i2c to group 8
[ 0.235096] iommu: Adding device c250000.i2c to group 9
[ 0.235452] iommu: Adding device 31e0000.i2c to group 10
[ 0.237432] iommu: Adding device 3210000.spi to group 11
[ 0.237745] iommu: Adding device c260000.spi to group 12
[ 0.238086] iommu: Adding device 3240000.spi to group 13
[ 0.238863] iommu: Adding device 3100000.serial to group 14
[ 0.239194] iommu: Adding device 3110000.serial to group 15
[ 0.239490] iommu: Adding device c280000.serial to group 16
[ 0.239793] iommu: Adding device 3130000.serial to group 17
[ 0.241089] iommu: Adding device 2490000.ether_qos to group 18
[ 0.241693] iommu: Adding device b000000.rtcpu to group 19
[ 0.242170] iommu: Adding device c1a0000.aon to group 20
[ 0.243059] Wake73 for irq=42
[ 0.243404] iommu: Adding device smmu_test to group 21
[ 0.243951] mc: mapped MMIO address: 0xffffff8000560000 → 0x2c10000
[ 0.243992] mc: mapped MMIO address: 0xffffff8000640000 → 0x2c20000
[ 0.244029] mc: mapped MMIO address: 0xffffff8000660000 → 0x2c30000
[ 0.244069] mc: mapped MMIO address: 0xffffff8000fa0000 → 0x2c40000
[ 0.244114] mc: mapped MMIO address: 0xffffff8000fc0000 → 0x2c50000
[ 0.244170] mc-err: Set intmask: 0xf3140
[ 0.244372] ecc-err: dram ecc disabled-MC_ECC_CONTROL:0x0000000c
[ 0.245240] Wake76 for irq=199
[ 0.245271] Wake77 for irq=199
[ 0.245292] Wake78 for irq=199
[ 0.245312] Wake79 for irq=199
[ 0.245338] Wake80 for irq=199
[ 0.245380] Wake81 for irq=199
[ 0.245400] Wake82 for irq=199
[ 0.245512] iommu: Adding device 3530000.xhci to group 22
[ 0.245885] iommu: Adding device 3550000.xudc to group 23
[ 0.246737] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.246773] tegra-pmc: ### PMC reset source: Software reset
[ 0.246797] tegra-pmc: ### PMC reset level: L1
[ 0.246820] tegra-pmc: ### PMC reset status reg: 0x2d
[ 0.247095] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.247134] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.247292] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.247321] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 320
[ 0.247806] iommu: Adding device 13e10000.host1x to group 24
[ 0.248074] iommu: Adding device 13e10000.host1x:ctx0 to group 25
[ 0.248320] iommu: Adding device 13e10000.host1x:ctx1 to group 26
[ 0.248569] iommu: Adding device 13e10000.host1x:ctx2 to group 27
[ 0.248798] iommu: Adding device 13e10000.host1x:ctx3 to group 28
[ 0.249011] iommu: Adding device 13e10000.host1x:ctx4 to group 29
[ 0.249267] iommu: Adding device 13e10000.host1x:ctx5 to group 30
[ 0.249480] iommu: Adding device 13e10000.host1x:ctx6 to group 31
[ 0.249752] iommu: Adding device 13e10000.host1x:ctx7 to group 32
[ 0.250180] iommu: Adding device 150c0000.nvcsi to group 33
[ 0.250784] iommu: Adding device 15700000.vi to group 34
[ 0.251104] iommu: Adding device 15600000.isp to group 35
[ 0.251486] iommu: Adding device 15210000.nvdisplay to group 36
[ 0.251690] platform 15210000.nvdisplay: IOVA linear map 0x00000000969ee000(800000)
[ 0.251732] platform 15210000.nvdisplay: IOVA linear map 0x00000000969eb000(3000)
[ 0.251949] iommu: Adding device 15340000.vic to group 37
[ 0.252145] iommu: Adding device 154c0000.nvenc to group 38
[ 0.252329] iommu: Adding device 15480000.nvdec to group 39
[ 0.252681] iommu: Adding device 15380000.nvjpg to group 40
[ 0.252891] iommu: Adding device 15500000.tsec to group 41
[ 0.253072] iommu: Adding device 15100000.tsecb to group 42
[ 0.253790] iommu: Adding device 15810000.se to group 43
[ 0.253990] iommu: Adding device 15820000.se to group 44
[ 0.254176] iommu: Adding device 15830000.se to group 45
[ 0.254376] iommu: Adding device 15840000.se to group 46
[ 0.254915] iommu: Adding device 17000000.gp10b to group 47
[ 0.256289] tegra-reset 5000000.clock: registered 193 resets.
[ 0.258284] iommu: Adding device d000000.bpmp to group 48
[ 0.258555] bpmp: ping status is 0
[ 0.258750] bpmp d000000.bpmp: firmware tag is 83385b61e34297b2f37e76e0cd1ff81e
[ 0.259107] bpmp d000000.bpmp: probe ok
[ 0.262133] iommu: Adding device 2600000.dma to group 49
[ 0.263188] GPIO line 461 (cam0-rst) hogged as output/low
[ 0.263246] GPIO line 456 (cam0-pwdn) hogged as output/low
[ 0.263318] GPIO line 457 (cam1-rst) hogged as output/low
[ 0.263365] GPIO line 426 (cam1-pwdn) hogged as output/low
[ 0.263416] GPIO line 424 (wifi-enable) hogged as output/high
[ 0.263466] GPIO line 445 (sdmmc-wake-input) hogged as input
[ 0.263517] GPIO line 446 (sdmmc-wake-output) hogged as output/low
[ 0.263614] gpiochip_add_data: registered GPIOs 320 to 511 on device: tegra-gpio
[ 0.265484] GPIO line 315 (wifi-wake-ap) hogged as input
[ 0.265605] gpiochip_add_data: registered GPIOs 256 to 319 on device: tegra-gpio-aon
[ 0.266488] iommu: Adding device 10003000.pcie-controller to group 50
[ 0.266769] iommu: Adding device sound to group 51
[ 0.268510] iommu: Adding device 3510000.hda to group 52
[ 0.269731] iommu: Adding device adsp_audio to group 53
[ 0.271197] iommu: Adding device 2993000.adsp to group 54
[ 0.280331] vdd-ac-bat: 5000 mV
[ 0.282576] vdd-1v8-ap: 1800 mV
[ 0.300910] SCSI subsystem initialized
[ 0.301124] libata version 3.00 loaded.
[ 0.301302] usbcore: registered new interface driver usbfs
[ 0.301363] usbcore: registered new interface driver hub
[ 0.301477] usbcore: registered new device driver usb
[ 0.305310] GPIO line 241 (touch-rail-1) hogged as output/high
[ 0.305767] GPIO line 242 (touch-rail-2) hogged as output/high
[ 0.305876] gpiochip_add_data: registered GPIOs 240 to 255 on device: tca9539
[ 0.307317] GPIO line 228 (lcd-bias-en-rail) hogged as output/high
[ 0.307410] gpiochip_add_data: registered GPIOs 224 to 239 on device: tca9539
[ 0.318321] media: Linux media interface: v0.10
[ 0.318389] Linux video capture interface: v2.00
[ 0.321475] pps_core: LinuxPPS API ver. 1 registered
[ 0.321510] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.321579] PTP clock support registered
[ 0.322589] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.322637] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.324048] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[ 0.326125] GPIO line 221 (spmic_gpio_input_5) hogged as input
[ 0.326332] GPIO line 222 (spmic_gpio_input_6) hogged as input
[ 0.326427] gpiochip_add_data: registered GPIOs 216 to 223 on device: max77620-gpio
[ 0.330231] vddio-ddr: at 1125 mV
[ 0.334075] avdd_dsi_csi: 1200 mV
[ 0.338072] vdd-1v8: 1800 mV
[ 0.342070] vdd-3v3-sys: 3300 mV
[ 0.343164] spmic-ldo0: at 1800 mV
[ 0.343950] spmic-ldo1: at 800 mV
[ 0.346073] vddio-3v3: 3300 mV
[ 0.346739] vddio-sdmmc1: 1800 ↔ 3300 mV at 3300 mV
[ 0.350073] vdd-rtc: at 800 mV
[ 0.350872] avdd-ts-hv: 1800 ↔ 3300 mV at 1800 mV
[ 0.354075] spmic-ldo6: at 1500 mV
[ 0.358072] vdd-pex-1v05: 1000 mV
[ 0.358677] dvdd-pex: 1000 mV
[ 0.358963] max77620 4-003c: max77620 probe successful
[ 0.359217] Advanced Linux Sound Architecture Driver Initialized.
[ 0.360202] en-vdd-sd: 3300 mV
[ 0.360748] en-vdd-cam: 1800 mV
[ 0.365756] vdd-hdmi: 5000 mV
[ 0.365930] vdd-usb0-5v: 5000 mV
[ 0.366100] vdd-usb1-5v: 5000 mV
[ 0.369757] en-vdd-ts-1v8: 1800 mV
[ 0.373755] en-vdd-ts-hv-3v3: 3300 mV
[ 0.374259] en-vdd-disp-3v3: 3300 mV
[ 0.374764] en-mdm-pwr-3v7: 3700 mV
[ 0.375278] en-vdd-disp-1v8: 1800 mV
[ 0.375794] en-vdd-cam-hv-2v8: 2800 mV
[ 0.376316] en-vdd-cam-1v2: 1200 mV
[ 0.376826] vdd-fan: 5000 mV
[ 0.376933] vdd-3v3: 3300 mV
[ 0.377640] dis-vdd-1v2: 1200 mV
[ 0.377757] en-vdd-vcm-2v8: 2800 mV
[ 0.378272] vdd-usb2-5v: 5000 mV
[ 0.378387] vdd-sys-bl: 3300 mV
[ 0.378897] en-vdd-sys: 1200 mV
[ 0.382221] extcon-gpio-states external-connection:extcon@1: Cable state 1
[ 0.382641] clocksource: Switched to clocksource arch_sys_counter
[ 0.400952] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.401235] nvmap: nvmap_override_cache_ops() set roc flush ops to replace cache ops by set/ways
[ 0.401716] nvmap_page_pool_init: Total RAM pages: 2008327
[ 0.401734] nvmap_page_pool_init: nvmap page pool size: 251040 pages (980 MB)
[ 0.401944] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.406569] Wake76 for irq=199
[ 0.406583] Wake77 for irq=199
[ 0.406593] Wake78 for irq=199
[ 0.406603] Wake79 for irq=199
[ 0.406613] Wake80 for irq=199
[ 0.406623] Wake81 for irq=199
[ 0.406632] Wake82 for irq=199
[ 0.407389] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[ 0.407590] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 0.407981] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.408062] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.408205] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tboard_tegra
[ 0.408350] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[ 0.408499] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type PMIC-Die
[ 0.408790] isomgr_init(): iso emc max clk=1866000KHz
[ 0.408803] isomgr_init(): max_iso_bw=26870400KB
[ 0.408887] NET: Registered protocol family 2
[ 0.409183] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.409411] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.409710] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.409766] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.409822] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.409987] NET: Registered protocol family 1
[ 0.410200] RPC: Registered named UNIX socket transport module.
[ 0.410216] RPC: Registered udp transport module.
[ 0.410228] RPC: Registered tcp transport module.
[ 0.410240] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.410261] PCI: CLS 0 bytes, default 128
[ 0.410356] Trying to unpack rootfs image as initramfs…
[ 0.424197] host1x 13e10000.host1x: initialized
[ 0.425053] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.427457] futex hash table entries: 2048 (order: 6, 262144 bytes)
[ 0.427556] audit: initializing netlink subsys (disabled)
[ 0.427598] audit: type=2000 audit(0.416:1): initialized
[ 0.437077] io scheduler noop registered
[ 0.437273] io scheduler cfq registered (default)
[ 0.440981] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 0.442458] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 0.443822] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 0.445151] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 0.449863] tsec 15500000.tsec: initialized
[ 0.451260] tsec 15100000.tsecb: initialized
[ 0.454355] nvdec 15480000.nvdec: initialized
[ 0.459160] falcon 15340000.vic: initialized
[ 0.460446] falcon 154c0000.nvenc: initialized
[ 0.461665] falcon 15380000.nvjpg: initialized
[ 0.462890] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 0.463685] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 0.464484] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 0.465251] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 0.465991] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 0.466763] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 0.467488] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 0.468231] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 0.471788] DC OR NODE connected to /host1x/sor1
[ 0.471964] generic_infoframe_type: 0x87
[ 0.472095] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.472098] tegradc 15210000.nvdisplay: DT parsed successfully
[ 0.472130] tegradc 15210000.nvdisplay: Display dc.ffffff8002320000 registered with id=0
[ 0.472316] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 0.472348] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=1500000, max_bw=4687500
[ 0.480926] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 16727000 KB/s
[ 0.480947] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 665600000 Hz
[ 0.480964] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 357620000 Hz
[ 0.481011] tegradc 15210000.nvdisplay: vblank syncpt # 7 for dc 1
[ 0.481034] tegradc 15210000.nvdisplay: vpulse3 syncpt # 8 for dc 1
[ 0.481968] tegradc 15210000.nvdisplay: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350937
[ 0.482354] tegra-adma 2930000.adma: Tegra ADMA driver register 10 channels
[ 0.484076] tegradc 15210000.nvdisplay: hdmi: no prod_list_hdmi_board, use default range
[ 0.485026] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 0.485339] tegradc 15210000.nvdisplay: probed
[ 0.485467] kfuse 3830000.kfuse: initialized
[ 0.487473] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.488094] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.490859] console [ttyS0] disabled
[ 0.490961] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 37, base_baud = 25500000) is a Tegra
[ 2.618734] console [ttyS0] enabled
[ 2.620556] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 38, base_baud = 0) is a TEGRA_UART
[ 2.621566] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 39, base_baud = 0) is a TEGRA_UART
[ 2.621755] serial-tegra 3130000.serial: RX in PIO mode
[ 2.622630] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 40, base_baud = 0) is a TEGRA_UART
[ 2.632095] brd: module loaded
[ 2.633839] Console: switching to colour frame buffer device 240x67
[ 2.636249] loop: module loaded
[ 2.636487] nct1008_nct72 7-004c: find device tree node, parsing dt
[ 2.636491] nct1008_nct72 7-004c: starting parse dt
[ 2.636573] nct1008_nct72 7-004c: success parsing dt
[ 2.636694] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ 2.718647] tegradc 15210000.nvdisplay: fb registered
[ 2.718698] tmp451: Enabled overheat logging at 104.00C
[ 2.718818] nct1008_nct72 7-004c: nct1008_probe: initialized
[ 2.735071] PD DISP0 index2 UP
[ 2.736028] THERMAL EST: found 3 subdevs
[ 2.736031] THERMAL EST num_resources: 0
[ 2.736034] [THERMAL EST subdev 0]
[ 2.736038] [THERMAL EST subdev 1]
[ 2.736040] [THERMAL EST subdev 2]
[ 2.736157] gk20a 17000000.gp10b: failed to allocate secure buffer -12
[ 2.736287] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 2.736288] THERMAL EST: thz register success.
[ 2.736362] THERMAL EST: end of probe, return err: 0
[ 2.736404] tegra_profiler: Branch: Dev
[ 2.736406] tegra_profiler: Version: 1.117
[ 2.736407] tegra_profiler: Samples version: 41
[ 2.736408] tegra_profiler: IO version: 22
[ 2.736412] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.736414] armv8_pmu: [0] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.736416] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.736418] armv8_pmu: [1] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 0, pmu ver: 0x1
[ 2.736420] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.736422] armv8_pmu: [2] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 0, pmu ver: 0x1
[ 2.736424] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.736426] armv8_pmu: [3] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.736428] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.736429] armv8_pmu: [4] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.736431] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.736433] armv8_pmu: [5] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.736570] tegra_profiler: auth: init
[ 2.739215] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 2.739222] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 2.739871] scsi host0: tegra_ahci
[ 2.740104] scsi host1: tegra_ahci
[ 2.740219] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 25
[ 2.740221] ata2: DUMMY
[ 2.740969] spi-tegra114 3210000.spi: Static pin configuration used
[ 2.741324] spi-tegra114 c260000.spi: Static pin configuration used
[ 2.741637] spi-tegra114 3240000.spi: Static pin configuration used
[ 2.742228] tun: Universal TUN/TAP device driver, 1.6
[ 2.742230] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 2.742359] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 2.742360] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.742387] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.3.0-k
[ 2.742388] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.743165] PPP generic driver version 2.4.2
[ 2.743263] PPP BSD Compression module registered
[ 2.743268] PPP Deflate Compression module registered
[ 2.743283] PPP MPPE Compression module registered
[ 2.743293] NET: Registered protocol family 24
[ 2.743333] usbcore: registered new interface driver r8152
[ 2.743362] usbcore: registered new interface driver asix
[ 2.743388] usbcore: registered new interface driver ax88179_178a
[ 2.743409] usbcore: registered new interface driver cdc_ether
[ 2.743436] usbcore: registered new interface driver smsc75xx
[ 2.743459] usbcore: registered new interface driver net1080
[ 2.743481] usbcore: registered new interface driver cdc_subset
[ 2.743502] usbcore: registered new interface driver zaurus
[ 2.743540] usbcore: registered new interface driver cdc_ncm
[ 2.743723] Wake76 for irq=199
[ 2.743725] Wake77 for irq=199
[ 2.743726] Wake78 for irq=199
[ 2.743727] Wake79 for irq=199
[ 2.743728] Wake80 for irq=199
[ 2.743729] Wake81 for irq=199
[ 2.743729] Wake82 for irq=199
[ 2.743772] tegra-xotg xotg: usb2 phy is not available yet
[ 2.744185] usbcore: registered new interface driver cdc_acm
[ 2.744186] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 2.744215] usbcore: registered new interface driver usb-storage
[ 2.744261] usbcore: registered new interface driver usbserial
[ 2.744281] usbcore: registered new interface driver cp210x
[ 2.744298] usbserial: USB Serial support registered for cp210x
[ 2.744316] usbcore: registered new interface driver ftdi_sio
[ 2.744329] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 2.744347] usbcore: registered new interface driver option
[ 2.744360] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.744378] usbcore: registered new interface driver pl2303
[ 2.744391] usbserial: USB Serial support registered for pl2303
[ 2.744527] tegra-usb-cd usb_cd: otg phy is not available yet
[ 2.746376] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b c4 f3 12
[ 2.746824] libphy: dwc_phy: probed
[ 2.747279] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 2.811802] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 2.876390] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 2.878599] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 2.878623] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 2.878754] i2c /dev entries driver
[ 2.879491] [OV5693]: probing v4l2 sensor.
[ 3.058647] ata1: SATA link down (SStatus 0 SControl 300)
[ 3.322981] PD DISP1 index3 UP
[ 3.327657] PD DISP2 index4 UP
[ 3.341279] Parent Clock set for DC plld2
[ 3.347782] edid invalid
[ 3.385675] edid invalid
[ 3.389576] edid invalid
[ 3.393462] tegradc 15210000.nvdisplay: hdmi: pclk:148351K, set prod-setting:prod_c_150M
[ 3.550969] tegradc 15210000.nvdisplay: blank - normal
[ 3.552480] tegradc 15210000.nvdisplay: blank - powerdown
[ 3.611128] PD DISP2 index4 DOWN
[ 3.612261] PD DISP1 index3 DOWN
[ 3.612904] PD DISP0 index2 DOWN
[ 3.642595] tegradc 15210000.nvdisplay: unblank
[ 3.642752] PD DISP0 index2 UP
[ 3.649205] PD DISP1 index3 UP
[ 3.649744] PD DISP2 index4 UP
[ 3.664889] Parent Clock set for DC plld2
[ 3.667974] tegradc 15210000.nvdisplay: hdmi: pclk:148500K, set prod-setting:prod_c_150M
[ 3.750903] gspca_main: v2.14.0 registered
[ 3.750944] usbcore: registered new interface driver gspca_zc3xx
[ 3.751261] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 3.753186] FAN dev name: pwm-fan
[ 3.753234] FAN:gpio request success.
[ 3.753240] FAN: can’t find tach_gpio
[ 3.753261] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 3.753426] pwm_fan_driver pwm-fan: got pwm for fan
[ 3.753430] pwm_fan_driver pwm-fan: tach period: 1000
[ 3.753719] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 3.753722] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 3.753725] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 3.753728] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 3.753731] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 3.753734] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 3.753737] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 3.753740] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 3.753743] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 3.753746] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 3.754454] device-mapper: uevent: version 1.0.3
[ 3.754656] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 3.755009] sdhci: Secure Digital Host Controller Interface driver
[ 3.755011] sdhci: Copyright(c) Pierre Ossman
[ 3.755015] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.755308] sdhci-tegra 3460000.sdhci: Parent select= pll_p rate=408000000
[ 3.755593] sdhci-tegra 3460000.sdhci: Parent select= pll_c4_out0 rate=196249804
[ 3.755824] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 3.756938] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 3.757059] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.758654] usbcore: registered new interface driver usbhid
[ 3.758655] usbhid: USB HID core driver
[ 3.763533] nvadsp 2993000.adsp: in probe()…
[ 3.777780] nvadsp 2993000.adsp: Registering AMC Error Interrupt
[ 3.777807] nvadsp 2993000.adsp: AMC/ARAM initialized.
[ 3.778009] nvadsp 2993000.adsp: nvadsp_app_module_probe
[ 3.778740] Denver: backdoor interface is NOT available.
[ 3.780388] coresight-tmc 8030000.etf: TMC initialized
[ 3.781444] coresight-tmc 8050000.etr: TMC initialized
[ 3.781773] coresight-tpiu 8060000.tpiu: TPIU initialized
[ 3.782214] coresight-funnel 9010000.funnel_bccplex: FUNNEL initialized
[ 3.782616] coresight-funnel 8010000.funnel_major: FUNNEL initialized
[ 3.783031] coresight-funnel 8820000.funnel_minor: FUNNEL initialized
[ 3.783434] coresight-replicator 8040000.replicator: REPLICATOR initialized
[ 3.784018] coresight-etm4x 9840000.ptm: ETM 4.0 initialized
[ 3.784544] coresight-etm4x 9940000.ptm: ETM 4.0 initialized
[ 3.785080] coresight-etm4x 9a40000.ptm: ETM 4.0 initialized
[ 3.785627] coresight-etm4x 9b40000.ptm: ETM 4.0 initialized
[ 3.785654] Module initialized successfully
[ 3.788951] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xa0000000
[ 3.790251] tegra186-cam-rtcpu b000000.rtcpu: already unhalted
[ 3.790510] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xa0110000-0xa011957f size=38272
[ 3.790639] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.790904] sdhci-tegra 3440000.sdhci: Parent select= pll_p rate=408000000
[ 3.790952] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 3.791047] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x1900-0x3980 TX[64x128]=0x3980-0x5a00
[ 3.791090] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x5a00-0x5ac0 TX[1x64]=0x5ac0-0x5b80
[ 3.791129] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x5b80-0x7000 TX[16x320]=0x7000-0x8480
[ 3.791154] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 3.791222] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8480-0x8900 TX[16x64]=0x8900-0x8d80
[ 3.791260] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x8d80-0x8f80 TX[1x384]=0x8f80-0x9180
[ 3.791306] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x384]=0x9180-0x9380 TX[1x384]=0x9380-0x9580
[ 3.791478] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (52)
[ 3.791480] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[ 3.792524] tegra-ivc ivc-b000000.rtcpu:echo@0: ivc channel driver missing
[ 3.792526] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: ivc channel driver missing
[ 3.792529] tegra-ivc ivc-b000000.rtcpu:mods@32c0: ivc channel driver missing
[ 3.792531] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivc channel driver missing
[ 3.792533] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivc channel driver missing
[ 3.792535] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: ivc channel driver missing
[ 3.792538] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: ivc channel driver missing
[ 3.792563] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=4 sha1=a8b1ecdd9615cd817a56df035be363fce3b0b88f
[ 3.796577] tegra-ivc-cdev ivc-b000000.rtcpu:echo@0: probing /dev/camchar-echo
[ 3.797392] tegra-ivc-cdev ivc-b000000.rtcpu:dbg@7c00: probing /dev/camchar-dbg
[ 3.797493] camchar: rtcpu character device driver loaded
[ 3.801045] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 3.801278] register_ari_mca_banks: Registered MCA ROC:IOB
[ 3.801366] register_ari_mca_banks: Registered MCA ROC:CCE
[ 3.801699] tegra18-bridge 2390000.axi2apb: bridge probed OK
[ 3.801725] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[ 3.801748] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[ 3.801771] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[ 3.801796] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[ 3.801820] tegra18-bridge 2100000.axip2p: bridge probed OK
[ 3.801844] tegra18-bridge 2110000.axip2p: bridge probed OK
[ 3.801867] tegra18-bridge 2120000.axip2p: bridge probed OK
[ 3.801891] tegra18-bridge 2130000.axip2p: bridge probed OK
[ 3.801914] tegra18-bridge 2140000.axip2p: bridge probed OK
[ 3.801938] tegra18-bridge 2150000.axip2p: bridge probed OK
[ 3.801961] tegra18-bridge 2160000.axip2p: bridge probed OK
[ 3.801987] tegra18-bridge 2170000.axip2p: bridge probed OK
[ 3.802010] tegra18-bridge 2180000.axip2p: bridge probed OK
[ 3.802032] tegra18-bridge 2190000.axip2p: bridge probed OK
[ 3.802082] **** A57 ECC: Enabled
[ 3.802084] tegra18_a57_serr_init: on CPU 5 a A57 Core
[ 3.802219] parse_throttle_dt_data: Num cap clks = 4
[ 3.802223] parse_throttle_dt_data: clk=mcpu type=1
[ 3.802225] parse_throttle_dt_data: clk=bcpu type=2
[ 3.802230] parse_throttle_dt_data: clk=gpu type=4
[ 3.802232] parse_throttle_dt_data: clk=emc type=3
[ 3.802715] tegra_throttle_probe: probe successful. #cdevs=4
[ 3.802801] tegra18x_actmon d230000.actmon: in actmon_register()…
[ 3.805342] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 3.805638] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[ 3.807671] tegra-se-nvhost 15810000.se: initialized
[ 3.808099] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 3.808412] tegra-se-nvhost 15820000.se: initialized
[ 3.808878] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 3.809156] tegra-se-nvhost 15830000.se: initialized
[ 3.809267] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 3.809536] tegra-se-nvhost 15840000.se: initialized
[ 3.809920] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 3.813606] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 3.816794] cpufreq: platform driver Initialization: pass
[ 3.816930] tegra_cluster_clk e090000.cluster_clk_priv: in probe()…
[ 3.816987] tegra_cluster_clk e090000.cluster_clk_priv: passed
[ 3.817152] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 3.817156] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 3.817190] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x2ab496
[ 3.817193] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x8
[ 3.818315] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 3.818846] tegra186-padctl 3520000.pinctrl: VBUS over-current detection enabled
[ 3.819340] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 0 not supported
[ 3.819731] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 3 not supported
[ 3.821129] cpuidle: Initializing cpuidle driver init for Denver cluster
[ 3.821238] cpuidle: Initializing cpuidle driver init for A57 cluster
[ 3.822123] tachometer tegra-tachometer: Tachometer driver tegra-tachometer registered
[ 3.822127] Tachometer driver initialized with pulse_per_rev: 2 and win_len: 2
[ 3.824728] tegra210_adsp_audio_platform_probe: platform probe started
[ 3.825273] tegra210-adsp adsp_audio: Default param-type to BYTE for mp3-dec1
[ 3.825512] tegra210-adsp adsp_audio: Default param-type to BYTE for spkprot
[ 3.825813] tegra210-adsp adsp_audio: Default param-type to BYTE for src
[ 3.826078] tegra210-adsp adsp_audio: Default param-type to BYTE for aac-dec1
[ 3.826374] tegra210-adsp adsp_audio: Default param-type to BYTE for aec
[ 3.826377] tegra210-adsp adsp_audio: adma channel page address dt entry not found
[ 3.826378] tegra210-adsp adsp_audio: using adma channel page 0
[ 3.826629] tegra210_adsp_audio_platform_probe probe successfull.
[ 3.826629] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.828627] mmc0: MAN_BKOPS_EN bit is not set
[ 3.830802] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 3.830844] sdhci-tegra 3400000.sdhci: Got WP GPIO
[ 3.832430] random: nonblocking pool is initialized
[ 3.841072] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 3.841190] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 3.849488] sdhci-tegra 3400000.sdhci: Parent select= pll_p rate=408000000
[ 3.849518] sdhci-tegra 3400000.sdhci: wakeup init done, cd_irq: 256
[ 3.850323] mmc0: Skipping tuning since strobe enabled
[ 3.851770] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 3.858342] mmc0: periodic cache flush enabled
[ 3.858349] mmc0: new HS400 MMC card at address 0001
[ 3.858653] mmcblk0: mmc0:0001 032G34 29.1 GiB
[ 3.858825] mmcblk0boot0: mmc0:0001 032G34 partition 1 4.00 MiB
[ 3.858997] mmcblk0boot1: mmc0:0001 032G34 partition 2 4.00 MiB
[ 3.859152] mmcblk0rpmb: mmc0:0001 032G34 partition 3 4.00 MiB
[ 3.860397] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29
[ 3.862701] OPE platform probe
[ 3.862784] OPE platform probe successful
[ 3.894745] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.899050] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 3.927659] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF1 ↔ ADMAIF1 mapping ok
[ 3.927727] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF2 ↔ ADMAIF2 mapping ok
[ 3.927795] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF3 ↔ ADMAIF3 mapping ok
[ 3.927883] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF4 ↔ ADMAIF4 mapping ok
[ 3.927949] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF5 ↔ ADMAIF5 mapping ok
[ 3.928016] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF6 ↔ ADMAIF6 mapping ok
[ 3.928087] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF7 ↔ ADMAIF7 mapping ok
[ 3.928152] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF8 ↔ ADMAIF8 mapping ok
[ 3.928233] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF9 ↔ ADMAIF9 mapping ok
[ 3.928302] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF10 ↔ ADMAIF10 mapping ok
[ 3.928370] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF11 ↔ ADMAIF11 mapping ok
[ 3.928438] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF12 ↔ ADMAIF12 mapping ok
[ 3.928516] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF13 ↔ ADMAIF13 mapping ok
[ 3.928588] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF14 ↔ ADMAIF14 mapping ok
[ 3.928653] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF15 ↔ ADMAIF15 mapping ok
[ 3.928719] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF16 ↔ ADMAIF16 mapping ok
[ 3.928786] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF17 ↔ ADMAIF17 mapping ok
[ 3.928872] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF18 ↔ ADMAIF18 mapping ok
[ 3.928938] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF19 ↔ ADMAIF19 mapping ok
[ 3.929009] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF20 ↔ ADMAIF20 mapping ok
[ 3.932011] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE1 ↔ ADSP PCM1 mapping ok
[ 3.932080] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE2 ↔ ADSP PCM2 mapping ok
[ 3.932104] compress asoc: ADSP-FE3 ↔ ADSP COMPR1 mapping ok
[ 3.932124] compress asoc: ADSP-FE4 ↔ ADSP COMPR2 mapping ok
[ 3.974484] input: tegra-snd-t186ref-mobile-rt565x Headphone Jack as /devices/sound/sound/card1/input2
[ 3.974900] tegra-snd-t186ref-mobile-rt565x sound: codec-dai “dit-hifi” registered
[ 3.974902] tegra-snd-t186ref-mobile-rt565x sound: This is a dummy codec
[ 3.975463] GACT probability NOT on
[ 3.975470] Mirror/redirect action on
[ 3.975477] u32 classifier
[ 3.975478] Actions configured
[ 3.975488] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[ 3.975836] IPVS: Registered protocols ()
[ 3.975856] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
[ 3.975900] IPVS: Creating netns size=1424 id=0
[ 3.975915] IPVS: ipvs loaded.
[ 3.975919] IPVS: [rr] scheduler registered.
[ 3.975970] ipip: IPv4 over IPv4 tunneling driver
[ 3.976218] Initializing XFRM netlink socket
[ 3.976450] NET: Registered protocol family 10
[ 3.976856] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 3.976897] NET: Registered protocol family 17
[ 3.976907] NET: Registered protocol family 15
[ 3.976923] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 3.976928] 8021q: 802.1Q VLAN Support v1.8
[ 3.977189] Registered cp15_barrier emulation handler
[ 3.977200] Registered setend emulation handler
[ 3.978416] registered taskstats version 1
[ 3.991645] isp 15600000.isp: initialized
[ 4.016078] nvcsi 150c0000.nvcsi: initialized
[ 4.016855] Wake76 for irq=199
[ 4.016856] Wake77 for irq=199
[ 4.016857] Wake78 for irq=199
[ 4.016858] Wake79 for irq=199
[ 4.016858] Wake80 for irq=199
[ 4.016859] Wake81 for irq=199
[ 4.016860] Wake82 for irq=199
[ 4.017145] xhci-tegra 3530000.xhci: UTMI port 0 has OTG_CAP
[ 4.017147] xhci-tegra 3530000.xhci: No USB3 port has OTG_CAP
[ 4.042864] spi-tegra114 3210000.spi: Static pin configuration used
[ 4.043006] xhci-tegra 3530000.xhci: Direct firmware load for tegra18x_xusb_firmware failed with error -2
[ 4.043008] xhci-tegra 3530000.xhci: Falling back to user helper
[ 4.045456] spi-tegra114 c260000.spi: Static pin configuration used
[ 4.050764] spi-tegra114 3240000.spi: Static pin configuration used
[ 4.053020] tegra-xotg xotg: OTG rev:0200, ADP:0, SRP:1, HNP:1, RSP:0
[ 4.053051] tegra-xotg xotg: update_id_state: ID floating
[ 4.053056] tegra-xotg xotg: update_vbus_state: VBUS detected
[ 4.053068] tegra-xotg xotg: Nvidia XUSB OTG Controller
[ 4.056188] tegra-xotg xotg: otg: gadget gadget registered
[ 4.056190] tegra-xotg xotg: set gadget otg_caps from OTG controller
[ 4.056192] tegra-xotg xotg: otg: host not registered yet
[ 4.056193] tegra-xotg xotg: otg: start OTG finite state machine
[ 4.056234] tegra-xudc-new 3550000.xudc: entering ELPG
[ 4.057314] input: gpio-keys as /devices/gpio-keys/input/input3
[ 4.057694] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 4.092539] tegra_rtc c2a0000.rtc: setting system clock to 2018-11-20 09:59:18 UTC (1542707958)
[ 4.097641] mmc1 tuning done saved tap delay=20
[ 4.097643] mmc1: hw tuning done …
[ 4.097650] mmc1: tuning_window[0]: 0xffffffff
[ 4.097655] mmc1: tuning_window[1]: 0xffffe3ff
[ 4.097660] mmc1: tuning_window[2]: 0xfc7fffff
[ 4.097664] mmc1: tuning_window[3]: 0x7fffffff
[ 4.097669] mmc1: tuning_window[4]: 0x0
[ 4.097673] mmc1: tuning_window[5]: 0x0
[ 4.097697] mmc1: tuning_window[6]: 0x0
[ 4.097701] mmc1: tuning_window[7]: 0x0
[ 4.097704] sdhci: Tap value: 20 | Trim value: 5
[ 4.097708] sdhci: SDMMC_VENDOR_INTR_STATUS[0x108]: 0x40000
[ 4.103195] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 4.103236] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 4.122297] bpmp: mounted debugfs mirror
[ 4.122844] [dram-timers] DRAM derating cdev registered.
[ 4.127006] spmic-ldo0: disabling
[ 4.127171] spmic-ldo1: disabling
[ 4.127308] en-vdd-sd: disabling
[ 4.127310] en-vdd-cam: disabling
[ 4.127312] vdd-usb0-5v: disabling
[ 4.127313] vdd-usb1-5v: disabling
[ 4.127316] en-vdd-disp-3v3: disabling
[ 4.127317] en-mdm-pwr-3v7: disabling
[ 4.127319] en-vdd-disp-1v8: disabling
[ 4.127320] en-vdd-cam-hv-2v8: disabling
[ 4.127321] en-vdd-cam-1v2: disabling
[ 4.127323] vdd-fan: disabling
[ 4.127324] vdd-3v3: disabling
[ 4.127326] en-vdd-vcm-2v8: disabling
[ 4.127327] vdd-usb2-5v: disabling
[ 4.127329] vdd-sys-bl: disabling
[ 4.127330] en-vdd-sys: disabling
[ 4.130668] tegra-usb-cd usb_cd: notification status (0x0, 0x1)
[ 4.130670] tegra-usb-cd usb_cd: set current 0ma
[ 4.130677] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 4.133595] ALSA device list:
[ 4.133597] #0: tegra-hda at 0x3518000 irq 400
[ 4.133599] #1: tegra-snd-t186ref-mobile-rt565x
[ 4.133946] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 4.133950] tegra-xudc-new 3550000.xudc: device mode on
[ 4.152489] tegra-vi4 15700000.vi: initialized
[ 4.153694] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi-2 bound
[ 4.153697] tegra-vi4 15700000.vi: subdev ov5693 2-0036 bound
[ 6.688847] tegradc 15210000.nvdisplay: hdmi: plugged
[ 6.693533] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 6.693546] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 6.694101] devtmpfs: mounted
[ 6.694392] Freeing unused kernel memory: 1168K (ffffffc001132000 - ffffffc001256000)
[ 6.694415] Freeing alternatives memory: 96K (ffffffc001256000 - ffffffc00126e000)
[ 6.698770] btb inv war enabled
[ 6.752533] systemd[1]: Configuration file /etc/systemd/system.conf is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 6.767685] systemd[1]: Configuration file /etc/systemd/system.conf is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 6.786293] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[ 6.806435] systemd[1]: Detected architecture arm64.
[ 6.821581] systemd[1]: Set hostname to .
[ 6.851340] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/lvm2-lvmpolld.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 6.870447] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/lvm2-lvmpolld.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 6.891541] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/plymouth-read-write.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 6.910435] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/plymouth-read-write.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 6.931888] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/rsync.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 6.949190] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/rsync.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 6.968689] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/dns-clean.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 6.986136] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/dns-clean.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.007211] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/brltty.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.024428] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/brltty.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.044017] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/plymouth-quit.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.061895] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/plymouth-quit.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.082048] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/gpsd.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.099211] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/gpsd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.118786] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/anacron.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.136340] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/anacron.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.156158] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/ssh.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.173368] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/ssh.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.192884] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/pppd-dns.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.210552] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/pppd-dns.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.230756] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/systemd-modules-load.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.249534] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/systemd-modules-load.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.270289] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/NetworkManager.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.288621] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/NetworkManager.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.309241] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/bluetooth.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.327142] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/bluetooth.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.347366] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/console-setup.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.365669] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/console-setup.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.390422] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/dnsmasq.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.408273] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/dnsmasq.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.428493] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/systemd-sysctl.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.447025] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/systemd-sysctl.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.467981] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/lvm2-lvmetad.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.486405] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/lvm2-lvmetad.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.507300] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/whoopsie.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.525559] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/whoopsie.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.546273] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/cron.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.564119] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/cron.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.584535] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/systemd-udevd.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.603234] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/systemd-udevd.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.624317] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/avahi-daemon.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.642959] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/avahi-daemon.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.666144] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/cups-browsed.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.684830] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/cups-browsed.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.705791] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/unattended-upgrades.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.725116] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/unattended-upgrades.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.746815] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/dbus.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.764890] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/dbus.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.790926] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/rsyslog.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.809336] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/rsyslog.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.830158] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/kerneloops.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.848901] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/kerneloops.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.869890] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/rpcbind.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.888354] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/rpcbind.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.909351] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/ubuntu-fan.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.928128] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/ubuntu-fan.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.949215] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/cups.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.967439] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/cups.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 7.988013] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/systemd-random-seed.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.007572] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/systemd-random-seed.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.029530] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/docker.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.047934] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/docker.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.068151] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/networking.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.086872] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/networking.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.108094] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/rc-local.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.126700] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/rc-local.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.147619] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/lightdm.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.166125] systemd-sysv-generator[262]: Configuration file /lib/systemd/system/lightdm.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.200463] systemd-sysv-generator[262]: Overwriting existing symlink /run/systemd/generator.late/skeleton.service with real service.
[ 8.218719] systemd[1]: Configuration file /lib/systemd/system/local-fs.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.237193] systemd[1]: Configuration file /lib/systemd/system/local-fs.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.258476] systemd[1]: Configuration file /lib/systemd/system/systemd-remount-fs.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.278041] systemd[1]: Configuration file /lib/systemd/system/systemd-remount-fs.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.299759] systemd[1]: Configuration file /lib/systemd/system/system.slice is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.318085] systemd[1]: Configuration file /lib/systemd/system/system.slice is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.338965] systemd[1]: Configuration file /lib/systemd/system/-.slice is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.355446] systemd[1]: Configuration file /lib/systemd/system/-.slice is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.374151] systemd[1]: Configuration file /lib/systemd/system/slices.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.391045] systemd[1]: Configuration file /lib/systemd/system/slices.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.410323] systemd[1]: Configuration file /lib/systemd/system/systemd-journald.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.428085] systemd[1]: Configuration file /lib/systemd/system/systemd-journald.socket is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.451033] systemd[1]: Configuration file /lib/systemd/system/systemd-journald.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.468914] systemd[1]: Configuration file /lib/systemd/system/systemd-journald.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.489429] systemd[1]: Configuration file /lib/systemd/system/sysinit.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.506416] systemd[1]: Configuration file /lib/systemd/system/sysinit.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.527798] systemd[1]: Configuration file /lib/systemd/system/systemd-machine-id-commit.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.546502] systemd[1]: Configuration file /lib/systemd/system/systemd-machine-id-commit.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.567640] systemd[1]: Configuration file /lib/systemd/system/systemd-sysctl.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.585315] systemd[1]: Configuration file /lib/systemd/system/systemd-sysctl.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.604210] systemd[1]: Configuration file /lib/systemd/system/sys-kernel-debug.mount is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.621880] systemd[1]: Configuration file /lib/systemd/system/sys-kernel-debug.mount is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.642014] systemd[1]: Configuration file /lib/systemd/system/systemd-ask-password-console.path is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.660627] systemd[1]: Configuration file /lib/systemd/system/systemd-ask-password-console.path is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.681649] systemd[1]: Configuration file /lib/systemd/system/systemd-ask-password-console.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.700529] systemd[1]: Configuration file /lib/systemd/system/systemd-ask-password-console.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.725697] systemd[1]: Configuration file /lib/systemd/system/paths.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.742456] systemd[1]: Configuration file /lib/systemd/system/paths.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.761527] systemd[1]: Configuration file /lib/systemd/system/systemd-modules-load.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.779710] systemd[1]: Configuration file /lib/systemd/system/systemd-modules-load.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.799134] systemd[1]: Configuration file /lib/systemd/system/systemd-hwdb-update.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.817295] systemd[1]: Configuration file /lib/systemd/system/systemd-hwdb-update.service is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 8.837878] systemd[1]: Configuration file /lib/systemd/system/systemd-random-seed.service is marked executable. Please remove executable permission bits. Proceeding anyway.
Following is my host file system types :
Filesystem Type 1K-blocks Used Available Use% Mounted on
udev devtmpfs 8136100 0 8136100 0% /dev
tmpfs tmpfs 1634004 9824 1624180 1% /run
/dev/sda7 ext4 106126432 97631612 3080832 97% /
tmpfs tmpfs 8170020 110008 8060012 2% /dev/shm
tmpfs tmpfs 5120 4 5116 1% /run/lock
tmpfs tmpfs 8170020 0 8170020 0% /sys/fs/cgroup
/dev/sda2 vfat 364544 88360 276184 25% /boot/efi
tmpfs tmpfs 1634004 80 1633924 1% /run/user/1000
/dev/sda8 fuseblk 479979516 173769284 306210232 37% /media/myntra/Data
/dev/sda4 fuseblk 370258676 124211464 246047212 34% /media/myntra/Windows
/media/myntra/Data is where my 3.3 Jetpack is
filesystem in my target
nvidia@tegra-ubuntu:~$ df -hT
Filesystem Type Size Used Avail Use% Mounted on
/dev/root ext4 28G 14G 13G 54% /
devtmpfs devtmpfs 7.6G 0 7.6G 0% /dev
tmpfs tmpfs 7.7G 8.0K 7.7G 1% /dev/shm
tmpfs tmpfs 7.7G 62M 7.7G 1% /run
tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs tmpfs 7.7G 0 7.7G 0% /sys/fs/cgroup
tmpfs tmpfs 785M 32K 785M 1% /run/user/106
tmpfs tmpfs 785M 0 785M 0% /run/user/1001
I took clue from this thread https://devtalk.nvidia.com/default/topic/1021542/jetson-tx2/jetson-tx2-failed-to-flash-on-jetpack-3-1/2 and
moved my Jetpack 3.3 installer to /dev/sda7 in the above message and i saw my Keyboard connected to USB responding in my JetsonTx2 :)
nvidia@tegra-ubuntu:~$ dmesg
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.38-tegra (buildbrain@mobile-u64-773) (gcc version 4.8.5 (GCC) ) #1 SMP PREEMPT Thu May 17 00:15:19 PDT 2018
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] earlycon: Early serial console at MMIO32 0x3100000 (options ‘’)
[ 0.000000] bootconsole [uart0] enabled
[ 0.000000] Found tegra_fbmem2: 00800000@969ee000
[ 0.000000] Found lut_mem2: 00002008@969eb000
[ 0.000000] Reserved memory: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[ 0.000000] On node 0 totalpages: 2052096
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 519680 pages, LIFO batch:31
[ 0.000000] Normal zone: 23968 pages used for memmap
[ 0.000000] Normal zone: 1532416 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] PERCPU: Embedded 17 pages/cpu @ffffffc1f5f9a000 s31360 r8192 d30080 u69632
[ 0.000000] pcpu-alloc: s31360 r8192 d30080 u69632 alloc=174096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2019936
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x03100000 nvdumper_reserved=0x2772e0000 gpt tegra_fbmem2=0x800000@0x969ee000 lut_mem2=0x2008@0x969eb000 tegraid=18.1.2.0.0 tegra_keep_boot_clocks maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2.1 androidboot.serialno=0422618030385 bl_prof_dataptr=0x10000@0x277040000 sdhci_tegra.en_boot_part_access=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7967772K/8208384K available (11296K kernel code, 1841K rwdata, 5796K rodata, 1168K init, 691K bss, 175076K reserved, 65536K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vmalloc : 0xffffff8000000000 - 0xffffffbdbfff0000 ( 246 GB)
vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum)
0xffffffbdc2000000 - 0xffffffbdc9da0000 ( 125 MB actual)
fixed : 0xffffffbffa7fd000 - 0xffffffbffac00000 ( 4108 KB)
PCI I/O : 0xffffffbffae00000 - 0xffffffbffbe00000 ( 16 MB)
modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB)
memory : 0xffffffc000000000 - 0xffffffc1f6800000 ( 8040 MB)
.init : 0xffffffc001132000 - 0xffffffc001256000 ( 1168 KB)
.text : 0xffffffc000080000 - 0xffffffc001132000 ( 17096 KB)
.data : 0xffffffc001278000 - 0xffffffc001444730 ( 1842 KB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.009796] Console: colour dummy device 80x25
[ 0.014455] console [tty0] enabled
[ 0.018013] bootconsole [uart0] disabled
[ 0.022116] kmemleak: Kernel memory leak detector disabled
[ 0.022128] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.022140] pid_max: default: 32768 minimum: 301
[ 0.022189] Security Framework initialized
[ 0.022228] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.022239] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.022618] Initializing cgroup subsys io
[ 0.022631] Initializing cgroup subsys memory
[ 0.022648] Initializing cgroup subsys devices
[ 0.022657] Initializing cgroup subsys freezer
[ 0.022666] Initializing cgroup subsys net_cls
[ 0.022676] Initializing cgroup subsys perf_event
[ 0.022685] Initializing cgroup subsys net_prio
[ 0.022696] Initializing cgroup subsys pids
[ 0.022704] Initializing cgroup subsys debug
[ 0.022842] CPU0 ipc=752
[ 0.022852] CPU1 ipc=1024
[ 0.022860] CPU2 ipc=1024
[ 0.022869] CPU3 ipc=752
[ 0.022878] CPU4 ipc=752
[ 0.022887] CPU5 ipc=752
[ 0.022924] ASID allocator initialised with 65536 entries
[ 0.046065] tegra-id: chipid=21817.
[ 0.046082] tegra-id: opt_subrevision=1.
[ 0.046095] Tegra Revision: A02p SKU: 0xdc CPU Process: 0 SoC Process: 0
[ 0.046736] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.4/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.046763] DTB Build time: May 17 2018 00:17:47
[ 0.062542] CPU1: Booted secondary processor [4e0f0030]
[ 0.074057] CPU2: Booted secondary processor [4e0f0030]
[ 0.085764] CPU3: Booted secondary processor [411fd073]
[ 0.097776] CPU4: Booted secondary processor [411fd073]
[ 0.109787] CPU5: Booted secondary processor [411fd073]
[ 0.109851] Brought up 6 CPUs
[ 0.109907] SMP: Total of 6 processors activated.
[ 0.109919] CPU: All CPU(s) started at EL2
[ 0.110345] devtmpfs: initialized
[ 0.137334] Initilizing CustomIPI irq domain
[ 0.137529] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.138276] pinctrl core: initialized pinctrl subsystem
[ 0.138455] OS set in device tree is not L4T.
[ 0.138647] regulator-dummy: no parameters
[ 0.138750] Initializing plugin-manager
[ 0.138801] Plugin module not found
[ 0.139204] node /plugin-manager/soc-prod-a02-fragment match with chip-id A02P
[ 0.139533] node /plugin-manager/fragement@0 match with odm-data enable-denver-wdt
[ 0.140128] node /plugin-manager/fragement@4 match with odm-data enable-denver-wdt
[ 0.141263] node /plugin-manager/fragment-sdwake-p3310-1000-300 match with board >=3310-1000-300
[ 0.141635] node /plugin-manager/fragement-pmon-p3310-1000-300 match with board >=3310-1000-300
[ 0.141883] node /plugin-manager/fragement-pmon-p3310-1000-800 match with board >=3310-1000-800
[ 0.142099] node /plugin-manager/fragment-devslp@0 match with board >=3310-1000-200
[ 0.142514] node /plugin-manager/fragment-500-pcie-config match with board >=3310-1000-500
[ 0.142948] node /plugin-manager/fragment-500-xusb-config match with board >=3310-1000-500
[ 0.143219] node /plugin-manager/fragment-500-e3325-pcie match with board >=3310-1000-500
[ 0.143591] node /plugin-manager/fragment-p3310-c00-comm match with board >=3310-1000-800
[ 0.143832] node /plugin-manager/fragment-p3310-c00-pmic match with board >=3310-1000-800
[ 0.144047] node /plugin-manager/fragment-p3310-c01 match with board >=3310-1000-900
[ 0.144303] node /plugin-manager/fragment-p3310-c03 match with board >=3310-1000-B00
[ 0.145844] node /plugin-manager/fragment-e3326@0 match with board 3326-
[ 0.146903] node /plugin-manager/fragment-p3310-c00-camera match with board >=3310-1000-800
[ 0.148641] Adding domain adsp-pd to PM domain ape-pd
[ 0.150898] NET: Registered protocol family 16
[ 0.151748] console [pstore-1] enabled
[ 0.151760] pstore: Registered ramoops as persistent store backend
[ 0.151772] ramoops: attached 0x200000@0x277080000, ecc: 0/0
[ 0.161323] cpuidle: using governor ladder
[ 0.165764] cpuidle: using governor menu
[ 0.166926] bpmp: waiting for handshake
[ 0.166942] bpmp: handshake completed
[ 0.166983] bpmp: synchronizing channels
[ 0.167010] bpmp: channels synchronized
[ 0.167022] bpmp: mail init ok
[ 0.167404] vdso: 2 pages (1 code @ ffffffc00127d000, 1 data @ ffffffc00127c000)
[ 0.167438] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.168400] atomic_pool_init():526: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.169858] tegra_powergate_init: DONE
[ 0.169879] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.4/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.169905] DTB Build time: May 17 2018 00:17:47
[ 0.170837] Tegra reboot handler registered.
[ 0.171875] Registering Tegra186 clocks (this may take a while)…done
[ 0.173983] arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.174001] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.174014] arm-smmu 12000000.iommu: stage 1 translation
[ 0.174027] arm-smmu 12000000.iommu: stage 2 translation
[ 0.174039] arm-smmu 12000000.iommu: nested translation
[ 0.174054] arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.174073] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.174092] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.174106] arm-smmu 12000000.iommu: Stage-1: 39-bit VA → 48-bit IPA
[ 0.174119] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA → 48-bit PA
[ 0.221792] arm-smmu 12000000.iommu: registered 67 master devices
[ 0.227520] iommu: Adding device 3460000.sdhci to group 0
[ 0.228581] iommu: Adding device 3400000.sdhci to group 1
[ 0.232428] iommu: Adding device 3507000.ahci-sata to group 2
[ 0.232882] iommu: Adding device 3160000.i2c to group 3
[ 0.233309] iommu: Adding device c240000.i2c to group 4
[ 0.233658] iommu: Adding device 3180000.i2c to group 5
[ 0.234021] iommu: Adding device 3190000.i2c to group 6
[ 0.234477] iommu: Adding device 31b0000.i2c to group 7
[ 0.234871] iommu: Adding device 31c0000.i2c to group 8
[ 0.235217] iommu: Adding device c250000.i2c to group 9
[ 0.235547] iommu: Adding device 31e0000.i2c to group 10
[ 0.237411] iommu: Adding device 3210000.spi to group 11
[ 0.237742] iommu: Adding device c260000.spi to group 12
[ 0.238053] iommu: Adding device 3240000.spi to group 13
[ 0.238885] iommu: Adding device 3100000.serial to group 14
[ 0.239197] iommu: Adding device 3110000.serial to group 15
[ 0.239529] iommu: Adding device c280000.serial to group 16
[ 0.239865] iommu: Adding device 3130000.serial to group 17
[ 0.241172] iommu: Adding device 2490000.ether_qos to group 18
[ 0.241859] iommu: Adding device b000000.rtcpu to group 19
[ 0.242345] iommu: Adding device c1a0000.aon to group 20
[ 0.243244] Wake73 for irq=42
[ 0.243586] iommu: Adding device smmu_test to group 21
[ 0.244119] mc: mapped MMIO address: 0xffffff8000560000 → 0x2c10000
[ 0.244162] mc: mapped MMIO address: 0xffffff8000640000 → 0x2c20000
[ 0.244201] mc: mapped MMIO address: 0xffffff8000660000 → 0x2c30000
[ 0.244238] mc: mapped MMIO address: 0xffffff8000fa0000 → 0x2c40000
[ 0.244275] mc: mapped MMIO address: 0xffffff8000fc0000 → 0x2c50000
[ 0.244320] mc-err: Set intmask: 0xf3140
[ 0.244549] ecc-err: dram ecc disabled-MC_ECC_CONTROL:0x0000000c
[ 0.245373] Wake76 for irq=199
[ 0.245398] Wake77 for irq=199
[ 0.245420] Wake78 for irq=199
[ 0.245442] Wake79 for irq=199
[ 0.245463] Wake80 for irq=199
[ 0.245483] Wake81 for irq=199
[ 0.245505] Wake82 for irq=199
[ 0.245700] iommu: Adding device 3530000.xhci to group 22
[ 0.246062] iommu: Adding device 3550000.xudc to group 23
[ 0.246891] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.246924] tegra-pmc: ### PMC reset source: Power on reset
[ 0.246950] tegra-pmc: ### PMC reset level: L0
[ 0.246973] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.247275] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.247329] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.247512] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.247544] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 320
[ 0.248046] iommu: Adding device 13e10000.host1x to group 24
[ 0.248340] iommu: Adding device 13e10000.host1x:ctx0 to group 25
[ 0.248583] iommu: Adding device 13e10000.host1x:ctx1 to group 26
[ 0.248844] iommu: Adding device 13e10000.host1x:ctx2 to group 27
[ 0.249137] iommu: Adding device 13e10000.host1x:ctx3 to group 28
[ 0.249395] iommu: Adding device 13e10000.host1x:ctx4 to group 29
[ 0.249637] iommu: Adding device 13e10000.host1x:ctx5 to group 30
[ 0.249928] iommu: Adding device 13e10000.host1x:ctx6 to group 31
[ 0.250169] iommu: Adding device 13e10000.host1x:ctx7 to group 32
[ 0.250658] iommu: Adding device 150c0000.nvcsi to group 33
[ 0.251192] iommu: Adding device 15700000.vi to group 34
[ 0.251546] iommu: Adding device 15600000.isp to group 35
[ 0.251931] iommu: Adding device 15210000.nvdisplay to group 36
[ 0.252131] platform 15210000.nvdisplay: IOVA linear map 0x00000000969ee000(800000)
[ 0.252174] platform 15210000.nvdisplay: IOVA linear map 0x00000000969eb000(3000)
[ 0.252364] iommu: Adding device 15340000.vic to group 37
[ 0.252569] iommu: Adding device 154c0000.nvenc to group 38
[ 0.252791] iommu: Adding device 15480000.nvdec to group 39
[ 0.253139] iommu: Adding device 15380000.nvjpg to group 40
[ 0.253338] iommu: Adding device 15500000.tsec to group 41
[ 0.253527] iommu: Adding device 15100000.tsecb to group 42
[ 0.254247] iommu: Adding device 15810000.se to group 43
[ 0.254457] iommu: Adding device 15820000.se to group 44
[ 0.254716] iommu: Adding device 15830000.se to group 45
[ 0.254917] iommu: Adding device 15840000.se to group 46
[ 0.255441] iommu: Adding device 17000000.gp10b to group 47
[ 0.256829] tegra-reset 5000000.clock: registered 193 resets.
[ 0.259263] iommu: Adding device d000000.bpmp to group 48
[ 0.259490] bpmp: ping status is 0
[ 0.259704] bpmp d000000.bpmp: firmware tag is 83385b61e34297b2f37e76e0cd1ff81e
[ 0.260067] bpmp d000000.bpmp: probe ok
[ 0.262929] iommu: Adding device 2600000.dma to group 49
[ 0.263724] GPIO line 461 (cam0-rst) hogged as output/low
[ 0.263807] GPIO line 456 (cam0-pwdn) hogged as output/low
[ 0.263866] GPIO line 457 (cam1-rst) hogged as output/low
[ 0.263952] GPIO line 426 (cam1-pwdn) hogged as output/low
[ 0.264010] GPIO line 424 (wifi-enable) hogged as output/high
[ 0.264066] GPIO line 445 (sdmmc-wake-input) hogged as input
[ 0.264122] GPIO line 446 (sdmmc-wake-output) hogged as output/low
[ 0.264258] gpiochip_add_data: registered GPIOs 320 to 511 on device: tegra-gpio
[ 0.266130] GPIO line 315 (wifi-wake-ap) hogged as input
[ 0.266248] gpiochip_add_data: registered GPIOs 256 to 319 on device: tegra-gpio-aon
[ 0.267191] iommu: Adding device 10003000.pcie-controller to group 50
[ 0.267459] iommu: Adding device sound to group 51
[ 0.269158] iommu: Adding device 3510000.hda to group 52
[ 0.270354] iommu: Adding device adsp_audio to group 53
[ 0.271856] iommu: Adding device 2993000.adsp to group 54
[ 0.281142] vdd-ac-bat: 5000 mV
[ 0.283727] vdd-1v8-ap: 1800 mV
[ 0.300591] SCSI subsystem initialized
[ 0.300786] libata version 3.00 loaded.
[ 0.300964] usbcore: registered new interface driver usbfs
[ 0.301030] usbcore: registered new interface driver hub
[ 0.301145] usbcore: registered new device driver usb
[ 0.304950] GPIO line 241 (touch-rail-1) hogged as output/high
[ 0.305408] GPIO line 242 (touch-rail-2) hogged as output/high
[ 0.305521] gpiochip_add_data: registered GPIOs 240 to 255 on device: tca9539
[ 0.306956] GPIO line 228 (lcd-bias-en-rail) hogged as output/high
[ 0.307071] gpiochip_add_data: registered GPIOs 224 to 239 on device: tca9539
[ 0.317899] media: Linux media interface: v0.10
[ 0.318003] Linux video capture interface: v2.00
[ 0.321182] pps_core: LinuxPPS API ver. 1 registered
[ 0.321223] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.321287] PTP clock support registered
[ 0.322352] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.322404] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.323913] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[ 0.325989] GPIO line 221 (spmic_gpio_input_5) hogged as input
[ 0.326173] GPIO line 222 (spmic_gpio_input_6) hogged as input
[ 0.326276] gpiochip_add_data: registered GPIOs 216 to 223 on device: max77620-gpio
[ 0.330709] vddio-ddr: at 1125 mV
[ 0.334553] avdd_dsi_csi: 1200 mV
[ 0.338552] vdd-1v8: 1800 mV
[ 0.342551] vdd-3v3-sys: 3300 mV
[ 0.343650] spmic-ldo0: at 1800 mV
[ 0.344469] spmic-ldo1: at 800 mV
[ 0.350549] vddio-3v3: 3300 mV
[ 0.351234] vddio-sdmmc1: 1800 <–> 3300 mV at 3300 mV
[ 0.354555] vdd-rtc: at 800 mV
[ 0.355356] avdd-ts-hv: 1800 <–> 3300 mV at 1800 mV
[ 0.358555] spmic-ldo6: at 1500 mV
[ 0.361781] vdd-pex-1v05: 1000 mV
[ 0.362362] dvdd-pex: 1000 mV
[ 0.362627] max77620 4-003c: max77620 probe successful
[ 0.362877] Advanced Linux Sound Architecture Driver Initialized.
[ 0.363846] en-vdd-sd: 3300 mV
[ 0.364484] en-vdd-cam: 1800 mV
[ 0.365789] vdd-hdmi: 5000 mV
[ 0.365964] vdd-usb0-5v: 5000 mV
[ 0.366132] vdd-usb1-5v: 5000 mV
[ 0.369792] en-vdd-ts-1v8: 1800 mV
[ 0.373790] en-vdd-ts-hv-3v3: 3300 mV
[ 0.374299] en-vdd-disp-3v3: 3300 mV
[ 0.374806] en-mdm-pwr-3v7: 3700 mV
[ 0.375317] en-vdd-disp-1v8: 1800 mV
[ 0.375838] en-vdd-cam-hv-2v8: 2800 mV
[ 0.376358] en-vdd-cam-1v2: 1200 mV
[ 0.376886] vdd-fan: 5000 mV
[ 0.376996] vdd-3v3: 3300 mV
[ 0.377713] dis-vdd-1v2: 1200 mV
[ 0.377835] en-vdd-vcm-2v8: 2800 mV
[ 0.378349] vdd-usb2-5v: 5000 mV
[ 0.378467] vdd-sys-bl: 3300 mV
[ 0.378977] en-vdd-sys: 1200 mV
[ 0.382200] extcon-gpio-states external-connection:extcon@1: Cable state 1
[ 0.382603] clocksource: Switched to clocksource arch_sys_counter
[ 0.400771] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.401034] nvmap: nvmap_override_cache_ops() set roc flush ops to replace cache ops by set/ways
[ 0.401503] nvmap_page_pool_init: Total RAM pages: 2008327
[ 0.401520] nvmap_page_pool_init: nvmap page pool size: 251040 pages (980 MB)
[ 0.401691] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.406146] Wake76 for irq=199
[ 0.406160] Wake77 for irq=199
[ 0.406171] Wake78 for irq=199
[ 0.406181] Wake79 for irq=199
[ 0.406191] Wake80 for irq=199
[ 0.406200] Wake81 for irq=199
[ 0.406210] Wake82 for irq=199
[ 0.406956] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[ 0.407154] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 0.407553] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.407635] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.407783] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tboard_tegra
[ 0.407930] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[ 0.408081] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type PMIC-Die
[ 0.408375] isomgr_init(): iso emc max clk=1866000KHz
[ 0.408388] isomgr_init(): max_iso_bw=26870400KB
[ 0.408476] NET: Registered protocol family 2
[ 0.408786] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.409022] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.409324] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.409382] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.409440] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.409614] NET: Registered protocol family 1
[ 0.409829] RPC: Registered named UNIX socket transport module.
[ 0.409845] RPC: Registered udp transport module.
[ 0.409857] RPC: Registered tcp transport module.
[ 0.409869] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.409890] PCI: CLS 0 bytes, default 128
[ 0.409989] Trying to unpack rootfs image as initramfs…
[ 0.423599] host1x 13e10000.host1x: initialized
[ 0.424435] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.426137] futex hash table entries: 2048 (order: 6, 262144 bytes)
[ 0.426233] audit: initializing netlink subsys (disabled)
[ 0.426264] audit: type=2000 audit(0.412:1): initialized
[ 0.433189] io scheduler noop registered
[ 0.433295] io scheduler cfq registered (default)
[ 0.436246] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 0.437433] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 0.438501] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 0.439573] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 0.442964] tsec 15500000.tsec: initialized
[ 0.444065] tsec 15100000.tsecb: initialized
[ 0.446331] nvdec 15480000.nvdec: initialized
[ 0.449898] falcon 15340000.vic: initialized
[ 0.450897] falcon 154c0000.nvenc: initialized
[ 0.451878] falcon 15380000.nvjpg: initialized
[ 0.452623] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 0.453120] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 0.453614] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 0.454112] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 0.454621] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 0.455124] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 0.455618] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 0.456126] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 0.458579] DC OR NODE connected to /host1x/sor1
[ 0.458719] generic_infoframe_type: 0x87
[ 0.458728] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.458822] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 0.458838] tegradc 15210000.nvdisplay: DT parsed successfully
[ 0.458853] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=1500000, max_bw=4687500
[ 0.458869] tegradc 15210000.nvdisplay: Display dc.ffffff8002320000 registered with id=0
[ 0.466126] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 16727000 KB/s
[ 0.466147] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 665600000 Hz
[ 0.466164] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 357620000 Hz
[ 0.466207] tegradc 15210000.nvdisplay: vblank syncpt # 7 for dc 1
[ 0.466223] tegradc 15210000.nvdisplay: vpulse3 syncpt # 8 for dc 1
[ 0.466395] tegra-adma 2930000.adma: Tegra ADMA driver register 10 channels
[ 0.467118] tegradc 15210000.nvdisplay: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350937
[ 0.468794] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 0.469141] kfuse 3830000.kfuse: initialized
[ 0.469277] tegradc 15210000.nvdisplay: hdmi: no prod_list_hdmi_board, use default range
[ 0.470643] tegradc 15210000.nvdisplay: probed
[ 0.470808] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.471434] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.473344] console [ttyS0] disabled
[ 0.473408] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 37, base_baud = 25500000) is a Tegra
[ 2.600834] console [ttyS0] enabled
[ 2.602831] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 38, base_baud = 0) is a TEGRA_UART
[ 2.603910] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 39, base_baud = 0) is a TEGRA_UART
[ 2.604145] serial-tegra 3130000.serial: RX in PIO mode
[ 2.605024] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 40, base_baud = 0) is a TEGRA_UART
[ 2.615660] Console: switching to colour frame buffer device 240x67
[ 2.616727] brd: module loaded
[ 2.621933] loop: module loaded
[ 2.622158] nct1008_nct72 7-004c: find device tree node, parsing dt
[ 2.622169] nct1008_nct72 7-004c: starting parse dt
[ 2.622252] nct1008_nct72 7-004c: success parsing dt
[ 2.622373] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ 2.633640] gk20a 17000000.gp10b: failed to allocate secure buffer -12
[ 2.659220] tmp451: Enabled overheat logging at 104.00C
[ 2.659374] nct1008_nct72 7-004c: nct1008_probe: initialized
[ 2.661643] THERMAL EST: found 3 subdevs
[ 2.661647] THERMAL EST num_resources: 0
[ 2.661651] [THERMAL EST subdev 0]
[ 2.661655] [THERMAL EST subdev 1]
[ 2.661659] [THERMAL EST subdev 2]
[ 2.662006] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 2.662008] THERMAL EST: thz register success.
[ 2.662143] THERMAL EST: end of probe, return err: 0
[ 2.662195] tegra_profiler: Branch: Dev
[ 2.662196] tegra_profiler: Version: 1.117
[ 2.662199] tegra_profiler: Samples version: 41
[ 2.662200] tegra_profiler: IO version: 22
[ 2.662207] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.662212] armv8_pmu: [0] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.662215] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.662219] armv8_pmu: [1] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2, pmu ver: 0x1
[ 2.662222] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.662225] armv8_pmu: [2] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2, pmu ver: 0x1
[ 2.662229] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.662232] armv8_pmu: [3] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.662235] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.662238] armv8_pmu: [4] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.662241] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.662244] armv8_pmu: [5] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.662431] tegra_profiler: auth: init
[ 2.666078] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 2.666089] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 2.667293] scsi host0: tegra_ahci
[ 2.667750] scsi host1: tegra_ahci
[ 2.667961] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 25
[ 2.667964] ata2: DUMMY
[ 2.668987] spi-tegra114 3210000.spi: Static pin configuration used
[ 2.669481] spi-tegra114 c260000.spi: Static pin configuration used
[ 2.669917] spi-tegra114 3240000.spi: Static pin configuration used
[ 2.670897] tun: Universal TUN/TAP device driver, 1.6
[ 2.670899] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 2.671112] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 2.671114] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.671159] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.3.0-k
[ 2.671161] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.672239] PPP generic driver version 2.4.2
[ 2.672417] PPP BSD Compression module registered
[ 2.672428] PPP Deflate Compression module registered
[ 2.672448] PPP MPPE Compression module registered
[ 2.672461] NET: Registered protocol family 24
[ 2.672532] usbcore: registered new interface driver r8152
[ 2.672572] usbcore: registered new interface driver asix
[ 2.672605] usbcore: registered new interface driver ax88179_178a
[ 2.672638] usbcore: registered new interface driver cdc_ether
[ 2.672679] usbcore: registered new interface driver smsc75xx
[ 2.672709] usbcore: registered new interface driver net1080
[ 2.672739] usbcore: registered new interface driver cdc_subset
[ 2.672770] usbcore: registered new interface driver zaurus
[ 2.672825] usbcore: registered new interface driver cdc_ncm
[ 2.673172] Wake76 for irq=199
[ 2.673175] Wake77 for irq=199
[ 2.673177] Wake78 for irq=199
[ 2.673181] Wake79 for irq=199
[ 2.673182] Wake80 for irq=199
[ 2.673184] Wake81 for irq=199
[ 2.673186] Wake82 for irq=199
[ 2.673249] tegra-xotg xotg: usb2 phy is not available yet
[ 2.673858] usbcore: registered new interface driver cdc_acm
[ 2.673866] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 2.673913] usbcore: registered new interface driver usb-storage
[ 2.673982] usbcore: registered new interface driver usbserial
[ 2.674014] usbcore: registered new interface driver cp210x
[ 2.674036] usbserial: USB Serial support registered for cp210x
[ 2.674060] usbcore: registered new interface driver ftdi_sio
[ 2.674081] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 2.674105] usbcore: registered new interface driver option
[ 2.674125] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.674150] usbcore: registered new interface driver pl2303
[ 2.674172] usbserial: USB Serial support registered for pl2303
[ 2.674385] tegra-usb-cd usb_cd: otg phy is not available yet
[ 2.675297] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b c4 f3 12
[ 2.675823] libphy: dwc_phy: probed
[ 2.676784] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 2.739784] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 2.808373] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 2.810596] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 2.810621] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 2.810759] i2c /dev entries driver
[ 2.811489] [OV5693]: probing v4l2 sensor.
[ 2.986641] ata1: SATA link down (SStatus 0 SControl 300)
[ 3.299503] tegradc 15210000.nvdisplay: fb registered
[ 3.306297] PD DISP0 index2 UP
[ 3.311576] PD DISP1 index3 UP
[ 3.316153] PD DISP2 index4 UP
[ 3.329805] Parent Clock set for DC plld2
[ 3.336329] edid invalid
[ 3.385246] edid invalid
[ 3.389114] edid invalid
[ 3.392970] tegradc 15210000.nvdisplay: hdmi: pclk:148351K, set prod-setting:prod_c_150M
[ 3.546864] tegradc 15210000.nvdisplay: blank - normal
[ 3.552058] tegradc 15210000.nvdisplay: blank - powerdown
[ 3.610738] PD DISP2 index4 DOWN
[ 3.613380] PD DISP1 index3 DOWN
[ 3.613977] PD DISP0 index2 DOWN
[ 3.643339] tegradc 15210000.nvdisplay: unblank
[ 3.643428] PD DISP0 index2 UP
[ 3.649682] PD DISP1 index3 UP
[ 3.650236] PD DISP2 index4 UP
[ 3.665648] Parent Clock set for DC plld2
[ 3.668614] tegradc 15210000.nvdisplay: hdmi: pclk:148500K, set prod-setting:prod_c_150M
[ 3.684527] gspca_main: v2.14.0 registered
[ 3.684576] usbcore: registered new interface driver gspca_zc3xx
[ 3.684900] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 3.686862] FAN dev name: pwm-fan
[ 3.686910] FAN:gpio request success.
[ 3.686915] FAN: can’t find tach_gpio
[ 3.686938] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 3.687107] pwm_fan_driver pwm-fan: got pwm for fan
[ 3.687110] pwm_fan_driver pwm-fan: tach period: 1000
[ 3.687407] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 3.687411] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 3.687414] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 3.687417] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 3.687420] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 3.687423] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 3.687426] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 3.687429] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 3.687432] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 3.687435] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 3.688184] device-mapper: uevent: version 1.0.3
[ 3.688380] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 3.688828] sdhci: Secure Digital Host Controller Interface driver
[ 3.688830] sdhci: Copyright(c) Pierre Ossman
[ 3.688834] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.689131] sdhci-tegra 3460000.sdhci: Parent select= pll_p rate=408000000
[ 3.689426] sdhci-tegra 3460000.sdhci: Parent select= pll_c4_out0 rate=196249804
[ 3.689665] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 3.689902] random: nonblocking pool is initialized
[ 3.690811] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 3.690931] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.692469] usbcore: registered new interface driver usbhid
[ 3.692470] usbhid: USB HID core driver
[ 3.697307] nvadsp 2993000.adsp: in probe()…
[ 3.699212] nvadsp 2993000.adsp: Registering AMC Error Interrupt
[ 3.699241] nvadsp 2993000.adsp: AMC/ARAM initialized.
[ 3.699430] nvadsp 2993000.adsp: nvadsp_app_module_probe
[ 3.700150] Denver: backdoor interface is NOT available.
[ 3.701843] coresight-tmc 8030000.etf: TMC initialized
[ 3.702893] coresight-tmc 8050000.etr: TMC initialized
[ 3.703232] coresight-tpiu 8060000.tpiu: TPIU initialized
[ 3.703691] coresight-funnel 9010000.funnel_bccplex: FUNNEL initialized
[ 3.704102] coresight-funnel 8010000.funnel_major: FUNNEL initialized
[ 3.704499] coresight-funnel 8820000.funnel_minor: FUNNEL initialized
[ 3.704891] coresight-replicator 8040000.replicator: REPLICATOR initialized
[ 3.705468] coresight-etm4x 9840000.ptm: ETM 4.0 initialized
[ 3.705981] coresight-etm4x 9940000.ptm: ETM 4.0 initialized
[ 3.706491] coresight-etm4x 9a40000.ptm: ETM 4.0 initialized
[ 3.707007] coresight-etm4x 9b40000.ptm: ETM 4.0 initialized
[ 3.707032] Module initialized successfully
[ 3.710174] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xa0000000
[ 3.711456] tegra186-cam-rtcpu b000000.rtcpu: already unhalted
[ 3.711686] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xa0110000-0xa011957f size=38272
[ 3.712057] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 3.712100] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x1900-0x3980 TX[64x128]=0x3980-0x5a00
[ 3.712137] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x5a00-0x5ac0 TX[1x64]=0x5ac0-0x5b80
[ 3.712176] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x5b80-0x7000 TX[16x320]=0x7000-0x8480
[ 3.712212] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8480-0x8900 TX[16x64]=0x8900-0x8d80
[ 3.712247] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x8d80-0x8f80 TX[1x384]=0x8f80-0x9180
[ 3.712284] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x384]=0x9180-0x9380 TX[1x384]=0x9380-0x9580
[ 3.712428] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (52)
[ 3.712430] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[ 3.713400] tegra-ivc ivc-b000000.rtcpu:echo@0: ivc channel driver missing
[ 3.713403] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: ivc channel driver missing
[ 3.713405] tegra-ivc ivc-b000000.rtcpu:mods@32c0: ivc channel driver missing
[ 3.713408] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivc channel driver missing
[ 3.713410] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivc channel driver missing
[ 3.713412] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: ivc channel driver missing
[ 3.713414] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: ivc channel driver missing
[ 3.713437] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=4 sha1=a8b1ecdd9615cd817a56df035be363fce3b0b88f
[ 3.717322] tegra-ivc-cdev ivc-b000000.rtcpu:echo@0: probing /dev/camchar-echo
[ 3.718069] tegra-ivc-cdev ivc-b000000.rtcpu:dbg@7c00: probing /dev/camchar-dbg
[ 3.718162] camchar: rtcpu character device driver loaded
[ 3.721700] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 3.721929] register_ari_mca_banks: Registered MCA ROC:IOB
[ 3.722017] register_ari_mca_banks: Registered MCA ROC:CCE
[ 3.722348] tegra18-bridge 2390000.axi2apb: bridge probed OK
[ 3.722374] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[ 3.722397] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[ 3.722420] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[ 3.722447] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[ 3.722470] tegra18-bridge 2100000.axip2p: bridge probed OK
[ 3.722493] tegra18-bridge 2110000.axip2p: bridge probed OK
[ 3.722515] tegra18-bridge 2120000.axip2p: bridge probed OK
[ 3.722539] tegra18-bridge 2130000.axip2p: bridge probed OK
[ 3.722561] tegra18-bridge 2140000.axip2p: bridge probed OK
[ 3.722584] tegra18-bridge 2150000.axip2p: bridge probed OK
[ 3.722637] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.722639] tegra18-bridge 2160000.axip2p: bridge probed OK
[ 3.722670] tegra18-bridge 2170000.axip2p: bridge probed OK
[ 3.722702] tegra18-bridge 2180000.axip2p: bridge probed OK
[ 3.722769] tegra18-bridge 2190000.axip2p: bridge probed OK
[ 3.722842] **** A57 ECC: Enabled
[ 3.722844] tegra18_a57_serr_init: on CPU 3 a A57 Core
[ 3.722888] sdhci-tegra 3440000.sdhci: Parent select= pll_p rate=408000000
[ 3.723055] parse_throttle_dt_data: Num cap clks = 4
[ 3.723057] parse_throttle_dt_data: clk=mcpu type=1
[ 3.723059] parse_throttle_dt_data: clk=bcpu type=2
[ 3.723065] parse_throttle_dt_data: clk=gpu type=4
[ 3.723067] parse_throttle_dt_data: clk=emc type=3
[ 3.723138] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 3.723719] tegra_throttle_probe: probe successful. #cdevs=4
[ 3.723807] tegra18x_actmon d230000.actmon: in actmon_register()…
[ 3.726396] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 3.726740] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[ 3.728879] tegra-se-nvhost 15810000.se: initialized
[ 3.729330] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 3.729670] tegra-se-nvhost 15820000.se: initialized
[ 3.730175] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 3.730464] tegra-se-nvhost 15830000.se: initialized
[ 3.730572] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 3.730880] tegra-se-nvhost 15840000.se: initialized
[ 3.733880] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 3.737860] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 3.741194] cpufreq: platform driver Initialization: pass
[ 3.741328] tegra_cluster_clk e090000.cluster_clk_priv: in probe()…
[ 3.741376] tegra_cluster_clk e090000.cluster_clk_priv: passed
[ 3.741536] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 3.741540] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 3.741574] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x2ab496
[ 3.741577] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x8
[ 3.742722] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 3.743236] tegra186-padctl 3520000.pinctrl: VBUS over-current detection enabled
[ 3.743720] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 0 not supported
[ 3.744045] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 3 not supported
[ 3.745464] cpuidle: Initializing cpuidle driver init for Denver cluster
[ 3.745573] cpuidle: Initializing cpuidle driver init for A57 cluster
[ 3.746453] tachometer tegra-tachometer: Tachometer driver tegra-tachometer registered
[ 3.746456] Tachometer driver initialized with pulse_per_rev: 2 and win_len: 2
[ 3.749099] tegra210_adsp_audio_platform_probe: platform probe started
[ 3.749643] tegra210-adsp adsp_audio: Default param-type to BYTE for mp3-dec1
[ 3.749881] tegra210-adsp adsp_audio: Default param-type to BYTE for spkprot
[ 3.750182] tegra210-adsp adsp_audio: Default param-type to BYTE for src
[ 3.750445] tegra210-adsp adsp_audio: Default param-type to BYTE for aac-dec1
[ 3.750756] tegra210-adsp adsp_audio: Default param-type to BYTE for aec
[ 3.750760] tegra210-adsp adsp_audio: adma channel page address dt entry not found
[ 3.750761] tegra210-adsp adsp_audio: using adma channel page 0
[ 3.758633] tegra210_adsp_audio_platform_probe probe successfull.
[ 3.758633] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.758972] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 3.759013] sdhci-tegra 3400000.sdhci: Got WP GPIO
[ 3.759072] sdhci-tegra 3400000.sdhci: Parent select= pll_p rate=408000000
[ 3.759098] sdhci-tegra 3400000.sdhci: wakeup init done, cd_irq: 256
[ 3.759306] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 3.760630] mmc0: MAN_BKOPS_EN bit is not set
[ 3.761392] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 3.761531] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 3.765322] OPE platform probe
[ 3.765390] OPE platform probe successful
[ 3.768020] mmc0: Skipping tuning since strobe enabled
[ 3.776510] mmc0: periodic cache flush enabled
[ 3.776518] mmc0: new HS400 MMC card at address 0001
[ 3.776851] mmcblk0: mmc0:0001 032G34 29.1 GiB
[ 3.777012] mmcblk0boot0: mmc0:0001 032G34 partition 1 4.00 MiB
[ 3.777166] mmcblk0boot1: mmc0:0001 032G34 partition 2 4.00 MiB
[ 3.777307] mmcblk0rpmb: mmc0:0001 032G34 partition 3 4.00 MiB
[ 3.778801] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29
[ 3.798726] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.815031] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 3.824158] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 3.824227] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 3.824294] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 3.824363] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 3.824428] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 3.824497] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 3.824566] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 3.824634] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 3.824705] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 3.824773] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 3.824846] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 3.824911] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 3.824977] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 3.825043] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 3.825109] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 3.825179] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 3.825245] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 3.825313] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 3.825381] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 3.825450] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 3.828357] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE1 <-> ADSP PCM1 mapping ok
[ 3.828433] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE2 <-> ADSP PCM2 mapping ok
[ 3.828455] compress asoc: ADSP-FE3 <-> ADSP COMPR1 mapping ok
[ 3.828478] compress asoc: ADSP-FE4 <-> ADSP COMPR2 mapping ok
[ 3.869381] input: tegra-snd-t186ref-mobile-rt565x Headphone Jack as /devices/sound/sound/card1/input2
[ 3.870154] tegra-snd-t186ref-mobile-rt565x sound: codec-dai “dit-hifi” registered
[ 3.870158] tegra-snd-t186ref-mobile-rt565x sound: This is a dummy codec
[ 3.870786] GACT probability NOT on
[ 3.870796] Mirror/redirect action on
[ 3.870809] u32 classifier
[ 3.870810] Actions configured
[ 3.870828] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[ 3.871455] IPVS: Registered protocols ()
[ 3.871486] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
[ 3.871559] IPVS: Creating netns size=1424 id=0
[ 3.871586] IPVS: ipvs loaded.
[ 3.871592] IPVS: [rr] scheduler registered.
[ 3.871666] ipip: IPv4 over IPv4 tunneling driver
[ 3.871984] Initializing XFRM netlink socket
[ 3.872325] NET: Registered protocol family 10
[ 3.872964] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 3.873041] NET: Registered protocol family 17
[ 3.873054] NET: Registered protocol family 15
[ 3.873078] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 3.873084] 8021q: 802.1Q VLAN Support v1.8
[ 3.873827] Registered cp15_barrier emulation handler
[ 3.873847] Registered setend emulation handler
[ 3.875713] registered taskstats version 1
[ 3.879205] isp 15600000.isp: initialized
[ 3.883380] nvcsi 150c0000.nvcsi: initialized
[ 3.884446] Wake76 for irq=199
[ 3.884447] Wake77 for irq=199
[ 3.884448] Wake78 for irq=199
[ 3.884448] Wake79 for irq=199
[ 3.884449] Wake80 for irq=199
[ 3.884450] Wake81 for irq=199
[ 3.884450] Wake82 for irq=199
[ 3.884751] xhci-tegra 3530000.xhci: UTMI port 0 has OTG_CAP
[ 3.884753] xhci-tegra 3530000.xhci: No USB3 port has OTG_CAP
[ 3.906897] spi-tegra114 3210000.spi: Static pin configuration used
[ 3.907041] xhci-tegra 3530000.xhci: Direct firmware load for tegra18x_xusb_firmware failed with error -2
[ 3.907042] xhci-tegra 3530000.xhci: Falling back to user helper
[ 3.907581] spi-tegra114 c260000.spi: Static pin configuration used
[ 3.908285] spi-tegra114 3240000.spi: Static pin configuration used
[ 3.908982] tegra-xotg xotg: OTG rev:0200, ADP:0, SRP:1, HNP:1, RSP:0
[ 3.909016] tegra-xotg xotg: update_id_state: ID floating
[ 3.909020] tegra-xotg xotg: update_vbus_state: VBUS detected
[ 3.909035] tegra-xotg xotg: Nvidia XUSB OTG Controller
[ 3.910741] tegra-xotg xotg: otg: gadget gadget registered
[ 3.910743] tegra-xotg xotg: set gadget otg_caps from OTG controller
[ 3.910744] tegra-xotg xotg: otg: host not registered yet
[ 3.910746] tegra-xotg xotg: otg: start OTG finite state machine
[ 3.910788] tegra-xudc-new 3550000.xudc: entering ELPG
[ 3.911294] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 3.912220] input: gpio-keys as /devices/gpio-keys/input/input3
[ 3.946557] tegra_rtc c2a0000.rtc: setting system clock to 2018-11-20 12:52:39 UTC (1542718359)
[ 3.986037] bpmp: mounted debugfs mirror
[ 3.987239] [dram-timers] DRAM derating cdev registered.
[ 3.992397] spmic-ldo0: disabling
[ 3.992580] spmic-ldo1: disabling
[ 3.992786] en-vdd-cam: disabling
[ 3.992789] vdd-usb0-5v: disabling
[ 3.992791] vdd-usb1-5v: disabling
[ 3.992794] en-vdd-disp-3v3: disabling
[ 3.992795] en-mdm-pwr-3v7: disabling
[ 3.992797] en-vdd-disp-1v8: disabling
[ 3.992802] en-vdd-cam-hv-2v8: disabling
[ 3.992804] en-vdd-cam-1v2: disabling
[ 3.992806] vdd-fan: disabling
[ 3.992808] vdd-3v3: disabling
[ 3.992810] en-vdd-vcm-2v8: disabling
[ 3.992812] vdd-usb2-5v: disabling
[ 3.992814] vdd-sys-bl: disabling
[ 3.992815] en-vdd-sys: disabling
[ 4.000003] ALSA device list:
[ 4.000007] #0: tegra-hda at 0x3518000 irq 400
[ 4.000008] #1: tegra-snd-t186ref-mobile-rt565x
[ 4.000752] tegra-vi4 15700000.vi: initialized
[ 4.001866] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi-2 bound
[ 4.001869] tegra-vi4 15700000.vi: subdev ov5693 2-0036 bound
[ 4.014824] mmc1 tuning done saved tap delay=20
[ 4.014826] mmc1: hw tuning done …
[ 4.014832] mmc1: tuning_window[0]: 0xffffffff
[ 4.014837] mmc1: tuning_window[1]: 0xffffe3ff
[ 4.014841] mmc1: tuning_window[2]: 0xfc7fffff
[ 4.014846] mmc1: tuning_window[3]: 0x7fffffff
[ 4.014850] mmc1: tuning_window[4]: 0x0
[ 4.014854] mmc1: tuning_window[5]: 0x0
[ 4.014879] mmc1: tuning_window[6]: 0x0
[ 4.014883] mmc1: tuning_window[7]: 0x0
[ 4.014893] sdhci: Tap value: 20 | Trim value: 5
[ 4.014896] sdhci: SDMMC_VENDOR_INTR_STATUS[0x108]: 0x40000
[ 4.020481] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 4.020523] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 4.074662] tegra-usb-cd usb_cd: notification status (0x0, 0x1)
[ 4.074666] tegra-usb-cd usb_cd: set current 0ma
[ 4.074673] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 4.075599] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 4.075602] tegra-xudc-new 3550000.xudc: device mode on
[ 6.682982] tegradc 15210000.nvdisplay: hdmi: plugged
[ 7.010212] EXT4-fs (mmcblk0p1): 19 orphan inodes deleted
[ 7.017016] EXT4-fs (mmcblk0p1): recovery complete
[ 7.033796] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 7.043303] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 7.052304] devtmpfs: mounted
[ 7.056969] Freeing unused kernel memory: 1168K (ffffffc001132000 - ffffffc001256000)
[ 7.066276] Freeing alternatives memory: 96K (ffffffc001256000 - ffffffc00126e000)
[ 7.079356] btb inv war enabled
[ 7.137093] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[ 7.157018] systemd[1]: Detected architecture arm64.
[ 7.170955] systemd[1]: Set hostname to .
[ 7.294676] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 7.306471] systemd[1]: Created slice System Slice.
[ 7.314822] systemd[1]: Reached target Encrypted Volumes.
[ 7.323791] systemd[1]: Listening on LVM2 metadata daemon socket.
[ 7.333389] systemd[1]: Listening on Journal Socket (/dev/log).
[ 7.343207] systemd[1]: Created slice User and Session Slice.
[ 7.352469] systemd[1]: Reached target Slices.
[ 7.360953] systemd[1]: Created slice system-getty.slice.
[ 7.370095] systemd[1]: Listening on Syslog Socket.
[ 7.378811] systemd[1]: Listening on Journal Audit Socket.
[ 7.388360] systemd[1]: Reached target Remote File Systems (Pre).
[ 7.398550] systemd[1]: Reached target Remote File Systems.
[ 7.409555] systemd[1]: Reached target Swap.
[ 7.417032] systemd[1]: Listening on udev Control Socket.
[ 7.426581] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 7.435895] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 7.445307] systemd[1]: Reached target User and Group Name Lookups.
[ 7.454616] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 7.464794] systemd[1]: Listening on Journal Socket.
[ 7.474910] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling…
[ 7.491905] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 7.505433] systemd[1]: Starting Journal Service…
[ 7.555083] systemd[1]: Starting Load Kernel Modules…
[ 7.556287] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 7.573622] systemd[1]: Mounting POSIX Message Queue File System…
[ 7.587808] systemd[1]: Started Braille Device Support.
[ 7.597685] systemd[1]: Listening on udev Kernel Socket.
[ 7.609201] systemd[1]: Mounting Debug File System…
[ 7.618523] systemd[1]: Listening on LVM2 poll daemon socket.
[ 7.634532] systemd[1]: Starting Create list of required static device nodes for the current kernel…
[ 7.652254] systemd[1]: Mounted Debug File System.
[ 7.661129] systemd[1]: Mounted POSIX Message Queue File System.
[ 7.671847] systemd[1]: Started Journal Service.
[ 7.877796] systemd-journald[271]: Received request to flush runtime journal from PID 1
[ 8.041214] tegra-pcie 10003000.pcie-controller: 4x1, 1x1 configuration
[ 8.057948] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
[ 8.058382] tegra-pcie 10003000.pcie-controller: probing port 0, using 4 lanes
[ 8.060554] tegra-pcie 10003000.pcie-controller: probing port 2, using 1 lanes
[ 8.204636] xhci-tegra 3530000.xhci: cannot find firmware…retry after 1 second
[ 8.323718] dhd_module_init in
[ 8.323748] tegra_net_perf_init: cannot get wifi sclk
[ 8.323816] found wifi platform device bcmdhd_wlan
[ 8.326490] wifi_platform_get_country_code_map: could not get country_code_map
[ 8.326492] wifi_plat_dev_drv_probe:platform country code map is not available
[ 8.326502] Power-up adapter ‘DHD generic adapter’
[ 8.326507] wifi_platform_set_power = 1
[ 8.500622] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 8.526628] wifi_platform_bus_enumerate device present 1
[ 8.552189] wifi_platform_bus_enumerate device present 0
[ 8.562123] F1 signature read @0x18000000=0x17214354
[ 8.573406] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 8.573915] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 8.573968] wifi_platform_prealloc: failed to alloc static mem section 7
[ 8.573977] wifi_platform_get_mac_addr
[ 8.579737] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
[ 8.743511] wl_create_event_handler(): thread:wl_event_handler:27e started
[ 8.743591] CFG80211-ERROR) wl_event_handler : tsk Enter, tsk = 0xffffffc1ddce1a70
[ 8.762156] dhd_attach(): thread:dhd_watchdog_thread:281 started
[ 8.770323] dhd_attach(): thread:dhd_dpc:283 started
[ 8.770358] dhd_attach(): thread:dhd_rxf:284 started
[ 8.770363] dhd_deferred_work_init: work queue initialized
[ 8.771787] Dongle Host Driver, version 1.201.82 (r)
Compiled in drivers/net/wireless/bcmdhd on May 17 2018 at 00:12:47
[ 8.772060] tegra_sysfs_register
[ 8.772089] Register interface [wlan0] MAC: 00:04:4b:c4:f3:10
[ 8.772091] dhd_prot_ioctl : bus is down. we have nothing to do
[ 8.772172] sdhci-tegra 3440000.sdhci: Tuning already done, restoring the best tap value : 20
[ 8.773211] wifi_platform_set_power = 0
[ 8.924624] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 9.010965] using random self ethernet address
[ 9.016907] using random host ethernet address
[ 9.034383] Mass Storage Function, version: 2009/09/11
[ 9.041091] LUN: removable file: (no medium)
[ 9.051450] using random self ethernet address
[ 9.057359] using random host ethernet address
[ 9.068710] usb0: HOST MAC 6a:0e:28:87:09:d5
[ 9.076144] usb0: MAC 06:39:7e:5b:dc:0b
[ 9.082641] usb1: HOST MAC f2:64:ee:96:21:94
[ 9.089021] usb1: MAC 3a:e6:1c:c9:c9:a2
[ 9.094983] tegra-xudc-new 3550000.xudc: ep 0 (type: 0, dir: out) enabled
[ 9.234285] device usb0 entered promiscuous mode
[ 9.244971] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 9.255895] device usb1 entered promiscuous mode
[ 9.267282] IPv6: ADDRCONF(NETDEV_UP): usb1: link is not ready
[ 9.275319] xhci-tegra 3530000.xhci: Firmware timestamp: 2017-12-07 10:50:08 UTC, Version: 55.09 release
[ 9.286875] l4tbr0: port 2(usb1) entered forwarding state
[ 9.288883] xhci-tegra 3530000.xhci: xHCI Host Controller
[ 9.288896] xhci-tegra 3530000.xhci: new USB bus registered, assigned bus number 1
[ 9.289693] xhci-tegra 3530000.xhci: hcc params 0x0184fd25 hci version 0x100 quirks 0x00010810
[ 9.289714] xhci-tegra 3530000.xhci: irq 59, io mem 0x03530000
[ 9.289799] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 9.289801] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 9.289803] usb usb1: Product: xHCI Host Controller
[ 9.289805] usb usb1: Manufacturer: Linux 4.4.38-tegra xhci-hcd
[ 9.289806] usb usb1: SerialNumber: 3530000.xhci
[ 9.290066] hub 1-0:1.0: USB hub found
[ 9.290086] hub 1-0:1.0: 4 ports detected
[ 9.301956] android_work: did not send uevent (0 0 (null))
[ 9.370609] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 9.372622] tegra-pcie 10003000.pcie-controller: link 0 down, ignoring
[ 9.374771] android_work: sent uevent USB_STATE=CONNECTED
[ 9.414860] l4tbr0: port 2(usb1) entered forwarding state
[ 9.426756] xhci-tegra 3530000.xhci: xHCI Host Controller
[ 9.426763] xhci-tegra 3530000.xhci: new USB bus registered, assigned bus number 2
[ 9.426914] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 9.426916] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 9.426918] usb usb2: Product: xHCI Host Controller
[ 9.426920] usb usb2: Manufacturer: Linux 4.4.38-tegra xhci-hcd
[ 9.426921] usb usb2: SerialNumber: 3530000.xhci
[ 9.427191] hub 2-0:1.0: USB hub found
[ 9.427211] hub 2-0:1.0: 3 ports detected
[ 9.427585] tegra-xotg xotg: otg: host 3530000.xhci registered
[ 9.429937] android_work: sent uevent USB_STATE=DISCONNECTED
[ 9.522733] android_work: sent uevent USB_STATE=CONNECTED
[ 9.531441] configfs-gadget gadget: high-speed config #1: c
[ 9.538960] tegra-xudc-new 3550000.xudc: ep 5 (type: 3, dir: in) enabled
[ 9.547637] tegra-xudc-new 3550000.xudc: ep 3 (type: 2, dir: in) enabled
[ 9.556230] tegra-xudc-new 3550000.xudc: ep 2 (type: 2, dir: out) enabled
[ 9.564941] tegra-xudc-new 3550000.xudc: ep 9 (type: 3, dir: in) enabled
[ 9.573492] tegra-xudc-new 3550000.xudc: ep 7 (type: 2, dir: in) enabled
[ 9.582024] tegra-xudc-new 3550000.xudc: ep 4 (type: 2, dir: out) enabled
[ 9.590639] tegra-xudc-new 3550000.xudc: ep 15 (type: 3, dir: in) enabled
[ 9.599260] tegra-xudc-new 3550000.xudc: ep 11 (type: 2, dir: in) enabled
[ 9.607924] tegra-xudc-new 3550000.xudc: ep 6 (type: 2, dir: out) enabled
[ 9.607951] IPv6: ADDRCONF(NETDEV_CHANGE): usb0: link becomes ready
[ 9.608028] l4tbr0: port 1(usb0) entered forwarding state
[ 9.608049] l4tbr0: port 1(usb0) entered forwarding state
[ 9.608118] android_work: sent uevent USB_STATE=CONFIGURED
[ 9.650221] tegra-xudc-new 3550000.xudc: ep 13 (type: 2, dir: in) enabled
[ 9.659045] tegra-xudc-new 3550000.xudc: ep 8 (type: 2, dir: out) enabled
[ 9.667988] IPv6: ADDRCONF(NETDEV_CHANGE): usb1: link becomes ready
[ 9.790618] usb 1-2: new low-speed USB device number 2 using xhci-tegra
[ 9.832742] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 9.913684] IPVS: Creating netns size=1424 id=1
[ 9.934766] usb 1-2: New USB device found, idVendor=413c, idProduct=2113
[ 9.943423] usb 1-2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 9.953640] usb 1-2: Product: Dell KB216 Wired Keyboard
[ 9.960951] usb 1-2: ep 0x81 - rounding interval to 128 microframes, ep desc says 192 microframes
[ 9.960968] usb 1-2: ep 0x82 - rounding interval to 256 microframes, ep desc says 384 microframes
[ 9.961329] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work mailbox command 6
[ 9.965924] input: Dell KB216 Wired Keyboard as /devices/3530000.xhci/usb1/1-2/1-2:1.0/0003:413C:2113.0001/input/input4
[ 10.018956] hid-generic 0003:413C:2113.0001: input,hidraw0: USB HID v1.11 Keyboard [Dell KB216 Wired Keyboard] on usb-3530000.xhci-2/input0
[ 10.040825] input: Dell KB216 Wired Keyboard as /devices/3530000.xhci/usb1/1-2/1-2:1.1/0003:413C:2113.0002/input/input5
[ 10.061884] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 10.072451] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 10.080442] cfg80211: World regulatory domain updated:
[ 10.087751] cfg80211: DFS Master region: unset
[ 10.092191] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 10.106587] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 10.116850] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 10.128299] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 10.138592] hid-generic 0003:413C:2113.0002: input,hidraw1: USB HID v1.11 Device [Dell KB216 Wired Keyboard] on usb-3530000.xhci-2/input1
[ 10.153450] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 10.165902] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 10.177977] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 10.188357] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 10.188359] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 10.198186] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 10.198254]
[ 10.198256] wl_android_wifi_on in
[ 10.198258] wifi_platform_set_power = 1
[ 10.386632] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 10.421372] gk20a 17000000.gp10b: railgate is disabled.
[ 10.467649] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 10.482156] tegradc 15210000.nvdisplay: blank - powerdown
[ 10.539585] sdhci-tegra 3440000.sdhci: Tuning already done, restoring the best tap value : 20
[ 10.540249] F1 signature read @0x18000000=0x17214354
[ 10.540700] PD DISP2 index4 DOWN
[ 10.540829] PD DISP1 index3 DOWN
[ 10.540937] PD DISP0 index2 DOWN
[ 10.545707] F1 signature OK, socitype:0x1 chip:0x4354 rev:0x1 pkg:0x2
[ 10.546478] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 10.584309] tegradc 15210000.nvdisplay: unblank
[ 10.584322] PD DISP0 index2 UP
[ 10.585288] PD DISP1 index3 UP
[ 10.585389] PD DISP2 index4 UP
[ 10.588685] Parent Clock set for DC plld2
[ 10.590409] tegradc 15210000.nvdisplay: hdmi: pclk:148500K, set prod-setting:prod_c_150M
[ 10.611815] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 10.674002] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[ 10.674435] Enabling wake69
[ 10.675394] wifi_platform_get_mac_addr
[ 10.677762] Firmware up: op_mode=0x0005, MAC=00:04:4b:c4:f3:10
[ 10.686076] dhd_preinit_ioctls pspretend_threshold for HostAPD failed -23
[ 10.692892] Firmware version = wl0: Dec 12 2017 15:09:35 version 7.35.221.34 (r679642) FWID 01-e35dbe99
[ 10.696777] dhd_in
Using ssh login, does this succeed?
sudo ls
If it fails, what is the error message?
His latest log is a working one. I guess there should be no issue now.
Yes i have no issue now. Thank you
