I am trying to flash my image into a tx2 board.
Everything works fine, except usb2 not working if i connect something to it during boot time.
Its working only if i connect something to it 15 sec after boot.
What can cause this problem?
The dedicated image was cloned from another tx2 that contains no issue with usb2.
I am flashing from a script called: flash.sh.
I tried with different jetpacks but with no success.
What can cause this usb2 issue?
Usb3 working just fine
BTW. when booting i get this messages:
[ 11.792277] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 11.825990] vdd-1v8: voltage operation not allowed
[ 11.832086] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 11.858213] vdd-1v8: voltage operation not allowed
[ 11.863122] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 11.872804] vdd-1v8: voltage operation not allowed
[ 11.877713] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 12.017551] vdd-1v8: voltage operation not allowed
[ 12.022407] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 12.026240] vdd-1v8: voltage operation not allowed
[ 12.026248] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 12.028850] vdd-1v8: voltage operation not allowed
[ 12.028856] sdhci-tegra 3440000.sdhci: could not set regulator OCR (-1)
[ 18.337322] Bridge firewalling registered
I will try to explain again. I can flash the image using the flash.sh script.
But USB2 is not working if I connect something to it during the boot process. If I connect something to USB2 after 15 sec during the boot process then it works
Ok, then this message is dummy and no need to tell it next time. It is just noise.
Please connect your usb device, boot up. After boot up, use the serial console and run command “dmesg > log.txt”.
(This is the scenario which you said you can reproduce issue, right?)
Yes.
And i believe those lines refer to the proble:
2.138301] usb 1-1: new full-speed USB device number 3 using tegra-xusb
[ 2.138845] usb 1-1: Device not responding to setup address.
[ 2.346805] usb 1-1: Device not responding to setup address.
[ 2.554300] usb 1-1: device not accepting address 3, error -71
