40hdr - SPI1 gpio padctl register bit[10] effect by gpiod tools in JP6
This issue may affect to control GPIO in JP6.
We have an official patch to fix this issue as following:
diff --git a/drivers/pinctrl/tegra/pinctrl-tegra.c b/drivers/pinctrl/tegra/pinctrl-tegra.c
index 953a3a650a9e..7022faa2a7ce 100644
--- a/drivers/pinctrl/tegra/pinctrl-tegra.c
+++ b/drivers/pinctrl/tegra/pinctrl-tegra.c
@@ -281,7 +281,7 @@ static int tegra_pinctrl_set_mux(struct pinctrl_dev *pctldev,
 static const struct tegra_pingroup *tegra_pinctrl_get_group(struct pinctrl_dev *pctldev,
-                                                       unsigned int offset)
+					unsigned int offset, struct tegra_pingroup_config **config)
 		struct tegra_pmx *pmx = pinctrl_dev_get_drvdata(pctldev);
 		unsigned int group, num_pins, j;
@@ -293,9 +293,12 @@ static const struct tegra_pingroup *tegra_pinctrl_get_group(struct pinctrl_dev *
 			if (ret < 0)
 				continue;
 			for (j = 0; j < num_pins; j++) {
-				if (offset == pins[j])
+				if (offset == pins[j]) {
+					if (config)
+						*config = &pmx->pingroup_configs[group];
 				return &pmx->soc->groups[group];
@@ -309,12 +312,14 @@ static int tegra_pinctrl_gpio_request_enable(struct pinctrl_dev *pctldev,
 	const struct tegra_pingroup *group;
+	struct tegra_pingroup_config *config;
 	u32 value;
 	if (!pmx->soc->sfsel_in_mux)
 		return 0;
-	group = tegra_pinctrl_get_group(pctldev, offset);
+	group = tegra_pinctrl_get_group(pctldev, offset, &config);
 	if (!group)
 		return -EINVAL;
@@ -323,6 +328,7 @@ static int tegra_pinctrl_gpio_request_enable(struct pinctrl_dev *pctldev,
 		return -EINVAL;
 	value = pmx_readl(pmx, group->mux_bank, group->mux_reg);
+	config->is_sfsel = (value & BIT(group->sfsel_bit)) != 0;
 	value &= ~BIT(group->sfsel_bit);
 	pmx_writel(pmx, value, group->mux_bank, group->mux_reg);
@@ -335,12 +341,14 @@ static void tegra_pinctrl_gpio_disable_free(struct pinctrl_dev *pctldev,
 	u32 value;
 		return;
 	if (!group)
 		return;
@@ -348,7 +356,8 @@ static void tegra_pinctrl_gpio_disable_free(struct pinctrl_dev *pctldev,
 		return;
-	value |= BIT(group->sfsel_bit);
+	if (config->is_sfsel)
+		value |= BIT(group->sfsel_bit);
@@ -801,6 +810,11 @@ int tegra_pinctrl_probe(struct platform_device *pdev,
 	pmx->dev = &pdev->dev;
 	pmx->soc = soc_data;
+	pmx->pingroup_configs = devm_kcalloc(&pdev->dev,
+		pmx->soc->ngroups, sizeof(*pmx->pingroup_configs), GFP_KERNEL);
+	if (!pmx->pingroup_configs)
+		return -ENOMEM;
 	 * Each mux group will appear in 4 functions' list of groups.
 	 * This over-allocates slightly, since not all groups are mux groups.
diff --git a/drivers/pinctrl/tegra/pinctrl-tegra.h b/drivers/pinctrl/tegra/pinctrl-tegra.h
index 216cc59b62b4..a47ac519f3ec 100644
--- a/drivers/pinctrl/tegra/pinctrl-tegra.h
+++ b/drivers/pinctrl/tegra/pinctrl-tegra.h
@@ -8,6 +8,10 @@
 #ifndef __PINMUX_TEGRA_H__
 #define __PINMUX_TEGRA_H__
+struct tegra_pingroup_config {
+	bool is_sfsel;
 struct tegra_pmx {
 	struct device *dev;
 	struct pinctrl_dev *pctl;
@@ -21,6 +25,8 @@ struct tegra_pmx {
 	int nbanks;
 	void __iomem **regs;
 	u32 *backup_regs;
+	/* Array of size soc->ngroups */
+	struct tegra_pingroup_config *pingroup_configs;
 enum tegra_pinconf_param {
