Jetson Orin NX 8G flash failure
I am flashing a Orin NX 8G from Jetpack 5.1.1 to Jetpack 6.2,
it failed with some USB or rcm_state related error.
SDKM_logs_JetPack_6.2_Linux_for_Jetson_Orin_NX_8GB_2025-03-25_15-31-35.zip (157.7 KB)
I tried using SDK manager or command line on ubuntu 20.04 / 22.04 all received the same results.
USB 2.0 is working fine and target Orin NX was put in recovery mode successfully.
Some questions to confirm:
  • Is your ubuntu a native or a virtual machine (e.g. VMware)?
  • Is your Orin Nx a dev kit or a custom board?
Hi David,
I am using native ubuntu and NX Dev Kit.
just solved the issue by Disable autosuspend on host PC with below command:
sudo -s
echo -1 > /sys/module/usbcore/parameters/autosuspend
referring to another post.
the other question to you:
I am trying to put NX in SUPER mode, from command script flashing, there’s option to enable:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1
-c tools/kernel_flash/flash_l4t_t234_nvme.xml -p “-c bootloader/generic/cfg/flash_t234_qspi.xml”
–showlogs --network usb0 jetson-orin-nano-devkit-super internal
however, by SDK Manager there’s no such option, how to enable SUPER mode if I flash NX using SDK Manager?
SDK manager default will use the jetson-orin-nano-devkit-super config and enable the super mode
Flashed Orin NX 8G to L4T R36.4.3, set power mode to MAXN, however GPU frequency is till Maximized at 765MHz instead of 1.2GHz.
also in nvpmodel.conf
< POWER_MODEL ID=3 NAME=20W >
I didn’t see
< POWER_MODEL ID=4 NAME=40W >
what other configuration I need to change?
Hi @DavidDDD,
please advise.
Regards,
Apologies for mislead.
With internal team discussion, current sdkm not support it.
Please download Driver Package (BSP) and Sample Root Filesystem from Jetson Linux | NVIDIA Developer.
And follow the Quick Start — NVIDIA Jetson Linux Developer Guide to setup
and execute flash command below:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -p "-c ./bootloader/generic/cfg/flash_t234_qspi.xml" -c ./tools/kernel_flash/flash_l4t_t234_nvme.xml --showlogs --network usb0 jetson-orin-nano-devkit-super external
Also, Do you execute sudo jetson_clocks before stress test?
Hi @DavidDDD
yes, did jetson_clocks after flashing and Orin NX 16G GPU frequency tops at 918 MHz.
using command script, still failed with below messages:
adv@adv-Default-string:~/Downloads/Linux_for_Tegra$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -p “-c ./bootloader/generic/cfg/flash_t234_qspi.xml” -c ./tools/kernel_flash/flash_l4t_t234_nvme.xml --showlogs --network usb0 jetson-orin-nano-devkit-super external
Please install the Secureboot package to use initrd flash for fused board
Entry added by NVIDIA initrd flash tool
/home/adv/Downloads/Linux_for_Tegra/tools/kernel_flash/tmp 127.0.0.1(rw,nohide,insecure,no_subtree_check,async,no_root_squash)
rpcbind: another rpcbind is already running. Aborting
Export list for localhost:
/home/adv/Downloads/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh --no-flash --external-device nvme0n1p1 -p -c ./bootloader/generic/cfg/flash_t234_qspi.xml -c ./tools/kernel_flash/flash_l4t_t234_nvme.xml --showlogs --network usb0 jetson-orin-nano-devkit-super external
  • Step 1: Generate flash packages *
Create folder to store images to flash
Generate image for internal storage devices
Generate images to be flashed
ADDITIONAL_DTB_OVERLAY=“” /home/adv/Downloads/Linux_for_Tegra/flash.sh --no-flash --sign -c ./bootloader/generic/cfg/flash_t234_qspi.xml jetson-orin-nano-devkit-super external
L4T BSP Information:
R36 , REVISION: 4.3
User release: 0.0
ECID is 0x80012344705DE80B140000000D008180
copying device_config(/home/adv/Downloads/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-device-p3767-0000.dts)… done.
copying misc_config(/home/adv/Downloads/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-misc-p3767-0000.dts)… done.
copying emc_fuse_dev_params(/home/adv/Downloads/Linux_for_Tegra/bootloader/generic/BCT/tegra234-br-bct-diag-boot.dts)… done.
copying minratchet_config(/home/adv/Downloads/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-ratchet-p3767-0000.dts)… done.
Existing emcfuse(/home/adv/Downloads/Linux_for_Tegra/bootloader/fuse_t234.xml) reused.
./tegraflash.py --chip “0x23” --applet “/home/adv/Downloads/Linux_for_Tegra/bootloader/mb1_t234_prod.bin” --skipuid --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3767-0000.dts --misc_config tegra234-mb1-bct-misc-p3767-0000.dts --bins “mb2_applet applet_t234.bin” --minratchet_config tegra234-mb1-bct-ratchet-p3767-0000.dts --cmd “readfuses fuse_t234.bin fuse_t234.xml; dump eeprom cvm cvm.bin; dump try_custinfo custinfo_out.bin; reboot recovery”
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0716 ] Reading fuses
[ 0.0731 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.0744 ] File rcm_state open failed
[ 0.0750 ] ERROR: failed to read rcm_state
[ 0.0750 ]
[ 0.0778 ] tegrasign_v3.py --key None --getmode mode.txt
[ 0.0782 ] Assuming zero filled SBK key
[ 0.0760 ] Pre-processing config: tegra234-mb1-bct-device-p3767-0000.dts
[ 0.0960 ] Pre-processing config: tegra234-mb1-bct-misc-p3767-0000.dts
[ 0.1281 ] Pre-processing config: tegra234-mb1-bct-ratchet-p3767-0000.dts
[ 0.1470 ] Parsing partition layout
[ 0.1484 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.1520 ] Kernel DTB used: None
[ 0.1520 ] WARNING: dce base dtb is not provided
[ 0.1520 ] Parsing partition layout
[ 0.1535 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.1557 ] Creating list of images to be signed
[ 0.1572 ] Generating ratchet blob
[ 0.1573 ] Generating coldboot mb1-bct
[ 0.1586 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[ 0.1601 ] MB1-BCT version: 0.13
[ 0.1634 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.1642 ] Added Platform Config 9 data with size :- 100
[ 0.1642 ]
[ 0.1642 ] Parsing config file :tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb
[ 0.1642 ]
[ 0.1643 ] Updating mb1-bct with firmware information
[ 0.1657 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.1701 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[ 0.1717 ] Generating SHA2 Hash for mb1bct
[ 0.1776 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[ 0.1809 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[ 0.1800 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[ 0.1813 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[ 0.1865 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.1869 ] Assuming zero filled SBK key
[ 0.1917 ] Warning: pub_key.key is not found
[ 0.1909 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.1949 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --ratchet_blob ratchet_blob.bin --list images_list.xml zerosbk
[ 0.1963 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.1993 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.2005 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.2178 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.2196 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.2358 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.2364 ] adding BCH for mb2_t234_aligned.bin
[ 0.2464 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.2895 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.2902 ] adding BCH for mb2_t234_aligned.bin
[ 0.3421 ] Filling MB1 storage info
[ 0.3422 ] Parsing dev params for multi chains
[ 0.3617 ] Generating br-bct
[ 0.3631 ] Updating dev and MSS params in BR BCT
[ 0.3632 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 0.3650 ] Updating bl info
[ 0.3665 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin
[ 0.3679 ] WARNING: boot chain is not completed. set to 0
[ 0.3703 ] Generating signatures
[ 0.3731 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.3734 ] Assuming zero filled SBK key
[ 0.4068 ] Warning: pub_key.key is not found
[ 0.4046 ] Parsing dev params for multi chains
[ 0.4046 ] Generating br-bct
[ 0.4061 ] Updating dev and MSS params in BR BCT
[ 0.4062 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 0.4085 ] Updating bl info
[ 0.4100 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.4113 ] WARNING: boot chain is not completed. set to 0
[ 0.4141 ] Generating SHA2 Hash
[ 0.4198 ] Sha saved in br_bct_BR.sha
[ 0.4174 ] Get Signed section of bct
[ 0.4187 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[ 0.4211 ] Signing BCT
[ 0.4238 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.4242 ] Assuming zero filled SBK key
[ 0.4317 ] Sha saved in br_bct_BR.sha
[ 0.4328 ] Warning: pub_key.key is not found
[ 0.4302 ] Updating BCT with signature
[ 0.4322 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[ 0.4334 ] Offset :4608 Len :3584
[ 0.4351 ] Generating SHA2 Hash
[ 0.4378 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[ 0.4384 ] Assuming zero filled SBK key
[ 0.4385 ] Assuming zero filled SBK key
[ 0.4459 ] Sha saved in br_bct_BR.sha
[ 0.4440 ] Updating BCT with SHA2 Hash
[ 0.4456 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[ 0.4469 ] Offset :4608 Len :3584
[ 0.4478 ] Offset :68 Len :8124
[ 0.4485 ] Generating coldboot mb1-bct
[ 0.4500 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[ 0.4512 ] MB1-BCT version: 0.13
[ 0.4554 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.4554 ] Added Platform Config 9 data with size :- 100
[ 0.4554 ]
[ 0.4554 ] Parsing config file :tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb
[ 0.4554 ]
[ 0.4555 ] Updating mb1-bct with firmware information
[ 0.4572 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.4620 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[ 0.4641 ] Generating SHA2 Hash for mb1bct
[ 0.4706 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[ 0.4740 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[ 0.4731 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[ 0.4744 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[ 0.4798 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.4802 ] Assuming zero filled SBK key
[ 0.4849 ] Warning: pub_key.key is not found
[ 0.4840 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.4873 ] Generating recovery mb1-bct
[ 0.4892 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[ 0.4907 ] MB1-BCT version: 0.13
[ 0.4950 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.4959 ] Added Platform Config 9 data with size :- 100
[ 0.4959 ]
[ 0.4959 ] Parsing config file :tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb
[ 0.4959 ]
[ 0.4960 ] Updating mb1-bct with firmware information
[ 0.4988 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.5035 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[ 0.5054 ] Generating SHA2 Hash for mb1bct
[ 0.5121 ] Sha saved in mb1_bct_MB1_aligned.sha
[ 0.5153 ] Sha saved in mb1_bct_MB1.sha
[ 0.5144 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[ 0.5157 ] adding BCH for mb1_bct_MB1_aligned.bct
[ 0.5209 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.5213 ] Assuming zero filled SBK key
[ 0.5256 ] Warning: pub_key.key is not found
[ 0.5244 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.5281 ] Info: Skip generating mem_bct because sdram_config is not defined
[ 0.5281 ] Copying signatures
[ 0.5296 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.5464 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 0.5468 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 0.5468 ] Boot Rom communication
[ 0.5483 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 0.5496 ] BR_CID: 0x80012344705DE80B140000000D008180
[ 0.5513 ] Sending bct_br
[ 0.5517 ] ERROR: might be timeout in USB write.
Error: Return value 3
Command tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 10.7746 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 10.7783 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 10.7821 ] Retrieving board information
[ 10.7836 ] tegrarcm_v2 --chip 0x23 0 --oem platformdetails chip chip_info.bin
[ 10.7856 ] Retrieving EEPROM data
[ 10.7858 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/adv/Downloads/Linux_for_Tegra/bootloader/cvm.bin --chip 0x23 0
[ 10.7893 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 10.7929 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 10.7948 ] Dumping customer Info
[ 10.7964 ] tegrarcm_v2 --chip 0x23 0 --oem dump bct tmp.bct
[ 10.8003 ] tegrabct_v2 --brbct tmp.bct --chip 0x23 0 --custinfo /home/adv/Downloads/Linux_for_Tegra/bootloader/custinfo_out.bin
[ 10.8017 ] File tmp.bct open failed
[ 10.8023 ] Error: try getting custinfo fail. Moving on
[ 10.8024 ] Rebooting to recovery mode
[ 10.8040 ] tegrarcm_v2 --chip 0x23 0 --ismb2
[ 10.8061 ] Rebooting to recovery mode
[ 10.8084 ] tegrarcm_v2 --chip 0x23 0 --reboot recovery
Parsing board information failed.
Error: failed to generate images
Cleaning up…
the last parameter should be internal or external on Orin NX?
I tried both failed.
or any other way I can enable SUPER mode with current L4T 36.4.3 ?
is the failure caused by 5V VDD_IN ?
Just to clarify this first. Is your host PC able to flash the same board if you run the command manually but with non-super config file?
Basically this flash is just same thing with different board config. For normal one, use the one that has no “-super” in the config name.
