Jetson AGX Orin FAQ
Q: Sometimes noise screen is shown when rebooting or shutting down the device
Please apply this solution:
When enabling rt build in Jetpack6.2, white noise appears on the screen during restart - #13 by wichiu
Q: How to apply PCN210100 overlay patch?
PCN210100 is supported from Jetpack 5.1.3. If you are using 5.1.1 or 5.1.2, there are overlay packages in:
Jetson Linux 35.3.1 | NVIDIA Developer
Jetson Linux 35.4.1 | NVIDIA Developer
If your device is AGX Orin 64GB, please also add the patch mentioned in below link:
AGX orin 64GB flash fail - #3 by DaveYYY
Without this patch, Orin AGX 64GB with PCN update may not get flashed
Q: I cannot control GPIO in Jetpack 6.0, 6.1 and 6.2, but it works with JP 5.x
It may be caused from SFIO(bit 10) been set by gpiod.
Please apply the following patch if you want to control GPIO but using JP6.0(R36.3.0) or JP6.1(R36.4.0)
40hdr - SPI1 gpio padctl register bit[10] effect by gpiod tools in JP6 - #20 by KevinFFF
It is fixed in Jetpack 6.2.2 r36.5
Q: How do I know which Jetson Linux release I am using?
Please execute the command to get information:
$ cat /etc/nv_tegra_release
# R35 (release), REVISION: 1.0, GCID: 31346300, BOARD: t186ref, EABI: aarch64, DATE: Thu Aug 25 18:41:45 UTC 2022
If you see R34, the release is developer preview, and please upgrade to at least >= r35.1
Q: How to know if I use Orin developer kit or Orin 32GB module?
Please execute the command:
$ cat /etc/nv_boot_control.conf
And check the information:
[Orin developer kit]
TNSPEC 3701-RC1-0000-C.0-1-1-jetson-agx-orin-devkit-
[Orin 32GB module]
TNSPEC 3701-500-0004-G.0-1-1-jetson-agx-orin-devkit-
Q: How can we get UART log from AGX Orin developer kit for further debugging?
Please refer to this page: Making sure you're not a bot!
Q: I hit an issue and need to have a solution. Could you help?
We have quick solutions for some known issues. Please check
Q: I get a USB timeout error during flash Orin. How to resolve that?
A known issue for ubuntu 20.04 host is the USB autosuspend function is enabled on it by default. This leads to Jetson recovery mode gets suspended before flash. To bypass this error, need to:
  1. Disable autosuspend on host PC with below command:
sudo -s
echo -1 > /sys/module/usbcore/parameters/autosuspend
  1. Plug out the USB cable, put jetson back into recovery mode again and plug the usb cable back.
Or please try Fix for "ERROR: might be timeout in USB write" - increase usbfs_memory_mb to 2048
If USB timeout is still there after above commands, please file a topic to forum and let moderator help check.
Q: Is there any example of running RTSP streaming?
For Jetpack 5, please download test-launch.c of 1.16.2:
gst-rtsp-server/examples/test-launch.c at 1.16.2 · GStreamer/gst-rtsp-server · GitHub
For Jetpack 6, please download 1.20 from
And refer to steps in Jetson Nano FAQ
Real practices on Orin:
RTSP Server (GStreamer) on Jetson Orin – Only one VLC client works with shared pipeline (appsrc + nvv4l2h264enc) - #10 by DaneLLL
RTSP Server (GStreamer) on Jetson Orin – Only one VLC client works with shared pipeline (appsrc + nvv4l2h264enc) - #14 by DaneLLL
Q: Is there an example for running UDP streaming?
A: Please refer to the posts:
Gstreamer TCPserversink 2-3 seconds latency - #5 by DaneLLL
Real-Time Camera UDP Stream VLC Player Problem - #6 by DaneLLL
Slow GStreamer accelerated pipeline - #5 by DaneLLL
Hosting Multiple Remote Streams Using Compositor Gstreamer - #11 by DaneLLL
Q: How to autorun an app or commands at startup?
A: Please refer to Jetson Nano FAQ
Q: How to autorun a command before rootfs mounted?
A: Pleaser refer to SSD e2fsck in /etc/fstab - #9 by KevinFFF for this use case.
Q: I have a USB camera. How can I launch it on AGX Orin?
nvoverlaysink is deprecated on Jetpack 5 releases. Please use nv3dsink, nveglglessink, or nvdrmvideosink.
Q: Cannot run Cheese app to launch a USB camera
A: Please check the post:
Open cheese failed in JetPack 6.0 - #6 by DaneLLL
Q: Is hardware acceleration enabled in ffmpeg?
Wee have enabled hardware decoding. Hardware encoding is not supported.
Please check developer guide
and this post for downloading source code and building the package
If you would like to use later version, please check the community contribution:
Installing ffmpeg on jetson docker image (nvcr.io/nvidia/l4t-jetpack:r36.4.0 ) - #7 by barry14
Q: How to remove the texts printed in UEFI logo?
Those texts are from both UEFI and kernel.
Please refer to How can I remove text printing from the UEFI Logo interface? - #4 by KevinFFF for the paths
Q: There is a wait in UEFI stage. How to disable it to accelerate system booting?
Please refer to the UEFI source
edk2-nvidia/Platform/NVIDIA/NVIDIA.common.dsc.inc at main · NVIDIA/edk2-nvidia · GitHub
gEfiMdePkgTokenSpaceGuid.PcdPlatformBootTimeOut|L"Timeout"|gEfiGlobalVariableGuid|0x0|5
This 5 seconds is for user to interrupt and enter UEFI menu. It could be customized setting to 0 to disable.
For R36.5 and later releases like R38.x and R39.x, please refer to the following thread for the customization.
UEFI Adaption and Splash Screen - #20 by KevinFFF
Q: New boot device causes boot-order changed. How can I configure them in runtime?
User can configure New Boot Devices to the “Bottom” of the Boot Order and reconfigure the existing boot order.
Rin Nano 8GB Developer Kit - Realtek PHY MAC Address Change Causes Boot Issue - #8 by KevinFFF
Q: Is there any tips for debugging UEFI?
Please rebuild the UEFI source with the link above. After you rebuild it, there would be a debug version of binary. Please replace the old “uefi_jetson.bin” file in your BSP folder and then reflash the board. It will enable full log in UEFI.
Q: There is an error in source_sync.sh script. How to resolve it?
If you are syncing rel-35.2.1 and as below error. Then it is not fatal. Those files are not needed for Orin compilation. You could just ignore it.
→ Fatal: remote error: access denied or repository not exported: /device/hardware/nvidia/platform/t23x/prometheus-dts
Q: Flashing over USBSS.
Flashing over USBSS is not supported at present.
Q: Is the DC Jack on Xavier devkit compatible to that of Orin?
Yes, they are compatible, and some customer validated that.
Q: What is the Orin power consumption of SC7?
The CVM power at SC7 is ~300mW. The CVM+CVB total power is close to 1.1W.
Q: RTC0 or RTC1 for default RTC clock during power off?
The Orignial default RTC source is set as RTC1 (Orin_RTC), which can not keep time if power off. So a patch to set default RTC to RTC0 (PSEQ_RTC) is needed.
Q: Does MGBE lines support P/N reversal?
Yes, the 10G ethernet PHY support P/N correction automatically. To make the trace smooth, we swap P and N.
Q: What is the usage of pin MOD_TEMP_SHDN_EN_N (J62) in P3737_A04?
MOD_TEMP_SHDN_EN_N is not used on commercial module. It is for Auto/industrial module to gate buffers of temp_therm and soc_pwr_req. Suggest to short to GND to keep the messaging consistent across all modules: floating = TEMP_THERM and SOC_PWR_REQ gated, GND= un-gated.
Q: Is there a signal output can be used to indicate a SW RESET thing?
There is no explicit pin on Orin that indicates an internal SW reset has occurred. Internal SW reset does not propagate to the IO pin. One way to set an indicator is to use the internal watchdog timer and use WDT_RESET_OUTA (GP63) or WDT_RESET_OUTB (GP21) as the indicator. Both signals are available on the CVM connector.
Q: How to enable HDMI on Orin AGX if I design a custom board?
Please refer to below post to modify necessary software change in device tree and pinmux.
HDMI Display does not work after update to JetPack 5.0.2 - #27 by WayneWWW
Q: How to read bootloader version with userspace command?
$ cat /sys/devices/virtual/dmi/id/bios_version
$ cat /sys/devices/virtual/dmi/id/bios_date
Q: Why thermal zone/tegrastats reports -256C?
The GPU, CV power rails might be turned off at idle by run time power management. The temperature cannot be read from GPU, CV thermal sensors when the power is off. Attempts to read a sensor with the power off will return error code -256000.
Q: How to run realsense camera on Orin devices?
Please refer to the methods:
Problem installing Intel d435 camera - #5 by carolyuu
Connecting Intelrealsense Depth Camera D455 to Jetson Orin Nano 8GB - #5 by DaneLLL
If the camera has IMU, please try the steps from 3rdparty:
Realsense device is not being detected in Nvidia Jetson Orin Nano Dev kit · Issue #13892 · realsenseai/librealsense · GitHub
Q: Where to download the Cypress firmware for AGX Orin?
Please go to the page: Jetson Linux 35.2.1 | NVIDIA Developer
Additional Files
Please note it can be used for either Jetpack 5 version, not specific to r35.2.1
Q: How to run developer kit in headless mode?
Please refer to this post
The example is for Orin Nano and applicable to AGX Orin, Orin NX. Please ensure correct device tree file is modified.
Q: How to configure VNC w/o monitor connected for Jetson?
Please reference detail steps from: What is the best way to control the jetson Orin GUI remotely? - #5 by KevinFFF
Q: My device got stuck in “recovery boot”. How to recover without reflashing?
please refer to this post
Q: In UEFI, Why press F9 to Reset to Defaults will cause Auto Boot Time-out to 0s?
It’s an known issue, but it would not affect the functionality of UEFI.
Auto Boot Time-out means the timeout for waiting user’s interrupt to enter UEFI menu.
Q: Why my device enters into recovery boot after successive reboots?
It may be caused from that you run reboot command before nv-l4t-bootloader-config.service gets ready.
You could refer to https://forums.developer.nvidia.com/t/reset-timing-of-boot-retry-count/277168/7 for the logic of retry count.
Q: How to flash external storage devices with WSL2?
For flashing eMMC/SD card with flash.sh, the default setting of WSL2 will work fine.
However, if you are trying to use initrd flash to flash NVMe/USB, please refer to the following post to re-build the Linux kernel with a customized kernel config, as the default kernel of WSL2 shipped by Microsoft lacks some functionalities that are required for initrd flash to work.
Flash Jetson Orin Nano WSL2 - #9 by henkman
Q: How to test DMA performance of Orin PCIe EP ?
For rel-35, need to follow below post
AGX Orin Devkit PCIE bandwidth test - #4 by WayneWWW
Q: How to set up static IP address?
Please refer to the post:
How to configure static IP on Jetson AGX Orin with JP5.1.1 - #3 by DaneLLL
Q: How to set different partition sizes for APP and APP_b when ROOTFS_AB is enabled?
You need to modify three files in total: flash.sh, board config file, and partition layout file.
Refer to this post for more detail:
Modify APP and APP_b partitions sizes - #22 by DaveYYY
Q: Why can’t I use nvbootctrl on JetPack 5 + RT kernel?
It’s an issue in the upstream Linux kernel, and please refer to this post to enable/mount efivarfs to fix it:
Error: read variable BootChainFwCurrent failed! - #14 by DaveYYY
Q: How to build an OpenCV with CUDA support on JetPack 6.0 GA?
An auto-build script is available. Please check here for info.
Q: How to upgrade TensorRT 10.0GA on JetPack 6.0 GA?
Please refer to the below post:
Is it possible to already use TensorRT 10 on Jestson AGX Orin - #10 by AastaLLL
Q: How to set OFA frequency to max on Jetpack 6.0 GA?
Please run the below command:
# echo performance > /sys/class/devfreq/15a50000.ofa/governor
Q: On Jetpack 6 release, we cannot launch 8+ decoding/encoding processes.
On JP6 the allocation of hardware resource is refined. If hardware resource is insufficient, it fail to create the process. So for running 8+ decoding/encoding tasks, please create multiple threads in single process. Some discussion in the topic:
Please use Jetpack 6.1/6.2/6.2.1, apply the patches and rebuild kernel:
Orin AGX Jetpack 6 NVDEC limitation of <= 8 streams - #7 by DaneLLL
The patches are included in Jetpack 6.2.2 r36.5.
Q: How to configure rootfs as read-only file system?
Please modify the following line in /etc/fstab
# <file system> <mount point>             <type>          <options>                               <dump> <pass>
- /dev/root            /                     ext4           defaults                                     0 1
+ /dev/root            /                     ext4           ro,errors=remount-ro                         0 1
And note that this operation cannot be reversed because it can not be modified with read-only file system.
Q: How to install PyTorch
Please refer to PyTorch for Jetson to install corresponded version.
Q: docker 28.0.0 is not working on r36.4.3.
The latest docker fails on JetPack 6.2 as it requires extra kernel configs. Please find this comment for the workaround.
Q: Is there a devel l4t-cuda container for JetPack 6.1/6.2?
Yes, please find the container in this link.
Q: Disable HDMI2.1 items
Please refer to this link to apply patch link
Q: How to disable auto upgrade in Ubuntu system?
Please refer to this link and run commands in the system link
Q: Rootfs-A/B fail to switch to the other slot with Yocto.
Please check whether this is Yocto specific issue to confirm it was missing EFI integration in the Yocto configuration.
if yes.. add the following to the Yocto distribution to fix it. DISTRO_FEATURES += "efi"
please see-also Topic 352631.
Q: How to add 2nd fan configuration for nvfancontrol service
please check Topic 348680 for the steps to edit /etc/nvpower/libjetsonpower/jetsonpower_t234.conf and also /etc/nvfancontrol.conf for adding 2nd fan into nvfancontrol service.
Q: How to remove default user created by l4t_create_default_user.sh
Please refer to this link to run mentioned instructions.
Q: How to fix a forgotten password when login Ubuntu
Please refer to this link.
Q: How to run Kubernetes on JetPack 6
Q: How to remove PXE boot option
Q: Mmc0: Timeout waiting for hardware interrupt (emmc fw update)
please refer to this link Mmc0: Timeout waiting for hardware interrupt - #10 by WayneWWW
Q: DLA runtime unavailable on JetPack 7.2
DLA support is added in TensorRT 11.3. Please refer to DLA runtime unavailable on JetPack 7.2 (L4T R39.2) — Cannot create DLA engine - #12 by AastaLLL
Headless Setup for Jetson Orin Nano
Optimizing UEFI boot time
Jetson agx orin flash失败,
Hdmi doesn’t work for some monitors ,Discovering Again
Jetson Gstreamer NVRmMemInit failed
N/W DMA into Hardware buffer
Ethernet via RGMII on custom board
Ethernet ip setting
JETSON-AGX-ORIN reflash R35.6.0 ‘ERROR: might be timeout in USB write’
Accelerated HW Decoding with FFMpeg
Headless setup for jetson orin nano
Red and blue color swap while using HDMI
Jetson AGX Orin 64GB devkit flash issues
Massflash in Orin
Massflash in Orin
Orin has black screen after jetpack upgrade, fan 100% and "Reading board information failed"
Continuing the discussion from [Uefi assert and broken again]
Jetson Orin Nano headless system installation
Export video stream from Orin Nano to a remote display
Use netplan.io apply static ip will cause kernel warning
SDK uefi boot disable
How can I migrate system from emmc to nvme in my AGX orin
Having 2d Lidar data and Odometry to make 3d depth map
冷启动时间优化
How to enlarge the shared-dma-pool on orin?
Jetpack 5.1.1 not booting on AGX Orin SOM
RTSP Video Output Gstreamer Error: no element "nvv4l2h264"
Gstreamer issue streaming USB camera from Xavier NX over UDP
Vi error when update 36.3.0
Emulate AGX ORIN to NANO without data loss
Start up current and voltage for NVIDIA Jetson AGX Orin 64GB Development Kit
Jetson Orin Nano Video Encoding
Jetpack 6 install Error on Jetson Orin Nano
Cvm eeprom fails to read during boot
Overlay without eeprom
Boot Issue on AGX Orin Custom Board – ASSERT [FvbNorFlashStandaloneMm] Error
Orin nx烧录成功, 启动失败
When boot, can i skip desktop view with long time login logo?
Jetson agx orin goes into emergency mode
AV1/RTSP Streaming Not Working
ORIN NX适配Intel® RealSense™ D457 camera
Rgmii接8211phy,导致原来的pcie的8111phy无法工作
Ubuntu的恢复模式
Jetson Orin Nano stopped booting
Jetson AGX Orin unstable ssh
Mmc1 Data timeout error
GStreamer pipeline takes 2 minutes to start? NVENC HW engine?
Disable ota auto upgrade
Flashing linux on nvme ssd fails at mount of NFS server
How configure the Orin AGX 32/64G with Jetpack 5.1.2 to default to HDMI display output instead of DP?
USB0 Flashing in Recovery Mode Failure
Modprobe: FATAL: Module openvswitch not found in directory /lib/modules/5.15.148-tegra
Uninstall Open CV
jp6.2系统的PINMUX问题
Issue with Arducam PTZ Camera After Installing OpenCV with CUDA
AGX Xavier Boot Time
No DP Video Output
SDK --- FLASHing woes (continues......)
Jetson AGX cannot control the PAC.04 pin in version R36.3
Is there any example how to use nvenc/nvdec in python?
Cannot flash my Jetson Orin nano
Cannot run 8 cameras at the same time
Unable to flash Jetson Orin Nano
Flashing issues using WSL
How can I use UART3@0xc280000 in UEFI Bootloader
SSH Access Issue After Flashing Jetson Orin Nano with Minimal Rootfs
Enable Night mode in Jeton Nano
Jetson AGX Orin: Can't Connect GigE Camera
Flashing Jetpack 6.1 to Orin NX 16G on custom board stucks at "Waiting for target to boot-up..."
Gstreamer使用vic加速时概率性报错
Can't open any file in Jetson AGX Xavier when it is opened through NoMachine
Does Video data output available over PCIe or MGBE in Jetson AGX Orin 64GB SoM?
Orin has entered the Recovery Boot
Jetson AGX working with Meta Quest 3
Flash Failed - New SSD Drive
Restore Nvme Clone Writing system.img takes forever
Video Stream from Jetvariety arducam ar0234 to PC over UDP
ORIN NX 8G无法正常启动,修改启动项之后启动正常
Intel RealSense D435i Not Detected on Jetson Orin Nano with JetPack 6.0 and SDK Version 2.55.1
After the agx orin is powered on, the first rtmp push multiplexes are stuck
How to check nvidia module P/N or CPU P/N?
Can not update firmware when setting up Jetson Orin Nano
Hardware differences between Orin AGXs
Lose WiFi modules of Jetson AGX Orin
GStreamer Warning and Black Screen with USBCamera on Jetson
Query about Parallel Processing for Video Frame Conversion Using nvvidconv on Jetson AGX Orin
Nomachine remote error jetpack5.1.2
Unable to flash | Factory Reset
使用jetpack5.1.3 Linux for tegra 和 kernel编译的Image刷机后,HDMI无显示
About tc-tapiro, tc-mqprio, the support of mapping traffic flows to hardware queue ranges
UART sends data causing Jetson to fail to start properly
How to set and modify static IP on the Jetson Linux 32.6.1? (/etc/init.d/NetworkMange)
Error using Jetpack 6.2 with realsense D455 camera (jetson orin NX)
Linux sysfs's spectre_v2 output is different in two orin ,Why? and What consequences will it bring?
Jetpack r36.2.0: Change in multimedia API?
Recording script based on gstreamer doesn't work with Dahua camera
5.1.2 update to 5.1.4, is there a convenient method to update
Can not boot on after refreshing the device tree
How to disable the UEFI runtime services?
The package nvidia-l4t-core needs to be reinstalled
How to apply fsck for /dev/mmcblk0p1
Jetson AGX Orin 64GB Dev Kit not powering on
Jetson Orin Dev Kit is not power on
JP 6.0 RT_Patch Flash Issue with Initrd
Jetson Orin 32G / Devkit board / TOS / Unhandled Exception from EL1
PEX_WAKE_N no Function
Install JetPack 6.2 failed with SDK manager on AGX orin 64G
RTSP stream transmission using gstreamer
Are recent bootloaders backward compatible?
Increasing latency when using Gstreamer in OpenCV
Why does Jetson Orin Nano suddenly fail to turn on, it keeps being stuck in this interface, and there is no picture when I connect the monitor directl
VNC to connect AGX orin without a connected monitor
Intel Realsense camera doesn't work on Nvidia Orin Nano board with Jetpack 6.0
Jetson AGX Orin Unable to read data from USB video capture card!
AGX Orin Flash Jetson Linux failed
Jetson agx orin customised carrier board is hanging while in boot process
Reporting the message "Reading board information failed." when burning the custom board of Orin NX with version 36.2. Do you have any suggestion?
Orin nano Developer kit takes long time to boot
Unable to flash Jetson Agx Orin 64gb dev kit
Orin boot up long time
JetPack6.1 Kernel build error
Orin 运行中出现 [kworker/6:0+pm] 进程cpu占用 100%
Disable NVIDIA bootloader screen JP5.1.2
How to initrd in Jetson Orin NX
VNC access on headless system running JetPack 5.1.x
I met some questions that confused me, I'd like to know if these questions are caused by the old Jetpack version
Jetson Orin NX 8GB and Orin Nano 8GB fails to boot
Problem during flashing on sd card
How to view video stream in GPU memory(CUDA memory)
Setting up & running sample app on Jetson Orin Nano
Orin AGX no boot, no UART, after flashing secure boot and encrypted internal disk
Parsing board information failed. Error: failed to generate images in orin nano
USB WEBCAM FRAME CHANGE IS VERY SLOW
Jetson Orin Nano Headless VNC Setup Guide
Device won't go past boot
Unable to start orin nx
Is it possible to run a GStreamer pipeline in headless mode with the source plugin nvarguscamerasrc?
The nx connected to the virtual realiser uses the GPU
Jetson Orin WIFI&Lan module disappeared after rt_kernel built
Unable to flash NVMe in Jetson Orin Nano 8GB Waveshare
Jetson ORIN系列HDMI支持4K吗
"read rcm_state" error while flashing jetson-agx-orin
Kernel panic as result of CPU:0, Error:cbb-noc error on L4t 35.4.1
Nvidia xavier emmc corruption after reboot when using jetpack 5.1.2
Flashing failed Depnds on failed component
Jetpack 6.0: mgbe_payload_cs_err increasing after MACsec removal on orin
Jetson AGX Orin Bootup Failed
Rtsp stream
AGX - No video output on wide-screen
Flashing fails
Chromium/Electron Applications Hang on Launch on GNOME Wayland
How to setup a VNC server with 1080p resolution
Jetson AGX Orin Developer Kit (64GB) unable to Boot from nvme SSD after removing it
Sources for the max96724 deser driver
How to apply GPIO patch for Jetpack 6.x for Orin AGX Devkit
Orin NX - Getting display back to monitor from headless
Error in attempting to reflash from SDK Manager on AGX Orin Devkt 64GB
Building issue - Linux kernel module on RT linux - 5.15.148-rt-tegra
Could not flash my brand new Jetson Orin Nano 8G Devkit
Orin NX unable to boot after days in fully functional operation
Eliminating black screen flashes during boot splash transitions on Jetson Orin NX
Orin devkit 启动失败
Docker compose is weird
Headless setup
How can I only update UEFI image
3D body pose
Jetson Orin NX Latency and Accelerated Gstreamer help
Jetson AGX is not detecting the Intelrealsense D435ia
Unable to Flash firmware on Jetson AGX Orin 64GB
Confuse on nvidia-l4t-kernel.deb
How does the Xavier AGX enter recovery mode?
Orin PCN211461
Disabling bios screen
What is the maximum number of encoder instances that can be created concurrently on Orin?
Can I use Win11 wsl for sdk manager?
How to config PCIe C4 on AGX orin
Jetson AGX ORIN Install error
Jetson Xavier NX connection with ground without internet for live processed video transmission (Distance 5 or 6km (UAV altitude from ground))
AQR113C - How to program. (Boot/Flash)
Disable Jetson Bootloader progress bar
Eeprom fails to read when setting I2C1 to input in pinmux config, causing fail at boot
Headless mode
InitNVDEC: Host1x channel open failed
Flashing with Ubuntu 24.04/Docker sdkmanager-2.2.0.12028-Ubuntu_22.04_docker.tar.gz libc-bin segmentation fault
SDKManager Jetson Orin AGX 32GB flash failed
Jetson AGX Orin booting to black screen
Issue Enabling UEFI Secure Boot Using UEFI Utilities on Jetson Orin
Failed to flash the NVMe SSD with SDKManager
How to remove the gestures from chromium while running in Kiosk mode
Video streaming using jetson orin nano
Cannot flash Jetson AGX orin: “Reading board information failed”
How to set iptables on Jetson AGX Orin
Deepstream gst-launch-1.0
USB Camera (C920)Detected via v4l-utils but not working to get streaming in Jetson Orin Nano
Jetson agx orin启动失败,报错Launcher: Attempting Recovery Boot
[gstreamer] gstCamera::Capture() -- a timeout occurred waiting for the next image buffer
SDK Manager fails to flash to nvme
Kernel Panics with Memory Mapped access on Jetson AGX Orin
Streaming
HELP Can't flash Jetson Orin Nano 8GB with SDK Manager
Flashing using VM
How to stream CCTV footage in real-time and set up ROI (Regions of Interest) and tripwire configurations
Need to initialized the Jetson AGX Orin host machine
JetPack 6.0 (r36.3) Jetson Multimedia API Transform UYVY to YUV420 for JPEG
Orin 32GB Modulewith DevKit Carrier Board on JetPack5.1.1 cause Kernel Panic
Realsense Viewer cannot detect depth camera on Jetson orin nx super 16GB Jetpack 6.2
Problem with receiving RTSP stream
No Display Output After Booting Jetson AGX Orin
Jetson linux 36.4.3 falsh error
GPU Usage of Argus ISP Pipeline
Libargus latency with imx390 capture
FFmpeg vs GStreamer for GMSL camera encoding
AGX ORIN 64GB failed to Flash
Orin SDcard Issue
USB 3.2 & 2.0 Recovery Mode Design Questions
Insert-seq-hdr with jetson_multimedia_api
Cannot flash agx orin in recovery mode
V4l2_nv_extensions.h -Wextra-semi compiler error
The I2C@3190000 in orin jetpack6 cannot work
Failed to flash jetpack 6.0
USB Connection Issues When Flashing Jetson AGX Orin with JetPack 6.x/5.x- Installation Fails
Install the T265 driver but neither the binary installation nor the source installation recognizes the device
Jetson Nano USB Camera issues with Timeout Occurred
I would like to consult some questions about UEFI optimization。
Getting feed from an AV display to Jetson ORIN NX via clearclick converter
The same autonomous driving program consumes significantly different CPU usage on different machines
UEFI/Bootloader SDMMC disable probe
Jetson AGX Orin: Bluescreen after update to JetPack 6.2
Sdkmanager flash ERROR: failed to read rcm_state
Flash Error(ERROR: failed to read rcm_state)
When reflash module or whole device ,happened an error
Using gst-launch-1.0 pipeline to Receiving (on target) : Network Source + video decode + video render
How to flash to nvme instead of emmc
Jetson Orin NX 8GB Multiple USB cameras
[Jetson AGX orin 64GB] reflash image errors
Apply_binaries.sh fail on Basic Flavor Root File System (L4T 36.4.3 DP)
Jetson Ag xOrin Industrial with Jetson Linux R35.6.0, how to add custom partition in layout file?
Jetson Orin NX 16GB flash issue: error: failed to read rcm_state
Camera access in headless mode
How to enable wifi and BT through sdio interface on Jetson AGX Orin
gStreamer - high delay, low fps
GStreamer caps selecting resolution, cannot change - urgent help greatly appreciated
Jetson Orin Nano Developer Kit Flashing not working
Jtop doesn't detect GPU temperature consistently
Jetpack installation failed - system will not reboot now
Flashing is failing on all devices (1) Development Nvidia Orin (2) Jetson nano devkit
Transfer the Real time captured camera frames from Jetson xavier nx to HOST PC (windows) using USB port
K3S on Jetson ORIN Jetapack 6.2.1 => kernel error : failed to perform ipset restore
Wireguard Kernel Module Error on 5.14.104-tegra
MP4 picture flicker
Recovery and OTA Query
Unable to sync kernel source for Jetpack 6.2
Network Configuration Issues After Flashing Jetson Orion Nano with Minimal RootFS
Build opencv with gstreamer(no flashing)
NvArgus Camera Issue with Xvfb and GStreamer
BLACK screen when enable multiuser.target
AGX orin 64G USB 3.2 cannot connect to Zed mini camera for use?
V4l2 -capture 4k raw data
Establishment of RTSP Server through RTSP streaming video
Does nvme-ssd needs a pre-formatting before mass flashing the orin NXs?
Ffmpeg with h264_nvenc not working
No mimicgen data
Flashing Jetpack 6 to USB flash drive
Issue with yolov8s-seg conversion from onnx to engine
Not able to flash
Memory warning logs when using 9 gstreamer commands with nvdec
VNC error when no hdmi plug
Agx Oirn auto enter recovery mode,why?
Intel RealSense D435i Not Detected After Upgrading to JetPack 6.1.2
Flashing
How to generate firmware flash compressed file(mfi_xxx.tar.gz) for AGX ORIN without connecting device?
Jetson Orin NX working with a USB camera "gets stuck" for 2 seconds
Jetson Orin Nano - DP-Display Blank screen Out of Range
Jetson Orin devkit 64GB Flash Jetpack DP_6.0 Failed - ERROR: might be timeout in USB write
Can't flash orin nano: timeout in USB write
Connect to jetson device over the internet (GUI/ SSH without from LAN )
EGL_BAD_DISPLAY error with SSH
Output to Second Display/Monitor
AGX ORIN 32G HDMI无显示
SDK Manager on WSL2 failing to install DP 6 on Orin AGX
SDK Manager doesn't detect Jetson Orin Nano in recovery mode
USB port C not working
Kernel boot time optimization JP5.1.2
Clone and flash issue
Splitmuxsink record time not true
Unable to open camera in google meet or zoom
Headless monitor access via RDP -any progress
SDMMC1 - Disable Clock Gating - AGX ORIN
Jetson AGX Orin (DK) Stuck in Recovery
Jetson AGX orin does not restart after flashing Linux successfully
Jetpack on Jetson Orin Nano through WSL: Depends on failed component error
Flashing L4T 35.4.1 to orin nano 4gb som fails
Error flashing Orin Nano devkit 8 GB w/ 500 GB NVME gen 3 SSD
Jetson Flashing with window
Is it possible to connect a camera to a jetson carrier board with just power and take a video
WSL2 Flashing Jetpack 5.1.13 No Luck
Service script doesnt work for first boot after some time
Disable NVMe SSD from BIOS?
SDK manger not working
Use UDP rtsp sink in Deepstream without packet drops
Nvh264dec latency on host machine (slower than jetson)
GStreamer x264enc faster than nvv4l2h264enc?
Can not flash nx on WSL2 with Win11
Error when flashing Jetpack 5.1 on Jetson [Reading board information failed]
How to flash kernel alone in "jetpack 5.1.3 & orin"
Jetson not booting after installing xubuntu-desktop
Tegra-host1x 13e00000.host1x: syncpt_load failed
After AGX Orin devkit flash jetpack6.1, usb type-c can not use
JETSON-AGX-ROINR reflash R35.4.1 and R36.2.0 'ERROR: might be timeout in USB write'
Error while flash to nvme of Jetson AGX orin Devkit
FFmpeg gpu Hardware acceleration
Is it possible to take images using a camera on boot?
Jetson 硬件解码 .H264 为 YUV 文件出现丢失
Power Issues and I2C Transfer Timeouts on Jetson AGX Orin Developer Kit 64GB
USB camera with interface board not working
Problems with loading a kernel from /boot on external rootfs
Cannot install OpenCV with GStreamer support on JetPack 6.2 with OpenCV 4.11
Issues install jetpack 6.0 with SDK manager on WSL
OpenCV and GStreamer Error on Jetson Orion Nano but Works on Jetson Xavier AGX
The apk based on Gstreamer dont have a x window output when the machine autostart
OpenCV/Pythin doesn't support Gstreamer
Does AGX Orin support PCIE device(RTL8125) use wake on lan function?
Unable to Flash NVME Jetson AGX Orin 64GB Dev kit with supplied USB Cable
Jetson Orin Nano devkit flash failing
How to convert from mjpeg to h264 and stream to the virtual camera
Is it possible to turn on the board via wol?
Unable to login or boot Jetson AGX Orin 64GB module
Issue flashing Jetpack 6.2
Can't enable modeset on boot for wayland
Ask for help about the delay of video hardware decoding
Is NvTransformAsync available to use?
Jetson AGX Orin not booting on custom carrier board with EEPROM (AT24C02 with address: 0x56)
Qv4l2 failed to open the video device
Gstreamer streaming
Jetson Orin USB3: ITP frame count errors and ~1.6s xHCI controller stall with CYUSB3065-based camera
Nvidia agx orin Backup making mirror burning to another device, mirror burning successful, boot failure
Issues Setting Up Ad-Hoc Network with Orin Nanos Jetpack 6.0 - BSSID Mismatch
SPI cs-gpios
Adding a New sensor driver to the JP6 Orin NX
Finding server port In RTSP server base on RTP with UDP transport
Jetson orin Flashing Failed SDK mnager
Jetson orin nano error flash.sh
Blackfly S USB camera frame rate
After boot screen Orin AGX display stops working
MB2 still trying to read CVB EEPROM after changing misc dts
Orin nx 8G flash failure
AGX Orin unable to boot after flasing
Flashed AGX Orin, now no display and can't access unit through USB
Question about update camera firmware on Nano with Jetpack 5.1.3
Why my orin develop kit is only active 8 cpu?
Jetson orin nx Black screen caused by insufficient root directory space
Software encoding with x264enc Jetson Orin Nano Issue
Headless and time question
Setting Up Fixed IP on Jetson Nano for Ethernet Connection
JP 6.0 mass flash takes a long time
QSPI problem?
How to build nvidia-l4t-kernel-headers_arm64.deb
How to enable tc358743 on 36.3?
About UVC driver
Jetson Orin Nano Headless Setup?
Booting Issue on Jetson Orin Nano with Minimal Root Filesystem - PARTUUID Mount Fail
Segmenration fault after restarting gstreamer pipeline
When and how does B_kernel partition take effect
The connected Jetson device is not ready for flash
Agx-Orin: PCIe RP could read ram memory after increasing aperture size for mapping non-prefetchable BARs of endpointson RP
ORIN startup failure
Failed to flash from 6 to lower version
Use the h264_nvmpi hardware decoder to decode H264 experiences a memory leak
Restart USB Type C Port in Userspace
RAM DISK
[AGX orin]SOM on our custom board can't boot in MB2
Failed to Flash Jetson Orin NX ERROR: failed to read rcm_state
Jetson agx orin 32g clone to 64g
Error trying to flash Jetson AGX Orin with SDK Manager
IMX390 cameras for RTSP with file store and show pictures
UEFI waits in Boot Maintenance Manager during boot
Control the Jetson OrinNX remotely with GUI access
Error: Product version '5.1.2' not found, in SDKManager docker version
Regarding the industrial Orin module, when the power is restarted several times, there will be a system problem that can not enter the system, and it
Error value 3 and t186ref when flashing AGX
内核编译问题
UEFI Secure Boot fails flashing
Jetson Oring AGX 64GB doesn't start
R36.3: l4t_initrd_flash let APP be maximum storage size
Unable to boot with microSD. Log shows the MMC device is detected later on
L4T-README in Desktop does not open
Orin agx bios goes black screen启动bios界面后黑屏日志显示gpu错误
PPS input to GPIO on Jetpack 6.1
Jetson AGX Orin won't boot, and the host doesn't detect it
Orin Nano 4GB Production Module on dev kit Flash issues
Unable to initalize gstreamer pipeline
[Jetson AGX orin]refalsh Jetpack
Transmiter Nvida jetson orin nano ethernet
Recovery boot issue - Orin AGX
NVMe disk encryption and default encryption key
Headless mode fails with EGL error
How to control the gpio in orin nx(jetpack6.x)
Jetson AGX Orin 32gb not booting after flashing to JetPack 6.1
Missing RT kernel header in /rootfs/usr/src
Cmake opencv not found
Kernel thread blocking due to nvvrs-pseq-rtc IRQs
Intel Realsense camera D455 is not working with pyrealsense2 on orin dev kit
Orin 32GB 启动失败
Mouse and keyboard do not work after attempting upgrade
The jeston agx orin core board is powered on and starts
Flashing jetson linux to NVMe on a borken usb c jetson AGX 32GB
Jetson Orin Nano 8GB Development Board Kernel Customization, Compilation, and Ubuntu 22.04 Flash
How to Prevent Data Loss in Camera Recordings Without Slowing Down the System?
Problem building nvdisplay display driver for Orin AGX with Jetpack 5.1.3
Rcm Kernel Boot
FSKP Fuse Burn: USB Write Timeout
Change power mode without reboot
Jetson Orin NX stuck at NVIDIA logo after custom kernel flash
UEFI automatic update?
Jetson Ubuntu GUI login loop
Errors trying installing librealsense2 on Jetson orin nano
Log in infinite loop
I would like to build the OpenCV with CUDA on Orin Nano
Remote Desktop GUI Recommendation
Flash.sh fail when used "sudo reboot force recovery"
Upgrading from Jetpack 6 DP to Jetpack 6.2 seems to have broken GPIO
Boot Freeze with "ERROR: nvme0n1p1 not found" After Installing Custom Kernel with PreemptRT Patch
Orin SPI2 in jekpack 6.0, can not work
Doesn't want to go in recovery mode
SDK Manager Install Error
AGX Orin 64 GB - JetPack 6.2 Docker Issue after Flashing the Board
Jetson Orin AGX 32 no screen after flashing
# Flashing Failure: USB Write Timeout and Connection Issues on Nvidia Jetson Orin NX 16
Default flashing method from source doesn't work
AGX Orin flash issue
Is GStreamer package from Jetpack 6 built with debugging symbols?
Can i provide command to JETSON Orin Nano using my mobile tablet while Video Streaming using WIFI
Jetson AGX Orin Black Screen on Boot
Error in building kernel
RTSP decoding performance using OpenCV with GStreamer
Power doesn't reach the PCB on the AGX Orin Dev Kit
Jetson AGX Orin devkit 64GB flashing issue with jetpack 5.1.1
Watch screen through Nomachine when Display Port is unplugged
OpenCV no Gstreamer on VSCode
Jetson multimedia api "17_frontend" sample VideoEncoder class usage
Guidance on Building FFMPEG with NVIDIA GPU Support for H.265 Decoding
Startup of jetson orin nano
Flashing failed after burning fuses
Running `gst-inspect-1.0 nvv4l2h264dec` will show that there is no such element as `nvv4l2h264dec`
Orin NX pcie work abnormal with nvme SSD
USB3 UVC Camera Frame Drops
First boot service not triggering after nv-late-init.service. Swapdisk creation
Issue with Video Format Conversion Using GStreamer-1.0 nvvidconv Plugin in ROS
[RTSP Stream][Jetson-Inference] Cannot stream from another device to jetson Nx board
Orin Nx OS Booting Mediums
AGX Orin Headless Mode
Instructions for installing opencv with CUDA support for Jetson Orin Nano Jetpack 6.2
Stopping gdm increases Latency on NVENC
[URGENT] System-Wide USB Host Failure on Jetson Orin (R36.4.4) - Confirmed DTB/Kernel Initialization Issue - Need Host Mode Fix
USB Webcam not working in Orin Jetson nano super
File→RTSP (OpenCV+GStreamer→mediamtx) unstable on Jetson; direct RTSP works
Error during Intel Realsense T265 Tracking Camera on Jetson Orin Nano (Jetpack 6.2.1)
Usb camera
Gst-launch-1.0 not-negotiated
Jetson Orin Nx Seeed Studio Version freeze and reboot when a usb cam is used
Issues with H.265, H.264, and MJPEG decompression
NVME OS & Target Package Installation to Xavier NX 16GB Development Kit
Intel RealSense D435i “bad optional access” on Jetson (non-root)
Jetson Orin Nano Super – RTSP Stream Lag, High RAM Usage, and Slow Face Detection
Jetson Orin Nano Super 8GB: Stuck in Reboot Loop During JetPack 7.2 ISO Firmware Update (UEFI Capsule Update Fails)
Flash JetPack 7.2 into Jetson Orin Nano Developer Kit microSD card issue
JetPack on AGX Orin with RHEL: Hardware Video Encoding/Decoding (NVMPI) Fails in Headless Environment
Getting a segmentation fault on jetson Orin NX when closing an rtsp stream(client side) and reopening it on client laptop using GST-Launch-1.0
Intermittent Flashing failure in orin nx
Can't flash Orin NX 16GB "ERROR: failed to read rcm_state"
After a while, it stops producing images
Official CYPD4226 (Cypress PD controller) firmware for Jetson AGX Orin on Jetson Linux R39.2.1 / JetPack 7.2.1?
Tson AGX Orin Stuck on Flashing Underscore and Can't Enter Recovery Mode
Issue with Custom Carrier Board for Jetson AGX Orin: Wi-Fi Card Connected via SDIO Fails to Detect Any Wi-Fi Access Points
USB camera Anker C200 camera is not recognized in Jupyter Notbook(Hello camera)
Jetson AGX Orin Stuck on Flashing Underscore and Can't Enter Recovery Mode
Jetson Orin NX - Intel RealSense doesn't work please help me
Allowed GPU frequencies in AGX Orin
Dma buffer to opencv mat (after jetpack 5.1.1)
Cannot switch AB slot back
Usb time out on Jetson Nano Orin 4GB
Flashing Jetson Orin Nano Problem - always fail Sends error Code 1011
Scaling_governor set to performace failed
Seeed J3011/J401 Orin Nano flashing fails - line 43: remove_udev_rules: command not found
Unable to Boot Jetson After Automatic Loading of xdma.ko and Application Startup – Need Help Mounting File System in Recovery Mode to Modify rc.local
Controlling GPIO output pin via gpioset does not work in JP 6.x
Remotely Access the Jetson Orin Nano Dev Kit
Realsense install on Jetson orin nx
Jetson Orin Nano Headless Setup (SSH, Ethernet, and Power Only)
Display port not working " current input timing is not supported by the monitor display "
Cheese does not work well on 36.4
“Reading board information failed” when emulating back to default configuration Jetson Orin AGX
[ 0.0441 ] ERROR: might be timeout in USB write for JetPack 6, 36.3
AGX Orin USB camera -> RTP stream failing quietly
Docker Version has to be downgraded for anything to work!
AGX Orin Display Port Stopped Working After it Initially Worked
30X Cam + Orin NX 16GB with InHouse Carrier Board
Jetson Orin AutoStart is not working
In System,the USB no respond
Set static ip in L4T
Headless configurations with remote openGL accelerated desktop - Jetson Xavier
VNC without monitor
Gstreamer on Jetson OrIn industrial 64GB
Cannot change Jetson Orin AGX GPIO output level after boot
Agx orin flash failed: ERROR: might be timeout in USB write
Kernel Custom
RGMII Ethernet Not Enabled on Jetson AGX Orin Custom Carrier Board
Unable to flash Orin NX devkit
Hdmi是否与管脚复用有关?
Jetpack 6 installation fails on Orin NX 16GB Boardo
Flash fails on Jetson Orin Nano
Jetson Orin Not Detected SDK Manager and Unable to Reset
About CYPD4226 firmware update
Jetson AI Fundamentals - Error Creating Camera Object
Socket Communication Using Virtual Ethernet Via USB
Flashing to Jetpack 6 is failing
Issues Testing Gstreamer RTSP Server with USB Camera and Hardware Encoding on Jetson Orin Nx
Pixel Phase and Video Color output Orin Nano dev kit
How to disable UEFI print information and progress bar?
[Jetson AGX Orin] DisplayPort not detected – Only dummy screen available after boot
Not enough space when flashing customized rootfs
How to find PORT number on a Jetson AGX Orin?
Inquiries regarding AGX Orin module boot time optimization
Error: command error code: 67
使用video-viewer 在jetson推流,浏览器上观看到的是绿屏
Jetson Orin Nano (GPIO) -> with gpioset and gpioget
How to reflash jetson agx orin to l4t 36.2.0 using sdk manager?
Under what circumstances does UEFI start recovery mode
UEFI progress bar - Nvidia Xavier Nx
Jetson Orin Nano Developer kit 8GB initial boot to NVME SSD fails in WSL2 Ubuntu 20.04
RTSP with Gstreamer to VLC
Nvidia agx orin Kernel sources compiled ,but Directory &quot;nvgpu&quot; is not found, exiting
UDP streaming doesn't works
Building OpenCV with CUDA support in Orin NX 16GB
Moving from JP5.1.3 to JP6.1 Caused GPIO Error
