Problem with pin 208 output default state
Bit 10 should not be enabled if you want to use it as GPIO/Output.
Please check if the patch from 40hdr - SPI1 gpio padctl register bit[10] effect by gpiod tools in JP6 - #20 by KevinFFF could help for your case.
