I can see
SPI_MISO_LVS , SPI_MOSI_LVS ,SPI_CS0_LVS ,SPI_CS0_LVS ,SPI_CS1_LVS
is SPI1 bus
So can I connect directly to a custom SPI device for testing ?
Register as a spidev device to read and write directly ?
I can see
is SPI1 bus
Please refer to Jetson/TX2 SPI - eLinux.org, concept is similar.
Is there any PINMUX documentation for ORIN??
pinmux configuration files not bootloader/t186ref/BCT/tegra186-mb1-bct-pinmux-*.cfg.
seems to be modified to tegra234-mb1-bct-pinmux-p3701-0000.dtsi
ORIN SPI3 in 40 pin conn
So I modify tegra234-mb1-bct-pinmux-p3701-0000.dtsi
spi3_sck_py0 {
nvidia,pins = “spi3_sck_py0”;
nvidia,function = “spi3”;
nvidia,pull = <TEGRA_PIN_PULL_DOWN>;
nvidia,tristate = <TEGRA_PIN_DISABLE>;
nvidia,enable-input = <TEGRA_PIN_ENABLE>;
nvidia,io-high-voltage = <TEGRA_PIN_DISABLE>;
nvidia,lpdr = <TEGRA_PIN_DISABLE>;
spi3_miso_py1 {
nvidia,pins = "spi3_miso_py1";
nvidia,function = "spi3";
//nvidia,pull = <TEGRA_PIN_PULL_DOWN>;
//nvidia,tristate = <TEGRA_PIN_DISABLE>;
nvidia,pull = <TEGRA_PIN_PULL_UP>;
nvidia,tristate = <TEGRA_PIN_ENABLE>;
spi3_mosi_py2 {
nvidia,pins = "spi3_mosi_py2";
spi3_cs0_py3 {
nvidia,pins = "spi3_cs0_py3";
spi3_cs1_py4 {
nvidia,pins = "spi3_cs1_py4";
And short circuit these two pins
but still not working
root@user-desktop:/home/user# ./spidev_test -v -D /dev/spidev2.1
spi mode: 0x0
bits per word: 8
max speed: 500000 Hz (500 kHz)
TX | FF FF FF FF FF FF 40 00 00 00 00 95 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF F0 0D |…@…|
RX | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |…|
root@user-desktop:/home/user# ./spidev_test -v -D /dev/spidev2.0
spi mode: 0x0
bits per word: 8
How to confirm that PINMUX is set successfully ???
Change the setting to spi1, still no response
spi1_sck_pz3 {
nvidia,pins = "spi1_sck_pz3";
nvidia,function = "spi1";
nvidia,pull = <TEGRA_PIN_PULL_NONE>;
nvidia,enable-input = <TEGRA_PIN_DISABLE>;
//pinmux.0x0243d020 = 0x00000458;
spi1_miso_pz4 {
nvidia,pins = "spi1_miso_pz4";
nvidia,function = "spi1"; //1:0
nvidia,pull = <TEGRA_PIN_PULL_UP>; //3:2
nvidia,tristate = <TEGRA_PIN_ENABLE>; //4
nvidia,io-high-voltage = <TEGRA_PIN_DISABLE>;//5
nvidia,enable-input = <TEGRA_PIN_ENABLE>; //6
nvidia,lpdr = <TEGRA_PIN_DISABLE>; //7
spi1_mosi_pz5 {
nvidia,pins = "spi1_mosi_pz5";
//pinmux.0x0243d010 = 0x00000400;
spi1_cs0_pz6 {
nvidia,pins = "spi1_cs0_pz6";
spi1_cs1_pz7 {
nvidia,pins = "spi1_cs1_pz7";
root@user-desktop:/home/user# ./spidev_test -v -D /dev/spidev0.0
spi mode: 0x0
bits per word: 8
How to update only pinmux config ?
How to confirm whether pinmux has been updated successfully?
You can directly read the register after you boot up.
root@user-desktop:/home/user# cat /sys/kernel/debug/tegra_pinctrl_reg
cat: /sys/kernel/debug/tegra_pinctrl_reg: No such file or directory
Why no tegra_pinctrl_reg ??
I mean you can directly read the register which you just posted in above comment by using devmem.
I set it directly and it seems to work
But why can’t I modify Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-pinmux-p3701-0000.dtsi to take effect
root@user-desktop:/home/user# busybox devmem 0x0243d008 32 0x400
ox devmem 0x0243d018 32 0x458
root@user-desktop:/home/user# busybox devmem 0x0243d018 32 0x458
root@user-desktop:/home/user# busybox devmem 0x0243d028 32 0x400
root@user-desktop:/home/user# busybox devmem 0x0243d038 32 0x400
root@user-desktop:/home/user# busybox devmem 0x0243d040 32 0x400
0x00000400
0x00000458
0x00000400
0x00000400
0x00000400
spi mode: 0x0
bits per word: 8
RX | FF FF FF FF FF FF 40 00 00 00 00 95 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF F0 0D |…@…|
Could you share which file got modified and how you flash?
./flash.sh -k A_kernel jetson-agx-orin-devkit mmcblk0p1
20220630_flash.log (54.5 KB)
I can see
copying pinmux_config(/home/share/HD2/NVDIA_DATA/Tegra186_git_3410_org/tegra186/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-pinmux-p3701-0000.dtsi)… done.
tegra234-mb1-bct-pinmux-p3701-0000.dtsi (68.4 KB)
That dtsi is not in in use in the kernel partition. Please full flash again
./flash.sh jetson-agx-orin-devkit mmcblk0p1
20220630_flash_all.log (66.9 KB)
0x00000000
0x00000058
0x00001000
0x00000000
0x00000000
still not working …
Then please check if any device tree node is using this pin.
I tried many times
Still can’t update pinmux
tegra234-p3701-0000-p3737-0000_o.dts (387.0 KB)
tegra234-mb1-bct-pinmux-p3701-0000.dtsi (66.7 KB)
202207011700_flash.log (66.8 KB)
0x00000000
0x00000058
0x00001000
0x00000000
0x00000000
Just want to confirm. What is current status?
You can make SPI work if you directly modify the pinmux register directly?
I directly modify the pinmux register
The actual mount reads the nor-flash id,
miso no data read, all are 0
root@user-desktop:/home/user# insmod /lib/modules/5.10.65-tegra/kernel/drivers/mtd/spi-nor/spi-nor.ko
[ 2098.758864] spi-nor spi0.1: unrecognized JEDEC id bytes: 00 00 00 00 00 00
How to confirm pinmux update ??
Regarding the pinmux update, how can I confirm it?
Are you trying to configure SPI1 as master ? Can you specify the ask here ? I will try to provide you the pinmux settings
