For our custom Orin NX board, we are adding a MAX14830 to the device tree. The chip has an interrupt line connected to the DP1_HPD / GPIO3_PM.00, which gives kernel errors during boot. Here is our device tree:
model = "Custom Jetson Board";
compatible = "nvidia,jetson-custom-board", "nvidia,tegra234";
clocks {
max14830_xtal: max14830_xtal {
compatible = "fixed-clock";
#clock-cells = <0>;
clock-frequency = <3686400>;
bus@0 {
spi@3210000 {
status = "okay";
max14830@0 {
compatible = "maxim,max14830";
reg = <0x0>;
spi-max-frequency = <500000>;
clocks = <&max14830_xtal>;
clock-names = "xtal";
interrupt-parent = <&tegra_main_gpio>;
interrupts = <TEGRA234_MAIN_GPIO(M, 0) IRQ_TYPE_LEVEL_LOW>;
gpio-controller;
#gpio-cells = <2>;
controller-data {
nvidia,enable-hw-based-cs;
nvidia,rx-clk-tap-delay = <0x10>;
nvidia,tx-clk-tap-delay = <0x0>;
However, I get the following error message when booting the board, regarding the interrupt:
[ 10.685448] CPU:0, Error: cbb-fabric@0x13a00000, irq=178
[ 10.685453] **************************************
[ 10.685455] CPU:0, Error:cbb-fabric, Errmon:2
[ 10.685460] Error Code : SLAVE_ERR
[ 10.685469] Error Code : SLAVE_ERR
[ 10.685470] MASTER_ID : CCPLEX
[ 10.685471] Address : 0x2212000
[ 10.685472] Cache : 0x1 -- Bufferable
[ 10.685473] Protection : 0x2 -- Unprivileged, Non-Secure, Data Access
[ 10.685475] Access_Type : Read
[ 10.685476] Access_ID : 0x14
[ 10.685477] Fabric : cbb-fabric
[ 10.685477] Slave_Id : 0x3b
[ 10.685478] Burst_length : 0x0
[ 10.685479] Burst_type : 0x1
[ 10.685479] Beat_size : 0x2
[ 10.685480] VQC : 0x0
[ 10.685480] GRPSEC : 0x7e
[ 10.685481] FALCONSEC : 0x0
[ 10.685482] Slave : AXI2APB_9
[ 10.685484] **************************************
[ 10.685505] ------------[ cut here ]------------
[ 10.685506] WARNING: CPU: 0 PID: 647 at /drivers/soc/tegra/cbb/tegra234-cbb.c:608 tegra234_cbb_isr+0x154/0x1a0
[ 10.685526] Modules linked in: thermal_trip_event(O+) tegra_aconnect(+) nv_imx219(O+) snd_hda_tegra(+) snd_hda_codec snd_hda_core pwm_tegra_tachometer(O) r8168(O+) at24 pwm_tegra host1x_fence(O) mc_hwpm(O) spi_tegra114(+) nvidia_vrs_pseq(O) tegra_bpmp_thermal nvhost_isp5(O) nvhost_vi5(O) nvhost_nvcsi_t194(O) tegra_camera(O) v4l2_dv_timings nvhost_nvcsi(O) tegra_camera_platform(O) capture_ivc(O) tegra_camera_rtcpu(O) ivc_bus(O) hsp_mailbox_client(O) ivc_ext(O) v4l2_fwnode v4l2_async videobuf2_dma_contig videobuf2_memops videobuf2_v4l2 videobuf2_common governor_userspace videodev mc tegra_drm(O) nvhost_pva(O) nvhost_nvdla(O) nvhost_capture(O) tegra_wmark(O) nvhwpm(O) cec spidev pwm_fan nvidia_drm(O) nvidia_modeset(O) nvidia(O) tegra_dce(O) tsecriscv(O) host1x_nvhost(O) drm_kms_helper nvgpu(O) governor_pod_scaling(O) nvmap(O) nvsciipc(O) host1x(O) mc_utils(O) dm_multipath ina3221 fuse drm nfnetlink ipv6 nvme nvme_core tegra_xudc pcie_tegra194 phy_tegra194_p2u
[ 10.685589] CPU: 0 PID: 647 Comm: (udev-worker) Tainted: G O 5.15.148-l4t-r36.4-1012.12+g8dc079d5c8c4 #1
[ 10.685592] Hardware name: NVIDIA Custom Jetson Board/Jetson, BIOS v36.4.0 01/08/2024
[ 10.685594] pstate: 604000c9 (nZCv daIF +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[ 10.685597] pc : tegra234_cbb_isr+0x154/0x1a0
[ 10.685600] lr : tegra234_cbb_isr+0x12c/0x1a0
[ 10.685603] sp : ffff800008003e60
[ 10.685604] x29: ffff800008003e60 x28: ffff0000803bcd80 x27: 00000000000000c0
[ 10.685607] x26: 0000000000000001 x25: ffffde1e490bbae0 x24: ffffde1e49fba770
[ 10.685610] x23: ffffde1e4945c008 x22: 00000000000000b2 x21: ffffde1e49defc08
[ 10.685612] x20: ffffde1e49defcc8 x19: 0000000000000000 x18: 00000000fffffffd
[ 10.685615] x17: ffff21e3a7dce000 x16: ffff800008000000 x15: ffffde1e49f74b84
[ 10.685618] x14: 0000000000000001 x13: 2a2a2a2a2a2a2a2a x12: 2a2a2a2a2a2a2a2a
[ 10.685620] x11: 2a2a2a2a2a2a2a2a x10: 2a2a2a2a2a2a2a2a x9 : 2a2a2a2a2a2a2a2a
[ 10.685622] x8 : 2a2a2a2a2a2a2a2a x7 : 0000000000000000 x6 : 000000000000000c
[ 10.685625] x5 : ffff0001f122ca10 x4 : 00000000fffff2e1 x3 : 0000000000000000
[ 10.685627] x2 : ffffde1e47521298 x1 : ffff0000803bcd80 x0 : 0000000100010000
[ 10.685630] Call trace:
[ 10.685632] tegra234_cbb_isr+0x154/0x1a0
[ 10.685635] __handle_irq_event_percpu+0x70/0x268
[ 10.685643] handle_irq_event+0x74/0x11c
[ 10.685646] handle_fasteoi_irq+0xac/0x1a0
[ 10.685649] handle_domain_irq+0x74/0xa8
[ 10.685652] gic_handle_irq+0x68/0x140
[ 10.685657] call_on_irq_stack+0x20/0x5c
[ 10.685661] do_interrupt_handler+0x70/0x80
[ 10.685663] el1_interrupt+0x30/0x7c
[ 10.685667] el1h_64_irq_handler+0x18/0x24
[ 10.685669] el1h_64_irq+0x7c/0x80
[ 10.685670] _dev_err+0x38/0xa8
[ 10.685674] gpiochip_lock_as_irq+0x164/0x168
[ 10.685679] gpiochip_irq_reqres+0x48/0xa0
[ 10.685681] __setup_irq+0x3b0/0x8ac
[ 10.685683] request_threaded_irq+0xd4/0x174
[ 10.685685] devm_request_threaded_irq+0x8c/0x108
[ 10.685687] max310x_spi_probe+0x850/0xa10
[ 10.685692] spi_probe+0x90/0xf8
[ 10.685696] really_probe+0xcc/0x46c
[ 10.685700] __driver_probe_device+0x114/0x170
[ 10.685703] driver_probe_device+0x54/0x130
[ 10.685705] __device_attach_driver+0xc8/0x170
[ 10.685707] bus_for_each_drv+0x94/0xf0
[ 10.685709] __device_attach+0xac/0x1d0
[ 10.685711] device_initial_probe+0x2c/0x40
[ 10.685713] bus_probe_device+0xb0/0xc0
[ 10.685716] device_add+0x44c/0x90c
[ 10.685717] __spi_add_device+0x84/0x184
[ 10.685720] spi_add_device+0x50/0x88
[ 10.685722] of_register_spi_device+0x1fc/0x3a0
[ 10.685725] spi_register_controller+0x644/0x8c0
[ 10.685727] devm_spi_register_controller+0x58/0xb0
[ 10.685729] tegra_spi_probe+0x3c0/0x578 [spi_tegra114]
[ 10.685742] platform_probe+0x74/0xe4
[ 10.685745] really_probe+0xcc/0x46c
[ 10.685747] __driver_probe_device+0x114/0x170
[ 10.685750] driver_probe_device+0x54/0x130
[ 10.685752] __driver_attach+0xd8/0x200
[ 10.685753] bus_for_each_dev+0x8c/0xf0
[ 10.685755] driver_attach+0x38/0x48
[ 10.685757] bus_add_driver+0x15c/0x260
[ 10.685759] driver_register+0x80/0x140
[ 10.685761] __platform_driver_register+0x3c/0x58
[ 10.685764] tegra_spi_driver_init+0x2c/0x1000 [spi_tegra114]
[ 10.685767] do_one_initcall+0x64/0x2c0
[ 10.685769] do_init_module+0x54/0x240
[ 10.685774] load_module+0x2098/0x2618
[ 10.685777] __do_sys_finit_module+0xa8/0x120
[ 10.685779] __arm64_sys_finit_module+0x30/0x40
[ 10.685782] invoke_syscall+0x5c/0x120
[ 10.685786] el0_svc_common.constprop.0+0xf0/0x110
[ 10.685789] do_el0_svc+0x3c/0x9c
[ 10.685791] el0_svc+0x20/0x60
[ 10.685793] el0t_64_sync_handler+0x108/0x120
[ 10.685795] el0t_64_sync+0x1a4/0x1a8
[ 10.685798] ---[ end trace 6316402b7856fa70 ]---
[ 11.489808] gpio gpiochip0: (tegra234-gpio): gpiochip_lock_as_irq: tried to flag a GPIO set as output for IRQ
[ 11.489814] gpio gpiochip0: (tegra234-gpio): unable to lock HW IRQ 76 for IRQ
[ 11.489817] genirq: Failed to request resources for spi0.0 (irq 249) on irqchip 2200000.gpio
[ 11.489844] max310x spi0.0: Unable to reguest IRQ 249
gpioinfo confirms that it is set as output:
root@p3768-0000-p3767-0001:~# gpioinfo | grep PM.00
line 76: "PM.00" kernel output active-high [used]
Although I set it up as input here is my pinmux:
dp_aux_ch0_hpd_pm0 {
nvidia,pins = "dp_aux_ch0_hpd_pm0";
nvidia,function = "rsvd1";
nvidia,pull = <TEGRA_PIN_PULL_UP>;
nvidia,tristate = <TEGRA_PIN_ENABLE>;
nvidia,enable-input = <TEGRA_PIN_ENABLE>;
nvidia,io-high-voltage = <TEGRA_PIN_DISABLE>;
nvidia,lpdr = <TEGRA_PIN_DISABLE>;
Is there anything I am missing, or anything more that needs to be setup?
