Now I installed an Ubuntu Linux 22.04 and Nvidia SDK manager, and I’m trying to flash the Jetson Orin Nano Dev kit. The flashing process stopped on about 96% with the error. Do not know how to proceed now… I attached NVme module to the Jetson device and tried to flash on this module.
I suspect, main error message is the following:
15:43:32.877 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: Creating filesystem with 62133513 4k blocks and 15540224 inodes
15:43:32.878 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: Filesystem UUID: 74797da7-d1b9-4c7f-a49e-1fbb20da2170
15:43:32.878 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: Superblock backups stored on blocks:
15:43:32.878 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: 32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208,
15:43:32.878 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: 4096000, 7962624, 11239424, 20480000, 23887872
15:43:32.907 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: Allocating group tables: 0/1897 done
15:43:32.907 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: Writing inode tables: 0/1897 done
15:43:33.359 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: Creating journal (262144 blocks): done
15:43:33.397 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: Writing superblocks and filesystem accounting information: 0/1897 done
15:43:33.397 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: Formatting APP parition done
15:43:33.421 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: Formatting APP partition /dev/nvme0n1p1 ...
15:43:33.421 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: tar -xpf /mnt/external/system.img --checkpoint=10000 --warning=no-timestamp --numeric-owner --xattrs --xattrs-include=* -C /tmp/ci-BySF8P9Awz
15:43:34.611 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: tar: Read checkpoint 10000
15:43:35.651 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: tar: Read checkpoint 20000
15:43:36.680 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: tar: Read checkpoint 30000
15:43:37.685 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: tar: Read checkpoint 40000
15:43:38.844 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: tar: Read checkpoint 50000
15:43:39.989 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: tar: Read checkpoint 60000
15:43:41.061 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: tar: Read checkpoint 70000
15:43:42.173 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: tar: Read checkpoint 80000
15:43:43.232 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: tar: Read checkpoint 90000
15:43:44.387 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: tar: Read checkpoint 100000
15:43:45.445 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: tar: Read checkpoint 110000
15:43:46.505 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: tar: Read checkpoint 120000
15:43:47.553 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: tar: Read checkpoint 130000
15:43:48.718 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: tar: Read checkpoint 140000
15:43:49.950 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: tar: Read checkpoint 150000
15:49:50.273 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: Flash failure
15:49:50.274 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: Cleaning up...
15:49:50.308 - error: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: [exec_command]: /bin/bash -c /tmp/tmp_NV_L4T_FLASH_JETSON_LINUX_COMP.igor.sh; [error]: 128307 blocks
15:49:50.308 - info: Event: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS - error is: [exec_command]: /bin/bash -c /tmp/tmp_NV_L4T_FLASH_JETSON_LINUX_COMP.igor.sh; [error]: 128307 blocks
15:49:50.308 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS:
15:49:50.309 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS:
15:49:50.309 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: [ Component Install Finished with Error ]
15:49:50.309 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: [host] [ 19.51 GB used. Disk Avail: 659.67 GB ]
15:49:50.309 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_ORIN_NANO_TARGETS: [ NV_L4T_FLASH_JETSON_LINUX_COMP Install took 13m50s ]
several spots from the logs , that might be relevant, are below
Pre-processing mb2bct config: tegra234-mb2-bct-misc-p3767-0000.dts
[ 0.1761 ] Pre-processing mb2bct config: tegra234-mb2-bct-scr-p3767-0000.dts
[ 0.3368 ] Generating coldboot mb2-bct
[ 0.3368 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_cold_boot_bct.cfg --mb2bctcfg tegra234-mb2-bct-misc-p3767-0000_cpp.dtb --scr tegra234-mb2-bct-scr-p3767-0000_cpp.dtb
[ 0.3371 ] ERROR: value 0x31 is out of range
[ 0.3381 ] ERROR: value 0x31 is out of range
[ 1.4711 ] Parsing config file :tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb
[ 1.4711 ] ERROR: /ratchet/atf is not supported
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0099 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.0102 ] File rcm_state open failed
[ 0.0103 ] ERROR: failed to read rcm_state
tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.0700 ] Error: Skip generating mem_bct because sdram_config is not defined
[ 0.0700 ] Copying signatures
[ 0.1011 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download applet applet_t234_sigheader.bin.encrypt
[ 0.1013 ] BL: version 1.4.0.1-t234-54845784-08e631ca last_boot_error: 0
[ 0.3175 ] Sending applet
[ 0.4191 ] completed
[ 0.1224 ] Added binary blob_tegra234-p3768-0000+p3767-0005-nv.dtb of size 241963
[ 0.1650 ] tegrarcm_v2 --instance 3-2 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
[ 0.1653 ] BL: version 1.4.0.1-t234-54845784-08e631ca last_boot_error: 0
[ 0.3240 ] Sending bct_mem
[ 0.3401 ] Sending blob
[ 3.6946 ] RCM-boot started
dd if=/mnt/external/gpt_primary_9_0.bin of=/dev/nvme0n1 bs=1 skip=0 seek=512 count=16896
16896+0 records in
16896+0 records out
16896 bytes (17 kB, 16 KiB) copied, 0.0285908 s, 591 kB/s
Writing primary_gpt partition done
Error: The backup GPT table is corrupt, but the primary appears OK, so that will be used.
Warning: Not all of the space available to /dev/nvme0n1 appears to be used, you can fix the GPT to use all of the space (an extra 380580528 blocks) or continue with the current setting?
Writing secondary_gpt partition with gpt_secondary_9_0.bin
Offset is not aligned to K Bytes, no optimization is applied
dd if=/mnt/external/gpt_secondary_9_0.bin of=/dev/nvme0n1 bs=1 skip=0 seek=61203267072 count=16896
16896+0 records in
16896+0 records out
16896 bytes (17 kB, 16 KiB) copied, 0.0287382 s, 588 kB/s
Writing secondary_gpt partition done
Fix/Ignore? Fix
Model: SK hynix BC711 HFM256GD3JX013N (nvme)
Disk /dev/nvme0n1: 256GB
Sector size (logical/physical): 512B/512B
Partition Table: gpt
Flash failure
Cleaning up…
15:49:50.300 - Error: [exec_command]: /bin/bash -c /tmp/tmp_NV_L4T_FLASH_JETSON_LINUX_COMP.igor.sh; [error]: 128307 blocks
15:49:50.300 - Info: [ Component Install Finished with Error ]
15:49:50.300 - Info: [host] [ 19.51 GB used. Disk Avail: 659.67 GB ]
15:49:50.300 - Info: [ NV_L4T_FLASH_JETSON_LINUX_COMP Install took 13m50s ]
