Thank you for the hint. I installed same Ubuntu Version (18.04) “bare metal” and re-initiated the process. Here is the log:
14:11:18 SUMMARY: Drivers for Jetson - target_image: Install completed successfully.
14:19:47 SUMMARY: File System and OS - target_image: Install completed successfully.
14:26:41 SUMMARY: CUDA on Host - host: Install completed successfully.
14:30:04 SUMMARY: CUDA Cross Compile Package on Host - host: Install completed successfully.
14:30:11 SUMMARY: NvSci - host: Install completed successfully.
14:31:03 ERROR: Detected selected device is already in recovery mode. Please 1. double check if correct target device has been selected. 2. if does, change to 'Manual Setup' to continue.
14:31:16 ERROR: VPI on Host - host: |/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
14:31:25 ERROR: Detected selected device is already in recovery mode. Please 1. double check if correct target device has been selected. 2. if does, change to 'Manual Setup' to continue.
14:31:29 SUMMARY: VPI on Host - host: Install completed successfully.
14:31:47 ERROR: Detected selected device is already in recovery mode. Please 1. double check if correct target device has been selected. 2. if does, change to 'Manual Setup' to continue.
14:32:04 SUMMARY: Nsight Systems - host: Install completed successfully.
14:32:07 ERROR: Detected selected device is already in recovery mode. Please 1. double check if correct target device has been selected. 2. if does, change to 'Manual Setup' to continue.
14:32:29 ERROR: Detected selected device is already in recovery mode. Please 1. double check if correct target device has been selected. 2. if does, change to 'Manual Setup' to continue.
14:32:33 SUMMARY: Nsight Graphics - host: Install completed successfully.
14:32:51 ERROR: Detected selected device is already in recovery mode. Please 1. double check if correct target device has been selected. 2. if does, change to 'Manual Setup' to continue.
14:33:20 ERROR: Flash Jetson Linux - flash: [ 0.1484 ] ERROR: failed to read rcm_state
14:33:20 ERROR: Flash Jetson Linux - flash: [ 0.9339 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
14:33:20 ERROR: Flash Jetson Linux - flash: [ 0.9347 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
14:33:20 ERROR: Flash Jetson Linux - flash: [ 0.9353 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
14:33:20 ERROR: Flash Jetson Linux - flash: [ 0.9361 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
14:33:20 ERROR: Flash Jetson Linux - flash: [ 0.9371 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
14:33:20 ERROR: Flash Jetson Linux - flash: [ 0.9371 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
14:33:20 ERROR: Flash Jetson Linux - flash: [ 0.9371 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
14:33:20 ERROR: Flash Jetson Linux - flash: [ 0.9371 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
14:33:20 ERROR: Flash Jetson Linux - flash: [ 0.9371 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
14:33:20 ERROR: Flash Jetson Linux - flash: [ 0.9371 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
14:33:20 ERROR: Flash Jetson Linux - flash: [ 0.9371 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
14:33:20 ERROR: Flash Jetson Linux - flash: [ 0.9372 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
14:33:20 ERROR: Flash Jetson Linux - flash: [ 0.9372 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
14:33:20 ERROR: Flash Jetson Linux - flash: [ 0.9372 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
14:33:21 ERROR: Flash Jetson Linux - flash: [ 1.0768 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
14:33:21 ERROR: Flash Jetson Linux - flash: [ 1.0778 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
14:33:21 ERROR: Flash Jetson Linux - flash: [ 1.0785 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
14:33:21 ERROR: Flash Jetson Linux - flash: [ 1.0792 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
14:33:21 ERROR: Flash Jetson Linux - flash: [ 1.0844 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
14:33:21 ERROR: Flash Jetson Linux - flash: [ 1.0851 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
14:33:21 ERROR: Flash Jetson Linux - flash: [ 1.0871 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
14:33:21 ERROR: Flash Jetson Linux - flash: [ 1.0887 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
14:33:21 ERROR: Flash Jetson Linux - flash: [ 1.0962 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
14:33:21 ERROR: Flash Jetson Linux - flash: [ 1.0962 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
14:33:21 ERROR: Flash Jetson Linux - flash: [ 1.0962 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
14:33:21 ERROR: Flash Jetson Linux - flash: [ 1.0962 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
14:33:21 ERROR: Flash Jetson Linux - flash: [ 1.0962 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
14:33:21 ERROR: Flash Jetson Linux - flash: [ 1.0963 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
14:33:21 ERROR: Flash Jetson Linux - flash: [ 1.1818 ] Error: Skip generating mem_bct because sdram_config is not defined
14:33:26 ERROR: Flash Jetson Linux - flash: [ 1.2228 ] ERROR: might be timeout in USB write.
14:33:26 ERROR: Flash Jetson Linux - flash: Error: Return value 3
14:33:26 ERROR: Flash Jetson Linux - flash: --- Error: Reading board information failed.
14:33:26 ERROR: Flash Jetsthere on Linux - flash: command terminated with error
Jetpack installer also complains that it cannot access the jetson by ssh. Why should it? After the flash, I should be able to get a GUI (I attatched a monitor to the DP).
What are my network-settings supposed to be, if I connect the Ubuntu-host straight with the jetson (10GigE-port, which has steady green LED)? I set ubuntu to a manual IP-address 192.168.55.5, Network mask 255.255.255.0 Gateway: 192.168.55.1. But my Ubuntu does not accept this: ip a always says that the network is unreachable. Ubuntu network works fine the moment I plug into my LAN-switch, instead of the jetson. However, from the dhcp-server in my LAN I get IP-address 10.0.4.60.
One more question: the fan doesn’t spin. The temperature of the passive cooler remains moderate throughout installation process, but I’m a bit worried about this nevertheless. Of course, the cable of the cooler is plugged in properly. Could you please share your experience?
I followed the procedure in the link (incl. recovery mode), and re-initialized the process. Choosing “automatic” mode, jetlink complained about “target device already in recovery mode”. So I am now trying manual mode. I am now at step 03, “Installing …37%”. Keep fingers crossed.
Could you please tell me what network-setup I should set on the host? Or is that irrelevant?
I want to add some details about ethernet on USB. When a Jetson is fully running it will have one connector which looks like a wired ethernet device when plugged into the host PC. When the PC does performs its DHCP request the host will get assigned address 192.168.55.100, and the Jetson end is address 192.168.55.1. If you have configured your host PC to 192.168.55.5, and if that is on the host PC’s regular ethernet, then this is incorrect and the host would never have a route to the Jetson’s USB virtual ethernet. If this assignment is on the virtual USB device at the host PC end, then this is also wrong since DHCP should have assigned 192.168.55.100. The only way assigning 192.168.55.5 on the host PC would be correct is if this is through the PC’s regular ethernet, and that ethernet is going to the same switch or network the Jetson’s wired ethernet is going to. This would still be wrong unless the virtual ethernet were disabled and the Jetson’s wired network is set to use 192.168.55.1 (you shouldn’t have both the virtual wired and actual wired with the same address or overlapping subnets unless there is something special like bonding going on).
You can easily use the Jetson’s wired interface if it has an address and if that address is accessible to the host PC on the same subnet. Most people, when using wired, would plug the Jetson and the PC into a router and the router would assign addresses through DHCP without manual setting. Manual setting works too if there is no router.
The previous operation was a success. However, I can not proceed with USB- or Ethernet, due to the ssh-server issue.
I do not get the OS login screen when connecting a monitor with DP - even after a restart of the jetson.
I connected both (host and jetson) to a switch using ethernet cables. On the ubuntu-host, I entered a manual IP (10.0.6.23) Netmask 255.255.0.0., Gateway and DNS: 10.0.0.1. This way, ubuntu has access to Internet. The router should provide ubuntu with a IP through dhcp, but it seems to fail (if I turn dhcp on, I get an IP, can ping the router, but I cannot access the internet). I have no such issues no my other linux-machines. On my other linux-machines, I enable dhcp and provide a dns-server. That is sufficient.
Find attached the latest logs. Please let me know how to proceed.
The Monitor (DisplayPort) does not show any image.
If I ping 192.168.55.1, I do not get a response. I tried manual IP-settings on the host (192.169.55.100). I also tried dhcp, with the dhcp-server being 192.168.55.1. No luck.
