I am unable to flash my TX2 with Jetpack 3.0 after repeated attempts. Both host and target are connected to router via ethernet, USBMicro-B is connected to TX2 and host, and I have followed the procedure to place system in Force USB Recovery Mode.
Following the content of the flash_os log
/tegraflash.py --chip 0x18 --applet “/home/tx2/Nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/mb1_recovery_prod.bin” --cmd “dump eeprom boardinfo cvm.bin” --skipuid
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0241 ] Generating RCM messages
[ 0.0316 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 --download rcm /home/tx2/Nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/mb1_recovery_prod.bin 0 0
[ 0.0327 ] RCM 0 is saved as rcm_0.rcm
[ 0.0387 ] RCM 1 is saved as rcm_1.rcm
[ 0.0387 ] List of rcm files are saved in rcm_list.xml
[ 0.0387 ]
[ 0.0387 ] Signing RCM messages
[ 0.0467 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0478 ] Assuming zero filled SBK key
[ 0.0795 ]
[ 0.0795 ] Copying signature to RCM mesages
[ 0.0808 ] tegrarcm_v2 --chip 0x18 --updatesig rcm_list_signed.xml
[ 0.0986 ]
[ 0.0987 ] Boot Rom communication
[ 0.1041 ] tegrarcm_v2 --chip 0x18 --rcm rcm_list_signed.xml --skipuid
[ 0.1410 ]
Error: Return value 8
Command tegrarcm_v2 --chip 0x18 --rcm rcm_list_signed.xml --skipuid
Reading board information failed.
Your assistance would be appreciated.
Thank you
During a flash only the micro-B USB connector matters…you can safely ignore network connections until flash completes and networking for package downloads is setting up.
One thing which is fairly subtle is that between every command to flash or clone the Jetson must have recovery mode restarted, e.g., recovery button held down and reset button pressed between flash attempts. So if you tried to flash twice without setting the Jetson to recovery mode between attempts it will always fail.
The first thing to check is that before each flash attempt make sure it is put back into recovery mode, then verify that this shows output from the PC host before running the flash:
lsusb -d 0955:7c18
Can you verify that the lsusb command shows the Jetson present prior to the flash attempt?
I was able to move past the issue mentioned above. However, I am still unable to complete the flashing process and following is the log:
./tegraflash.py --chip 0x18 --applet “/home/tx2/Nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/mb1_recovery_prod.bin” --cmd “dump eeprom boardinfo cvm.bin” --skipuid
version 1.0.0
[ 0.0052 ] Generating RCM messages
[ 0.0087 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 --download rcm /home/tx2/Nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/mb1_recovery_prod.bin 0 0
[ 0.0097 ] RCM 0 is saved as rcm_0.rcm
[ 0.0141 ] RCM 1 is saved as rcm_1.rcm
[ 0.0141 ] List of rcm files are saved in rcm_list.xml
[ 0.0141 ]
[ 0.0141 ] Signing RCM messages
[ 0.0216 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0229 ] Assuming zero filled SBK key
[ 0.0539 ]
[ 0.0540 ] Copying signature to RCM mesages
[ 0.0551 ] tegrarcm_v2 --chip 0x18 --updatesig rcm_list_signed.xml
[ 0.0858 ]
[ 0.0860 ] Boot Rom communication
[ 0.0932 ] tegrarcm_v2 --chip 0x18 --rcm rcm_list_signed.xml --skipuid
[ 0.0953 ] RCM version 0X180001
[ 0.1078 ] Boot Rom communication completed
[ 1.6292 ]
[ 6.6366 ] Retrieving EEPROM data
[ 6.6368 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/tx2/Nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/cvm.bin
[ 6.6381 ] Applet version 01.00.0000
[ 6.7368 ] Saved platform info in /home/tx2/Nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/cvm.bin
[ 6.9164 ]
Board version(B00)
copying bctfile(/home/tx2/Nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/BCT/P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg)… done.
copying misc_config(/home/tx2/Nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/BCT/tegra186-mb1-bct-misc-si-l4t.cfg)… done.
copying pinmux_config(/home/tx2/Nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/BCT/tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg)… done.
copying pmic_config(/home/tx2/Nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/BCT/tegra186-mb1-bct-pmic-quill-p3310-1000-c03.cfg)… done.
copying pmc_config(/home/tx2/Nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/BCT/tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg)… done.
copying prod_config(/home/tx2/Nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/BCT/tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg)… done.
copying scr_config(/home/tx2/Nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/BCT/minimal_scr.cfg)… done.
copying bootrom_config(/home/tx2/Nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/BCT/tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg)… done.
copying dev_params(/home/tx2/Nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/BCT/emmc.cfg)… done.
Existing bootloader(/home/tx2/Nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/nvtboot_cpu.bin) reused.
copying initrd(/home/tx2/Nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/l4t_initrd.img)… done.
populating kernel to rootfs… done.
populating initrd to rootfs… done.
populating extlinux.conf.emmc to rootfs… done.
populating /home/tx2/Nvidia/64_TX2/Linux_for_Tegra_tx2/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb to rootfs… done.
done.
Making Boot image… done.
Existing sosfile(/home/tx2/Nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/mb1_recovery_prod.bin) reused.
copying tegraboot(/home/tx2/Nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/nvtboot.bin)… done.
Existing mb2blfile(/home/tx2/Nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/nvtboot_recovery.bin) reused.
Existing mtspreboot(/home/tx2/Nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/preboot_d15_prod_cr.bin) reused.
Existing mts(/home/tx2/Nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/mce_mts_d15_prod_cr.bin) reused.
Existing mb1file(/home/tx2/Nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/mb1_prod.bin) reused.
Existing bpffile(/home/tx2/Nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/bpmp.bin) reused.
copying bpfdtbfile(/home/tx2/Nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/tegra186-a02-bpmp-quill-p3310-1000-c01-00-te770d-ucm2.dtb)… done.
Existing scefile(/home/tx2/Nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/camera-rtcpu-sce.bin) reused.
Existing spefile(/home/tx2/Nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/spe.bin) reused.
copying wb0boot(/home/tx2/Nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/warmboot.bin)… done.
Existing tosfile(/home/tx2/Nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/tos.img) reused.
Existing eksfile(/home/tx2/Nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/eks.img) reused.
copying dtbfile(/home/tx2/Nvidia/64_TX2/Linux_for_Tegra_tx2/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb)… done.
Making system.img…
populating rootfs from /home/tx2/Nvidia/64_TX2/Linux_for_Tegra_tx2/rootfs … done.
Sync’ing system.img … done.
Converting RAW image to Sparse image…
---- Raw to Sparse Image Converter v1.0 ----------------------------
0: RAW: 4239360( 1035 blks) ==> 28:4239372
1: SKP: 24576( 6 blks) ==> 4239400:12
2: RAW: 4096( 1 blks) ==> 4239412:4108
3: SKP: 61440( 15 blks) ==> 4243520:12
4: RAW: 4096( 1 blks) ==> 4243532:4108
5: SKP: 33550336( 8191 blks) ==> 4247640:12
6: RAW: 24576( 6 blks) ==> 4247652:24588
7: SKP: 96309248( 23513 blks) ==> 4272240:12
8: RAW: 12288( 3 blks) ==> 4272252:12300
9: SKP: 4431872( 1082 blks) ==> 4284552:12
10: RAW: 77824( 19 blks) ==> 4284564:77836
11: SKP: 24576( 6 blks) ==> 4362400:12
12: RAW: 131072( 32 blks) ==> 4362412:131084
13: SKP: 16384( 4 blks) ==> 4493496:12
14: RAW: 1114112( 272 blks) ==> 4493508:1114124
15: SKP: 16384( 4 blks) ==> 5607632:12
16: RAW: 4096( 1 blks) ==> 5607644:4108
17: SKP: 40960( 10 blks) ==> 5611752:12
18: RAW: 4096( 1 blks) ==> 5611764:4108
19: SKP: 8192( 2 blks) ==> 5615872:12
20: RAW: 86016( 21 blks) ==> 5615884:86028
21: SKP: 4096( 1 blks) ==> 5701912:12
22: RAW: 118784( 29 blks) ==> 5701924:118796
23: SKP: 4096( 1 blks) ==> 5820720:12
24: RAW: 450560( 110 blks) ==> 5820732:450572
25: SKP: 8192( 2 blks) ==> 6271304:12
26: RAW: 487424( 119 blks) ==> 6271316:487436
27: SKP: 24576( 6 blks) ==> 6758752:12
28: RAW: 20480( 5 blks) ==> 6758764:20492
29: SKP: 122880( 30 blks) ==> 6779256:12
30: RAW: 122880( 30 blks) ==> 6779268:122892
31: SKP: 8192( 2 blks) ==> 6902160:12
32: RAW: 954368( 233 blks) ==> 6902172:954380
33: SKP: 94208( 23 blks) ==> 7856552:12
34: RAW: 315392( 77 blks) ==> 7856564:315404
35: SKP: 4096( 1 blks) ==> 8171968:12
36: RAW: 3977216( 971 blks) ==> 8171980:3977228
37: SKP: 69632( 17 blks) ==> 12149208:12
38: RAW: 20480( 5 blks) ==> 12149220:20492
39: SKP: 4096( 1 blks) ==> 12169712:12
40: RAW: 23179264( 5659 blks) ==> 12169724:23179276
41: SKP: 4096( 1 blks) ==> 35349000:12
42: RAW: 8192( 2 blks) ==> 35349012:8204
43: SKP: 4096( 1 blks) ==> 35357216:12
44: RAW: 552960( 135 blks) ==> 35357228:552972
45: SKP: 4096( 1 blks) ==> 35910200:12
46: RAW: 4988928( 1218 blks) ==> 35910212:4988940
47: SKP: 421888( 103 blks) ==> 40899152:12
48: RAW: 15732736( 3841 blks) ==> 40899164:15732748
49: SKP: 4096( 1 blks) ==> 56631912:12
50: RAW: 53248( 13 blks) ==> 56631924:53260
51: SKP: 4096( 1 blks) ==> 56685184:12
52: RAW: 6991872( 1707 blks) ==> 56685196:6991884
53: SKP: 20480( 5 blks) ==> 63677080:12
54: RAW: 5267456( 1286 blks) ==> 63677092:5267468
55: SKP: 237568( 58 blks) ==> 68944560:12
56: RAW: 11509760( 2810 blks) ==> 68944572:11509772
57: SKP: 24576( 6 blks) ==> 80454344:12
58: RAW: 1015808( 248 blks) ==> 80454356:1015820
59: SKP: 32768( 8 blks) ==> 81470176:12
60: RAW: 4988928( 1218 blks) ==> 81470188:4988940
61: SKP: 253952( 62 blks) ==> 86459128:12
62: RAW: 3584000( 875 blks) ==> 86459140:3584012
63: SKP: 610304( 149 blks) ==> 90043152:12
64: RAW: 851968( 208 blks) ==> 90043164:851980
65: SKP: 196608( 48 blks) ==> 90895144:12
66: RAW: 40960( 10 blks) ==> 90895156:40972
67: SKP: 12288( 3 blks) ==> 90936128:12
68: RAW: 720896( 176 blks) ==> 90936140:720908
69: SKP: 12288( 3 blks) ==> 91657048:12
70: RAW: 1257472( 307 blks) ==> 91657060:1257484
71: SKP: 1101824( 269 blks) ==> 92914544:12
72: RAW: 33554432( 8192 blks) ==> 92914556:33554444
73: SKP: 4194304( 1024 blks) ==> 126469000:12
74: RAW: 7884800( 1925 blks) ==> 126469012:7884812
75: SKP: 110592( 27 blks) ==> 134353824:12
76: RAW: 110592( 27 blks) ==> 134353836:110604
77: SKP: 282624( 69 blks) ==> 134464440:12
78: RAW: 67072000( 16375 blks) ==> 134464452:67072012
79: SKP: 36864( 9 blks) ==> 201536464:12
80: RAW: 19320832( 4717 blks) ==> 201536476:19320844
81: SKP: 602112( 147 blks) ==> 220857320:12
82: RAW: 7438336( 1816 blks) ==> 220857332:7438348
83: SKP: 20480( 5 blks) ==> 228295680:12
84: RAW: 450560( 110 blks) ==> 228295692:450572
85: SKP: 479232( 117 blks) ==> 228746264:12
86: RAW: 9437184( 2304 blks) ==> 228746276:9437196
87: SKP: 4194304( 1024 blks) ==> 238183472:12
88: RAW: 9895936( 2416 blks) ==> 238183484:9895948
89: SKP: 40960( 10 blks) ==> 248079432:12
90: RAW: 311296( 76 blks) ==> 248079444:311308
91: SKP: 6529024( 1594 blks) ==> 248390752:12
92: RAW: 12288( 3 blks) ==> 248390764:12300
93: SKP: 4186112( 1022 blks) ==> 248403064:12
94: RAW: 3391488( 828 blks) ==> 248403076:3391500
95: SKP: 4096( 1 blks) ==> 251794576:12
96: RAW: 737280( 180 blks) ==> 251794588:737292
97: SKP: 32768( 8 blks) ==> 252531880:12
98: RAW: 393216( 96 blks) ==> 252531892:393228
99: SKP: 45056( 11 blks) ==> 252925120:12
100: RAW: 1253376( 306 blks) ==> 252925132:1253388
101: SKP: 430080( 105 blks) ==> 254178520:12
102: RAW: 1875968( 458 blks) ==> 254178532:1875980
103: SKP: 49152( 12 blks) ==> 256054512:12
104: RAW: 2015232( 492 blks) ==> 256054524:2015244
105: SKP: 53248( 13 blks) ==> 258069768:12
106: RAW: 77824( 19 blks) ==> 258069780:77836
107: SKP: 20480( 5 blks) ==> 258147616:12
108: RAW: 1236992( 302 blks) ==> 258147628:1237004
109: SKP: 962560( 235 blks) ==> 259384632:12
110: RAW: 25079808( 6123 blks) ==> 259384644:25079820
111: SKP: 8192( 2 blks) ==> 284464464:12
112: RAW: 57196544( 13964 blks) ==> 284464476:57196556
113: SKP: 12288( 3 blks) ==> 341661032:12
114: RAW: 49152( 12 blks) ==> 341661044:49164
115: SKP: 36864( 9 blks) ==> 341710208:12
116: RAW: 9138176( 2231 blks) ==> 341710220:9138188
117: SKP: 16384( 4 blks) ==> 350848408:12
118: RAW: 18952192( 4627 blks) ==> 350848420:18952204
119: SKP: 6950912( 1697 blks) ==> 369800624:12
120: RAW: 10129408( 2473 blks) ==> 369800636:10129420
121: SKP: 94208( 23 blks) ==> 379930056:12
122: RAW: 217088( 53 blks) ==> 379930068:217100
123: SKP: 45056( 11 blks) ==> 380147168:12
124: RAW: 974848( 238 blks) ==> 380147180:974860
125: SKP: 73728( 18 blks) ==> 381122040:12
126: RAW: 48799744( 11914 blks) ==> 381122052:48799756
127: SKP: 4096( 1 blks) ==> 429921808:12
128: RAW: 9244672( 2257 blks) ==> 429921820:9244684
129: SKP: 8192( 2 blks) ==> 439166504:12
130: RAW: 4096( 1 blks) ==> 439166516:4108
131: SKP: 8192( 2 blks) ==> 439170624:12
132: RAW: 16384( 4 blks) ==> 439170636:16396
133: SKP: 4096( 1 blks) ==> 439187032:12
134: RAW: 348160( 85 blks) ==> 439187044:348172
135: SKP: 4096( 1 blks) ==> 439535216:12
136: RAW: 4096( 1 blks) ==> 439535228:4108
137: SKP: 4096( 1 blks) ==> 439539336:12
138: RAW: 409600( 100 blks) ==> 439539348:409612
139: SKP: 4096( 1 blks) ==> 439948960:12
140: RAW: 229376( 56 blks) ==> 439948972:229388
141: SKP: 4096( 1 blks) ==> 440178360:12
142: RAW: 155648( 38 blks) ==> 440178372:155660
143: SKP: 8192( 2 blks) ==> 440334032:12
144: RAW: 180224( 44 blks) ==> 440334044:180236
145: SKP: 8192( 2 blks) ==> 440514280:12
146: RAW: 12288( 3 blks) ==> 440514292:12300
147: SKP: 4096( 1 blks) ==> 440526592:12
148: RAW: 32768( 8 blks) ==> 440526604:32780
149: SKP: 12288( 3 blks) ==> 440559384:12
150: RAW: 36864( 9 blks) ==> 440559396:36876
151: SKP: 4096( 1 blks) ==> 440596272:12
152: RAW: 135168( 33 blks) ==> 440596284:135180
153: SKP: 8192( 2 blks) ==> 440731464:12
154: RAW: 520192( 127 blks) ==> 440731476:520204
155: SKP: 4096( 1 blks) ==> 441251680:12
156: RAW: 28672( 7 blks) ==> 441251692:28684
157: SKP: 4096( 1 blks) ==> 441280376:12
158: RAW: 36864( 9 blks) ==> 441280388:36876
159: SKP: 4096( 1 blks) ==> 441317264:12
160: RAW: 565248( 138 blks) ==> 441317276:565260
161: SKP: 90112( 22 blks) ==> 441882536:12
162: RAW: 815104( 199 blks) ==> 441882548:815116
163: SKP: 102400( 25 blks) ==> 442697664:12
164: RAW: 2662400( 650 blks) ==> 442697676:2662412
165: SKP: 4096( 1 blks) ==> 445360088:12
166: RAW: 258048( 63 blks) ==> 445360100:258060
167: SKP: 4096( 1 blks) ==> 445618160:12
168: RAW: 81920( 20 blks) ==> 445618172:81932
169: SKP: 135168( 33 blks) ==> 445700104:12
170: RAW: 3092480( 755 blks) ==> 445700116:3092492
171: SKP: 16384( 4 blks) ==> 448792608:12
172: RAW: 16384( 4 blks) ==> 448792620:16396
173: SKP: 4096( 1 blks) ==> 448809016:12
174: RAW: 12288( 3 blks) ==> 448809028:12300
175: SKP: 4096( 1 blks) ==> 448821328:12
176: RAW: 1929216( 471 blks) ==> 448821340:1929228
177: SKP: 2265088( 553 blks) ==> 450750568:12
178: RAW: 14102528( 3443 blks) ==> 450750580:14102540
179: SKP: 20480( 5 blks) ==> 464853120:12
180: RAW: 249856( 61 blks) ==> 464853132:249868
181: SKP: 8192( 2 blks) ==> 465103000:12
182: RAW: 184320( 45 blks) ==> 465103012:184332
183: SKP: 4096( 1 blks) ==> 465287344:12
184: RAW: 1253376( 306 blks) ==> 465287356:1253388
185: SKP: 4096( 1 blks) ==> 466540744:12
186: RAW: 790528( 193 blks) ==> 466540756:790540
187: SKP: 159744( 39 blks) ==> 467331296:12
188: RAW: 13959168( 3408 blks) ==> 467331308:13959180
189: SKP: 4096( 1 blks) ==> 481290488:12
190: RAW: 1527808( 373 blks) ==> 481290500:1527820
191: SKP: 1286144( 314 blks) ==> 482818320:12
192: RAW: 13361152( 3262 blks) ==> 482818332:13361164
193: SKP: 16384( 4 blks) ==> 496179496:12
194: RAW: 8192( 2 blks) ==> 496179508:8204
195: SKP: 16384( 4 blks) ==> 496187712:12
196: RAW: 32768( 8 blks) ==> 496187724:32780
197: SKP: 4096( 1 blks) ==> 496220504:12
198: RAW: 4096( 1 blks) ==> 496220516:4108
199: SKP: 12288( 3 blks) ==> 496224624:12
200: RAW: 8192( 2 blks) ==> 496224636:8204
201: SKP: 12288( 3 blks) ==> 496232840:12
202: RAW: 8192( 2 blks) ==> 496232852:8204
203: SKP: 8192( 2 blks) ==> 496241056:12
204: RAW: 28672( 7 blks) ==> 496241068:28684
205: SKP: 4096( 1 blks) ==> 496269752:12
206: RAW: 4096( 1 blks) ==> 496269764:4108
207: SKP: 12288( 3 blks) ==> 496273872:12
208: RAW: 8192( 2 blks) ==> 496273884:8204
209: SKP: 12288( 3 blks) ==> 496282088:12
210: RAW: 32768( 8 blks) ==> 496282100:32780
211: SKP: 12288( 3 blks) ==> 496314880:12
212: RAW: 8192( 2 blks) ==> 496314892:8204
213: SKP: 12288( 3 blks) ==> 496323096:12
214: RAW: 4096( 1 blks) ==> 496323108:4108
215: SKP: 12288( 3 blks) ==> 496327216:12
216: RAW: 8192( 2 blks) ==> 496327228:8204
217: SKP: 12288( 3 blks) ==> 496335432:12
218: RAW: 8192( 2 blks) ==> 496335444:8204
219: SKP: 12288( 3 blks) ==> 496343648:12
220: RAW: 4096( 1 blks) ==> 496343660:4108
221: SKP: 12288( 3 blks) ==> 496347768:12
222: RAW: 8192( 2 blks) ==> 496347780:8204
223: SKP: 12288( 3 blks) ==> 496355984:12
224: RAW: 8192( 2 blks) ==> 496355996:8204
225: SKP: 12288( 3 blks) ==> 496364200:12
226: RAW: 4096( 1 blks) ==> 496364212:4108
227: SKP: 12288( 3 blks) ==> 496368320:12
228: RAW: 8192( 2 blks) ==> 496368332:8204
229: SKP: 12288( 3 blks) ==> 496376536:12
230: RAW: 8192( 2 blks) ==> 496376548:8204
231: SKP: 12288( 3 blks) ==> 496384752:12
232: RAW: 4096( 1 blks) ==> 496384764:4108
233: SKP: 12288( 3 blks) ==> 496388872:12
234: RAW: 8192( 2 blks) ==> 496388884:8204
235: SKP: 12288( 3 blks) ==> 496397088:12
236: RAW: 8192( 2 blks) ==> 496397100:8204
237: SKP: 12288( 3 blks) ==> 496405304:12
238: RAW: 4096( 1 blks) ==> 496405316:4108
239: SKP: 12288( 3 blks) ==> 496409424:12
240: RAW: 8192( 2 blks) ==> 496409436:8204
241: SKP: 12288( 3 blks) ==> 496417640:12
242: RAW: 4096( 1 blks) ==> 496417652:4108
243: SKP: 12288( 3 blks) ==> 496421760:12
244: RAW: 8192( 2 blks) ==> 496421772:8204
245: SKP: 12288( 3 blks) ==> 496429976:12
246: RAW: 4096( 1 blks) ==> 496429988:4108
247: SKP: 12288( 3 blks) ==> 496434096:12
248: RAW: 8192( 2 blks) ==> 496434108:8204
249: SKP: 12288( 3 blks) ==> 496442312:12
250: RAW: 4096( 1 blks) ==> 496442324:4108
251: SKP: 12288( 3 blks) ==> 496446432:12
252: RAW: 8192( 2 blks) ==> 496446444:8204
253: SKP: 12288( 3 blks) ==> 496454648:12
254: RAW: 8192( 2 blks) ==> 496454660:8204
255: SKP: 8192( 2 blks) ==> 496462864:12
256: RAW: 8192( 2 blks) ==> 496462876:8204
257: SKP: 4096( 1 blks) ==> 496471080:12
258: RAW: 4096( 1 blks) ==> 496471092:4108
259: SKP: 16384( 4 blks) ==> 496475200:12
260: RAW: 16384( 4 blks) ==> 496475212:16396
261: SKP: 12288( 3 blks) ==> 496491608:12
262: RAW: 8192( 2 blks) ==> 496491620:8204
263: SKP: 4096( 1 blks) ==> 496499824:12
264: RAW: 8192( 2 blks) ==> 496499836:8204
265: SKP: 12288( 3 blks) ==> 496508040:12
266: RAW: 12288( 3 blks) ==> 496508052:12300
267: SKP: 12288( 3 blks) ==> 496520352:12
268: RAW: 8192( 2 blks) ==> 496520364:8204
269: SKP: 12288( 3 blks) ==> 496528568:12
270: RAW: 8192( 2 blks) ==> 496528580:8204
271: SKP: 12288( 3 blks) ==> 496536784:12
272: RAW: 8192( 2 blks) ==> 496536796:8204
273: SKP: 12288( 3 blks) ==> 496545000:12
274: RAW: 8192( 2 blks) ==> 496545012:8204
275: SKP: 12288( 3 blks) ==> 496553216:12
276: RAW: 4096( 1 blks) ==> 496553228:4108
277: SKP: 12288( 3 blks) ==> 496557336:12
278: RAW: 8192( 2 blks) ==> 496557348:8204
279: SKP: 12288( 3 blks) ==> 496565552:12
280: RAW: 8192( 2 blks) ==> 496565564:8204
281: SKP: 12288( 3 blks) ==> 496573768:12
282: RAW: 4096( 1 blks) ==> 496573780:4108
283: SKP: 12288( 3 blks) ==> 496577888:12
284: RAW: 8192( 2 blks) ==> 496577900:8204
285: SKP: 12288( 3 blks) ==> 496586104:12
286: RAW: 4096( 1 blks) ==> 496586116:4108
287: SKP: 12288( 3 blks) ==> 496590224:12
288: RAW: 8192( 2 blks) ==> 496590236:8204
289: SKP: 12288( 3 blks) ==> 496598440:12
290: RAW: 8192( 2 blks) ==> 496598452:8204
291: SKP: 8192( 2 blks) ==> 496606656:12
292: RAW: 8192( 2 blks) ==> 496606668:8204
293: SKP: 12288( 3 blks) ==> 496614872:12
294: RAW: 8192( 2 blks) ==> 496614884:8204
295: SKP: 12288( 3 blks) ==> 496623088:12
296: RAW: 4096( 1 blks) ==> 496623100:4108
297: SKP: 12288( 3 blks) ==> 496627208:12
298: RAW: 8192( 2 blks) ==> 496627220:8204
299: SKP: 12288( 3 blks) ==> 496635424:12
300: RAW: 4096( 1 blks) ==> 496635436:4108
301: SKP: 12288( 3 blks) ==> 496639544:12
302: RAW: 8192( 2 blks) ==> 496639556:8204
303: SKP: 12288( 3 blks) ==> 496647760:12
304: RAW: 4096( 1 blks) ==> 496647772:4108
305: SKP: 12288( 3 blks) ==> 496651880:12
306: RAW: 8192( 2 blks) ==> 496651892:8204
307: SKP: 12288( 3 blks) ==> 496660096:12
308: RAW: 4096( 1 blks) ==> 496660108:4108
309: SKP: 12288( 3 blks) ==> 496664216:12
310: RAW: 8192( 2 blks) ==> 496664228:8204
311: SKP: 12288( 3 blks) ==> 496672432:12
312: RAW: 8192( 2 blks) ==> 496672444:8204
313: SKP: 12288( 3 blks) ==> 496680648:12
314: RAW: 4096( 1 blks) ==> 496680660:4108
315: SKP: 12288( 3 blks) ==> 496684768:12
316: RAW: 8192( 2 blks) ==> 496684780:8204
317: SKP: 12288( 3 blks) ==> 496692984:12
318: RAW: 4096( 1 blks) ==> 496692996:4108
319: SKP: 12288( 3 blks) ==> 496697104:12
320: RAW: 4096( 1 blks) ==> 496697116:4108
321: SKP: 4096( 1 blks) ==> 496701224:12
322: RAW: 4096( 1 blks) ==> 496701236:4108
323: SKP: 12288( 3 blks) ==> 496705344:12
324: RAW: 4096( 1 blks) ==> 496705356:4108
325: SKP: 12288( 3 blks) ==> 496709464:12
326: RAW: 8192( 2 blks) ==> 496709476:8204
327: SKP: 12288( 3 blks) ==> 496717680:12
328: RAW: 8192( 2 blks) ==> 496717692:8204
329: SKP: 12288( 3 blks) ==> 496725896:12
330: RAW: 4096( 1 blks) ==> 496725908:4108
331: SKP: 12288( 3 blks) ==> 496730016:12
332: RAW: 8192( 2 blks) ==> 496730028:8204
333: SKP: 12288( 3 blks) ==> 496738232:12
334: RAW: 8192( 2 blks) ==> 496738244:8204
335: SKP: 12288( 3 blks) ==> 496746448:12
336: RAW: 4096( 1 blks) ==> 496746460:4108
337: SKP: 12288( 3 blks) ==> 496750568:12
338: RAW: 8192( 2 blks) ==> 496750580:8204
339: SKP: 12288( 3 blks) ==> 496758784:12
340: RAW: 8192( 2 blks) ==> 496758796:8204
341: SKP: 8192( 2 blks) ==> 496767000:12
342: RAW: 8192( 2 blks) ==> 496767012:8204
343: SKP: 12288( 3 blks) ==> 496775216:12
344: RAW: 8192( 2 blks) ==> 496775228:8204
345: SKP: 12288( 3 blks) ==> 496783432:12
346: RAW: 8192( 2 blks) ==> 496783444:8204
347: SKP: 12288( 3 blks) ==> 496791648:12
348: RAW: 4096( 1 blks) ==> 496791660:4108
349: SKP: 12288( 3 blks) ==> 496795768:12
350: RAW: 8192( 2 blks) ==> 496795780:8204
351: SKP: 12288( 3 blks) ==> 496803984:12
352: RAW: 4096( 1 blks) ==> 496803996:4108
353: SKP: 12288( 3 blks) ==> 496808104:12
354: RAW: 12288( 3 blks) ==> 496808116:12300
355: SKP: 12288( 3 blks) ==> 496820416:12
356: RAW: 8192( 2 blks) ==> 496820428:8204
357: SKP: 12288( 3 blks) ==> 496828632:12
358: RAW: 12288( 3 blks) ==> 496828644:12300
359: SKP: 12288( 3 blks) ==> 496840944:12
360: RAW: 8192( 2 blks) ==> 496840956:8204
361: SKP: 12288( 3 blks) ==> 496849160:12
362: RAW: 8192( 2 blks) ==> 496849172:8204
363: SKP: 12288( 3 blks) ==> 496857376:12
364: RAW: 4096( 1 blks) ==> 496857388:4108
365: SKP: 12288( 3 blks) ==> 496861496:12
366: RAW: 8192( 2 blks) ==> 496861508:8204
367: SKP: 12288( 3 blks) ==> 496869712:12
368: RAW: 8192( 2 blks) ==> 496869724:8204
369: SKP: 8192( 2 blks) ==> 496877928:12
370: RAW: 8192( 2 blks) ==> 496877940:8204
371: SKP: 12288( 3 blks) ==> 496886144:12
372: RAW: 12288( 3 blks) ==> 496886156:12300
373: SKP: 12288( 3 blks) ==> 496898456:12
374: RAW: 12288( 3 blks) ==> 496898468:12300
375: SKP: 12288( 3 blks) ==> 496910768:12
376: RAW: 8192( 2 blks) ==> 496910780:8204
377: SKP: 12288( 3 blks) ==> 496918984:12
378: RAW: 4096( 1 blks) ==> 496918996:4108
379: SKP: 12288( 3 blks) ==> 496923104:12
380: RAW: 8192( 2 blks) ==> 496923116:8204
381: SKP: 12288( 3 blks) ==> 496931320:12
382: RAW: 8192( 2 blks) ==> 496931332:8204
383: SKP: 12288( 3 blks) ==> 496939536:12
384: RAW: 4096( 1 blks) ==> 496939548:4108
385: SKP: 12288( 3 blks) ==> 496943656:12
386: RAW: 8192( 2 blks) ==> 496943668:8204
387: SKP: 12288( 3 blks) ==> 496951872:12
388: RAW: 8192( 2 blks) ==> 496951884:8204
389: SKP: 12288( 3 blks) ==> 496960088:12
390: RAW: 12288( 3 blks) ==> 496960100:12300
391: SKP: 12288( 3 blks) ==> 496972400:12
392: RAW: 8192( 2 blks) ==> 496972412:8204
393: SKP: 12288( 3 blks) ==> 496980616:12
394: RAW: 8192( 2 blks) ==> 496980628:8204
395: SKP: 4096( 1 blks) ==> 496988832:12
396: RAW: 8192( 2 blks) ==> 496988844:8204
397: SKP: 8192( 2 blks) ==> 496997048:12
398: RAW: 8192( 2 blks) ==> 496997060:8204
399: SKP: 12288( 3 blks) ==> 497005264:12
400: RAW: 8192( 2 blks) ==> 497005276:8204
401: SKP: 12288( 3 blks) ==> 497013480:12
402: RAW: 4096( 1 blks) ==> 497013492:4108
403: SKP: 12288( 3 blks) ==> 497017600:12
404: RAW: 8192( 2 blks) ==> 497017612:8204
405: SKP: 12288( 3 blks) ==> 497025816:12
406: RAW: 4096( 1 blks) ==> 497025828:4108
407: SKP: 12288( 3 blks) ==> 497029936:12
408: RAW: 8192( 2 blks) ==> 497029948:8204
409: SKP: 12288( 3 blks) ==> 497038152:12
410: RAW: 4096( 1 blks) ==> 497038164:4108
411: SKP: 12288( 3 blks) ==> 497042272:12
412: RAW: 8192( 2 blks) ==> 497042284:8204
413: SKP: 12288( 3 blks) ==> 497050488:12
414: RAW: 4096( 1 blks) ==> 497050500:4108
415: SKP: 12288( 3 blks) ==> 497054608:12
416: RAW: 8192( 2 blks) ==> 497054620:8204
417: SKP: 12288( 3 blks) ==> 497062824:12
418: RAW: 4096( 1 blks) ==> 497062836:4108
419: SKP: 12288( 3 blks) ==> 497066944:12
420: RAW: 8192( 2 blks) ==> 497066956:8204
421: SKP: 12288( 3 blks) ==> 497075160:12
422: RAW: 4096( 1 blks) ==> 497075172:4108
423: SKP: 12288( 3 blks) ==> 497079280:12
424: RAW: 8192( 2 blks) ==> 497079292:8204
425: SKP: 4096( 1 blks) ==> 497087496:12
426: RAW: 4096( 1 blks) ==> 497087508:4108
427: SKP: 12288( 3 blks) ==> 497091616:12
428: RAW: 4096( 1 blks) ==> 497091628:4108
429: SKP: 4096( 1 blks) ==> 497095736:12
430: RAW: 4096( 1 blks) ==> 497095748:4108
431: SKP: 12288( 3 blks) ==> 497099856:12
432: RAW: 16384( 4 blks) ==> 497099868:16396
433: SKP: 12288( 3 blks) ==> 497116264:12
434: RAW: 4096( 1 blks) ==> 497116276:4108
435: SKP: 4096( 1 blks) ==> 497120384:12
436: RAW: 4096( 1 blks) ==> 497120396:4108
437: SKP: 12288( 3 blks) ==> 497124504:12
438: RAW: 8192( 2 blks) ==> 497124516:8204
439: SKP: 12288( 3 blks) ==> 497132720:12
440: RAW: 4096( 1 blks) ==> 497132732:4108
441: SKP: 12288( 3 blks) ==> 497136840:12
442: RAW: 8192( 2 blks) ==> 497136852:8204
443: SKP: 12288( 3 blks) ==> 497145056:12
444: RAW: 4096( 1 blks) ==> 497145068:4108
445: SKP: 12288( 3 blks) ==> 497149176:12
446: RAW: 8192( 2 blks) ==> 497149188:8204
447: SKP: 12288( 3 blks) ==> 497157392:12
448: RAW: 8192( 2 blks) ==> 497157404:8204
449: SKP: 8192( 2 blks) ==> 497165608:12
450: RAW: 12288( 3 blks) ==> 497165620:12300
451: SKP: 12288( 3 blks) ==> 497177920:12
452: RAW: 8192( 2 blks) ==> 497177932:8204
453: SKP: 12288( 3 blks) ==> 497186136:12
454: RAW: 4096( 1 blks) ==> 497186148:4108
455: SKP: 12288( 3 blks) ==> 497190256:12
456: RAW: 8192( 2 blks) ==> 497190268:8204
457: SKP: 12288( 3 blks) ==> 497198472:12
458: RAW: 4096( 1 blks) ==> 497198484:4108
459: SKP: 12288( 3 blks) ==> 497202592:12
460: RAW: 8192( 2 blks) ==> 497202604:8204
461: SKP: 12288( 3 blks) ==> 497210808:12
462: RAW: 4096( 1 blks) ==> 497210820:4108
463: SKP: 12288( 3 blks) ==> 497214928:12
464: RAW: 8192( 2 blks) ==> 497214940:8204
465: SKP: 12288( 3 blks) ==> 497223144:12
466: RAW: 4096( 1 blks) ==> 497223156:4108
467: SKP: 12288( 3 blks) ==> 497227264:12
468: RAW: 8192( 2 blks) ==> 497227276:8204
469: SKP: 12288( 3 blks) ==> 497235480:12
470: RAW: 4096( 1 blks) ==> 497235492:4108
471: SKP: 12288( 3 blks) ==> 497239600:12
472: RAW: 8192( 2 blks) ==> 497239612:8204
473: SKP: 12288( 3 blks) ==> 497247816:12
474: RAW: 4096( 1 blks) ==> 497247828:4108
475: SKP: 12288( 3 blks) ==> 497251936:12
476: RAW: 8192( 2 blks) ==> 497251948:8204
477: SKP: 12288( 3 blks) ==> 497260152:12
478: RAW: 8192( 2 blks) ==> 497260164:8204
479: SKP: 8192( 2 blks) ==> 497268368:12
480: RAW: 8192( 2 blks) ==> 497268380:8204
481: SKP: 12288( 3 blks) ==> 497276584:12
482: RAW: 8192( 2 blks) ==> 497276596:8204
483: SKP: 12288( 3 blks) ==> 497284800:12
484: RAW: 4096( 1 blks) ==> 497284812:4108
485: SKP: 12288( 3 blks) ==> 497288920:12
486: RAW: 8192( 2 blks) ==> 497288932:8204
487: SKP: 12288( 3 blks) ==> 497297136:12
488: RAW: 4096( 1 blks) ==> 497297148:4108
489: SKP: 12288( 3 blks) ==> 497301256:12
490: RAW: 8192( 2 blks) ==> 497301268:8204
491: SKP: 12288( 3 blks) ==> 497309472:12
492: RAW: 4096( 1 blks) ==> 497309484:4108
493: SKP: 12288( 3 blks) ==> 497313592:12
494: RAW: 8192( 2 blks) ==> 497313604:8204
495: SKP: 12288( 3 blks) ==> 497321808:12
496: RAW: 4096( 1 blks) ==> 497321820:4108
497: SKP: 12288( 3 blks) ==> 497325928:12
498: RAW: 8192( 2 blks) ==> 497325940:8204
499: SKP: 12288( 3 blks) ==> 497334144:12
500: RAW: 4096( 1 blks) ==> 497334156:4108
501: SKP: 12288( 3 blks) ==> 497338264:12
502: RAW: 8192( 2 blks) ==> 497338276:8204
503: SKP: 12288( 3 blks) ==> 497346480:12
504: RAW: 8192( 2 blks) ==> 497346492:8204
505: SKP: 12288( 3 blks) ==> 497354696:12
506: RAW: 4096( 1 blks) ==> 497354708:4108
507: SKP: 12288( 3 blks) ==> 497358816:12
508: RAW: 8192( 2 blks) ==> 497358828:8204
509: SKP: 12288( 3 blks) ==> 497367032:12
510: RAW: 8192( 2 blks) ==> 497367044:8204
511: SKP: 12288( 3 blks) ==> 497375248:12
512: RAW: 4096( 1 blks) ==> 497375260:4108
513: SKP: 12288( 3 blks) ==> 497379368:12
514: RAW: 8192( 2 blks) ==> 497379380:8204
515: SKP: 12288( 3 blks) ==> 497387584:12
516: RAW: 4096( 1 blks) ==> 497387596:4108
517: SKP: 12288( 3 blks) ==> 497391704:12
518: RAW: 8192( 2 blks) ==> 497391716:8204
519: SKP: 12288( 3 blks) ==> 497399920:12
520: RAW: 8192( 2 blks) ==> 497399932:8204
521: SKP: 8192( 2 blks) ==> 497408136:12
522: RAW: 8192( 2 blks) ==> 497408148:8204
523: SKP: 12288( 3 blks) ==> 497416352:12
524: RAW: 8192( 2 blks) ==> 497416364:8204
525: SKP: 12288( 3 blks) ==> 497424568:12
526: RAW: 4096( 1 blks) ==> 497424580:4108
527: SKP: 12288( 3 blks) ==> 497428688:12
528: RAW: 8192( 2 blks) ==> 497428700:8204
529: SKP: 12288( 3 blks) ==> 497436904:12
530: RAW: 4096( 1 blks) ==> 497436916:4108
531: SKP: 12288( 3 blks) ==> 497441024:12
532: RAW: 8192( 2 blks) ==> 497441036:8204
533: SKP: 4096( 1 blks) ==> 497449240:12
534: RAW: 4096( 1 blks) ==> 497449252:4108
535: SKP: 12288( 3 blks) ==> 497453360:12
536: RAW: 8192( 2 blks) ==> 497453372:8204
537: SKP: 12288( 3 blks) ==> 497461576:12
538: RAW: 4096( 1 blks) ==> 497461588:4108
539: SKP: 12288( 3 blks) ==> 497465696:12
540: RAW: 4096( 1 blks) ==> 497465708:4108
541: SKP: 12288( 3 blks) ==> 497469816:12
542: RAW: 12288( 3 blks) ==> 497469828:12300
543: SKP: 12288( 3 blks) ==> 497482128:12
544: RAW: 4096( 1 blks) ==> 497482140:4108
545: SKP: 12288( 3 blks) ==> 497486248:12
546: RAW: 8192( 2 blks) ==> 497486260:8204
547: SKP: 12288( 3 blks) ==> 497494464:12
548: RAW: 4096( 1 blks) ==> 497494476:4108
549: SKP: 12288( 3 blks) ==> 497498584:12
550: RAW: 20480( 5 blks) ==> 497498596:20492
551: SKP: 4186112( 1022 blks) ==> 497519088:12
552: RAW: 1523712( 372 blks) ==> 497519100:1523724
553: SKP: 61440( 15 blks) ==> 499042824:12
554: RAW: 208896( 51 blks) ==> 499042836:208908
555: SKP: 299008( 73 blks) ==> 499251744:12
556: RAW: 2002944( 489 blks) ==> 499251756:2002956
557: SKP: 20480( 5 blks) ==> 501254712:12
558: RAW: 8192( 2 blks) ==> 501254724:8204
559: SKP: 77824( 19 blks) ==> 501262928:12
560: RAW: 8192( 2 blks) ==> 501262940:8204
561: SKP: 12288( 3 blks) ==> 501271144:12
562: RAW: 4096( 1 blks) ==> 501271156:4108
563: SKP: 12288( 3 blks) ==> 501275264:12
564: RAW: 8192( 2 blks) ==> 501275276:8204
565: SKP: 12288( 3 blks) ==> 501283480:12
566: RAW: 8192( 2 blks) ==> 501283492:8204
567: SKP: 12288( 3 blks) ==> 501291696:12
568: RAW: 4096( 1 blks) ==> 501291708:4108
569: SKP: 12288( 3 blks) ==> 501295816:12
570: RAW: 8192( 2 blks) ==> 501295828:8204
571: SKP: 12288( 3 blks) ==> 501304032:12
572: RAW: 8192( 2 blks) ==> 501304044:8204
573: SKP: 12288( 3 blks) ==> 501312248:12
574: RAW: 122880( 30 blks) ==> 501312260:122892
575: SKP: 12288( 3 blks) ==> 501435152:12
576: RAW: 8192( 2 blks) ==> 501435164:8204
577: SKP: 12288( 3 blks) ==> 501443368:12
578: RAW: 4096( 1 blks) ==> 501443380:4108
579: SKP: 12288( 3 blks) ==> 501447488:12
580: RAW: 8192( 2 blks) ==> 501447500:8204
581: SKP: 24576( 6 blks) ==> 501455704:12
582: RAW: 73728( 18 blks) ==> 501455716:73740
583: SKP: 12288( 3 blks) ==> 501529456:12
584: RAW: 8192( 2 blks) ==> 501529468:8204
585: SKP: 12288( 3 blks) ==> 501537672:12
586: RAW: 8192( 2 blks) ==> 501537684:8204
587: SKP: 12288( 3 blks) ==> 501545888:12
588: RAW: 4096( 1 blks) ==> 501545900:4108
589: SKP: 12288( 3 blks) ==> 501550008:12
590: RAW: 12288( 3 blks) ==> 501550020:12300
591: SKP: 8192( 2 blks) ==> 501562320:12
592: RAW: 12288( 3 blks) ==> 501562332:12300
593: SKP: 12288( 3 blks) ==> 501574632:12
594: RAW: 8192( 2 blks) ==> 501574644:8204
595: SKP: 12288( 3 blks) ==> 501582848:12
596: RAW: 8192( 2 blks) ==> 501582860:8204
597: SKP: 12288( 3 blks) ==> 501591064:12
598: RAW: 8192( 2 blks) ==> 501591076:8204
599: SKP: 12288( 3 blks) ==> 501599280:12
600: RAW: 4096( 1 blks) ==> 501599292:4108
601: SKP: 4096( 1 blks) ==> 501603400:12
602: RAW: 4096( 1 blks) ==> 501603412:4108
603: SKP: 12288( 3 blks) ==> 501607520:12
604: RAW: 4096( 1 blks) ==> 501607532:4108
605: SKP: 8192( 2 blks) ==> 501611640:12
606: RAW: 4096( 1 blks) ==> 501611652:4108
607: SKP: 4096( 1 blks) ==> 501615760:12
608: RAW: 4096( 1 blks) ==> 501615772:4108
609: SKP: 4096( 1 blks) ==> 501619880:12
610: RAW: 16384( 4 blks) ==> 501619892:16396
611: SKP: 4096( 1 blks) ==> 501636288:12
612: RAW: 4096( 1 blks) ==> 501636300:4108
613: SKP: 4096( 1 blks) ==> 501640408:12
614: RAW: 4096( 1 blks) ==> 501640420:4108
615: SKP: 8192( 2 blks) ==> 501644528:12
616: RAW: 12288( 3 blks) ==> 501644540:12300
617: SKP: 4096( 1 blks) ==> 501656840:12
618: RAW: 4096( 1 blks) ==> 501656852:4108
619: SKP: 4096( 1 blks) ==> 501660960:12
620: RAW: 4096( 1 blks) ==> 501660972:4108
621: SKP: 8192( 2 blks) ==> 501665080:12
622: RAW: 4096( 1 blks) ==> 501665092:4108
623: SKP: 4096( 1 blks) ==> 501669200:12
624: RAW: 4096( 1 blks) ==> 501669212:4108
625: SKP: 4096( 1 blks) ==> 501673320:12
626: RAW: 16384( 4 blks) ==> 501673332:16396
627: SKP: 4096( 1 blks) ==> 501689728:12
628: RAW: 4096( 1 blks) ==> 501689740:4108
629: SKP: 4096( 1 blks) ==> 501693848:12
630: RAW: 4096( 1 blks) ==> 501693860:4108
631: SKP: 4096( 1 blks) ==> 501697968:12
632: RAW: 16384( 4 blks) ==> 501697980:16396
633: SKP: 4096( 1 blks) ==> 501714376:12
634: RAW: 4096( 1 blks) ==> 501714388:4108
635: SKP: 4096( 1 blks) ==> 501718496:12
636: RAW: 4096( 1 blks) ==> 501718508:4108
637: SKP: 8192( 2 blks) ==> 501722616:12
638: RAW: 12288( 3 blks) ==> 501722628:12300
639: SKP: 4096( 1 blks) ==> 501734928:12
640: RAW: 4096( 1 blks) ==> 501734940:4108
641: SKP: 4096( 1 blks) ==> 501739048:12
642: RAW: 4096( 1 blks) ==> 501739060:4108
643: SKP: 8192( 2 blks) ==> 501743168:12
644: RAW: 4096( 1 blks) ==> 501743180:4108
645: SKP: 4096( 1 blks) ==> 501747288:12
646: RAW: 4096( 1 blks) ==> 501747300:4108
647: SKP: 4096( 1 blks) ==> 501751408:12
648: RAW: 12288( 3 blks) ==> 501751420:12300
649: SKP: 8192( 2 blks) ==> 501763720:12
650: RAW: 4096( 1 blks) ==> 501763732:4108
651: SKP: 4096( 1 blks) ==> 501767840:12
652: RAW: 4096( 1 blks) ==> 501767852:4108
653: SKP: 4096( 1 blks) ==> 501771960:12
654: RAW: 16384( 4 blks) ==> 501771972:16396
655: SKP: 4096( 1 blks) ==> 501788368:12
656: RAW: 4096( 1 blks) ==> 501788380:4108
657: SKP: 4096( 1 blks) ==> 501792488:12
658: RAW: 4096( 1 blks) ==> 501792500:4108
659: SKP: 8192( 2 blks) ==> 501796608:12
660: RAW: 12288( 3 blks) ==> 501796620:12300
661: SKP: 4096( 1 blks) ==> 501808920:12
662: RAW: 4096( 1 blks) ==> 501808932:4108
663: SKP: 4096( 1 blks) ==> 501813040:12
664: RAW: 4096( 1 blks) ==> 501813052:4108
665: SKP: 8192( 2 blks) ==> 501817160:12
666: RAW: 12288( 3 blks) ==> 501817172:12300
667: SKP: 4096( 1 blks) ==> 501829472:12
668: RAW: 4096( 1 blks) ==> 501829484:4108
669: SKP: 4096( 1 blks) ==> 501833592:12
670: RAW: 4096( 1 blks) ==> 501833604:4108
671: SKP: 8192( 2 blks) ==> 501837712:12
672: RAW: 4096( 1 blks) ==> 501837724:4108
673: SKP: 4096( 1 blks) ==> 501841832:12
674: RAW: 4096( 1 blks) ==> 501841844:4108
675: SKP: 4096( 1 blks) ==> 501845952:12
676: RAW: 16384( 4 blks) ==> 501845964:16396
677: SKP: 4096( 1 blks) ==> 501862360:12
678: RAW: 4096( 1 blks) ==> 501862372:4108
679: SKP: 4096( 1 blks) ==> 501866480:12
680: RAW: 4096( 1 blks) ==> 501866492:4108
681: SKP: 4096( 1 blks) ==> 501870600:12
682: RAW: 16384( 4 blks) ==> 501870612:16396
683: SKP: 4096( 1 blks) ==> 501887008:12
684: RAW: 4096( 1 blks) ==> 501887020:4108
685: SKP: 4096( 1 blks) ==> 501891128:12
686: RAW: 4096( 1 blks) ==> 501891140:4108
687: SKP: 8192( 2 blks) ==> 501895248:12
688: RAW: 12288( 3 blks) ==> 501895260:12300
689: SKP: 4096( 1 blks) ==> 501907560:12
690: RAW: 4096( 1 blks) ==> 501907572:4108
691: SKP: 4096( 1 blks) ==> 501911680:12
692: RAW: 4096( 1 blks) ==> 501911692:4108
693: SKP: 8192( 2 blks) ==> 501915800:12
694: RAW: 4096( 1 blks) ==> 501915812:4108
695: SKP: 4096( 1 blks) ==> 501919920:12
696: RAW: 4096( 1 blks) ==> 501919932:4108
697: SKP: 4096( 1 blks) ==> 501924040:12
698: RAW: 12288( 3 blks) ==> 501924052:12300
699: SKP: 8192( 2 blks) ==> 501936352:12
700: RAW: 4096( 1 blks) ==> 501936364:4108
701: SKP: 4096( 1 blks) ==> 501940472:12
702: RAW: 4096( 1 blks) ==> 501940484:4108
703: SKP: 4096( 1 blks) ==> 501944592:12
704: RAW: 16384( 4 blks) ==> 501944604:16396
705: SKP: 4096( 1 blks) ==> 501961000:12
706: RAW: 4096( 1 blks) ==> 501961012:4108
707: SKP: 4096( 1 blks) ==> 501965120:12
708: RAW: 4096( 1 blks) ==> 501965132:4108
709: SKP: 8192( 2 blks) ==> 501969240:12
710: RAW: 12288( 3 blks) ==> 501969252:12300
711: SKP: 4096( 1 blks) ==> 501981552:12
712: RAW: 4096( 1 blks) ==> 501981564:4108
713: SKP: 4096( 1 blks) ==> 501985672:12
714: RAW: 4096( 1 blks) ==> 501985684:4108
715: SKP: 8192( 2 blks) ==> 501989792:12
716: RAW: 4096( 1 blks) ==> 501989804:4108
717: SKP: 4096( 1 blks) ==> 501993912:12
718: RAW: 4096( 1 blks) ==> 501993924:4108
719: SKP: 4096( 1 blks) ==> 501998032:12
720: RAW: 12288( 3 blks) ==> 501998044:12300
721: SKP: 8192( 2 blks) ==> 502010344:12
722: RAW: 4096( 1 blks) ==> 502010356:4108
723: SKP: 4096( 1 blks) ==> 502014464:12
724: RAW: 4096( 1 blks) ==> 502014476:4108
725: SKP: 4096( 1 blks) ==> 502018584:12
726: RAW: 16384( 4 blks) ==> 502018596:16396
727: SKP: 4096( 1 blks) ==> 502034992:12
728: RAW: 4096( 1 blks) ==> 502035004:4108
729: SKP: 4096( 1 blks) ==> 502039112:12
730: RAW: 4096( 1 blks) ==> 502039124:4108
731: SKP: 8192( 2 blks) ==> 502043232:12
732: RAW: 12288( 3 blks) ==> 502043244:12300
733: SKP: 4096( 1 blks) ==> 502055544:12
734: RAW: 4096( 1 blks) ==> 502055556:4108
735: SKP: 4096( 1 blks) ==> 502059664:12
736: RAW: 4096( 1 blks) ==> 502059676:4108
737: SKP: 8192( 2 blks) ==> 502063784:12
738: RAW: 12288( 3 blks) ==> 502063796:12300
739: SKP: 4096( 1 blks) ==> 502076096:12
740: RAW: 4096( 1 blks) ==> 502076108:4108
741: SKP: 4096( 1 blks) ==> 502080216:12
742: RAW: 4096( 1 blks) ==> 502080228:4108
743: SKP: 8192( 2 blks) ==> 502084336:12
744: RAW: 4096( 1 blks) ==> 502084348:4108
745: SKP: 4096( 1 blks) ==> 502088456:12
746: RAW: 4096( 1 blks) ==> 502088468:4108
747: SKP: 4096( 1 blks) ==> 502092576:12
748: RAW: 16384( 4 blks) ==> 502092588:16396
749: SKP: 4096( 1 blks) ==> 502108984:12
750: RAW: 4096( 1 blks) ==> 502108996:4108
751: SKP: 4096( 1 blks) ==> 502113104:12
752: RAW: 4096( 1 blks) ==> 502113116:4108
753: SKP: 4096( 1 blks) ==> 502117224:12
754: RAW: 16384( 4 blks) ==> 502117236:16396
755: SKP: 4096( 1 blks) ==> 502133632:12
756: RAW: 4096( 1 blks) ==> 502133644:4108
757: SKP: 4096( 1 blks) ==> 502137752:12
758: RAW: 4096( 1 blks) ==> 502137764:4108
759: SKP: 8192( 2 blks) ==> 502141872:12
760: RAW: 12288( 3 blks) ==> 502141884:12300
761: SKP: 4096( 1 blks) ==> 502154184:12
762: RAW: 4096( 1 blks) ==> 502154196:4108
763: SKP: 4096( 1 blks) ==> 502158304:12
764: RAW: 4096( 1 blks) ==> 502158316:4108
765: SKP: 8192( 2 blks) ==> 502162424:12
766: RAW: 4096( 1 blks) ==> 502162436:4108
767: SKP: 4096( 1 blks) ==> 502166544:12
768: RAW: 4096( 1 blks) ==> 502166556:4108
769: SKP: 4096( 1 blks) ==> 502170664:12
770: RAW: 8192( 2 blks) ==> 502170676:8204
771: SKP: 12288( 3 blks) ==> 502178880:12
772: RAW: 4096( 1 blks) ==> 502178892:4108
773: SKP: 12288( 3 blks) ==> 502183000:12
774: RAW: 8192( 2 blks) ==> 502183012:8204
775: SKP: 12288( 3 blks) ==> 502191216:12
776: RAW: 8192( 2 blks) ==> 502191228:8204
777: SKP: 12288( 3 blks) ==> 502199432:12
778: RAW: 4096( 1 blks) ==> 502199444:4108
779: SKP: 12288( 3 blks) ==> 502203552:12
780: RAW: 8192( 2 blks) ==> 502203564:8204
781: SKP: 12288( 3 blks) ==> 502211768:12
782: RAW: 4096( 1 blks) ==> 502211780:4108
783: SKP: 12288( 3 blks) ==> 502215888:12
784: RAW: 8192( 2 blks) ==> 502215900:8204
785: SKP: 12288( 3 blks) ==> 502224104:12
786: RAW: 4096( 1 blks) ==> 502224116:4108
787: SKP: 12288( 3 blks) ==> 502228224:12
788: RAW: 8192( 2 blks) ==> 502228236:8204
789: SKP: 12288( 3 blks) ==> 502236440:12
790: RAW: 4096( 1 blks) ==> 502236452:4108
791: SKP: 12288( 3 blks) ==> 502240560:12
792: RAW: 8192( 2 blks) ==> 502240572:8204
793: SKP: 12288( 3 blks) ==> 502248776:12
794: RAW: 4096( 1 blks) ==> 502248788:4108
795: SKP: 12288( 3 blks) ==> 502252896:12
796: RAW: 8192( 2 blks) ==> 502252908:8204
797: SKP: 12288( 3 blks) ==> 502261112:12
798: RAW: 8192( 2 blks) ==> 502261124:8204
799: SKP: 8192( 2 blks) ==> 502269328:12
800: RAW: 8192( 2 blks) ==> 502269340:8204
801: SKP: 12288( 3 blks) ==> 502277544:12
802: RAW: 8192( 2 blks) ==> 502277556:8204
803: SKP: 12288( 3 blks) ==> 502285760:12
804: RAW: 4096( 1 blks) ==> 502285772:4108
805: SKP: 12288( 3 blks) ==> 502289880:12
806: RAW: 8192( 2 blks) ==> 502289892:8204
807: SKP: 12288( 3 blks) ==> 502298096:12
808: RAW: 4096( 1 blks) ==> 502298108:4108
809: SKP: 12288( 3 blks) ==> 502302216:12
810: RAW: 4096( 1 blks) ==> 502302228:4108
811: SKP: 4096( 1 blks) ==> 502306336:12
812: RAW: 4096( 1 blks) ==> 502306348:4108
813: SKP: 12288( 3 blks) ==> 502310456:12
814: RAW: 8192( 2 blks) ==> 502310468:8204
815: SKP: 12288( 3 blks) ==> 502318672:12
816: RAW: 4096( 1 blks) ==> 502318684:4108
817: SKP: 12288( 3 blks) ==> 502322792:12
818: RAW: 8192( 2 blks) ==> 502322804:8204
819: SKP: 12288( 3 blks) ==> 502331008:12
820: RAW: 12288( 3 blks) ==> 502331020:12300
821: SKP: 12288( 3 blks) ==> 502343320:12
822: RAW: 4096( 1 blks) ==> 502343332:4108
823: SKP: 12288( 3 blks) ==> 502347440:12
824: RAW: 12288( 3 blks) ==> 502347452:12300
825: SKP: 12288( 3 blks) ==> 502359752:12
826: RAW: 4096( 1 blks) ==> 502359764:4108
827: SKP: 12288( 3 blks) ==> 502363872:12
828: RAW: 8192( 2 blks) ==> 502363884:8204
829: SKP: 12288( 3 blks) ==> 502372088:12
830: RAW: 4096( 1 blks) ==> 502372100:4108
831: SKP: 12288( 3 blks) ==> 502376208:12
832: RAW: 8192( 2 blks) ==> 502376220:8204
833: SKP: 12288( 3 blks) ==> 502384424:12
834: RAW: 4096( 1 blks) ==> 502384436:4108
835: SKP: 12288( 3 blks) ==> 502388544:12
836: RAW: 8192( 2 blks) ==> 502388556:8204
837: SKP: 12288( 3 blks) ==> 502396760:12
838: RAW: 8192( 2 blks) ==> 502396772:8204
839: SKP: 12288( 3 blks) ==> 502404976:12
840: RAW: 4096( 1 blks) ==> 502404988:4108
841: SKP: 12288( 3 blks) ==> 502409096:12
842: RAW: 8192( 2 blks) ==> 502409108:8204
843: SKP: 12288( 3 blks) ==> 502417312:12
844: RAW: 8192( 2 blks) ==> 502417324:8204
845: SKP: 12288( 3 blks) ==> 502425528:12
846: RAW: 4096( 1 blks) ==> 502425540:4108
847: SKP: 12288( 3 blks) ==> 502429648:12
848: RAW: 8192( 2 blks) ==> 502429660:8204
849: SKP: 12288( 3 blks) ==> 502437864:12
850: RAW: 4096( 1 blks) ==> 502437876:4108
851: SKP: 12288( 3 blks) ==> 502441984:12
852: RAW: 8192( 2 blks) ==> 502441996:8204
853: SKP: 12288( 3 blks) ==> 502450200:12
854: RAW: 8192( 2 blks) ==> 502450212:8204
855: SKP: 8192( 2 blks) ==> 502458416:12
856: RAW: 8192( 2 blks) ==> 502458428:8204
857: SKP: 12288( 3 blks) ==> 502466632:12
858: RAW: 8192( 2 blks) ==> 502466644:8204
859: SKP: 12288( 3 blks) ==> 502474848:12
860: RAW: 4096( 1 blks) ==> 502474860:4108
861: SKP: 12288( 3 blks) ==> 502478968:12
862: RAW: 8192( 2 blks) ==> 502478980:8204
863: SKP: 12288( 3 blks) ==> 502487184:12
864: RAW: 8192( 2 blks) ==> 502487196:8204
865: SKP: 12288( 3 blks) ==> 502495400:12
866: RAW: 4096( 1 blks) ==> 502495412:4108
867: SKP: 12288( 3 blks) ==> 502499520:12
868: RAW: 8192( 2 blks) ==> 502499532:8204
869: SKP: 12288( 3 blks) ==> 502507736:12
870: RAW: 8192( 2 blks) ==> 502507748:8204
871: SKP: 12288( 3 blks) ==> 502515952:12
872: RAW: 4096( 1 blks) ==> 502515964:4108
873: SKP: 12288( 3 blks) ==> 502520072:12
874: RAW: 8192( 2 blks) ==> 502520084:8204
875: SKP: 12288( 3 blks) ==> 502528288:12
876: RAW: 4096( 1 blks) ==> 502528300:4108
877: SKP: 12288( 3 blks) ==> 502532408:12
878: RAW: 8192( 2 blks) ==> 502532420:8204
879: SKP: 12288( 3 blks) ==> 502540624:12
880: RAW: 8192( 2 blks) ==> 502540636:8204
881: SKP: 12288( 3 blks) ==> 502548840:12
882: RAW: 4096( 1 blks) ==> 502548852:4108
883: SKP: 12288( 3 blks) ==> 502552960:12
884: RAW: 8192( 2 blks) ==> 502552972:8204
885: SKP: 12288( 3 blks) ==> 502561176:12
886: RAW: 8192( 2 blks) ==> 502561188:8204
887: SKP: 12288( 3 blks) ==> 502569392:12
888: RAW: 4096( 1 blks) ==> 502569404:4108
889: SKP: 12288( 3 blks) ==> 502573512:12
890: RAW: 8192( 2 blks) ==> 502573524:8204
891: SKP: 12288( 3 blks) ==> 502581728:12
892: RAW: 8192( 2 blks) ==> 502581740:8204
893: SKP: 8192( 2 blks) ==> 502589944:12
894: RAW: 8192( 2 blks) ==> 502589956:8204
895: SKP: 12288( 3 blks) ==> 502598160:12
896: RAW: 8192( 2 blks) ==> 502598172:8204
897: SKP: 12288( 3 blks) ==> 502606376:12
898: RAW: 8192( 2 blks) ==> 502606388:8204
899: SKP: 12288( 3 blks) ==> 502614592:12
900: RAW: 4096( 1 blks) ==> 502614604:4108
901: SKP: 12288( 3 blks) ==> 502618712:12
902: RAW: 8192( 2 blks) ==> 502618724:8204
903: SKP: 12288( 3 blks) ==> 502626928:12
904: RAW: 4096( 1 blks) ==> 502626940:4108
905: SKP: 12288( 3 blks) ==> 502631048:12
906: RAW: 8192( 2 blks) ==> 502631060:8204
907: SKP: 12288( 3 blks) ==> 502639264:12
908: RAW: 8192( 2 blks) ==> 502639276:8204
909: SKP: 8192( 2 blks) ==> 502647480:12
910: RAW: 8192( 2 blks) ==> 502647492:8204
911: SKP: 12288( 3 blks) ==> 502655696:12
912: RAW: 20480( 5 blks) ==> 502655708:20492
913: SKP: 12288( 3 blks) ==> 502676200:12
914: RAW: 8192( 2 blks) ==> 502676212:8204
915: SKP: 12288( 3 blks) ==> 502684416:12
916: RAW: 4096( 1 blks) ==> 502684428:4108
917: SKP: 12288( 3 blks) ==> 502688536:12
918: RAW: 8192( 2 blks) ==> 502688548:8204
919: SKP: 12288( 3 blks) ==> 502696752:12
920: RAW: 8192( 2 blks) ==> 502696764:8204
921: SKP: 12288( 3 blks) ==> 502704968:12
922: RAW: 4096( 1 blks) ==> 502704980:4108
923: SKP: 12288( 3 blks) ==> 502709088:12
924: RAW: 8192( 2 blks) ==> 502709100:8204
925: SKP: 12288( 3 blks) ==> 502717304:12
926: RAW: 4096( 1 blks) ==> 502717316:4108
927: SKP: 12288( 3 blks) ==> 502721424:12
928: RAW: 8192( 2 blks) ==> 502721436:8204
929: SKP: 12288( 3 blks) ==> 502729640:12
930: RAW: 40960( 10 blks) ==> 502729652:40972
931: SKP: 12288( 3 blks) ==> 502770624:12
932: RAW: 8192( 2 blks) ==> 502770636:8204
933: SKP: 12288( 3 blks) ==> 502778840:12
934: RAW: 4096( 1 blks) ==> 502778852:4108
935: SKP: 12288( 3 blks) ==> 502782960:12
936: RAW: 8192( 2 blks) ==> 502782972:8204
937: SKP: 12288( 3 blks) ==> 502791176:12
938: RAW: 8192( 2 blks) ==> 502791188:8204
939: SKP: 12288( 3 blks) ==> 502799392:12
940: RAW: 8192( 2 blks) ==> 502799404:8204
941: SKP: 12288( 3 blks) ==> 502807608:12
942: RAW: 8192( 2 blks) ==> 502807620:8204
943: SKP: 12288( 3 blks) ==> 502815824:12
944: RAW: 12288( 3 blks) ==> 502815836:12300
945: SKP: 12288( 3 blks) ==> 502828136:12
946: RAW: 4096( 1 blks) ==> 502828148:4108
947: SKP: 12288( 3 blks) ==> 502832256:12
948: RAW: 8192( 2 blks) ==> 502832268:8204
949: SKP: 12288( 3 blks) ==> 502840472:12
950: RAW: 4096( 1 blks) ==> 502840484:4108
951: SKP: 12288( 3 blks) ==> 502844592:12
952: RAW: 8192( 2 blks) ==> 502844604:8204
953: SKP: 12288( 3 blks) ==> 502852808:12
954: RAW: 4096( 1 blks) ==> 502852820:4108
955: SKP: 12288( 3 blks) ==> 502856928:12
956: RAW: 8192( 2 blks) ==> 502856940:8204
957: SKP: 12288( 3 blks) ==> 502865144:12
958: RAW: 8192( 2 blks) ==> 502865156:8204
959: SKP: 12288( 3 blks) ==> 502873360:12
960: RAW: 8192( 2 blks) ==> 502873372:8204
961: SKP: 12288( 3 blks) ==> 502881576:12
962: RAW: 4096( 1 blks) ==> 502881588:4108
963: SKP: 12288( 3 blks) ==> 502885696:12
964: RAW: 8192( 2 blks) ==> 502885708:8204
965: SKP: 12288( 3 blks) ==> 502893912:12
966: RAW: 8192( 2 blks) ==> 502893924:8204
967: SKP: 1568768( 383 blks) ==> 502902128:12
968: RAW: 4096( 1 blks) ==> 502902140:4108
969: SKP: 12288( 3 blks) ==> 502906248:12
970: RAW: 8192( 2 blks) ==> 502906260:8204
971: SKP: 1568768( 383 blks) ==> 502914464:12
972: RAW: 4096( 1 blks) ==> 502914476:4108
973: SKP: 12288( 3 blks) ==> 502918584:12
974: RAW: 12288( 3 blks) ==> 502918596:12300
975: SKP: 4096( 1 blks) ==> 502930896:12
976: RAW: 4096( 1 blks) ==> 502930908:4108
977: SKP: 1671168( 408 blks) ==> 502935016:12
978: RAW: 29159424( 7119 blks) ==> 502935028:29159436
979: SKP: 49152( 12 blks) ==> 532094464:12
980: RAW: 4096( 1 blks) ==> 532094476:4108
981: SKP: 61440( 15 blks) ==> 532098584:12
982: RAW: 20480( 5 blks) ==> 532098596:20492
983: SKP: 16384( 4 blks) ==> 532119088:12
984: RAW: 1720320( 420 blks) ==> 532119100:1720332
985: SKP: 32768( 8 blks) ==> 533839432:12
986: RAW: 98304( 24 blks) ==> 533839444:98316
987: SKP: 294912( 72 blks) ==> 533937760:12
988: RAW: 30715904( 7499 blks) ==> 533937772:30715916
989: SKP: 741376( 181 blks) ==> 564653688:12
990: RAW: 2011136( 491 blks) ==> 564653700:2011148
991: SKP: 8192( 2 blks) ==> 566664848:12
992: RAW: 36864( 9 blks) ==> 566664860:36876
993: SKP: 8192( 2 blks) ==> 566701736:12
994: RAW: 8192( 2 blks) ==> 566701748:8204
995: SKP: 8192( 2 blks) ==> 566709952:12
996: RAW: 8192( 2 blks) ==> 566709964:8204
997: SKP: 2105344( 514 blks) ==> 566718168:12
998: RAW: 29343744( 7164 blks) ==> 566718180:29343756
999: SKP: 4096( 1 blks) ==> 596061936:12
1000: RAW: 40960( 10 blks) ==> 596061948:40972
1001: SKP: 73728( 18 blks) ==> 596102920:12
1002: RAW: 4096( 1
Following is the tail end of the log:
2800: RAW: 2629632( 642 blks) ==> 3110753116:2629644
2801: SKP: 30924800( 7550 blks) ==> 3113382760:12
2802: RAW: 5627904( 1374 blks) ==> 3113382772:5627916
2803: SKP: 94904320( 23170 blks) ==> 3119010688:12
2804: RAW: 45240320( 11045 blks) ==> 3119010700:45240332
2805: SKP: 20480( 5 blks) ==> 3164251032:12
2806: RAW: 49643520( 12120 blks) ==> 3164251044:49643532
2807: SKP: 8192( 2 blks) ==> 3213894576:12
2808: RAW: 307200( 75 blks) ==> 3213894588:307212
2809: SKP: 12288( 3 blks) ==> 3214201800:12
2810: RAW: 368640( 90 blks) ==> 3214201812:368652
2811: SKP: 24576( 6 blks) ==> 3214570464:12
2812: RAW: 102400( 25 blks) ==> 3214570476:102412
2813: SKP: 20480( 5 blks) ==> 3214672888:12
2814: RAW: 65536( 16 blks) ==> 3214672900:65548
2815: SKP: 8192( 2 blks) ==> 3214738448:12
2816: RAW: 78147584( 19079 blks) ==> 3214738460:78147596
2817: SKP: 4096( 1 blks) ==> 3292886056:12
2818: RAW: 7266304( 1774 blks) ==> 3292886068:7266316
2819: SKP: 20086784( 4904 blks) ==> 3300152384:12
2820: RAW: 12857344( 3139 blks) ==> 3300152396:12857356
2821: SKP: 4096( 1 blks) ==> 3313009752:12
2822: RAW: 4411392( 1077 blks) ==> 3313009764:4411404
2823: SKP: 4096( 1 blks) ==> 3317421168:12
2824: RAW: 16277504( 3974 blks) ==> 3317421180:16277516
2825: SKP: 1778384896( 434176 blks) ==> 3333698696:12
2826: RAW: 8192( 2 blks) ==> 3333698708:8204
2827: SKP: 57344( 14 blks) ==> 3333706912:12
2828: RAW: 4096( 1 blks) ==> 3333706924:4108
2829: SKP: 61440( 15 blks) ==> 3333711032:12
2830: RAW: 1183744( 289 blks) ==> 3333711044:1183756
2831: SKP: 32370688( 7903 blks) ==> 3334894800:12
2832: RAW: 5300224( 1294 blks) ==> 3334894812:5300236
2833: SKP: 95232000( 23250 blks) ==> 3340195048:12
2834: RAW: 19783680( 4830 blks) ==> 3340195060:19783692
2835: SKP: 1993482240( 486690 blks) ==> 3359978752:12
– Total: -----------------------------------------------------------
2836 CHUNK 30064771072(7340032 blks) ==> 3359978764(820299 blks)
done.
system.img built successfully.
Existing tbcfile(/home/tx2/Nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/cboot.bin) reused.
copying tbcdtbfile(/home/tx2/Nvidia/64_TX2/Linux_for_Tegra_tx2/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb)… done.
copying cfgfile(/home/tx2/Nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/cfg/flash_l4t_t186.xml) to flash.xml… done.
Existing flasher(/home/tx2/Nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/nvtboot_recovery_cpu.bin) reused.
Existing flashapp(/home/tx2/Nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/tegraflash.py) reused.
./tegraflash.py --bl nvtboot_recovery_cpu.bin --sdram_config P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --odmdata 0x1090000 --applet mb1_recovery_prod.bin --cmd “flash;reboot” --cfg flash.xml --chip 0x18 --misc_config tegra186-mb1-bct-misc-si-l4t.cfg --pinmux_config tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmic_config tegra186-mb1-bct-pmic-quill-p3310-1000-c03.cfg --pmc_config tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --prod_config tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg --scr_config minimal_scr.cfg --br_cmd_config tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --dev_params emmc.cfg --bins “mb2_bootloader nvtboot_recovery.bin; mts_preboot preboot_d15_prod_cr.bin; mts_bootpack mce_mts_d15_prod_cr.bin; bpmp_fw bpmp.bin; bpmp_fw_dtb tegra186-a02-bpmp-quill-p3310-1000-c01-00-te770d-ucm2.dtb; tlk tos.img; eks eks.img; bootloader_dtb tegra186-quill-p3310-1000-c03-00-base.dtb”
saving flash command in /home/tx2/Nvidia/64_TX2/Linux_for_Tegra_tx2/bootloader/flashcmd.txt
*** Flashing target device started. ***
version 1.0.0
[ 0.0091 ] tegrasign_v2 --key None --getmode mode.txt
[ 0.0103 ] Assuming zero filled SBK key
[ 0.0540 ]
[ 0.0540 ] Generating RCM messages
[ 0.0598 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 --download rcm mb1_recovery_prod.bin 0 0
[ 0.0609 ] RCM 0 is saved as rcm_0.rcm
[ 0.0753 ] RCM 1 is saved as rcm_1.rcm
[ 0.0755 ] List of rcm files are saved in rcm_list.xml
[ 0.0920 ]
[ 0.0921 ] Signing RCM messages
[ 0.0931 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0940 ] Assuming zero filled SBK key
[ 0.1218 ]
[ 0.1219 ] Copying signature to RCM mesages
[ 0.1239 ] tegrarcm_v2 --chip 0x18 --updatesig rcm_list_signed.xml
[ 0.1458 ]
[ 0.1458 ] Parsing partition layout
[ 0.1546 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.1806 ]
[ 0.1807 ] Creating list of images to be signed
[ 0.1843 ] tegrahost_v2 --chip 0x18 --partitionlayout flash.xml.bin --list images_list.xml zerosbk
[ 0.2809 ]
[ 0.2809 ] Generating signatures
[ 0.2820 ] tegrasign_v2 --key None --list images_list.xml --pubkeyhash pub_key.key
[ 0.2858 ] Assuming zero filled SBK key
[ 0.4523 ]
[ 0.4523 ] Generating br-bct
[ 0.4583 ] Updating dev and MSS params in BR BCT
[ 0.4585 ] tegrabct_v2 --dev_param emmc.cfg --sdram P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --brbct br_bct.cfg --chip 0x18
[ 0.4602 ] MB1 BCT version is : c
[ 0.4895 ] Copying Sdram info from 0 to 1 set
[ 0.5143 ] Copying Sdram info from 1 to 2 set
[ 0.5171 ] Copying Sdram info from 2 to 3 set
[ 0.5361 ]
[ 0.5361 ] Updating bl info
[ 0.5372 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 0.5625 ]
[ 0.5625 ] Updating Odmdata
[ 0.5666 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --updatefields Odmdata =0x1090000
[ 0.5891 ]
[ 0.5891 ] Get Signed section bct
[ 0.5905 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --listbct bct_list.xml
[ 0.6121 ]
[ 0.6121 ] Signing BCT
[ 0.6132 ] tegrasign_v2 --key None --list bct_list.xml --pubkeyhash pub_key.key
[ 0.6141 ] Assuming zero filled SBK key
[ 0.6325 ]
[ 0.6326 ] Updating BCT with signature
[ 0.6409 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --updatesig bct_list_signed.xml
[ 0.6598 ]
[ 0.6599 ] Generating coldboot mb1-bct
[ 0.6609 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct.cfg --sdram P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --misc tegra186-mb1-bct-misc-si-l4t.cfg --scr minimal_scr.cfg --pinmux tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmc tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --pmic tegra186-mb1-bct-pmic-quill-p3310-1000-c03.cfg --brcommand tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --prod tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 0.6657 ] MB1 BCT version is : c
[ 0.6733 ] Copying Sdram info from 0 to 1 set
[ 0.6964 ] Copying Sdram info from 1 to 2 set
[ 0.7028 ] Copying Sdram info from 2 to 3 set
[ 0.7058 ] Packing sdram param for instance[0]
[ 0.7100 ] Packing sdram param for instance[1]
[ 0.7162 ] Packing sdram param for instance[2]
[ 0.7244 ] Packing sdram param for instance[3]
[ 0.7294 ] Parsing platform config file :tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg
[ 0.7375 ] Appending platform config data of size :- 2904
[ 0.7390 ]
[ 0.7390 ] Parsing platform config file :minimal_scr.cfg
[ 0.7390 ] Appending platform config data of size :- 12240
[ 0.7390 ]
[ 0.7390 ] Parsing platform config file :tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg
[ 0.7390 ] Appending platform config data of size :- 24
[ 0.7390 ]
[ 0.7390 ] Parsing platform config file :tegra186-mb1-bct-pmic-quill-p3310-1000-c03.cfg
[ 0.7390 ] Appending platform config data of size :- 684
[ 0.7390 ]
[ 0.7390 ] Parsing platform config file :tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg
[ 0.7390 ] Appending platform config data of size :- 64
[ 0.7390 ]
[ 0.7390 ] Parsing platform config file :tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 0.7390 ] Appending platform config data of size :- 1628
[ 0.7390 ]
[ 0.7390 ] Updating mb1-bct with firmware information
[ 0.7443 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 0.7798 ]
[ 0.7815 ] tegrahost_v2 --align mb1_cold_boot_bct_MB1.bct
[ 0.8014 ]
[ 0.8027 ] tegrahost_v2 --appendsigheader mb1_cold_boot_bct_MB1.bct zerosbk
[ 0.8188 ]
[ 0.8232 ] tegrasign_v2 --key None --list mb1_cold_boot_bct_MB1_sigheader.bct_list.xml
[ 0.8277 ] Assuming zero filled SBK key
[ 0.8596 ]
[ 0.8686 ] tegrahost_v2 --updatesigheader mb1_cold_boot_bct_MB1_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_sigheader.bct.hash zerosbk
[ 0.8963 ]
[ 0.8964 ] Generating recovery mb1-bct
[ 0.8996 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct.cfg --sdram P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --misc tegra186-mb1-bct-misc-si-l4t.cfg --scr minimal_scr.cfg --pinmux tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmc tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --pmic tegra186-mb1-bct-pmic-quill-p3310-1000-c03.cfg --brcommand tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --prod tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 0.9083 ] MB1 BCT version is : c
[ 0.9150 ] Copying Sdram info from 0 to 1 set
[ 0.9371 ] Copying Sdram info from 1 to 2 set
[ 0.9401 ] Copying Sdram info from 2 to 3 set
[ 0.9430 ] Packing sdram param for instance[0]
[ 0.9473 ] Packing sdram param for instance[1]
[ 0.9563 ] Packing sdram param for instance[2]
[ 0.9563 ] Packing sdram param for instance[3]
[ 0.9563 ]
[ 0.9563 ] Parsing platform config file :tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg
[ 0.9563 ] Appending platform config data of size :- 2904
[ 0.9563 ]
[ 0.9563 ] Parsing platform config file :minimal_scr.cfg
[ 0.9563 ] Appending platform config data of size :- 12240
[ 0.9563 ]
[ 0.9563 ] Parsing platform config file :tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg
[ 0.9563 ] Appending platform config data of size :- 24
[ 0.9563 ]
[ 0.9563 ] Parsing platform config file :tegra186-mb1-bct-pmic-quill-p3310-1000-c03.cfg
[ 0.9563 ] Appending platform config data of size :- 684
[ 0.9563 ]
[ 0.9563 ] Parsing platform config file :tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg
[ 0.9563 ] Appending platform config data of size :- 64
[ 0.9563 ]
[ 0.9563 ] Parsing platform config file :tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 0.9563 ] Appending platform config data of size :- 1628
[ 0.9563 ]
[ 0.9563 ] Updating mb1-bct with firmware information
[ 0.9595 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 0.9962 ]
[ 0.9974 ] tegrahost_v2 --align mb1_bct_MB1.bct
[ 1.0080 ]
[ 1.0130 ] tegrahost_v2 --appendsigheader mb1_bct_MB1.bct zerosbk
[ 1.0392 ]
[ 1.0408 ] tegrasign_v2 --key None --list mb1_bct_MB1_sigheader.bct_list.xml
[ 1.0416 ] Assuming zero filled SBK key
[ 1.0621 ]
[ 1.0636 ] tegrahost_v2 --updatesigheader mb1_bct_MB1_sigheader.bct.encrypt mb1_bct_MB1_sigheader.bct.hash zerosbk
[ 1.0860 ]
[ 1.0861 ] Copying signatures
[ 1.0871 ] tegrahost_v2 --chip 0x18 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 1.1362 ]
[ 1.1362 ] Boot Rom communication
[ 1.1374 ] tegrarcm_v2 --chip 0x18 --rcm rcm_list_signed.xml
[ 1.1385 ] BootRom is not running
In my logs of flashing a TX2 with R27.1 this end log is normal:
However, it should continue with this immediately after the BootRom not running line (your log does not):
[ 0.8318 ]
[ 5.8370 ] Retrieving board information
[ 5.8409 ] tegrarcm_v2 --oem platformdetails chip chip_info.bin
[ 5.8445 ] Applet version 01.00.0000
[ 6.0573 ] Saved platform info in chip_info.bin
[ 6.1085 ] Chip minor revision: 2
[ 6.1092 ]
[ 6.1092 ] Sending BCTs
Notice that the BootRom not running line is around 1.1 seconds into the log, which is about right. My system shows this at 0.7 seconds, so must be a bit faster than yours. The next message does not occur for about 5 more seconds…how long did you wait after BootRom not running? Things were correct up to this point.
The flashing process does not proceed past ‘[ 1.1385 ] BootRom is not running’ and nothing else is logged on repeated attempts. I have waited several minutes on each occasion past the last message to see if it would continue.
This is an odd error. On your host , if you run dmesg prior to starting the flash, and then again while it is hanging, is there any kind of error message showing up?
No discernible error messages prior to flash. Following is what I see after running dmseg while the flash process is hanging:
[ 1691.966406] INFO: task tegrarcm_v2:3146 blocked for more than 120 seconds.
[ 1691.966414] Tainted: G OE 4.8.0-58-generic #63~16.04.1-Ubuntu
[ 1691.966416] “echo 0 > /proc/sys/kernel/hung_task_timeout_secs” disables this message.
[ 1691.966419] tegrarcm_v2 D ffff8a9836dbbbc8 0 3146 3088 0x20020000
[ 1691.966428] ffff8a9836dbbbc8 ffff8a983b40c9c0 ffffffffb520d500 ffff8a983a3f0ec0
[ 1691.966432] 0000000000000000 ffff8a9836dbc000 ffff8a9836dbbc10 ffff8a983fc0fe00
[ 1691.966436] 00000000ffffffff 0000000000000000 ffff8a9836dbbbe0 ffffffffb4c960a5
[ 1691.966439] Call Trace:
[ 1691.966449] [] schedule+0x35/0x80
[ 1691.966453] [] schedule_timeout+0x1ea/0x3f0
[ 1691.966459] [] ? put_prev_entity+0x240/0x410
[ 1691.966463] [] ? del_timer_sync+0x50/0x50
[ 1691.966466] [] wait_for_completion_timeout+0xac/0x140
[ 1691.966470] [] ? wake_up_q+0x70/0x70
[ 1691.966476] [] usb_start_wait_urb+0x8c/0x170
[ 1691.966479] [] usb_bulk_msg+0xbd/0x160
[ 1691.966483] [] proc_bulk+0x22c/0x3a0
[ 1691.966486] [] usbdev_do_ioctl+0x907/0x1120
[ 1691.966489] [] usbdev_compat_ioctl+0x10/0x20
[ 1691.966494] [] compat_SyS_ioctl+0xc2/0x330
[ 1691.966498] [] do_int80_syscall_32+0x59/0xb0
[ 1691.966501] [] entry_INT80_compat+0x33/0x40
This is the cause…USB on the host is failing during the flash. It is hard to say though why it is failing, just that it is in bulk transfer mode and then times out. Is this a VM? VMs do this a lot.
Following the latest log’s tail end:
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0101 ] tegrasign_v2 --key None --getmode mode.txt
[ 0.0113 ] Assuming zero filled SBK key
[ 0.0504 ]
[ 0.0505 ] Generating RCM messages
[ 0.0551 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 --download rcm mb1_recovery_prod.bin 0 0
[ 0.0561 ] RCM 0 is saved as rcm_0.rcm
[ 0.0687 ] RCM 1 is saved as rcm_1.rcm
[ 0.0690 ] List of rcm files are saved in rcm_list.xml
[ 0.0902 ]
[ 0.0903 ] Signing RCM messages
[ 0.0914 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0928 ] Assuming zero filled SBK key
[ 0.1280 ]
[ 0.1281 ] Copying signature to RCM mesages
[ 0.1297 ] tegrarcm_v2 --chip 0x18 --updatesig rcm_list_signed.xml
[ 0.1546 ]
[ 0.1547 ] Parsing partition layout
[ 0.1632 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.1901 ]
[ 0.1902 ] Creating list of images to be signed
[ 0.1961 ] tegrahost_v2 --chip 0x18 --partitionlayout flash.xml.bin --list images_list.xml zerosbk
[ 0.3059 ]
[ 0.3059 ] Generating signatures
[ 0.3070 ] tegrasign_v2 --key None --list images_list.xml --pubkeyhash pub_key.key
[ 0.3106 ] Assuming zero filled SBK key
[ 0.4702 ]
[ 0.4702 ] Generating br-bct
[ 0.4803 ] Updating dev and MSS params in BR BCT
[ 0.4804 ] tegrabct_v2 --dev_param emmc.cfg --sdram P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --brbct br_bct.cfg --chip 0x18
[ 0.4822 ] MB1 BCT version is : c
[ 0.5111 ] Copying Sdram info from 0 to 1 set
[ 0.5315 ] Copying Sdram info from 1 to 2 set
[ 0.5365 ] Copying Sdram info from 2 to 3 set
[ 0.5506 ]
[ 0.5506 ] Updating bl info
[ 0.5516 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 0.5693 ]
[ 0.5693 ] Updating Odmdata
[ 0.5744 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --updatefields Odmdata =0x1090000
[ 0.5824 ]
[ 0.5824 ] Get Signed section bct
[ 0.5868 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --listbct bct_list.xml
[ 0.6057 ]
[ 0.6057 ] Signing BCT
[ 0.6068 ] tegrasign_v2 --key None --list bct_list.xml --pubkeyhash pub_key.key
[ 0.6078 ] Assuming zero filled SBK key
[ 0.6355 ]
[ 0.6355 ] Updating BCT with signature
[ 0.6372 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --updatesig bct_list_signed.xml
[ 0.6506 ]
[ 0.6506 ] Generating coldboot mb1-bct
[ 0.6519 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct.cfg --sdram P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --misc tegra186-mb1-bct-misc-si-l4t.cfg --scr minimal_scr.cfg --pinmux tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmc tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --pmic tegra186-mb1-bct-pmic-quill-p3310-1000-c03.cfg --brcommand tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --prod tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 0.6584 ] MB1 BCT version is : c
[ 0.6694 ] Copying Sdram info from 0 to 1 set
[ 0.6908 ] Copying Sdram info from 1 to 2 set
[ 0.6946 ] Copying Sdram info from 2 to 3 set
[ 0.6975 ] Packing sdram param for instance[0]
[ 0.7017 ] Packing sdram param for instance[1]
[ 0.7077 ] Packing sdram param for instance[2]
[ 0.7123 ] Packing sdram param for instance[3]
[ 0.7135 ] Parsing platform config file :tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg
[ 0.7224 ] Appending platform config data of size :- 2904
[ 0.7340 ]
[ 0.7340 ] Parsing platform config file :minimal_scr.cfg
[ 0.7340 ] Appending platform config data of size :- 12240
[ 0.7340 ]
[ 0.7340 ] Parsing platform config file :tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg
[ 0.7340 ] Appending platform config data of size :- 24
[ 0.7340 ]
[ 0.7340 ] Parsing platform config file :tegra186-mb1-bct-pmic-quill-p3310-1000-c03.cfg
[ 0.7340 ] Appending platform config data of size :- 684
[ 0.7341 ]
[ 0.7341 ] Parsing platform config file :tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg
[ 0.7341 ] Appending platform config data of size :- 64
[ 0.7341 ]
[ 0.7341 ] Parsing platform config file :tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 0.7341 ] Appending platform config data of size :- 1628
[ 0.7341 ]
[ 0.7341 ] Updating mb1-bct with firmware information
[ 0.7394 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 0.7664 ]
[ 0.7674 ] tegrahost_v2 --align mb1_cold_boot_bct_MB1.bct
[ 0.7802 ]
[ 0.7814 ] tegrahost_v2 --appendsigheader mb1_cold_boot_bct_MB1.bct zerosbk
[ 0.7933 ]
[ 0.8007 ] tegrasign_v2 --key None --list mb1_cold_boot_bct_MB1_sigheader.bct_list.xml
[ 0.8017 ] Assuming zero filled SBK key
[ 0.8363 ]
[ 0.8414 ] tegrahost_v2 --updatesigheader mb1_cold_boot_bct_MB1_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_sigheader.bct.hash zerosbk
[ 0.8589 ]
[ 0.8590 ] Generating recovery mb1-bct
[ 0.8605 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct.cfg --sdram P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --misc tegra186-mb1-bct-misc-si-l4t.cfg --scr minimal_scr.cfg --pinmux tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmc tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --pmic tegra186-mb1-bct-pmic-quill-p3310-1000-c03.cfg --brcommand tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --prod tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 0.8680 ] MB1 BCT version is : c
[ 0.8757 ] Copying Sdram info from 0 to 1 set
[ 0.8972 ] Copying Sdram info from 1 to 2 set
[ 0.9001 ] Copying Sdram info from 2 to 3 set
[ 0.9032 ] Packing sdram param for instance[0]
[ 0.9077 ] Packing sdram param for instance[1]
[ 0.9201 ] Packing sdram param for instance[2]
[ 0.9201 ] Packing sdram param for instance[3]
[ 0.9201 ]
[ 0.9201 ] Parsing platform config file :tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg
[ 0.9201 ] Appending platform config data of size :- 2904
[ 0.9202 ]
[ 0.9202 ] Parsing platform config file :minimal_scr.cfg
[ 0.9202 ] Appending platform config data of size :- 12240
[ 0.9202 ]
[ 0.9202 ] Parsing platform config file :tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg
[ 0.9202 ] Appending platform config data of size :- 24
[ 0.9202 ]
[ 0.9202 ] Parsing platform config file :tegra186-mb1-bct-pmic-quill-p3310-1000-c03.cfg
[ 0.9202 ] Appending platform config data of size :- 684
[ 0.9202 ]
[ 0.9202 ] Parsing platform config file :tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg
[ 0.9202 ] Appending platform config data of size :- 64
[ 0.9202 ]
[ 0.9202 ] Parsing platform config file :tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg
[ 0.9202 ] Appending platform config data of size :- 1628
[ 0.9202 ]
[ 0.9210 ] Updating mb1-bct with firmware information
[ 0.9240 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 0.9567 ]
[ 0.9579 ] tegrahost_v2 --align mb1_bct_MB1.bct
[ 0.9729 ]
[ 0.9740 ] tegrahost_v2 --appendsigheader mb1_bct_MB1.bct zerosbk
[ 0.9957 ]
[ 0.9972 ] tegrasign_v2 --key None --list mb1_bct_MB1_sigheader.bct_list.xml
[ 1.0012 ] Assuming zero filled SBK key
[ 1.0260 ]
[ 1.0276 ] tegrahost_v2 --updatesigheader mb1_bct_MB1_sigheader.bct.encrypt mb1_bct_MB1_sigheader.bct.hash zerosbk
[ 1.0508 ]
[ 1.0509 ] Copying signatures
[ 1.0519 ] tegrahost_v2 --chip 0x18 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 1.0840 ]
[ 1.0841 ] Boot Rom communication
[ 1.0860 ] tegrarcm_v2 --chip 0x18 --rcm rcm_list_signed.xml
[ 1.0898 ] BootRom is not running
[ 1.1482 ]
[ 6.1537 ] Retrieving board information
[ 6.1561 ] tegrarcm_v2 --oem platformdetails chip chip_info.bin
[ 6.1578 ] Applet is not running on device. Continue with Bootloader
[ 1013.0589 ]
[ 1013.0700 ] tegradevflash_v2 --oem platformdetails chip chip_info.bin
[ 1013.0711 ] CPU Bootloader is not running on device.
[ 2028.8669 ]
Error: Return value 4
Command tegradevflash_v2 --oem platformdetails chip chip_info.bin
Failed flashing t186ref.
Anyone have a list of the meaning of the return values on a TX2 flash?
The host itself has USB issues, else dmesg would not have given the driver error. Same question…is the host a VM? VMs most often have USB issues.
Hi architectureofthings,
Could you describe your environment? As linuxdev point out, do you use a VM?
Is the usb works normally?
Do you have any logs from UART?
kayccc
July 27, 2017, 4:43am
14
Have you clarified the cause and resolved this flash issue?
Any result can be shared?
I was able to flash my TX2. Following are the details associated with my preflash setup:
Host:
Mac Mini Server (Late 2012) with macOS Sierra Version 10.12.6
VirtualBox 5.1.24 r117012 (Qt5.6.2) with ubuntu 16.04 LTS
VirtualBox 5.1.24 Extension Pack
Configure Virtualbox USB settings via the Devices->USB->USB Settings menu:
Enable USB Controller.
Select USB 3.0 (xHCI) Controller.
Once the TX2 in recovery mode, confirm NVIDIA Corp. APX appears in a lsusb command listing
and is check marked via Devices->USB menu.
Add NVIDIA Corp. APX to the list of USB Device Filters. Set the ‘remote’ setting to ‘any’ for this specific filter.
Target:
Jetson TX2
Connectivity:
Host and Target connected to internet connected router via ethernet cables.
Host and Target connected via USB Micro-B cable
Host and Target connected via USB to TTL Serial Cable
