Jetson was wired with the router and my laptop was connected to router via wireless because it does not have network ethernet port.
lsusb -t does not show anything.
I connect my monitor from DVI port ( I also tried HDMI one but the same the keyboard and mouse does not work).
The output of logfile:
ubuntu@tegra-ubuntu:/var/log$ cat Xorg.0.log
[ 37.453]
X.Org X Server 1.18.3
Release Date: 2016-04-04
[ 37.453] X Protocol Version 11, Revision 0
[ 37.453] Build Operating System: Linux 3.13.0-85-generic aarch64 Ubuntu
[ 37.453] Current Operating System: Linux tegra-ubuntu 4.4.38-tegra #1 SMP PREEMPT Thu Jul 20 00:49:07 PDT 2017 aarch64
[ 37.453] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x03100000 nvdumper_reserved=0x2772e0000 gpt tegraid=18.1.2.0.0 tegra_keep_boot_clocks maxcpus=6 androidboot.serialno=0322417005970 bl_prof_dataptr=0x10000@0x277240000 sdhci_tegra.en_boot_part_access=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4
[ 37.453] Build Date: 18 May 2016 01:12:13AM
[ 37.453] xorg-server 2:1.18.3-1ubuntu2.2 (For technical support please see http://www.ubuntu.com/support)
[ 37.453] Current version of pixman: 0.33.6
[ 37.453] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 37.453] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 37.453] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Aug 29 02:10:23 2017
[ 37.453] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 37.454] (==) No Layout section. Using the first Screen section.
[ 37.454] (==) No screen section available. Using defaults.
[ 37.454] (**) |-->Screen "Default Screen Section" (0)
[ 37.454] (**) | |-->Monitor "<default monitor>"
[ 37.454] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 37.454] (==) Automatically adding devices
[ 37.454] (==) Automatically enabling devices
[ 37.454] (==) Automatically adding GPU devices
[ 37.454] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 37.454] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 37.454] Entry deleted from font path.
[ 37.454] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 37.454] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 37.454] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[ 37.454] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 37.454] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 37.454] (==) ModulePath set to "/usr/lib/aarch64-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
[ 37.454] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 37.454] (II) Loader magic: 0x556f5a1d68
[ 37.454] (II) Module ABI versions:
[ 37.454] X.Org ANSI C Emulation: 0.4
[ 37.454] X.Org Video Driver: 20.0
[ 37.454] X.Org XInput driver : 22.1
[ 37.454] X.Org Server Extension : 9.0
[ 37.455] (++) using VT number 7
[ 37.455] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 37.455] (II) no primary bus or device found
[ 37.455] (II) LoadModule: "glx"
[ 37.455] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 37.457] (II) Module glx: vendor="X.Org Foundation"
[ 37.457] compiled for 1.18.3, module version = 1.0.0
[ 37.458] ABI class: X.Org Server Extension, version 9.0
[ 37.458] (==) AIGLX enabled
[ 37.458] (==) Matched modesetting as autoconfigured driver 0
[ 37.458] (==) Matched fbdev as autoconfigured driver 1
[ 37.458] (==) Assigned the driver to the xf86ConfigLayout
[ 37.458] (II) LoadModule: "modesetting"
[ 37.458] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 37.458] (II) Module modesetting: vendor="X.Org Foundation"
[ 37.458] compiled for 1.18.3, module version = 1.18.3
[ 37.458] Module class: X.Org Video Driver
[ 37.458] ABI class: X.Org Video Driver, version 20.0
[ 37.458] (II) LoadModule: "fbdev"
[ 37.458] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 37.458] (II) Module fbdev: vendor="X.Org Foundation"
[ 37.458] compiled for 1.18.1, module version = 0.4.4
[ 37.458] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 37.458] (II) FBDEV: driver for framebuffer: fbdev
[ 37.458] (WW) Falling back to old probe method for modesetting
[ 37.458] (EE) open /dev/dri/card0: No such file or directory
[ 37.458] (WW) Falling back to old probe method for fbdev
[ 37.459] (II) Loading sub module "fbdevhw"
[ 37.459] (II) LoadModule: "fbdevhw"
[ 37.459] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 37.459] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 37.459] compiled for 1.18.3, module version = 0.0.2
[ 37.459] ABI class: X.Org Video Driver, version 20.0
[ 37.459] (II) FBDEV(0): using default device
[ 37.459] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 37.459] (II) FBDEV(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 37.459] (==) FBDEV(0): Depth 24, (==) framebuffer bpp 32
[ 37.459] (==) FBDEV(0): RGB weight 888
[ 37.459] (==) FBDEV(0): Default visual is TrueColor
[ 37.459] (==) FBDEV(0): Using gamma correction (1.0, 1.0, 1.0)
[ 37.459] (II) FBDEV(0): hardware: tegra_fb (video memory: 73728kB)
[ 37.459] (II) FBDEV(0): checking modes against framebuffer device...
[ 37.459] (II) FBDEV(0): checking modes against monitor...
[ 37.459] (--) FBDEV(0): Virtual size is 1680x1050 (pitch 1680)
[ 37.459] (**) FBDEV(0): Built-in mode "current": 119.0 MHz, 64.7 kHz, 59.9 Hz
[ 37.459] (II) FBDEV(0): Modeline "current"x0.0 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync +vsync -csync (64.7 kHz b)
[ 37.459] (==) FBDEV(0): DPI set to (96, 96)
[ 37.459] (II) Loading sub module "fb"
[ 37.459] (II) LoadModule: "fb"
[ 37.459] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 37.459] (II) Module fb: vendor="X.Org Foundation"
[ 37.459] compiled for 1.18.3, module version = 1.0.0
[ 37.459] ABI class: X.Org ANSI C Emulation, version 0.4
[ 37.459] (**) FBDEV(0): using shadow framebuffer
[ 37.459] (II) Loading sub module "shadow"
[ 37.460] (II) LoadModule: "shadow"
[ 37.460] (II) Loading /usr/lib/xorg/modules/libshadow.so
[ 37.460] (II) Module shadow: vendor="X.Org Foundation"
[ 37.460] compiled for 1.18.3, module version = 1.1.0
[ 37.460] ABI class: X.Org ANSI C Emulation, version 0.4
[ 37.460] (II) UnloadModule: "modesetting"
[ 37.460] (II) Unloading modesetting
[ 37.460] (==) Depth 24 pixmap format is 32 bpp
[ 39.472] (==) FBDEV(0): Backing store enabled
[ 39.472] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
[ 39.473] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
[ 39.474] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
[ 39.475] (EE) FBDEV(0): FBIOPUTCMAP: Invalid argument
[ 39.475] (==) FBDEV(0): DPMS enabled
[ 39.475] (==) RandR enabled
[ 39.482] (II) SELinux: Disabled on system
[ 39.483] (II) AIGLX: Screen 0 is not DRI2 capable
[ 39.483] (EE) AIGLX: reverting to software rendering
[ 39.489] (II) AIGLX: enabled GLX_MESA_copy_sub_buffer
[ 39.489] (II) AIGLX: Loaded and initialized swrast
[ 39.489] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 39.544] (II) config/udev: Adding input device tegra-hda HDMI/DP,pcm=3 (/dev/input/event0)
[ 39.545] (II) No input driver specified, ignoring this device.
[ 39.545] (II) This device may have been added with another device file.
[ 39.545] (II) config/udev: Adding input device tegra-hda HDMI/DP,pcm=7 (/dev/input/event1)
[ 39.545] (II) config/udev: Adding input device gpio-keys (/dev/input/event3)
[ 39.545] (**) gpio-keys: Applying InputClass "evdev keyboard catchall"
[ 39.545] (II) LoadModule: "evdev"
[ 39.546] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 39.546] (II) Module evdev: vendor="X.Org Foundation"
[ 39.546] compiled for 1.18.1, module version = 2.10.1
[ 39.546] Module class: X.Org XInput Driver
[ 39.546] ABI class: X.Org XInput driver, version 22.1
[ 39.546] (II) Using input driver 'evdev' for 'gpio-keys'
[ 39.546] (**) gpio-keys: always reports core events
[ 39.546] (**) evdev: gpio-keys: Device: "/dev/input/event3"
[ 39.546] (--) evdev: gpio-keys: Vendor 0x1 Product 0x1
[ 39.546] (--) evdev: gpio-keys: Found keys
[ 39.546] (II) evdev: gpio-keys: Configuring as keyboard
[ 39.546] (**) Option "config_info" "udev:/sys/devices/gpio-keys/input/input3/event3"
[ 39.546] (II) XINPUT: Adding extended input device "gpio-keys" (type: KEYBOARD, id 6)
[ 39.546] (**) Option "xkb_rules" "evdev"
[ 39.546] (**) Option "xkb_model" "pc105"
[ 39.547] (**) Option "xkb_layout" "us"
[ 39.548] (II) config/udev: Adding input device tegra-snd-t186ref-mobile-rt565x Headphone Jack (/dev/input/event2)
[ 39.548] (**) tegra-snd-t186ref-mobile-rt565x Headphone Jack: Applying InputClass "evdev keyboard catchall"
[ 39.548] (II) Using input driver 'evdev' for 'tegra-snd-t186ref-mobile-rt565x Headphone Jack'
[ 39.548] (**) tegra-snd-t186ref-mobile-rt565x Headphone Jack: always reports core events
[ 39.548] (**) evdev: tegra-snd-t186ref-mobile-rt565x Headphone Jack: Device: "/dev/input/event2"
[ 39.548] (--) evdev: tegra-snd-t186ref-mobile-rt565x Headphone Jack: Vendor 0 Product 0
[ 39.548] (--) evdev: tegra-snd-t186ref-mobile-rt565x Headphone Jack: Found keys
[ 39.548] (II) evdev: tegra-snd-t186ref-mobile-rt565x Headphone Jack: Configuring as keyboard
[ 39.548] (**) Option "config_info" "udev:/sys/devices/sound/sound/card1/input2/event2"
[ 39.548] (II) XINPUT: Adding extended input device "tegra-snd-t186ref-mobile-rt565x Headphone Jack" (type: KEYBOARD, id 7)
[ 39.548] (**) Option "xkb_rules" "evdev"
[ 39.548] (**) Option "xkb_model" "pc105"
[ 39.548] (**) Option "xkb_layout" "us"
when I try a command with sudo using ssh I get this message:
sudo: /usr/bin/sudo must be owned by uid 0 and have the setuid bit set
Thank you
