./tegraflash.py --chip 0x18 --applet “/home/Jetson/tx2/64_TX2/Linux_for_Tegra_tx2/bootloader/mb1_recovery_prod.bin” --cmd “dump eeprom boardinfo cvm.bin” --skipuid
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0023 ] Generating RCM messages
[ 0.0037 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 --download rcm /home/Jetson/tx2/64_TX2/Linux_for_Tegra_tx2/bootloader/mb1_recovery_prod.bin 0 0
[ 0.0052 ] RCM 0 is saved as rcm_0.rcm
[ 0.0330 ] RCM 1 is saved as rcm_1.rcm
[ 0.0330 ] List of rcm files are saved in rcm_list.xml
[ 0.0330 ]
[ 0.0330 ] Signing RCM messages
[ 0.0520 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0539 ] Assuming zero filled SBK key
[ 0.0628 ]
[ 0.0629 ] Copying signature to RCM mesages
[ 0.0650 ] tegrarcm_v2 --chip 0x18 --updatesig rcm_list_signed.xml
[ 0.0676 ]
[ 0.0677 ] Boot Rom communication
[ 0.0704 ] tegrarcm_v2 --chip 0x18 --rcm rcm_list_signed.xml --skipuid
[ 0.0716 ] RCM version 0X180001
[ 0.0745 ] Boot Rom communication completed
[ 1.0986 ]
[ 1.1018 ] tegrarcm_v2 --isapplet
[ 1.1032 ] USB communication failed.Check if device is in recovery
[ 1.2432 ]
[ 1.2634 ] tegradevflash_v2 --iscpubl
[ 1.2649 ] CPU Bootloader is not running on device.
[ 1.3275 ]
[ 2.3972 ] Retrieving EEPROM data
[ 2.3973 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/Jetson/tx2/64_TX2/Linux_for_Tegra_tx2/bootloader/cvm.bin
[ 2.3983 ] Applet version 01.00.0000
[ 2.4547 ] Saved platform info in /home/Jetson/tx2/64_TX2/Linux_for_Tegra_tx2/bootloader/cvm.bin
[ 2.5986 ]
Board ID(3310) version(B00)
copying bctfile(/home/Jetson/tx2/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/BCT/P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg)… done.
copying misc_config(/home/Jetson/tx2/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/BCT/tegra186-mb1-bct-misc-si-l4t.cfg)… done.
copying pinmux_config(/home/Jetson/tx2/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/BCT/tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg)… done.
copying pmic_config(/home/Jetson/tx2/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/BCT/tegra186-mb1-bct-pmic-quill-p3310-1000-c03.cfg)… done.
copying pmc_config(/home/Jetson/tx2/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/BCT/tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg)… done.
copying prod_config(/home/Jetson/tx2/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/BCT/tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg)… done.
copying scr_config(/home/Jetson/tx2/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/BCT/minimal_scr.cfg)… done.
copying scr_cold_boot_config(/home/Jetson/tx2/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/BCT/mobile_scr.cfg)… done.
copying bootrom_config(/home/Jetson/tx2/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/BCT/tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg)… done.
copying dev_params(/home/Jetson/tx2/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/BCT/emmc.cfg)… done.
Existing bootloader(/home/Jetson/tx2/64_TX2/Linux_for_Tegra_tx2/bootloader/nvtboot_cpu.bin) reused.
populating kernel to rootfs… done.
populating initrd to rootfs… done.
populating extlinux.conf.emmc to rootfs… done.
populating /home/Jetson/tx2/64_TX2/Linux_for_Tegra_tx2/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb to rootfs… done.
done.
Making Boot image… done.
Existing sosfile(/home/Jetson/tx2/64_TX2/Linux_for_Tegra_tx2/bootloader/mb1_recovery_prod.bin) reused.
copying tegraboot(/home/Jetson/tx2/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/nvtboot.bin)… done.
Existing mb2blfile(/home/Jetson/tx2/64_TX2/Linux_for_Tegra_tx2/bootloader/nvtboot_recovery.bin) reused.
Existing mtspreboot(/home/Jetson/tx2/64_TX2/Linux_for_Tegra_tx2/bootloader/preboot_d15_prod_cr.bin) reused.
Existing mts(/home/Jetson/tx2/64_TX2/Linux_for_Tegra_tx2/bootloader/mce_mts_d15_prod_cr.bin) reused.
Existing mb1file(/home/Jetson/tx2/64_TX2/Linux_for_Tegra_tx2/bootloader/mb1_prod.bin) reused.
Existing bpffile(/home/Jetson/tx2/64_TX2/Linux_for_Tegra_tx2/bootloader/bpmp.bin) reused.
copying bpfdtbfile(/home/Jetson/tx2/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/tegra186-a02-bpmp-quill-p3310-1000-c01-00-te770d-ucm2.dtb)… done.
Existing scefile(/home/Jetson/tx2/64_TX2/Linux_for_Tegra_tx2/bootloader/camera-rtcpu-sce.bin) reused.
Existing spefile(/home/Jetson/tx2/64_TX2/Linux_for_Tegra_tx2/bootloader/spe.bin) reused.
copying wb0boot(/home/Jetson/tx2/64_TX2/Linux_for_Tegra_tx2/bootloader/t186ref/warmboot.bin)… done.
Existing tosfile(/home/Jetson/tx2/64_TX2/Linux_for_Tegra_tx2/bootloader/tos.img) reused.
Existing eksfile(/home/Jetson/tx2/64_TX2/Linux_for_Tegra_tx2/bootloader/eks.img) reused.
copying dtbfile(/home/Jetson/tx2/64_TX2/Linux_for_Tegra_tx2/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb)… done.
Making system.img…
populating rootfs from /home/Jetson/tx2/64_TX2/Linux_for_Tegra_tx2/rootfs … tar: usr/share/help/kn/gnome-help/color-calibrationdevices.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/kn/gnome-help/hardware-cardreader.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/kn/gnome-help/privacy-history-recent-off.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/kn/gnome-help/printing-booklet-duplex.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/ko/eog: time stamp 2020-09-05 01:37:29 is 81323070.237604235 s in the future
tar: usr/share/help/fr/gedit/legal.xml: Cannot open: Permission denied
tar: usr/share/help/fr/gedit/gedit-tabs-moving.page: time stamp 2032-01-26 15:54:48 is 440802106.552148912 s in the future
tar: usr/share/help/kk/ubuntu-help/net-wireless-troubleshooting-initial-check.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/kk/ubuntu-help/net-wired-connect.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/kk/ubuntu-help/color-assignprofiles.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/kk/ubuntu-help/color-whatisprofile.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/kk/ubuntu-help/wacom-left-handed.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/kk/ubuntu-help/music-cantplay-drm.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/kk/ubuntu-help/color-calibrationtargets.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/kk/ubuntu-help/unity-menubar-intro.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/kk/ubuntu-help/tips-specialchars.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/kk/ubuntu-help/addremove-install.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/kk/ubuntu-help/net-wireless-troubleshooting-device-drivers.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/kk/ubuntu-help/color-missingvcgt.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/kk/ubuntu-help/nautilus-behavior.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/kk/ubuntu-help/user-goodpassword.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/kk/ubuntu-help/documents-collections.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/kk/ubuntu-help/printing-cancel-job.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/kk/ubuntu-help/color-calibrate-screen.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/kk/ubuntu-help/power-batterylife.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/kk/ubuntu-help/screen-shot-record.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/kk/ubuntu-help/unity-scrollbars-intro.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/kk/ubuntu-help/color-notifications.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/kk/ubuntu-help/user-changepicture.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/kk/ubuntu-help/shell-apps-favorites.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/kk/ubuntu-help/color-whyimportant.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/kk/ubuntu-help/net-wireless-find.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/kk/ubuntu-help/keyboard-shortcuts-set.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/kk/ubuntu-help/net-wireless-troubleshooting.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/kk/ubuntu-help/shell-windows-states.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/kk/ubuntu-help/bluetooth-problem-connecting.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/kk/ubuntu-help/music-player-notrecognized.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/kk/ubuntu-help/documents-formats.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/kk/ubuntu-help/power-batterybroken.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/kk/ubuntu-help/session-screenlocks.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/kk/ubuntu-help/net-wireless-wepwpa.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/kk/ubuntu-help/net-wireless-edit-connection.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/kk/ubuntu-help/net-wireless-hidden.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/kk/ubuntu-help/music-player-newipod.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/kk/ubuntu-help/user-admin-change.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/kk/ubuntu-help/power-constantfan.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/kk/ubuntu-help/net-fixed-ip-address.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/ta/ubuntu-help/color-why-calibrate.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/ta/ubuntu-help/contacts-edit-details.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/ta/ubuntu-help/contacts-link-unlink.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/ta/ubuntu-help/unity-dash-photos.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/ta/ubuntu-help/shell-windows-switching.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/de/ubuntu-help/power-batterylife.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/de/ubuntu-help/unity-launcher-shapes.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/de/ubuntu-help/shell-apps-favorites.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/de/ubuntu-help/unity-dash-photos.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/de/ubuntu-help/unity-introduction.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/de/ubuntu-help/color-canshareprofiles.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/de/gnome-help/keyboard-key-super.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/de/gnome-help/music-cantplay-drm.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/de/gnome-help/color-why-calibrate.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/de/gnome-help/net-firewall-on-off.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/de/gnome-help/look-display-fuzzy.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/de/gnome-help/color-whyimportant.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/de/gnome-help/accounts-provider-not-available.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/de/gnome-help/bluetooth-connect-device.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/de/gnome-help/nautilus-file-properties-permissions.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/de/gnome-help/bluetooth-remove-connection.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/de/gnome-help/display-brightness.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/de/gnome-help/shell-introduction.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/pt_BR/ubuntu-help/addremove-install-synaptic.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/pt_BR/ubuntu-help/wacom-left-handed.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/pt_BR/ubuntu-help/clock-timezone.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/pt_BR/ubuntu-help/color-calibrationdevices.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/pt_BR/ubuntu-help/nautilus-behavior.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/pt_BR/ubuntu-help/documents-previews.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/pt_BR/ubuntu-help/user-changepicture.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/pt_BR/ubuntu-help/net-wireless-find.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/pt_BR/ubuntu-help/accounts-disable-service.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/pt_BR/ubuntu-help/bluetooth-turn-on-off.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/pt_BR/ubuntu-help/documents-formats.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/pt_BR/ubuntu-help/accounts-whyadd.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/pt_BR/ubuntu-help/startup-applications.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/pt_BR/ubuntu-help/a11y-visualalert.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/pt_BR/ubuntu-help/printing-setup-default-printer.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/pt_BR/ubuntu-help/net-wireless-wepwpa.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/pt_BR/ubuntu-help/unity-launcher-menu.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/pt_BR/ubuntu-help/color-virtualdevice.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/pt_BR/ubuntu-help/mouse-mousekeys.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/pt_BR/ubuntu-help/hardware-problems-graphics.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/pt_BR/ubuntu-help/net-macaddress.page: Cannot create symlink to ‘’: No such file or directory
tar: usr/share/help/pt_BR/ubuntu-help/power-closelid.page: Cannot create symlink to ‘’: No such file or directory
tar: Exiting with failure status due to previous errors
failed.
