Cannot flash jetson orin nano with any method
SDKM_logs_JetPack_6.0_DP_Linux_for_Jetson_Orin_Nano_modules_2024-04-16_18-15-32.zip (123.9 KB)
I’ve tried flashing with the sdkmanager, etcher, and from the command line. Tried the SD card and the NVMe. Nothing works. In the attached logs am using Ubuntu 22.04, trying to flash jetpack 6.0 to the NVMe. This is a native host PC, not a VM. I am putting the device in recovery mode, when I type lsusb I see this: ID 0955:7523 NVIDIA Corp. APX
I have tried leaving the jumper in during flashing, and taking it out before flashing. Neither work.
I am getting the following errors:
18:16:03 INFO: exec_command: true
18:16:03 INFO: command finished successfully
18:16:03 DEBUG: running command < /tmp/device_mode_host_setup.ysunil3.sh >
18:16:03 INFO: exec_command: /tmp/device_mode_host_setup.ysunil3.sh
18:16:03 INFO: Found route default enp0s31f6, setting up device mode
18:16:03 INFO: [host] [sudo] password for ysunil3:
18:16:03 INFO: net.ipv4.ip_forward = 1
18:16:03 INFO: Device mode on host successfully set with DNS 8.8.8.8!
18:16:03 DEBUG: running command < true >
18:16:03 INFO: Flash Jetson Linux - flash: sudo ./nvsdkmanager_flash.sh --storage nvme0n1p1 --nv-auto-config --username saferobolab
18:20:32 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 270000
18:20:32 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 320000
18:20:33 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 350000
18:20:33 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 360000
18:20:33 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 420000
18:20:33 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 430000
18:20:33 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 440000
18:20:33 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 450000
18:20:33 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 460000
18:20:33 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 470000
18:20:33 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 480000
18:20:33 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 490000
18:20:33 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 500000
18:20:34 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 510000
18:20:34 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 520000
18:20:34 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 530000
18:20:34 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 540000
18:20:34 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 550000
18:20:34 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 560000
18:20:34 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 570000
18:20:34 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 580000
18:20:34 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 590000
18:20:34 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 600000
18:20:35 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 610000
18:20:35 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 620000
18:20:35 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 630000
18:20:35 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 640000
18:20:35 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 650000
18:20:45 ERROR: Flash Jetson Linux - flash: 52057 blocks
18:20:45 ERROR: Flash Jetson Linux - flash: gzip: /home/ysunil3/nvidia/nvidia_sdk/JetPack_6.0_DP_Linux_DP_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/kernel/Image: not in gzip format
18:20:49 ERROR: Flash Jetson Linux - flash: 74756 blocks
18:20:50 ERROR: Flash Jetson Linux - flash: 20 bytes copied, 7.9361e-05 s, 252 kB/s
18:20:50 ERROR: Flash Jetson Linux - flash: 67108864 bytes (67 MB, 64 MiB) copied, 0.1104 s, 608 MB/s
18:20:55 ERROR: Flash Jetson Linux - flash: /home/ysunil3/nvidia/nvidia_sdk/JetPack_6.0_DP_Linux_DP_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/L4TConfiguration_updated.dts: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
18:20:55 ERROR: Flash Jetson Linux - flash: /home/ysunil3/nvidia/nvidia_sdk/JetPack_6.0_DP_Linux_DP_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/L4TConfiguration.dtbo: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
18:20:56 ERROR: Flash Jetson Linux - flash: [ 0.2989 ] ERROR: value 0x31 is out of range
18:20:58 ERROR: Flash Jetson Linux - flash: [ 2.2666 ] ERROR: value 0x31 is out of range
18:20:59 ERROR: Flash Jetson Linux - flash: 74756 blocks
18:21:06 ERROR: Flash Jetson Linux - flash: 128307 blocks
18:29:02 ERROR: Flash Jetson Linux - flash: command terminated with error
18:29:02 SUMMARY: Flash Jetson Linux - flash: First Error: Installation failed.
I tried this in case the rcm error was because of this:
Q: I get a USB timeout error during flash Orin. How to resolve that?
A known issue for ubuntu 20.04 host is the USB autosuspend function is enabled on it by default. This leads to Jetson recovery mode gets suspended before flash. To bypass this error, need to:
Disable autosuspend on host PC with below command:
sudo -s
echo -1 > /sys/module/usbcore/parameters/autosuspend
Plug out the USB cable, put jetson back into recovery mode again and plug the usb cable back.
If USB timeout is still there after above commands, please file a topic to forum and let moderator help check.
Still doesnt work.
Waiting for device to expose ssh ...Run command: flash on fc00:1:1:0::2
SSH ready
mount.nfs: Connection timed out
Flash failure
Cleaning up...
Do you have nfs-common and nfs-kernel-server installed on your host PC?
Or maybe with a different USB cable.
I don’t know if this will help, but when I am flashing my Orin Nano 8gb (using a Turing Pi 2 board), I get the “waiting for device to boot up…” message. I found an obscure forum post somewhere that actually fixed everything:
https://forum.turingpi.com/t/16218946/turing-pi-v2-orin-nx-v36-2-ubuntu-22-04-kernel-5-15-122-tegr#0f458a94-52cb-4818-9448-febb2ab50a92
TL;DR: Try the “disable NFSv4 after ./apply_binaries.sh”, and add the “echo on > /sys/bus/usb/devices/usb2/power/control” to line 222 of “tools/kernel_flash/initrd_flash/nv_enable_remote.sh”. Note: I’m using the standard flash methods via usb to NVMe, not using the sdkmanager.
I will look into this and let you know!
I will try this!
So I tried this, but looks like it is still not working
I’m in the same boat. I see plenty of past threads about this but it seems like they are prior generations of the dev board or Nano module.
This is USB-C (not Micro-USB) and I can’t get a USB detected in any case. Latest flash to MicroSD boots to a dead screen as previously reported by numerous users. USB in dmesg is full of “Cannot enable, Maybe the USB cable is bad?” Trying multiple devices and 5 different USB cables shows no difference.
The only way I can make any use of this pricey bit of kit is to switch from Device Tree to ACPI mode and boot Fedora on NVMe which works fine but without the proper GPU drivers. Is this just a problem with newer generation modules/dev boards? What a rocky dev experience. It looks like my model is the latest P3767-0005 module in a P3768-0000 carrier board.
Finally booted in recovery mode via poor-man’s jumper. I wouldn’t recommend this but it was picked up instantly when I plugged it back in. All seems good. Funny they don’t bother to include jumpers in this kit.
I tried this as well, but no luck
Flashing terminal.pdf (420.6 KB)
This ended in flash failure. My computer does recognize the device, so does sdkmanager. However I do see during the flashing process, it seems to disconnect and reconnect, not sure if that is expected? I have tried multiple USB cables.
I always seem to get these in sdkmanager:
14:18:27 ERROR: Flash Jetson Linux - flash: [ 0.0193 ] ERROR: failed to read rcm_state
14:18:27 ERROR: Flash Jetson Linux - flash: [ 0.1196 ] Error: Skip generating mem_bct because sdram_config is not defined
Not sure why rcm_state seems to never be able to be read. This whole process has been so draining.
Are either of you using the official NV Dev board with your Orins, or are you using a “custom” board, such as the Turing Pi 2?
If you’re using a custom board, please see this:
EEPROM is an optional component for a customized carrier board. In the case the carrier board
is designed without an EEPROM, below modifications will be needed on the MB2 BCT file:
Linux_for_Tegra/bootloader/tegra234-mb2-bct-common.dtsi
-cvb_eeprom_read_size = <0x100>
+cvb_eeprom_read_size = <0x0>
In the case of JP6 on an Orin, the file is bootloader/generic/BCT/tegra234-mb2-bct-misc-p3767-0000.dts
I am using the official NVIDIA Jetson Orin Nano Developer Kit
Formatting APP parition done
Formatting APP partition /dev/nvme0n1p1 ...
tar -xpf /mnt/external/system.img --checkpoint=10000 --warning=no-timestamp --numeric-owner
--xattrs --xattrs-include=* -C /tmp/ci-qgGjQAXVcJ
tar: Re14:18:27 ERROR: Flash Jetson Linux - flash: [ 0.0193 ] ERROR: failed to read rcm_state
because sdram_config is not definedad checkpoint 10000
tar: Read checkpoint 20000
tar: Read checkpoint 30000
This means the NFS error seen before has been resolved, but writing to the NVMe drive is somehow disrupted.
You can try using a diffrent USB cable, or prepare the disk by connecting it to the host manually like this:
https://docs.nvidia.com/jetson/archives/r36.2/DeveloperGuide/SD/FlashingSupport.html#flashing-to-an-nvme-drive
