Flashing of Nvidia jetson orin nx board
I am having the Jetson Orin NX 16 Gb board when i am trying to flash through ubuntu 18 linux it throwing some errors as defined below, can solve it?
16:46:20 SUMMARY: CUDA on Host - host: Install completed successfully.
16:46:20 SUMMARY: CUDA Cross Compile Package on Host - host: Install completed successfully.
16:46:20 SUMMARY: NvSci - host: Install completed successfully.
16:46:20 SUMMARY: VPI on Host - host: Install completed successfully.
16:46:20 SUMMARY: Nsight Graphics - host: Install completed successfully.
16:47:25 ERROR: Flash Jetson Linux - flash: [ 0.6837 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
16:47:25 ERROR: Flash Jetson Linux - flash: [ 0.6837 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
16:47:25 ERROR: Flash Jetson Linux - flash: [ 0.6837 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
16:47:25 ERROR: Flash Jetson Linux - flash: [ 0.6837 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
16:47:25 ERROR: Flash Jetson Linux - flash: [ 0.6929 ] ERROR: /misc/enable_dram_page_blacklisting is not supported
16:47:25 ERROR: Flash Jetson Linux - flash: [ 0.6930 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
16:47:25 ERROR: Flash Jetson Linux - flash: [ 0.6931 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
16:47:25 ERROR: Flash Jetson Linux - flash: [ 0.6932 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
16:47:25 ERROR: Flash Jetson Linux - flash: [ 0.6941 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
16:47:30 ERROR: Flash Jetson Linux - flash: [ 0.1081 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
16:47:30 ERROR: Flash Jetson Linux - flash: [ 0.1082 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
16:47:30 ERROR: Flash Jetson Linux - flash: [ 0.1082 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
16:47:30 ERROR: Flash Jetson Linux - flash: [ 0.1082 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
16:47:30 ERROR: Flash Jetson Linux - flash: [ 0.1182 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
16:47:30 ERROR: Flash Jetson Linux - flash: [ 0.1196 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
16:47:30 ERROR: Flash Jetson Linux - flash: [ 0.1275 ] Error: Skip generating mem_bct because sdram_config is not defined
16:47:41 ERROR: Flash Jetson Linux - flash: 58208 blocks
16:47:50 ERROR: Flash Jetson Linux - flash: /home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/L4TConfiguration_updated.dts: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
16:48:03 ERROR: Flash Jetson Linux - flash: gzip: /home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/kernel/Image: not in gzip format
16:48:07 ERROR: Flash Jetson Linux - flash: 58208 blocks
16:53:57 ERROR: Flash Jetson Linux - flash: 67108864 bytes (67 MB, 64 MiB) copied, 0.674579 s, 99.5 MB/s
16:54:13 ERROR: Flash Jetson Linux - flash: XPath set is empty
16:54:16 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 20000
16:54:17 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 30000
16:54:23 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 40000
16:54:25 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 50000
16:54:31 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 70000
16:55:27 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 220000
16:55:35 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 240000
16:55:43 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 280000
16:55:46 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 290000
16:55:55 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 310000
16:55:56 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 320000
16:56:13 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 370000
16:56:25 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 410000
16:56:26 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 420000
16:56:28 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 430000
16:56:39 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 450000
16:56:41 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 460000
16:56:42 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 470000
16:56:44 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 480000
16:56:46 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 490000
16:56:53 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 500000
16:56:55 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 510000
16:56:56 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 520000
16:56:57 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 530000
16:56:59 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 540000
16:57:01 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 550000
16:57:08 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 560000
16:57:09 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 570000
16:58:09 ERROR: Flash Jetson Linux - flash: [ 0.5284 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
16:58:09 ERROR: Flash Jetson Linux - flash: [ 0.5417 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
16:58:15 ERROR: Flash Jetson Linux - flash: 41966 blocks
16:58:15 ERROR: Flash Jetson Linux - flash: gzip: /home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/kernel/Image: not in gzip format
16:58:21 ERROR: Flash Jetson Linux - flash: 58208 blocks
16:58:22 ERROR: Flash Jetson Linux - flash: 20 bytes copied, 0.000501449 s, 39.9 kB/s
16:58:22 ERROR: Flash Jetson Linux - flash: /home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/flash.sh: line 3235: python: command not found
16:58:23 ERROR: Flash Jetson Linux - flash: 67108864 bytes (67 MB, 64 MiB) copied, 0.694968 s, 96.6 MB/s
16:58:30 ERROR: Flash Jetson Linux - flash: /home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/L4TConfiguration_updated.dts: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
16:58:31 ERROR: Flash Jetson Linux - flash: [ 0.8607 ] ERROR: value 0x31 is out of range
16:58:34 ERROR: Flash Jetson Linux - flash: [ 3.7490 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
16:58:36 ERROR: Flash Jetson Linux - flash: [ 5.2743 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED1/ is not supported
16:58:36 ERROR: Flash Jetson Linux - flash: [ 5.8412 ] ERROR: value 0x31 is out of range
16:58:40 ERROR: Flash Jetson Linux - flash: 58208 blocks
16:58:44 ERROR: Flash Jetson Linux - flash: 84978 blocks
16:59:56 ERROR: Flash Jetson Linux - flash: command terminated with error
16:59:56 SUMMARY: DateTime Target Setup - target: Depends on failed component
Welcome to the NVIDIA Developer forums! Your topic will be best served in the Jetson category.
I will move this post over for visibility.
Cheers,
Tom
First of all:
Are you using a DevKit or a custom board?
What’s the L4T/JetPack version?
Please put the log in the form of zip archive from SDK Manager here.
Don’t crop it yourself.
Yes, I am using DevKit only with JetPack_5.1.3_Linux version
log.zip (1.3 KB)
I mean SDK Manager let’s you export the complete log as a zip file.
Use that.
Also, make sure it’s an Orin Nano DevKit.
SDK Manager does not support the combination of Xavier NX DevKit + Orin NX.
Yeah, it is NVIDIA Jetson Orin NX 16GB board only
SDKM_logs_2024-05-29_11-20-38.zip (482.2 KB)
Please get the serial console log:
It get solved, i have missed some BSP files of Jet pack 5.1.3. Steps to get solved:
1.we need to select necessary jet pack to be installed:
For JetPack-5.1
      Orin NX: ~/nvidia/nvidia_sdk/JetPack_5.1_Linux_JETSON_ORIN_NX_TARGETS/
For JetPack-5.1.1
      Orin NX: ~/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/
      Orin Nano: ~/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NANO_TARGETS/
For JetPack-5.1.2
      Orin NX: ~/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NX_TARGETS/
      Orin Nano: ~/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/
For JetPack-5.1.3
      Orin NX: ~/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NX_TARGETS/
      Orin Nano: ~/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_ORIN_NANO_TARGETS/
  1. And then we need to download necessary BSP files for version of jet pack we have choosen.
    For JetPack-5.1:
Download the BSP files from GitHub link and extract it (Orin NX).
For JetPack-5.1.1:
Download the BSP files from GitHub link and extract it (Orin NX, Orin Nano).
For JetPack-5.1.2:
For JetPack-5.1.3:
  1. We need to extract the BSP file and then copy all the files present in that and paste, where the linux_for_tegra file was there(mostly it is the folder of jetpack file only).
  2. open the terminal in linux_for_tegra folder and then type these commands to create system binaries :
sudo ./tools/l4t_flash_prerequisites.sh
sudo ./apply_binaries.sh
  1. And then in same terminal we need to do this, Apply the new BSP files and interface configurations with the following commands below:
cd …
sudo ./replace_bsp_files.sh
cd Linux_for_Tegra/
  1. Then we need to check whether board is connected in RCM(Recovery mode) or not for this we need to type these command in same terminal:
Then, type “lsusb” and check the device connected in Recovery mode.
• “0955:7323 NVidia Corp.” for Orin NX 16GB
• “0955:7423 NVidia Corp.” for Orin NX 8GB
• “0955:7523 NVidia Corp.” for Orin Nano 8GB
• “0955:7623 NVidia Corp.” for Orin Nano 4GB
  1. At last after verifying we need to flashing Jetson OS using following command in the terminal:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml -p “-c bootloader/t186ref/cfg/flash_t234_qspi.xml” --showlogs --network usb0 jetson-orin-nano-devkit internal
Through these steps my problem was solved,
Thank You.
Hello, i am getting problem while restarting the orin nx board after its get successfully flashed its unable to boot the os ? can you solve this?
Please still get the console log.
Such description is unclear and does not help in debugging.
the board was successfully flashed and then linux was loaded and then i update all the things in linux and then it pop ups the window with restart is required to apply changes and then i clicked on restart, from there itself its stucked on the booting process unable to load the linux
Still, get the log so we know what happened.
Mostly it’s because something is broken during update.
You need to be very cautious when updating any packages on embedded systems.
unable to get the log the booting process was stucked!
so how to resolve it?
I’ve told you here.
its already completed but still its not working?
why? what’s the reason its unable to restart the already flshed board?
Please get the log.
unable to get the log its not showing in the terminal for the options of minicom? is there any way other than this?
I’m not sure what you mean with this.
the sudo minicom is running but its unable to show the options later that command
Can you put a screenshot here?
