Hello. Ive been having issues to flash to my custom carrier, so I ried to flash with NVIDIA SDK MANAGER 6.0.0, ubuntu 22, in the dev kit carrier for orin.
SDK Manager logs:
10:02:38 INFO: Flash Jetson Linux - flash: [ 4.8486 ] Reading ramcode from backup chip_info.bin file
10:02:38 INFO: Flash Jetson Linux - flash: [ 4.8487 ] RAMCODE Read from Device: 2
10:02:38 INFO: Flash Jetson Linux - flash: [ 4.8487 ] Using ramcode 0
10:02:38 INFO: Flash Jetson Linux - flash: [ 4.8487 ] Disabled BPMP dtb trim, using default dtb
10:02:38 INFO: Flash Jetson Linux - flash: [ 4.8493 ] tegrahost_v2 --chip 0x23 0 --align mem_rcm_aligned.bct
10:02:38 INFO: Flash Jetson Linux - flash: [ 4.8501 ] tegrahost_v2 --chip 0x23 0 --magicid MEM0 --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm_aligned.bct zerosbk
10:02:38 INFO: Flash Jetson Linux - flash: [ 4.8504 ] adding BCH for mem_rcm_aligned.bct
10:02:38 INFO: Flash Jetson Linux - flash: [ 4.8535 ] tegrasign_v3.py --key None --list mem_rcm_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
10:02:38 INFO: Flash Jetson Linux - flash: [ 4.8536 ] Assuming zero filled SBK key
10:02:38 INFO: Flash Jetson Linux - flash: [ 4.8552 ] Warning: pub_key.key is not found
10:02:38 INFO: Flash Jetson Linux - flash: [ 4.8550 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_rcm_aligned_sigheader.bct.encrypt mem_rcm_aligned_sigheader.bct.hash zerosbk
10:02:38 INFO: Flash Jetson Linux - flash: [ 4.8561 ] Copying signatures
10:02:38 INFO: Flash Jetson Linux - flash: [ 4.8565 ] tegrahost_v2 --chip 0x23 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
10:02:38 INFO: Flash Jetson Linux - flash: [ 4.8574 ] tegraparser_v2 --generategpt --pt flash.xml.bin
10:02:38 INFO: Flash Jetson Linux - flash: [ 4.8578 ] gpt_primary_9_0.bin:
10:02:38 INFO: Flash Jetson Linux - flash: [ 4.8581 ] partition_id partition_name StartingLba EndingLba
10:02:38 INFO: Flash Jetson Linux - flash: [ 4.8582 ] 1 APP 3050048 119537623
10:02:38 INFO: Flash Jetson Linux - flash: [ 4.8584 ] 2 A_kernel 40 262183
10:02:38 INFO: Flash Jetson Linux - flash: [ 4.8586 ] 3 A_kernel-dtb 262184 263719
10:02:38 INFO: Flash Jetson Linux - flash: [ 4.8588 ] 4 A_reserved_on_user 263720 328487
10:02:38 INFO: Flash Jetson Linux - flash: [ 4.8590 ] 5 B_kernel 328488 590631
10:02:38 INFO: Flash Jetson Linux - flash: [ 4.8592 ] 6 B_kernel-dtb 590632 592167
10:02:38 INFO: Flash Jetson Linux - flash: [ 4.8594 ] 7 B_reserved_on_user 592168 656935
10:02:38 INFO: Flash Jetson Linux - flash: [ 4.8595 ] 8 recovery 656936 820775
10:02:38 INFO: Flash Jetson Linux - flash: [ 4.8597 ] 9 recovery-dtb 820776 821799
10:02:38 INFO: Flash Jetson Linux - flash: [ 4.8599 ] 10 esp 821800 952871
10:02:38 INFO: Flash Jetson Linux - flash: [ 4.8601 ] 11 recovery_alt 952872 1116711
10:02:39 INFO: Flash Jetson Linux - flash: [ 4.8602 ] 12 recovery-dtb_alt 1116712 1117735
10:02:39 INFO: Flash Jetson Linux - flash: [ 4.8602 ] 13 esp_alt 1117736 1248807
10:02:39 INFO: Flash Jetson Linux - flash: [ 4.8602 ] 14 UDA 1248832 2068031
10:02:39 INFO: Flash Jetson Linux - flash: [ 4.8602 ] 15 reserved 2068032 3050047
10:02:39 INFO: Flash Jetson Linux - flash: [ 4.8602 ] gpt_secondary_9_0.bin:
10:02:39 INFO: Flash Jetson Linux - flash: [ 4.8602 ] partition_id partition_name StartingLba EndingLba
10:02:39 INFO: Flash Jetson Linux - flash: [ 4.8602 ] 1 APP 3050048 119537623
10:02:39 INFO: Flash Jetson Linux - flash: [ 4.8602 ] 2 A_kernel 40 262183
10:02:39 INFO: Flash Jetson Linux - flash: [ 4.8602 ] 6 B_kernel-dtb 590632 592167
10:02:39 INFO: Flash Jetson Linux - flash: [ 4.8602 ] 7 B_reserved_on_user 592168 656935
10:02:39 INFO: Flash Jetson Linux - flash: [ 4.8602 ] 9 recovery-dtb 820776 821799
10:02:39 INFO: Flash Jetson Linux - flash: [ 4.8602 ] 10 esp 821800 952871
10:02:39 INFO: Flash Jetson Linux - flash: [ 4.8602 ] 11 recovery_alt 952872 1116711
10:02:39 INFO: Flash Jetson Linux - flash: [ 4.9236 ] tegrahost_v2 --chip 0x23 0 --align uefi_jetson_with_dtb_aligned.bin
10:02:39 INFO: Flash Jetson Linux - flash: [ 4.9254 ] tegrahost_v2 --chip 0x23 0 --magicid CPBL --ratchet_blob ratchet_blob.bin --appendsigheader uefi_jetson_with_dtb_aligned.bin zerosbk
10:02:39 INFO: Flash Jetson Linux - flash: [ 4.9261 ] adding BCH for uefi_jetson_with_dtb_aligned.bin
10:02:39 INFO: Flash Jetson Linux - flash: [ 5.0550 ] tegrasign_v3.py --key None --list uefi_jetson_with_dtb_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
10:02:39 INFO: Flash Jetson Linux - flash: [ 5.0551 ] Assuming zero filled SBK key
10:02:41 INFO: Flash Jetson Linux - flash: [ 5.0649 ] Warning: pub_key.key is not found
10:02:41 INFO: Flash Jetson Linux - flash: [ 5.0647 ] tegrahost_v2 --chip 0x23 0 --updatesigheader uefi_jetson_with_dtb_aligned_sigheader.bin.encrypt uefi_jetson_with_dtb_aligned_sigheader.bin.hash zerosbk
10:02:41 INFO: Flash Jetson Linux - flash: [ 5.0738 ] Copying enc\/signed file in /media/user/a4a32d54-50e9-458f-b0b2-cc65329b563e/nvidia_dw/JetPack_6.0_DP_Linux_DP_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed
10:02:41 INFO: Flash Jetson Linux - flash: [ 5.0739 ] Copying br bct for multi chains
10:02:41 INFO: Flash Jetson Linux - flash: [ 5.0741 ] Signed BCT for boot chain A is copied to /media/user/a4a32d54-50e9-458f-b0b2-cc65329b563e/nvidia_dw/JetPack_6.0_DP_Linux_DP_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/br_bct_BR.bct
10:02:41 INFO: Flash Jetson Linux - flash: [ 5.0741 ] Signed BCT for boot chain B is copied to /media/user/a4a32d54-50e9-458f-b0b2-cc65329b563e/nvidia_dw/JetPack_6.0_DP_Linux_DP_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/br_bct_b_BR.bct
10:02:41 INFO: Flash Jetson Linux - flash: [ 5.0756 ] Copying uefi_jetson_with_dtb_sigheader.bin.encrypt to /media/user/a4a32d54-50e9-458f-b0b2-cc65329b563e/nvidia_dw/JetPack_6.0_DP_Linux_DP_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed
10:02:41 INFO: Flash Jetson Linux - flash: [ 5.0782 ] Signed file: /media/user/a4a32d54-50e9-458f-b0b2-cc65329b563e/nvidia_dw/JetPack_6.0_DP_Linux_DP_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/uefi_jetson_with_dtb_sigheader.bin.encrypt
10:02:41 INFO: Flash Jetson Linux - flash: [ 5.0801 ] tegraparser_v2 --pt flash.xml.bin --generateflashindex /media/user/a4a32d54-50e9-458f-b0b2-cc65329b563e/nvidia_dw/JetPack_6.0_DP_Linux_DP_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/flash.xml.tmp flash.idx
10:02:41 INFO: Flash Jetson Linux - flash: '/media/user/a4a32d54-50e9-458f-b0b2-cc65329b563e/nvidia_dw/JetPack_6.0_DP_Linux_DP_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/flash.idx' -> '/media/user/a4a32d54-50e9-458f-b0b2-cc65329b563e/nvidia_dw/JetPack_6.0_DP_Linux_DP_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/flash.idx'
10:02:41 INFO: Flash Jetson Linux - flash: Flash index file is /media/user/a4a32d54-50e9-458f-b0b2-cc65329b563e/nvidia_dw/JetPack_6.0_DP_Linux_DP_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/flash.idx
10:02:41 INFO: Flash Jetson Linux - flash: Number of lines is 18
10:02:41 INFO: Flash Jetson Linux - flash: max_index=17
10:02:41 INFO: Flash Jetson Linux - flash: Copying /media/user/a4a32d54-50e9-458f-b0b2-cc65329b563e/nvidia_dw/JetPack_6.0_DP_Linux_DP_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/mbr_9_0.bin /media/user/a4a32d54-50e9-458f-b0b2-cc65329b563e/nvidia_dw/JetPack_6.0_DP_Linux_DP_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/mbr_9_0.bin
10:02:41 INFO: Flash Jetson Linux - flash: '/media/user/a4a32d54-50e9-458f-b0b2-cc65329b563e/nvidia_dw/JetPack_6.0_DP_Linux_DP_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/mbr_9_0.bin' -> '/media/user/a4a32d54-50e9-458f-b0b2-cc65329b563e/nvidia_dw/JetPack_6.0_DP_Linux_DP_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/mbr_9_0.bin'
10:02:41 INFO: Flash Jetson Linux - flash: Copying /media/user/a4a32d54-50e9-458f-b0b2-cc65329b563e/nvidia_dw/JetPack_6.0_DP_Linux_DP_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/gpt_primary_9_0.bin /media/user/a4a32d54-50e9-458f-b0b2-cc65329b563e/nvidia_dw/JetPack_6.0_DP_Linux_DP_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/gpt_primary_9_0.bin
10:02:41 INFO: Flash Jetson Linux - flash: '/media/user/a4a32d54-50e9-458f-b0b2-cc65329b563e/nvidia_dw/JetPack_6.0_DP_Linux_DP_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/gpt_primary_9_0.bin' -> '/media/user/a4a32d54-50e9-458f-b0b2-cc65329b563e/nvidia_dw/JetPack_6.0_DP_Linux_DP_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/gpt_primary_9_0.bin'
10:02:41 INFO: Flash Jetson Linux - flash: Copying /media/user/a4a32d54-50e9-458f-b0b2-cc65329b563e/nvidia_dw/JetPack_6.0_DP_Linux_DP_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/boot.img /media/user/a4a32d54-50e9-458f-b0b2-cc65329b563e/nvidia_dw/JetPack_6.0_DP_Linux_DP_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/boot.img
10:02:41 INFO: Flash Jetson Linux - flash: '/media/user/a4a32d54-50e9-458f-b0b2-cc65329b563e/nvidia_dw/JetPack_6.0_DP_Linux_DP_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/boot.img' -> '/media/user/a4a32d54-50e9-458f-b0b2-cc65329b563e/nvidia_dw/JetPack_6.0_DP_Linux_DP_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/boot.img'
10:02:41 INFO: Flash Jetson Linux - flash: Copying /media/user/a4a32d54-50e9-458f-b0b2-cc65329b563e/nvidia_dw/JetPack_6.0_DP_Linux_DP_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/kernel_tegra234-p3768-0000+p3767-0001-nv.dtb /media/user/a4a32d54-50e9-458f-b0b2-cc65329b563e/nvidia_dw/JetPack_6.0_DP_Linux_DP_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/kernel_tegra234-p3768-0000+p3767-0001-nv.dtb
10:02:41 INFO: Flash Jetson Linux - flash: '/media/user/a4a32d54-50e9-458f-b0b2-cc65329b563e/nvidia_dw/JetPack_6.0_DP_Linux_DP_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/kernel_tegra234-p3768-0000+p3767-0001-nv.dtb' -> '/media/user/a4a32d54-50e9-458f-b0b2-cc65329b563e/nvidia_dw/JetPack_6.0_DP_Linux_DP_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/tools/kernel_flash/images/external/kernel_tegra234-p3768-0000+p3767-0001-nv.dtb'
10:06:47 INFO: Flash Jetson Linux - flash: [ 6.6569 ] partition type mb2_applet, magic id = MB2A
10:06:47 INFO: Flash Jetson Linux - flash: [ 6.7114 ] partition type xusb_fw, magic id = XUSB
10:07:06 INFO: Flash Jetson Linux - flash: version 1.0.0
serial logs:
[0579.771] I> MB1 (version: 1.4.0.1-t234-54845784-08e631ca)
[0579.776] I> t234-A01-0-Silicon (0x12347) Prod
[0579.781] I> Boot-mode : BPMP Diagnostic
[0579.784] I> Entry timestamp: 0x00000000
[0579.788] I> last_boot_error: 0x0
[0579.791] I> BR-BCT: preprod_dev_sign: 0
[0579.795] I> rst_source: 0xb, rst_level: 0x1
[0579.799] I> Task: Initialize MB2 params
[0579.803] I> MB2-params @ 0x40060000
[0579.807] I> Task: Crypto init
[0579.810] I> Task: Perform MB1 KAT tests
[0579.814] I> Task: NVRNG health check
[0579.817] I> NVRNG: Health check success
[0579.821] I> Task: Secure debug controls
[0579.825] I> Task: strap war set
[0579.828] I> Task: Program NV master stream id
[0579.832] I> Task: Verify boot mode
[0579.838] I> Task: Alias fuses
[0579.841] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0579.848] I> Task: Print SKU type
[0579.852] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c8
[0579.857] I> FUSE_OPT_GPC_DISABLE = 0x00000002
[0579.861] I> FUSE_OPT_TPC_DISABLE = 0x000000f0
[0579.865] I> FUSE_OPT_DLA_DISABLE = 0x00000002
[0579.870] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0579.874] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0579.878] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0579.883] I> FUSE_OPT_FSI_DISABLE = 0x00000001
[0579.887] I> FUSE_OPT_EMC_DISABLE = 0x0000000c
[0579.891] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0579.896] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0579.900] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0579.904] I> FUSE_SKU_INFO_0 = 0xd4
[0579.907] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0579.911] I> FUSE_PACKAGE_INFO_0 = 0x2
[0579.915] I> SKU: Prod
[0579.917] I> Task: Boost clocks
[0579.920] I> Initializing NAFLL for BPMP_CPU_NIC.
[0579.925] I> BPMP NAFLL: fll_lock = 1, dvco_min_reached = 0
[0579.931] I> BPMP NAFLL lock success.
[0579.934] I> BPMP_CPU_NIC : src = 42, divisor = 0
[0579.939] I> Initializing PLLC2 for AXI_CBB.
[0579.943] I> AXI_CBB : src = 35, divisor = 0
[0579.947] I> Task: Voltage monitor
[0579.950] I> VMON: Vmon re-calibration and fine tuning done
[0579.956] I> Task: UPHY init
[0579.959] W> UPHY: UPHY lane info table is empty in MB1 BCT.
[0579.965] I> Task: Boot device init
[0579.968] I> Boot_device: RCM
[0579.971] I> USB configuration success
[0579.975] I> Task: TSC init
[0579.978] I> Task: Enable WDT 5th expiry
[0579.982] I> Task: I2C register
[0579.985] I> Task: Set I2C bus freq
[0579.988] I> Task: Reset FSI
[0579.991] I> Task: Enable clock-mon
[0579.995] I> FMON: Fmon re-programming done
[0579.999] I> Task: Mapper init
[0580.002] I> Task: MB1 fixed firewalls
[0580.008] W> Firewall readback mismatch
[0580.013] I> Task: Load MB2/Applet/FSKP
[0580.017] I> Loading MB2 Applet
[0580.020] I> Slot: 0
[0580.022] I> Binary[21] block-352321536 (partition size: 0x50000)
[0580.028] I> Binary name: MB2-Applet
[0580.031] I> Size of crypto header is 8192
[0580.035] I> Size of crypto header is 8192
[0580.111] I> BCH of MB2-Applet read from storage
[0580.115] I> BCH address is : 0x4004e000
[0580.119] I> MB2-Applet header integrity check is success
[0580.125] I> Binary magic in BCH component 0 is MB2A
[0580.129] I> component binary type is 21
[0580.133] I> Size of crypto header is 8192
[0580.495] I> MB2-Applet binary is read from storage
[0580.500] I> MB2-Applet binary integrity check is success
[0580.505] I> Binary MB2-Applet loaded successfully at 0x40000000 (0x42440)
[0580.512] I> Task: Prepare MB2 params
[0580.516] I> Task: Misc NV security settings
[0580.520] I> NVDEC sticky bits programming done
[0580.525] I> Successfully powergated NVDEC
[0580.529] I> Task: Disable/Reload WDT
[0580.532] I> Task: Program misc carveouts
[0580.536] I> Task: Disable SCPM/POD reset
[0580.540] I> SLCG Global override status := 0x0
[0580.544] I> MB1: MSS reconfig completed
[0580.548] W> Firewall readback mismatch
[0580.552] W> Firewall readback mismatch
[0580.555] W> Firewall readback mismatch
[0580.559] W> Firewall readback mismatch
[0580.563] W> Firewall readback mismatch
[0580.566] W> Firewall readback mismatch
[0580.570] W> Firewall readback mismatch
[0580.574] W> Firewall readback mismatch
[0580.578] W> Firewall readback mismatch
[0580.581] W> Firewall readback mismatch
I> Applet (version: 0.0.0.0-t234-54845784-b648c465)
I> Emulation:
I> Task: Pinmux init
I> Applet do storage init
I> Boot_device: QSPI_FLASH instance: 0
I> Qspi clock source : clk_m
I> QSPI Flash: Macronix 64MB
I> QSPI-0l initialized successfully
I> Secondary storage device: SDMMC_BOOT instance: 3
E> Error in command_complete 18000 int_status
E> OCR failed, error = 39390706
E> STORAGE: Failed to open SDMMC: 3.
W> Ignoring init failure for device 0-3
I> Secondary storage device: SDMMC_USER instance: 3
W> Ignoring init failure for device 1-3
I> Secondary storage device: QSPI_FLASH instance: 0
I> Task: Register exit handlers
I> Task: Enter 3p server
I> Populate chip info
I> RAM_CODE 0x4000021
I> Populate eeprom info
I> Populate eeprom info for module cvm
I> dump bct
I> strt_pg_num(0) num_of_pgs(16) read_buf(0x40071738)
E> LOADER: Invalid value Header magic.
E> Validation failed for 1 copy of BRBCT @ 0
I> strt_pg_num(512) num_of_pgs(16) read_buf(0x40071738)
E> Validation failed for 2 copy of BRBCT @ 262144
I> strt_pg_num(1024) num_of_pgs(16) read_buf(0x40071738)
E> Validation failed for 3 copy of BRBCT @ 524288
I> strt_pg_num(1536) num_of_pgs(16) read_buf(0x40071738)
E> Validation failed for 4 copy of BRBCT @ 786432
E> NV3P_SERVER: Failed to get address for br bct from nv3p helper.
I> Rebooting : reboot-recovery
[0048.268] I> MB1 (version: 1.4.0.1-t234-54845784-08e631ca)
[0048.273] I> t234-A01-0-Silicon (0x12347) Prod
[0048.277] I> Boot-mode : Coldboot
[0048.280] I> Entry timestamp: 0x00000000
[0048.284] I> last_boot_error: 0x0
[0048.287] I> BR-BCT: preprod_dev_sign: 0
[0048.291] I> rst_source: 0xb, rst_level: 0x1
[0048.295] I> Task: SE error check
[0048.298] I> Task: Bootchain select WAR set
[0048.302] I> Task: Enable SLCG
[0048.305] I> Task: CRC check
[0048.308] I> Task: Initialize MB2 params
[0048.312] I> MB2-params @ 0x40060000
[0048.316] I> Task: Crypto init
[0048.319] I> Task: Perform MB1 KAT tests
[0048.323] I> Task: NVRNG health check
[0048.326] I> NVRNG: Health check success
[0048.330] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0048.336] I> Task: Enabling and initialization of Bandwidth limiter
[0048.342] I> No request to configure MBWT settings for any PC!
[0048.348] I> Task: Secure debug controls
[0048.352] I> Task: strap war set
[0048.355] I> Task: Initialize SOC Therm
[0048.358] I> Task: Program NV master stream id
[0048.363] I> Task: Verify boot mode
[0048.368] I> Task: Alias fuses
[0048.372] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0048.379] I> Task: Print SKU type
[0048.382] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c8
[0048.388] I> FUSE_OPT_GPC_DISABLE = 0x00000002
[0048.392] I> FUSE_OPT_TPC_DISABLE = 0x000000f0
[0048.396] I> FUSE_OPT_DLA_DISABLE = 0x00000002
[0048.401] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0048.405] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0048.409] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0048.414] I> FUSE_OPT_FSI_DISABLE = 0x00000001
[0048.418] I> FUSE_OPT_EMC_DISABLE = 0x0000000c
[0048.422] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0048.427] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0048.431] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0048.435] I> FUSE_SKU_INFO_0 = 0xd4
[0048.438] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0048.442] I> FUSE_PACKAGE_INFO_0 = 0x2
[0048.446] I> SKU: Prod
[0048.448] I> Task: Boost clocks
[0048.451] I> Initializing NAFLL for BPMP_CPU_NIC.
[0048.456] I> BPMP NAFLL: fll_lock = 1, dvco_min_reached = 0
[0048.462] I> BPMP NAFLL lock success.
[0048.465] I> BPMP_CPU_NIC : src = 42, divisor = 0
[0048.470] I> Initializing PLLC2 for AXI_CBB.
[0048.474] I> AXI_CBB : src = 35, divisor = 0
[0048.478] I> Task: Voltage monitor
[0048.481] I> VMON: Vmon re-calibration and fine tuning done
[0048.487] I> Task: UPHY init
[0048.492] I> HSIO UPHY init done
[0048.495] W> Skipping GBE UPHY config
[0048.498] I> Task: Boot device init
[0048.501] I> Boot_device: RCM
[0048.504] I> USB configuration success
[0048.508] I> Task: TSC init
[0048.511] I> Task: Load membct
[0048.514] I> RAM_CODE 0x4000021
[0048.517] I> Loading MEMBCT
[0048.520] I> Slot: 0
[0048.522] I> Binary[0] block-0 (partition size: 0x40000)
[0048.527] I> Binary name: MEM-BCT-0
[0048.530] I> Size of crypto header is 8192
[0048.534] I> Size of crypto header is 8192
[0048.549] I> BCH of MEM-BCT-0 read from storage
[0048.553] I> BCH address is : 0x40050000
[0048.557] I> MEM-BCT-0 header integrity check is success
[0048.562] I> Binary magic in BCH component 0 is MEM0
[0048.567] I> component binary type is 0
[0048.648] I> MEM-BCT-0 binary is read from storage
[0048.653] I> MEM-BCT-0 binary integrity check is success
[0048.658] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0048.664] I> RAM_CODE 0x4000021
[0048.670] I> RAM_CODE 0x4000021
[0048.674] I> Task: Load Page retirement list
[0048.678] I> Task: SDRAM params override
[0048.682] I> Task: Save mem-bct info
[0048.685] I> Task: Carveout allocate
[0048.689] I> Update CCPLEX IST carveout from MB1-BCT
[0048.693] I> ECC region[0]: Start:0x0, End:0x0
[0048.698] I> ECC region[1]: Start:0x0, End:0x0
[0048.702] I> ECC region[2]: Start:0x0, End:0x0
[0048.706] I> ECC region[3]: Start:0x0, End:0x0
[0048.711] I> ECC region[4]: Start:0x0, End:0x0
[0048.715] I> Non-ECC region[0]: Start:0x80000000, End:0x280000000
[0048.721] I> Non-ECC region[1]: Start:0x0, End:0x0
[0048.725] I> Non-ECC region[2]: Start:0x0, End:0x0
[0048.730] I> Non-ECC region[3]: Start:0x0, End:0x0
[0048.735] I> Non-ECC region[4]: Start:0x0, End:0x0
[0048.745] I> allocated(CO:43) base:0xbe000000 size:0x4000000 align: 0x200000
[0048.752] I> allocated(CO:39) base:0x27de00000 size:0x2200000 align: 0x10000
[0048.759] I> allocated(CO:20) base:0x27a000000 size:0x2000000 align: 0x2000000
[0048.766] I> allocated(CO:24) base:0x278000000 size:0x2000000 align: 0x2000000
[0048.773] I> allocated(CO:28) base:0x276000000 size:0x2000000 align: 0x2000000
[0048.781] I> allocated(CO:22) base:0x27c000000 size:0x1000000 align: 0x1000000
[0048.788] I> allocated(CO:35) base:0x275000000 size:0x1000000 align: 0x100000
[0048.795] I> allocated(CO:02) base:0x27d000000 size:0x800000 align: 0x800000
[0048.802] I> allocated(CO:03) base:0x274800000 size:0x800000 align: 0x800000
[0048.809] I> allocated(CO:06) base:0x274000000 size:0x800000 align: 0x800000
[0048.816] I> allocated(CO:56) base:0x273800000 size:0x800000 align: 0x200000
[0048.823] I> allocated(CO:07) base:0x27d800000 size:0x400000 align: 0x400000
[0048.829] I> allocated(CO:33) base:0x273400000 size:0x400000 align: 0x200000
[0048.836] I> allocated(CO:19) base:0x273180000 size:0x280000 align: 0x10000
[0048.843] I> allocated(CO:23) base:0x27dc00000 size:0x200000 align: 0x200000
[0048.850] I> allocated(CO:01) base:0x273000000 size:0x100000 align: 0x100000
[0048.857] I> allocated(CO:05) base:0x272f00000 size:0x100000 align: 0x100000
[0048.864] I> allocated(CO:08) base:0x272e00000 size:0x100000 align: 0x100000
[0048.871] I> allocated(CO:09) base:0x272d00000 size:0x100000 align: 0x100000
[0048.878] I> allocated(CO:12) base:0x272c00000 size:0x100000 align: 0x100000
[0048.885] I> allocated(CO:15) base:0x272b00000 size:0x100000 align: 0x100000
[0048.892] I> allocated(CO:17) base:0x272a00000 size:0x100000 align: 0x100000
[0048.899] I> allocated(CO:27) base:0x272900000 size:0x100000 align: 0x100000
[0048.906] I> allocated(CO:42) base:0x272800000 size:0x100000 align: 0x100000
[0048.913] I> allocated(CO:54) base:0x273100000 size:0x80000 align: 0x80000
[0048.919] I> allocated(CO:34) base:0x2727f0000 size:0x10000 align: 0x10000
[0048.926] I> allocated(CO:72) base:0x2725f0000 size:0x200000 align: 0x10000
[0048.933] I> allocated(CO:46) base:0x240000000 size:0x20000000 align: 0x20000000
[0048.940] I> allocated(CO:47) base:0x272000000 size:0x400000 align: 0x200000
[0048.947] I> allocated(CO:50) base:0x271e00000 size:0x200000 align: 0x100000
[0048.954] I> allocated(CO:48) base:0x2725d0000 size:0x20000 align: 0x10000
[0048.961] I> allocated(CO:69) base:0x2725b0000 size:0x20000 align: 0x10000
[0048.968] I> allocated(CO:49) base:0x2725a0000 size:0x10000 align: 0x10000
[0048.975] I> NSDRAM base: 0x80000000, end: 0x2725f0000, size: 0x1f25f0000
[0048.981] I> Task: Thermal check
[0048.984] I> max_chip_limit = 105
[0048.987] I> min_chip_limit = -28
[0048.991] I> max temp read = 40
[0048.994] I> min temp read = 39
[0048.997] I> Task: Update FSI SCR with thermal fuse data
[0049.002] I> Task: Enable WDT 5th expiry
[0049.006] I> Task: I2C register
[0049.009] I> Task: Set I2C bus freq
[0049.012] I> Task: Reset FSI
[0049.015] I> Task: Pinmux init
[0049.018] I> skipped mmio_addr = 0x9240008
[0049.022] I> skipped mmio_addr = 0x9240000
[0049.026] I> skipped mmio_addr = 0x9240010
[0049.030] I> skipped mmio_addr = 0x9240018
[0049.034] I> skipped mmio_addr = 0x9240020
[0049.038] I> skipped mmio_addr = 0x9240030
[0049.041] I> skipped mmio_addr = 0x9240028
[0049.045] I> skipped mmio_addr = 0x9240038
[0049.049] I> skipped mmio_addr = 0x9240040
[0049.053] I> skipped mmio_addr = 0x9240048
[0049.057] I> skipped mmio_addr = 0x9241000
[0049.061] I> skipped mmio_addr = 0x9241008
[0049.065] I> skipped mmio_addr = 0x9241010
[0049.069] I> skipped mmio_addr = 0x9241018
[0049.073] I> skipped mmio_addr = 0x9241020
[0049.077] I> skipped mmio_addr = 0x9241028
[0049.081] I> skipped mmio_addr = 0x9241030
[0049.085] I> skipped mmio_addr = 0x9241038
[0049.089] I> skipped mmio_addr = 0x9241040
[0049.093] I> skipped mmio_addr = 0x9242000
[0049.097] I> skipped mmio_addr = 0x9242008
[0049.101] I> Task: Prod config init
[0049.104] I> Task: Pad voltage init
[0049.107] I> Task: Prod init
[0049.110] I> Task: Program rst req config reg
[0049.114] I> Task: Common rail init
[0049.118] I> DONE: Thermal config
[0049.122] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0049.130] I> DONE: SOC rail config
[0049.134] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0049.140] I> DONE: MEMIO rail config
[0049.144] W> PMIC_CONFIG: Rail: GPU rail info not found in MB1 BCT.
[0049.150] I> DONE: GPU rail info
[0049.153] W> PMIC_CONFIG: Rail: CV rail info not found in MB1 BCT.
[0049.159] I> DONE: CV rail info
[0049.162] I> Task: Mem clock src
[0049.165] I> Task: Misc. board config
[0049.169] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0049.175] I> Task: SDRAM init
[0049.178] I> MemoryType: 4 MemBctRevision: 1
[0049.184] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 1
[0049.192] I> MSS CAR: Init PLLM
[0049.195] I> MSS CAR: Init PLLHUB
[0049.199] I> Encryption: MTS: en, TX: en, VPR: en, GSC: en
[0049.211] I> SDRAM initialized!
[0049.214] I> SDRAM Size in Total 0x200000000
[0049.218] I> Task: Dram Ecc scrub
[0049.221] I> Task: DRAM alias check
[0049.228] I> Task: Program NSDRAM carveout
[0049.232] I> NSDRAM carveout encryption is enabled
[0049.236] I> Program NSDRAM carveout
[0049.240] I> Task: Register checker
[0049.243] I> Task: Enable clock-mon
[0049.247] I> FMON: Fmon re-programming done
[0049.251] I> Task: Mapper init
[0049.254] I> Task: SC7 Context Init
[0049.258] W> SC7_CONTEXT_SAVE: SC7 ctx save is not supported.
[0049.263] I> Task: CCPLEX IST init
[0049.266] I> Task: CPU WP0
[0049.269] I> Loading MCE
[0049.271] I> Slot: 0
[0049.273] I> Binary[8] block-134217728 (partition size: 0x80000)
[0049.279] I> Binary name: MCE
[0049.282] I> Size of crypto header is 8192
[0049.286] I> Size of crypto header is 8192
When trying to flash also with my custom carrier, it also fails after [0049.282] I> Size of crypto header is 8192. (the usb device disappears on step3 (when flashing the image)
I was able to flash before, I’m not sure but maybe this issue came after I tried to flash with /doflash.sh.
Any idea…?
