I’m having a similar issue to the person in this post:
https://devtalk.nvidia.com/default/topic/1036953/jetson-tx2/jetson-tx2-screen-blank-after-i-changed-ip-address/2
I have 2 TX2 boards, one flashes fine, the other fails. Trying to manually flash, I get this:
sudo ./flash.sh jetson-tx2 mmcblk0p1
# L4T BSP Information:
# R32 (release), REVISION: 1.0, GCID: 14531094, BOARD: t186ref, EABI: aarch64,
# DATE: Wed Mar 13 07:41:08 UTC 2019
# Target Board Information:
# Name: jetson-tx2, Board Family: t186ref, SoC: Unknown,
# OpMode: pre-production, Boot Authentication: ,
Error: The Actual SoC ID(0x00) mismatches intended jetson-tx2 SoC ID(0x18).
Does this mean I have a faulty board, as suggested in the other thread? The board seems to work fine, except for this error when trying to flash.
Actually, I only get the above response after a failed flash attempt. After restart when I run flash.sh, I get this:
*** Flashing target device started. ***
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0704 ] tegrasign_v2 --key None --getmode mode.txt
[ 0.0795 ] Assuming zero filled SBK key
[ 0.1021 ]
[ 0.1022 ] Generating RCM messages
[ 0.1054 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 0 --download rcm mb1_recovery_prod.bin 0 0
[ 0.1110 ] RCM 0 is saved as rcm_0.rcm
[ 0.1132 ] RCM 1 is saved as rcm_1.rcm
[ 0.1142 ] List of rcm files are saved in rcm_list.xml
[ 0.1249 ]
[ 0.1250 ] Signing RCM messages
[ 0.1265 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.1276 ] Assuming zero filled SBK key
[ 0.1528 ]
[ 0.1529 ] Copying signature to RCM mesages
[ 0.1542 ] tegrarcm_v2 --chip 0x18 0 --updatesig rcm_list_signed.xml
[ 0.1648 ]
[ 0.1649 ] Parsing partition layout
[ 0.1729 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.1927 ]
[ 0.1928 ] Creating list of images to be signed
[ 0.1946 ] tegrahost_v2 --chip 0x18 0 --partitionlayout flash.xml.bin --list images_list.xml zerosbk
[ 0.2783 ]
[ 0.2784 ] Generating signatures
[ 0.2797 ] tegrasign_v2 --key None --list images_list.xml --pubkeyhash pub_key.key
[ 0.2850 ] Assuming zero filled SBK key
[ 0.8205 ]
[ 0.8207 ] Generating br-bct
[ 0.8224 ] Updating dev and MSS params in BR BCT
[ 0.8226 ] tegrabct_v2 --dev_param emmc.cfg --sdram P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --brbct br_bct.cfg --chip 0x18 0
[ 0.8843 ]
[ 0.8844 ] Updating bl info
[ 0.8856 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 0.8923 ]
[ 0.8923 ] Updating smd info
[ 0.8933 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 --updatesmdinfo flash.xml.bin
[ 0.9024 ]
[ 0.9025 ] Updating Odmdata
[ 0.9043 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --updatefields Odmdata =0x1090000
[ 0.9144 ]
[ 0.9145 ] Get Signed section of bct
[ 0.9168 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --listbct bct_list.xml
[ 0.9222 ]
[ 0.9234 ] tegrasign_v2 --key None --list bct_list.xml --pubkeyhash pub_key.key
[ 0.9244 ] Assuming zero filled SBK key
[ 0.9322 ]
[ 0.9323 ] Updating BCT with signature
[ 0.9333 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x18 0 --updatesig bct_list_signed.xml
[ 0.9564 ]
[ 0.9565 ] Generating coldboot mb1-bct
[ 0.9577 ] tegrabct_v2 --chip 0x18 0 --mb1bct mb1_cold_boot_bct.cfg --sdram P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --misc tegra186-mb1-bct-misc-si-l4t.cfg --scr mobile_scr.cfg --pinmux tegra186-mb1-bct-pinmux-quill-p3310-1000-a00.cfg --pmc tegra186-mb1-bct-pad-quill-p3310-1000-a00.cfg --pmic tegra186-mb1-bct-pmic-quill-p3310-1000-a00.cfg --brcommand tegra186-mb1-bct-bootrom-quill-p3310-1000-a00.cfg --prod tegra186-mb1-bct-prod-quill-p3310-1000-a00.cfg
[ 0.9588 ] MB1-BCT version: 0xf
[ 0.9596 ] Copying Sdram info from 2 to 3 set
[ 0.9748 ] Packing sdram param for instance[0]
[ 0.9758 ] Packing sdram param for instance[1]
[ 0.9771 ] Packing sdram param for instance[2]
[ 0.9826 ] Packing sdram param for instance[3]
[ 0.9833 ] Parsing config file :tegra186-mb1-bct-pinmux-quill-p3310-1000-a00.cfg
[ 0.9866 ] Appending platform config data of size :- 2952
[ 0.9888 ] Parsing config file :mobile_scr.cfg
[ 0.9899 ] Appending platform config data of size :- 12240
[ 0.9926 ] Parsing config file :tegra186-mb1-bct-pad-quill-p3310-1000-a00.cfg
[ 0.9947 ] Appending platform config data of size :- 24
[ 0.9964 ] Parsing config file :tegra186-mb1-bct-pmic-quill-p3310-1000-a00.cfg
[ 0.9979 ] Appending platform config data of size :- 468
[ 0.9980 ]
[ 0.9980 ] Parsing config file :tegra186-mb1-bct-bootrom-quill-p3310-1000-a00.cfg
[ 0.9981 ] Appending platform config data of size :- 64
[ 0.9981 ]
[ 0.9981 ] Parsing config file :tegra186-mb1-bct-prod-quill-p3310-1000-a00.cfg
[ 0.9982 ] Appending platform config data of size :- 1628
[ 0.9982 ]
[ 0.9983 ] Updating mb1-bct with firmware information
[ 0.9995 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 1.0007 ] MB1-BCT version: 0xf
[ 1.0081 ]
[ 1.0082 ] Updating mb1-bct with storage information
[ 1.0091 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_cold_boot_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 1.0103 ] MB1-BCT version: 0xf
[ 1.0182 ]
[ 1.0207 ] tegrahost_v2 --chip 0x18 --align mb1_cold_boot_bct_MB1.bct
[ 1.0281 ]
[ 1.0294 ] tegrahost_v2 --appendsigheader mb1_cold_boot_bct_MB1.bct zerosbk
[ 1.0361 ]
[ 1.0373 ] tegrasign_v2 --key None --list mb1_cold_boot_bct_MB1_sigheader.bct_list.xml
[ 1.0384 ] Assuming zero filled SBK key
[ 1.0441 ]
[ 1.0457 ] tegrahost_v2 --updatesigheader mb1_cold_boot_bct_MB1_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_sigheader.bct.hash zerosbk
[ 1.0561 ]
[ 1.0563 ] Generating recovery mb1-bct
[ 1.0582 ] tegrabct_v2 --chip 0x18 0 --mb1bct mb1_bct.cfg --sdram P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --misc tegra186-mb1-bct-misc-si-l4t.cfg --scr minimal_scr.cfg --pinmux tegra186-mb1-bct-pinmux-quill-p3310-1000-a00.cfg --pmc tegra186-mb1-bct-pad-quill-p3310-1000-a00.cfg --pmic tegra186-mb1-bct-pmic-quill-p3310-1000-a00.cfg --brcommand tegra186-mb1-bct-bootrom-quill-p3310-1000-a00.cfg --prod tegra186-mb1-bct-prod-quill-p3310-1000-a00.cfg
[ 1.0595 ] MB1-BCT version: 0xf
[ 1.0605 ] Copying Sdram info from 2 to 3 set
[ 1.0748 ] Packing sdram param for instance[0]
[ 1.0761 ] Packing sdram param for instance[1]
[ 1.0774 ] Packing sdram param for instance[2]
[ 1.0786 ] Packing sdram param for instance[3]
[ 1.0798 ] Parsing config file :tegra186-mb1-bct-pinmux-quill-p3310-1000-a00.cfg
[ 1.0852 ] Appending platform config data of size :- 2952
[ 1.0886 ] Parsing config file :minimal_scr.cfg
[ 1.0912 ] Appending platform config data of size :- 12240
[ 1.0913 ]
[ 1.0913 ] Parsing config file :tegra186-mb1-bct-pad-quill-p3310-1000-a00.cfg
[ 1.0914 ] Appending platform config data of size :- 24
[ 1.0914 ]
[ 1.0914 ] Parsing config file :tegra186-mb1-bct-pmic-quill-p3310-1000-a00.cfg
[ 1.0915 ] Appending platform config data of size :- 468
[ 1.0915 ]
[ 1.0915 ] Parsing config file :tegra186-mb1-bct-bootrom-quill-p3310-1000-a00.cfg
[ 1.0916 ] Appending platform config data of size :- 64
[ 1.0916 ]
[ 1.0916 ] Parsing config file :tegra186-mb1-bct-prod-quill-p3310-1000-a00.cfg
[ 1.0917 ] Appending platform config data of size :- 1628
[ 1.0917 ]
[ 1.0918 ] Updating mb1-bct with firmware information
[ 1.0937 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 1.0949 ] MB1-BCT version: 0xf
[ 1.0999 ]
[ 1.1000 ] Updating mb1-bct with storage information
[ 1.1010 ] tegrabct_v2 --chip 0x18 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 1.1021 ] MB1-BCT version: 0xf
[ 1.1088 ]
[ 1.1099 ] tegrahost_v2 --chip 0x18 --align mb1_bct_MB1.bct
[ 1.1216 ]
[ 1.1242 ] tegrahost_v2 --appendsigheader mb1_bct_MB1.bct zerosbk
[ 1.1289 ]
[ 1.1305 ] tegrasign_v2 --key None --list mb1_bct_MB1_sigheader.bct_list.xml
[ 1.1314 ] Assuming zero filled SBK key
[ 1.1368 ]
[ 1.1382 ] tegrahost_v2 --updatesigheader mb1_bct_MB1_sigheader.bct.encrypt mb1_bct_MB1_sigheader.bct.hash zerosbk
[ 1.1448 ]
[ 1.1450 ] Copying signatures
[ 1.1462 ] tegrahost_v2 --chip 0x18 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 1.1926 ]
[ 1.1927 ] Boot Rom communication
[ 1.1941 ] tegrarcm_v2 --chip 0x18 0 --rcm rcm_list_signed.xml
[ 1.1954 ] BootRom is not running
[ 6.3644 ]
[ 7.3706 ] tegrarcm_v2 --isapplet
[ 7.3754 ] Applet version 01.00.0000
[ 7.7403 ]
[ 7.7407 ] Sending BCTs
[ 7.7526 ] tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 7.7575 ] Applet version 01.00.0000
[ 7.9072 ] Sending bct_bootrom
[ 7.9086 ] [................................................] 100%
[ 7.9511 ] Sending bct_mb1
[ 7.9751 ] [................................................] 100%
[ 8.0762 ]
[ 8.0807 ] Generating blob
[ 8.0896 ] tegrahost_v2 --chip 0x18 --align blob_nvtboot_recovery_cpu.bin
[ 8.1002 ]
[ 8.1042 ] tegrahost_v2 --appendsigheader blob_nvtboot_recovery_cpu.bin zerosbk
[ 8.1277 ]
[ 8.1345 ] tegrasign_v2 --key None --list blob_nvtboot_recovery_cpu_sigheader.bin_list.xml
[ 8.1371 ] Assuming zero filled SBK key
[ 8.1568 ]
[ 8.1598 ] tegrahost_v2 --updatesigheader blob_nvtboot_recovery_cpu_sigheader.bin.encrypt blob_nvtboot_recovery_cpu_sigheader.bin.hash zerosbk
[ 8.1728 ]
[ 8.1743 ] tegrahost_v2 --chip 0x18 --align blob_nvtboot_recovery.bin
[ 8.1807 ]
[ 8.1817 ] tegrahost_v2 --appendsigheader blob_nvtboot_recovery.bin zerosbk
[ 8.1887 ]
[ 8.1900 ] tegrasign_v2 --key None --list blob_nvtboot_recovery_sigheader.bin_list.xml
[ 8.1911 ] Assuming zero filled SBK key
[ 8.2047 ]
[ 8.2067 ] tegrahost_v2 --updatesigheader blob_nvtboot_recovery_sigheader.bin.encrypt blob_nvtboot_recovery_sigheader.bin.hash zerosbk
[ 8.2126 ]
[ 8.2137 ] tegrahost_v2 --chip 0x18 --align blob_preboot_d15_prod_cr.bin
[ 8.2206 ]
[ 8.2216 ] tegrahost_v2 --appendsigheader blob_preboot_d15_prod_cr.bin zerosbk
[ 8.2286 ]
[ 8.2350 ] tegrasign_v2 --key None --list blob_preboot_d15_prod_cr_sigheader.bin_list.xml
[ 8.2367 ] Assuming zero filled SBK key
[ 8.2446 ]
[ 8.2461 ] tegrahost_v2 --updatesigheader blob_preboot_d15_prod_cr_sigheader.bin.encrypt blob_preboot_d15_prod_cr_sigheader.bin.hash zerosbk
[ 8.2526 ]
[ 8.2540 ] tegrahost_v2 --chip 0x18 --align blob_mce_mts_d15_prod_cr.bin
[ 8.2605 ]
[ 8.2614 ] tegrahost_v2 --appendsigheader blob_mce_mts_d15_prod_cr.bin zerosbk
[ 8.2766 ]
[ 8.2781 ] tegrasign_v2 --key None --list blob_mce_mts_d15_prod_cr_sigheader.bin_list.xml
[ 8.2791 ] Assuming zero filled SBK key
[ 8.3363 ]
[ 8.3378 ] tegrahost_v2 --updatesigheader blob_mce_mts_d15_prod_cr_sigheader.bin.encrypt blob_mce_mts_d15_prod_cr_sigheader.bin.hash zerosbk
[ 8.3479 ]
[ 8.3503 ] tegrahost_v2 --chip 0x18 --align blob_bpmp.bin
[ 8.3563 ]
[ 8.3573 ] tegrahost_v2 --appendsigheader blob_bpmp.bin zerosbk
[ 8.3665 ]
[ 8.3698 ] tegrasign_v2 --key None --list blob_bpmp_sigheader.bin_list.xml
[ 8.3711 ] Assuming zero filled SBK key
[ 8.3882 ]
[ 8.3897 ] tegrahost_v2 --updatesigheader blob_bpmp_sigheader.bin.encrypt blob_bpmp_sigheader.bin.hash zerosbk
[ 8.3961 ]
[ 8.3975 ] tegrahost_v2 --chip 0x18 --align blob_tegra186-a02-bpmp-quill-p3310-1000-a00-00-te770d-ucm2.dtb
[ 8.4082 ]
[ 8.4099 ] tegrahost_v2 --appendsigheader blob_tegra186-a02-bpmp-quill-p3310-1000-a00-00-te770d-ucm2.dtb zerosbk
[ 8.4161 ]
[ 8.4173 ] tegrasign_v2 --key None --list blob_tegra186-a02-bpmp-quill-p3310-1000-a00-00-te770d-ucm2_sigheader.dtb_list.xml
[ 8.4185 ] Assuming zero filled SBK key
[ 8.4383 ]
[ 8.4400 ] tegrahost_v2 --updatesigheader blob_tegra186-a02-bpmp-quill-p3310-1000-a00-00-te770d-ucm2_sigheader.dtb.encrypt blob_tegra186-a02-bpmp-quill-p3310-1000-a00-00-te770d-ucm2_sigheader.dtb.hash zerosbk
[ 8.4480 ]
[ 8.4492 ] tegrahost_v2 --chip 0x18 --align blob_tos-mon-only.img
[ 8.4560 ]
[ 8.4571 ] tegrahost_v2 --appendsigheader blob_tos-mon-only.img zerosbk
[ 8.4640 ]
[ 8.4651 ] tegrasign_v2 --key None --list blob_tos-mon-only_sigheader.img_list.xml
[ 8.4661 ] Assuming zero filled SBK key
[ 8.4799 ]
[ 8.4815 ] tegrahost_v2 --updatesigheader blob_tos-mon-only_sigheader.img.encrypt blob_tos-mon-only_sigheader.img.hash zerosbk
[ 8.4879 ]
[ 8.4890 ] tegrahost_v2 --chip 0x18 --align blob_eks.img
[ 8.4977 ]
[ 8.4987 ] tegrahost_v2 --appendsigheader blob_eks.img zerosbk
[ 8.5089 ]
[ 8.5105 ] tegrasign_v2 --key None --list blob_eks_sigheader.img_list.xml
[ 8.5115 ] Assuming zero filled SBK key
[ 8.5168 ]
[ 8.5190 ] tegrahost_v2 --updatesigheader blob_eks_sigheader.img.encrypt blob_eks_sigheader.img.hash zerosbk
[ 8.5249 ]
[ 8.5260 ] tegrahost_v2 --chip 0x18 --align blob_tegra186-quill-p3310-1000-a00-00-base.dtb
[ 8.5327 ]
[ 8.5336 ] tegrahost_v2 --appendsigheader blob_tegra186-quill-p3310-1000-a00-00-base.dtb zerosbk
[ 8.5448 ]
[ 8.5464 ] tegrasign_v2 --key None --list blob_tegra186-quill-p3310-1000-a00-00-base_sigheader.dtb_list.xml
[ 8.5478 ] Assuming zero filled SBK key
[ 8.5607 ]
[ 8.5622 ] tegrahost_v2 --updatesigheader blob_tegra186-quill-p3310-1000-a00-00-base_sigheader.dtb.encrypt blob_tegra186-quill-p3310-1000-a00-00-base_sigheader.dtb.hash zerosbk
[ 8.5687 ]
[ 8.5703 ] tegrahost_v2 --chip 0x18 --generateblob blob.xml blob.bin
[ 8.5754 ] number of images in blob are 9
[ 8.5777 ] blobsize is 3865752
[ 8.5782 ] Added binary blob_nvtboot_recovery_cpu_sigheader.bin.encrypt of size 202832
[ 8.5821 ] Added binary blob_nvtboot_recovery_sigheader.bin.encrypt of size 89184
[ 8.5845 ] Added binary blob_preboot_d15_prod_cr_sigheader.bin.encrypt of size 63104
[ 8.5872 ] Added binary blob_mce_mts_d15_prod_cr_sigheader.bin.encrypt of size 2082144
[ 8.5918 ] Added binary blob_bpmp_sigheader.bin.encrypt of size 533056
[ 8.5942 ] Added binary blob_tegra186-a02-bpmp-quill-p3310-1000-a00-00-te770d-ucm2_sigheader.dtb.encrypt of size 466128
[ 8.5973 ] Added binary blob_tos-mon-only_sigheader.img.encrypt of size 83760
[ 8.5992 ] Added binary blob_eks_sigheader.img.encrypt of size 1440
[ 8.6023 ] Added binary blob_tegra186-quill-p3310-1000-a00-00-base_sigheader.dtb.encrypt of size 343952
[ 8.6126 ]
[ 8.6127 ] Sending bootloader and pre-requisite binaries
[ 8.6141 ] tegrarcm_v2 --download blob blob.bin
[ 8.6162 ] Applet version 01.00.0000
[ 8.8943 ] Sending blob
[ 9.1608 ]
Error: Return value 1
Command tegrarcm_v2 --download blob blob.bin
Failed flashing t186ref.
In following this post:
https://devtalk.nvidia.com/default/topic/1001880/jetson-tx2/tx2-not-booting-after-successful-flashing-/1
I tried changing flash.sh to ext3 and removing metadata_csum,64bit from /etc/mke2fs.conf but I still get the same issue.
I think it is a faulty devices.
You could still try to use rel-28 based BSP (jetpack3.x) to flash the board and see if it works. According to the flash error, you are using jetpack4.2, right?
Yes, I was using Jetpack 4.2. I tried with Jetpack 3.3, and I get the same result.
Please start the RMA process. Thanks.
User error. I was trying to flash as a TX2, but I had grabbed a TX2i.
