Hi ,
I have a J3011 Jetson Orin Nano 8GB and quite new to this module.
I attempt to flash this module using Jetpack 6.1 and SDK Manager (Ubuntu20.04 Host). but never succeed. detail (filter only errors). below
Could someone advise me how to solve it?
17:41:58 SUMMARY: Drivers for Jetson - target_image: Install completed successfully.
17:50:10 SUMMARY: File System and OS - target_image: Install completed successfully.
17:59:12 SUMMARY: CUDA on Host - host: Install completed successfully.
18:02:20 SUMMARY: CUDA Cross Compile Package on Host - host: Install completed successfully.
18:02:24 SUMMARY: NvSci - host: Install completed successfully.
18:03:21 SUMMARY: VPI on Host - host: Install completed successfully.
18:03:54 SUMMARY: Nsight Systems - host: Install completed successfully.
18:04:18 SUMMARY: Nsight Graphics - host: Install completed successfully.
18:04:22 ERROR: [ 0.1104 ] ERROR: failed to read rcm_state
18:04:38 ERROR: [ 0.0243 ] ERROR: failed to read rcm_state
18:04:42 ERROR: Flash Jetson Linux - flash: [ 0.0252 ] ERROR: failed to read rcm_state
18:04:48 ERROR: Flash Jetson Linux - flash: [ 0.0244 ] ERROR: failed to read rcm_state
18:04:52 ERROR: Flash Jetson Linux - flash: [ 3.6357 ] Error: try getting custinfo fail. Moving on
18:04:58 ERROR: Flash Jetson Linux - flash: 72720 blocks
18:04:58 ERROR: Flash Jetson Linux - flash: gzip: /home/csg/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/kernel/Image: not in gzip format
18:05:15 ERROR: Flash Jetson Linux - flash: 96252 blocks
18:05:17 ERROR: Flash Jetson Linux - flash: 20+0 records in
18:05:17 ERROR: Flash Jetson Linux - flash: 20+0 records out
18:05:17 ERROR: Flash Jetson Linux - flash: 20 bytes copied, 0,000298502 s, 67,0 kB/s
18:05:18 ERROR: Flash Jetson Linux - flash: 131072+0 records in
18:05:18 ERROR: Flash Jetson Linux - flash: 131072+0 records out
18:05:18 ERROR: Flash Jetson Linux - flash: 67108864 bytes (67 MB, 64 MiB) copied, 0,423977 s, 158 MB/s
18:05:26 ERROR: Flash Jetson Linux - flash: /home/csg/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/L4TConfiguration_updated.dts: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
18:05:26 ERROR: Flash Jetson Linux - flash: /home/csg/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/L4TConfiguration.dtbo: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
18:05:27 ERROR: Flash Jetson Linux - flash: [ 0.9576 ] ERROR: value 0x31 is out of range
18:05:27 ERROR: Flash Jetson Linux - flash: [ 0.9587 ] ERROR: value 0x31 is out of range
18:05:27 ERROR: Flash Jetson Linux - flash: [ 0.9590 ] ERROR: value 0x31 is out of range
18:05:27 ERROR: Flash Jetson Linux - flash: [ 0.9592 ] ERROR: value 0x31 is out of range
18:05:34 ERROR: Flash Jetson Linux - flash: [ 7.5806 ] ERROR: value 0x31 is out of range
18:05:34 ERROR: Flash Jetson Linux - flash: [ 7.5816 ] ERROR: value 0x31 is out of range
18:05:34 ERROR: Flash Jetson Linux - flash: [ 7.5818 ] ERROR: value 0x31 is out of range
18:05:34 ERROR: Flash Jetson Linux - flash: [ 7.5820 ] ERROR: value 0x31 is out of range
18:05:37 ERROR: Flash Jetson Linux - flash: [ 0.0283 ] ERROR: failed to read rcm_state
18:05:40 ERROR: Flash Jetson Linux - flash: [ 3.2632 ] Error: try getting custinfo fail. Moving on
18:05:45 ERROR: Flash Jetson Linux - flash: 72720 blocks
18:05:45 ERROR: Flash Jetson Linux - flash: gzip: /home/csg/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/kernel/Image: not in gzip format
18:05:53 ERROR: Flash Jetson Linux - flash: 96252 blocks
18:05:55 ERROR: Flash Jetson Linux - flash: 20+0 records in
18:05:55 ERROR: Flash Jetson Linux - flash: 20+0 records out
18:05:55 ERROR: Flash Jetson Linux - flash: 20 bytes copied, 0,00107654 s, 18,6 kB/s
18:21:06 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 160000
18:21:08 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 170000
18:21:24 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 220000
18:21:54 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 310000
18:22:05 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 360000
18:22:34 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 460000
18:22:35 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 470000
18:22:39 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 480000
18:22:42 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 490000
18:22:51 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 520000
18:23:03 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 530000
18:23:23 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 570000
18:23:28 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 580000
18:23:55 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 630000
18:23:56 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 640000
18:23:58 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 650000
18:24:02 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 660000
18:24:21 ERROR: Flash Jetson Linux - flash: [ 0.1035 ] ERROR: failed to read rcm_state
18:24:24 ERROR: Flash Jetson Linux - flash: [ 3.7216 ] Error: try getting custinfo fail. Moving on
18:24:30 ERROR: Flash Jetson Linux - flash: 72720 blocks
18:24:30 ERROR: Flash Jetson Linux - flash: gzip: /home/csg/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/kernel/Image: not in gzip format
18:24:47 ERROR: Flash Jetson Linux - flash: 96252 blocks
18:24:49 ERROR: Flash Jetson Linux - flash: 20+0 records in
18:24:49 ERROR: Flash Jetson Linux - flash: 20+0 records out
18:24:50 ERROR: Flash Jetson Linux - flash: 131072+0 records in
18:24:57 ERROR: Flash Jetson Linux - flash: /home/csg/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/L4TConfiguration_updated.dts: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
18:24:57 ERROR: Flash Jetson Linux - flash: /home/csg/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/L4TConfiguration.dtbo: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
18:25:05 ERROR: Flash Jetson Linux - flash: [ 7.3453 ] ERROR: value 0x31 is out of range
18:25:05 ERROR: Flash Jetson Linux - flash: [ 7.3455 ] ERROR: value 0x31 is out of range
18:25:10 ERROR: Flash Jetson Linux - flash: 96252 blocks
18:26:23 SUMMARY: OpenCV Runtime - target: Depends on failed component
18:26:23 SUMMARY: CuPVA Runtime - target: Depends on failed component
