Any steps for making the orin nano to boot from nvme instead of SD card,
we had flashed image to nvme and powered on device , its stopping at bootloader level it seems,
prompt came,
Shell>
UEFI Interactive Shell v2.2
EDK II
UEFI v2.70 (EDK II, 0x00010000)
Mapping table
FS1: Alias(s):F1:
MemoryMapped(0xB,0x272000000,0x27230FFFF)
FS0: Alias(s):F0:
Fv(49A79A15-8F69-4BE7-A30C-A172F44ABCE7)
BLK0: Alias(s):
VenHw(1E5A432C-0466-4D31-B009-D4D9239271D3)/MemoryMapped(0xB,0x1416000
0,0x1417FFFF)/PciRoot(0x0)/Pci(0x0,0x0)/Pci(0x0,0x0)/NVMe(0x1,95-19-C5-2F-52-48-
35-7C)
Press ESC in 5 seconds to skip startup.nsh or any other key to continue.
Shell>
which is the stable version? we are doing a product development with some custom carrier board, so that which u suggest us to go ahead and use, right now we are using 36.2.1.
From 35.5. also same issue, i have attached the logs for reference,
do u want us to change the boo nvme_bootlogs_35_5.txt (37.0 KB)
tloader also from 35.5?
Your current log stands for a case called “recovery boot”.
This situation would happen when your “previous” boot are all failed and in consecutive 3 times.
Thus, what we need to check is your previous failure log, but not this time.
Reflash your board again and immediately share me the log right after your flash. Do not wait for a while. Your waiting may just lead to another recovery boot.
