Now, I want to add a GPIO node to the dts file and controlling the output high, but it’s faild.
My operation is as follows:
1、Revised tegra234-p3768-0000+p3767-0000.dts
2、When I executed “cat /sys/kernel/debug/gpio” in the Orin NX device, I received the following information:
But,When I measured the voltages of GPIO01, GPIO02 and GPIO12 pins, the measured values remained at the low level.
If I want to correctly add the gpio node in the file "tegra234-p3768-0000+p3767-0000.dts", what should I do?
Thanks !!
Hi sjz_shaohua,
Have you configured the pinmux for these 3 pins as output either using pinmux spreadsheet or pinmux@2430000 in kernel device tree before controlling them?
Hi KevinFFF
I have revised the pinmux table according to your suggestions. Here is my modification. After the modification, there is still no voltage output for GPIO1 and GPIO2. I hope to get your help.
Please share the gpio dtsi and the result of the following commands for further check.
//PQ.05 - SOC_GPIO32
$ sudo busybox devmem 0x02430068
//PP.06 - SOC_GPIO25
$ sudo busybox devmem 0x02430030
And also, check if you can pull them high with the following commands.
# gpioset --mode=wait `gpiofind "PQ.05"`=1
# gpioset --mode=wait `gpiofind "PP.06"`=1
Hi KevinFFF
Thanks for your help,the problem has been solved.
“3.3V Tolerance Enable” need to be configured as “Disabled”.
