Here is the log output during flash and then restart.
[0265.489] I> allocated(CO:15) base:0x30049000 size:0x1000 align: 0x0
[0265.495] I> allocated(CO:16) base:0x3004a000 size:0x1000 align: 0x0
[0265.501] I> allocated(CO:17) base:0x3004b000 size:0x1000 align: 0x0
[0265.507] I> allocated(CO:19) base:0x3004d000 size:0x1000 align: 0x0
[0265.514] I> allocated(CO:18) base:0x3004c000 size:0x1000 align: 0x0
[0265.520] I> allocated(CO:20) base:0x3004e000 size:0x1000 align: 0x0
[0265.526] I> allocated(CO:21) base:0x3004f000 size:0x1000 align: 0x0
[0265.532] I> allocated(CO:22) base:0x0 size:0x0 align: 0x0
[0265.538] I> allocated(CO:32) base:0xf6000000 size:0x600000 align: 0x400000
[0265.545] I> allocated(CO:24) base:0x0 size:0x0 align: 0x0
[0265.550] I> allocated(CO:25) base:0x0 size:0x0 align: 0x0
[0265.555] I> allocated(CO:26) base:0x0 size:0x0 align: 0x0
[0265.561] I> allocated(CO:39) base:0x96000000 size:0x2000000 align: 0x2000000
[0265.568] I> allocated(CO:38) base:0x84000000 size:0x400000 align: 0x400000
[0265.575] I> allocated(CO:37) base:0xf7fc0000 size:0x20000 align: 0x20000
[0265.581] I> allocated(CO:40) base:0x84800000 size:0xb00000 align: 0x800000
[0265.588] I> allocated(CO:41) base:0xf7f00000 size:0x80000 align: 0x80000
[0265.595] I> allocated(CO:28) base:0x84400000 size:0x400000 align: 0x400000
[0265.603] I> Boot-device: eMMC
[0265.606] I> sdmmc bdev is already initialized
[0265.610] W> MB1 PMIC CFG is version 1.2
[0265.614] W> Rail ID 7 is not found on MB1 BCT
[0265.618] W> MB1 PMIC CFG is version 1.2
[0265.624] W> MB1 PMIC CFG is version 1.2
[0265.632] W> MB1 PMIC CFG is version 1.2
[0265.636] I> sdram slot : 1
[0265.638] I> Initializing SDRAM
[0265.645] I> mss encrypt status check successful
[0265.649] I> downloaded image bct_mb1 successfully
[0266.040] I> Downloading blob at 0x0000000085300000
[0266.423] I> downloaded image blob successfully
[0266.453] I> exiting nv3p server
[0266.456] I> disabled_core_mask: 0xffffff0c
[0266.460] I> Enabled Cores: 0xf3
[0266.463] I> TPC disable fuse status: 0
[0266.467] I> Booting Parker Sku
[0266.470] I> Setup temp. GSC#29 (base:0x30000000, size:0x00010000)
[0266.476] I> Loading preboot
[0266.481] I> Binary(1) of size 59024 is loaded @ 0x40000000
[0266.486] I> Restrict GSC#29 access to DPMU only
[0266.491] I> Updated LSR_DVCOMP_PARAMS: 0xc07a0f45c
[0266.495] I> Updated LSR_DVCOMP_PARAMS: 0xc07c0f85c
[0266.500] I> WP0 triggered
[0266.503] I> Waypoint-0 ACK received :)
[0266.507] I> WP0.5 triggered
[0266.510] I> Initialized SCRs
[0266.513] W> MB1 PMIC CFG is version 1.2
[0266.521] W> MB1 PMIC CFG is version 1.2
[0266.571] I> Waypoint-0.5 ACK received :)
[0266.575] I> Setup temp. GSC#28 (base:0x84400000, size:0x00400000)
[0266.581] I> Loading MTS-DMCE
[0266.595] I> Binary(2) of size 266624 is loaded @ 0x84400000
[0266.601] I> disabled_core_mask: 0xffffff0c
[0266.605] I> Loading MTS-PROPER
[0266.608] I> Binary(3) of size 1809872 is loaded @ 0x0
[0266.613] I> Restrict GSC#28 access to DPMU only
[0266.617] I> disabled_core_mask: 0xffffff0c
[0266.621] I> WP1 triggered
[0266.624] I> Loading MB2
[0266.627] I> Binary(8) of size 59696 is loaded @ 0x84000000
[0266.632] W> MB1 PMIC CFG is version 1.2
[0266.637] I> Configure DMCE carveout GSC#13
[0266.641] I> CPU reset vector: 0x96000000
[0266.645] I> MB2-params @ 0xf7f00000
[0266.649] I> Waypoint-1 ACK received :)
[0266.653] I> Configure SC7 carveout GSC#23
[0266.657] I> MB1 recovery done
[0266.663] I> Welcome to MB2(TBoot-BPMP) Recovery(version: 01.00.160913-t186-M-00.00-mobile-597f2c10)
[0266.672] I> Default Heap @ [0xd486400 - 0xd488400]
[0266.677] I> DMA Heap @ [0x84900000 - 0x85300000]
[0266.682] I> bit @ 0xd480000
[0266.684] I> BR-BCT relocated to 0xf7f20000
[0266.689] I> Boot-device: eMMC
[0266.693] I> pmic: reset reason (nverc) : 0x80
[0266.697] I> Reading GPT from 512 for device 00000003
[0266.703] I> Reading GPT from 8388096 for device 00000003
[0266.710] I> Found 6 partitions in 00000003 device
[0266.715] I> Reading GPT from 512 for device 00010003
[0266.721] I> Found 17 partitions in 00010003 device
[0266.729] I> Binary(16) of size 524480 is loaded @ 0xf7600000
[0266.737] I> Binary(17) of size 326672 is loaded @ 0xf77b03e0
[0266.863] I> BPMP-FW load address = 0xf7600000
[0266.868] I> BPMP-FW DTB load address = 0x501b03e0
[0266.872] I> Copy BTCM section
[0266.876] I> Binary(13) of size 143872 is loaded @ 0x96000000
[0266.882] I> MB2-params @ 0xf7f00000
[0266.885] I> CPUBL-params @ 0xf7f00000
[0266.889] I> CPU-BL loaded at : 0x96000000
[0266.893] I> Loading TOS …
[0266.896] I> Binary(14) of size 54384 is loaded @ 0x8490f400
[0266.902] I> Copying Monitor (length: 0xd270) from 0x8490f600 to 0x40000000
[0266.909] I> Erasing Monitor @ 0x8490f600
[0266.914] I> Unhalting SCE
[0266.917] I> Waypoint2-ACK: 0x5200b694
[0266.921] I> MB2(TBoot-BPMP) Recovery done
NOTICE: BL31: v1.2(release):ff7a644
NOTICE: BL31: Built : 21:06:35, Mar 1 2017
NOTICE: Trusty image missing.
ERROR: Error initializing runtime service trusty_fast
[0267.283] I> Welcome to TBoot-CPU Recovery(version: 01.00.160913-t186-M-00.00-mobile-e9641362)
[0267.292] I> gpio framework initialized
[0267.296] I> tegrabl_gpio_driver_register: register ‘tegra_gpio_main_driver’ driver
[0267.303] I> tegrabl_gpio_driver_register: register ‘tegra_gpio_aon_driver’ driver
[0267.310] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xee
[0267.319] I> tegrabl_gpio_driver_register: register ‘tca9539_gpio_driver’ driver
[0267.326] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xe8
[0267.334] I> tegrabl_gpio_driver_register: register ‘tca9539_gpio_driver’ driver
[0267.342] I> CPU: ARM Cortex A57
[0267.345] I> CPU: MIDR: 0x411fd073, MPIDR: 0x80000100
[0267.349] I> L2 ECC enabled : yes
[0267.353] I> CPU-BL Params @ 0xf7f00000
[0267.356] I> 0) Base:0x00000000 Size:0x00000000
[0267.361] I> 1) Base:0xf7e00000 Size:0x00100000
[0267.365] I> 2) Base:0xf7d00000 Size:0x00100000
[0267.370] I> 3) Base:0xf7c00000 Size:0x00100000
[0267.374] I> 4) Base:0xf7b00000 Size:0x00100000
[0267.378] I> 5) Base:0xf7a00000 Size:0x00100000
[0267.383] I> 6) Base:0xf7600000 Size:0x00200000
[0267.387] I> 7) Base:0xf7000000 Size:0x00400000
[0267.392] I> 8) Base:0xf7900000 Size:0x00100000
[0267.396] I> 9) Base:0xf7800000 Size:0x00100000
[0267.401] I> 10) Base:0xf6800000 Size:0x00800000
[0267.405] I> 11) Base:0x30000000 Size:0x00040000
[0267.409] I> 12) Base:0xf7500000 Size:0x00100000
[0267.414] I> 13) Base:0x30040000 Size:0x00001000
[0267.418] I> 14) Base:0x30048000 Size:0x00001000
[0267.423] I> 15) Base:0x30049000 Size:0x00001000
[0267.427] I> 16) Base:0x3004a000 Size:0x00001000
[0267.432] I> 17) Base:0x3004b000 Size:0x00001000
[0267.436] I> 18) Base:0x3004c000 Size:0x00001000
[0267.440] I> 19) Base:0x3004d000 Size:0x00001000
[0267.445] I> 20) Base:0x3004e000 Size:0x00001000
[0267.449] I> 21) Base:0x3004f000 Size:0x00001000
[0267.454] I> 22) Base:0x00000000 Size:0x00000000
[0267.458] I> 23) Base:0xf7ff0000 Size:0x00010000
[0267.463] I> 24) Base:0x00000000 Size:0x00000000
[0267.467] I> 25) Base:0x00000000 Size:0x00000000
[0267.471] I> 26) Base:0x00000000 Size:0x00000000
[0267.476] I> 27) Base:0x00000000 Size:0x00000000
[0267.480] I> 28) Base:0x84400000 Size:0x00400000
[0267.485] I> 29) Base:0x30000000 Size:0x00010000
[0267.489] I> 30) Base:0xf8000000 Size:0x08000000
[0267.494] I> 31) Base:0x00000000 Size:0x00000000
[0267.498] I> 32) Base:0xf6000000 Size:0x00600000
[0267.502] I> 33) Base:0x80000000 Size:0x76000000
[0267.507] I> 34) Base:0x100000000 Size:0x180000000
[0267.512] I> 35) Base:0x00000000 Size:0x00000000
[0267.516] I> 36) Base:0x00000000 Size:0x00000000
[0267.520] I> 37) Base:0xf7fc0000 Size:0x00020000
[0267.525] I> 38) Base:0x84000000 Size:0x00400000
[0267.529] I> 39) Base:0x96000000 Size:0x02000000
[0267.534] I> 40) Base:0x84800000 Size:0x00b00000
[0267.538] I> 41) Base:0xf7f00000 Size:0x00080000
[0267.543] I> 42) Base:0x00000000 Size:0x00000000
[0267.547] I> 43) Base:0x00000000 Size:0x00000000
[0267.551] I> Boot-device: eMMC
[0267.576] I> sdmmc ddr50 mode
[0267.579] I> sdmmc bdev is already initialized
[0267.584] I> Reading GPT from 512 for device 00000003
[0267.589] I> Reading GPT from 8388096 for device 00000003
[0267.596] I> Found 6 partitions in 00000003 device
[0267.600] I> Reading GPT from 512 for device 00010003
[0267.606] I> Found 17 partitions in 00010003 device
[0267.611] I> Recovery boot_type: 0
[0267.614] I> Entering 3p server
[0267.617] I> Entering into 3p server…
[0267.621] I> Transport interface is USB
[0268.066] I> transport_usbf_priv_open USB configuration success
[0271.504] I> Populate storage info
[0271.519] I> Erasing device 0: 3
[0271.522] I> Erasing device 16384 blocks from block 0
[0271.543] I> Erase successful.
[0271.547] I> Writing device 0: 3
[0271.551] I> Total write size is 16896 bytes
[0271.594] I> Reading GPT from 512 for device 00000003
[0271.600] I> Reading GPT from 8388096 for device 00000003
[0271.606] I> Found 6 partitions in 00000003 device
[0271.611] I> Write successful.
[0271.615] I> Erasing device 1: 3
[0271.618] I> Erasing device 61071360 blocks from block 0
[0272.753] I> Erase successful.
[0272.757] I> Writing device 1: 3
[0272.760] I> Total write size is 512 bytes
[0272.766] I> Write successful.
[0272.770] I> Writing device 1: 3
[0272.773] I> Total write size is 2688 bytes
[0272.779] I> Reading GPT from 512 for device 00010003
[0272.785] I> Found 17 partitions in 00010003 device
[0272.789] I> Write successful.
[0272.793] I> Writing device 1: 3
[0272.796] I> Total write size is 16896 bytes
[0272.802] I> Reading GPT from 512 for device 00010003
[0272.808] I> Found 17 partitions in 00010003 device
[0272.813] I> Write successful.
[0272.817] I> Writing mb1 partition
[0272.820] I> Total write size is 88368 bytes
[0272.847] I> Write successful.
[0272.851] I> Writing spe-fw partition
[0272.855] I> Total write size is 57184 bytes
[0272.883] I> Write successful.
[0272.887] I> Writing mb2 partition
[0272.890] I> Total write size is 60720 bytes
[0272.924] I> Write successful.
[0272.928] I> Writing mts-preboot partition
[0272.932] I> Total write size is 59824 bytes
[0272.971] I> Write successful.
[0272.975] I> Writing device 1: 3
[0272.978] I> Total write size is 512 bytes
[0272.983] I> Write successful.
[0272.987] I> Writing APP partition
[0272.990] I> Total write size is 3359367596 bytes
[0412.121] I> Write successful.
[0412.125] I> Writing mts-bootpack partition
[0412.129] I> Total write size is 2077344 bytes
[0412.217] I> Write successful.
[0412.221] I> Writing cpu-bootloader partition
[0412.225] I> Total write size is 196176 bytes
[0412.245] I> Write successful.
[0412.249] I> Writing bootloader-dtb partition
[0412.254] I> Total write size is 248432 bytes
[0412.272] I> Write successful.
[0412.276] I> Writing secure-os partition
[0412.279] I> Total write size is 54784 bytes
[0412.287] I> Write successful.
[0412.291] I> Writing eks partition
[0412.294] I> Total write size is 1488 bytes
[0412.300] I> Write successful.
[0412.304] I> Writing bpmp-fw partition
[0412.308] I> Total write size is 524880 bytes
[0412.334] I> Write successful.
[0412.338] I> Writing bpmp-fw-dtb partition
[0412.342] I> Total write size is 327072 bytes
[0412.361] I> Write successful.
[0412.364] I> Writing sce-fw partition
[0412.368] I> Total write size is 65488 bytes
[0412.377] I> Write successful.
[0412.380] I> Writing sc7 partition
[0412.384] I> Total write size is 20848 bytes
[0412.390] I> Write successful.
[0412.394] I> Writing kernel partition
[0412.398] I> Total write size is 6717440 bytes
[0412.682] I> Write successful.
[0412.686] I> Writing kernel-dtb partition
[0412.690] I> Total write size is 248032 bytes
[0412.706] I> Write successful.
[0412.716] I> Writing BCT partition
[0412.719] I> Total write size is 3584 bytes
[0412.763] I> Write successful.
[0412.780] I> Writing MB1_BCT partition
[0412.784] I> Total write size is 49968 bytes
[0412.824] I> Write successful.
[0412.835] I> Rebooting : reset-coldboot
[0000.191] I> Welcome to MB2(TBoot-BPMP)(version: 01.00.160913-t186-M-00.00-mobile-f4c42291)
[0000.199] I> Default Heap @ [0xd486400 - 0xd488400]
[0000.204] I> DMA Heap @ [0x84900000 - 0x85300000]
[0000.209] I> bit @ 0xd480000
[0000.211] I> BR-BCT relocated to 0xf7f20000
[0000.216] I> Boot-device: eMMC
[0000.220] I> pmic: reset reason (nverc) : 0x0
[0000.224] I> Reading GPT from 512 for device 00000003
[0000.230] I> Reading GPT from 8388096 for device 00000003
[0000.237] I> Found 6 partitions in 00000003 device
[0000.241] I> Reading GPT from 512 for device 00010003
[0000.248] I> Found 17 partitions in 00010003 device
[0000.253] W> No valid slot number is found in scratch register
[0000.259] W> Return default slot: _a
[0000.262] I> A/B: bin_type (16) slot 0
[0000.266] I> Select partition: bpmp-fw
[0000.269] I> Loading partition bpmp-fw at 0xf7600000
[0000.274] I> Reading two headers - addr:0xf7600000 blocks:1
[0000.280] I> Addr: 0xf7600000, start-block: 58739717, num_blocks: 1
[0000.295] I> Binary(16) of size 524480 is loaded @ 0xf7600000
[0000.300] W> No valid slot number is found in scratch register
[0000.306] W> Return default slot: _a
[0000.309] I> A/B: bin_type (17) slot 0
[0000.313] I> Select partition: bpmp-fw-dtb
[0000.317] I> Loading partition bpmp-fw-dtb at 0xf77f0000
[0000.322] I> Reading two headers - addr:0xf77f0000 blocks:1
[0000.328] I> Addr: 0xf77f0000, start-block: 58740925, num_blocks: 1
[0000.339] I> Binary(17) of size 326672 is loaded @ 0xf77b0200
[0000.467] I> BPMP-FW load address = 0xf7600000
[0000.471] I> BPMP-FW DTB load address = 0x501b0200
[0000.476] I> Loading SCE-FW …
[0000.479] W> No valid slot number is found in scratch register
[0000.485] W> Return default slot: _a
[0000.488] I> A/B: bin_type (12) slot 0
[0000.492] I> Select partition: sce-fw
[0000.495] I> Loading partition sce-fw at 0xf7800000
[0000.500] I> Reading two headers - addr:0xf7800000 blocks:1
[0000.506] I> Addr: 0xf7800000, start-block: 58741925, num_blocks: 1
[0000.514] I> Binary(12) of size 65088 is loaded @ 0xf7800000
[0000.520] I> Init SCE
[0000.522] I> Copy BTCM section
[0000.525] W> No valid slot number is found in scratch register
[0000.530] W> Return default slot: _a
[0000.534] I> A/B: bin_type (13) slot 0
[0000.537] I> Select partition: cpu-bootloader
[0000.542] I> Loading partition cpu-bootloader at 0x96000000
[0000.547] I> Reading two headers - addr:0x96000000 blocks:1
[0000.553] I> Addr: 0x96000000, start-block: 58732545, num_blocks: 1
[0000.563] I> Binary(13) of size 195776 is loaded @ 0x96000000
[0000.568] W> No valid slot number is found in scratch register
[0000.574] W> Return default slot: _a
[0000.578] I> A/B: bin_type (20) slot 0
[0000.581] I> Select partition: bootloader-dtb
[0000.585] I> Loading partition bootloader-dtb at 0x85300000
[0000.591] I> Reading two headers - addr:0x85300000 blocks:1
[0000.596] I> Addr: 0x85300000, start-block: 58733057, num_blocks: 1
[0000.607] I> Binary(20) of size 248032 is loaded @ 0x85300000
[0000.613] I> MB2-params @ 0xf7f00000
[0000.616] I> CPUBL-params @ 0xf7f00000
[0000.620] I> CPU-BL loaded at : 0x96000000
[0000.624] I> Loading TOS …
[0000.627] W> No valid slot number is found in scratch register
[0000.632] W> Return default slot: _a
[0000.636] I> A/B: bin_type (14) slot 0
[0000.639] I> Select partition: secure-os
[0000.643] I> Loading partition secure-os at 0x8490f400
[0000.648] I> Reading two headers - addr:0x8490f400 blocks:1
[0000.654] I> Addr: 0x8490f400, start-block: 58733569, num_blocks: 1
[0000.662] I> Binary(14) of size 54384 is loaded @ 0x8490f400
[0000.668] I> Copying Monitor (length: 0xd270) from 0x8490f600 to 0x40000000
[0000.675] I> Erasing Monitor @ 0x8490f600
[0000.679] I> Unhalting SCE
[0000.683] I> Waypoint2-ACK: 0x5200b8d0
[0000.687] I> MB2(TBoot-BPMP) done
[0001.049] I> Welcome to Cboot
[0001.052] I> Cboot Version: 00.00.2014.50-t186-fabbc56c
[0001.057] I> CPU-BL Params @ 0xf7f00000
[0001.060] I> 0) Base:0x00000000 Size:0x00000000
[0001.065] I> 1) Base:0xf7e00000 Size:0x00100000
[0001.069] I> 2) Base:0xf7d00000 Size:0x00100000
[0001.074] I> 3) Base:0xf7c00000 Size:0x00100000
[0001.078] I> 4) Base:0xf7b00000 Size:0x00100000
[0001.082] I> 5) Base:0xf7a00000 Size:0x00100000
[0001.087] I> 6) Base:0xf7600000 Size:0x00200000
[0001.091] I> 7) Base:0xf7000000 Size:0x00400000
[0001.096] I> 8) Base:0xf7900000 Size:0x00100000
[0001.100] I> 9) Base:0xf7800000 Size:0x00100000
[0001.105] I> 10) Base:0xf6800000 Size:0x00800000
[0001.109] I> 11) Base:0x30000000 Size:0x00040000
[0001.113] I> 12) Base:0xf7500000 Size:0x00100000
[0001.118] I> 13) Base:0x30040000 Size:0x00001000
[0001.122] I> 14) Base:0x30048000 Size:0x00001000
[0001.127] I> 15) Base:0x30049000 Size:0x00001000
[0001.131] I> 16) Base:0x3004a000 Size:0x00001000
[0001.136] I> 17) Base:0x3004b000 Size:0x00001000
[0001.140] I> 18) Base:0x3004c000 Size:0x00001000
[0001.144] I> 19) Base:0x3004d000 Size:0x00001000
[0001.149] I> 20) Base:0x3004e000 Size:0x00001000
[0001.153] I> 21) Base:0x3004f000 Size:0x00001000
[0001.158] I> 22) Base:0x00000000 Size:0x00000000
[0001.162] I> 23) Base:0xf7ff0000 Size:0x00010000
[0001.167] I> 24) Base:0x00000000 Size:0x00000000
[0001.171] I> 25) Base:0x00000000 Size:0x00000000
[0001.175] I> 26) Base:0x00000000 Size:0x00000000
[0001.180] I> 27) Base:0x00000000 Size:0x00000000
[0001.184] I> 28) Base:0x84400000 Size:0x00400000
[0001.189] I> 29) Base:0x30000000 Size:0x00010000
[0001.193] I> 30) Base:0xf8000000 Size:0x08000000
[0001.198] I> 31) Base:0x00000000 Size:0x00000000
[0001.202] I> 32) Base:0xf6000000 Size:0x00600000
[0001.206] I> 33) Base:0x80000000 Size:0x76000000
[0001.211] I> 34) Base:0x100000000 Size:0x180000000
[0001.215] I> 35) Base:0x00000000 Size:0x00000000
[0001.220] I> 36) Base:0x00000000 Size:0x00000000
[0001.224] I> 37) Base:0xf7fc0000 Size:0x00020000
[0001.229] I> 38) Base:0x84000000 Size:0x00400000
[0001.233] I> 39) Base:0x96000000 Size:0x02000000
[0001.238] I> 40) Base:0x84800000 Size:0x00b00000
[0001.242] I> 41) Base:0xf7f00000 Size:0x00080000
[0001.246] I> 42) Base:0x00000000 Size:0x00000000
[0001.251] I> 43) Base:0x00000000 Size:0x00000000
[0001.255] platform_init_interrupts-121, 1*
[0001.260] Interrupts Init done
[0001.263] calling constructors
[0001.266] initializing heap
[0001.268] initializing threads
[0001.272] initializing timers
[0001.275] creating bootstrap completion thread
[0001.279] top of bootstrap2()
[0001.282] CPU: ARM Cortex A57
[0001.285] CPU: MIDR: 0x411FD073, MPIDR: 0x80000100
[0001.290] initializing platform
[0001.294] I> Boot-device: eMMC
[0001.297] I> odm data is 1090000
[0001.300] I> Reading GPT from 512 for device 00000003
[0001.306] I> Reading GPT from 8388096 for device 00000003
[0001.313] I> Found 6 partitions in 00000003 device
[0001.317] I> Reading GPT from 512 for device 00010003
[0001.323] I> Found 17 partitions in 00010003 device
[0001.328] W> No valid slot number is found in scratch register
[0001.333] W> Return default slot: _a
[0001.337] I> A/B: bin_type (1) slot 0
[0001.340] I> Select partition: kernel-dtb
[0001.344] I> Loading partition kernel-dtb at 0x92000000
[0001.353] I> Kernel_dtb @0x92000000
[0001.356] I> Bl_dtb @0x85300000
[0001.359] I> gpio framework initialized
[0001.363] I> tegrabl_gpio_driver_register: register ‘tegra_gpio_main_driver’ driver
[0001.370] I> tegrabl_gpio_driver_register: register ‘tegra_gpio_aon_driver’ driver
[0001.378] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xee
[0001.386] I> tegrabl_gpio_driver_register: register ‘tca9539_gpio_driver’ driver
[0001.393] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xe8
[0001.402] I> tegrabl_gpio_driver_register: register ‘tca9539_gpio_driver’ driver
[0001.409] E> tegrabl_blob_init: BMP partition does not have valid Blob
[0001.416] E> tegrabl_load_bmp_blob: BMP blob initialization failed
[0001.422] W> Loading bmp blob to memory failed
[0001.430] I> Find /i2c@c250000’s alias i2c7
[0001.434] I> Reading eeprom i2c=7 address=0x50
[0001.463] I> Device at /i2c@c250000:0x50
[0001.467] I> Reading eeprom i2c=7 address=0x57
[0001.496] I> Device at /i2c@c250000:0x57
[0001.501] I> Find /i2c@c240000’s alias i2c1
[0001.505] I> Reading eeprom i2c=1 address=0x51
[0001.511] I> Eeprom read failed 0x1a800027
[0001.515] I> Find /i2c@3160000’s alias i2c0
[0001.519] I> Reading eeprom i2c=0 address=0x50
[0001.524] I> Eeprom read failed 0x1a800027
[0001.529] I> Find /i2c@3180000’s alias i2c2
[0001.533] I> Reading eeprom i2c=2 address=0x54
[0001.538] I> Enabling gpio chip_id = 2, gpio pin = 9
[0001.568] I> Disabling gpio chip_id = 2, gpio pin = 9
[0001.573] I> Device at /i2c@3180000:0x54
[0001.577] I> create_pm_ids: id: 3310-1000-B00-E, len: 15
[0001.582] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0001.593] I> create_pm_ids: id: 2597-0000-501-B, len: 15
[0001.598] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0001.609] I> create_pm_ids: id: 3326-1000-100-M, len: 15
[0001.614] I> config: mem-type:ff,power-config:ff,misc-config:ff,modem-config:ff,touch-config:ff,display-config:ff, len: 93
[0001.625] initializing target
[0001.628] calling apps_init()
[0001.631] starting app android_boot_app
[0001.635] I> Gpio keyboard init success
[0001.639] I> Kernel type = Normal
[0001.642] I> Loading kernel/boot.img …
[0001.646] W> No valid slot number is found in scratch register
[0001.652] W> Return default slot: _a
[0001.655] I> A/B: bin_type (0) slot 0
[0001.658] I> Select partition: kernel
[0001.662] I> Loading partition kernel at 0xa8000000
[0001.743] W> No valid slot number is found in scratch register
[0001.749] W> Return default slot: _a
[0001.752] I> A/B: bin_type (1) slot 0
[0001.756] I> Select partition: kernel-dtb
[0001.759] I> Loading partition kernel-dtb at 0x92000000
[0001.768] I> Kernel DTB @ 0x92000000
[0001.772] I> Verified boot state = Orange
[0001.775] E> tegrabl_display_clear: display is not initialized
[0001.781] I> Checking boot.img header magic … [0001.785] I> [OK]
[0001.787] I> Valid boot.img @ 0xa8000000
[0001.791] I> decompressor handler not found
[0001.795] I> Copying kernel image (462634 bytes) from 0xa8000800 to 0x80080000 … [0001.802] I> Done
[0001.804] I> Move ramdisk (len: 6252235) from 0xa8071800 to 0x98000000
[0001.813] I> Updated bpmp info to DTB
[0001.819] I> Ramdisk: Base: 0x98000000; Size: 0x5f66cb
[0001.824] I> Updated initrd info to DTB
[0001.828] I> disabled_core_mask: 0xffffff0c
[0001.832] I> Kernel type = Normal
[0001.835] I> add_serialno: Serial Num = 0320817136116
[0001.840] W> No valid slot number is found in scratch register
[0001.845] W> Return default slot: _a
[0001.849] I> Linux Cmdline: root=/dev/mmcblk0p1 rw rootwait fbcon=map:0 net.ifnames=0 console=tty0 OS=l4t console=ttyS0,115200n8 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0
[0001.888] I> Updated bootarg info to DTB
[0001.893] I> eeprom_get_mac_addr: MAC (type: 0): 00:04:4b:8c:51:b0
[0001.899] I> eeprom_get_mac_addr: MAC (type: 1): 00:04:4b:8c:51:b1
[0001.905] I> eeprom_get_mac_addr: MAC (type: 2): 00:04:4b:8c:51:b2
[0001.911] E> “ids” doesn’t exist, creating
[0001.915] E> “connection” doesn’t exist, creating
[0001.920] E> “configs” doesn’t exist, creating
[0001.924] I> create_pm_ids: id: 3310-1000-B00-E, len: 15
[0001.929] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0001.940] I> create_pm_ids: id: 2597-0000-501-B, len: 15
[0001.945] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0001.956] I> create_pm_ids: id: 3326-1000-100-M, len: 15
[0001.962] I> config: mem-type:ff,power-config:ff,misc-config:ff,modem-config:ff,touch-config:ff,display-config:ff, len: 93
[0001.972] I> Adding plugin-manager/ids/3310-1000-B00=/i2c@c250000:module@0x50
[0001.979] E> “i2c@c250000” doesn’t exist, creating
[0001.984] E> “module@0x50” doesn’t exist, creating
[0001.989] I> Adding plugin-manager/ids/2597-0000-501=/i2c@c250000:module@0x57
[0001.996] E> “module@0x57” doesn’t exist, creating
[0002.001] I> Adding plugin-manager/ids/3326-1000-100=/i2c@3180000:module@0x54
[0002.008] E> “i2c@3180000” doesn’t exist, creating
[0002.013] E> “module@0x54” doesn’t exist, creating
[0002.019] I> Adding plugin-manager/ids/3310-1000-B00-E
[0002.026] I> Adding plugin-manager/configs/3310-mem-type 00
[0002.032] I> Adding plugin-manager/configs/3310-power-config 00
[0002.038] I> Adding plugin-manager/configs/3310-misc-config 00
[0002.043] I> Adding plugin-manager/configs/3310-modem-config 00
[0002.049] I> Adding plugin-manager/configs/3310-touch-config 00
[0002.055] I> Adding plugin-manager/configs/3310-display-config 00
[0002.061] E> “chip-id” doesn’t exist, creating
[0002.065] I> Adding plugin-manager/chip-id/A02P
[0002.072] I> Updated memory info to DTB
[0002.077] E> “reset” doesn’t exist, creating
[0002.081] E> “pmc-reset-reason” doesn’t exist, creating
[0002.087] E> “pmic-reset-reason” doesn’t exist, creating
[0002.092] I> disabled_core_mask: 0xffffff0c
[0002.103] I> tegrabl_load_kernel_and_dtb: Done
U-Boot 2016.07-g5971907 (Mar 01 2017 - 21:06:45 -0800)
TEGRA186
Model: NVIDIA P2771-0000-500
DRAM: 7.8 GiB
MC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: eth0: ethernet@2490000
Hit any key to stop autoboot: 0
MMC: no card present
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1…
starting USB…
No controllers found
USB is stopped. Please issue ‘usb start’ first.
starting USB…
ethernet@2490000 Waiting for PHY auto negotiation to complete… TIMEOUT !
ERROR: phy_startup() failed: -110
at /dvs/git/dirty/git-master_linux/3rdparty/u-boot/drivers/net/dwc_eth_qos.c:894/eqos_start()
ERROR: FAILED: -110
at /dvs/git/dirty/git-master_linux/3rdparty/u-boot/drivers/net/dwc_eth_qos.c:1122/eqos_start()
missing environment variable: pxeuuid
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/01-00-04-4b-8c-51-b2
ethernet@2490000 Waiting for PHY auto negotiation to complete… done
*** ERROR: serverip' not set missing environment variable: bootfile Retrieving file: pxelinux.cfg/00000000 ethernet@2490000 Waiting for PHY auto negotiation to complete...... done *** ERROR: serverip’ not set
*** ERROR: serverip' not set missing environment variable: bootfile Retrieving file: pxelinux.cfg/000000 ethernet@2490000 Waiting for PHY auto negotiation to complete...... done *** ERROR: serverip’ not set
*** ERROR: serverip' not set missing environment variable: bootfile Retrieving file: pxelinux.cfg/0000 ethernet@2490000 Waiting for PHY auto negotiation to complete.... done *** ERROR: serverip’ not set
*** ERROR: serverip' not set missing environment variable: bootfile Retrieving file: pxelinux.cfg/00 ethernet@2490000 Waiting for PHY auto negotiation to complete.... done *** ERROR: serverip’ not set
*** ERROR: serverip' not set missing environment variable: bootfile Retrieving file: pxelinux.cfg/default-arm-tegra186 ethernet@2490000 Waiting for PHY auto negotiation to complete.... done *** ERROR: serverip’ not set
*** ERROR: serverip' not set missing environment variable: bootfile Retrieving file: pxelinux.cfg/default ethernet@2490000 Waiting for PHY auto negotiation to complete.... done *** ERROR: serverip’ not set
Config file not found
starting USB…
BOOTP broadcast 1
BOOTP broadcast 2
DHCP client bound to address 192.168.1.208 (282 ms)
Using ethernet@2490000 device
TFTP from server 192.168.1.1; our IP address is 192.168.1.208
Filename ‘boot.scr.uimg’.
Load address: 0x90000000
Loading: T T T T T T T T T T
Retry count exceeded; starting again
ERROR: FAILED: -110
Tegra186 (P2771-0000-500) # ping 192.168.1.216
ethernet@2490000 Waiting for PHY auto negotiation to complete…user interrupt!
ERROR: phy_startup() failed: -4
ERROR: FAILED: -4
ping failed; host 192.168.1.216 is not alive
Tegra186 (P2771-0000-500) # ping 192.168.1.208
ERROR: FAILED: -4
ping failed; host 192.168.1.208 is not alive
Tegra186 (P2771-0000-500) # ping 192.168.1.1
ERROR: FAILED: -110
ping failed; host 192.168.1.1 is not alive
Tegra186 (P2771-0000-500) # [0000.183] I> Welcome to MB2(TBoot-BPMP)(version: 01.00.160913-t186-M-00.00-mobile-f4c42291)
[0000.191] I> Default Heap @ [0xd486400 - 0xd488400]
[0000.196] I> DMA Heap @ [0x84900000 - 0x85300000]
[0000.201] I> bit @ 0xd480000
[0000.204] I> BR-BCT relocated to 0xf7f20000
[0000.208] I> Boot-device: eMMC
[0000.212] I> pmic: reset reason (nverc) : 0x80
[0000.216] I> Reading GPT from 512 for device 00000003
[0000.222] I> Reading GPT from 8388096 for device 00000003
[0000.229] I> Found 6 partitions in 00000003 device
[0000.234] I> Reading GPT from 512 for device 00010003
[0000.240] I> Found 17 partitions in 00010003 device
[0000.246] W> No valid slot number is found in scratch register
[0000.251] W> Return default slot: _a
[0000.255] I> A/B: bin_type (16) slot 0
[0000.258] I> Select partition: bpmp-fw
[0000.262] I> Loading partition bpmp-fw at 0xf7600000
[0000.267] I> Reading two headers - addr:0xf7600000 blocks:1
[0000.272] I> Addr: 0xf7600000, start-block: 58739717, num_blocks: 1
[0000.287] I> Binary(16) of size 524480 is loaded @ 0xf7600000
[0000.293] W> No valid slot number is found in scratch register
[0000.298] W> Return default slot: _a
[0000.302] I> A/B: bin_type (17) slot 0
[0000.305] I> Select partition: bpmp-fw-dtb
[0000.309] I> Loading partition bpmp-fw-dtb at 0xf77f0000
[0000.314] I> Reading two headers - addr:0xf77f0000 blocks:1
[0000.320] I> Addr: 0xf77f0000, start-block: 58740925, num_blocks: 1
[0000.332] I> Binary(17) of size 326672 is loaded @ 0xf77b0200
[0000.459] I> BPMP-FW load address = 0xf7600000
[0000.464] I> BPMP-FW DTB load address = 0x501b0200
[0000.468] I> Loading SCE-FW …
[0000.471] W> No valid slot number is found in scratch register
[0000.477] W> Return default slot: _a
[0000.481] I> A/B: bin_type (12) slot 0
[0000.484] I> Select partition: sce-fw
[0000.488] I> Loading partition sce-fw at 0xf7800000
[0000.492] I> Reading two headers - addr:0xf7800000 blocks:1
[0000.498] I> Addr: 0xf7800000, start-block: 58741925, num_blocks: 1
[0000.506] I> Binary(12) of size 65088 is loaded @ 0xf7800000
[0000.512] I> Init SCE
[0000.514] I> Copy BTCM section
[0000.517] W> No valid slot number is found in scratch register
[0000.523] W> Return default slot: _a
[0000.526] I> A/B: bin_type (13) slot 0
[0000.530] I> Select partition: cpu-bootloader
[0000.534] I> Loading partition cpu-bootloader at 0x96000000
[0000.539] I> Reading two headers - addr:0x96000000 blocks:1
[0000.545] I> Addr: 0x96000000, start-block: 58732545, num_blocks: 1
[0000.555] I> Binary(13) of size 195776 is loaded @ 0x96000000
[0000.561] W> No valid slot number is found in scratch register
[0000.566] W> Return default slot: _a
[0000.570] I> A/B: bin_type (20) slot 0
[0000.574] I> Select partition: bootloader-dtb
[0000.578] I> Loading partition bootloader-dtb at 0x85300000
[0000.583] I> Reading two headers - addr:0x85300000 blocks:1
[0000.589] I> Addr: 0x85300000, start-block: 58733057, num_blocks: 1
[0000.599] I> Binary(20) of size 248032 is loaded @ 0x85300000
[0000.605] I> MB2-params @ 0xf7f00000
[0000.609] I> CPUBL-params @ 0xf7f00000
[0000.612] I> CPU-BL loaded at : 0x96000000
[0000.616] I> Loading TOS …
[0000.619] W> No valid slot number is found in scratch register
[0000.625] W> Return default slot: _a
[0000.628] I> A/B: bin_type (14) slot 0
[0000.632] I> Select partition: secure-os
[0000.635] I> Loading partition secure-os at 0x8490f400
[0000.640] I> Reading two headers - addr:0x8490f400 blocks:1
[0000.646] I> Addr: 0x8490f400, start-block: 58733569, num_blocks: 1
[0000.654] I> Binary(14) of size 54384 is loaded @ 0x8490f400
[0000.660] I> Copying Monitor (length: 0xd270) from 0x8490f600 to 0x40000000
[0000.667] I> Erasing Monitor @ 0x8490f600
[0000.671] I> Unhalting SCE
[0000.675] I> Waypoint2-ACK: 0x5200b8d0
[0000.679] I> MB2(TBoot-BPMP) done
[0001.041] I> Welcome to Cboot
[0001.044] I> Cboot Version: 00.00.2014.50-t186-fabbc56c
[0001.049] I> CPU-BL Params @ 0xf7f00000
[0001.052] I> 0) Base:0x00000000 Size:0x00000000
[0001.057] I> 1) Base:0xf7e00000 Size:0x00100000
[0001.061] I> 2) Base:0xf7d00000 Size:0x00100000
[0001.065] I> 3) Base:0xf7c00000 Size:0x00100000
[0001.070] I> 4) Base:0xf7b00000 Size:0x00100000
[0001.074] I> 5) Base:0xf7a00000 Size:0x00100000
[0001.079] I> 6) Base:0xf7600000 Size:0x00200000
[0001.083] I> 7) Base:0xf7000000 Size:0x00400000
[0001.088] I> 8) Base:0xf7900000 Size:0x00100000
[0001.092] I> 9) Base:0xf7800000 Size:0x00100000
[0001.096] I> 10) Base:0xf6800000 Size:0x00800000
[0001.101] I> 11) Base:0x30000000 Size:0x00040000
[0001.105] I> 12) Base:0xf7500000 Size:0x00100000
[0001.110] I> 13) Base:0x30040000 Size:0x00001000
[0001.114] I> 14) Base:0x30048000 Size:0x00001000
[0001.119] I> 15) Base:0x30049000 Size:0x00001000
[0001.123] I> 16) Base:0x3004a000 Size:0x00001000
[0001.127] I> 17) Base:0x3004b000 Size:0x00001000
[0001.132] I> 18) Base:0x3004c000 Size:0x00001000
[0001.136] I> 19) Base:0x3004d000 Size:0x00001000
[0001.141] I> 20) Base:0x3004e000 Size:0x00001000
[0001.145] I> 21) Base:0x3004f000 Size:0x00001000
[0001.150] I> 22) Base:0x00000000 Size:0x00000000
[0001.154] I> 23) Base:0xf7ff0000 Size:0x00010000
[0001.158] I> 24) Base:0x00000000 Size:0x00000000
[0001.163] I> 25) Base:0x00000000 Size:0x00000000
[0001.167] I> 26) Base:0x00000000 Size:0x00000000
[0001.172] I> 27) Base:0x00000000 Size:0x00000000
[0001.176] I> 28) Base:0x84400000 Size:0x00400000
[0001.181] I> 29) Base:0x30000000 Size:0x00010000
[0001.185] I> 30) Base:0xf8000000 Size:0x08000000
[0001.189] I> 31) Base:0x00000000 Size:0x00000000
[0001.194] I> 32) Base:0xf6000000 Size:0x00600000
[0001.198] I> 33) Base:0x80000000 Size:0x76000000
[0001.203] I> 34) Base:0x100000000 Size:0x180000000
[0001.207] I> 35) Base:0x00000000 Size:0x00000000
[0001.212] I> 36) Base:0x00000000 Size:0x00000000
[0001.216] I> 37) Base:0xf7fc0000 Size:0x00020000
[0001.221] I> 38) Base:0x84000000 Size:0x00400000
[0001.225] I> 39) Base:0x96000000 Size:0x02000000
[0001.230] I> 40) Base:0x84800000 Size:0x00b00000
[0001.234] I> 41) Base:0xf7f00000 Size:0x00080000
[0001.238] I> 42) Base:0x00000000 Size:0x00000000
[0001.243] I> 43) Base:0x00000000 Size:0x00000000
[0001.247] platform_init_interrupts-121, 1*
[0001.252] Interrupts Init done
[0001.255] calling constructors
[0001.258] initializing heap
[0001.260] initializing threads
[0001.264] initializing timers
[0001.267] creating bootstrap completion thread
[0001.271] top of bootstrap2()
[0001.274] CPU: ARM Cortex A57
[0001.277] CPU: MIDR: 0x411FD073, MPIDR: 0x80000100
[0001.282] initializing platform
[0001.286] I> Boot-device: eMMC
[0001.289] I> odm data is 1090000
[0001.292] I> Reading GPT from 512 for device 00000003
[0001.298] I> Reading GPT from 8388096 for device 00000003
[0001.305] I> Found 6 partitions in 00000003 device
[0001.309] I> Reading GPT from 512 for device 00010003
[0001.315] I> Found 17 partitions in 00010003 device
[0001.320] W> No valid slot number is found in scratch register
[0001.325] W> Return default slot: _a
[0001.329] I> A/B: bin_type (1) slot 0
[0001.332] I> Select partition: kernel-dtb
[0001.336] I> Loading partition kernel-dtb at 0x92000000
[0001.345] I> Kernel_dtb @0x92000000
[0001.348] I> Bl_dtb @0x85300000
[0001.351] I> gpio framework initialized
[0001.355] I> tegrabl_gpio_driver_register: register ‘tegra_gpio_main_driver’ driver
[0001.362] I> tegrabl_gpio_driver_register: register ‘tegra_gpio_aon_driver’ driver
[0001.370] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xee
[0001.378] I> tegrabl_gpio_driver_register: register ‘tca9539_gpio_driver’ driver
[0001.385] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xe8
[0001.394] I> tegrabl_gpio_driver_register: register ‘tca9539_gpio_driver’ driver
[0001.402] E> tegrabl_blob_init: BMP partition does not have valid Blob
[0001.408] E> tegrabl_load_bmp_blob: BMP blob initialization failed
[0001.414] W> Loading bmp blob to memory failed
[0001.422] I> Find /i2c@c250000’s alias i2c7
[0001.426] I> Reading eeprom i2c=7 address=0x50
[0001.456] I> Device at /i2c@c250000:0x50
[0001.459] I> Reading eeprom i2c=7 address=0x57
[0001.488] I> Device at /i2c@c250000:0x57
[0001.493] I> Find /i2c@c240000’s alias i2c1
[0001.497] I> Reading eeprom i2c=1 address=0x51
[0001.503] I> Eeprom read failed 0x1a800027
[0001.507] I> Find /i2c@3160000’s alias i2c0
[0001.511] I> Reading eeprom i2c=0 address=0x50
[0001.516] I> Eeprom read failed 0x1a800027
[0001.521] I> Find /i2c@3180000’s alias i2c2
[0001.525] I> Reading eeprom i2c=2 address=0x54
[0001.530] I> Enabling gpio chip_id = 2, gpio pin = 9
[0001.560] I> Disabling gpio chip_id = 2, gpio pin = 9
[0001.565] I> Device at /i2c@3180000:0x54
[0001.569] I> create_pm_ids: id: 3310-1000-B00-E, len: 15
[0001.574] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0001.585] I> create_pm_ids: id: 2597-0000-501-B, len: 15
[0001.590] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0001.601] I> create_pm_ids: id: 3326-1000-100-M, len: 15
[0001.606] I> config: mem-type:ff,power-config:ff,misc-config:ff,modem-config:ff,touch-config:ff,display-config:ff, len: 93
[0001.617] initializing target
[0001.620] calling apps_init()
[0001.623] starting app android_boot_app
[0001.627] I> Gpio keyboard init success
[0001.631] I> Kernel type = Normal
[0001.634] I> Loading kernel/boot.img …
[0001.638] W> No valid slot number is found in scratch register
[0001.644] W> Return default slot: _a
[0001.647] I> A/B: bin_type (0) slot 0
[0001.650] I> Select partition: kernel
[0001.654] I> Loading partition kernel at 0xa8000000
[0001.735] W> No valid slot number is found in scratch register
[0001.741] W> Return default slot: _a
[0001.744] I> A/B: bin_type (1) slot 0
[0001.748] I> Select partition: kernel-dtb
[0001.751] I> Loading partition kernel-dtb at 0x92000000
[0001.760] I> Kernel DTB @ 0x92000000
[0001.764] I> Verified boot state = Orange
[0001.767] E> tegrabl_display_clear: display is not initialized
[0001.773] I> Checking boot.img header magic … [0001.777] I> [OK]
[0001.779] I> Valid boot.img @ 0xa8000000
[0001.783] I> decompressor handler not found
[0001.787] I> Copying kernel image (462634 bytes) from 0xa8000800 to 0x80080000 … [0001.794] I> Done
[0001.796] I> Move ramdisk (len: 6252235) from 0xa8071800 to 0x98000000
[0001.805] I> Updated bpmp info to DTB
[0001.811] I> Ramdisk: Base: 0x98000000; Size: 0x5f66cb
[0001.816] I> Updated initrd info to DTB
[0001.820] I> disabled_core_mask: 0xffffff0c
[0001.824] I> Kernel type = Normal
[0001.827] I> add_serialno: Serial Num = 0320817136116
[0001.832] W> No valid slot number is found in scratch register
[0001.837] W> Return default slot: _a
[0001.841] I> Linux Cmdline: root=/dev/mmcblk0p1 rw rootwait fbcon=map:0 net.ifnames=0 console=tty0 OS=l4t console=ttyS0,115200n8 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0
[0001.880] I> Updated bootarg info to DTB
[0001.885] I> eeprom_get_mac_addr: MAC (type: 0): 00:04:4b:8c:51:b0
[0001.891] I> eeprom_get_mac_addr: MAC (type: 1): 00:04:4b:8c:51:b1
[0001.897] I> eeprom_get_mac_addr: MAC (type: 2): 00:04:4b:8c:51:b2
[0001.903] E> “ids” doesn’t exist, creating
[0001.907] E> “connection” doesn’t exist, creating
[0001.912] E> “configs” doesn’t exist, creating
[0001.916] I> create_pm_ids: id: 3310-1000-B00-E, len: 15
[0001.921] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0001.932] I> create_pm_ids: id: 2597-0000-501-B, len: 15
[0001.938] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00, len: 93
[0001.948] I> create_pm_ids: id: 3326-1000-100-M, len: 15
[0001.954] I> config: mem-type:ff,power-config:ff,misc-config:ff,modem-config:ff,touch-config:ff,display-config:ff, len: 93
[0001.964] I> Adding plugin-manager/ids/3310-1000-B00=/i2c@c250000:module@0x50
[0001.972] E> “i2c@c250000” doesn’t exist, creating
[0001.976] E> “module@0x50” doesn’t exist, creating
[0001.981] I> Adding plugin-manager/ids/2597-0000-501=/i2c@c250000:module@0x57
[0001.988] E> “module@0x57” doesn’t exist, creating
[0001.993] I> Adding plugin-manager/ids/3326-1000-100=/i2c@3180000:module@0x54
[0002.000] E> “i2c@3180000” doesn’t exist, creating
[0002.005] E> “module@0x54” doesn’t exist, creating
[0002.011] I> Adding plugin-manager/ids/3310-1000-B00-E
[0002.018] I> Adding plugin-manager/configs/3310-mem-type 00
[0002.024] I> Adding plugin-manager/configs/3310-power-config 00
[0002.030] I> Adding plugin-manager/configs/3310-misc-config 00
[0002.035] I> Adding plugin-manager/configs/3310-modem-config 00
[0002.041] I> Adding plugin-manager/configs/3310-touch-config 00
[0002.047] I> Adding plugin-manager/configs/3310-display-config 00
[0002.053] E> “chip-id” doesn’t exist, creating
[0002.057] I> Adding plugin-manager/chip-id/A02P
[0002.064] I> Updated memory info to DTB
[0002.069] E> “reset” doesn’t exist, creating
[0002.073] E> “pmc-reset-reason” doesn’t exist, creating
[0002.079] E> “pmic-reset-reason” doesn’t exist, creating
[0002.084] I> disabled_core_mask: 0xffffff0c
[0002.095] I> tegrabl_load_kernel_and_dtb: Done
TEGRA186
DRAM: 7.8 GiB
In: serial
Out: serial
Err: serial
Scanning mmc 0:1…
starting USB…
starting USB…
ERROR: FAILED: -110
*** ERROR: serverip' not set missing environment variable: bootfile Retrieving file: pxelinux.cfg/00000000 ethernet@2490000 Waiting for PHY auto negotiation to complete........ done *** ERROR: serverip’ not set
*** ERROR: serverip' not set missing environment variable: bootfile Retrieving file: pxelinux.cfg/000000 ethernet@2490000 Waiting for PHY auto negotiation to complete........ done *** ERROR: serverip’ not set
*** ERROR: serverip' not set missing environment variable: bootfile Retrieving file: pxelinux.cfg/0000 ethernet@2490000 Waiting for PHY auto negotiation to complete........ done *** ERROR: serverip’ not set
*** ERROR: serverip' not set missing environment variable: bootfile Retrieving file: pxelinux.cfg/00 ethernet@2490000 Waiting for PHY auto negotiation to complete........ done *** ERROR: serverip’ not set
*** ERROR: serverip' not set missing environment variable: bootfile Retrieving file: pxelinux.cfg/default-arm-tegra186 ethernet@2490000 Waiting for PHY auto negotiation to complete...... done *** ERROR: serverip’ not set
*** ERROR: serverip' not set missing environment variable: bootfile Retrieving file: pxelinux.cfg/default ethernet@2490000 Waiting for PHY auto negotiation to complete...... done *** ERROR: serverip’ not set
starting USB…
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
BOOTP broadcast 7
BOOTP broadcast 8
BOOTP broadcast 9
BOOTP broadcast 10
BOOTP broadcast 11
BOOTP broadcast 12
BOOTP broadcast 13
BOOTP broadcast 14
BOOTP broadcast 15
BOOTP broadcast 16
BOOTP broadcast 17
Retry time exceeded; starting again
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
BOOTP broadcast 7
BOOTP broadcast 8
BOOTP broadcast 9
BOOTP broadcast 10
BOOTP broadcast 11
BOOTP broadcast 12
BOOTP broadcast 13
BOOTP broadcast 14
BOOTP broadcast 15
BOOTP broadcast 16
BOOTP broadcast 17
CTRL-A Z for help | 115200 8N1 | NOR | Minicom 2.7 | VT102 | Online 0:15 | ttyUSB0
