Fail to flash the nvme drive on a Jetson Orin Nano 8Gb developer kit
Set the recovery jumper
See the jetson on Ubuntu 20.04 (lsusb)
Prepare image & other stuff (green bard)
Writing nvme drive => Fail
My SSD is SN520 258GB than drive first is ext4
what can I do…
/home/danny/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra/temp_initrdflash/bootloader0 /home/danny/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_ORIN_NANO_TARGETS/Linux_for_Tegra
./tegraflash.py --bl uefi_jetson_with_dtb_sigheader.bin.encrypt --bct br_bct_BR.bct --securedev --bldtb tegra234-p3767-0003-p3768-0000-a0.dtb --applet rcm_2_encrypt.rcm --applet_softfuse rcm_1_encrypt.rcm --cmd "rcmboot" --cfg secureflash.xml --chip 0x23 --mb1_bct mb1_bct_MB1_sigheader.bct.encrypt --mem_bct mem_rcm_sigheader.bct.encrypt --mb1_cold_boot_bct mb1_cold_boot_bct_MB1_sigheader.bct.encrypt --mb1_bin mb1_t234_prod_aligned_sigheader.bin.encrypt --psc_bl1_bin psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --mem_bct_cold_boot mem_coldboot_sigheader.bct.encrypt --bins "psc_fw pscfw_t234_prod_sigheader.bin.encrypt; mts_mce mce_flash_o10_cr_prod_sigheader.bin.encrypt; mb2_applet applet_t234_sigheader.bin.encrypt; mb2_bootloader mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt; xusb_fw xusb_t234_prod_sigheader.bin.encrypt; dce_fw display-t234-dce_sigheader.bin.encrypt; nvdec nvdec_t234_prod_sigheader.fw.encrypt; bpmp_fw bpmp_t234-TE950M-A1_prod_sigheader.bin.encrypt; bpmp_fw_dtb tegra234-bpmp-3767-0003-3509-a02_with_odm_sigheader.dtb.encrypt; sce_fw camera-rtcpu-sce_sigheader.img.encrypt; rce_fw camera-rtcpu-t234-rce_sigheader.img.encrypt; ape_fw adsp-fw_sigheader.bin.encrypt; spe_fw spe_t234_sigheader.bin.encrypt; tos tos-optee_t234_sigheader.img.encrypt; eks eks_t234_sigheader.img.encrypt; kernel boot0.img; kernel_dtb tegra234-p3767-0003-p3768-0000-a0.dtb" --secondary_gpt_backup --bct_backup --instance 1-2
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
Entering RCM boot
[ 0.0368 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from --mb1_bin
[ 0.0368 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from --psc_bl1_bin
[ 0.0368 ] rcm boot with presigned binaries
[ 0.0379 ] tegrarcm_v2 --instance 1-2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 0.0391 ] BR_CID: 0x80012344705DE7C70C0000000EFF8140
[ 0.0505 ] Sending bct_br
[ 0.0549 ] Sending mb1
[ 0.0553 ] Sending psc_bl1
[ 0.0656 ] Sending bct_mb1
[ 0.0720 ] Generating blob for T23x
[ 0.0747 ] tegrahost_v2 --chip 0x23 0 --generateblob blob.xml blob.bin
[ 0.0756 ] The number of images in blob is 18
[ 0.0759 ] blobsize is 73366298
[ 0.0760 ] Added binary blob_uefi_jetson_with_dtb_sigheader.bin.encrypt of size 2924608
[ 0.1046 ] Added binary blob_pscfw_t234_prod_sigheader.bin.encrypt of size 375168
[ 0.1055 ] Added binary blob_mce_flash_o10_cr_prod_sigheader.bin.encrypt of size 190592
[ 0.1059 ] Added binary blob_applet_t234_sigheader.bin.encrypt of size 277312
[ 0.1062 ] Not supported type: mb2_applet
[ 0.1063 ] Added binary blob_mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt of size 438768
[ 0.1067 ] Added binary blob_xusb_t234_prod_sigheader.bin.encrypt of size 164864
[ 0.1070 ] Added binary blob_display-t234-dce_sigheader.bin.encrypt of size 9097216
[ 0.1135 ] Added binary blob_nvdec_t234_prod_sigheader.fw.encrypt of size 294912
[ 0.1154 ] Added binary blob_bpmp_t234-TE950M-A1_prod_sigheader.bin.encrypt of size 1051136
[ 0.1161 ] Added binary blob_tegra234-bpmp-3767-0003-3509-a02_with_odm_sigheader.dtb.encrypt of size 110080
[ 0.1166 ] Added binary blob_camera-rtcpu-sce_sigheader.img.encrypt of size 166304
[ 0.1169 ] Added binary blob_camera-rtcpu-t234-rce_sigheader.img.encrypt of size 537952
[ 0.1172 ] Added binary blob_adsp-fw_sigheader.bin.encrypt of size 400864
[ 0.1175 ] Added binary blob_spe_t234_sigheader.bin.encrypt of size 270336
[ 0.1178 ] Added binary blob_tos-optee_t234_sigheader.img.encrypt of size 1127568
[ 0.1181 ] Added binary blob_eks_t234_sigheader.img.encrypt of size 9232
[ 0.1184 ] Added binary blob_boot0.img of size 55580672
[ 0.1545 ] Added binary blob_tegra234-p3767-0003-p3768-0000-a0.dtb of size 347610
[ 0.2096 ] tegrarcm_v2 --instance 1-2 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
[ 0.2102 ] BL: version 1.2.0.0-t234-54845784-562369e5 last_boot_error: 0
[ 0.3146 ] Sending bct_mem
[ 0.3255 ] Sending blob
[ 3.4686 ] RCM-boot started
* Step 3: Start the flashing process *
Waiting for target to boot-up...
Waiting for device to expose ssh ......RTNETLINK answers: File exists
Waiting for device to expose ssh ...Run command: flash on fc00:1:1:0::2
SSH ready
blockdev: cannot open /dev/mmcblk0boot0: No such file or directory
[ 0]: l4t_flash_from_kernel: Starting to create gpt for emmc
Active index file is /mnt/internal/flash.idx
Number of lines is 58
max_index=57
[ 1]: l4t_flash_from_kernel: Successfully create gpt for emmc
[ 1]: l4t_flash_from_kernel: Starting to create gpt for external device
Active index file is /mnt/external/flash.idx
Number of lines is 18
max_index=17
writing item=1, 9:0:primary_gpt, 512, 19968, gpt_primary_9_0.bin, 16896, fixed-<reserved>-0, 66cca7a3e57f1fe10e5ed62105c14d8afbaa6fe8
Error: Could not stat device /dev/nvme0n1 - No such file or directory.
Flash failure
Cleaning up...```
