How to diagnose whether a TX1 should be sent back for repair?
Our Jetson TX1 stopped working in the middle of a ssh session. We have tried to re-flash L4T and JetPack with no success. In the L4T case, the output of flash.sh was:
tegradevflash --pt flash.bin --storageinfo storage_info.bin --create
On the serial console we recieve the following output:
[0000.171] [TegraBoot] (version 24.00.2015.42-mobile-8f63c9bf)
[0000.176] Processing in cold boot mode Bootloader 2
[0000.181] A02 Bootrom Patch rev = 63
[0000.184] Power-up reason: on button
[0000.188] No Battery Present
[0000.190] RamCode = 0
[0000.193] Platform has Ddr4 type ram
[0000.196] max77620 disabling SD1 Remote Sense
[0000.200] Setting Ddr voltage to 1125mv
[0000.204] Serial Number of Pmic Max77663: 0x10bad
[0000.212] Entering ramdump check
[0000.215] Get RamDumpCarveOut = 0x0
[0000.218] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.223] Last reboot was clean, booting normally!
[0000.228] Sdram initialization is successful
[0000.232] SecureOs Carveout Base=0xff800000 Size=0x00800000
[0000.237] GSC1 Carveout Base=0xff700000 Size=0x00100000
[0000.242] GSC2 Carveout Base=0xff600000 Size=0x00100000
[0000.247] GSC3 Carveout Base=0xff500000 Size=0x00100000
[0000.253] GSC4 Carveout Base=0xff400000 Size=0x00100000
[0000.258] GSC5 Carveout Base=0xff300000 Size=0x00100000
[0000.263] BpmpFw Carveout Base=0xff2c0000 Size=0x00040000
[0000.268] Lp0 Carveout Base=0xff2bf000 Size=0x00001000
[0000.284] RamDump Carveout Base=0xff23f000 Size=0x00080000
[0000.289] Platform-DebugCarveout: 0
[0000.292] Nck Carveout Base=0xff03f000 Size=0x00200000
[0000.297] Non secure mode. Disable rollback prevention
[0000.302] AOTAG Init Done
[0000.350] Using GPT Primary to query partitions
[0000.355] Loading Tboot-CPU binary
[0000.404] Verifying bootloader in OdmNonSecureSBK mode
Is there anything else we could try before sending our board for repair?
Best,
Siniša
That amount of log does not show enough information to call it hardware failure. In the case of a Jetson suddenly failing, more information might also be useful about what was happening, and what steps were taken to flash (including if a VM host is involved).
One thing I often ask regarding systems mysteriously going down in the middle of normal operation is whether it was accessible by network to the outside world (the internet in general)? Unless your Jetson is isolated against remote logins via firewall or a router, then I’d expect the standard known user name and password of “ubuntu/ubuntu” to cause someone port scanning to find and vandalize the system within seconds to hours. Is it possible someone had remote access from an unprotected internet connection?
If possible, also describe your method of flashing, including if it was JetPack, which version of whatever flash method, and how much disk space is available on your host from where the flash program was run (e.g., “df -H -T” describes this).
The output I’ve pasted is all we get in minicom. When we press the res button, we get the same output again.
We were attempting to flash from two different native Ubuntu laptops following the instructions at:
http://developer.download.nvidia.com/embedded/L4T/r24_Release_v2.0/BSP/l4t_quick_start_guide.txt?autho=1477393718_89ce252d13f3333f862705619a0d2a15&file=l4t_quick_start_guide.txt
The command where the process hang was:
sudo ./flash.sh jetson-tx1 mmcblk0p1
One of the two laptops had only 10 GB space (however, I successfully flashed the latest Jetpack from that system on Friday) so we retried from another laptop which had hundreds of gigabytes free. The results were the same.
The system was on internet, so an intrusion is possible (I had checked with nmap, the only open port was ssh). However, I had changed the password so that would not be trivial. Anyway, I would not expect a hardware failure due to software exploit.
10 GB would result in a truncated image, but hundreds of GB would be more than enough.
It’s interesting that when I build a new system and connect it to the internet with a directly accessible IP address, within 30 seconds I start seeing port scans and root login attempts, along with dictionary login attempts to common login names. I agree that with the password changed you should be ok from any kind of simple attack.
For the flash command, could you try with size specified:
sudo ./flash.sh -S 14580MiB jetson-tx1 mmcblk0p1
If you want to log this, you can instead:
sudo ./flash.sh -S 14580MiB jetson-tx1 mmcblk0p1 2>&1 | tee flash_log.txt
…but expect the “progress” indicators for a logged flash session to be a huge amount of text in the log; you may have issues removing the progress indicator (its a single enormous line) before posting. This might not be important though, the real point is to see if it makes it far enough to have any initial transfer to the Jetson from the point of view of the flash script.
To avoid any extraneous noise from the serial console (just to be thorough), remove this before starting the flash. Keep monitoring the byte size of “bootloader/system.img” (which gets moved to system.img.raw at some point, so you need to see that size as well), and hopefully the raw image will be exactly 15288238080 bytes at some point. Use “df -H -T” from the flash directory to verify you still have disk space left and to also verify it is ext4. If it does work, expect creating the system.img and system.img.raw takes significant time prior to actual flash starting.
We have tried the flash command with the specified size on an Ubuntu laptop with a lot of free disk space. Unfortunately, the process still freezes. The flash log and the serial console log are pasted below.
===== flash log =====
Warning: missing eksfile (bootloader/eks.img), continue…
copying bctfile(/home/luce/Downloads/L4T/Linux_for_Tegra/bootloader/t210ref/BCT/P2180_A00_LP4_DSC_204Mhz.cfg)… done.
copying initrd(/home/luce/Downloads/L4T/Linux_for_Tegra/bootloader/l4t_initrd.img)… done.
populating kernel to rootfs… done.
populating initrd to rootfs… done.
populating extlinux.conf.emmc to rootfs… done.
populating /home/luce/Downloads/L4T/Linux_for_Tegra/kernel/dtb/tegra210-jetson-tx1-p2597-2180-a01-devkit.dtb to rootfs… done.
done.
copying bcffile(/home/luce/Downloads/L4T/Linux_for_Tegra/bootloader/t210ref/cfg/board_config_p2597-devkit.xml)… done.
Existing sosfile(/home/luce/Downloads/L4T/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
copying tegraboot(/home/luce/Downloads/L4T/Linux_for_Tegra/bootloader/t210ref/nvtboot.bin)… done.
Existing bpffile(/home/luce/Downloads/L4T/Linux_for_Tegra/bootloader/bpmp.bin) reused.
copying wb0boot(/home/luce/Downloads/L4T/Linux_for_Tegra/bootloader/t210ref/warmboot.bin)… done.
Existing tosfile(/home/luce/Downloads/L4T/Linux_for_Tegra/bootloader/tos.img) reused.
copying dtbfile(/home/luce/Downloads/L4T/Linux_for_Tegra/kernel/dtb/tegra210-jetson-tx1-p2597-2180-a01-devkit.dtb)… done.
Making system.img…
populating rootfs from /home/luce/Downloads/L4T/Linux_for_Tegra/rootfs … done.
Sync’ing system.img … done.
Converting RAW image to Sparse image…
---- Raw to Sparse Image Converter v1.0 ----------------------------
0: RAW: 3796992( 927 blks) ==> 28:3797004
1: SKP: 8192( 2 blks) ==> 3797032:8204
2: RAW: 8192( 2 blks) ==> 3797044:8204
3: SKP: 57344( 14 blks) ==> 3805248:57356
4: RAW: 3039232( 742 blks) ==> 3805260:3039244
5: SKP: 30515200( 7450 blks) ==> 6844504:30515212
6: RAW: 4820992( 1177 blks) ==> 6844516:4821004
7: SKP: 91971584( 22454 blks) ==> 11665520:91971596
8: RAW: 8192( 2 blks) ==> 11665532:8204
9: SKP: 3731456( 911 blks) ==> 11673736:3731468
10: RAW: 31014912( 7572 blks) ==> 11673748:31014924
11: SKP: 4096( 1 blks) ==> 42688672:4108
12: RAW: 65536( 16 blks) ==> 42688684:65548
13: SKP: 12288( 3 blks) ==> 42754232:12300
14: RAW: 81920( 20 blks) ==> 42754244:81932
15: SKP: 12288( 3 blks) ==> 42836176:12300
16: RAW: 4096( 1 blks) ==> 42836188:4108
17: SKP: 16384( 4 blks) ==> 42840296:16396
18: RAW: 1294336( 316 blks) ==> 42840308:1294348
19: SKP: 24576( 6 blks) ==> 44134656:24588
20: RAW: 73728( 18 blks) ==> 44134668:73740
21: SKP: 20480( 5 blks) ==> 44208408:20492
22: RAW: 4096( 1 blks) ==> 44208420:4108
23: SKP: 40960( 10 blks) ==> 44212528:40972
24: RAW: 4096( 1 blks) ==> 44212540:4108
25: SKP: 8192( 2 blks) ==> 44216648:8204
26: RAW: 5849088( 1428 blks) ==> 44216660:5849100
27: SKP: 12288( 3 blks) ==> 50065760:12300
28: RAW: 4096( 1 blks) ==> 50065772:4108
29: SKP: 4096( 1 blks) ==> 50069880:4108
30: RAW: 22339584( 5454 blks) ==> 50069892:22339596
31: SKP: 4096( 1 blks) ==> 72409488:4108
32: RAW: 9256960( 2260 blks) ==> 72409500:9256972
33: SKP: 8192( 2 blks) ==> 81666472:8204
34: RAW: 573440( 140 blks) ==> 81666484:573452
35: SKP: 4096( 1 blks) ==> 82239936:4108
36: RAW: 17821696( 4351 blks) ==> 82239948:17821708
37: SKP: 40960( 10 blks) ==> 100061656:40972
38: RAW: 1093632( 267 blks) ==> 100061668:1093644
39: SKP: 4096( 1 blks) ==> 101155312:4108
40: RAW: 33083392( 8077 blks) ==> 101155324:33083404
41: SKP: 28672( 7 blks) ==> 134238728:28684
42: RAW: 2723840( 665 blks) ==> 134238740:2723852
43: SKP: 294912( 72 blks) ==> 136962592:294924
44: RAW: 221184( 54 blks) ==> 136962604:221196
45: SKP: 4096( 1 blks) ==> 137183800:4108
46: RAW: 1638400( 400 blks) ==> 137183812:1638412
47: SKP: 8192( 2 blks) ==> 138822224:8204
48: RAW: 7544832( 1842 blks) ==> 138822236:7544844
49: SKP: 4096( 1 blks) ==> 146367080:4108
50: RAW: 8192( 2 blks) ==> 146367092:8204
51: SKP: 12288( 3 blks) ==> 146375296:12300
52: RAW: 12288( 3 blks) ==> 146375308:12300
53: SKP: 36864( 9 blks) ==> 146387608:36876
54: RAW: 10055680( 2455 blks) ==> 146387620:10055692
55: SKP: 4096( 1 blks) ==> 156443312:4108
56: RAW: 8286208( 2023 blks) ==> 156443324:8286220
57: SKP: 8192( 2 blks) ==> 164729544:8204
58: RAW: 2740224( 669 blks) ==> 164729556:2740236
59: SKP: 20480( 5 blks) ==> 167469792:20492
60: RAW: 3239936( 791 blks) ==> 167469804:3239948
61: SKP: 12288( 3 blks) ==> 170709752:12300
62: RAW: 1130496( 276 blks) ==> 170709764:1130508
63: SKP: 32768( 8 blks) ==> 171840272:32780
64: RAW: 1830912( 447 blks) ==> 171840284:1830924
65: SKP: 4096( 1 blks) ==> 173671208:4108
66: RAW: 44703744( 10914 blks) ==> 173671220:44703756
67: SKP: 32768( 8 blks) ==> 218374976:32780
68: RAW: 3309568( 808 blks) ==> 218374988:3309580
69: SKP: 4096( 1 blks) ==> 221684568:4108
70: RAW: 7589888( 1853 blks) ==> 221684580:7589900
71: SKP: 28672( 7 blks) ==> 229274480:28684
72: RAW: 15675392( 3827 blks) ==> 229274492:15675404
73: SKP: 4096( 1 blks) ==> 244949896:4108
74: RAW: 2088960( 510 blks) ==> 244949908:2088972
75: SKP: 8192( 2 blks) ==> 247038880:8204
76: RAW: 8192( 2 blks) ==> 247038892:8204
77: SKP: 4096( 1 blks) ==> 247047096:4108
78: RAW: 335872( 82 blks) ==> 247047108:335884
79: SKP: 8192( 2 blks) ==> 247382992:8204
80: RAW: 1835008( 448 blks) ==> 247383004:1835020
81: SKP: 4096( 1 blks) ==> 249218024:4108
82: RAW: 2932736( 716 blks) ==> 249218036:2932748
83: SKP: 4096( 1 blks) ==> 252150784:4108
84: RAW: 6045696( 1476 blks) ==> 252150796:6045708
85: SKP: 24576( 6 blks) ==> 258196504:24588
86: RAW: 1716224( 419 blks) ==> 258196516:1716236
87: SKP: 4096( 1 blks) ==> 259912752:4108
88: RAW: 15650816( 3821 blks) ==> 259912764:15650828
89: SKP: 3731456( 911 blks) ==> 275563592:3731468
90: RAW: 2682880( 655 blks) ==> 275563604:2682892
91: SKP: 24576( 6 blks) ==> 278246496:24588
92: RAW: 8192( 2 blks) ==> 278246508:8204
93: SKP: 20480( 5 blks) ==> 278254712:20492
94: RAW: 22683648( 5538 blks) ==> 278254724:22683660
95: SKP: 49152( 12 blks) ==> 300938384:49164
96: RAW: 4096( 1 blks) ==> 300938396:4108
97: SKP: 61440( 15 blks) ==> 300942504:61452
98: RAW: 20480( 5 blks) ==> 300942516:20492
99: SKP: 16384( 4 blks) ==> 300963008:16396
100: RAW: 3715072( 907 blks) ==> 300963020:3715084
101: SKP: 4096( 1 blks) ==> 304678104:4108
102: RAW: 9981952( 2437 blks) ==> 304678116:9981964
103: SKP: 8192( 2 blks) ==> 314660080:8204
104: RAW: 2863104( 699 blks) ==> 314660092:2863116
105: SKP: 8192( 2 blks) ==> 317523208:8204
106: RAW: 475136( 116 blks) ==> 317523220:475148
107: SKP: 16384( 4 blks) ==> 317998368:16396
108: RAW: 8192( 2 blks) ==> 317998380:8204
109: SKP: 4096( 1 blks) ==> 318006584:4108
110: RAW: 1785856( 436 blks) ==> 318006596:1785868
111: SKP: 4096( 1 blks) ==> 319792464:4108
112: RAW: 499712( 122 blks) ==> 319792476:499724
113: SKP: 12288( 3 blks) ==> 320292200:12300
114: RAW: 1634304( 399 blks) ==> 320292212:1634316
115: SKP: 12288( 3 blks) ==> 321926528:12300
116: RAW: 12288( 3 blks) ==> 321926540:12300
117: SKP: 4096( 1 blks) ==> 321938840:4108
118: RAW: 6733824( 1644 blks) ==> 321938852:6733836
119: SKP: 24576( 6 blks) ==> 328672688:24588
120: RAW: 6135808( 1498 blks) ==> 328672700:6135820
121: SKP: 360448( 88 blks) ==> 334808520:360460
122: RAW: 24649728( 6018 blks) ==> 334808532:24649740
123: SKP: 61440( 15 blks) ==> 359458272:61452
124: RAW: 4096( 1 blks) ==> 359458284:4108
125: SKP: 4096( 1 blks) ==> 359462392:4108
126: RAW: 8192( 2 blks) ==> 359462404:8204
127: SKP: 49152( 12 blks) ==> 359470608:49164
128: RAW: 98304( 24 blks) ==> 359470620:98316
129: SKP: 4096( 1 blks) ==> 359568936:4108
130: RAW: 16384( 4 blks) ==> 359568948:16396
131: SKP: 8192( 2 blks) ==> 359585344:8204
132: RAW: 12288( 3 blks) ==> 359585356:12300
133: SKP: 4096( 1 blks) ==> 359597656:4108
134: RAW: 40960( 10 blks) ==> 359597668:40972
135: SKP: 4096( 1 blks) ==> 359638640:4108
136: RAW: 3555328( 868 blks) ==> 359638652:3555340
137: SKP: 12288( 3 blks) ==> 363193992:12300
138: RAW: 7733248( 1888 blks) ==> 363194004:7733260
139: SKP: 4096( 1 blks) ==> 370927264:4108
140: RAW: 2265088( 553 blks) ==> 370927276:2265100
141: SKP: 8192( 2 blks) ==> 373192376:8204
142: RAW: 36864( 9 blks) ==> 373192388:36876
143: SKP: 8192( 2 blks) ==> 373229264:8204
144: RAW: 8192( 2 blks) ==> 373229276:8204
145: SKP: 8192( 2 blks) ==> 373237480:8204
146: RAW: 8192( 2 blks) ==> 373237492:8204
147: SKP: 16384( 4 blks) ==> 373245696:16396
148: RAW: 42090496( 10276 blks) ==> 373245708:42090508
149: SKP: 8192( 2 blks) ==> 415336216:8204
150: RAW: 1732608( 423 blks) ==> 415336228:1732620
151: SKP: 4096( 1 blks) ==> 417068848:4108
152: RAW: 40960( 10 blks) ==> 417068860:40972
153: SKP: 4096( 1 blks) ==> 417109832:4108
154: RAW: 450560( 110 blks) ==> 417109844:450572
155: SKP: 4096( 1 blks) ==> 417560416:4108
156: RAW: 434176( 106 blks) ==> 417560428:434188
157: SKP: 4096( 1 blks) ==> 417994616:4108
158: RAW: 131072( 32 blks) ==> 417994628:131084
159: SKP: 16384( 4 blks) ==> 418125712:16396
160: RAW: 122880( 30 blks) ==> 418125724:122892
161: SKP: 4096( 1 blks) ==> 418248616:4108
162: RAW: 557056( 136 blks) ==> 418248628:557068
163: SKP: 36864( 9 blks) ==> 418805696:36876
164: RAW: 651264( 159 blks) ==> 418805708:651276
165: SKP: 4096( 1 blks) ==> 419456984:4108
166: RAW: 73728( 18 blks) ==> 419456996:73740
167: SKP: 73728( 18 blks) ==> 419530736:73740
168: RAW: 4096( 1 blks) ==> 419530748:4108
169: SKP: 8192( 2 blks) ==> 419534856:8204
170: RAW: 4096( 1 blks) ==> 419534868:4108
171: SKP: 4096( 1 blks) ==> 419538976:4108
172: RAW: 4096( 1 blks) ==> 419538988:4108
173: SKP: 8192( 2 blks) ==> 419543096:8204
174: RAW: 16384( 4 blks) ==> 419543108:16396
175: SKP: 4096( 1 blks) ==> 419559504:4108
176: RAW: 4096( 1 blks) ==> 419559516:4108
177: SKP: 4096( 1 blks) ==> 419563624:4108
178: RAW: 4096( 1 blks) ==> 419563636:4108
179: SKP: 4096( 1 blks) ==> 419567744:4108
180: RAW: 12288( 3 blks) ==> 419567756:12300
181: SKP: 8192( 2 blks) ==> 419580056:8204
182: RAW: 24576( 6 blks) ==> 419580068:24588
183: SKP: 4096( 1 blks) ==> 419604656:4108
184: RAW: 8192( 2 blks) ==> 419604668:8204
185: SKP: 4096( 1 blks) ==> 419612872:4108
186: RAW: 8192( 2 blks) ==> 419612884:8204
187: SKP: 12288( 3 blks) ==> 419621088:12300
188: RAW: 16384( 4 blks) ==> 419621100:16396
189: SKP: 4096( 1 blks) ==> 419637496:4108
190: RAW: 8192( 2 blks) ==> 419637508:8204
191: SKP: 4096( 1 blks) ==> 419645712:4108
192: RAW: 73728( 18 blks) ==> 419645724:73740
193: SKP: 12288( 3 blks) ==> 419719464:12300
194: RAW: 4096( 1 blks) ==> 419719476:4108
195: SKP: 8192( 2 blks) ==> 419723584:8204
196: RAW: 24576( 6 blks) ==> 419723596:24588
197: SKP: 8192( 2 blks) ==> 419748184:8204
198: RAW: 16384( 4 blks) ==> 419748196:16396
199: SKP: 4096( 1 blks) ==> 419764592:4108
200: RAW: 4096( 1 blks) ==> 419764604:4108
201: SKP: 20480( 5 blks) ==> 419768712:20492
202: RAW: 4096( 1 blks) ==> 419768724:4108
203: SKP: 8192( 2 blks) ==> 419772832:8204
204: RAW: 4096( 1 blks) ==> 419772844:4108
205: SKP: 8192( 2 blks) ==> 419776952:8204
206: RAW: 8192( 2 blks) ==> 419776964:8204
207: SKP: 4096( 1 blks) ==> 419785168:4108
208: RAW: 4096( 1 blks) ==> 419785180:4108
209: SKP: 12288( 3 blks) ==> 419789288:12300
210: RAW: 4096( 1 blks) ==> 419789300:4108
211: SKP: 45056( 11 blks) ==> 419793408:45068
212: RAW: 8192( 2 blks) ==> 419793420:8204
213: SKP: 28672( 7 blks) ==> 419801624:28684
214: RAW: 4096( 1 blks) ==> 419801636:4108
215: SKP: 40960( 10 blks) ==> 419805744:40972
216: RAW: 4096( 1 blks) ==> 419805756:4108
217: SKP: 16384( 4 blks) ==> 419809864:16396
218: RAW: 16384( 4 blks) ==> 419809876:16396
219: SKP: 8192( 2 blks) ==> 419826272:8204
220: RAW: 53248( 13 blks) ==> 419826284:53260
221: SKP: 16384( 4 blks) ==> 419879544:16396
222: RAW: 4096( 1 blks) ==> 419879556:4108
223: SKP: 8192( 2 blks) ==> 419883664:8204
224: RAW: 8192( 2 blks) ==> 419883676:8204
225: SKP: 4096( 1 blks) ==> 419891880:4108
226: RAW: 385024( 94 blks) ==> 419891892:385036
227: SKP: 4096( 1 blks) ==> 420276928:4108
228: RAW: 241664( 59 blks) ==> 420276940:241676
229: SKP: 32768( 8 blks) ==> 420518616:32780
230: RAW: 8118272( 1982 blks) ==> 420518628:8118284
231: SKP: 53248( 13 blks) ==> 428636912:53260
232: RAW: 4681728( 1143 blks) ==> 428636924:4681740
233: SKP: 8192( 2 blks) ==> 433318664:8204
234: RAW: 1732608( 423 blks) ==> 433318676:1732620
235: SKP: 12288( 3 blks) ==> 435051296:12300
236: RAW: 10833920( 2645 blks) ==> 435051308:10833932
237: SKP: 4096( 1 blks) ==> 445885240:4108
238: RAW: 4136960( 1010 blks) ==> 445885252:4136972
239: SKP: 151552( 37 blks) ==> 450022224:151564
240: RAW: 4096( 1 blks) ==> 450022236:4108
241: SKP: 28672( 7 blks) ==> 450026344:28684
242: RAW: 8192( 2 blks) ==> 450026356:8204
243: SKP: 4096( 1 blks) ==> 450034560:4108
244: RAW: 12288( 3 blks) ==> 450034572:12300
245: SKP: 147456( 36 blks) ==> 450046872:147468
246: RAW: 4096( 1 blks) ==> 450046884:4108
247: SKP: 28672( 7 blks) ==> 450050992:28684
248: RAW: 8192( 2 blks) ==> 450051004:8204
249: SKP: 8192( 2 blks) ==> 450059208:8204
250: RAW: 8192( 2 blks) ==> 450059220:8204
251: SKP: 151552( 37 blks) ==> 450067424:151564
252: RAW: 4096( 1 blks) ==> 450067436:4108
253: SKP: 28672( 7 blks) ==> 450071544:28684
254: RAW: 8192( 2 blks) ==> 450071556:8204
255: SKP: 4096( 1 blks) ==> 450079760:4108
256: RAW: 12288( 3 blks) ==> 450079772:12300
257: SKP: 147456( 36 blks) ==> 450092072:147468
258: RAW: 4096( 1 blks) ==> 450092084:4108
259: SKP: 28672( 7 blks) ==> 450096192:28684
260: RAW: 8192( 2 blks) ==> 450096204:8204
261: SKP: 8192( 2 blks) ==> 450104408:8204
262: RAW: 901120( 220 blks) ==> 450104420:901132
263: SKP: 12288( 3 blks) ==> 451005552:12300
264: RAW: 1662976( 406 blks) ==> 451005564:1662988
265: SKP: 4096( 1 blks) ==> 452668552:4108
266: RAW: 4096( 1 blks) ==> 452668564:4108
267: SKP: 8192( 2 blks) ==> 452672672:8204
268: RAW: 4096( 1 blks) ==> 452672684:4108
269: SKP: 40960( 10 blks) ==> 452676792:40972
270: RAW: 8192( 2 blks) ==> 452676804:8204
271: SKP: 53248( 13 blks) ==> 452685008:53260
272: RAW: 16384( 4 blks) ==> 452685020:16396
273: SKP: 24576( 6 blks) ==> 452701416:24588
274: RAW: 1187840( 290 blks) ==> 452701428:1187852
275: SKP: 45056( 11 blks) ==> 453889280:45068
276: RAW: 19550208( 4773 blks) ==> 453889292:19550220
277: SKP: 20480( 5 blks) ==> 473439512:20492
278: RAW: 110592( 27 blks) ==> 473439524:110604
279: SKP: 12288( 3 blks) ==> 473550128:12300
280: RAW: 3436544( 839 blks) ==> 473550140:3436556
281: SKP: 12288( 3 blks) ==> 476986696:12300
282: RAW: 2166784( 529 blks) ==> 476986708:2166796
283: SKP: 4096( 1 blks) ==> 479153504:4108
284: RAW: 212992( 52 blks) ==> 479153516:213004
285: SKP: 8192( 2 blks) ==> 479366520:8204
286: RAW: 856064( 209 blks) ==> 479366532:856076
287: SKP: 8192( 2 blks) ==> 480222608:8204
288: RAW: 13565952( 3312 blks) ==> 480222620:13565964
289: SKP: 20480( 5 blks) ==> 493788584:20492
290: RAW: 3497984( 854 blks) ==> 493788596:3497996
291: SKP: 4096( 1 blks) ==> 497286592:4108
292: RAW: 1662976( 406 blks) ==> 497286604:1662988
293: SKP: 8192( 2 blks) ==> 498949592:8204
294: RAW: 933888( 228 blks) ==> 498949604:933900
295: SKP: 4096( 1 blks) ==> 499883504:4108
296: RAW: 3985408( 973 blks) ==> 499883516:3985420
297: SKP: 32768( 8 blks) ==> 503868936:32780
298: RAW: 1642496( 401 blks) ==> 503868948:1642508
299: SKP: 4096( 1 blks) ==> 505511456:4108
300: RAW: 2506752( 612 blks) ==> 505511468:2506764
301: SKP: 8192( 2 blks) ==> 508018232:8204
302: RAW: 2555904( 624 blks) ==> 508018244:2555916
303: SKP: 4096( 1 blks) ==> 510574160:4108
304: RAW: 16384( 4 blks) ==> 510574172:16396
305: SKP: 4096( 1 blks) ==> 510590568:4108
306: RAW: 327680( 80 blks) ==> 510590580:327692
307: SKP: 24576( 6 blks) ==> 510918272:24588
308: RAW: 135168( 33 blks) ==> 510918284:135180
309: SKP: 4096( 1 blks) ==> 511053464:4108
310: RAW: 57344( 14 blks) ==> 511053476:57356
311: SKP: 57344( 14 blks) ==> 511110832:57356
312: RAW: 380928( 93 blks) ==> 511110844:380940
313: SKP: 4096( 1 blks) ==> 511491784:4108
314: RAW: 16384( 4 blks) ==> 511491796:16396
315: SKP: 40960( 10 blks) ==> 511508192:40972
316: RAW: 4096( 1 blks) ==> 511508204:4108
317: SKP: 200704( 49 blks) ==> 511512312:200716
318: RAW: 339968( 83 blks) ==> 511512324:339980
319: SKP: 86016( 21 blks) ==> 511852304:86028
320: RAW: 229376( 56 blks) ==> 511852316:229388
321: SKP: 20480( 5 blks) ==> 512081704:20492
322: RAW: 8192( 2 blks) ==> 512081716:8204
323: SKP: 57344( 14 blks) ==> 512089920:57356
324: RAW: 4096( 1 blks) ==> 512089932:4108
325: SKP: 4096( 1 blks) ==> 512094040:4108
326: RAW: 7839744( 1914 blks) ==> 512094052:7839756
327: SKP: 49152( 12 blks) ==> 519933808:49164
328: RAW: 4096( 1 blks) ==> 519933820:4108
329: SKP: 167936( 41 blks) ==> 519937928:167948
330: RAW: 1204224( 294 blks) ==> 519937940:1204236
331: SKP: 28672( 7 blks) ==> 521142176:28684
332: RAW: 3780608( 923 blks) ==> 521142188:3780620
333: SKP: 8192( 2 blks) ==> 524922808:8204
334: RAW: 12091392( 2952 blks) ==> 524922820:12091404
335: SKP: 3731456( 911 blks) ==> 537014224:3731468
336: RAW: 3063808( 748 blks) ==> 537014236:3063820
337: SKP: 4096( 1 blks) ==> 540078056:4108
338: RAW: 385024( 94 blks) ==> 540078068:385036
339: SKP: 12288( 3 blks) ==> 540463104:12300
340: RAW: 65536( 16 blks) ==> 540463116:65548
341: SKP: 12288( 3 blks) ==> 540528664:12300
342: RAW: 65536( 16 blks) ==> 540528676:65548
343: SKP: 12288( 3 blks) ==> 540594224:12300
344: RAW: 61440( 15 blks) ==> 540594236:61452
345: SKP: 12288( 3 blks) ==> 540655688:12300
346: RAW: 61440( 15 blks) ==> 540655700:61452
347: SKP: 12288( 3 blks) ==> 540717152:12300
348: RAW: 2129920( 520 blks) ==> 540717164:2129932
349: SKP: 28672( 7 blks) ==> 542847096:28684
350: RAW: 8192( 2 blks) ==> 542847108:8204
351: SKP: 155648( 38 blks) ==> 542855312:155660
352: RAW: 8192( 2 blks) ==> 542855324:8204
353: SKP: 16384( 4 blks) ==> 542863528:16396
354: RAW: 217088( 53 blks) ==> 542863540:217100
355: SKP: 4096( 1 blks) ==> 543080640:4108
356: RAW: 172032( 42 blks) ==> 543080652:172044
357: SKP: 8192( 2 blks) ==> 543252696:8204
358: RAW: 184320( 45 blks) ==> 543252708:184332
359: SKP: 8192( 2 blks) ==> 543437040:8204
360: RAW: 204800( 50 blks) ==> 543437052:204812
361: SKP: 24576( 6 blks) ==> 543641864:24588
362: RAW: 8192( 2 blks) ==> 543641876:8204
363: SKP: 86016( 21 blks) ==> 543650080:86028
364: RAW: 4096( 1 blks) ==> 543650092:4108
365: SKP: 12288( 3 blks) ==> 543654200:12300
366: RAW: 4096( 1 blks) ==> 543654212:4108
367: SKP: 57344( 14 blks) ==> 543658320:57356
368: RAW: 8192( 2 blks) ==> 543658332:8204
369: SKP: 69632( 17 blks) ==> 543666536:69644
370: RAW: 16384( 4 blks) ==> 543666548:16396
371: SKP: 28672( 7 blks) ==> 543682944:28684
372: RAW: 5779456( 1411 blks) ==> 543682956:5779468
373: SKP: 12288( 3 blks) ==> 549462424:12300
374: RAW: 18309120( 4470 blks) ==> 549462436:18309132
375: SKP: 8192( 2 blks) ==> 567771568:8204
376: RAW: 2498560( 610 blks) ==> 567771580:2498572
377: SKP: 8192( 2 blks) ==> 570270152:8204
378: RAW: 2666496( 651 blks) ==> 570270164:2666508
379: SKP: 4096( 1 blks) ==> 572936672:4108
380: RAW: 348160( 85 blks) ==> 572936684:348172
381: SKP: 20480( 5 blks) ==> 573284856:20492
382: RAW: 139264( 34 blks) ==> 573284868:139276
383: SKP: 4096( 1 blks) ==> 573424144:4108
384: RAW: 57344( 14 blks) ==> 573424156:57356
385: SKP: 57344( 14 blks) ==> 573481512:57356
386: RAW: 376832( 92 blks) ==> 573481524:376844
387: SKP: 8192( 2 blks) ==> 573858368:8204
388: RAW: 12288( 3 blks) ==> 573858380:12300
389: SKP: 45056( 11 blks) ==> 573870680:45068
390: RAW: 4096( 1 blks) ==> 573870692:4108
391: SKP: 200704( 49 blks) ==> 573874800:200716
392: RAW: 278528( 68 blks) ==> 573874812:278540
393: SKP: 86016( 21 blks) ==> 574153352:86028
394: RAW: 4878336( 1191 blks) ==> 574153364:4878348
395: SKP: 4096( 1 blks) ==> 579031712:4108
396: RAW: 4096( 1 blks) ==> 579031724:4108
397: SKP: 4096( 1 blks) ==> 579035832:4108
398: RAW: 16384( 4 blks) ==> 579035844:16396
399: SKP: 4096( 1 blks) ==> 579052240:4108
400: RAW: 12288( 3 blks) ==> 579052252:12300
401: SKP: 4096( 1 blks) ==> 579064552:4108
402: RAW: 1916928( 468 blks) ==> 579064564:1916940
403: SKP: 4096( 1 blks) ==> 580981504:4108
404: RAW: 28672( 7 blks) ==> 580981516:28684
405: SKP: 12288( 3 blks) ==> 581010200:12300
406: RAW: 8192( 2 blks) ==> 581010212:8204
407: SKP: 4096( 1 blks) ==> 581018416:4108
408: RAW: 12288( 3 blks) ==> 581018428:12300
409: SKP: 20480( 5 blks) ==> 581030728:20492
410: RAW: 2007040( 490 blks) ==> 581030740:2007052
411: SKP: 4096( 1 blks) ==> 583037792:4108
412: RAW: 6066176( 1481 blks) ==> 583037804:6066188
413: SKP: 4096( 1 blks) ==> 589103992:4108
414: RAW: 4096( 1 blks) ==> 589104004:4108
415: SKP: 8192( 2 blks) ==> 589108112:8204
416: RAW: 495616( 121 blks) ==> 589108124:495628
417: SKP: 4096( 1 blks) ==> 589603752:4108
418: RAW: 3383296( 826 blks) ==> 589603764:3383308
419: SKP: 8192( 2 blks) ==> 592987072:8204
420: RAW: 8192( 2 blks) ==> 592987084:8204
421: SKP: 16384( 4 blks) ==> 592995288:16396
422: RAW: 2646016( 646 blks) ==> 592995300:2646028
423: SKP: 36864( 9 blks) ==> 595641328:36876
424: RAW: 5615616( 1371 blks) ==> 595641340:5615628
425: SKP: 4096( 1 blks) ==> 601256968:4108
426: RAW: 4333568( 1058 blks) ==> 601256980:4333580
427: SKP: 24576( 6 blks) ==> 605590560:24588
428: RAW: 335872( 82 blks) ==> 605590572:335884
429: SKP: 49152( 12 blks) ==> 605926456:49164
430: RAW: 2748416( 671 blks) ==> 605926468:2748428
431: SKP: 4096( 1 blks) ==> 608674896:4108
432: RAW: 8183808( 1998 blks) ==> 608674908:8183820
433: SKP: 57344( 14 blks) ==> 616858728:57356
434: RAW: 5484544( 1339 blks) ==> 616858740:5484556
435: SKP: 12288( 3 blks) ==> 622343296:12300
436: RAW: 974848( 238 blks) ==> 622343308:974860
437: SKP: 4096( 1 blks) ==> 623318168:4108
438: RAW: 4722688( 1153 blks) ==> 623318180:4722700
439: SKP: 20480( 5 blks) ==> 628040880:20492
440: RAW: 12288( 3 blks) ==> 628040892:12300
441: SKP: 57344( 14 blks) ==> 628053192:57356
442: RAW: 495616( 121 blks) ==> 628053204:495628
443: SKP: 32768( 8 blks) ==> 628548832:32780
444: RAW: 200704( 49 blks) ==> 628548844:200716
445: SKP: 36864( 9 blks) ==> 628749560:36876
446: RAW: 155648( 38 blks) ==> 628749572:155660
447: SKP: 57344( 14 blks) ==> 628905232:57356
448: RAW: 16384( 4 blks) ==> 628905244:16396
449: SKP: 53248( 13 blks) ==> 628921640:53260
450: RAW: 2117632( 517 blks) ==> 628921652:2117644
451: SKP: 8192( 2 blks) ==> 631039296:8204
452: RAW: 1716224( 419 blks) ==> 631039308:1716236
453: SKP: 4096( 1 blks) ==> 632755544:4108
454: RAW: 57344( 14 blks) ==> 632755556:57356
455: SKP: 4096( 1 blks) ==> 632812912:4108
456: RAW: 106496( 26 blks) ==> 632812924:106508
457: SKP: 4096( 1 blks) ==> 632919432:4108
458: RAW: 1384448( 338 blks) ==> 632919444:1384460
459: SKP: 8192( 2 blks) ==> 634303904:8204
460: RAW: 3182592( 777 blks) ==> 634303916:3182604
461: SKP: 4096( 1 blks) ==> 637486520:4108
462: RAW: 40968192( 10002 blks) ==> 637486532:40968204
463: SKP: 4096( 1 blks) ==> 678454736:4108
464: RAW: 40960( 10 blks) ==> 678454748:40972
465: SKP: 73728( 18 blks) ==> 678495720:73740
466: RAW: 4096( 1 blks) ==> 678495732:4108
467: SKP: 8192( 2 blks) ==> 678499840:8204
468: RAW: 4096( 1 blks) ==> 678499852:4108
469: SKP: 4096( 1 blks) ==> 678503960:4108
470: RAW: 4096( 1 blks) ==> 678503972:4108
471: SKP: 8192( 2 blks) ==> 678508080:8204
472: RAW: 4096( 1 blks) ==> 678508092:4108
473: SKP: 4096( 1 blks) ==> 678512200:4108
474: RAW: 16384( 4 blks) ==> 678512212:16396
475: SKP: 4096( 1 blks) ==> 678528608:4108
476: RAW: 4096( 1 blks) ==> 678528620:4108
477: SKP: 4096( 1 blks) ==> 678532728:4108
478: RAW: 12288( 3 blks) ==> 678532740:12300
479: SKP: 12288( 3 blks) ==> 678545040:12300
480: RAW: 20480( 5 blks) ==> 678545052:20492
481: SKP: 4096( 1 blks) ==> 678565544:4108
482: RAW: 8192( 2 blks) ==> 678565556:8204
483: SKP: 8192( 2 blks) ==> 678573760:8204
484: RAW: 4096( 1 blks) ==> 678573772:4108
485: SKP: 12288( 3 blks) ==> 678577880:12300
486: RAW: 28672( 7 blks) ==> 678577892:28684
487: SKP: 4096( 1 blks) ==> 678606576:4108
488: RAW: 73728( 18 blks) ==> 678606588:73740
489: SKP: 12288( 3 blks) ==> 678680328:12300
490: RAW: 4096( 1 blks) ==> 678680340:4108
491: SKP: 8192( 2 blks) ==> 678684448:8204
492: RAW: 16384( 4 blks) ==> 678684460:16396
493: SKP: 4096( 1 blks) ==> 678700856:4108
494: RAW: 8192( 2 blks) ==> 678700868:8204
495: SKP: 4096( 1 blks) ==> 678709072:4108
496: RAW: 16384( 4 blks) ==> 678709084:16396
497: SKP: 4096( 1 blks) ==> 678725480:4108
498: RAW: 4096( 1 blks) ==> 678725492:4108
499: SKP: 20480( 5 blks) ==> 678729600:20492
500: RAW: 4096( 1 blks) ==> 678729612:4108
501: SKP: 8192( 2 blks) ==> 678733720:8204
502: RAW: 8192( 2 blks) ==> 678733732:8204
503: SKP: 8192( 2 blks) ==> 678741936:8204
504: RAW: 12288( 3 blks) ==> 678741948:12300
505: SKP: 12288( 3 blks) ==> 678754248:12300
506: RAW: 4096( 1 blks) ==> 678754260:4108
507: SKP: 45056( 11 blks) ==> 678758368:45068
508: RAW: 8192( 2 blks) ==> 678758380:8204
509: SKP: 32768( 8 blks) ==> 678766584:32780
510: RAW: 4096( 1 blks) ==> 678766596:4108
511: SKP: 36864( 9 blks) ==> 678770704:36876
512: RAW: 4096( 1 blks) ==> 678770716:4108
513: SKP: 16384( 4 blks) ==> 678774824:16396
514: RAW: 16384( 4 blks) ==> 678774836:16396
515: SKP: 8192( 2 blks) ==> 678791232:8204
516: RAW: 53248( 13 blks) ==> 678791244:53260
517: SKP: 16384( 4 blks) ==> 678844504:16396
518: RAW: 4096( 1 blks) ==> 678844516:4108
519: SKP: 12288( 3 blks) ==> 678848624:12300
520: RAW: 4096( 1 blks) ==> 678848636:4108
521: SKP: 4096( 1 blks) ==> 678852744:4108
522: RAW: 28672( 7 blks) ==> 678852756:28684
523: SKP: 4096( 1 blks) ==> 678881440:4108
524: RAW: 352256( 86 blks) ==> 678881452:352268
525: SKP: 4096( 1 blks) ==> 679233720:4108
526: RAW: 241664( 59 blks) ==> 679233732:241676
527: SKP: 36864( 9 blks) ==> 679475408:36876
528: RAW: 3264512( 797 blks) ==> 679475420:3264524
529: SKP: 49152( 12 blks) ==> 682739944:49164
530: RAW: 4096( 1 blks) ==> 682739956:4108
531: SKP: 61440( 15 blks) ==> 682744064:61452
532: RAW: 98304( 24 blks) ==> 682744076:98316
533: SKP: 28672( 7 blks) ==> 682842392:28684
534: RAW: 106496( 26 blks) ==> 682842404:106508
535: SKP: 12288( 3 blks) ==> 682948912:12300
536: RAW: 8192( 2 blks) ==> 682948924:8204
537: SKP: 12288( 3 blks) ==> 682957128:12300
538: RAW: 4096( 1 blks) ==> 682957140:4108
539: SKP: 12288( 3 blks) ==> 682961248:12300
540: RAW: 8192( 2 blks) ==> 682961260:8204
541: SKP: 12288( 3 blks) ==> 682969464:12300
542: RAW: 8192( 2 blks) ==> 682969476:8204
543: SKP: 12288( 3 blks) ==> 682977680:12300
544: RAW: 4096( 1 blks) ==> 682977692:4108
545: SKP: 12288( 3 blks) ==> 682981800:12300
546: RAW: 8192( 2 blks) ==> 682981812:8204
547: SKP: 12288( 3 blks) ==> 682990016:12300
548: RAW: 8192( 2 blks) ==> 682990028:8204
549: SKP: 12288( 3 blks) ==> 682998232:12300
550: RAW: 122880( 30 blks) ==> 682998244:122892
551: SKP: 12288( 3 blks) ==> 683121136:12300
552: RAW: 8192( 2 blks) ==> 683121148:8204
553: SKP: 12288( 3 blks) ==> 683129352:12300
554: RAW: 4096( 1 blks) ==> 683129364:4108
555: SKP: 12288( 3 blks) ==> 683133472:12300
556: RAW: 8192( 2 blks) ==> 683133484:8204
557: SKP: 24576( 6 blks) ==> 683141688:24588
558: RAW: 73728( 18 blks) ==> 683141700:73740
559: SKP: 12288( 3 blks) ==> 683215440:12300
560: RAW: 8192( 2 blks) ==> 683215452:8204
561: SKP: 12288( 3 blks) ==> 683223656:12300
562: RAW: 8192( 2 blks) ==> 683223668:8204
563: SKP: 12288( 3 blks) ==> 683231872:12300
564: RAW: 4096( 1 blks) ==> 683231884:4108
565: SKP: 12288( 3 blks) ==> 683235992:12300
566: RAW: 12288( 3 blks) ==> 683236004:12300
567: SKP: 8192( 2 blks) ==> 683248304:8204
568: RAW: 12288( 3 blks) ==> 683248316:12300
569: SKP: 12288( 3 blks) ==> 683260616:12300
570: RAW: 8192( 2 blks) ==> 683260628:8204
571: SKP: 12288( 3 blks) ==> 683268832:12300
572: RAW: 8192( 2 blks) ==> 683268844:8204
573: SKP: 12288( 3 blks) ==> 683277048:12300
574: RAW: 8192( 2 blks) ==> 683277060:8204
575: SKP: 12288( 3 blks) ==> 683285264:12300
576: RAW: 4096( 1 blks) ==> 683285276:4108
577: SKP: 4096( 1 blks) ==> 683289384:4108
578: RAW: 4096( 1 blks) ==> 683289396:4108
579: SKP: 12288( 3 blks) ==> 683293504:12300
580: RAW: 4096( 1 blks) ==> 683293516:4108
581: SKP: 8192( 2 blks) ==> 683297624:8204
582: RAW: 4096( 1 blks) ==> 683297636:4108
583: SKP: 4096( 1 blks) ==> 683301744:4108
584: RAW: 4096( 1 blks) ==> 683301756:4108
585: SKP: 4096( 1 blks) ==> 683305864:4108
586: RAW: 16384( 4 blks) ==> 683305876:16396
587: SKP: 4096( 1 blks) ==> 683322272:4108
588: RAW: 4096( 1 blks) ==> 683322284:4108
589: SKP: 4096( 1 blks) ==> 683326392:4108
590: RAW: 4096( 1 blks) ==> 683326404:4108
591: SKP: 8192( 2 blks) ==> 683330512:8204
592: RAW: 12288( 3 blks) ==> 683330524:12300
593: SKP: 4096( 1 blks) ==> 683342824:4108
594: RAW: 4096( 1 blks) ==> 683342836:4108
595: SKP: 4096( 1 blks) ==> 683346944:4108
596: RAW: 4096( 1 blks) ==> 683346956:4108
597: SKP: 8192( 2 blks) ==> 683351064:8204
598: RAW: 4096( 1 blks) ==> 683351076:4108
599: SKP: 4096( 1 blks) ==> 683355184:4108
600: RAW: 4096( 1 blks) ==> 683355196:4108
601: SKP: 4096( 1 blks) ==> 683359304:4108
602: RAW: 16384( 4 blks) ==> 683359316:16396
603: SKP: 4096( 1 blks) ==> 683375712:4108
604: RAW: 4096( 1 blks) ==> 683375724:4108
605: SKP: 4096( 1 blks) ==> 683379832:4108
606: RAW: 4096( 1 blks) ==> 683379844:4108
607: SKP: 4096( 1 blks) ==> 683383952:4108
608: RAW: 16384( 4 blks) ==> 683383964:16396
609: SKP: 4096( 1 blks) ==> 683400360:4108
610: RAW: 4096( 1 blks) ==> 683400372:4108
611: SKP: 4096( 1 blks) ==> 683404480:4108
612: RAW: 4096( 1 blks) ==> 683404492:4108
613: SKP: 8192( 2 blks) ==> 683408600:8204
614: RAW: 12288( 3 blks) ==> 683408612:12300
615: SKP: 4096( 1 blks) ==> 683420912:4108
616: RAW: 4096( 1 blks) ==> 683420924:4108
617: SKP: 4096( 1 blks) ==> 683425032:4108
618: RAW: 4096( 1 blks) ==> 683425044:4108
619: SKP: 8192( 2 blks) ==> 683429152:8204
620: RAW: 4096( 1 blks) ==> 683429164:4108
621: SKP: 4096( 1 blks) ==> 683433272:4108
622: RAW: 4096( 1 blks) ==> 683433284:4108
623: SKP: 4096( 1 blks) ==> 683437392:4108
624: RAW: 12288( 3 blks) ==> 683437404:12300
625: SKP: 8192( 2 blks) ==> 683449704:8204
626: RAW: 4096( 1 blks) ==> 683449716:4108
627: SKP: 4096( 1 blks) ==> 683453824:4108
628: RAW: 4096( 1 blks) ==> 683453836:4108
629: SKP: 4096( 1 blks) ==> 683457944:4108
630: RAW: 16384( 4 blks) ==> 683457956:16396
631: SKP: 4096( 1 blks) ==> 683474352:4108
632: RAW: 4096( 1 blks) ==> 683474364:4108
633: SKP: 4096( 1 blks) ==> 683478472:4108
634: RAW: 4096( 1 blks) ==> 683478484:4108
635: SKP: 8192( 2 blks) ==> 683482592:8204
636: RAW: 12288( 3 blks) ==> 683482604:12300
637: SKP: 4096( 1 blks) ==> 683494904:4108
638: RAW: 4096( 1 blks) ==> 683494916:4108
639: SKP: 4096( 1 blks) ==> 683499024:4108
640: RAW: 4096( 1 blks) ==> 683499036:4108
641: SKP: 8192( 2 blks) ==> 683503144:8204
642: RAW: 12288( 3 blks) ==> 683503156:12300
643: SKP: 4096( 1 blks) ==> 683515456:4108
644: RAW: 4096( 1 blks) ==> 683515468:4108
645: SKP: 4096( 1 blks) ==> 683519576:4108
646: RAW: 4096( 1 blks) ==> 683519588:4108
647: SKP: 8192( 2 blks) ==> 683523696:8204
648: RAW: 4096( 1 blks) ==> 683523708:4108
649: SKP: 4096( 1 blks) ==> 683527816:4108
650: RAW: 4096( 1 blks) ==> 683527828:4108
651: SKP: 4096( 1 blks) ==> 683531936:4108
652: RAW: 16384( 4 blks) ==> 683531948:16396
653: SKP: 4096( 1 blks) ==> 683548344:4108
654: RAW: 4096( 1 blks) ==> 683548356:4108
655: SKP: 4096( 1 blks) ==> 683552464:4108
656: RAW: 4096( 1 blks) ==> 683552476:4108
657: SKP: 4096( 1 blks) ==> 683556584:4108
658: RAW: 16384( 4 blks) ==> 683556596:16396
659: SKP: 4096( 1 blks) ==> 683572992:4108
660: RAW: 4096( 1 blks) ==> 683573004:4108
661: SKP: 4096( 1 blks) ==> 683577112:4108
662: RAW: 4096( 1 blks) ==> 683577124:4108
663: SKP: 8192( 2 blks) ==> 683581232:8204
664: RAW: 12288( 3 blks) ==> 683581244:12300
665: SKP: 4096( 1 blks) ==> 683593544:4108
666: RAW: 4096( 1 blks) ==> 683593556:4108
667: SKP: 4096( 1 blks) ==> 683597664:4108
668: RAW: 4096( 1 blks) ==> 683597676:4108
669: SKP: 8192( 2 blks) ==> 683601784:8204
670: RAW: 4096( 1 blks) ==> 683601796:4108
671: SKP: 4096( 1 blks) ==> 683605904:4108
672: RAW: 4096( 1 blks) ==> 683605916:4108
673: SKP: 4096( 1 blks) ==> 683610024:4108
674: RAW: 12288( 3 blks) ==> 683610036:12300
675: SKP: 8192( 2 blks) ==> 683622336:8204
676: RAW: 4096( 1 blks) ==> 683622348:4108
677: SKP: 4096( 1 blks) ==> 683626456:4108
678: RAW: 4096( 1 blks) ==> 683626468:4108
679: SKP: 4096( 1 blks) ==> 683630576:4108
680: RAW: 16384( 4 blks) ==> 683630588:16396
681: SKP: 4096( 1 blks) ==> 683646984:4108
682: RAW: 4096( 1 blks) ==> 683646996:4108
683: SKP: 4096( 1 blks) ==> 683651104:4108
684: RAW: 4096( 1 blks) ==> 683651116:4108
685: SKP: 8192( 2 blks) ==> 683655224:8204
686: RAW: 12288( 3 blks) ==> 683655236:12300
687: SKP: 4096( 1 blks) ==> 683667536:4108
688: RAW: 4096( 1 blks) ==> 683667548:4108
689: SKP: 4096( 1 blks) ==> 683671656:4108
690: RAW: 4096( 1 blks) ==> 683671668:4108
691: SKP: 8192( 2 blks) ==> 683675776:8204
692: RAW: 4096( 1 blks) ==> 683675788:4108
693: SKP: 4096( 1 blks) ==> 683679896:4108
694: RAW: 4096( 1 blks) ==> 683679908:4108
695: SKP: 4096( 1 blks) ==> 683684016:4108
696: RAW: 12288( 3 blks) ==> 683684028:12300
697: SKP: 8192( 2 blks) ==> 683696328:8204
698: RAW: 4096( 1 blks) ==> 683696340:4108
699: SKP: 4096( 1 blks) ==> 683700448:4108
700: RAW: 4096( 1 blks) ==> 683700460:4108
701: SKP: 4096( 1 blks) ==> 683704568:4108
702: RAW: 16384( 4 blks) ==> 683704580:16396
703: SKP: 4096( 1 blks) ==> 683720976:4108
704: RAW: 4096( 1 blks) ==> 683720988:4108
705: SKP: 4096( 1 blks) ==> 683725096:4108
706: RAW: 4096( 1 blks) ==> 683725108:4108
707: SKP: 8192( 2 blks) ==> 683729216:8204
708: RAW: 12288( 3 blks) ==> 683729228:12300
709: SKP: 4096( 1 blks) ==> 683741528:4108
710: RAW: 4096( 1 blks) ==> 683741540:4108
711: SKP: 4096( 1 blks) ==> 683745648:4108
712: RAW: 4096( 1 blks) ==> 683745660:4108
713: SKP: 8192( 2 blks) ==> 683749768:8204
714: RAW: 12288( 3 blks) ==> 683749780:12300
715: SKP: 4096( 1 blks) ==> 683762080:4108
716: RAW: 4096( 1 blks) ==> 683762092:4108
717: SKP: 4096( 1 blks) ==> 683766200:4108
718: RAW: 4096( 1 blks) ==> 683766212:4108
719: SKP: 8192( 2 blks) ==> 683770320:8204
720: RAW: 4096( 1 blks) ==> 683770332:4108
721: SKP: 4096( 1 blks) ==> 683774440:4108
722: RAW: 4096( 1 blks) ==> 683774452:4108
723: SKP: 4096( 1 blks) ==> 683778560:4108
724: RAW: 16384( 4 blks) ==> 683778572:16396
725: SKP: 4096( 1 blks) ==> 683794968:4108
726: RAW: 4096( 1 blks) ==> 683794980:4108
727: SKP: 4096( 1 blks) ==> 683799088:4108
728: RAW: 4096( 1 blks) ==> 683799100:4108
729: SKP: 4096( 1 blks) ==> 683803208:4108
730: RAW: 16384( 4 blks) ==> 683803220:16396
731: SKP: 4096( 1 blks) ==> 683819616:4108
732: RAW: 4096( 1 blks) ==> 683819628:4108
733: SKP: 4096( 1 blks) ==> 683823736:4108
734: RAW: 4096( 1 blks) ==> 683823748:4108
735: SKP: 8192( 2 blks) ==> 683827856:8204
736: RAW: 12288( 3 blks) ==> 683827868:12300
737: SKP: 4096( 1 blks) ==> 683840168:4108
738: RAW: 4096( 1 blks) ==> 683840180:4108
739: SKP: 4096( 1 blks) ==> 683844288:4108
740: RAW: 4096( 1 blks) ==> 683844300:4108
741: SKP: 8192( 2 blks) ==> 683848408:8204
742: RAW: 4096( 1 blks) ==> 683848420:4108
743: SKP: 4096( 1 blks) ==> 683852528:4108
744: RAW: 4096( 1 blks) ==> 683852540:4108
745: SKP: 4096( 1 blks) ==> 683856648:4108
746: RAW: 8192( 2 blks) ==> 683856660:8204
747: SKP: 12288( 3 blks) ==> 683864864:12300
748: RAW: 4096( 1 blks) ==> 683864876:4108
749: SKP: 12288( 3 blks) ==> 683868984:12300
750: RAW: 8192( 2 blks) ==> 683868996:8204
751: SKP: 12288( 3 blks) ==> 683877200:12300
752: RAW: 8192( 2 blks) ==> 683877212:8204
753: SKP: 12288( 3 blks) ==> 683885416:12300
754: RAW: 4096( 1 blks) ==> 683885428:4108
755: SKP: 12288( 3 blks) ==> 683889536:12300
756: RAW: 8192( 2 blks) ==> 683889548:8204
757: SKP: 12288( 3 blks) ==> 683897752:12300
758: RAW: 4096( 1 blks) ==> 683897764:4108
759: SKP: 12288( 3 blks) ==> 683901872:12300
760: RAW: 8192( 2 blks) ==> 683901884:8204
761: SKP: 12288( 3 blks) ==> 683910088:12300
762: RAW: 4096( 1 blks) ==> 683910100:4108
763: SKP: 12288( 3 blks) ==> 683914208:12300
764: RAW: 8192( 2 blks) ==> 683914220:8204
765: SKP: 12288( 3 blks) ==> 683922424:12300
766: RAW: 4096( 1 blks) ==> 683922436:4108
767: SKP: 12288( 3 blks) ==> 683926544:12300
768: RAW: 8192( 2 blks) ==> 683926556:8204
769: SKP: 12288( 3 blks) ==> 683934760:12300
770: RAW: 4096( 1 blks) ==> 683934772:4108
771: SKP: 12288( 3 blks) ==> 683938880:12300
772: RAW: 8192( 2 blks) ==> 683938892:8204
773: SKP: 12288( 3 blks) ==> 683947096:12300
774: RAW: 8192( 2 blks) ==> 683947108:8204
775: SKP: 8192( 2 blks) ==> 683955312:8204
776: RAW: 8192( 2 blks) ==> 683955324:8204
777: SKP: 12288( 3 blks) ==> 683963528:12300
778: RAW: 8192( 2 blks) ==> 683963540:8204
779: SKP: 12288( 3 blks) ==> 683971744:12300
780: RAW: 4096( 1 blks) ==> 683971756:4108
781: SKP: 12288( 3 blks) ==> 683975864:12300
782: RAW: 8192( 2 blks) ==> 683975876:8204
783: SKP: 12288( 3 blks) ==> 683984080:12300
784: RAW: 4096( 1 blks) ==> 683984092:4108
785: SKP: 12288( 3 blks) ==> 683988200:12300
786: RAW: 4096( 1 blks) ==> 683988212:4108
787: SKP: 4096( 1 blks) ==> 683992320:4108
788: RAW: 4096( 1 blks) ==> 683992332:4108
789: SKP: 12288( 3 blks) ==> 683996440:12300
790: RAW: 8192( 2 blks) ==> 683996452:8204
791: SKP: 12288( 3 blks) ==> 684004656:12300
792: RAW: 4096( 1 blks) ==> 684004668:4108
793: SKP: 12288( 3 blks) ==> 684008776:12300
794: RAW: 8192( 2 blks) ==> 684008788:8204
795: SKP: 12288( 3 blks) ==> 684016992:12300
796: RAW: 12288( 3 blks) ==> 684017004:12300
797: SKP: 12288( 3 blks) ==> 684029304:12300
798: RAW: 4096( 1 blks) ==> 684029316:4108
799: SKP: 12288( 3 blks) ==> 684033424:12300
800: RAW: 12288( 3 blks) ==> 684033436:12300
801: SKP: 12288( 3 blks) ==> 684045736:12300
802: RAW: 4096( 1 blks) ==> 684045748:4108
803: SKP: 12288( 3 blks) ==> 684049856:12300
804: RAW: 8192( 2 blks) ==> 684049868:8204
805: SKP: 12288( 3 blks) ==> 684058072:12300
806: RAW: 4096( 1 blks) ==> 684058084:4108
807: SKP: 12288( 3 blks) ==> 684062192:12300
808: RAW: 8192( 2 blks) ==> 684062204:8204
809: SKP: 12288( 3 blks) ==> 684070408:12300
810: RAW: 4096( 1 blks) ==> 684070420:4108
811: SKP: 12288( 3 blks) ==> 684074528:12300
812: RAW: 8192( 2 blks) ==> 684074540:8204
813: SKP: 12288( 3 blks) ==> 684082744:12300
814: RAW: 8192( 2 blks) ==> 684082756:8204
815: SKP: 12288( 3 blks) ==> 684090960:12300
816: RAW: 4096( 1 blks) ==> 684090972:4108
817: SKP: 12288( 3 blks) ==> 684095080:12300
818: RAW: 8192( 2 blks) ==> 684095092:8204
819: SKP: 12288( 3 blks) ==> 684103296:12300
820: RAW: 8192( 2 blks) ==> 684103308:8204
821: SKP: 12288( 3 blks) ==> 684111512:12300
822: RAW: 4096( 1 blks) ==> 684111524:4108
823: SKP: 12288( 3 blks) ==> 684115632:12300
824: RAW: 8192( 2 blks) ==> 684115644:8204
825: SKP: 12288( 3 blks) ==> 684123848:12300
826: RAW: 4096( 1 blks) ==> 684123860:4108
827: SKP: 12288( 3 blks) ==> 684127968:12300
828: RAW: 8192( 2 blks) ==> 684127980:8204
829: SKP: 12288( 3 blks) ==> 684136184:12300
830: RAW: 8192( 2 blks) ==> 684136196:8204
831: SKP: 8192( 2 blks) ==> 684144400:8204
832: RAW: 8192( 2 blks) ==> 684144412:8204
833: SKP: 12288( 3 blks) ==> 684152616:12300
834: RAW: 8192( 2 blks) ==> 684152628:8204
835: SKP: 12288( 3 blks) ==> 684160832:12300
836: RAW: 4096( 1 blks) ==> 684160844:4108
837: SKP: 12288( 3 blks) ==> 684164952:12300
838: RAW: 8192( 2 blks) ==> 684164964:8204
839: SKP: 12288( 3 blks) ==> 684173168:12300
840: RAW: 8192( 2 blks) ==> 684173180:8204
841: SKP: 12288( 3 blks) ==> 684181384:12300
842: RAW: 4096( 1 blks) ==> 684181396:4108
843: SKP: 12288( 3 blks) ==> 684185504:12300
844: RAW: 8192( 2 blks) ==> 684185516:8204
845: SKP: 12288( 3 blks) ==> 684193720:12300
846: RAW: 8192( 2 blks) ==> 684193732:8204
847: SKP: 12288( 3 blks) ==> 684201936:12300
848: RAW: 4096( 1 blks) ==> 684201948:4108
849: SKP: 12288( 3 blks) ==> 684206056:12300
850: RAW: 8192( 2 blks) ==> 684206068:8204
851: SKP: 12288( 3 blks) ==> 684214272:12300
852: RAW: 4096( 1 blks) ==> 684214284:4108
853: SKP: 12288( 3 blks) ==> 684218392:12300
854: RAW: 8192( 2 blks) ==> 684218404:8204
855: SKP: 12288( 3 blks) ==> 684226608:12300
856: RAW: 8192( 2 blks) ==> 684226620:8204
857: SKP: 12288( 3 blks) ==> 684234824:12300
858: RAW: 4096( 1 blks) ==> 684234836:4108
859: SKP: 12288( 3 blks) ==> 684238944:12300
860: RAW: 8192( 2 blks) ==> 684238956:8204
861: SKP: 12288( 3 blks) ==> 684247160:12300
862: RAW: 8192( 2 blks) ==> 684247172:8204
863: SKP: 12288( 3 blks) ==> 684255376:12300
864: RAW: 4096( 1 blks) ==> 684255388:4108
865: SKP: 12288( 3 blks) ==> 684259496:12300
866: RAW: 8192( 2 blks) ==> 684259508:8204
867: SKP: 12288( 3 blks) ==> 684267712:12300
868: RAW: 8192( 2 blks) ==> 684267724:8204
869: SKP: 8192( 2 blks) ==> 684275928:8204
870: RAW: 8192( 2 blks) ==> 684275940:8204
871: SKP: 12288( 3 blks) ==> 684284144:12300
872: RAW: 8192( 2 blks) ==> 684284156:8204
873: SKP: 12288( 3 blks) ==> 684292360:12300
874: RAW: 8192( 2 blks) ==> 684292372:8204
875: SKP: 12288( 3 blks) ==> 684300576:12300
876: RAW: 4096( 1 blks) ==> 684300588:4108
877: SKP: 12288( 3 blks) ==> 684304696:12300
878: RAW: 8192( 2 blks) ==> 684304708:8204
879: SKP: 12288( 3 blks) ==> 684312912:12300
880: RAW: 4096( 1 blks) ==> 684312924:4108
881: SKP: 12288( 3 blks) ==> 684317032:12300
882: RAW: 8192( 2 blks) ==> 684317044:8204
883: SKP: 12288( 3 blks) ==> 684325248:12300
884: RAW: 8192( 2 blks) ==> 684325260:8204
885: SKP: 8192( 2 blks) ==> 684333464:8204
886: RAW: 8192( 2 blks) ==> 684333476:8204
887: SKP: 12288( 3 blks) ==> 684341680:12300
888: RAW: 20480( 5 blks) ==> 684341692:20492
889: SKP: 12288( 3 blks) ==> 684362184:12300
890: RAW: 8192( 2 blks) ==> 684362196:8204
891: SKP: 12288( 3 blks) ==> 684370400:12300
892: RAW: 4096( 1 blks) ==> 684370412:4108
893: SKP: 12288( 3 blks) ==> 684374520:12300
894: RAW: 8192( 2 blks) ==> 684374532:8204
895: SKP: 12288( 3 blks) ==> 684382736:12300
896: RAW: 8192( 2 blks) ==> 684382748:8204
897: SKP: 12288( 3 blks) ==> 684390952:12300
898: RAW: 4096( 1 blks) ==> 684390964:4108
899: SKP: 12288( 3 blks) ==> 684395072:12300
900: RAW: 8192( 2 blks) ==> 684395084:8204
901: SKP: 12288( 3 blks) ==> 684403288:12300
902: RAW: 4096( 1 blks) ==> 684403300:4108
903: SKP: 12288( 3 blks) ==> 684407408:12300
904: RAW: 8192( 2 blks) ==> 684407420:8204
905: SKP: 12288( 3 blks) ==> 684415624:12300
906: RAW: 40960( 10 blks) ==> 684415636:40972
907: SKP: 12288( 3 blks) ==> 684456608:12300
908: RAW: 8192( 2 blks) ==> 684456620:8204
909: SKP: 12288( 3 blks) ==> 684464824:12300
910: RAW: 4096( 1 blks) ==> 684464836:4108
911: SKP: 12288( 3 blks) ==> 684468944:12300
912: RAW: 8192( 2 blks) ==> 684468956:8204
913: SKP: 12288( 3 blks) ==> 684477160:12300
914: RAW: 8192( 2 blks) ==> 684477172:8204
915: SKP: 12288( 3 blks) ==> 684485376:12300
916: RAW: 8192( 2 blks) ==> 684485388:8204
917: SKP: 12288( 3 blks) ==> 684493592:12300
918: RAW: 8192( 2 blks) ==> 684493604:8204
919: SKP: 12288( 3 blks) ==> 684501808:12300
920: RAW: 12288( 3 blks) ==> 684501820:12300
921: SKP: 12288( 3 blks) ==> 684514120:12300
922: RAW: 4096( 1 blks) ==> 684514132:4108
923: SKP: 12288( 3 blks) ==> 684518240:12300
924: RAW: 8192( 2 blks) ==> 684518252:8204
925: SKP: 12288( 3 blks) ==> 684526456:12300
926: RAW: 4096( 1 blks) ==> 684526468:4108
927: SKP: 12288( 3 blks) ==> 684530576:12300
928: RAW: 8192( 2 blks) ==> 684530588:8204
929: SKP: 12288( 3 blks) ==> 684538792:12300
930: RAW: 4096( 1 blks) ==> 684538804:4108
931: SKP: 12288( 3 blks) ==> 684542912:12300
932: RAW: 8192( 2 blks) ==> 684542924:8204
933: SKP: 12288( 3 blks) ==> 684551128:12300
934: RAW: 8192( 2 blks) ==> 684551140:8204
935: SKP: 12288( 3 blks) ==> 684559344:12300
936: RAW: 8192( 2 blks) ==> 684559356:8204
937: SKP: 12288( 3 blks) ==> 684567560:12300
938: RAW: 4096( 1 blks) ==> 684567572:4108
939: SKP: 12288( 3 blks) ==> 684571680:12300
940: RAW: 8192( 2 blks) ==> 684571692:8204
941: SKP: 12288( 3 blks) ==> 684579896:12300
942: RAW: 8192( 2 blks) ==> 684579908:8204
943: SKP: 1568768( 383 blks) ==> 684588112:1568780
944: RAW: 4096( 1 blks) ==> 684588124:4108
945: SKP: 12288( 3 blks) ==> 684592232:12300
946: RAW: 8192( 2 blks) ==> 684592244:8204
947: SKP: 1568768( 383 blks) ==> 684600448:1568780
948: RAW: 4096( 1 blks) ==> 684600460:4108
949: SKP: 12288( 3 blks) ==> 684604568:12300
950: RAW: 12288( 3 blks) ==> 684604580:12300
951: SKP: 4096( 1 blks) ==> 684616880:4108
952: RAW: 5775360( 1410 blks) ==> 684616892:5775372
953: SKP: 16384( 4 blks) ==> 690392264:16396
954: RAW: 8192( 2 blks) ==> 690392276:8204
955: SKP: 16384( 4 blks) ==> 690400480:16396
956: RAW: 32768( 8 blks) ==> 690400492:32780
957: SKP: 4096( 1 blks) ==> 690433272:4108
958: RAW: 4096( 1 blks) ==> 690433284:4108
959: SKP: 12288( 3 blks) ==> 690437392:12300
960: RAW: 8192( 2 blks) ==> 690437404:8204
961: SKP: 12288( 3 blks) ==> 690445608:12300
962: RAW: 8192( 2 blks) ==> 690445620:8204
963: SKP: 8192( 2 blks) ==> 690453824:8204
964: RAW: 28672( 7 blks) ==> 690453836:28684
965: SKP: 4096( 1 blks) ==> 690482520:4108
966: RAW: 4096( 1 blks) ==> 690482532:4108
967: SKP: 12288( 3 blks) ==> 690486640:12300
968: RAW: 8192( 2 blks) ==> 690486652:8204
969: SKP: 12288( 3 blks) ==> 690494856:12300
970: RAW: 32768( 8 blks) ==> 690494868:32780
971: SKP: 12288( 3 blks) ==> 690527648:12300
972: RAW: 8192( 2 blks) ==> 690527660:8204
973: SKP: 12288( 3 blks) ==> 690535864:12300
974: RAW: 4096( 1 blks) ==> 690535876:4108
975: SKP: 12288( 3 blks) ==> 690539984:12300
976: RAW: 8192( 2 blks) ==> 690539996:8204
977: SKP: 12288( 3 blks) ==> 690548200:12300
978: RAW: 8192( 2 blks) ==> 690548212:8204
979: SKP: 12288( 3 blks) ==> 690556416:12300
980: RAW: 4096( 1 blks) ==> 690556428:4108
981: SKP: 12288( 3 blks) ==> 690560536:12300
982: RAW: 8192( 2 blks) ==> 690560548:8204
983: SKP: 12288( 3 blks) ==> 690568752:12300
984: RAW: 8192( 2 blks) ==> 690568764:8204
985: SKP: 12288( 3 blks) ==> 690576968:12300
986: RAW: 4096( 1 blks) ==> 690576980:4108
987: SKP: 12288( 3 blks) ==> 690581088:12300
988: RAW: 8192( 2 blks) ==> 690581100:8204
989: SKP: 12288( 3 blks) ==> 690589304:12300
990: RAW: 8192( 2 blks) ==> 690589316:8204
991: SKP: 12288( 3 blks) ==> 690597520:12300
992: RAW: 4096( 1 blks) ==> 690597532:4108
993: SKP: 12288( 3 blks) ==> 690601640:12300
994: RAW: 8192( 2 blks) ==> 690601652:8204
995: SKP: 12288( 3 blks) ==> 690609856:12300
996: RAW: 8192( 2 blks) ==> 690609868:8204
997: SKP: 12288( 3 blks) ==> 690618072:12300
998: RAW: 4096( 1 blks) ==> 690618084:4108
999: SKP: 12288( 3 blks) ==> 690622192:12300
1000: RAW: 8192( 2 blks) ==> 690622204:8204
1001: SKP: 12288( 3 blks) ==> 690630408:12300
1002: RAW: 4096( 1 blks) ==> 690630420:4108
1003: SKP: 12288( 3 blks) ==> 690634528:12300
1004: RAW: 8192( 2 blks) ==> 690634540:8204
1005: SKP: 12288( 3 blks) ==> 690642744:12300
1006: RAW: 4096( 1 blks) ==> 690642756:4108
1007: SKP: 12288( 3 blks) ==> 690646864:12300
1008: RAW: 8192( 2 blks) ==> 690646876:8204
1009: SKP: 12288( 3 blks) ==> 690655080:12300
1010: RAW: 4096( 1 blks) ==> 690655092:4108
1011: SKP: 12288( 3 blks) ==> 690659200:12300
1012: RAW: 8192( 2 blks) ==> 690659212:8204
1013: SKP: 12288( 3 blks) ==> 690667416:12300
1014: RAW: 8192( 2 blks) ==> 690667428:8204
1015: SKP: 8192( 2 blks) ==> 690675632:8204
1016: RAW: 8192( 2 blks) ==> 690675644:8204
1017: SKP: 4096( 1 blks) ==> 690683848:4108
1018: RAW: 4096( 1 blks) ==> 690683860:4108
1019: SKP: 16384( 4 blks) ==> 690687968:16396
1020: RAW: 16384( 4 blks) ==> 690687980:16396
1021: SKP: 12288( 3 blks) ==> 690704376:12300
1022: RAW: 8192( 2 blks) ==> 690704388:8204
1023: SKP: 4096( 1 blks) ==> 690712592:4108
1024: RAW: 8192( 2 blks) ==> 690712604:8204
1025: SKP: 12288( 3 blks) ==> 690720808:12300
1026: RAW: 12288( 3 blks) ==> 690720820:12300
1027: SKP: 12288( 3 blks) ==> 690733120:12300
1028: RAW: 8192( 2 blks) ==> 690733132:8204
1029: SKP: 12288( 3 blks) ==> 690741336:12300
1030: RAW: 8192( 2 blks) ==> 690741348:8204
1031: SKP: 12288( 3 blks) ==> 690749552:12300
1032: RAW: 8192
Looks like the log truncated during post to the forum (post length was probably at max). The point at which it truncated it was still compressing the raw image into a sparse image. Would you post an excerpt of the log via:
cat flash_log.txt | gawk '/CHUNK/,/Writing partition TBC/' | sed 's/\r.*100[%]/SNIP/'
What this does is show the portion of the log at the end of creating sparse image and beyond, and cut out the long progress line (replacing it with “SNIP”). The “\r” is used because the flash.sh script has a windows style end of line on just that part of the script and can be used to mark the beginning of that progress line, while “100[%]” is the end of that progress line. Without this the progress line itself can be enormous. The part of the flash which is interesting really starts when something is written to the Jetson (we already know the image is created, the question is how it writes).
You were right, the log got truncated during posting. Sorry!
I have placed the output on our web server, you can access it at the following address:
http://www.zemris.fer.hr/~ssegvic/flash_log.txt
The output of your command is pasted below:
2526 CHUNK 15288238080(3732480 blks) ==> 3358443140(819925 blks)
done.
system.img built successfully.
Existing tbcfile(/home/luce/Downloads/L4T/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
copying cfgfile(/home/luce/Downloads/L4T/Linux_for_Tegra/bootloader/t210ref/cfg/gnu_linux_tegraboot_emmc_full.xml) to flash.xml… done.
creating gpt(ppt.img)…
*** GPT Parameters ***
device size -------------- 31276924928
bootpart size ------------ 8388608
userpart size ------------ 31268536320
Erase Block Size --------- 2097152
sector size -------------- 4096
Partition Config file ---- flash.xml
Visible partition flag — GP1
Primary GPT output ------- PPT->ppt.img
Secondary GPT output ----- GPT->gpt.img
Target device name ------- none
*** PARTITION LAYOUT(23 partitions) ***
[ BCT] BH 0 8191 4.0MiB
[ NVC] BH 8192 16383 4.0MiB nvtboot.bin
[ PPT] UH 0 4095 2.0MiB
[ GP1] UH 4096 8191 2.0MiB
[ APP] UH 8192 29868031 14580.0MiB system.img
[ TBC] UV 29868032 29872127 2.0MiB nvtboot_cpu.bin
[ EBT] UV 29872128 29880319 4.0MiB u-boot-dtb.bin
[ BPF] UV 29880320 29884415 2.0MiB bpmp.bin
[ WB0] UV 29884416 29896703 6.0MiB warmboot.bin
[ RP1] UV 29896704 29904895 4.0MiB tegra210-jetson-tx1-p2597-2180-a01-devkit.dtb
[ TOS] UV 29904896 29917183 6.0MiB tos.img
[ EKS] UV 29917184 29921279 2.0MiB
[ FX] UV 29921280 29925375 2.0MiB
[ SOS] UV 29925376 29966335 20.0MiB
[ EXI] UV 29966336 30097407 64.0MiB
[ LNX] UV 30097408 30228479 64.0MiB
[ DTB] UV 30228480 30236671 4.0MiB tegra210-jetson-tx1-p2597-2180-a01-devkit.dtb
[ NXT] UV 30236672 30240767 2.0MiB
[ MXB] UV 30240768 30253055 6.0MiB
[ MXP] UV 30253056 30265343 6.0MiB
[ USP] UV 30265344 30269439 2.0MiB
[ UDA] UV 30269440 61067263 15038.0MiB
[ GPT] UH 61067264 61071359 2.0MiB
copying flasher(/home/luce/Downloads/L4T/Linux_for_Tegra/bootloader/t210ref/cboot.bin)… done.
Existing flashapp(/home/luce/Downloads/L4T/Linux_for_Tegra/bootloader/tegraflash.py) reused.
*** Flashing target device started. ***
./tegraflash.py --bl cboot.bin --bct P2180_A00_LP4_DSC_204Mhz.cfg --odmdata 0x84000 --bldtb tegra210-jetson-tx1-p2597-2180-a01-devkit.dtb --applet nvtboot_recovery.bin --boardconfig board_config_p2597-devkit.xml --cmd “flash;reboot” --cfg flash.xml --chip 0x21
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0000 ] Generating RCM messages
[ 0.1524 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 --download rcm nvtboot_recovery.bin 0 0
[ 0.1533 ] RCM 0 is saved as rcm_0.rcm
[ 0.1998 ] RCM 1 is saved as rcm_1.rcm
[ 0.1998 ] List of rcm files are saved in rcm_list.xml
[ 0.1998 ]
[ 0.1998 ] Signing RCM messages
[ 0.2252 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.2261 ] Assuming zero filled SBK key
[ 0.2340 ]
[ 0.2341 ] Copying signature to RCM mesages
[ 0.2350 ] tegrarcm --chip 0x21 --updatesig rcm_list_signed.xml
[ 0.2364 ]
[ 0.2364 ] Parsing partition layout
[ 0.2553 ] tegraparser --pt flash.xml
[ 0.2572 ]
[ 0.2572 ] Creating list of images to be signed
[ 0.2686 ] tegrahost --chip 0x21 --partitionlayout flash.bin --list images_list.xml
[ 0.3207 ]
[ 0.3207 ] Generating signatures
[ 0.3217 ] tegrasign --key None --list images_list.xml --pubkeyhash pub_key.key
[ 0.3227 ] Assuming zero filled SBK key
[ 0.3713 ]
[ 0.4007 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.cfg --chip 0x21
[ 0.4018 ] Copying Sdram info from 0 to 1 set
[ 0.4192 ] Copying Sdram info from 1 to 2 set
[ 0.4192 ] Copying Sdram info from 2 to 3 set
[ 0.4192 ]
[ 0.4192 ] Updating boot device parameters
[ 0.4211 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --updatedevparam flash.bin
[ 0.4232 ] Warning: No sdram params
[ 0.4239 ]
[ 0.4239 ] Updating bl info
[ 0.4260 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --updateblinfo flash.bin --updatesig images_list_signed.xml
[ 0.4293 ]
[ 0.4293 ] Updating secondary storage information into bct
[ 0.4313 ] tegraparser --pt flash.bin --chip 0x21 --updatecustinfo P2180_A00_LP4_DSC_204Mhz.bct
[ 0.4335 ]
[ 0.4335 ] Updating board information from board config into bct
[ 0.4353 ] tegraparser --boardconfig board_config_p2597-devkit.xml --chip 0x21 --updatecustinfo P2180_A00_LP4_DSC_204Mhz.bct
[ 0.4381 ]
[ 0.4381 ] Updating Odmdata
[ 0.4397 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --updatefields Odmdata = 0x84000
[ 0.4413 ] Warning: No sdram params
[ 0.4417 ]
[ 0.4418 ] Get Signed section bct
[ 0.4434 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --listbct bct_list.xml
[ 0.4452 ]
[ 0.4453 ] Signing BCT
[ 0.4471 ] tegrasign --key None --list bct_list.xml --pubkeyhash pub_key.key
[ 0.4490 ] Assuming zero filled SBK key
[ 0.4504 ]
[ 0.4505 ] Updating BCT with signature
[ 0.4525 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --updatesig bct_list_signed.xml
[ 0.4544 ]
[ 0.4545 ] Copying signatures
[ 0.4559 ] tegrahost --chip 0x21 --partitionlayout flash.bin --updatesig images_list_signed.xml
[ 0.4572 ] Run tegrabct to update tboot signature in bct
[ 0.4601 ]
[ 0.4601 ] Updating BFS information
[ 0.4615 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --updatebfsinfo flash.bin
[ 0.4631 ]
[ 0.4631 ] Boot Rom communication
[ 0.4648 ] tegrarcm --chip 0x21 --rcm rcm_list_signed.xml
[ 0.4666 ] BR_CID: 0x32101001640d06c82400000008ff8280
[ 0.5490 ] RCM version 0X210001
[ 0.5494 ] Boot Rom communication completed
[ 1.5561 ]
[ 1.5561 ] Sending BCTs
[ 1.5585 ] tegrarcm --download bct P2180_A00_LP4_DSC_204Mhz.bct
[ 1.5608 ] Applet version 00.01.0000
[ 1.5632 ] Sending bct
[ 1.5635 ] […] 100%
[ 1.7222 ]
[ 1.7223 ] Sending bootloader and pre-requisite binaries
[ 1.7233 ] tegrarcm --download ebt cboot.bin 0 0 --download rp1 tegra210-jetson-tx1-p2597-2180-a01-devkit.dtb 0
[ 1.7254 ] Applet version 00.01.0000
[ 1.7284 ] Sending ebt
[ 1.7288 ] […] 100%
[ 1.8195 ] Sending rp1
[ 1.8406 ] […] 100%
[ 1.9114 ]
[ 1.9115 ] Retrieving storage infomation
[ 1.9132 ] tegrarcm --oem platformdetails storage storage_info.bin
[ 1.9148 ] Applet version 00.01.0000
[ 1.9169 ] Saved platform info in storage_info.bin
[ 1.9746 ]
[ 1.9764 ] tegrarcm --boot recovery
[ 1.9786 ] Applet version 00.01.0000
It looks like it partially works. ebt and rp1 are successfully sent, so up until that point you can be sure that at least the Jetson is in recovery mode and that it was able to receive and write data. I’m not sure where storage_info.bin is; this could be on the Jetson’s eMMC (I don’t see it on any of my host’s flashes’ after using them…I have R19.2 through R24.2 and “locate” does not show this anywhere on the host at all…seems it must be a file on eMMC).
Then things halt. If you were using a VM I’d suspect this (they’ve been known to suddenly fail like this by halting USB in the middle of doing something), but since you are not, I have to conclude that wherever the storage_info.bin is the memory never completes write. This is probably a hardware failure for RMA.
If you go to this URL there is info on RMA near the top:
https://devtalk.nvidia.com/default/topic/793798/embedded-systems/some-jetson-web-links/
