Jetson Orin Nano Dev Kit 8GB Unable to Flash Through SDK Manager
My Jetson Orin Nano Dev Kit (microSD card version) had the same issue from another post. I followed the steps from the documentation provided by NVIDIA. I used a host machine with Ubuntu 18.04. I tried both automatic setup and manual setup with the jumper. However, I have been running into an issue whenever I get to the “flash” part of the setup with the following message.
07:07:06 INFO: Flash Jetson Linux - flash: *** Reading EEPROM ... "/home/derek/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py" --chip 0x23 --applet "/home/derek/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/mb1_t234_prod.bin" --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3701-0000.dts --misc_config tegra234-mb1-bct-misc-p3701-0000.dts --bins "mb2_applet applet_t234.bin" --skipuid --cmd "dump eeprom cvm cvm.bin; reboot recovery"
07:07:06 INFO: Flash Jetson Linux - flash: [ 0.1173 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
07:07:06 INFO: Flash Jetson Linux - flash: [ 0.1236 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
07:07:06 INFO: Flash Jetson Linux - flash: [ 0.1238 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
07:07:06 INFO: Flash Jetson Linux - flash: [ 0.1301 ] adding BCH for mb2_t234_aligned.bin
07:07:06 INFO: Flash Jetson Linux - flash: [ 0.1338 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
07:07:06 INFO: Flash Jetson Linux - flash: [ 0.1476 ] adding BCH for mb2_t234_aligned.bin
07:07:06 INFO: Flash Jetson Linux - flash: [ 0.1758 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin
07:07:06 INFO: Flash Jetson Linux - flash: [ 0.1765 ] WARNING: boot chain is not completed. set to 0
07:07:06 INFO: Flash Jetson Linux - flash: [ 0.1785 ] Assuming zero filled SBK key
07:07:06 INFO: Flash Jetson Linux - flash: [ 0.1998 ] WARNING: boot chain is not completed. set to 0
07:07:06 INFO: Flash Jetson Linux - flash: [ 0.2043 ] Assuming zero filled SBK key
07:07:06 INFO: Flash Jetson Linux - flash: [ 0.2101 ] Assuming zero filled SBK key
07:07:07 ERROR: Flash Jetson Linux - flash: [ 0.2188 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
07:07:07 INFO: Flash Jetson Linux - flash: [ 0.2250 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
07:07:07 ERROR: Flash Jetson Linux - flash: [ 0.2338 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
07:07:07 ERROR: Flash Jetson Linux - flash: [ 0.2348 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
07:07:07 INFO: Flash Jetson Linux - flash: [ 0.2422 ] Assuming zero filled SBK key
07:07:07 INFO: Flash Jetson Linux - flash: [ 0.2530 ] BR_CID: 0x80012344705DE6C40C0000000DFD0140
07:07:07 INFO: Flash Jetson Linux - flash: [ 0.2540 ] Sending bct_br
07:07:07 INFO: Flash Jetson Linux - flash: [ 0.2694 ] Sending mb1
07:07:07 INFO: Flash Jetson Linux - flash: [ 0.2699 ] Sending psc_bl1
07:07:07 INFO: Flash Jetson Linux - flash: [ 0.2794 ] Sending bct_mb1
07:07:07 INFO: Flash Jetson Linux - flash: [ 0.2892 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --appendsigheader applet_t234_aligned.bin zerosbk
07:07:07 INFO: Flash Jetson Linux - flash: [ 0.2901 ] adding BCH for applet_t234_aligned.bin
07:07:07 INFO: Flash Jetson Linux - flash: [ 0.3014 ] Assuming zero filled SBK key
07:07:07 INFO: Flash Jetson Linux - flash: [ 0.3057 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download applet applet_t234_sigheader.bin.encrypt
07:07:07 INFO: Flash Jetson Linux - flash: [ 0.4946 ] Sending applet
07:07:07 INFO: Flash Jetson Linux - flash: [ 0.6090 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
07:07:07 INFO: Flash Jetson Linux - flash: [ 0.8241 ] MB2 Applet version 01.00.0000
07:07:07 INFO: Flash Jetson Linux - flash: [ 0.8279 ] tegrarcm_v2 --chip 0x23 0 --oem platformdetails chip chip_info.bin
07:07:07 INFO: Flash Jetson Linux - flash: [ 0.8291 ] MB2 Applet version 01.00.0000
07:07:07 INFO: Flash Jetson Linux - flash: [ 0.8534 ] Chip Sample: prod
07:07:07 INFO: Flash Jetson Linux - flash: [ 0.8540 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/derek/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/cvm.bin --chip 0x23 0
07:07:07 INFO: Flash Jetson Linux - flash: [ 0.8549 ] MB2 Applet version 01.00.0000
07:07:07 INFO: Flash Jetson Linux - flash: [ 0.8714 ] Saved platform info in /home/derek/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/cvm.bin
07:07:07 INFO: Flash Jetson Linux - flash: [ 0.9084 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
07:07:07 INFO: Flash Jetson Linux - flash: [ 0.9090 ] MB2 Applet version 01.00.0000
07:07:07 INFO: Flash Jetson Linux - flash: [ 0.9254 ] tegrarcm_v2 --chip 0x23 0 --reboot recovery
07:07:07 INFO: Flash Jetson Linux - flash: [ 0.9262 ] MB2 Applet version 01.00.0000
07:07:09 INFO: Flash Jetson Linux - flash: --- Reading board information succeeded.
07:07:09 INFO: Flash Jetson Linux - flash: Parsing module EEPROM:
07:07:09 INFO: Flash Jetson Linux - flash: --- Parsing board ID (3767) succeeded.
07:07:09 INFO: Flash Jetson Linux - flash: jetson-orin-nano-devkit found.
07:07:09 INFO: Flash Jetson Linux - flash: Flashing Jeton Orin Nano
07:07:09 INFO: Flash Jetson Linux - flash: /home/derek/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh --no-flash --external-device mmcblk1p1 -c tools/kernel_flash/flash_l4t_external.xml --showlogs --network usb0 -p --no-systemimg -c bootloader/t186ref/cfg/flash_t234_qspi.xml jetson-orin-nano-devkit internal
07:07:09 INFO: Flash Jetson Linux - flash: Cleaning up...
07:07:09 ERROR: Flash Jetson Linux - flash: NOTE: this default has changed since nfs-utils version 1.0.x
07:07:09 ERROR: Flash Jetson Linux - flash: command terminated with error
07:07:09 SUMMARY: DateTime Target Setup - target: Depends on failed component
I tried to search the web to resolve the issue but was not able to flash the Jetson.
I also tried to install dtc as described
sudo apt-get install device-tree-compiler
Is there a workaround to release the 1GB of RAM other than flashing the Jetson with SDK Manager or resolving the issue with SDK Manager?
I don’t understand what 1GB RAM you are talking about here.
Please share the full log from sdkmanager. I actually don’t see any fatal log from what you posted. The error log might be something else.
Hi @WayneWWW
The 1GB Memory I mean is shown below
when I do jtop it shows I have 6.3 G memory which is the same issue from the other thread as I was mentioning in the previous post.
I am attempting to flash the Jetson Orin Nano to get 8 GB of memory.
I am not sure which log you need to see the fatal error I did export the log and there are many files. From the terminal, the error message I keep encountering is the FileNotFoundError
06:42:31 INFO: File System and OS - target_image: Pre-installing bootloader package, skip flashing
06:42:31 INFO: File System and OS - target_image: Setting up nvidia-l4t-3d-core (35.3.1-20230319081403) ...
06:42:31 INFO: File System and OS - target_image: Setting up nvidia-l4t-gbm (35.3.1-20230319081403) ...
06:42:31 INFO: File System and OS - target_image: Setting up nvidia-l4t-initrd (35.3.1-20230319081403) ...
06:42:31 INFO: File System and OS - target_image: Pre-installing initrd package, skip flashing
06:42:31 INFO: File System and OS - target_image: Setting up nvidia-l4t-jetson-io (35.3.1-20230319081403) ...
06:42:31 INFO: File System and OS - target_image: Setting up nvidia-l4t-multimedia (35.3.1-20230319081403) ...
06:42:31 INFO: File System and OS - target_image: Setting up nvidia-l4t-vulkan-sc-samples (35.3.1-20230319081403) ...
06:42:31 INFO: File System and OS - target_image: Setting up nvidia-l4t-weston (35.3.1-20230319081403) ...
06:42:32 INFO: File System and OS - target_image: Setting up nvidia-l4t-display-kernel (5.10.104-tegra-35.3.1-20230319081403) ...
06:42:32 INFO: File System and OS - target_image: Setting up nvidia-l4t-camera (35.3.1-20230319081403) ...
06:42:32 INFO: File System and OS - target_image: Setting up nvidia-l4t-graphics-demos (35.3.1-20230319081403) ...
06:42:32 INFO: File System and OS - target_image: Setting up nvidia-l4t-gstreamer (35.3.1-20230319081403) ...
06:42:32 INFO: File System and OS - target_image: Processing triggers for nvidia-l4t-kernel (5.10.104-tegra-35.3.1-20230319081403) ...
06:42:32 INFO: File System and OS - target_image: Processing triggers for libc-bin (2.31-0ubuntu9.9) ...
06:42:33 INFO: File System and OS - target_image: Removing QEMU binary from rootfs
06:42:33 INFO: File System and OS - target_image: Removing stashed Debian packages from rootfs
06:42:33 INFO: File System and OS - target_image: L4T BSP package installation completed!
06:42:33 INFO: File System and OS - target_image: Disabling NetworkManager-wait-online.service
06:42:33 INFO: File System and OS - target_image: Disable the ondemand service by changing the runlevels to 'K'
06:42:33 INFO: File System and OS - target_image: Success!
06:42:33 INFO: File System and OS - target_image: [ NV_L4T_FILE_SYSTEM_AND_OS_COMP Install took 4m15s ]
06:42:33 INFO: File System and OS - target_image: command finished successfully
06:42:33 SUMMARY: File System and OS - target_image: Install completed successfully.
06:43:41 INFO: Device info before flashing: Jetson Orin Nano [8GB developer kit version] | 001/014 | 1-5 | Recovery
06:43:41 DEBUG: running command < true >
06:43:41 INFO: command finished successfully
06:43:41 DEBUG: running command < /tmp/device_mode_host_setup.sh >
06:43:41 INFO: exec_command: /tmp/device_mode_host_setup.sh
06:43:41 INFO: Found route default wlp5s0, setting up device mode
06:43:41 INFO: net.ipv4.ip_forward = 1
06:43:41 INFO: Device mode on host successfully set with DNS 8.8.8.8!
06:43:41 DEBUG: Flash Jetson Linux - flash: using adapter to install NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS to /home/derek/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NANO_TARGETS
06:43:41 INFO: Flash Jetson Linux - flash: [ Component Install Started ]
06:43:41 INFO: Flash Jetson Linux - flash: sudo ./nvsdkmanager_flash.sh --storage mmcblk1p1
06:43:41 INFO: Flash Jetson Linux - flash: user entered mmcblk1p1
06:43:41 INFO: Flash Jetson Linux - flash: *** Checking ONLINE mode ... OK.
06:43:41 INFO: Flash Jetson Linux - flash: *** Checking target board connection ... 1 connections found.
06:43:41 INFO: Flash Jetson Linux - flash: *** Reading ECID ... FUSELEVEL=fuselevel_production hwchipid=0x23 bootauth=NS
06:43:41 INFO: Flash Jetson Linux - flash: *** Reading EEPROM ... "/home/derek/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py" --chip 0x23 --applet "/home/derek/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/mb1_t234_prod.bin" --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3701-0000.dts --misc_config tegra234-mb1-bct-misc-p3701-0000.dts --bins "mb2_applet applet_t234.bin" --skipuid --cmd "dump eeprom cvm cvm.bin; reboot recovery"
06:43:42 INFO: Flash Jetson Linux - flash: [ 0.0723 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
06:43:42 INFO: Flash Jetson Linux - flash: [ 0.0735 ] File rcm_state open failed
06:43:42 INFO: Flash Jetson Linux - flash: [ 0.0745 ] Pre-processing config: tegra234-mb1-bct-device-p3701-0000.dts
06:43:42 ERROR: Flash Jetson Linux - flash: FileNotFoundError: [Errno 2] No such file or directory: 'dtc': 'dtc'
06:43:42 ERROR: Flash Jetson Linux - flash: --- Error: Reading board information failed.
06:43:42 ERROR: Flash Jetson Linux - flash: command terminated with error
06:43:42 SUMMARY: DateTime Target Setup - target: Depends on failed component
The list of log files are
Yes, generally you just attach the whole zip file to the forum for me to check.
When you run dtc --help on your host, will it give you the outupt?
I am uploading the zip file of the log file.
SDKM_logs_JetPack_5.1.1_(rev._1)_Linux_for_Jetson_Orin_Nano_modules_2023-05-16_07-01-45.zip (112.2 KB)
The latest log suggest you to install
ERROR sshpass not found! To install - please run: “sudo apt-get install sshpass”
Hi @WayneWWW,
I was able to flash the nano after installing some dependencies. Thank you so much for helping me through this.
