I wanted to re-flash a Jetson TX1 to start from clean state. Used Jetpack 3.1 and did everything according to steps but it produced errot that it failed to flash device and said to correct error from log flash_os_64_TX1 file. I cannot understand what seems to be problem.
[code]copying bctfile(/media/eduards/Data/Programming/Jetpack/64_TX1/Linux_for_Tegra_64_tx1/bootloader/t210ref/BCT/P2180_A00_LP4_DSC_204Mhz.cfg)… done.
copying bootloader(/media/eduards/Data/Programming/Jetpack/64_TX1/Linux_for_Tegra_64_tx1/bootloader/t210ref/cboot.bin)… done.
populating kernel to rootfs… done.
populating initrd to rootfs… done.
populating extlinux.conf.emmc to rootfs… done.
populating /media/eduards/Data/Programming/Jetpack/64_TX1/Linux_for_Tegra_64_tx1/kernel/dtb/tegra210-jetson-tx1-p2597-2180-a01-devkit.dtb to rootfs… done.
done.
Making Boot image… done.
copying bcffile(/media/eduards/Data/Programming/Jetpack/64_TX1/Linux_for_Tegra_64_tx1/bootloader/t210ref/cfg/board_config_p2597-devkit.xml)… done.
Existing sosfile(/media/eduards/Data/Programming/Jetpack/64_TX1/Linux_for_Tegra_64_tx1/bootloader/nvtboot_recovery.bin) reused.
copying tegraboot(/media/eduards/Data/Programming/Jetpack/64_TX1/Linux_for_Tegra_64_tx1/bootloader/t210ref/nvtboot.bin)… done.
Existing bpffile(/media/eduards/Data/Programming/Jetpack/64_TX1/Linux_for_Tegra_64_tx1/bootloader/bpmp.bin) reused.
copying wb0boot(/media/eduards/Data/Programming/Jetpack/64_TX1/Linux_for_Tegra_64_tx1/bootloader/t210ref/warmboot.bin)… done.
Existing tosfile(/media/eduards/Data/Programming/Jetpack/64_TX1/Linux_for_Tegra_64_tx1/bootloader/tos.img) reused.
Existing eksfile(/media/eduards/Data/Programming/Jetpack/64_TX1/Linux_for_Tegra_64_tx1/bootloader/eks.img) reused.
copying dtbfile(/media/eduards/Data/Programming/Jetpack/64_TX1/Linux_for_Tegra_64_tx1/kernel/dtb/tegra210-jetson-tx1-p2597-2180-a01-devkit.dtb)… done.
Making system.img…
populating rootfs from /media/eduards/Data/Programming/Jetpack/64_TX1/Linux_for_Tegra_64_tx1/rootfs … done.
Sync’ing system.img … done.
Converting RAW image to Sparse image…
---- Raw to Sparse Image Converter v1.0 ----------------------------
0: RAW: 3706880( 905 blks) ==> 28:3706892
1: SKP: 32768( 8 blks) ==> 3706920:12
2: RAW: 24576( 6 blks) ==> 3706932:24588
3: SKP: 40960( 10 blks) ==> 3731520:12
4: RAW: 12185600( 2975 blks) ==> 3731532:12185612
5: SKP: 21368832( 5217 blks) ==> 15917144:12
6: RAW: 57733120( 14095 blks) ==> 15917156:57733132
7: SKP: 39124992( 9552 blks) ==> 73650288:12
8: RAW: 8192( 2 blks) ==> 73650300:8204
9: SKP: 3665920( 895 blks) ==> 73658504:12
10: RAW: 1449984( 354 blks) ==> 73658516:1449996
11: SKP: 667648( 163 blks) ==> 75108512:12
12: RAW: 98304( 24 blks) ==> 75108524:98316
13: SKP: 24576( 6 blks) ==> 75206840:12
14: RAW: 106496( 26 blks) ==> 75206852:106508
15: SKP: 12288( 3 blks) ==> 75313360:12
16: RAW: 4096( 1 blks) ==> 75313372:4108
17: SKP: 16384( 4 blks) ==> 75317480:12
18: RAW: 1130496( 276 blks) ==> 75317492:1130508
19: SKP: 4096( 1 blks) ==> 76448000:12
20: RAW: 307200( 75 blks) ==> 76448012:307212
21: SKP: 4096( 1 blks) ==> 76755224:12
22: RAW: 122880( 30 blks) ==> 76755236:122892
23: SKP: 4096( 1 blks) ==> 76878128:12
24: RAW: 59891712( 14622 blks) ==> 76878140:59891724
25: SKP: 4096( 1 blks) ==> 136769864:12
26: RAW: 43204608( 10548 blks) ==> 136769876:43204620
27: SKP: 4096( 1 blks) ==> 179974496:12
28: RAW: 40960( 10 blks) ==> 179974508:40972
29: SKP: 4096( 1 blks) ==> 180015480:12
30: RAW: 450560( 110 blks) ==> 180015492:450572
31: SKP: 4096( 1 blks) ==> 180466064:12
32: RAW: 434176( 106 blks) ==> 180466076:434188
33: SKP: 4096( 1 blks) ==> 180900264:12
34: RAW: 131072( 32 blks) ==> 180900276:131084
35: SKP: 16384( 4 blks) ==> 181031360:12
36: RAW: 122880( 30 blks) ==> 181031372:122892
37: SKP: 4096( 1 blks) ==> 181154264:12
38: RAW: 557056( 136 blks) ==> 181154276:557068
39: SKP: 36864( 9 blks) ==> 181711344:12
40: RAW: 651264( 159 blks) ==> 181711356:651276
41: SKP: 4096( 1 blks) ==> 182362632:12
42: RAW: 73728( 18 blks) ==> 182362644:73740
43: SKP: 73728( 18 blks) ==> 182436384:12
44: RAW: 4096( 1 blks) ==> 182436396:4108
45: SKP: 8192( 2 blks) ==> 182440504:12
46: RAW: 4096( 1 blks) ==> 182440516:4108
47: SKP: 4096( 1 blks) ==> 182444624:12
48: RAW: 4096( 1 blks) ==> 182444636:4108
49: SKP: 8192( 2 blks) ==> 182448744:12
50: RAW: 16384( 4 blks) ==> 182448756:16396
51: SKP: 4096( 1 blks) ==> 182465152:12
52: RAW: 4096( 1 blks) ==> 182465164:4108
53: SKP: 4096( 1 blks) ==> 182469272:12
54: RAW: 4096( 1 blks) ==> 182469284:4108
55: SKP: 4096( 1 blks) ==> 182473392:12
56: RAW: 12288( 3 blks) ==> 182473404:12300
57: SKP: 8192( 2 blks) ==> 182485704:12
58: RAW: 24576( 6 blks) ==> 182485716:24588
59: SKP: 4096( 1 blks) ==> 182510304:12
60: RAW: 8192( 2 blks) ==> 182510316:8204
61: SKP: 4096( 1 blks) ==> 182518520:12
62: RAW: 8192( 2 blks) ==> 182518532:8204
63: SKP: 12288( 3 blks) ==> 182526736:12
64: RAW: 16384( 4 blks) ==> 182526748:16396
65: SKP: 4096( 1 blks) ==> 182543144:12
66: RAW: 8192( 2 blks) ==> 182543156:8204
67: SKP: 4096( 1 blks) ==> 182551360:12
68: RAW: 73728( 18 blks) ==> 182551372:73740
69: SKP: 12288( 3 blks) ==> 182625112:12
70: RAW: 4096( 1 blks) ==> 182625124:4108
71: SKP: 8192( 2 blks) ==> 182629232:12
72: RAW: 24576( 6 blks) ==> 182629244:24588
73: SKP: 8192( 2 blks) ==> 182653832:12
74: RAW: 16384( 4 blks) ==> 182653844:16396
75: SKP: 4096( 1 blks) ==> 182670240:12
76: RAW: 4096( 1 blks) ==> 182670252:4108
77: SKP: 20480( 5 blks) ==> 182674360:12
78: RAW: 4096( 1 blks) ==> 182674372:4108
79: SKP: 8192( 2 blks) ==> 182678480:12
80: RAW: 4096( 1 blks) ==> 182678492:4108
81: SKP: 8192( 2 blks) ==> 182682600:12
82: RAW: 8192( 2 blks) ==> 182682612:8204
83: SKP: 4096( 1 blks) ==> 182690816:12
84: RAW: 4096( 1 blks) ==> 182690828:4108
85: SKP: 12288( 3 blks) ==> 182694936:12
86: RAW: 4096( 1 blks) ==> 182694948:4108
87: SKP: 45056( 11 blks) ==> 182699056:12
88: RAW: 8192( 2 blks) ==> 182699068:8204
89: SKP: 28672( 7 blks) ==> 182707272:12
90: RAW: 4096( 1 blks) ==> 182707284:4108
91: SKP: 40960( 10 blks) ==> 182711392:12
92: RAW: 4096( 1 blks) ==> 182711404:4108
93: SKP: 16384( 4 blks) ==> 182715512:12
94: RAW: 16384( 4 blks) ==> 182715524:16396
95: SKP: 8192( 2 blks) ==> 182731920:12
96: RAW: 53248( 13 blks) ==> 182731932:53260
97: SKP: 16384( 4 blks) ==> 182785192:12
98: RAW: 4096( 1 blks) ==> 182785204:4108
99: SKP: 8192( 2 blks) ==> 182789312:12
100: RAW: 8192( 2 blks) ==> 182789324:8204
101: SKP: 4096( 1 blks) ==> 182797528:12
102: RAW: 385024( 94 blks) ==> 182797540:385036
103: SKP: 4096( 1 blks) ==> 183182576:12
104: RAW: 241664( 59 blks) ==> 183182588:241676
105: SKP: 32768( 8 blks) ==> 183424264:12
106: RAW: 32657408( 7973 blks) ==> 183424276:32657420
107: SKP: 49152( 12 blks) ==> 216081696:12
108: RAW: 4096( 1 blks) ==> 216081708:4108
109: SKP: 61440( 15 blks) ==> 216085816:12
110: RAW: 20480( 5 blks) ==> 216085828:20492
111: SKP: 16384( 4 blks) ==> 216106320:12
112: RAW: 33636352( 8212 blks) ==> 216106332:33636364
113: SKP: 16384( 4 blks) ==> 249742696:12
114: RAW: 8192( 2 blks) ==> 249742708:8204
115: SKP: 16384( 4 blks) ==> 249750912:12
116: RAW: 32768( 8 blks) ==> 249750924:32780
117: SKP: 4096( 1 blks) ==> 249783704:12
118: RAW: 4096( 1 blks) ==> 249783716:4108
119: SKP: 12288( 3 blks) ==> 249787824:12
120: RAW: 8192( 2 blks) ==> 249787836:8204
121: SKP: 12288( 3 blks) ==> 249796040:12
122: RAW: 8192( 2 blks) ==> 249796052:8204
123: SKP: 8192( 2 blks) ==> 249804256:12
124: RAW: 28672( 7 blks) ==> 249804268:28684
125: SKP: 4096( 1 blks) ==> 249832952:12
126: RAW: 4096( 1 blks) ==> 249832964:4108
127: SKP: 12288( 3 blks) ==> 249837072:12
128: RAW: 8192( 2 blks) ==> 249837084:8204
129: SKP: 12288( 3 blks) ==> 249845288:12
130: RAW: 32768( 8 blks) ==> 249845300:32780
131: SKP: 12288( 3 blks) ==> 249878080:12
132: RAW: 8192( 2 blks) ==> 249878092:8204
133: SKP: 12288( 3 blks) ==> 249886296:12
134: RAW: 4096( 1 blks) ==> 249886308:4108
135: SKP: 12288( 3 blks) ==> 249890416:12
136: RAW: 8192( 2 blks) ==> 249890428:8204
137: SKP: 12288( 3 blks) ==> 249898632:12
138: RAW: 8192( 2 blks) ==> 249898644:8204
139: SKP: 12288( 3 blks) ==> 249906848:12
140: RAW: 4096( 1 blks) ==> 249906860:4108
141: SKP: 12288( 3 blks) ==> 249910968:12
142: RAW: 8192( 2 blks) ==> 249910980:8204
143: SKP: 12288( 3 blks) ==> 249919184:12
144: RAW: 8192( 2 blks) ==> 249919196:8204
145: SKP: 12288( 3 blks) ==> 249927400:12
146: RAW: 4096( 1 blks) ==> 249927412:4108
147: SKP: 12288( 3 blks) ==> 249931520:12
148: RAW: 8192( 2 blks) ==> 249931532:8204
149: SKP: 12288( 3 blks) ==> 249939736:12
150: RAW: 8192( 2 blks) ==> 249939748:8204
151: SKP: 12288( 3 blks) ==> 249947952:12
152: RAW: 4096( 1 blks) ==> 249947964:4108
153: SKP: 12288( 3 blks) ==> 249952072:12
154: RAW: 8192( 2 blks) ==> 249952084:8204
155: SKP: 12288( 3 blks) ==> 249960288:12
156: RAW: 8192( 2 blks) ==> 249960300:8204
157: SKP: 12288( 3 blks) ==> 249968504:12
158: RAW: 4096( 1 blks) ==> 249968516:4108
159: SKP: 12288( 3 blks) ==> 249972624:12
160: RAW: 8192( 2 blks) ==> 249972636:8204
161: SKP: 12288( 3 blks) ==> 249980840:12
162: RAW: 4096( 1 blks) ==> 249980852:4108
163: SKP: 12288( 3 blks) ==> 249984960:12
164: RAW: 8192( 2 blks) ==> 249984972:8204
165: SKP: 12288( 3 blks) ==> 249993176:12
166: RAW: 4096( 1 blks) ==> 249993188:4108
167: SKP: 12288( 3 blks) ==> 249997296:12
168: RAW: 8192( 2 blks) ==> 249997308:8204
169: SKP: 12288( 3 blks) ==> 250005512:12
170: RAW: 4096( 1 blks) ==> 250005524:4108
171: SKP: 12288( 3 blks) ==> 250009632:12
172: RAW: 8192( 2 blks) ==> 250009644:8204
173: SKP: 12288( 3 blks) ==> 250017848:12
174: RAW: 8192( 2 blks) ==> 250017860:8204
175: SKP: 8192( 2 blks) ==> 250026064:12
176: RAW: 8192( 2 blks) ==> 250026076:8204
177: SKP: 4096( 1 blks) ==> 250034280:12
178: RAW: 4096( 1 blks) ==> 250034292:4108
179: SKP: 16384( 4 blks) ==> 250038400:12
180: RAW: 16384( 4 blks) ==> 250038412:16396
181: SKP: 12288( 3 blks) ==> 250054808:12
182: RAW: 8192( 2 blks) ==> 250054820:8204
183: SKP: 4096( 1 blks) ==> 250063024:12
184: RAW: 8192( 2 blks) ==> 250063036:8204
185: SKP: 12288( 3 blks) ==> 250071240:12
186: RAW: 12288( 3 blks) ==> 250071252:12300
187: SKP: 12288( 3 blks) ==> 250083552:12
188: RAW: 8192( 2 blks) ==> 250083564:8204
189: SKP: 12288( 3 blks) ==> 250091768:12
190: RAW: 8192( 2 blks) ==> 250091780:8204
191: SKP: 12288( 3 blks) ==> 250099984:12
192: RAW: 8192( 2 blks) ==> 250099996:8204
193: SKP: 12288( 3 blks) ==> 250108200:12
194: RAW: 8192( 2 blks) ==> 250108212:8204
195: SKP: 12288( 3 blks) ==> 250116416:12
196: RAW: 4096( 1 blks) ==> 250116428:4108
197: SKP: 12288( 3 blks) ==> 250120536:12
198: RAW: 8192( 2 blks) ==> 250120548:8204
199: SKP: 12288( 3 blks) ==> 250128752:12
200: RAW: 8192( 2 blks) ==> 250128764:8204
201: SKP: 12288( 3 blks) ==> 250136968:12
202: RAW: 4096( 1 blks) ==> 250136980:4108
203: SKP: 12288( 3 blks) ==> 250141088:12
204: RAW: 8192( 2 blks) ==> 250141100:8204
205: SKP: 12288( 3 blks) ==> 250149304:12
206: RAW: 4096( 1 blks) ==> 250149316:4108
207: SKP: 12288( 3 blks) ==> 250153424:12
208: RAW: 8192( 2 blks) ==> 250153436:8204
209: SKP: 12288( 3 blks) ==> 250161640:12
210: RAW: 8192( 2 blks) ==> 250161652:8204
211: SKP: 8192( 2 blks) ==> 250169856:12
212: RAW: 8192( 2 blks) ==> 250169868:8204
213: SKP: 12288( 3 blks) ==> 250178072:12
214: RAW: 8192( 2 blks) ==> 250178084:8204
215: SKP: 12288( 3 blks) ==> 250186288:12
216: RAW: 4096( 1 blks) ==> 250186300:4108
217: SKP: 12288( 3 blks) ==> 250190408:12
218: RAW: 8192( 2 blks) ==> 250190420:8204
219: SKP: 12288( 3 blks) ==> 250198624:12
220: RAW: 4096( 1 blks) ==> 250198636:4108
221: SKP: 12288( 3 blks) ==> 250202744:12
222: RAW: 8192( 2 blks) ==> 250202756:8204
223: SKP: 12288( 3 blks) ==> 250210960:12
224: RAW: 4096( 1 blks) ==> 250210972:4108
225: SKP: 12288( 3 blks) ==> 250215080:12
226: RAW: 8192( 2 blks) ==> 250215092:8204
227: SKP: 12288( 3 blks) ==> 250223296:12
228: RAW: 4096( 1 blks) ==> 250223308:4108
229: SKP: 12288( 3 blks) ==> 250227416:12
230: RAW: 8192( 2 blks) ==> 250227428:8204
231: SKP: 12288( 3 blks) ==> 250235632:12
232: RAW: 8192( 2 blks) ==> 250235644:8204
233: SKP: 12288( 3 blks) ==> 250243848:12
234: RAW: 4096( 1 blks) ==> 250243860:4108
235: SKP: 12288( 3 blks) ==> 250247968:12
236: RAW: 8192( 2 blks) ==> 250247980:8204
237: SKP: 12288( 3 blks) ==> 250256184:12
238: RAW: 4096( 1 blks) ==> 250256196:4108
239: SKP: 12288( 3 blks) ==> 250260304:12
240: RAW: 4096( 1 blks) ==> 250260316:4108
241: SKP: 4096( 1 blks) ==> 250264424:12
242: RAW: 4096( 1 blks) ==> 250264436:4108
243: SKP: 12288( 3 blks) ==> 250268544:12
244: RAW: 4096( 1 blks) ==> 250268556:4108
245: SKP: 12288( 3 blks) ==> 250272664:12
246: RAW: 8192( 2 blks) ==> 250272676:8204
247: SKP: 12288( 3 blks) ==> 250280880:12
248: RAW: 8192( 2 blks) ==> 250280892:8204
249: SKP: 12288( 3 blks) ==> 250289096:12
250: RAW: 4096( 1 blks) ==> 250289108:4108
251: SKP: 12288( 3 blks) ==> 250293216:12
252: RAW: 8192( 2 blks) ==> 250293228:8204
253: SKP: 12288( 3 blks) ==> 250301432:12
254: RAW: 8192( 2 blks) ==> 250301444:8204
255: SKP: 12288( 3 blks) ==> 250309648:12
256: RAW: 4096( 1 blks) ==> 250309660:4108
257: SKP: 12288( 3 blks) ==> 250313768:12
258: RAW: 8192( 2 blks) ==> 250313780:8204
259: SKP: 12288( 3 blks) ==> 250321984:12
260: RAW: 8192( 2 blks) ==> 250321996:8204
261: SKP: 8192( 2 blks) ==> 250330200:12
262: RAW: 8192( 2 blks) ==> 250330212:8204
263: SKP: 12288( 3 blks) ==> 250338416:12
264: RAW: 8192( 2 blks) ==> 250338428:8204
265: SKP: 12288( 3 blks) ==> 250346632:12
266: RAW: 8192( 2 blks) ==> 250346644:8204
267: SKP: 12288( 3 blks) ==> 250354848:12
268: RAW: 4096( 1 blks) ==> 250354860:4108
269: SKP: 12288( 3 blks) ==> 250358968:12
270: RAW: 8192( 2 blks) ==> 250358980:8204
271: SKP: 12288( 3 blks) ==> 250367184:12
272: RAW: 4096( 1 blks) ==> 250367196:4108
273: SKP: 12288( 3 blks) ==> 250371304:12
274: RAW: 12288( 3 blks) ==> 250371316:12300
275: SKP: 12288( 3 blks) ==> 250383616:12
276: RAW: 8192( 2 blks) ==> 250383628:8204
277: SKP: 12288( 3 blks) ==> 250391832:12
278: RAW: 12288( 3 blks) ==> 250391844:12300
279: SKP: 12288( 3 blks) ==> 250404144:12
280: RAW: 8192( 2 blks) ==> 250404156:8204
281: SKP: 12288( 3 blks) ==> 250412360:12
282: RAW: 8192( 2 blks) ==> 250412372:8204
283: SKP: 12288( 3 blks) ==> 250420576:12
284: RAW: 4096( 1 blks) ==> 250420588:4108
285: SKP: 12288( 3 blks) ==> 250424696:12
286: RAW: 8192( 2 blks) ==> 250424708:8204
287: SKP: 12288( 3 blks) ==> 250432912:12
288: RAW: 8192( 2 blks) ==> 250432924:8204
289: SKP: 8192( 2 blks) ==> 250441128:12
290: RAW: 8192( 2 blks) ==> 250441140:8204
291: SKP: 12288( 3 blks) ==> 250449344:12
292: RAW: 12288( 3 blks) ==> 250449356:12300
293: SKP: 12288( 3 blks) ==> 250461656:12
294: RAW: 12288( 3 blks) ==> 250461668:12300
295: SKP: 12288( 3 blks) ==> 250473968:12
296: RAW: 8192( 2 blks) ==> 250473980:8204
297: SKP: 12288( 3 blks) ==> 250482184:12
298: RAW: 4096( 1 blks) ==> 250482196:4108
299: SKP: 12288( 3 blks) ==> 250486304:12
300: RAW: 8192( 2 blks) ==> 250486316:8204
301: SKP: 12288( 3 blks) ==> 250494520:12
302: RAW: 8192( 2 blks) ==> 250494532:8204
303: SKP: 12288( 3 blks) ==> 250502736:12
304: RAW: 4096( 1 blks) ==> 250502748:4108
305: SKP: 12288( 3 blks) ==> 250506856:12
306: RAW: 8192( 2 blks) ==> 250506868:8204
307: SKP: 12288( 3 blks) ==> 250515072:12
308: RAW: 8192( 2 blks) ==> 250515084:8204
309: SKP: 12288( 3 blks) ==> 250523288:12
310: RAW: 12288( 3 blks) ==> 250523300:12300
311: SKP: 12288( 3 blks) ==> 250535600:12
312: RAW: 8192( 2 blks) ==> 250535612:8204
313: SKP: 12288( 3 blks) ==> 250543816:12
314: RAW: 8192( 2 blks) ==> 250543828:8204
315: SKP: 4096( 1 blks) ==> 250552032:12
316: RAW: 8192( 2 blks) ==> 250552044:8204
317: SKP: 8192( 2 blks) ==> 250560248:12
318: RAW: 8192( 2 blks) ==> 250560260:8204
319: SKP: 12288( 3 blks) ==> 250568464:12
320: RAW: 8192( 2 blks) ==> 250568476:8204
321: SKP: 12288( 3 blks) ==> 250576680:12
322: RAW: 4096( 1 blks) ==> 250576692:4108
323: SKP: 12288( 3 blks) ==> 250580800:12
324: RAW: 8192( 2 blks) ==> 250580812:8204
325: SKP: 12288( 3 blks) ==> 250589016:12
326: RAW: 4096( 1 blks) ==> 250589028:4108
327: SKP: 12288( 3 blks) ==> 250593136:12
328: RAW: 8192( 2 blks) ==> 250593148:8204
329: SKP: 12288( 3 blks) ==> 250601352:12
330: RAW: 4096( 1 blks) ==> 250601364:4108
331: SKP: 12288( 3 blks) ==> 250605472:12
332: RAW: 8192( 2 blks) ==> 250605484:8204
333: SKP: 12288( 3 blks) ==> 250613688:12
334: RAW: 4096( 1 blks) ==> 250613700:4108
335: SKP: 12288( 3 blks) ==> 250617808:12
336: RAW: 8192( 2 blks) ==> 250617820:8204
337: SKP: 12288( 3 blks) ==> 250626024:12
338: RAW: 4096( 1 blks) ==> 250626036:4108
339: SKP: 12288( 3 blks) ==> 250630144:12
340: RAW: 8192( 2 blks) ==> 250630156:8204
341: SKP: 12288( 3 blks) ==> 250638360:12
342: RAW: 4096( 1 blks) ==> 250638372:4108
343: SKP: 12288( 3 blks) ==> 250642480:12
344: RAW: 8192( 2 blks) ==> 250642492:8204
345: SKP: 4096( 1 blks) ==> 250650696:12
346: RAW: 4096( 1 blks) ==> 250650708:4108
347: SKP: 12288( 3 blks) ==> 250654816:12
348: RAW: 4096( 1 blks) ==> 250654828:4108
349: SKP: 4096( 1 blks) ==> 250658936:12
350: RAW: 4096( 1 blks) ==> 250658948:4108
351: SKP: 12288( 3 blks) ==> 250663056:12
352: RAW: 16384( 4 blks) ==> 250663068:16396
353: SKP: 12288( 3 blks) ==> 250679464:12
354: RAW: 4096( 1 blks) ==> 250679476:4108
355: SKP: 4096( 1 blks) ==> 250683584:12
356: RAW: 4096( 1 blks) ==> 250683596:4108
357: SKP: 12288( 3 blks) ==> 250687704:12
358: RAW: 8192( 2 blks) ==> 250687716:8204
359: SKP: 12288( 3 blks) ==> 250695920:12
360: RAW: 4096( 1 blks) ==> 250695932:4108
361: SKP: 12288( 3 blks) ==> 250700040:12
362: RAW: 8192( 2 blks) ==> 250700052:8204
363: SKP: 12288( 3 blks) ==> 250708256:12
364: RAW: 4096( 1 blks) ==> 250708268:4108
365: SKP: 12288( 3 blks) ==> 250712376:12
366: RAW: 8192( 2 blks) ==> 250712388:8204
367: SKP: 12288( 3 blks) ==> 250720592:12
368: RAW: 8192( 2 blks) ==> 250720604:8204
369: SKP: 8192( 2 blks) ==> 250728808:12
370: RAW: 12288( 3 blks) ==> 250728820:12300
371: SKP: 12288( 3 blks) ==> 250741120:12
372: RAW: 8192( 2 blks) ==> 250741132:8204
373: SKP: 12288( 3 blks) ==> 250749336:12
374: RAW: 4096( 1 blks) ==> 250749348:4108
375: SKP: 12288( 3 blks) ==> 250753456:12
376: RAW: 8192( 2 blks) ==> 250753468:8204
377: SKP: 12288( 3 blks) ==> 250761672:12
378: RAW: 4096( 1 blks) ==> 250761684:4108
379: SKP: 12288( 3 blks) ==> 250765792:12
380: RAW: 8192( 2 blks) ==> 250765804:8204
381: SKP: 12288( 3 blks) ==> 250774008:12
382: RAW: 4096( 1 blks) ==> 250774020:4108
383: SKP: 12288( 3 blks) ==> 250778128:12
384: RAW: 8192( 2 blks) ==> 250778140:8204
385: SKP: 12288( 3 blks) ==> 250786344:12
386: RAW: 4096( 1 blks) ==> 250786356:4108
387: SKP: 12288( 3 blks) ==> 250790464:12
388: RAW: 8192( 2 blks) ==> 250790476:8204
389: SKP: 12288( 3 blks) ==> 250798680:12
390: RAW: 4096( 1 blks) ==> 250798692:4108
391: SKP: 12288( 3 blks) ==> 250802800:12
392: RAW: 8192( 2 blks) ==> 250802812:8204
393: SKP: 12288( 3 blks) ==> 250811016:12
394: RAW: 4096( 1 blks) ==> 250811028:4108
395: SKP: 12288( 3 blks) ==> 250815136:12
396: RAW: 8192( 2 blks) ==> 250815148:8204
397: SKP: 12288( 3 blks) ==> 250823352:12
398: RAW: 8192( 2 blks) ==> 250823364:8204
399: SKP: 8192( 2 blks) ==> 250831568:12
400: RAW: 8192( 2 blks) ==> 250831580:8204
401: SKP: 12288( 3 blks) ==> 250839784:12
402: RAW: 8192( 2 blks) ==> 250839796:8204
403: SKP: 12288( 3 blks) ==> 250848000:12
404: RAW: 4096( 1 blks) ==> 250848012:4108
405: SKP: 12288( 3 blks) ==> 250852120:12
406: RAW: 8192( 2 blks) ==> 250852132:8204
407: SKP: 12288( 3 blks) ==> 250860336:12
408: RAW: 4096( 1 blks) ==> 250860348:4108
409: SKP: 12288( 3 blks) ==> 250864456:12
410: RAW: 8192( 2 blks) ==> 250864468:8204
411: SKP: 12288( 3 blks) ==> 250872672:12
412: RAW: 4096( 1 blks) ==> 250872684:4108
413: SKP: 12288( 3 blks) ==> 250876792:12
414: RAW: 8192( 2 blks) ==> 250876804:8204
415: SKP: 12288( 3 blks) ==> 250885008:12
416: RAW: 4096( 1 blks) ==> 250885020:4108
417: SKP: 12288( 3 blks) ==> 250889128:12
418: RAW: 8192( 2 blks) ==> 250889140:8204
419: SKP: 12288( 3 blks) ==> 250897344:12
420: RAW: 4096( 1 blks) ==> 250897356:4108
421: SKP: 12288( 3 blks) ==> 250901464:12
422: RAW: 8192( 2 blks) ==> 250901476:8204
423: SKP: 12288( 3 blks) ==> 250909680:12
424: RAW: 8192( 2 blks) ==> 250909692:8204
425: SKP: 12288( 3 blks) ==> 250917896:12
426: RAW: 4096( 1 blks) ==> 250917908:4108
427: SKP: 12288( 3 blks) ==> 250922016:12
428: RAW: 8192( 2 blks) ==> 250922028:8204
429: SKP: 12288( 3 blks) ==> 250930232:12
430: RAW: 8192( 2 blks) ==> 250930244:8204
431: SKP: 12288( 3 blks) ==> 250938448:12
432: RAW: 4096( 1 blks) ==> 250938460:4108
433: SKP: 12288( 3 blks) ==> 250942568:12
434: RAW: 8192( 2 blks) ==> 250942580:8204
435: SKP: 12288( 3 blks) ==> 250950784:12
436: RAW: 4096( 1 blks) ==> 250950796:4108
437: SKP: 12288( 3 blks) ==> 250954904:12
438: RAW: 8192( 2 blks) ==> 250954916:8204
439: SKP: 12288( 3 blks) ==> 250963120:12
440: RAW: 8192( 2 blks) ==> 250963132:8204
441: SKP: 8192( 2 blks) ==> 250971336:12
442: RAW: 8192( 2 blks) ==> 250971348:8204
443: SKP: 12288( 3 blks) ==> 250979552:12
444: RAW: 8192( 2 blks) ==> 250979564:8204
445: SKP: 12288( 3 blks) ==> 250987768:12
446: RAW: 4096( 1 blks) ==> 250987780:4108
447: SKP: 12288( 3 blks) ==> 250991888:12
448: RAW: 8192( 2 blks) ==> 250991900:8204
449: SKP: 12288( 3 blks) ==> 251000104:12
450: RAW: 4096( 1 blks) ==> 251000116:4108
451: SKP: 12288( 3 blks) ==> 251004224:12
452: RAW: 8192( 2 blks) ==> 251004236:8204
453: SKP: 4096( 1 blks) ==> 251012440:12
454: RAW: 4096( 1 blks) ==> 251012452:4108
455: SKP: 12288( 3 blks) ==> 251016560:12
456: RAW: 8192( 2 blks) ==> 251016572:8204
457: SKP: 12288( 3 blks) ==> 251024776:12
458: RAW: 4096( 1 blks) ==> 251024788:4108
459: SKP: 12288( 3 blks) ==> 251028896:12
460: RAW: 4096( 1 blks) ==> 251028908:4108
461: SKP: 12288( 3 blks) ==> 251033016:12
462: RAW: 12288( 3 blks) ==> 251033028:12300
463: SKP: 12288( 3 blks) ==> 251045328:12
464: RAW: 4096( 1 blks) ==> 251045340:4108
465: SKP: 12288( 3 blks) ==> 251049448:12
466: RAW: 8192( 2 blks) ==> 251049460:8204
467: SKP: 12288( 3 blks) ==> 251057664:12
468: RAW: 4096( 1 blks) ==> 251057676:4108
469: SKP: 12288( 3 blks) ==> 251061784:12
470: RAW: 8192( 2 blks) ==> 251061796:8204
471: SKP: 12288( 3 blks) ==> 251070000:12
472: RAW: 8192( 2 blks) ==> 251070012:8204
473: SKP: 12288( 3 blks) ==> 251078216:12
474: RAW: 4096( 1 blks) ==> 251078228:4108
475: SKP: 12288( 3 blks) ==> 251082336:12
476: RAW: 8192( 2 blks) ==> 251082348:8204
477: SKP: 12288( 3 blks) ==> 251090552:12
478: RAW: 8192( 2 blks) ==> 251090564:8204
479: SKP: 12288( 3 blks) ==> 251098768:12
480: RAW: 4096( 1 blks) ==> 251098780:4108
481: SKP: 12288( 3 blks) ==> 251102888:12
482: RAW: 8192( 2 blks) ==> 251102900:8204
483: SKP: 12288( 3 blks) ==> 251111104:12
484: RAW: 8192( 2 blks) ==> 251111116:8204
485: SKP: 12288( 3 blks) ==> 251119320:12
486: RAW: 122880( 30 blks) ==> 251119332:122892
487: SKP: 12288( 3 blks) ==> 251242224:12
488: RAW: 8192( 2 blks) ==> 251242236:8204
489: SKP: 12288( 3 blks) ==> 251250440:12
490: RAW: 4096( 1 blks) ==> 251250452:4108
491: SKP: 12288( 3 blks) ==> 251254560:12
492: RAW: 8192( 2 blks) ==> 251254572:8204
493: SKP: 24576( 6 blks) ==> 251262776:12
494: RAW: 73728( 18 blks) ==> 251262788:73740
495: SKP: 12288( 3 blks) ==> 251336528:12
496: RAW: 8192( 2 blks) ==> 251336540:8204
497: SKP: 12288( 3 blks) ==> 251344744:12
498: RAW: 8192( 2 blks) ==> 251344756:8204
499: SKP: 12288( 3 blks) ==> 251352960:12
500: RAW: 4096( 1 blks) ==> 251352972:4108
501: SKP: 12288( 3 blks) ==> 251357080:12
502: RAW: 12288( 3 blks) ==> 251357092:12300
503: SKP: 8192( 2 blks) ==> 251369392:12
504: RAW: 12288( 3 blks) ==> 251369404:12300
505: SKP: 12288( 3 blks) ==> 251381704:12
506: RAW: 8192( 2 blks) ==> 251381716:8204
507: SKP: 12288( 3 blks) ==> 251389920:12
508: RAW: 8192( 2 blks) ==> 251389932:8204
509: SKP: 12288( 3 blks) ==> 251398136:12
510: RAW: 8192( 2 blks) ==> 251398148:8204
511: SKP: 12288( 3 blks) ==> 251406352:12
512: RAW: 4096( 1 blks) ==> 251406364:4108
513: SKP: 4096( 1 blks) ==> 251410472:12
514: RAW: 4096( 1 blks) ==> 251410484:4108
515: SKP: 12288( 3 blks) ==> 251414592:12
516: RAW: 4096( 1 blks) ==> 251414604:4108
517: SKP: 8192( 2 blks) ==> 251418712:12
518: RAW: 4096( 1 blks) ==> 251418724:4108
519: SKP: 4096( 1 blks) ==> 251422832:12
520: RAW: 4096( 1 blks) ==> 251422844:4108
521: SKP: 4096( 1 blks) ==> 251426952:12
522: RAW: 16384( 4 blks) ==> 251426964:16396
523: SKP: 4096( 1 blks) ==> 251443360:12
524: RAW: 4096( 1 blks) ==> 251443372:4108
525: SKP: 4096( 1 blks) ==> 251447480:12
526: RAW: 4096( 1 blks) ==> 251447492:4108
527: SKP: 8192( 2 blks) ==> 251451600:12
528: RAW: 12288( 3 blks) ==> 251451612:12300
529: SKP: 4096( 1 blks) ==> 251463912:12
530: RAW: 4096( 1 blks) ==> 251463924:4108
531: SKP: 4096( 1 blks) ==> 251468032:12
532: RAW: 4096( 1 blks) ==> 251468044:4108
533: SKP: 8192( 2 blks) ==> 251472152:12
534: RAW: 4096( 1 blks) ==> 251472164:4108
535: SKP: 4096( 1 blks) ==> 251476272:12
536: RAW: 4096( 1 blks) ==> 251476284:4108
537: SKP: 4096( 1 blks) ==> 251480392:12
538: RAW: 16384( 4 blks) ==> 251480404:16396
539: SKP: 4096( 1 blks) ==> 251496800:12
540: RAW: 4096( 1 blks) ==> 251496812:4108
541: SKP: 4096( 1 blks) ==> 251500920:12
542: RAW: 4096( 1 blks) ==> 251500932:4108
543: SKP: 4096( 1 blks) ==> 251505040:12
544: RAW: 16384( 4 blks) ==> 251505052:16396
545: SKP: 4096( 1 blks) ==> 251521448:12
546: RAW: 4096( 1 blks) ==> 251521460:4108
547: SKP: 4096( 1 blks) ==> 251525568:12
548: RAW: 4096( 1 blks) ==> 251525580:4108
549: SKP: 8192( 2 blks) ==> 251529688:12
550: RAW: 12288( 3 blks) ==> 251529700:12300
551: SKP: 4096( 1 blks) ==> 251542000:12
552: RAW: 4096( 1 blks) ==> 251542012:4108
553: SKP: 4096( 1 blks) ==> 251546120:12
554: RAW: 4096( 1 blks) ==> 251546132:4108
555: SKP: 8192( 2 blks) ==> 251550240:12
556: RAW: 4096( 1 blks) ==> 251550252:4108
557: SKP: 4096( 1 blks) ==> 251554360:12
558: RAW: 4096( 1 blks) ==> 251554372:4108
559: SKP: 4096( 1 blks) ==> 251558480:12
560: RAW: 12288( 3 blks) ==> 251558492:12300
561: SKP: 8192( 2 blks) ==> 251570792:12
562: RAW: 4096( 1 blks) ==> 251570804:4108
563: SKP: 4096( 1 blks) ==> 251574912:12
564: RAW: 4096( 1 blks) ==> 251574924:4108
565: SKP: 4096( 1 blks) ==> 251579032:12
566: RAW: 16384( 4 blks) ==> 251579044:16396
567: SKP: 4096( 1 blks) ==> 251595440:12
568: RAW: 4096( 1 blks) ==> 251595452:4108
569: SKP: 4096( 1 blks) ==> 251599560:12
570: RAW: 4096( 1 blks) ==> 251599572:4108
571: SKP: 8192( 2 blks) ==> 251603680:12
572: RAW: 12288( 3 blks) ==> 251603692:12300
573: SKP: 4096( 1 blks) ==> 251615992:12
574: RAW: 4096( 1 blks) ==> 251616004:4108
575: SKP: 4096( 1 blks) ==> 251620112:12
576: RAW: 4096( 1 blks) ==> 251620124:4108
577: SKP: 8192( 2 blks) ==> 251624232:12
578: RAW: 12288( 3 blks) ==> 251624244:12300
579: SKP: 4096( 1 blks) ==> 251636544:12
580: RAW: 4096( 1 blks) ==> 251636556:4108
581: SKP: 4096( 1 blks) ==> 251640664:12
582: RAW: 4096( 1 blks) ==> 251640676:4108
583: SKP: 8192( 2 blks) ==> 251644784:12
584: RAW: 4096( 1 blks) ==> 251644796:4108
585: SKP: 4096( 1 blks) ==> 251648904:12
586: RAW: 4096( 1 blks) ==> 251648916:4108
587: SKP: 4096( 1 blks) ==> 251653024:12
588: RAW: 16384( 4 blks) ==> 251653036:16396
589: SKP: 4096( 1 blks) ==> 251669432:12
590: RAW: 4096( 1 blks) ==> 251669444:4108
591: SKP: 4096( 1 blks) ==> 251673552:12
592: RAW: 4096( 1 blks) ==> 251673564:4108
593: SKP: 4096( 1 blks) ==> 251677672:12
594: RAW: 16384( 4 blks) ==> 251677684:16396
595: SKP: 4096( 1 blks) ==> 251694080:12
596: RAW: 4096( 1 blks) ==> 251694092:4108
597: SKP: 4096( 1 blks) ==> 251698200:12
598: RAW: 4096( 1 blks) ==> 251698212:4108
599: SKP: 8192( 2 blks) ==> 251702320:12
600: RAW: 12288( 3 blks) ==> 251702332:12300
601: SKP: 4096( 1 blks) ==> 251714632:12
602: RAW: 4096( 1 blks) ==> 251714644:4108
603: SKP: 4096( 1 blks) ==> 251718752:12
604: RAW: 4096( 1 blks) ==> 251718764:4108
605: SKP: 8192( 2 blks) ==> 251722872:12
606: RAW: 4096( 1 blks) ==> 251722884:4108
607: SKP: 4096( 1 blks) ==> 251726992:12
608: RAW: 4096( 1 blks) ==> 251727004:4108
609: SKP: 4096( 1 blks) ==> 251731112:12
610: RAW: 12288( 3 blks) ==> 251731124:12300
611: SKP: 8192( 2 blks) ==> 251743424:12
612: RAW: 4096( 1 blks) ==> 251743436:4108
613: SKP: 4096( 1 blks) ==> 251747544:12
614: RAW: 4096( 1 blks) ==> 251747556:4108
615: SKP: 4096( 1 blks) ==> 251751664:12
616: RAW: 16384( 4 blks) ==> 251751676:16396
617: SKP: 4096( 1 blks) ==> 251768072:12
618: RAW: 4096( 1 blks) ==> 251768084:4108
619: SKP: 4096( 1 blks) ==> 251772192:12
620: RAW: 4096( 1 blks) ==> 251772204:4108
621: SKP: 8192( 2 blks) ==> 251776312:12
622: RAW: 12288( 3 blks) ==> 251776324:12300
623: SKP: 4096( 1 blks) ==> 251788624:12
624: RAW: 4096( 1 blks) ==> 251788636:4108
625: SKP: 4096( 1 blks) ==> 251792744:12
626: RAW: 4096( 1 blks) ==> 251792756:4108
627: SKP: 8192( 2 blks) ==> 251796864:12
628: RAW: 4096( 1 blks) ==> 251796876:4108
629: SKP: 4096( 1 blks) ==> 251800984:12
630: RAW: 4096( 1 blks) ==> 251800996:4108
631: SKP: 4096( 1 blks) ==> 251805104:12
632: RAW: 12288( 3 blks) ==> 251805116:12300
633: SKP: 8192( 2 blks) ==> 251817416:12
634: RAW: 4096( 1 blks) ==> 251817428:4108
635: SKP: 4096( 1 blks) ==> 251821536:12
636: RAW: 4096( 1 blks) ==> 251821548:4108
637: SKP: 4096( 1 blks) ==> 251825656:12
638: RAW: 16384( 4 blks) ==> 251825668:16396
639: SKP: 4096( 1 blks) ==> 251842064:12
640: RAW: 4096( 1 blks) ==> 251842076:4108
641: SKP: 4096( 1 blks) ==> 251846184:12
642: RAW: 4096( 1 blks) ==> 251846196:4108
643: SKP: 8192( 2 blks) ==> 251850304:12
644: RAW: 12288( 3 blks) ==> 251850316:12300
645: SKP: 4096( 1 blks) ==> 251862616:12
646: RAW: 4096( 1 blks) ==> 251862628:4108
647: SKP: 4096( 1 blks) ==> 251866736:12
648: RAW: 4096( 1 blks) ==> 251866748:4108
649: SKP: 8192( 2 blks) ==> 251870856:12
650: RAW: 12288( 3 blks) ==> 251870868:12300
651: SKP: 4096( 1 blks) ==> 251883168:12
652: RAW: 4096( 1 blks) ==> 251883180:4108
653: SKP: 4096( 1 blks) ==> 251887288:12
654: RAW: 4096( 1 blks) ==> 251887300:4108
655: SKP: 8192( 2 blks) ==> 251891408:12
656: RAW: 4096( 1 blks) ==> 251891420:4108
657: SKP: 4096( 1 blks) ==> 251895528:12
658: RAW: 4096( 1 blks) ==> 251895540:4108
659: SKP: 4096( 1 blks) ==> 251899648:12
660: RAW: 16384( 4 blks) ==> 251899660:16396
661: SKP: 4096( 1 blks) ==> 251916056:12
662: RAW: 4096( 1 blks) ==> 251916068:4108
663: SKP: 4096( 1 blks) ==> 251920176:12
664: RAW: 4096( 1 blks) ==> 251920188:4108
665: SKP: 4096( 1 blks) ==> 251924296:12
666: RAW: 16384( 4 blks) ==> 251924308:16396
667: SKP: 4096( 1 blks) ==> 251940704:12
668: RAW: 4096( 1 blks) ==> 251940716:4108
669: SKP: 4096( 1 blks) ==> 251944824:12
670: RAW: 4096( 1 blks) ==> 251944836:4108
671: SKP: 8192( 2 blks) ==> 251948944:12
672: RAW: 12288( 3 blks) ==> 251948956:12300
673: SKP: 4096( 1 blks) ==> 251961256:12
674: RAW: 4096( 1 blks) ==> 251961268:4108
675: SKP: 4096( 1 blks) ==> 251965376:12
676: RAW: 4096( 1 blks) ==> 251965388:4108
677: SKP: 8192( 2 blks) ==> 251969496:12
678: RAW: 4096( 1 blks) ==> 251969508:4108
679: SKP: 4096( 1 blks) ==> 251973616:12
680: RAW: 4096( 1 blks) ==> 251973628:4108
681: SKP: 4096( 1 blks) ==> 251977736:12
682: RAW: 8192( 2 blks) ==> 251977748:8204
683: SKP: 12288( 3 blks) ==> 251985952:12
684: RAW: 4096( 1 blks) ==> 251985964:4108
685: SKP: 12288( 3 blks) ==> 251990072:12
686: RAW: 8192( 2 blks) ==> 251990084:8204
687: SKP: 12288( 3 blks) ==> 251998288:12
688: RAW: 8192( 2 blks) ==> 251998300:8204
689: SKP: 12288( 3 blks) ==> 252006504:12
690: RAW: 4096( 1 blks) ==> 252006516:4108
691: SKP: 12288( 3 blks) ==> 252010624:12
692: RAW: 8192( 2 blks) ==> 252010636:8204
693: SKP: 12288( 3 blks) ==> 252018840:12
694: RAW: 4096( 1 blks) ==> 252018852:4108
695: SKP: 12288( 3 blks) ==> 252022960:12
696: RAW: 8192( 2 blks) ==> 252022972:8204
697: SKP: 12288( 3 blks) ==> 252031176:12
698: RAW: 4096( 1 blks) ==> 252031188:4108
699: SKP: 12288( 3 blks) ==> 252035296:12
700: RAW: 8192( 2 blks) ==> 252035308:8204
701: SKP: 12288( 3 blks) ==> 252043512:12
702: RAW: 4096( 1 blks) ==> 252043524:4108
703: SKP: 12288( 3 blks) ==> 252047632:12
704: RAW: 8192( 2 blks) ==> 252047644:8204
705: SKP: 12288( 3 blks) ==> 252055848:12
706: RAW: 4096( 1 blks) ==> 252055860:4108
707: SKP: 12288( 3 blks) ==> 252059968:12
708: RAW: 8192( 2 blks) ==> 252059980:8204
709: SKP: 12288( 3 blks) ==> 252068184:12
710: RAW: 8192( 2 blks) ==> 252068196:8204
711: SKP: 8192( 2 blks) ==> 252076400:12
712: RAW: 8192( 2 blks) ==> 252076412:8204
713: SKP: 12288( 3 blks) ==> 252084616:12
714: RAW: 8192( 2 blks) ==> 252084628:8204
715: SKP: 12288( 3 blks) ==> 252092832:12
716: RAW: 4096( 1 blks) ==> 252092844:4108
717: SKP: 12288( 3 blks) ==> 252096952:12
718: RAW: 8192( 2 blks) ==> 252096964:8204
719: SKP: 12288( 3 blks) ==> 252105168:12
720: RAW: 4096( 1 blks) ==> 252105180:4108
721: SKP: 12288( 3 blks) ==> 252109288:12
722: RAW: 4096( 1 blks) ==> 252109300:4108
723: SKP: 4096( 1 blks) ==> 252113408:12
724: RAW: 4096( 1 blks) ==> 252113420:4108
725: SKP: 12288( 3 blks) ==> 252117528:12
726: RAW: 8192( 2 blks) ==> 252117540:8204
727: SKP: 12288( 3 blks) ==> 252125744:12
728: RAW: 4096( 1 blks) ==> 252125756:4108
729: SKP: 12288( 3 blks) ==> 252129864:12
730: RAW: 8192( 2 blks) ==> 252129876:8204
731: SKP: 12288( 3 blks) ==> 252138080:12
732: RAW: 12288( 3 blks) ==> 252138092:12300
733: SKP: 12288( 3 blks) ==> 252150392:12
734: RAW: 4096( 1 blks) ==> 252150404:4108
735: SKP: 12288( 3 blks) ==> 252154512:12
736: RAW: 12288( 3 blks) ==> 252154524:12300
737: SKP: 12288( 3 blks) ==> 252166824:12
738: RAW: 4096( 1 blks) ==> 252166836:4108
739: SKP: 12288( 3 blks) ==> 252170944:12
740: RAW: 8192( 2 blks) ==> 252170956:8204
741: SKP: 12288( 3 blks) ==> 252179160:12
742: RAW: 4096( 1 blks) ==> 252179172:4108
743: SKP: 12288( 3 blks) ==> 252183280:12
744: RAW: 8192( 2 blks) ==> 252183292:8204
745: SKP: 12288( 3 blks) ==> 252191496:12
746: RAW: 4096( 1 blks) ==> 252191508:4108
747: SKP: 12288( 3 blks) ==> 252195616:12
748: RAW: 8192( 2 blks) ==> 252195628:8204
749: SKP: 12288( 3 blks) ==> 252203832:12
750: RAW: 8192( 2 blks) ==> 252203844:8204
751: SKP: 12288( 3 blks) ==> 252212048:12
752: RAW: 4096( 1 blks) ==> 252212060:4108
753: SKP: 12288( 3 blks) ==> 252216168:12
754: RAW: 8192( 2 blks) ==> 252216180:8204
755: SKP: 12288( 3 blks) ==> 252224384:12
756: RAW: 8192( 2 blks) ==> 252224396:8204
757: SKP: 12288( 3 blks) ==> 252232600:12
758: RAW: 4096( 1 blks) ==> 252232612:4108
759: SKP: 12288( 3 blks) ==> 252236720:12
760: RAW: 8192( 2 blks) ==> 252236732:8204
761: SKP: 12288( 3 blks) ==> 252244936:12
762: RAW: 4096( 1 blks) ==> 252244948:4108
763: SKP: 12288( 3 blks) ==> 252249056:12
764: RAW: 8192( 2 blks) ==> 252249068:8204
765: SKP: 12288( 3 blks) ==> 252257272:12
766: RAW: 8192( 2 blks) ==> 252257284:8204
767: SKP: 8192( 2 blks) ==> 252265488:12
768: RAW: 8192( 2 blks) ==> 252265500:8204
769: SKP: 12288( 3 blks) ==> 252273704:12
770: RAW: 8192( 2 blks) ==> 252273716:8204
771: SKP: 12288( 3 blks) ==> 252281920:12
772: RAW: 4096( 1 blks) ==> 252281932:4108
773: SKP: 12288( 3 blks) ==> 252286040:12
774: RAW: 8192( 2 blks) ==> 252286052:8204
775: SKP: 12288( 3 blks) ==> 252294256:12
776: RAW: 8192( 2 blks) ==> 252294268:8204
777: SKP: 12288( 3 blks) ==> 252302472:12
778: RAW: 4096( 1 blks) ==> 252302484:4108
779: SKP: 12288( 3 blks) ==> 252306592:12
780: RAW: 8192( 2 blks) ==> 252306604:8204
781: SKP: 12288( 3 blks) ==> 252314808:12
782: RAW: 8192( 2 blks) ==> 252314820:8204
783: SKP: 12288( 3 blks) ==> 252323024:12
784: RAW: 4096( 1 blks) ==> 252323036:4108
785: SKP: 12288( 3 blks) ==> 252327144:12
786: RAW: 8192( 2 blks) ==> 252327156:8204
787: SKP: 12288( 3 blks) ==> 252335360:12
788: RAW: 4096( 1 blks) ==> 252335372:4108
789: SKP: 12288( 3 blks) ==> 252339480:12
790: RAW: 8192( 2 blks) ==> 252339492:8204
791: SKP: 12288( 3 blks) ==> 252347696:12
792: RAW: 8192( 2 blks) ==> 252347708:8204
793: SKP: 12288( 3 blks) ==> 252355912:12
794: RAW: 4096( 1 blks) ==> 252355924:4108
795: SKP: 12288( 3 blks) ==> 252360032:12
796: RAW: 8192( 2 blks) ==> 252360044:8204
797: SKP: 12288( 3 blks) ==> 252368248:12
798: RAW: 8192( 2 blks) ==> 252368260:8204
799: SKP: 12288( 3 blks) ==> 252376464:12
800: RAW: 4096( 1 blks) ==> 252376476:4108
801: SKP: 12288( 3 blks) ==> 252380584:12
802: RAW: 8192( 2 blks) ==> 252380596:8204
803: SKP: 12288( 3 blks) ==> 252388800:12
804: RAW: 8192( 2 blks) ==> 252388812:8204
805: SKP: 8192( 2 blks) ==> 252397016:12
806: RAW: 8192( 2 blks) ==> 252397028:8204
807: SKP: 12288( 3 blks) ==> 252405232:12
808: RAW: 8192( 2 blks) ==> 252405244:8204
809: SKP: 12288( 3 blks) ==> 252413448:12
810: RAW: 8192( 2 blks) ==> 252413460:8204
811: SKP: 12288( 3 blks) ==> 252421664:12
812: RAW: 4096( 1 blks) ==> 252421676:4108
813: SKP: 12288( 3 blks) ==> 252425784:12
814: RAW: 8192( 2 blks) ==> 252425796:8204
815: SKP: 12288( 3 blks) ==> 252434000:12
816: RAW: 4096( 1 blks) ==> 252434012:4108
817: SKP: 12288( 3 blks) ==> 252438120:12
818: RAW: 8192( 2 blks) ==> 252438132:8204
819: SKP: 12288( 3 blks) ==> 252446336:12
820: RAW: 8192( 2 blks) ==> 252446348:8204
821: SKP: 8192( 2 blks) ==> 252454552:12
822: RAW: 8192( 2 blks) ==> 252454564:8204
823: SKP: 12288( 3 blks) ==> 252462768:12
824: RAW: 20480( 5 blks) ==> 252462780:20492
825: SKP: 12288( 3 blks) ==> 252483272:12
826: RAW: 8192( 2 blks) ==> 252483284:8204
827: SKP: 12288( 3 blks) ==> 252491488:12
828: RAW: 4096( 1 blks) ==> 252491500:4108
829: SKP: 12288( 3 blks) ==> 252495608:12
830: RAW: 8192( 2 blks) ==> 252495620:8204
831: SKP: 12288( 3 blks) ==> 252503824:12
832: RAW: 8192( 2 blks) ==> 252503836:8204
833: SKP: 12288( 3 blks) ==> 252512040:12
834: RAW: 4096( 1 blks) ==> 252512052:4108
835: SKP: 12288( 3 blks) ==> 252516160:12
836: RAW: 8192( 2 blks) ==> 252516172:8204
837: SKP: 12288( 3 blks) ==> 252524376:12
838: RAW: 4096( 1 blks) ==> 252524388:4108
839: SKP: 12288( 3 blks) ==> 252528496:12
840: RAW: 8192( 2 blks) ==> 252528508:8204
841: SKP: 12288( 3 blks) ==> 252536712:12
842: RAW: 40960( 10 blks) ==> 252536724:40972
843: SKP: 12288( 3 blks) ==> 252577696:12
844: RAW: 8192( 2 blks) ==> 252577708:8204
845: SKP: 12288( 3 blks) ==> 252585912:12
846: RAW: 4096( 1 blks) ==> 252585924:4108
847: SKP: 12288( 3 blks) ==> 252590032:12
848: RAW: 8192( 2 blks) ==> 252590044:8204
849: SKP: 12288( 3 blks) ==> 252598248:12
850: RAW: 8192( 2 blks) ==> 252598260:8204
851: SKP: 12288( 3 blks) ==> 252606464:12
852: RAW: 8192( 2 blks) ==> 252606476:8204
853: SKP: 12288( 3 blks) ==> 252614680:12
854: RAW: 8192( 2 blks) ==> 252614692:8204
855: SKP: 12288( 3 blks) ==> 252622896:12
856: RAW: 12288( 3 blks) ==> 252622908:12300
857: SKP: 12288( 3 blks) ==> 252635208:12
858: RAW: 4096( 1 blks) ==> 252635220:4108
859: SKP: 12288( 3 blks) ==> 252639328:12
860: RAW: 8192( 2 blks) ==> 252639340:8204
861: SKP: 12288( 3 blks) ==> 252647544:12
862: RAW: 4096( 1 blks) ==> 252647556:4108
863: SKP: 12288( 3 blks) ==> 252651664:12
864: RAW: 8192( 2 blks) ==> 252651676:8204
865: SKP: 12288( 3 blks) ==> 252659880:12
866: RAW: 4096( 1 blks) ==> 252659892:4108
867: SKP: 12288( 3 blks) ==> 252664000:12
868: RAW: 8192( 2 blks) ==> 252664012:8204
869: SKP: 12288( 3 blks) ==> 252672216:12
870: RAW: 8192( 2 blks) ==> 252672228:8204
871: SKP: 12288( 3 blks) ==> 252680432:12
872: RAW: 8192( 2 blks) ==> 252680444:8204
873: SKP: 12288( 3 blks) ==> 252688648:12
874: RAW: 4096( 1 blks) ==> 252688660:4108
875: SKP: 12288( 3 blks) ==> 252692768:12
876: RAW: 8192( 2 blks) ==> 252692780:8204
877: SKP: 12288( 3 blks) ==> 252700984:12
878: RAW: 8192( 2 blks) ==> 252700996:8204
879: SKP: 1568768( 383 blks) ==> 252709200:12
880: RAW: 4096( 1 blks) ==> 252709212:4108
881: SKP: 12288( 3 blks) ==> 252713320:12
882: RAW: 8192( 2 blks) ==> 252713332:8204
883: SKP: 1568768( 383 blks) ==> 252721536:12
884: RAW: 4096( 1 blks) ==> 252721548:4108
885: SKP: 12288( 3 blks) ==> 252725656:12
886: RAW: 12288( 3 blks) ==> 252725668:12300
887: SKP: 4096( 1 blks) ==> 252737968:12
888: RAW: 31019008( 7573 blks) ==> 252737980:31019020
889: SKP: 4096( 1 blks) ==> 283757000:12
890: RAW: 40960( 10 blks) ==> 283757012:40972
891: SKP: 73728( 18 blks) ==> 283797984:12
892: RAW: 4096( 1 blks) ==> 283797996:4108
893: SKP: 8192( 2 blks) ==> 283802104:12
894: RAW: 4096( 1 blks) ==> 283802116:4108
895: SKP: 4096( 1 blks) ==> 283806224:12
896: RAW: 4096( 1 blks) ==> 283806236:4108
897: SKP: 8192( 2 blks) ==> 283810344:12
898: RAW: 4096( 1 blks) ==> 283810356:4108
899: SKP: 4096( 1 blks) ==> 283814464:12
900: RAW: 16384( 4 blks) ==> 283814476:16396
901: SKP: 4096( 1 blks) ==> 283830872:12
902: RAW: 4096( 1 blks) ==> 283830884:4108
903: SKP: 4096( 1 blks) ==> 283834992:12
904: RAW: 12288( 3 blks) ==> 283835004:12300
905: SKP: 12288( 3 blks) ==> 283847304:12
906: RAW: 20480( 5 blks) ==> 283847316:20492
907: SKP: 4096( 1 blks) ==> 283867808:12
908: RAW: 8192( 2 blks) ==> 283867820:8204
909: SKP: 8192( 2 blks) ==> 283876024:12
910: RAW: 4096( 1 blks) ==> 283876036:4108
911: SKP: 12288( 3 blks) ==> 283880144:12
912: RAW: 28672( 7 blks) ==> 283880156:28684
913: SKP: 4096( 1 blks) ==> 283908840:12
914: RAW: 73728( 18 blks) ==> 283908852:73740
915: SKP: 12288( 3 blks) ==> 283982592:12
916: RAW: 4096( 1 blks) ==> 283982604:4108
917: SKP: 8192( 2 blks) ==> 283986712:12
918: RAW: 16384( 4 blks) ==> 283986724:16396
919: SKP: 4096( 1 blks) ==> 284003120:12
920: RAW: 8192( 2 blks) ==> 284003132:8204
921: SKP: 4096( 1 blks) ==> 284011336:12
922: RAW: 16384( 4 blks) ==> 284011348:16396
923: SKP: 4096( 1 blks) ==> 284027744:12
924: RAW: 4096( 1 blks) ==> 284027756:4108
925: SKP: 20480( 5 blks) ==> 284031864:12
926: RAW: 4096( 1 blks) ==> 284031876:4108
927: SKP: 8192( 2 blks) ==> 284035984:12
928: RAW: 8192( 2 blks) ==> 284035996:8204
929: SKP: 8192( 2 blks) ==> 284044200:12
930: RAW: 12288( 3 blks) ==> 284044212:12300
931: SKP: 12288( 3 blks) ==> 284056512:12
932: RAW: 4096( 1 blks) ==> 284056524:4108
933: SKP: 45056( 11 blks) ==> 284060632:12
934: RAW: 8192( 2 blks) ==> 284060644:8204
935: SKP: 32768( 8 blks) ==> 284068848:12
936: RAW: 4096( 1 blks) ==> 284068860:4108
937: SKP: 36864( 9 blks) ==> 284072968:12
938: RAW: 4096( 1 blks) ==> 284072980:4108
939: SKP: 16384( 4 blks) ==> 284077088:12
940: RAW: 16384( 4 blks) ==> 284077100:16396
941: SKP: 8192( 2 blks) ==> 284093496:12
942: RAW: 53248( 13 blks) ==> 284093508:53260
943: SKP: 16384( 4 blks) ==> 284146768:12
944: RAW: 4096( 1 blks) ==> 284146780:4108
945: SKP: 12288( 3 blks) ==> 284150888:12
946: RAW: 4096( 1 blks) ==> 284150900:4108
947: SKP: 4096( 1 blks) ==> 284155008:12
948: RAW: 28672( 7 blks) ==> 284155020:28684
949: SKP: 4096( 1 blks) ==> 284183704:12
950: RAW: 352256( 86 blks) ==> 284183716:352268
951: SKP: 4096( 1 blks) ==> 284535984:12
952: RAW: 241664( 59 blks) ==> 284535996:241676
953: SKP: 36864( 9 blks) ==> 284777672:12
954: RAW: 196608( 48 blks) ==> 284777684:196620
955: SKP: 24576( 6 blks) ==> 284974304:12
956: RAW: 2244608( 548 blks) ==> 284974316:2244620
957: SKP: 16384( 4 blks) ==> 287218936:12
958: RAW: 20480( 5 blks) ==> 287218948:20492
959: SKP: 4096( 1 blks) ==> 287239440:12
960: RAW: 42184704( 10299 blks) ==> 287239452:42184716
961: SKP: 3665920( 895 blks) ==> 329424168:12
962: RAW: 3207168( 783 blks) ==> 329424180:3207180
963: SKP: 45056( 11 blks) ==> 332631360:12
964: RAW: 25026560( 6110 blks) ==> 332631372:25026572
965: SKP: 12288( 3 blks) ==> 357657944:12
966: RAW: 49152( 12 blks) ==> 357657956:49164
967: SKP: 36864( 9 blks) ==> 357707120:12
968: RAW: 9138176( 2231 blks) ==> 357707132:9138188
969: SKP: 16384( 4 blks) ==> 366845320:12
970: RAW: 34205696( 8351 blks) ==> 366845332:34205708
971: SKP: 8192( 2 blks) ==> 401051040:12
972: RAW: 9973760( 2435 blks) ==> 401051052:9973772
973: SKP: 40960( 10 blks) ==> 411024824:12
974: RAW: 1466368( 358 blks) ==> 411024836:1466380
975: SKP: 20480( 5 blks) ==> 412491216:12
976: RAW: 63934464( 15609 blks) ==> 412491228:63934476
977: SKP: 8192( 2 blks) ==> 476425704:12
978: RAW: 32235520( 7870 blks) ==> 476425716:32235532
979: SKP: 8192( 2 blks) ==> 508661248:12
980: RAW: 274432( 67 blks) ==> 508661260:274444
981: SKP: 4096( 1 blks) ==> 508935704:12
982: RAW: 14540800( 3550 blks) ==> 508935716:14540812
983: SKP: 8192( 2 blks) ==> 523476528:12
984: RAW: 17350656( 4236 blks) ==> 523476540:17350668
985: SKP: 4096( 1 blks) ==> 540827208:12
986: RAW: 46370816( 11321 blks) ==> 540827220:46370828
987: SKP: 4096( 1 blks) ==> 587198048:12
988: RAW: 6778880( 1655 blks) ==> 587198060:6778892
989: SKP: 3665920( 895 blks) ==> 593976952:12
990: RAW: 2473984( 604 blks) ==> 593976964:2473996
991: SKP: 8192( 2 blks) ==> 596450960:12
992: RAW: 4096( 1 blks) ==> 596450972:4108
993: SKP: 8192( 2 blks) ==> 596455080:12
994: RAW: 16384( 4 blks) ==> 596455092:16396
995: SKP: 4096( 1 blks) ==> 596471488:12
996: RAW: 348160( 85 blks) ==> 596471500:348172
997: SKP: 4096( 1 blks) ==> 596819672:12
998: RAW: 4096( 1 blks) ==> 596819684:4108
999: SKP: 4096( 1 blks) ==> 596823792:12
1000: RAW: 409600( 100 blks) ==> 596823804:409612
1001: SKP: 4096( 1 blks) ==> 597233416:12
1002: RAW: 229376( 56 blks) ==> 597233428:229388
1003: SKP: 4096( 1 blks) ==> 597462816:12
1004: RAW: 155648( 38 blks) ==> 597462828:155660
1005: SKP: 8192( 2 blks) ==> 597618488:12
1006: RAW: 180224( 44 blks) ==> 597618500:180236
1007: SKP: 8192( 2 blks) ==> 597798736:12
1008: RAW: 12288( 3 blks) ==> 597798748:12300
1009: SKP: 4096( 1 blks) ==> 597811048:12
1010: RAW: 32768( 8 blks) ==> 597811060:32780
1011: SKP: 12288( 3 blks) ==> 597843840:12
1012: RAW: 36864( 9 blks) ==> 597843852:36876
1013: SKP: 4096( 1 blks) ==> 597880728:12
1014: RAW: 135168( 33 blks) ==> 597880740:135180
1015: SKP: 8192( 2 blks) ==> 598015920:12
1016: RAW: 520192( 127 blks) ==> 598015932:520204
1017: SKP: 4096( 1 blks) ==> 598536136:12
1018: RAW: 28672( 7 blks) ==> 598536148:28684
1019: SKP: 4096( 1 blks) ==> 598564832:12
1020: RAW: 36864( 9 blks) ==> 598564844:36876
1021: SKP: 4096( 1 blks) ==> 598601720:12
1022: RAW: 6279168( 1533 blks) ==> 598601732:6279180
1023: SKP: 20480( 5 blks) ==> 604880912:12
1024: RAW: 249856( 61 blks) ==> 604880924:249868
1025: SKP: 8192( 2 blks) ==> 605130792:12
1026: RAW: 184320( 45 blks) ==> 605130804:184332
1027: SKP: 4096( 1 blks) ==> 605315136:12
1028: RAW: 76779520( 18745 blks) ==> 605315148:76779532
1029: SKP: 4096( 1 blks) ==> 682094680:12
1030: RAW: 10960896( 2676 blks) ==> 682094692:10960908
1031: SKP: 4096( 1 blks) ==> 693055600:12
1032: RAW: 69632( 17 blks) ==> 693055612:69644
1033: SKP: 4096( 1 blks) ==> 693125256:12
1034: RAW: 16384( 4 blks) ==> 693125268:16396
1035: SKP: 4096( 1 blks) ==> 693141664:12
1036: RAW: 90112( 22 blks) ==> 693141676:90124
1037: SKP: 4096( 1 blks) ==> 693231800:12
1038: RAW: 221184( 54 blks) ==> 693231812:221196
1039: SKP: 12288( 3 blks) ==> 693453008:12
1040: RAW: 135168( 33 blks) ==> 693453020:135180
1041: SKP: 32768( 8 blks) ==> 693588200:12
1042: RAW: 1527808( 373 blks) ==> 693588212:1527820
1043: SKP: 12288( 3 blks) ==> 695116032:12
1044: RAW: 8192( 2 blks) ==> 695116044:8204
1045: SKP: 4096( 1 blks) ==> 695124248:12
1046: RAW: 28672( 7 blks) ==> 695124260:28684
1047: SKP: 12288( 3 blks) ==> 695152944:12
1048: RAW: 16384( 4 blks) ==> 695152956:16396
1049: SKP: 8192( 2 blks) ==> 695169352:12
1050: RAW: 40960( 10 blks) ==> 695169364:40972
1051: SKP: 4096( 1 blks) ==> 695210336:12
1052: RAW: 4096( 1 blks) ==> 695210348:4108
1053: SKP: 4096( 1 blks) ==> 695214456:12
1054: RAW: 45056( 11 blks) ==> 695214468:45068
1055: SKP: 4096( 1 blks) ==> 695259536:12
1056: RAW: 8192( 2 blks) ==> 695259548:8204
1057: SKP: 4096( 1 blks) ==> 695267752:12
1058: RAW: 98304( 24 blks) ==> 695267764:98316
1059: SKP: 16384( 4 blks) ==> 695366080:12
1060: RAW: 16384( 4 blks) ==> 695366092:16396
1061: SKP: 12288( 3 blks) ==> 695382488:12
1062: RAW: 4096( 1 blks) ==> 695382500:4108
1063: SKP: 8192( 2 blks) ==> 695386608:12
1064: RAW: 356352( 87 blks) ==> 695386620:356364
1065: SKP: 4096( 1 blks) ==> 695742984:12
1066: RAW: 4096( 1 blks) ==> 695742996:4108
1067: SKP: 4096( 1 blks) ==> 695747104:12
1068: RAW: 4096(
