Jetson Orin Nano devkit flash failing
I am trying to flash jetpack 6.0 on orin nano 8gb in ubuntu 20.04.
This error occurred and nothing progresses. please help me…
10:37:42 INFO: Flash Jetson Linux - flash: [ 0.2439 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
10:37:42 INFO: Flash Jetson Linux - flash: [ 0.2454 ] BR_CID: 0x80012344705DF2060C00000016FF80C0
10:37:42 INFO: Flash Jetson Linux - flash: [ 0.2815 ] Sending bct_br
10:37:53 ERROR: Flash Jetson Linux - flash: [ 0.3309 ] ERROR: might be
10:37:53 INFO: Flash Jetson Linux - flash: timeout in USB write.
10:37:53 ERROR: Flash Jetson Linux - flash: Error: Return value 3
10:37:53 INFO: Flash Jetson Linux - flash: Command tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
10:37:53 ERROR: Flash Jetson Linux - flash: — Error: Reading board information failed.
10:37:53 ERROR: Flash Jetson Linux - flash: *** ERROR: Parsing boardid failed
10:37:53 ERROR: Flash Jetson Linux - flash: [exec_command]: /bin/bash -c /tmp/tmp_NV_L4T_FLASH_JETSON_LINUX_COMP.suhyun.sh; [error]: *** ERROR: Parsing boardid failed
10:37:53 INFO: Flash Jetson Linux - flash: [ Component Install Finished with Error ]
10:37:53 INFO: Flash Jetson Linux - flash: [host] [ Disk Avail on Partition : 0.00 B ]
SDKM_logs_2024-07-03_10-38-52.zip (339.5 KB)
10:37:42.803 - Info: [   0.2815 ] Sending bct_br
10:37:53.214 - Info: [   0.3309 ] ERROR: might be
10:37:53.214 - Info: timeout in USB write.
10:37:53.228 - Info: Error: Return value 3
sudo -s
echo -1 > /sys/module/usbcore/parameters/autosuspend
After executing this, I tried flashing again, but this error appeared.
11:47:45 ERROR: Flash Jetson Linux - flash: [ 0.0209 ] ERROR: failed to read rcm_state
11:47:56 ERROR: Flash Jetson Linux - flash: [ 0.2644 ] ERROR: mig
11:47:56 ERROR: Flash Jetson Linux - flash: Error: Return value 3
11:47:56 ERROR: Flash Jetson Linux - flash: — Error: Reading board information failed.
11:47:56 ERROR: Flash Jetson Linux - flash: *** ERROR: Parsing boardid failed
11:47:56 ERROR: Flash Jetson Linux - flash: [exec_command]: /bin/bash -c /tmp/tmp_NV_L4T_FLASH_JETSON_LINUX_COMP.suhyun.sh; [error]: *** ERROR: Parsing boardid failed
Disable USB auso suspend → unplug the flashing cable → put the device in force recovery mode again → plug in the flashing cable → flash again
Current progress.
After rebooting the computer
sudo -s
Enter command - run SDK - connect Orin Nano via USB
and this error…
11:55:35 ERROR: Flash Jetson Linux - flash: [ 0.0283 ] ERROR: failed to read rcm_state
11:55:45 ERROR: Flash Jetson Linux - flash: Error: Return value 3
11:55:45 ERROR: Flash Jetson Linux - flash: — Error: Reading board information failed.
11:55:45 ERROR: Flash Jetson Linux - flash: *** ERROR: Parsing boardid failed
11:55:45 ERROR: Flash Jetson Linux - flash: [exec_command]: /bin/bash -c /tmp/tmp_NV_L4T_FLASH_JETSON_LINUX_COMP.suhyun.sh; [error]: *** ERROR: Parsing boardid failed
11:55:45 ERROR: Flash Jetson Linux - flash: command terminated with error
how can i fix it? please help me…
Is it still the same error you previously met?
Give a try to another host PC/USB cable.
I tried c to c, a to c, and each port on the pc. Yesterday, an error occurred on another PC as well. Is there any other way?
12:39:28 ERROR: Flash Jetson Linux - flash: [ 0.0147 ] ERROR: failed to read rcm_state
11:55:19 INFO: CuDNN on Target - target: Found file /home/suhyun/Downloads/nvidia/sdkm_downloads/cudnn-local-tegra-repo-ubuntu2204-8.9.4.25_1.0-1_arm64.deb with correct checksum, skip downloading.
12:39:38 ERROR: Flash Jetson Linux - flash: [ 0.2716 ] ERROR: m
12:39:38 ERROR: Flash Jetson Linux - flash: Error: Return value 3
12:39:38 ERROR: Flash Jetson Linux - flash: — Error: Reading board information failed.
12:39:38 ERROR: Flash Jetson Linux - flash: *** ERROR: Parsing boardid failed
12:39:38 ERROR: Flash Jetson Linux - flash: [exec_command]: /bin/bash -c /tmp/tmp_NV_L4T_FLASH_JETSON_LINUX_COMP.suhyun.sh; [error]: *** ERROR: Parsing boardid failed
12:39:38 ERROR: Flash Jetson Linux - flash: command terminated with error
That’s all you can do.
???So I can’t use orin??? What should I do?
SDKM_logs_2024-07-03_13-05-59.zip (249.8 KB)
Make sure you are following every steps mentioned here.
