Invalid configuration output pin in custom development board
hello:
my Core board baord is Jetson Orin NX 16GB-DRAM, kernel version is:
root@tegra-ubuntu:/home/yz/nfs# uname -a
Linux tegra-ubuntu 5.10.120-rt70-tegra #6 SMP PREEMPT RT Tue May 27 19:24:22 CST 2025 aarch64 aarch64 aarch64 GNU/Linux
 I change pin set Configuration Features as blow picture in excel file:
Generate and modify device tree:
pinmux@2430000{
		pinctrl-names = "default";
		pinctrl-0 = <&exp_header_pinmux>;
		exp_header_pinmux:header-pinmux {
               soc_gpio25_pp6 {
				nvidia,pins = "soc_gpio25_pp6";
				nvidia,function = "gpio";
				nvidia,pull = <TEGRA_PIN_PULL_NONE>;
				nvidia,tristate = <TEGRA_PIN_DISABLE>;
				nvidia,enable-input = <TEGRA_PIN_DISABLE>;
				nvidia,lpdr = <TEGRA_PIN_DISABLE>;
	i2c@c240000{
		status = "okay";  // 启用该设备
		dlp3010@1B {
        	compatible = "bopixel,dlp3010";  // 设备的兼容性字符串
       		reg = <0x1B>;  					// I2C 地址为 0x36
			dlp-id = <0>;
			enable-gpios =  <&tegra_main_gpio  TEGRA234_MAIN_GPIO(P, 6)  GPIO_ACTIVE_HIGH>; //控制dlp的上电开关
			dlp-name = "dlp3010_0"; 		// 指定设备节点名称
			clock-frequency = <100000>;  // Set speed to 400kH
my drive code is :
static struct dlp_data{
    struct i2c_client   *client;
    struct gpio_desc   *enable_gpio;
    struct class 	    *dlp_class;
    struct device 	    *dlp_device;
    struct cdev         cdev;
    u8                  index;
    int                 major;
    dev_t               dev_number;
    char                dev_name[15];
}g_dlp[DLP_MAX_DEVICES];
 dlpData->enable_gpio = devm_gpiod_get(dev, "enable", GPIOD_OUT_LOW);
    if (IS_ERR(dlpData->enable_gpio)) {
		vc_err(dev, "Failed to get enable-gpios gpio\n");
		return PTR_ERR(dlpData->enable_gpio);
    gpiod_set_value_cansleep(dlpData->enable_gpio, 1);
The driver code did not report any errors,But the pin test has always been at a low level, not a 1.8V voltage。
May I ask what else I need to do?
Moving to Jetson Orin NX forum
Hi asfsdgag,
The pinmux/gpio dtsi generated from pinmux spreadsheet are loaded in early-boot(MB1).
You should just refer to the instruction in Jetson Orin NX and Nano Series — Jetson Linux Developer Guide documentation to apply the change.
As my understanding, it should be specified in gpio-output-high of gpio dtsi so that it could be configured as High by default.
Do you control PP.06 in your driver?
If so, is there any error reporting in dmesg?
hi KevinFFE:
very thank you, I solved this problem in your way!
