2:57:12 INFO: Flash Jetson Linux - flash: ************************************
12:57:12 INFO: Flash Jetson Linux - flash: Create folder to store images to flash
12:57:12 INFO: Flash Jetson Linux - flash: Generate image for internal storage devices
12:57:12 INFO: Flash Jetson Linux - flash: ###############################################################################
12:57:12 INFO: Flash Jetson Linux - flash: ECID is
12:57:12 INFO: Flash Jetson Linux - flash: Board ID() version() sku() revision()
12:57:12 INFO: Flash Jetson Linux - flash: Cleaning up…
12:57:12 INFO: Flash Jetson Linux - flash: [ NV_L4T_FLASH_JETSON_LINUX_COMP Install took 4s ]
12:57:12 ERROR: Flash Jetson Linux - flash: command terminated with error
12:57:12 SUMMARY: DateTime Target Setup - target: Depends on failed component
