Issue trying to flash Jetpack 6.2 on SSD
Hello there,
I have a Jetson Orin Nano bought via Yahboom. I thought it was the normal developer kit, but it has no SD entry - and looking at jtop info says it’s a P3767-0003 version. Anyway, used it for almost a year (flashed on Jetpack 6.0) and was trying to upgrade to Jetpack 6.2 for a couple of days now with no success.
Once it has no SD Card entry, I’ve been trying to flash it on the SSD (NVMe) currently flashed to the 6.0 version, but had a lot of issues and found no way out until now.
Attached is the log file. Tried it through sdkmanager using a Ubuntu host, also via WSL, both same issues. If someone could please shed a light on how to solve it I’d be really glad:
0:28:37 ERROR: [ 0.0542 ] ERROR: failed to read rcm_state
20:28:48 ERROR: [ 0.2000 ] ERROR: might be timeout in USB write.
20:28:48 ERROR: Error: Return value 3
20:28:48 ERROR: --- Error: Reading board information failed.
20:28:48 ERROR: Bootrom status check failed.
20:29:19 ERROR: [ 0.0326 ] ERROR: failed to read rcm_state
20:29:29 ERROR: [ 0.1285 ] ERROR: might be timeout in USB write.
20:29:29 ERROR: Error: Return value 3
20:29:29 ERROR: --- Error: Reading board information failed.
20:29:30 ERROR: Bootrom status check failed.
20:30:17 ERROR: [ 0.0319 ] ERROR: failed to read rcm_state
20:30:21 ERROR: Flash Jetson Linux - flash: [ 0.0330 ] ERROR: failed to read rcm_state
20:30:23 ERROR: Flash Jetson Linux - flash: cat: /sys/module/usbcore/parameters/autosuspend: No such file or directory
20:26:57 INFO: Drivers for Jetson - target_image: verifying checksum of /home/jvitordm/Downloads/nvidia/sdkm_downloads/Jetson_Linux_R36.4.3_aarch64.tbz2
20:30:23 ERROR: Flash Jetson Linux - flash: /home/jvitordm/nvidia/nvidia_sdk/JetPack_6.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash.sh: line 94: /sys/module/usbcore/parameters/autosuspend: Permission denied
20:26:57 INFO: File System and OS - target_image: verifying checksum of /home/jvitordm/Downloads/nvidia/sdkm_downloads/Tegra_Linux_Sample-Root-Filesystem_R36.4.3_aarch64.tbz2
20:30:23 ERROR: Flash Jetson Linux - flash: rpcbind: another rpcbind is already running. Aborting
20:26:58 INFO: Drivers for Jetson - target_image: Found file /home/jvitordm/Downloads/nvidia/sdkm_downloads/Jetson_Linux_R36.4.3_aarch64.tbz2 with correct checksum, skip downloading.
20:30:25 ERROR: Flash Jetson Linux - flash: [ 0.0319 ] ERROR: failed to read rcm_state
20:27:00 INFO: File System and OS - target_image: Found file /home/jvitordm/Downloads/nvidia/sdkm_downloads/Tegra_Linux_Sample-Root-Filesystem_R36.4.3_aarch64.tbz2 with correct checksum, skip downloading.
20:30:30 ERROR: Flash Jetson Linux - flash: 72720 blocks
20:27:06 DEBUG: running command < true >
20:30:30 ERROR: Flash Jetson Linux - flash: gzip: /home/jvitordm/nvidia/nvidia_sdk/JetPack_6.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/kernel/Image: not in gzip format
20:27:06 INFO: exec_command: true
20:30:35 ERROR: Flash Jetson Linux - flash: 96292 blocks
20:27:06 INFO: command finished successfully
20:27:06 DEBUG: running command < sudo timeout 300 apt-get update && sudo timeout 300 apt-get check >
20:30:36 ERROR: Flash Jetson Linux - flash: 20+0 records out
20:27:06 INFO: exec_command: sudo timeout 300 apt-get update && sudo timeout 300 apt-get check
20:27:06 INFO: [host] [sudo] password for jvitordm:
20:27:06 INFO: Hit:1 http://security.ubuntu.com/ubuntu focal-security InRelease
20:27:07 INFO: Hit:2 http://archive.ubuntu.com/ubuntu focal InRelease
20:27:07 INFO: Get:3 http://archive.ubuntu.com/ubuntu focal-updates InRelease [128 kB]
20:27:08 INFO: Hit:4 http://archive.ubuntu.com/ubuntu focal-backports InRelease
20:27:08 INFO: Fetched 128 kB in 2s (54.2 kB/s)
20:30:46 ERROR: Flash Jetson Linux - flash: [ 0.0342 ] ERROR: failed to read rcm_state
20:27:09 INFO: Reading package lists...
20:30:50 ERROR: Flash Jetson Linux - flash: 72720 blocks
20:30:50 ERROR: Flash Jetson Linux - flash: gzip: /home/jvitordm/nvidia/nvidia_sdk/JetPack_6.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/kernel/Image: not in gzip format
20:27:09 INFO: Building dependency tree...
20:27:09 INFO: Reading state information...
20:27:09 INFO: command finished successfully
20:27:09 DEBUG: running command < true >
20:27:09 INFO: exec_command: true
20:31:54 ERROR: Flash Jetson Linux - flash: 131072+0 records out
20:27:09 DEBUG: running command < sudo dpkg --audit >
20:27:09 INFO: exec_command: sudo dpkg --audit
20:27:09 INFO: Install pre check APT repository access for Debian package installation(host). verify succeed.
20:27:09 INFO: Drivers for Jetson - target_image: verifying checksum of /home/jvitordm/Downloads/nvidia/sdkm_downloads/Jetson_Linux_R36.4.3_aarch64.tbz2
20:32:05 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 20000
20:32:29 ERROR: Flash Jetson Linux - flash: tar: Write checkpoint 670000
20:32:33 ERROR: Flash Jetson Linux - flash: [ 0.0519 ] ERROR: failed to read rcm_state
20:32:37 ERROR: Flash Jetson Linux - flash: 72720 blocks
20:32:37 ERROR: Flash Jetson Linux - flash: gzip: /home/jvitordm/nvidia/nvidia_sdk/JetPack_6.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/kernel/Image: not in gzip format
20:32:44 ERROR: Flash Jetson Linux - flash: 96292 blocks
20:32:44 ERROR: Flash Jetson Linux - flash: 20+0 records in
20:32:44 ERROR: Flash Jetson Linux - flash: 20+0 records out
20:32:44 ERROR: Flash Jetson Linux - flash: 20 bytes copied, 9.0672e-05 s, 221 kB/s
20:32:44 ERROR: Flash Jetson Linux - flash: 131072+0 records in
20:32:44 ERROR: Flash Jetson Linux - flash: 131072+0 records out
20:32:44 ERROR: Flash Jetson Linux - flash: 67108864 bytes (67 MB, 64 MiB) copied, 0.10765 s, 623 MB/s
20:32:50 ERROR: Flash Jetson Linux - flash: /home/jvitordm/nvidia/nvidia_sdk/JetPack_6.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/L4TConfiguration_updated.dts: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
20:32:50 ERROR: Flash Jetson Linux - flash: /home/jvitordm/nvidia/nvidia_sdk/JetPack_6.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/L4TConfiguration.dtbo: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
20:32:55 ERROR: Flash Jetson Linux - flash: 96292 blocks
20:33:04 ERROR: Flash Jetson Linux - flash: 147916 blocks
20:33:04 ERROR: Flash Jetson Linux - flash: rpcbind: another rpcbind is already running. Aborting
20:35:15 ERROR: Flash Jetson Linux - flash: /home/jvitordm/nvidia/nvidia_sdk/JetPack_6.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash.sh: line 46: /sys/module/usbcore/parameters/autosuspend: Permission denied
20:35:15 ERROR: Flash Jetson Linux - flash: [exec_command]: /bin/bash -c /home/jvitordm/.nvsdkm/replays/scripts/JetPack_6.2_Linux/NV_L4T_FLASH_JETSON_LINUX_COMP.sh; [error]: /home/jvitordm/nvidia/nvidia_sdk/JetPack_6.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash.sh: line 46: /sys/module/usbcore/parameters/autosuspend: Permission denied
20:35:15 ERROR: command error code: 11
20:35:15 ERROR: Flash Jetson Linux - flash: command terminated with error
20:35:15 SUMMARY: Flash Jetson Linux - flash: First Error: Installation failed.
20:30:47 INFO: Flash Jetson Linux - flash: [ 1.2901 ] MB2 Applet version 01.00.0000
20:30:47 INFO: Flash Jetson Linux - flash: [ 1.2978 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
20:30:47 INFO: Flash Jetson Linux - flash: [ 1.2983 ] MB2 Applet version 01.00.0000
20:30:47 INFO: Flash Jetson Linux - flash: [ 1.3059 ] Retrieving board information
20:30:49 INFO: Flash Jetson Linux - flash: copying minratchet_config(/home/jvitordm/nvidia/nvidia_sdk/JetPack_6.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-ratchet-p3767-0000.dts)... done.
20:30:49 INFO: Flash Jetson Linux - flash: copying device_config(/home/jvitordm/nvidia/nvidia_sdk/JetPack_6.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-device-p3767-0000.dts)... done.
20:30:49 INFO: Flash Jetson Linux - flash: copying misc_config(/home/jvitordm/nvidia/nvidia_sdk/JetPack_6.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-misc-p3767-0000.dts)... done.
20:30:49 INFO: Flash Jetson Linux - flash: copying pinmux_config(/home/jvitordm/nvidia/nvidia_sdk/JetPack_6.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-pinmux-p3767-dp-a03.dtsi)... done.
20:30:49 INFO: Flash Jetson Linux - flash: copying gpioint_config(/home/jvitordm/nvidia/nvidia_sdk/JetPack_6.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-gpioint-p3767-0000.dts)... done.
20:30:49 INFO: Flash Jetson Linux - flash: copying pmic_config(/home/jvitordm/nvidia/nvidia_sdk/JetPack_6.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-pmic-p3767-0000-a02.dts)... done.
20:30:49 INFO: Flash Jetson Linux - flash: copying pmc_config(/home/jvitordm/nvidia/nvidia_sdk/JetPack_6.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-padvoltage-p3767-dp-a03.dtsi)... done.
20:30:49 INFO: Flash Jetson Linux - flash: copying deviceprod_config(/home/jvitordm/nvidia/nvidia_sdk/JetPack_6.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-cprod-p3767-0000.dts)... done.
20:30:49 INFO: Flash Jetson Linux - flash: copying prod_config(/home/jvitordm/nvidia/nvidia_sdk/JetPack_6.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-prod-p3767-0000.dts)... done.
20:30:49 INFO: Flash Jetson Linux - flash: copying scr_config(/home/jvitordm/nvidia/nvidia_sdk/JetPack_6.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb2-bct-scr-p3767-0000.dts)... done.
20:30:49 INFO: Flash Jetson Linux - flash: copying wb0sdram(/home/jvitordm/nvidia/nvidia_sdk/JetPack_6.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/generic/BCT/tegra234-p3767-0001-wb0sdram-l4t.dts)... done.
20:30:49 INFO: Flash Jetson Linux - flash: copying bootrom_config(/home/jvitordm/nvidia/nvidia_sdk/JetPack_6.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-reset-p3767-0000.dts)... done.
20:30:49 INFO: Flash Jetson Linux - flash: Existing uphylane_config(/home/jvitordm/nvidia/nvidia_sdk/JetPack_6.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/tegra234-mb1-bct-uphylane-si.dtsi) reused.
20:30:49 INFO: Flash Jetson Linux - flash: copying dev_params(/home/jvitordm/nvidia/nvidia_sdk/JetPack_6.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/generic/BCT/tegra234-br-bct-p3767-0000-l4t.dts)... done.
20:30:49 INFO: Flash Jetson Linux - flash: copying dev_params_b(/home/jvitordm/nvidia/nvidia_sdk/JetPack_6.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/generic/BCT/tegra234-br-bct_b-p3767-0000-l4t.dts)... done.
20:30:49 INFO: Flash Jetson Linux - flash: copying mb2bct_cfg(/home/jvitordm/nvidia/nvidia_sdk/JetPack_6.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb2-bct-misc-p3767-0000.dts)... done.
20:30:49 INFO: Flash Jetson Linux - flash: Existing tscfwfile(/home/jvitordm/nvidia/nvidia_sdk/JetPack_6.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/tsec_t234.bin) reused.
20:30:49 INFO: Flash Jetson Linux - flash: Existing mb2applet(/home/jvitordm/nvidia/nvidia_sdk/JetPack_6.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/applet_t234.bin) reused.
20:30:49 INFO: Flash Jetson Linux - flash: Existing bootloader(/home/jvitordm/nvidia/nvidia_sdk/JetPack_6.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
NV_L4T_FLASH_JETSON_LINUX_COMP.log (411.4 KB)
Thanks in advance!
Use a native Ubuntu box 22.04
Just check and indeed was the 20 version, let me try with the 22 and get back here
Yep, still same issues (log attached)
Thought it could be something related to this topic: Can't flash a working NVMe SSD on Jetson Orin AGX - #13 by SimonBirrell
but I’ve seen that firewall isn’t blocking anything. Any other ideas?
SDKM_logs_JetPack_6.2_Linux_for_Jetson_Orin_Nano_8GB_2025-01-19_16-32-36.zip (257.2 KB)
I’ve noticed that the usb connection speed is being limited to 480Mb, like a 2.0 connection, even though connected to a 3.0 port on the host machine (tested also different ports and cables - and even to a Windows machine). Apparently the Jetson board itself is limiting the usb speed - may that be the problem?
Could you share the link you bought?
Also could you try download Driver Package (BSP) and Sample Root Filesystem from here.
And follow the quick start guide to flash your device.
Sure! Here it is (the 8GB Ult Kit):
Alright, let me try these and let you know how it goes. Thanks David!
Trying my best here, but still facing issues. For example when finally trying to run:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 \
  -c tools/kernel_flash/flash_l4t_t234_nvme.xml -p "-c bootloader/generic/cfg/flash_t234_qspi.xml" \
  --showlogs --network usb0 jetson-orin-nano-devkit-super internal
I get the error could not stat device /dev/nvme0n1 - no such file or directory among some others (like some files not being in the gzip format)…
Was further reading the link you suggested and here I found something about flashing on NVMe:
https://docs.nvidia.com/jetson/archives/r36.4.3/DeveloperGuide/SD/FlashingSupport.html#manually-setting-up-an-nvme-drive-for-booting
  1. Confirm that the device can boot successfully from eMMC. If it cannot, correct the problem by flashing to eMMC first.
This first point i think it’s already my issue. The device simply doesn’t boot successfully when not in recovery mode, just opens the UEFI Interactive Shell below. Is it maybe some fault on eMMC? How can I flash to it first as the guide suggests?
Could you provide your flash log and the serial log for us to review?
To record the serial log, please refer to below links.
Yahboom’s Jetson Orin Nano 4GB/8GB development board kit is based on our commercial version of the Jetson Orin Nano 4GB/8GB module, and those modules do not come with the microSD card slot and thus require NVMe SSD on the carrier board.
Because it may have a different carrier board hardware configuration, the NVIDIA SDK Manager may not support it.
Please follow Yahboom’s instruction to get this kit upgraded to JetPack 6.2.
  1. Basic Setting > 2.7 Upgrade to SUPER version
Hello there @cyato,
Thanks for the reply. The solution they propose is the exact same in the NVIDIA Quick Start Guide shared by @DavidDDD. I’ve abandoned the old linux host machine I was working with and tried with a newer/better one and things finally started working out (don’t know if it was something about connection or timeouts happening, anyway…)
I was now able to flash it successfully as in the guides, then used SDKManager to install the rest of the SDKs.
Thanks for the support!
