Flashing it again with JetPack 3.0 and Ethernet cable installed:
[0000.183] I> Welcome to MB2(TBoot-BPMP)(version: 01.00.160913-t186-M-00.00-mobile-f4c42291)
[0000.191] I> Default Heap @ [0xd486400 - 0xd488400]
[0000.196] I> DMA Heap @ [0x84900000 - 0x85300000]
[0000.200] I> bit @ 0xd480000
[0000.203] I> BR-BCT relocated to 0xf7f20000
[0000.207] I> Boot-device: eMMC
[0000.211] I> pmic: reset reason (nverc) : 0x4
[0000.216] I> Reading GPT from 512 for device 00000003
[0000.222] I> Reading GPT from 8388096 for device 00000003
[0000.229] I> Found 6 partitions in 00000003 device
[0000.233] I> Reading GPT from 512 for device 00010003
[0000.240] I> Found 17 partitions in 00010003 device
[0000.245] W> No valid slot number is found in scratch register
[0000.251] W> Return default slot: _a
[0000.254] I> A/B: bin_type (16) slot 0
[0000.258] I> Select partition: bpmp-fw
[0000.261] I> Loading partition bpmp-fw at 0xf7600000
[0000.266] I> Reading two headers - addr:0xf7600000 blocks:1
[0000.272] I> Addr: 0xf7600000, start-block: 58739717, num_blocks: 1
[0000.287] I> Binary(16) of size 524480 is loaded @ 0xf7600000
[0000.292] W> No valid slot number is found in scratch register
[0000.298] W> Return default slot: _a
[0000.301] I> A/B: bin_type (17) slot 0
[0000.305] I> Select partition: bpmp-fw-dtb
[0000.309] I> Loading partition bpmp-fw-dtb at 0xf77f0000
[0000.314] I> Reading two headers - addr:0xf77f0000 blocks:1
[0000.320] I> Addr: 0xf77f0000, start-block: 58740925, num_blocks: 1
[0000.331] I> Binary(17) of size 326672 is loaded @ 0xf77b0200
[0000.458] I> BPMP-FW load address = 0xf7600000
[0000.463] I> BPMP-FW DTB load address = 0x501b0200
[0000.467] I> Loading SCE-FW ...
[0000.470] W> No valid slot number is found in scratch register
[0000.476] W> Return default slot: _a
[0000.479] I> A/B: bin_type (12) slot 0
[0000.483] I> Select partition: sce-fw
[0000.487] I> Loading partition sce-fw at 0xf7800000
[0000.491] I> Reading two headers - addr:0xf7800000 blocks:1
[0000.497] I> Addr: 0xf7800000, start-block: 58741925, num_blocks: 1
[0000.505] I> Binary(12) of size 65088 is loaded @ 0xf7800000
[0000.511] I> Init SCE
[0000.513] I> Copy BTCM section
[0000.516] W> No valid slot number is found in scratch register
[0000.522] W> Return default slot: _a
[0000.525] I> A/B: bin_type (13) slot 0
[0000.529] I> Select partition: cpu-bootloader
[0000.533] I> Loading partition cpu-bootloader at 0x96000000
[0000.538] I> Reading two headers - addr:0x96000000 blocks:1
[0000.544] I> Addr: 0x96000000, start-block: 58732545, num_blocks: 1
[0000.554] I> Binary(13) of size 195776 is loaded @ 0x96000000
[0000.560] W> No valid slot number is found in scratch register
[0000.565] W> Return default slot: _a
[0000.569] I> A/B: bin_type (20) slot 0
[0000.573] I> Select partition: bootloader-dtb
[0000.577] I> Loading partition bootloader-dtb at 0x85300000
[0000.582] I> Reading two headers - addr:0x85300000 blocks:1
[0000.588] I> Addr: 0x85300000, start-block: 58733057, num_blocks: 1
[0000.599] I> Binary(20) of size 248032 is loaded @ 0x85300000
[0000.604] I> MB2-params @ 0xf7f00000
[0000.608] I> CPUBL-params @ 0xf7f00000
[0000.611] I> CPU-BL loaded at : 0x96000000
[0000.615] I> Loading TOS ...
[0000.618] W> No valid slot number is found in scratch register
[0000.624] W> Return default slot: _a
[0000.627] I> A/B: bin_type (14) slot 0
[0000.631] I> Select partition: secure-os
[0000.635] I> Loading partition secure-os at 0x8490f400
[0000.640] I> Reading two headers - addr:0x8490f400 blocks:1
[0000.645] I> Addr: 0x8490f400, start-block: 58733569, num_blocks: 1
[0000.653] I> Binary(14) of size 54384 is loaded @ 0x8490f400
[0000.659] I> Copying Monitor (length: 0xd270) from 0x8490f600 to 0x40000000
[0000.666] I> Erasing Monitor @ 0x8490f600
[0000.670] I> Unhalting SCE
[0000.674] I> Waypoint2-ACK: 0x5200b8d0
[0000.678] I> MB2(TBoot-BPMP) done
NOTICE: BL31: v1.2(release):ff7a644
NOTICE: BL31: Built : 21:06:35, Mar 1 2017
NOTICE: Trusty image missing.
ERROR: Error initializing runtime service trusty_fast
[0001.040] I> Welcome to Cboot
[0001.043] I> Cboot Version: 00.00.2014.50-t186-fabbc56c
[0001.048] I> CPU-BL Params @ 0xf7f00000
[0001.051] I> 0) Base:0x00000000 Size:0x00000000
[0001.056] I> 1) Base:0xf7e00000 Size:0x00100000
[0001.060] I> 2) Base:0xf7d00000 Size:0x00100000
[0001.065] I> 3) Base:0xf7c00000 Size:0x00100000
[0001.069] I> 4) Base:0xf7b00000 Size:0x00100000
[0001.073] I> 5) Base:0xf7a00000 Size:0x00100000
[0001.078] I> 6) Base:0xf7600000 Size:0x00200000
[0001.082] I> 7) Base:0xf7000000 Size:0x00400000
[0001.087] I> 8) Base:0xf7900000 Size:0x00100000
[0001.091] I> 9) Base:0xf7800000 Size:0x00100000
[0001.096] I> 10) Base:0xf6800000 Size:0x00800000
[0001.100] I> 11) Base:0x30000000 Size:0x00040000
[0001.104] I> 12) Base:0xf7500000 Size:0x00100000
[0001.109] I> 13) Base:0x30040000 Size:0x00001000
[0001.113] I> 14) Base:0x30048000 Size:0x00001000
[0001.118] I> 15) Base:0x30049000 Size:0x00001000
[0001.122] I> 16) Base:0x3004a000 Size:0x00001000
[0001.127] I> 17) Base:0x3004b000 Size:0x00001000
[0001.131] I> 18) Base:0x3004c000 Size:0x00001000
[0001.135] I> 19) Base:0x3004d000 Size:0x00001000
[0001.140] I> 20) Base:0x3004e000 Size:0x00001000
[0001.144] I> 21) Base:0x3004f000 Size:0x00001000
[0001.149] I> 22) Base:0x00000000 Size:0x00000000
[0001.153] I> 23) Base:0xf7ff0000 Size:0x00010000
[0001.158] I> 24) Base:0x00000000 Size:0x00000000
[0001.162] I> 25) Base:0x00000000 Size:0x00000000
[0001.166] I> 26) Base:0x00000000 Size:0x00000000
[0001.171] I> 27) Base:0x00000000 Size:0x00000000
[0001.175] I> 28) Base:0x84400000 Size:0x00400000
[0001.180] I> 29) Base:0x30000000 Size:0x00010000
[0001.184] I> 30) Base:0xf8000000 Size:0x08000000
[0001.189] I> 31) Base:0x00000000 Size:0x00000000
[0001.193] I> 32) Base:0xf6000000 Size:0x00600000
[0001.197] I> 33) Base:0x80000000 Size:0x76000000
[0001.202] I> 34) Base:0x100000000 Size:0x180000000
[0001.206] I> 35) Base:0x00000000 Size:0x00000000
[0001.211] I> 36) Base:0x00000000 Size:0x00000000
[0001.215] I> 37) Base:0xf7fc0000 Size:0x00020000
[0001.220] I> 38) Base:0x84000000 Size:0x00400000
[0001.224] I> 39) Base:0x96000000 Size:0x02000000
[0001.229] I> 40) Base:0x84800000 Size:0x00b00000
[0001.233] I> 41) Base:0xf7f00000 Size:0x00080000
[0001.237] I> 42) Base:0x00000000 Size:0x00000000
[0001.242] I> 43) Base:0x00000000 Size:0x00000000
[0001.246] platform_init_interrupts-121, 1*
[0001.251] Interrupts Init done
[0001.254] calling constructors
[0001.257] initializing heap
[0001.260] initializing threads
[0001.263] initializing timers
[0001.266] creating bootstrap completion thread
[0001.270] top of bootstrap2()
[0001.273] CPU: ARM Cortex A57
[0001.277] CPU: MIDR: 0x411FD073, MPIDR: 0x80000100
[0001.282] initializing platform
[0001.285] I> Boot-device: eMMC
[0001.288] I> odm data is 1090000
[0001.292] I> Reading GPT from 512 for device 00000003
[0001.297] I> Reading GPT from 8388096 for device 00000003
[0001.304] I> Found 6 partitions in 00000003 device
[0001.308] I> Reading GPT from 512 for device 00010003
[0001.314] I> Found 17 partitions in 00010003 device
[0001.319] W> No valid slot number is found in scratch register
[0001.325] W> Return default slot: _a
[0001.328] I> A/B: bin_type (1) slot 0
[0001.331] I> Select partition: kernel-dtb
[0001.335] I> Loading partition kernel-dtb at 0x92000000
[0001.344] I> Kernel_dtb @0x92000000
[0001.347] I> Bl_dtb @0x85300000
[0001.350] I> gpio framework initialized
[0001.354] I> tegrabl_gpio_driver_register: register 'tegra_gpio_main_driver' driver
[0001.361] I> tegrabl_gpio_driver_register: register 'tegra_gpio_aon_driver' driver
[0001.369] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xee
[0001.377] I> tegrabl_gpio_driver_register: register 'tca9539_gpio_driver' driver
[0001.385] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xe8
[0001.393] I> tegrabl_gpio_driver_register: register 'tca9539_gpio_driver' driver
[0001.401] E> tegrabl_blob_init: BMP partition does not have valid Blob
[0001.407] E> tegrabl_load_bmp_blob: BMP blob initialization failed
[0001.413] W> Loading bmp blob to memory failed
[0001.421] I> Find /i2c@c250000's alias i2c7
[0001.425] I> Reading eeprom i2c=7 address=0x50
[0019.382] I> Welcome to MB1 recovery(prd-version : 10.02.161215-t186-M-00.00-f24525c4)
[0019.390] I> rst_source : 0x0
[0019.393] I> rst_level : 0x0
[0019.396] I> Boot-device: eMMC
[0019.419] I> sdmmc ddr50 mode
[0019.423] I> Entering into 3p server..
[0019.426] I> Transport interface is USB
[0019.832] I> transport_usbf_priv_open USB configuration success
[0025.536] I> Populate eeprom info for module cvm
[0141.987] I> bit @ 0xd480000
[0141.990] I> Downloading bct_bootrom at 0x000000004004e800
[0141.996] I> downloaded image bct_bootrom successfully
[0142.003] I> Downloading bct_mb1 at 0x0000000040041000
[0142.013] I> MB1-BCT relocated to 0xd48bc00 from 0x40041000
[0142.019] I> Supported mb1-bct versions 9-12
[0142.023] I> Version of mb1 bct binary 12
[0142.027] W> MB1 BCT does not have controller prod config data
[0142.032] I> Bootrom patch version : 31 (correctly patched)
[0142.038] I> ATE fuse revision : 0x30880
[0142.042] I> chip revision : A02P
[0142.045] I> disabled_core_mask: 0xffffff0c
[0142.049] I> Enabled Cores: 0xf3
[0142.052] I> TPC disable fuse status: 0
[0142.056] I> Booting Parker Sku
[0142.059] I> Ram repair fuse : 0x0
[0142.062] I> allocated(CO:30) base:0xf8000000 size:0x8000000 align: 0x8000000
[0142.069] I> allocated(CO:23) base:0xf7ff0000 size:0x10000 align: 0x10000
[0142.076] I> allocated(CO:31) base:0x0 size:0x0 align: 0x0
[0142.081] I> allocated(CO:1) base:0xf7e00000 size:0x100000 align: 0x100000
[0142.088] I> allocated(CO:2) base:0xf7d00000 size:0x100000 align: 0x100000
[0142.095] I> allocated(CO:3) base:0xf7c00000 size:0x100000 align: 0x100000
[0142.102] I> allocated(CO:4) base:0xf7b00000 size:0x100000 align: 0x100000
[0142.108] I> allocated(CO:5) base:0xf7a00000 size:0x100000 align: 0x100000
[0142.115] I> allocated(CO:8) base:0xf7900000 size:0x100000 align: 0x100000
[0142.122] I> allocated(CO:27) base:0x0 size:0x0 align: 0x0
[0142.127] I> allocated(CO:6) base:0xf7600000 size:0x200000 align: 0x200000
[0142.134] I> allocated(CO:7) base:0xf7000000 size:0x400000 align: 0x400000
[0142.141] I> allocated(CO:9) base:0xf7800000 size:0x100000 align: 0x100000
[0142.148] I> allocated(CO:10) base:0xf6800000 size:0x800000 align: 0x800000
[0142.155] I> allocated(CO:11) base:0x30000000 size:0x40000 align: 0x0
[0142.161] I> allocated(CO:12) base:0xf7500000 size:0x100000 align: 0x100000
[0142.168] I> allocated(CO:13) base:0x30040000 size:0x1000 align: 0x0
[0142.174] I> allocated(CO:14) base:0x30048000 size:0x1000 align: 0x0
[0142.180] I> allocated(CO:15) base:0x30049000 size:0x1000 align: 0x0
[0142.187] I> allocated(CO:16) base:0x3004a000 size:0x1000 align: 0x0
[0142.193] I> allocated(CO:17) base:0x3004b000 size:0x1000 align: 0x0
[0142.199] I> allocated(CO:19) base:0x3004d000 size:0x1000 align: 0x0
[0142.205] I> allocated(CO:18) base:0x3004c000 size:0x1000 align: 0x0
[0142.212] I> allocated(CO:20) base:0x3004e000 size:0x1000 align: 0x0
[0142.218] I> allocated(CO:21) base:0x3004f000 size:0x1000 align: 0x0
[0142.224] I> allocated(CO:22) base:0x0 size:0x0 align: 0x0
[0142.229] I> allocated(CO:32) base:0xf6000000 size:0x600000 align: 0x400000
[0142.236] I> allocated(CO:24) base:0x0 size:0x0 align: 0x0
[0142.242] I> allocated(CO:25) base:0x0 size:0x0 align: 0x0
[0142.247] I> allocated(CO:26) base:0x0 size:0x0 align: 0x0
[0142.252] I> allocated(CO:39) base:0x96000000 size:0x2000000 align: 0x2000000
[0142.259] I> allocated(CO:38) base:0x84000000 size:0x400000 align: 0x400000
[0142.266] I> allocated(CO:37) base:0xf7fc0000 size:0x20000 align: 0x20000
[0142.273] I> allocated(CO:40) base:0x84800000 size:0xb00000 align: 0x800000
[0142.280] I> allocated(CO:41) base:0xf7f00000 size:0x80000 align: 0x80000
[0142.287] I> allocated(CO:28) base:0x84400000 size:0x400000 align: 0x400000
[0142.294] I> Boot-device: eMMC
[0142.297] I> sdmmc bdev is already initialized
[0142.302] W> MB1 PMIC CFG is version 1.2
[0142.305] W> Rail ID 7 is not found on MB1 BCT
[0142.310] W> MB1 PMIC CFG is version 1.2
[0142.316] W> MB1 PMIC CFG is version 1.2
[0142.323] W> MB1 PMIC CFG is version 1.2
[0142.327] I> sdram slot : 1
[0142.330] I> Initializing SDRAM
[0142.336] I> mss encrypt status check successful
[0142.341] I> downloaded image bct_mb1 successfully
[0143.236] I> Downloading blob at 0x0000000085300000
[0143.620] I> downloaded image blob successfully
[0144.344] I> exiting nv3p server
[0144.347] I> disabled_core_mask: 0xffffff0c
[0144.351] I> Enabled Cores: 0xf3
[0144.354] I> TPC disable fuse status: 0
[0144.358] I> Booting Parker Sku
[0144.361] I> Setup temp. GSC#29 (base:0x30000000, size:0x00010000)
[0144.367] I> Loading preboot
[0144.372] I> Binary(1) of size 59024 is loaded @ 0x40000000
[0144.377] I> Restrict GSC#29 access to DPMU only
[0144.382] I> Updated LSR_DVCOMP_PARAMS: 0xc0760ec5c
[0144.386] I> Updated LSR_DVCOMP_PARAMS: 0xc07a0f45c
[0144.391] I> WP0 triggered
[0144.394] I> Waypoint-0 ACK received :)
[0144.397] I> WP0.5 triggered
[0144.401] I> Initialized SCRs
[0144.404] W> MB1 PMIC CFG is version 1.2
[0144.411] W> MB1 PMIC CFG is version 1.2
[0144.462] I> Waypoint-0.5 ACK received :)
[0144.466] I> Setup temp. GSC#28 (base:0x84400000, size:0x00400000)
[0144.472] I> Loading MTS-DMCE
[0144.486] I> Binary(2) of size 266624 is loaded @ 0x84400000
[0144.491] I> disabled_core_mask: 0xffffff0c
[0144.495] I> Loading MTS-PROPER
[0144.498] I> Binary(3) of size 1809872 is loaded @ 0x0
[0144.503] I> Restrict GSC#28 access to DPMU only
[0144.508] I> disabled_core_mask: 0xffffff0c
[0144.512] I> WP1 triggered
[0144.515] I> Loading MB2
[0144.518] I> Binary(8) of size 59696 is loaded @ 0x84000000
[0144.523] W> MB1 PMIC CFG is version 1.2
[0144.528] I> Configure DMCE carveout GSC#13
[0144.532] I> CPU reset vector: 0x96000000
[0144.536] I> MB2-params @ 0xf7f00000
[0144.540] I> Waypoint-1 ACK received :)
[0144.544] I> Configure SC7 carveout GSC#23
[0144.548] I> MB1 recovery done
[0144.554] I> Welcome to MB2(TBoot-BPMP) Recovery(version: 01.00.160913-t186-M-00.00-mobile-597f2c10)
[0144.563] I> Default Heap @ [0xd486400 - 0xd488400]
[0144.568] I> DMA Heap @ [0x84900000 - 0x85300000]
[0144.572] I> bit @ 0xd480000
[0144.575] I> BR-BCT relocated to 0xf7f20000
[0144.579] I> Boot-device: eMMC
[0144.583] I> pmic: reset reason (nverc) : 0x80
[0144.588] I> Reading GPT from 512 for device 00000003
[0144.594] I> Reading GPT from 8388096 for device 00000003
[0144.601] I> Found 6 partitions in 00000003 device
[0144.605] I> Reading GPT from 512 for device 00010003
[0144.612] I> Found 17 partitions in 00010003 device
[0144.620] I> Binary(16) of size 524480 is loaded @ 0xf7600000
[0144.627] I> Binary(17) of size 326672 is loaded @ 0xf77b03e0
[0144.753] I> BPMP-FW load address = 0xf7600000
[0144.758] I> BPMP-FW DTB load address = 0x501b03e0
[0144.762] I> Copy BTCM section
[0144.766] I> Binary(13) of size 143872 is loaded @ 0x96000000
[0144.772] I> MB2-params @ 0xf7f00000
[0144.775] I> CPUBL-params @ 0xf7f00000
[0144.779] I> CPU-BL loaded at : 0x96000000
[0144.783] I> Loading TOS ...
[0144.786] I> Binary(14) of size 54384 is loaded @ 0x8490f400
[0144.792] I> Copying Monitor (length: 0xd270) from 0x8490f600 to 0x40000000
[0144.799] I> Erasing Monitor @ 0x8490f600
[0144.803] I> Unhalting SCE
[0144.807] I> Waypoint2-ACK: 0x5200b694
[0144.811] I> MB2(TBoot-BPMP) Recovery done
[0145.173] I> Welcome to TBoot-CPU Recovery(version: 01.00.160913-t186-M-00.00-mobile-e9641362)
[0145.182] I> gpio framework initialized
[0145.185] I> tegrabl_gpio_driver_register: register 'tegra_gpio_main_driver' driver
[0145.193] I> tegrabl_gpio_driver_register: register 'tegra_gpio_aon_driver' driver
[0145.200] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xee
[0145.209] I> tegrabl_gpio_driver_register: register 'tca9539_gpio_driver' driver
[0145.216] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xe8
[0145.224] I> tegrabl_gpio_driver_register: register 'tca9539_gpio_driver' driver
[0145.231] I> CPU: ARM Cortex A57
[0145.234] I> CPU: MIDR: 0x411fd073, MPIDR: 0x80000100
[0145.239] I> L2 ECC enabled : yes
[0145.242] I> CPU-BL Params @ 0xf7f00000
[0145.246] I> 0) Base:0x00000000 Size:0x00000000
[0145.251] I> 1) Base:0xf7e00000 Size:0x00100000
[0145.255] I> 2) Base:0xf7d00000 Size:0x00100000
[0145.259] I> 3) Base:0xf7c00000 Size:0x00100000
[0145.264] I> 4) Base:0xf7b00000 Size:0x00100000
[0145.268] I> 5) Base:0xf7a00000 Size:0x00100000
[0145.273] I> 6) Base:0xf7600000 Size:0x00200000
[0145.277] I> 7) Base:0xf7000000 Size:0x00400000
[0145.282] I> 8) Base:0xf7900000 Size:0x00100000
[0145.286] I> 9) Base:0xf7800000 Size:0x00100000
[0145.290] I> 10) Base:0xf6800000 Size:0x00800000
[0145.295] I> 11) Base:0x30000000 Size:0x00040000
[0145.299] I> 12) Base:0xf7500000 Size:0x00100000
[0145.304] I> 13) Base:0x30040000 Size:0x00001000
[0145.308] I> 14) Base:0x30048000 Size:0x00001000
[0145.313] I> 15) Base:0x30049000 Size:0x00001000
[0145.317] I> 16) Base:0x3004a000 Size:0x00001000
[0145.321] I> 17) Base:0x3004b000 Size:0x00001000
[0145.326] I> 18) Base:0x3004c000 Size:0x00001000
[0145.330] I> 19) Base:0x3004d000 Size:0x00001000
[0145.335] I> 20) Base:0x3004e000 Size:0x00001000
[0145.339] I> 21) Base:0x3004f000 Size:0x00001000
[0145.344] I> 22) Base:0x00000000 Size:0x00000000
[0145.348] I> 23) Base:0xf7ff0000 Size:0x00010000
[0145.353] I> 24) Base:0x00000000 Size:0x00000000
[0145.357] I> 25) Base:0x00000000 Size:0x00000000
[0145.361] I> 26) Base:0x00000000 Size:0x00000000
[0145.366] I> 27) Base:0x00000000 Size:0x00000000
[0145.370] I> 28) Base:0x84400000 Size:0x00400000
[0145.375] I> 29) Base:0x30000000 Size:0x00010000
[0145.379] I> 30) Base:0xf8000000 Size:0x08000000
[0145.384] I> 31) Base:0x00000000 Size:0x00000000
[0145.388] I> 32) Base:0xf6000000 Size:0x00600000
[0145.392] I> 33) Base:0x80000000 Size:0x76000000
[0145.397] I> 34) Base:0x100000000 Size:0x180000000
[0145.401] I> 35) Base:0x00000000 Size:0x00000000
[0145.406] I> 36) Base:0x00000000 Size:0x00000000
[0145.410] I> 37) Base:0xf7fc0000 Size:0x00020000
[0145.415] I> 38) Base:0x84000000 Size:0x00400000
[0145.419] I> 39) Base:0x96000000 Size:0x02000000
[0145.424] I> 40) Base:0x84800000 Size:0x00b00000
[0145.428] I> 41) Base:0xf7f00000 Size:0x00080000
[0145.432] I> 42) Base:0x00000000 Size:0x00000000
[0145.437] I> 43) Base:0x00000000 Size:0x00000000
[0145.441] I> Boot-device: eMMC
[0145.466] I> sdmmc ddr50 mode
[0145.469] I> sdmmc bdev is already initialized
[0145.474] I> Reading GPT from 512 for device 00000003
[0145.479] I> Reading GPT from 8388096 for device 00000003
[0145.486] I> Found 6 partitions in 00000003 device
[0145.490] I> Reading GPT from 512 for device 00010003
[0145.496] I> Found 17 partitions in 00010003 device
[0145.501] I> Recovery boot_type: 0
[0145.504] I> Entering 3p server
[0145.507] I> Entering into 3p server..
[0145.511] I> Transport interface is USB
[0145.917] I> transport_usbf_priv_open USB configuration success
[0149.890] I> Populate storage info
[0150.094] I> Erasing device 0: 3
[0150.098] I> Erasing device 16384 blocks from block 0
[0150.119] I> Erase successful.
[0150.123] I> Writing device 0: 3
[0150.126] I> Total write size is 16896 bytes
[0150.170] I> Reading GPT from 512 for device 00000003
[0150.176] I> Reading GPT from 8388096 for device 00000003
[0150.182] I> Found 6 partitions in 00000003 device
[0150.187] I> Write successful.
[0150.191] I> Erasing device 1: 3
[0150.194] I> Erasing device 61071360 blocks from block 0
[0151.332] I> Erase successful.
[0151.337] I> Writing device 1: 3
[0151.340] I> Total write size is 512 bytes
[0151.345] I> Write successful.
[0151.349] I> Writing device 1: 3
[0151.352] I> Total write size is 2688 bytes
[0151.359] I> Reading GPT from 512 for device 00010003
[0151.364] I> Found 17 partitions in 00010003 device
[0151.369] I> Write successful.
[0151.373] I> Writing device 1: 3
[0151.376] I> Total write size is 16896 bytes
[0151.383] I> Reading GPT from 512 for device 00010003
[0151.389] I> Found 17 partitions in 00010003 device
[0151.393] I> Write successful.
[0151.397] I> Writing mb1 partition
[0151.401] I> Total write size is 88368 bytes
[0151.428] I> Write successful.
[0151.432] I> Writing spe-fw partition
[0151.436] I> Total write size is 57184 bytes
[0151.465] I> Write successful.
[0151.469] I> Writing mb2 partition
[0151.473] I> Total write size is 60720 bytes
[0151.507] I> Write successful.
[0151.511] I> Writing mts-preboot partition
[0151.515] I> Total write size is 59824 bytes
[0151.555] I> Write successful.
[0151.559] I> Writing device 1: 3
[0151.562] I> Total write size is 512 bytes
[0151.568] I> Write successful.
[0151.572] I> Writing APP partition
[0151.575] I> Total write size is 3359363332 bytes
[0304.258] I> Write successful.
[0304.261] I> Writing mts-bootpack partition
[0304.265] I> Total write size is 2077344 bytes
[0304.359] I> Write successful.
[0304.363] I> Writing cpu-bootloader partition
[0304.367] I> Total write size is 196176 bytes
[0304.382] I> Write successful.
[0304.386] I> Writing bootloader-dtb partition
[0304.390] I> Total write size is 248432 bytes
[0304.411] I> Write successful.
[0304.415] I> Writing secure-os partition
[0304.419] I> Total write size is 54784 bytes
[0304.427] I> Write successful.
[0304.430] I> Writing eks partition
[0304.434] I> Total write size is 1488 bytes
[0304.440] I> Write successful.
[0304.444] I> Writing bpmp-fw partition
[0304.447] I> Total write size is 524880 bytes
[0304.476] I> Write successful.
[0304.480] I> Writing bpmp-fw-dtb partition
[0304.484] I> Total write size is 327072 bytes
[0304.505] I> Write successful.
[0304.509] I> Writing sce-fw partition
[0304.513] I> Total write size is 65488 bytes
[0304.522] I> Write successful.
[0304.526] I> Writing sc7 partition
[0304.529] I> Total write size is 20848 bytes
[0304.536] I> Write successful.
[0304.540] I> Writing kernel partition
[0304.543] I> Total write size is 6717440 bytes
[0304.843] I> Write successful.
[0304.847] I> Writing kernel-dtb partition
[0304.851] I> Total write size is 248032 bytes
[0304.869] I> Write successful.
[0305.235] I> Writing BCT partition
[0305.239] I> Total write size is 3584 bytes
[0305.280] I> Write successful.
[0305.644] I> Writing MB1_BCT partition
[0305.647] I> Total write size is 49968 bytes
[0305.688] I> Write successful.
[0305.999] I> Rebooting : reset-coldboot
[0000.213] I> Welcome to MB2(TBoot-BPMP)(version: 01.00.160913-t186-M-00.00-mobile-f4c42291)
[0000.221] I> Default Heap @ [0xd486400 - 0xd488400]
[0000.226] I> DMA Heap @ [0x84900000 - 0x85300000]
[0000.230] I> bit @ 0xd480000
[0000.233] I> BR-BCT relocated to 0xf7f20000
[0000.237] I> Boot-device: eMMC
[0000.242] I> pmic: reset reason (nverc) : 0x0
[0000.246] I> Reading GPT from 512 for device 00000003
[0000.252] I> Reading GPT from 8388096 for device 00000003
[0000.259] I> Found 6 partitions in 00000003 device
[0000.263] I> Reading GPT from 512 for device 00010003
[0000.270] I> Found 17 partitions in 00010003 device
[0000.275] W> No valid slot number is found in scratch register
[0000.281] W> Return default slot: _a
[0000.284] I> A/B: bin_type (16) slot 0
[0000.288] I> Select partition: bpmp-fw
[0000.291] I> Loading partition bpmp-fw at 0xf7600000
[0000.296] I> Reading two headers - addr:0xf7600000 blocks:1
[0000.302] I> Addr: 0xf7600000, start-block: 58739717, num_blocks: 1
[0000.317] I> Binary(16) of size 524480 is loaded @ 0xf7600000
[0000.322] W> No valid slot number is found in scratch register
[0000.328] W> Return default slot: _a
[0000.331] I> A/B: bin_type (17) slot 0
[0000.335] I> Select partition: bpmp-fw-dtb
[0000.339] I> Loading partition bpmp-fw-dtb at 0xf77f0000
[0000.344] I> Reading two headers - addr:0xf77f0000 blocks:1
[0000.350] I> Addr: 0xf77f0000, start-block: 58740925, num_blocks: 1
[0000.361] I> Binary(17) of size 326672 is loaded @ 0xf77b0200
[0000.489] I> BPMP-FW load address = 0xf7600000
[0000.493] I> BPMP-FW DTB load address = 0x501b0200
[0000.498] I> Loading SCE-FW ...
[0000.501] W> No valid slot number is found in scratch register
[0000.507] W> Return default slot: _a
[0000.510] I> A/B: bin_type (12) slot 0
[0000.514] I> Select partition: sce-fw
[0000.517] I> Loading partition sce-fw at 0xf7800000
[0000.522] I> Reading two headers - addr:0xf7800000 blocks:1
[0000.528] I> Addr: 0xf7800000, start-block: 58741925, num_blocks: 1
[0000.536] I> Binary(12) of size 65088 is loaded @ 0xf7800000
[0000.542] I> Init SCE
[0000.544] I> Copy BTCM section
[0000.547] W> No valid slot number is found in scratch register
[0000.553] W> Return default slot: _a
[0000.556] I> A/B: bin_type (13) slot 0
[0000.560] I> Select partition: cpu-bootloader
[0000.564] I> Loading partition cpu-bootloader at 0x96000000
[0000.569] I> Reading two headers - addr:0x96000000 blocks:1
[0000.575] I> Addr: 0x96000000, start-block: 58732545, num_blocks: 1
[0000.585] I> Binary(13) of size 195776 is loaded @ 0x96000000
[0000.591] W> No valid slot number is found in scratch register
[0000.596] W> Return default slot: _a
[0000.600] I> A/B: bin_type (20) slot 0
[0000.603] I> Select partition: bootloader-dtb
[0000.607] I> Loading partition bootloader-dtb at 0x85300000
[0000.613] I> Reading two headers - addr:0x85300000 blocks:1
[0000.618] I> Addr: 0x85300000, start-block: 58733057, num_blocks: 1
[0000.629] I> Binary(20) of size 248032 is loaded @ 0x85300000
[0000.635] I> MB2-params @ 0xf7f00000
[0000.638] I> CPUBL-params @ 0xf7f00000
[0000.642] I> CPU-BL loaded at : 0x96000000
[0000.646] I> Loading TOS ...
[0000.649] W> No valid slot number is found in scratch register
[0000.654] W> Return default slot: _a
[0000.658] I> A/B: bin_type (14) slot 0
[0000.662] I> Select partition: secure-os
[0000.665] I> Loading partition secure-os at 0x8490f400
[0000.670] I> Reading two headers - addr:0x8490f400 blocks:1
[0000.676] I> Addr: 0x8490f400, start-block: 58733569, num_blocks: 1
[0000.684] I> Binary(14) of size 54384 is loaded @ 0x8490f400
[0000.690] I> Copying Monitor (length: 0xd270) from 0x8490f600 to 0x40000000
[0000.697] I> Erasing Monitor @ 0x8490f600
[0000.701] I> Unhalting SCE
[0000.705] I> Waypoint2-ACK: 0x5200b8d0
[0000.709] I> MB2(TBoot-BPMP) done
[0001.071] I> Welcome to Cboot
[0001.074] I> Cboot Version: 00.00.2014.50-t186-fabbc56c
[0001.079] I> CPU-BL Params @ 0xf7f00000
[0001.082] I> 0) Base:0x00000000 Size:0x00000000
[0001.087] I> 1) Base:0xf7e00000 Size:0x00100000
[0001.091] I> 2) Base:0xf7d00000 Size:0x00100000
[0001.096] I> 3) Base:0xf7c00000 Size:0x00100000
[0001.100] I> 4) Base:0xf7b00000 Size:0x00100000
[0001.104] I> 5) Base:0xf7a00000 Size:0x00100000
[0001.109] I> 6) Base:0xf7600000 Size:0x00200000
[0001.113] I> 7) Base:0xf7000000 Size:0x00400000
[0001.118] I> 8) Base:0xf7900000 Size:0x00100000
[0001.122] I> 9) Base:0xf7800000 Size:0x00100000
[0001.127] I> 10) Base:0xf6800000 Size:0x00800000
[0001.131] I> 11) Base:0x30000000 Size:0x00040000
[0001.135] I> 12) Base:0xf7500000 Size:0x00100000
[0001.140] I> 13) Base:0x30040000 Size:0x00001000
[0001.144] I> 14) Base:0x30048000 Size:0x00001000
[0001.149] I> 15) Base:0x30049000 Size:0x00001000
[0001.153] I> 16) Base:0x3004a000 Size:0x00001000
[0001.158] I> 17) Base:0x3004b000 Size:0x00001000
[0001.162] I> 18) Base:0x3004c000 Size:0x00001000
[0001.166] I> 19) Base:0x3004d000 Size:0x00001000
[0001.171] I> 20) Base:0x3004e000 Size:0x00001000
[0001.175] I> 21) Base:0x3004f000 Size:0x00001000
[0001.180] I> 22) Base:0x00000000 Size:0x00000000
[0001.184] I> 23) Base:0xf7ff0000 Size:0x00010000
[0001.189] I> 24) Base:0x00000000 Size:0x00000000
[0001.193] I> 25) Base:0x00000000 Size:0x00000000
[0001.197] I> 26) Base:0x00000000 Size:0x00000000
[0001.202] I> 27) Base:0x00000000 Size:0x00000000
[0001.206] I> 28) Base:0x84400000 Size:0x00400000
[0001.211] I> 29) Base:0x30000000 Size:0x00010000
[0001.215] I> 30) Base:0xf8000000 Size:0x08000000
[0001.220] I> 31) Base:0x00000000 Size:0x00000000
[0001.224] I> 32) Base:0xf6000000 Size:0x00600000
[0001.228] I> 33) Base:0x80000000 Size:0x76000000
[0001.233] I> 34) Base:0x100000000 Size:0x180000000
[0001.237] I> 35) Base:0x00000000 Size:0x00000000
[0001.242] I> 36) Base:0x00000000 Size:0x00000000
[0001.246] I> 37) Base:0xf7fc0000 Size:0x00020000
[0001.251] I> 38) Base:0x84000000 Size:0x00400000
[0001.255] I> 39) Base:0x96000000 Size:0x02000000
[0001.260] I> 40) Base:0x84800000 Size:0x00b00000
[0001.264] I> 41) Base:0xf7f00000 Size:0x00080000
[0001.268] I> 42) Base:0x00000000 Size:0x00000000
[0001.273] I> 43) Base:0x00000000 Size:0x00000000
[0001.277] platform_init_interrupts-121, 1*
[0001.282] Interrupts Init done
[0001.285] calling constructors
[0001.288] initializing heap
[0001.290] initializing threads
[0001.294] initializing timers
[0001.297] creating bootstrap completion thread
[0001.301] top of bootstrap2()
[0001.304] CPU: ARM Cortex A57
[0001.307] CPU: MIDR: 0x411FD073, MPIDR: 0x80000100
[0001.312] initializing platform
[0001.316] I> Boot-device: eMMC
[0001.319] I> odm data is 1090000
[0001.322] I> Reading GPT from 512 for device 00000003
[0001.328] I> Reading GPT from 8388096 for device 00000003
[0001.335] I> Found 6 partitions in 00000003 device
[0001.339] I> Reading GPT from 512 for device 00010003
[0001.345] I> Found 17 partitions in 00010003 device
[0001.350] W> No valid slot number is found in scratch register
[0001.355] W> Return default slot: _a
[0001.359] I> A/B: bin_type (1) slot 0
[0001.362] I> Select partition: kernel-dtb
[0001.366] I> Loading partition kernel-dtb at 0x92000000
[0001.375] I> Kernel_dtb @0x92000000
[0001.378] I> Bl_dtb @0x85300000
[0001.381] I> gpio framework initialized
[0001.385] I> tegrabl_gpio_driver_register: register 'tegra_gpio_main_driver' driver
[0001.392] I> tegrabl_gpio_driver_register: register 'tegra_gpio_aon_driver' driver
[0001.400] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xee
[0001.408] I> tegrabl_gpio_driver_register: register 'tca9539_gpio_driver' driver
[0001.416] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xe8
[0001.424] I> tegrabl_gpio_driver_register: register 'tca9539_gpio_driver' driver
[0001.432] E> tegrabl_blob_init: BMP partition does not have valid Blob
[0001.438] E> tegrabl_load_bmp_blob: BMP blob initialization failed
[0001.444] W> Loading bmp blob to memory failed
[0001.452] I> Find /i2c@c250000's alias i2c7
[0001.456] I> Reading eeprom i2c=7 address=0x50
[0001.486] I> Device at /i2c@c250000:0x50
[0001.489] I> Reading eeprom i2c=7 address=0x57
[0001.518] I> Device at /i2c@c250000:0x57
[0001.523] I> Find /i2c@c240000's alias i2c1
[0001.527] I> Reading eeprom i2c=1 address=0x51
[0001.533] I> Eeprom read failed 0x1a800027
[0001.537] I> Find /i2c@3160000's alias i2c0
[0001.541] I> Reading eeprom i2c=0 address=0x50
[0001.547] I> Eeprom read failed 0x1a800027
[0001.551] I> Find /i2c@3180000's alias i2c2
[0001.555] I> Reading eeprom i2c=2 address=0x54
[0001.560] I> Enabling gpio chip_id = 2, gpio pin = 9
[0001.590] I> Disabling gpio chip_id = 2, gpio pin = 9
[0001.595] I> Device at /i2c@3180000:0x54
[0001.599] I> create_pm_ids: id: 3310-1000-B00-E, len: 15
[0001.604] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, le3
[0001.615] I> create_pm_ids: id: 2597-0000-500-C, len: 15
[0001.620] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, le3
[0001.631] I> create_pm_ids: id: 3326-1000-100-M, len: 15
[0001.636] I> config: mem-type:ff,power-config:ff,misc-config:ff,modem-config:ff,touch-config:ff,display-config:ff,, le3
[0001.647] initializing target
[0001.650] calling apps_init()
[0001.653] starting app android_boot_app
[0001.657] I> Gpio keyboard init success
[0001.661] I> Kernel type = Normal
[0001.664] I> Loading kernel/boot.img ...
[0001.668] W> No valid slot number is found in scratch register
[0001.674] W> Return default slot: _a
[0001.677] I> A/B: bin_type (0) slot 0
[0001.681] I> Select partition: kernel
[0001.684] I> Loading partition kernel at 0xa8000000
[0001.765] W> No valid slot number is found in scratch register
[0001.771] W> Return default slot: _a
[0001.774] I> A/B: bin_type (1) slot 0
[0001.778] I> Select partition: kernel-dtb
[0001.781] I> Loading partition kernel-dtb at 0x92000000
[0001.790] I> Kernel DTB @ 0x92000000
[0001.794] I> Verified boot state = Orange
[0001.798] E> tegrabl_display_clear: display is not initialized
[0001.803] I> Checking boot.img header magic ... [0001.807] I> [OK]
[0001.809] I> Valid boot.img @ 0xa8000000
[0001.813] I> decompressor handler not found
[0001.817] I> Copying kernel image (462634 bytes) from 0xa8000800 to 0x80080000 ... [0001.824] I> Done
[0001.826] I> Move ramdisk (len: 6252235) from 0xa8071800 to 0x98000000
[0001.835] I> Updated bpmp info to DTB
[0001.841] I> Ramdisk: Base: 0x98000000; Size: 0x5f66cb
[0001.846] I> Updated initrd info to DTB
[0001.850] I> disabled_core_mask: 0xffffff0c
[0001.854] I> Kernel type = Normal
[0001.857] I> add_serialno: Serial Num = 0320717049259
[0001.862] W> No valid slot number is found in scratch register
[0001.867] W> Return default slot: _a
[0001.871] I> Linux Cmdline: root=/dev/mmcblk0p1 rw rootwait fbcon=map:0 net.ifnames=0 console=tty0 OS=l4t console=ttyS
[0001.910] I> Updated bootarg info to DTB
[0001.915] I> eeprom_get_mac_addr: MAC (type: 0): 00:04:4b:8c:45:d3
[0001.921] I> eeprom_get_mac_addr: MAC (type: 1): 00:04:4b:8c:45:d4
[0001.927] I> eeprom_get_mac_addr: MAC (type: 2): 00:04:4b:8c:45:d5
[0001.933] E> "ids" doesn't exist, creating
[0001.937] E> "connection" doesn't exist, creating
[0001.942] E> "configs" doesn't exist, creating
[0001.946] I> create_pm_ids: id: 3310-1000-B00-E, len: 15
[0001.951] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, le3
[0001.962] I> create_pm_ids: id: 2597-0000-500-C, len: 15
[0001.968] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, le3
[0001.978] I> create_pm_ids: id: 3326-1000-100-M, len: 15
[0001.984] I> config: mem-type:ff,power-config:ff,misc-config:ff,modem-config:ff,touch-config:ff,display-config:ff,, le3
[0001.995] I> Adding plugin-manager/ids/3310-1000-B00=/i2c@c250000:module@0x50
[0002.002] E> "i2c@c250000" doesn't exist, creating
[0002.006] E> "module@0x50" doesn't exist, creating
[0002.011] I> Adding plugin-manager/ids/2597-0000-500=/i2c@c250000:module@0x57
[0002.018] E> "module@0x57" doesn't exist, creating
[0002.023] I> Adding plugin-manager/ids/3326-1000-100=/i2c@3180000:module@0x54
[0002.030] E> "i2c@3180000" doesn't exist, creating
[0002.035] E> "module@0x54" doesn't exist, creating
[0002.041] I> Adding plugin-manager/ids/3310-1000-B00-E
[0002.048] I> Adding plugin-manager/configs/3310-mem-type 00
[0002.054] I> Adding plugin-manager/configs/3310-power-config 00
[0002.060] I> Adding plugin-manager/configs/3310-misc-config 00
[0002.065] I> Adding plugin-manager/configs/3310-modem-config 00
[0002.071] I> Adding plugin-manager/configs/3310-touch-config 00
[0002.077] I> Adding plugin-manager/configs/3310-display-config 00
[0002.083] E> "chip-id" doesn't exist, creating
[0002.087] I> Adding plugin-manager/chip-id/A02P
[0002.094] I> Updated memory info to DTB
[0002.099] E> "reset" doesn't exist, creating
[0002.103] E> "pmc-reset-reason" doesn't exist, creating
[0002.109] E> "pmic-reset-reason" doesn't exist, creating
[0002.114] I> disabled_core_mask: 0xffffff0c
[0002.125] I> tegrabl_load_kernel_and_dtb: Done
U-Boot 2016.07-g5971907 (Mar 01 2017 - 21:06:45 -0800)
TEGRA186
Model: NVIDIA P2771-0000-500
DRAM: 7.8 GiB
MC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: eth0: ethernet@2490000
Hit any key to stop autoboot: 0
MMC: no card present
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1...
starting USB...
No controllers found
USB is stopped. Please issue 'usb start' first.
starting USB...
ethernet@2490000 Waiting for PHY auto negotiation to complete.... done
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
DHCP client bound to address 192.168.1.150 (2323 ms)
*** Warning: no boot file name; using 'C0A80196.img'
Using ethernet@2490000 device
TFTP from server 0.0.0.0; our IP address is 192.168.1.150; sending through gateway 192.168.1.1
Filename 'C0A80196.img'.
Load address: 0x80080000
Loading: T T T T T T T T T T
Retry count exceeded; starting again
missing environment variable: pxeuuid
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/01-00-04-4b-8c-45-d5
*** ERROR: `serverip' not set
Retrieving file: pxelinux.cfg/C0A80196
ethernet@2490000 Waiting for PHY auto negotiation to complete..... done
ethernet@2490000 Waiting for PHY auto negotiation to complete...... done
Retrieving file: pxelinux.cfg/default-arm-tegra186
Config file not found
starting USB...
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
DHCP client bound to address 192.168.1.150 (3112 ms)
Filename 'boot.scr.uimg'.
Load address: 0x90000000
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
DHCP client bound to address 192.168.1.150 (2328 ms)
Tegra186 (P2771-0000-500) #
On my hard disk (ext4) used for flashing I have 11GB free storage left (after flashing is finished):
/dev/sda1 252G 229G 11G 96% /media/fab/Externe
Flashing Output:
https://pastebin.com/bJK2EDTF
Rootfs looks like this:
Linux_for_Tegra/rootfs$ sudo tree | head -n 30
├── bin
│ ├── archdetect
│ ├── bash
│ ├── btrfs
│ ├── btrfs-calc-size
│ ├── btrfsck -> btrfs
│ ├── btrfs-convert
│ ├── btrfs-debug-tree
│ ├── btrfs-find-root
│ ├── btrfs-image
│ ├── btrfs-map-logical
│ ├── btrfs-select-super
│ ├── btrfs-show-super
│ ├── btrfstune
│ ├── btrfs-zero-log
│ ├── bunzip2
│ ├── busybox
│ ├── bzcat
│ ├── bzcmp -> bzdiff
│ ├── bzdiff
│ ├── bzegrep -> bzgrep
│ ├── bzexe
│ ├── bzfgrep -> bzgrep
│ ├── bzgrep
│ ├── bzip2
│ ├── bzip2recover
│ ├── bzless -> bzmore
│ ├── bzmore
│ ├── cat
