I tried so many time to flash the orin nano but it keeps failing. I am using a Ubuntu 22.04 system and trying to flash jetpack 6. The error log reads:
20:39:54 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 420000
20:39:54 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 430000
20:39:54 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 450000
20:39:55 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 480000
20:39:55 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 490000
20:39:55 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 500000
20:39:55 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 510000
20:40:12 ERROR: Flash Jetson Linux - flash: [ 0.1010 ] Error: Skip generating mem_bct because sdram_config is not defined
20:40:17 ERROR: Flash Jetson Linux - flash: 52057 blocks
20:40:17 ERROR: Flash Jetson Linux - flash: gzip: /home/donnylu/nvidia/nvidia_sdk/JetPack_6.0_DP_Linux_DP_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/kernel/Image: not in gzip format
20:40:25 ERROR: Flash Jetson Linux - flash: 74756 blocks
20:40:25 ERROR: Flash Jetson Linux - flash: 20+0 records in
20:40:25 ERROR: Flash Jetson Linux - flash: 20+0 records out
20:40:25 ERROR: Flash Jetson Linux - flash: 20 bytes copied, 0.000636571 s, 31.4 kB/s
20:40:25 ERROR: Flash Jetson Linux - flash: /home/donnylu/nvidia/nvidia_sdk/JetPack_6.0_DP_Linux_DP_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/flash.sh: line 3145: python: command not found
20:40:26 ERROR: Flash Jetson Linux - flash: 131072+0 records in
20:40:26 ERROR: Flash Jetson Linux - flash: 131072+0 records out
20:40:26 ERROR: Flash Jetson Linux - flash: 67108864 bytes (67 MB, 64 MiB) copied, 0.170268 s, 394 MB/s
20:40:31 ERROR: Flash Jetson Linux - flash: /home/donnylu/nvidia/nvidia_sdk/JetPack_6.0_DP_Linux_DP_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/L4TConfiguration_updated.dts: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
20:40:31 ERROR: Flash Jetson Linux - flash: /home/donnylu/nvidia/nvidia_sdk/JetPack_6.0_DP_Linux_DP_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/L4TConfiguration.dtbo: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
20:40:32 ERROR: Flash Jetson Linux - flash: [ 0.6113 ] ERROR: value 0x31 is out of range
20:40:32 ERROR: Flash Jetson Linux - flash: [ 0.6119 ] ERROR: value 0x31 is out of range
20:40:32 ERROR: Flash Jetson Linux - flash: [ 0.6121 ] ERROR: value 0x31 is out of range
20:40:32 ERROR: Flash Jetson Linux - flash: [ 0.6122 ] ERROR: value 0x31 is out of range
20:40:34 ERROR: Flash Jetson Linux - flash: [ 2.3012 ] ERROR: /ratchet/atf is not supported
20:40:35 ERROR: Flash Jetson Linux - flash: [ 3.7556 ] ERROR: /ratchet/atf is not supported
20:40:35 ERROR: Flash Jetson Linux - flash: [ 3.7647 ] ERROR: /ratchet/atf is not supported
20:40:36 ERROR: Flash Jetson Linux - flash: [ 4.1924 ] ERROR: value 0x31 is out of range
20:40:36 ERROR: Flash Jetson Linux - flash: [ 4.1931 ] ERROR: value 0x31 is out of range
20:40:36 ERROR: Flash Jetson Linux - flash: [ 4.1932 ] ERROR: value 0x31 is out of range
20:40:36 ERROR: Flash Jetson Linux - flash: [ 4.1933 ] ERROR: value 0x31 is out of range
20:40:38 ERROR: Flash Jetson Linux - flash: 74756 blocks
20:40:47 ERROR: Flash Jetson Linux - flash: 128307 blocks
20:42:32 ERROR: Flash Jetson Linux - flash: Error: The backup GPT table is corrupt, but the primary appears OK, so that will be used.
20:53:06 ERROR: Flash Jetson Linux - flash: [exec_command]: /bin/bash -c /tmp/tmp_NV_L4T_FLASH_JETSON_LINUX_COMP.donnylu.sh; [error]: 128307 blocks
20:53:06 ERROR: Flash Jetson Linux - flash: command terminated with error
20:53:06 SUMMARY: Flash Jetson Linux - flash: First Error: Installation failed.
20:38:11 INFO: Flash Jetson Linux - flash: [ 3.7268 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
20:38:11 INFO: Flash Jetson Linux - flash: [ 3.7271 ] 32768+0 records in
20:38:11 INFO: Flash Jetson Linux - flash: [ 3.7589 ] 32768+0 records out
20:38:11 INFO: Flash Jetson Linux - flash: [ 3.7589 ] 32768 bytes (33 kB, 32 KiB) copied, 0.0314563 s, 1.0 MB/s
20:38:11 INFO: Flash Jetson Linux - flash: [ 3.7589 ] Concatenating BCT for chain A to bct_backup.img
20:38:11 INFO: Flash Jetson Linux - flash: [ 3.7589 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
20:38:11 INFO: Flash Jetson Linux - flash: [ 3.7594 ] 8192+0 records in
20:38:11 INFO: Flash Jetson Linux - flash: [ 3.7647 ] 8192+0 records out
20:38:11 INFO: Flash Jetson Linux - flash: [ 3.7647 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.00496522 s, 1.6 MB/s
20:38:11 INFO: Flash Jetson Linux - flash: [ 3.7722 ] Parsing config file :tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb
20:38:11 INFO: Flash Jetson Linux - flash: [ 3.7723 ] Added Platform Config 0 data with size :- 2416
20:38:11 INFO: Flash Jetson Linux - flash: [ 3.7743 ] Added Platform Config 2 data with size :- 24
20:38:11 INFO: Flash Jetson Linux - flash: [ 3.7745 ] Added Platform Config 3 data with size :- 52
20:46:08 INFO: Flash Jetson Linux - flash: Writing /mnt/internal/eks_t234_sigheader.img.encrypt (9232 bytes) into /dev/mtd0:54919168
20:46:08 INFO: Flash Jetson Linux - flash: Copied 9232 bytes from /mnt/internal/eks_t234_sigheader.img.encrypt to address 0x03460000 in flash
20:46:08 INFO: Flash Jetson Linux - flash: Writing display-t234-dce_with_tegra234-p3768-0000+p3767-0005-nv_with_odm_overlay.dtb_aligned_blob_w_bin_sigheader.bin.encrypt (parittion: B_dce-fw) into /dev/mtd0
20:46:09 INFO: Flash Jetson Linux - flash: Writing spe_t234_sigheader.bin.encrypt (parittion: B_spe-fw) into /dev/mtd0
20:46:11 INFO: Flash Jetson Linux - flash: [ 220]: l4t_flash_from_kernel: Warning: skip writing worm partition as no image is specified
20:46:11 INFO: Flash Jetson Linux - flash: Writing bct_backup.img (parittion: BCT-boot-chain_backup) into /dev/mtd0
20:46:11 INFO: Flash Jetson Linux - flash: Sha1 checksum matched for /mnt/internal/bct_backup.img
20:46:11 INFO: Flash Jetson Linux - flash: Writing /mnt/internal/bct_backup.img (32768 bytes) into /dev/mtd0:66715648
20:46:11 INFO: Flash Jetson Linux - flash: Copied 32768 bytes from /mnt/internal/bct_backup.img to address 0x03fa0000 in flash
20:46:11 INFO: Flash Jetson Linux - flash: Copied 16896 bytes from /mnt/internal/gpt_backup_secondary_3_0.bin to address 0x03fc0000 in flash
20:46:11 INFO: Flash Jetson Linux - flash: Writing qspi_bootblob_ver.txt (parittion: B_VER) into /dev/mtd0
20:46:11 INFO: Flash Jetson Linux - flash: Sha1 checksum matched for /mnt/internal/qspi_bootblob_ver.txt
20:46:12 INFO: Flash Jetson Linux - flash: [ 221]: l4t_flash_from_kernel: Successfully flash the emmc
20:46:12 INFO: Flash Jetson Linux - flash: Active index file is /mnt/external/flash.idx
20:46:12 INFO: Flash Jetson Linux - flash: writing item=1, 9:0:primary_gpt, 512, 19968, gpt_primary_9_0.bin, 16896, fixed--0, f15dd33f8c6188259a0802ec3a1cdd06c9888e64
20:46:12 INFO: Flash Jetson Linux - flash: dd if=/mnt/external/boot.img of=/dev/mmcblk0 bs=1K skip=0 seek=20 count=52528
20:46:18 INFO: Flash Jetson Linux - flash: 241664 bytes (242 kB, 236 KiB) copied, 0.0227394 s, 10.6 MB/s
