Cannot flash Orin dev kit with SDK Manager 1.8.0.10363
trying to flash my Orin dev kit from SDK manager.
using the manual method, ie set device to recovery mode whilst powering up. device shows up fine in SDK manager, flashing begins. then at 2% it fails every time, i tried a different cable, all the usb sockets on my laptop (x86 Ubuntu 20.04.2 LTS). Tried restarting a few times. I have the usb cable connected to the usb c socket next to the 2 rows of IO Pins, and power connected to the usbc c above the DC jack socket.
here is the terminal output from SDK Manager.
Any ideas whats going on here?
08:04:57 INFO: Flash Jetson AGX Orin - flash: [ 1.2214 ] Sending mb1
08:04:57 INFO: Flash Jetson AGX Orin - flash: [ 1.2218 ] Sending psc_bl1
08:04:57 INFO: Flash Jetson AGX Orin - flash: [ 1.2307 ] Sending bct_mb1
08:04:57 INFO: Flash Jetson AGX Orin - flash: [ 1.2394 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --appendsigheader applet_t234_aligned.bin zerosbk
08:04:57 INFO: Flash Jetson AGX Orin - flash: [ 1.2400 ] adding BCH for applet_t234_aligned.bin
08:04:57 INFO: Flash Jetson AGX Orin - flash: [ 1.2537 ] Assuming zero filled SBK key
08:04:57 INFO: Flash Jetson AGX Orin - flash: [ 1.2505 ] tegrahost_v2 --chip 0x23 0 --updatesigheader applet_t234_aligned_sigheader.bin.encrypt applet_t234_aligned_sigheader.bin.hash zerosbk
08:04:58 INFO: Flash Jetson AGX Orin - flash: [ 1.2530 ] tegrarcm_v2 --chip 0x23 --pollbl --download applet applet_t234_sigheader.bin.encrypt
08:04:58 INFO: Flash Jetson AGX Orin - flash: [ 1.2541 ] BL: version 0.11.0.0-t234-54845784-7fb1fa27 last_boot_error: 0
08:04:58 INFO: Flash Jetson AGX Orin - flash: [ 1.9856 ] Sending applet
08:04:59 INFO: Flash Jetson AGX Orin - flash: [ 2.5489 ] tegrarcm_v2 --chip 0x23 --ismb2applet
08:04:59 INFO: Flash Jetson AGX Orin - flash: [ 3.2846 ] tegrarcm_v2 --chip 0x23 --ismb2applet
08:05:00 INFO: Flash Jetson AGX Orin - flash: [ 3.8185 ] MB2 Applet version 01.00.0000
08:05:00 INFO: Flash Jetson AGX Orin - flash: [ 4.3499 ] Chip Sample: prod
08:05:01 INFO: Flash Jetson AGX Orin - flash: [ 4.3505 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/cvm.bin --chip 0x23
08:05:01 INFO: Flash Jetson AGX Orin - flash: [ 4.3515 ] MB2 Applet version 01.00.0000
08:05:01 INFO: Flash Jetson AGX Orin - flash: [ 5.0871 ] Saved platform info in /home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/cvm.bin
08:05:01 INFO: Flash Jetson AGX Orin - flash: [ 5.1203 ] tegrarcm_v2 --chip 0x23 --ismb2applet
08:05:02 INFO: Flash Jetson AGX Orin - flash: [ 5.6530 ] tegrarcm_v2 --chip 0x23 --ismb2applet
08:05:03 INFO: Flash Jetson AGX Orin - flash: [ 6.3924 ] tegrarcm_v2 --chip 0x23 --oem dump bct tmp.bct
08:05:03 INFO: Flash Jetson AGX Orin - flash: [ 6.3930 ] MB2 Applet version 01.00.0000
08:05:03 INFO: Flash Jetson AGX Orin - flash: [ 7.1278 ] Saved bct in tmp.bct
08:05:03 INFO: Flash Jetson AGX Orin - flash: [ 7.1366 ] tegrabct_v2 --brbct tmp.bct --chip 0x23 0 --custinfo /home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/custinfo_out.bin
08:05:03 INFO: Flash Jetson AGX Orin - flash: [ 7.1384 ] tegrarcm_v2 --chip 0x23 --ismb2
08:05:04 INFO: Flash Jetson AGX Orin - flash: [ 7.6648 ] tegrarcm_v2 --chip 0x23 --ismb2applet
08:05:05 INFO: Flash Jetson AGX Orin - flash: [ 8.4011 ] tegrarcm_v2 --chip 0x23 --reboot recovery
08:05:05 INFO: Flash Jetson AGX Orin - flash: [ 8.4018 ] MB2 Applet version 01.00.0000
08:05:07 INFO: Flash Jetson AGX Orin - flash: [ 9.1434 ]
08:05:07 INFO: Flash Jetson AGX Orin - flash: Board ID(3701) version(500) sku(0000) revision(H.0)
08:05:07 INFO: Flash Jetson AGX Orin - flash: Copy /home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/kernel/dtb/tegra234-p3701-0000-p3737-0000.dtb to /home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/kernel/dtb/tegra234-p3701-0000-p3737-0000.dtb.rec
08:05:07 INFO: Flash Jetson AGX Orin - flash: copying bctfile(/home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-p3701-0000-p3737-0000-TE990M-sdram.dts)… done.
08:05:07 INFO: Flash Jetson AGX Orin - flash: copying misc_config(/home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-misc-p3701-0000.dts)… done.
08:05:07 INFO: Flash Jetson AGX Orin - flash: copying gpioint_config(/home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-gpioint-p3701-0000.dts)… done.
08:05:07 INFO: Flash Jetson AGX Orin - flash: copying pmc_config(/home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-padvoltage-p3701-0000.dtsi)… done.
08:05:07 INFO: Flash Jetson AGX Orin - flash: copying wb0sdram(/home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-p3701-0000-p3737-0000-TE990M-wb0sdram.dts)… done.
08:05:07 INFO: Flash Jetson AGX Orin - flash: copying dev_params(/home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-br-bct-p3701-0000.dts)… done.
08:05:07 INFO: Flash Jetson AGX Orin - flash: copying mb2bct_cfg(/home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb2-bct-misc-p3701-0000.dts)… done.
08:05:07 INFO: Flash Jetson AGX Orin - flash: Existing pscfwfile(/home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/pscfw_t234_prod.bin) reused.
08:05:07 INFO: Flash Jetson AGX Orin - flash: Existing pscbl1file(/home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/psc_bl1_t234_prod.bin) reused.
08:05:07 INFO: Flash Jetson AGX Orin - flash: Existing mtsmcefile(/home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/mce_flash_o10_cr_prod.bin) reused.
08:05:07 INFO: Flash Jetson AGX Orin - flash: Existing mb2applet(/home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/applet_t234.bin) reused.
08:05:07 INFO: Flash Jetson AGX Orin - flash: Existing bootloader(/home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
08:05:07 INFO: Flash Jetson AGX Orin - flash: copying initrd(/home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/l4t_initrd.img)… done.
08:05:07 INFO: Flash Jetson AGX Orin - flash: Making Boot image… done.
08:05:07 INFO: Flash Jetson AGX Orin - flash: Re-generating recovery ramdisk for recovery image…
08:05:07 INFO: Flash Jetson AGX Orin - flash: /home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/ramdisk_tmp /home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader /home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra
08:05:07 ERROR: Flash Jetson AGX Orin - flash: 36137 blocks
08:05:07 ERROR: Flash Jetson AGX Orin - flash: /home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/tools/ota_tools/version_upgrade/ota_make_recovery_img_dtb.sh: line 177: strings: command not found
08:05:07 ERROR: Flash Jetson AGX Orin - flash: command terminated with error
08:05:07 SUMMARY: DateTime Target Setup - target: Depends on failed component
full logs from sdk manager for reference
SDKM_logs_JetPack_5.0_DP_Linux_for_Jetson_AGX_Orin_modules_2022-05-13_08-04-32.zip (37.4 KB)
Please uninstall JetPack-5.0 via SDKM and delete /home/nvidia/fs/Linux_for_Tegra folder on host machine first, then run SDK Manager to download again.
Tried this. Same problem again…
Hi SideWheelie,
Please try flash by manually:
Put device into recovery mode
Flash:
$ cd /home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra
$ sudo ./flash.sh jetson-agx-orin-devkit mmcblk0p1
ok , tried the flash from the command line - similar problem - here is the output:
L4T BSP Information:
R34 , REVISION: 1.0
Target Board Information:
Name: jetson-agx-orin-devkit, Board Family: t186ref, SoC: Tegra 234,
OpMode: production, Boot Authentication: NS,
Disk encryption: disabled ,
copying emc_fuse_dev_params(/home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-br-bct-diag-boot.dts)… done.
copying device_config(/home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-device-p3701-0000.dts)… done.
./tegraflash.py --chip 0x23 --applet “/home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/mb1_t234_prod.bin” --skipuid --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3701-0000.dts --misc_config tegra234-mb1-bct-misc-p3701-0000.dts --bins “mb2_applet applet_t234.bin” --cmd “dump eeprom cvm cvm.bin; dump custinfo custinfo_out.bin; reboot recovery”
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0057 ] tegrarcm_v2 --chip 0x23 --ismb2applet
[ 0.0063 ] File rcm_state open failed
[ 0.0063 ] ERROR: failed to read rcm_state
[ 0.0063 ]
[ 0.0069 ] tegrasign_v3.py --key None --getmode mode.txt
[ 0.0070 ] Assuming zero filled SBK key
[ 0.0066 ] Pre-processing config: tegra234-mb1-bct-device-p3701-0000.dts
[ 0.0102 ] Pre-processing config: tegra234-br-bct-diag-boot.dts
[ 0.0136 ] Pre-processing config: tegra234-mb1-bct-misc-p3701-0000.dts
[ 0.0188 ] Parsing partition layout
[ 0.0193 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0202 ]
[ 0.0206 ] Parsing partition layout
[ 0.0212 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0218 ]
[ 0.0219 ] Creating list of images to be signed
[ 0.0224 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --list images_list.xml zerosbk
[ 0.0231 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.0235 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.0238 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.0270 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.0273 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.0304 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.0307 ] adding BCH for mb2_t234_aligned.bin
[ 0.0327 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.0430 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.0432 ] adding BCH for mb2_t234_aligned.bin
[ 0.0554 ]
[ 0.0554 ] Generating signatures
[ 0.0560 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.0561 ] Assuming zero filled SBK key
[ 0.0633 ] Warning: pub_key.key is not found
[ 0.0628 ] Generating br-bct
[ 0.0633 ] Updating dev and MSS params in BR BCT
[ 0.0634 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 0.0642 ]
[ 0.0642 ] Updating bl info
[ 0.0649 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.0654 ] WARNING: boot chain is not completed. set to 0
[ 0.0660 ]
[ 0.0661 ] Get Signed section of bct
[ 0.0666 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[ 0.0674 ]
[ 0.0674 ] Signing BCT
[ 0.0680 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.0682 ] Assuming zero filled SBK key
[ 0.0698 ] Sha saved in br_bct_BR.sha
[ 0.0701 ] Warning: pub_key.key is not found
[ 0.0695 ] Updating BCT with signature
[ 0.0701 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[ 0.0707 ]
[ 0.0707 ] Generating SHA2 Hash
[ 0.0713 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[ 0.0714 ] Assuming zero filled SBK key
[ 0.0732 ] Sha saved in br_bct_BR.sha
[ 0.0729 ] Updating BCT with SHA2 Hash
[ 0.0734 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 --updatesha bct_list_signed.xml
[ 0.0739 ] Offset :68 Len :8124
[ 0.0740 ]
[ 0.0741 ] Generating coldboot mb1-bct
[ 0.0746 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.0752 ] MB1-BCT version: 0.7
[ 0.0754 ] ERROR: /misc/axi_ap_virtual_client is not supported
[ 0.0761 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.0763 ] Added Platform Config 9 data with size :- 80
[ 0.0763 ]
[ 0.0763 ] Updating mb1-bct with firmware information
[ 0.0768 ] tegrabct_v2 --chip 0x23 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.0774 ]
[ 0.0780 ] tegrahost_v2 --chip 0x23 --align mb1_cold_boot_bct_MB1_aligned.bct
[ 0.0785 ]
[ 0.0790 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[ 0.0794 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[ 0.0799 ]
[ 0.0806 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --sha sha512
[ 0.0807 ] Assuming zero filled SBK key
[ 0.0816 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.0823 ]
[ 0.0824 ] Generating recovery mb1-bct
[ 0.0828 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.0833 ] MB1-BCT version: 0.7
[ 0.0834 ] ERROR: /misc/axi_ap_virtual_client is not supported
[ 0.0841 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.0842 ] Added Platform Config 9 data with size :- 80
[ 0.0842 ]
[ 0.0842 ] Updating mb1-bct with firmware information
[ 0.0847 ] tegrabct_v2 --chip 0x23 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.0853 ]
[ 0.0859 ] tegrahost_v2 --chip 0x23 --align mb1_bct_MB1_aligned.bct
[ 0.0864 ]
[ 0.0869 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[ 0.0873 ] adding BCH for mb1_bct_MB1_aligned.bct
[ 0.0878 ]
[ 0.0885 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --sha sha512
[ 0.0886 ] Assuming zero filled SBK key
[ 0.0896 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.0903 ]
[ 0.0904 ] Error: Skip generating mem_bct because sdram_config is not defined
[ 0.0904 ] Copying signatures
[ 0.0908 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.0940 ]
[ 0.0944 ] Boot Rom communication
[ 0.0949 ] tegrarcm_v2 --new_session --chip 0x23 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 0.0953 ] BR_CID: 0x80012344705DD10F2000000005030100
[ 0.8258 ] Sending bct_br
[ 1.5585 ] Sending mb1
[ 1.5594 ] Sending psc_bl1
[ 1.5704 ] Sending bct_mb1
[ 1.5757 ]
[ 1.5758 ] Boot Rom communication completed
[ 1.5797 ] tegrahost_v2 --chip 0x23 --align applet_t234_aligned.bin
[ 1.5824 ]
[ 1.5852 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --appendsigheader applet_t234_aligned.bin zerosbk
[ 1.5879 ] adding BCH for applet_t234_aligned.bin
[ 1.5983 ]
[ 1.5991 ] tegrasign_v3.py --key None --list applet_t234_aligned_sigheader.bin_list.xml --sha sha512
[ 1.5992 ] Assuming zero filled SBK key
[ 1.6006 ] tegrahost_v2 --chip 0x23 0 --updatesigheader applet_t234_aligned_sigheader.bin.encrypt applet_t234_aligned_sigheader.bin.hash zerosbk
[ 1.6016 ]
[ 1.6019 ] Sending mb2_applet…
[ 1.6025 ] tegrarcm_v2 --chip 0x23 --pollbl --download applet applet_t234_sigheader.bin.encrypt
[ 1.6030 ] BL: version 0.11.0.0-t234-54845784-7fb1fa27 last_boot_error: 0
[ 2.3350 ] Sending applet
[ 3.1022 ]
[ 3.1023 ] completed
[ 3.1057 ] tegrarcm_v2 --chip 0x23 --ismb2applet
[ 3.1086 ] MB2 Applet version 01.00.0000
[ 3.6380 ]
[ 3.6387 ] tegrarcm_v2 --chip 0x23 --ismb2applet
[ 3.6393 ] MB2 Applet version 01.00.0000
[ 4.1641 ]
[ 4.1671 ] Retrieving board information
[ 4.1697 ] tegrarcm_v2 --chip 0x23 --oem platformdetails chip chip_info.bin
[ 4.1724 ] MB2 Applet version 01.00.0000
[ 4.9084 ] Saved platform info in chip_info.bin
[ 4.9149 ] Chip minor revision: 1
[ 4.9150 ] Bootrom revision: 0x7
[ 4.9151 ] Ram code: 0x0
[ 4.9151 ] Chip sku: 0xd0
[ 4.9152 ] Chip Sample: prod
[ 4.9154 ]
[ 4.9156 ] Retrieving EEPROM data
[ 4.9156 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/cvm.bin --chip 0x23
[ 4.9163 ] MB2 Applet version 01.00.0000
[ 5.6595 ] Saved platform info in /home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/cvm.bin
[ 5.6915 ]
[ 5.6923 ] tegrarcm_v2 --chip 0x23 --ismb2applet
[ 5.6929 ] MB2 Applet version 01.00.0000
[ 6.4328 ]
[ 6.4336 ] tegrarcm_v2 --chip 0x23 --ismb2applet
[ 6.4341 ] MB2 Applet version 01.00.0000
[ 6.9605 ]
[ 6.9606 ] Dumping customer Info
[ 6.9632 ] tegrarcm_v2 --chip 0x23 --oem dump bct tmp.bct
[ 6.9656 ] MB2 Applet version 01.00.0000
[ 7.7005 ] Saved bct in tmp.bct
[ 7.7079 ]
[ 7.7086 ] tegrabct_v2 --brbct tmp.bct --chip 0x23 0 --custinfo /home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/custinfo_out.bin
[ 7.7091 ] Customer data saved in /home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/custinfo_out.bin successfully
[ 7.7093 ] Rebooting to recovery mode
[ 7.7099 ] tegrarcm_v2 --chip 0x23 --ismb2
[ 8.2368 ]
[ 8.2376 ] tegrarcm_v2 --chip 0x23 --ismb2applet
[ 8.2381 ] MB2 Applet version 01.00.0000
[ 8.9807 ]
[ 8.9808 ] Booting to recovery mode
[ 8.9837 ] tegrarcm_v2 --chip 0x23 --reboot recovery
[ 8.9861 ] MB2 Applet version 01.00.0000
[ 9.7245 ]
copying pinmux_config(/home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-pinmux-p3701-0000.dtsi)… done.
copying pmic_config(/home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-pmic-p3701-0000.dts)… done.
copying deviceprod_config(/home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-cprod-p3701-0000.dts)… done.
copying prod_config(/home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-prod-p3701-0000.dts)… done.
copying bootrom_config(/home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-reset-p3701-0000.dts)… done.
Making recovery ramdisk for recovery image…
36137 blocks
gzip: /home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/kernel/Image: not in gzip format
ERROR: failed to get kernel version from /home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/kernel/Image
SDK Manager Version that i downloaded is - sdkmanager_1.8.0-10363_amd64.deb
Please install binutils on your host.
OK.. Now the flash process executes ok, thanks for the tip Wayne.
only problem is after it completes the devices resets and i just get a black screen. I tried this using SDK Manager and also manually from the command line, tried both a few times and I just get the same result. I tried power cycling the device after completion too. still the same problem.
Here is the output from the manual flash process. incase there is any clues in there?
Thanks for your assistance.
R34 , REVISION: 1.0
version 1.0.0
[ 0.0084 ] tegrarcm_v2 --chip 0x23 --ismb2applet
[ 0.0089 ] File rcm_state open failed
[ 0.0090 ] ERROR: failed to read rcm_state
[ 0.0090 ]
[ 0.0097 ] tegrasign_v3.py --key None --getmode mode.txt
[ 0.0099 ] Assuming zero filled SBK key
[ 0.0094 ] Pre-processing config: tegra234-mb1-bct-device-p3701-0000.dts
[ 0.0132 ] Pre-processing config: tegra234-br-bct-diag-boot.dts
[ 0.0171 ] Pre-processing config: tegra234-mb1-bct-misc-p3701-0000.dts
[ 0.0227 ] Parsing partition layout
[ 0.0233 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0241 ]
[ 0.0245 ] Parsing partition layout
[ 0.0251 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0259 ]
[ 0.0259 ] Creating list of images to be signed
[ 0.0266 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --list images_list.xml zerosbk
[ 0.0271 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.0277 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.0279 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.0311 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.0313 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.0347 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.0349 ] adding BCH for mb2_t234_aligned.bin
[ 0.0370 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.0470 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.0472 ] adding BCH for mb2_t234_aligned.bin
[ 0.0596 ]
[ 0.0596 ] Generating signatures
[ 0.0602 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.0603 ] Assuming zero filled SBK key
[ 0.0680 ] Warning: pub_key.key is not found
[ 0.0675 ] Generating br-bct
[ 0.0682 ] Updating dev and MSS params in BR BCT
[ 0.0682 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 0.0689 ]
[ 0.0689 ] Updating bl info
[ 0.0697 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.0702 ] WARNING: boot chain is not completed. set to 0
[ 0.0707 ]
[ 0.0708 ] Get Signed section of bct
[ 0.0713 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[ 0.0722 ]
[ 0.0722 ] Signing BCT
[ 0.0728 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.0730 ] Assuming zero filled SBK key
[ 0.0751 ] Sha saved in br_bct_BR.sha
[ 0.0753 ] Warning: pub_key.key is not found
[ 0.0748 ] Updating BCT with signature
[ 0.0753 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[ 0.0760 ]
[ 0.0760 ] Generating SHA2 Hash
[ 0.0766 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[ 0.0767 ] Assuming zero filled SBK key
[ 0.0783 ] Sha saved in br_bct_BR.sha
[ 0.0779 ] Updating BCT with SHA2 Hash
[ 0.0784 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 --updatesha bct_list_signed.xml
[ 0.0788 ] Offset :68 Len :8124
[ 0.0790 ]
[ 0.0791 ] Generating coldboot mb1-bct
[ 0.0797 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.0802 ] MB1-BCT version: 0.7
[ 0.0804 ] ERROR: /misc/axi_ap_virtual_client is not supported
[ 0.0811 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.0812 ] Added Platform Config 9 data with size :- 80
[ 0.0812 ]
[ 0.0812 ] Updating mb1-bct with firmware information
[ 0.0818 ] tegrabct_v2 --chip 0x23 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.0824 ]
[ 0.0830 ] tegrahost_v2 --chip 0x23 --align mb1_cold_boot_bct_MB1_aligned.bct
[ 0.0835 ]
[ 0.0840 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[ 0.0845 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[ 0.0849 ]
[ 0.0856 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --sha sha512
[ 0.0857 ] Assuming zero filled SBK key
[ 0.0871 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.0879 ]
[ 0.0881 ] Generating recovery mb1-bct
[ 0.0887 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.0893 ] MB1-BCT version: 0.7
[ 0.0894 ] ERROR: /misc/axi_ap_virtual_client is not supported
[ 0.0901 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.0902 ] Added Platform Config 9 data with size :- 80
[ 0.0902 ]
[ 0.0902 ] Updating mb1-bct with firmware information
[ 0.0907 ] tegrabct_v2 --chip 0x23 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.0914 ]
[ 0.0920 ] tegrahost_v2 --chip 0x23 --align mb1_bct_MB1_aligned.bct
[ 0.0926 ]
[ 0.0932 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[ 0.0937 ] adding BCH for mb1_bct_MB1_aligned.bct
[ 0.0941 ]
[ 0.0948 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --sha sha512
[ 0.0949 ] Assuming zero filled SBK key
[ 0.0961 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.0969 ]
[ 0.0971 ] Error: Skip generating mem_bct because sdram_config is not defined
[ 0.0971 ] Copying signatures
[ 0.0976 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.1008 ]
[ 0.1011 ] Boot Rom communication
[ 0.1017 ] tegrarcm_v2 --new_session --chip 0x23 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 0.1022 ] BR_CID: 0x80012344705DD10F2000000005030100
[ 0.8375 ] Sending bct_br
[ 1.3734 ] Sending mb1
[ 1.3738 ] Sending psc_bl1
[ 1.3834 ] Sending bct_mb1
[ 1.3902 ]
[ 1.3902 ] Boot Rom communication completed
[ 1.3912 ] tegrahost_v2 --chip 0x23 --align applet_t234_aligned.bin
[ 1.3917 ]
[ 1.3925 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --appendsigheader applet_t234_aligned.bin zerosbk
[ 1.3930 ] adding BCH for applet_t234_aligned.bin
[ 1.3998 ]
[ 1.4007 ] tegrasign_v3.py --key None --list applet_t234_aligned_sigheader.bin_list.xml --sha sha512
[ 1.4008 ] Assuming zero filled SBK key
[ 1.4025 ] tegrahost_v2 --chip 0x23 0 --updatesigheader applet_t234_aligned_sigheader.bin.encrypt applet_t234_aligned_sigheader.bin.hash zerosbk
[ 1.4036 ]
[ 1.4039 ] Sending mb2_applet…
[ 1.4045 ] tegrarcm_v2 --chip 0x23 --pollbl --download applet applet_t234_sigheader.bin.encrypt
[ 1.4051 ] BL: version 0.11.0.0-t234-54845784-7fb1fa27 last_boot_error: 0
[ 1.9341 ] Sending applet
[ 2.7016 ]
[ 2.7016 ] completed
[ 2.7027 ] tegrarcm_v2 --chip 0x23 --ismb2applet
[ 2.7035 ] MB2 Applet version 01.00.0000
[ 3.2317 ]
[ 3.2326 ] tegrarcm_v2 --chip 0x23 --ismb2applet
[ 3.2333 ] MB2 Applet version 01.00.0000
[ 3.9798 ]
[ 3.9807 ] Retrieving board information
[ 3.9813 ] tegrarcm_v2 --chip 0x23 --oem platformdetails chip chip_info.bin
[ 3.9819 ] MB2 Applet version 01.00.0000
[ 4.5075 ] Saved platform info in chip_info.bin
[ 4.5130 ] Chip minor revision: 1
[ 4.5131 ] Bootrom revision: 0x7
[ 4.5132 ] Ram code: 0x0
[ 4.5132 ] Chip sku: 0xd0
[ 4.5133 ] Chip Sample: prod
[ 4.5137 ]
[ 4.5138 ] Retrieving EEPROM data
[ 4.5139 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/cvm.bin --chip 0x23
[ 4.5146 ] MB2 Applet version 01.00.0000
[ 5.2524 ] Saved platform info in /home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/cvm.bin
[ 5.2845 ]
[ 5.2853 ] tegrarcm_v2 --chip 0x23 --ismb2applet
[ 5.2862 ] MB2 Applet version 01.00.0000
[ 5.8277 ]
[ 5.8286 ] tegrarcm_v2 --chip 0x23 --ismb2applet
[ 5.8292 ] MB2 Applet version 01.00.0000
[ 6.3677 ]
[ 6.3677 ] Dumping customer Info
[ 6.3685 ] tegrarcm_v2 --chip 0x23 --oem dump bct tmp.bct
[ 6.3695 ] MB2 Applet version 01.00.0000
[ 7.1036 ] Saved bct in tmp.bct
[ 7.1108 ]
[ 7.1116 ] tegrabct_v2 --brbct tmp.bct --chip 0x23 0 --custinfo /home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/custinfo_out.bin
[ 7.1122 ] Customer data saved in /home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/custinfo_out.bin successfully
[ 7.1124 ] Rebooting to recovery mode
[ 7.1130 ] tegrarcm_v2 --chip 0x23 --ismb2
[ 7.6437 ]
[ 7.6446 ] tegrarcm_v2 --chip 0x23 --ismb2applet
[ 7.6453 ] MB2 Applet version 01.00.0000
[ 8.1748 ]
[ 8.1748 ] Booting to recovery mode
[ 8.1757 ] tegrarcm_v2 --chip 0x23 --reboot recovery
[ 8.1763 ] MB2 Applet version 01.00.0000
[ 8.7113 ]
36137 blocks
_BASE_KERNEL_VERSION=5.10.65-tegra
52382 blocks
Making Recovery image…
copying recdtbfile(/home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/kernel/dtb/tegra234-p3701-0000-p3737-0000.dtb.rec)… done.
20+0 records in
20+0 records out
20 bytes copied, 7.9104e-05 s, 253 kB/s
Existing sosfile(/home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
Existing tegraboot(/home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing cpu_bootloader(/home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing mb2blfile(/home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing xusbfile(/home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/xusb_t234_prod.bin) reused.
Existing dcefile(/home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/dce.bin) reused.
Existing nvdecfile(/home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/nvdec_t234_prod.fw) reused.
Existing psc_rf(/home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/psc_rf_t234_prod.bin) reused.
Existing mb2_rf(/home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/nvtboot_cpurf_t234.bin) reused.
Existing mb1file(/home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
Existing bpffile(/home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/bpmp_t234-TE990M-A1_prod.bin) reused.
copying bpfdtbfile(/home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/t186ref/tegra234-bpmp-3701-0000-3737-0000.dtb)… done.
Existing scefile(/home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
Existing camerafw(/home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/camera-rtcpu-t234-rce.img) reused.
Existing apefile(/home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/adsp-fw.bin) reused.
Existing spefile(/home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/spe_t234.bin) reused.
Existing wb0boot(/home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/sc7_t234_prod.bin) reused.
Existing tosfile(/home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/tos-mon-only_t234.img) reused.
Existing eksfile(/home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/kernel/dtb/tegra234-p3701-0000-p3737-0000.dtb)… done.
Copying nv_boot_control.conf to rootfs
populating kernel to rootfs… done.
populating initrd to rootfs… done.
populating kernel_tegra234-p3701-0000-p3737-0000.dtb to rootfs… done.
Making system.img…
Setting “FDT /boot/dtb/kernel_tegra234-p3701-0000-p3737-0000.dtb” successfully in the extlinux.conf…done.
populating rootfs from /home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/rootfs … populating /boot/extlinux/extlinux.conf … done.
Sync’ing system.img … done.
Converting RAW image to Sparse image… done.
system.img built successfully.
Existing tbcfile(/home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/uefi_jetson.bin) reused.
131072+0 records in
131072+0 records out
67108864 bytes (67 MB, 64 MiB) copied, 0.153768 s, 436 MB/s
Sync’ing esp.img … done.
copying tbcdtbfile(/home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/kernel/dtb/tegra234-p3701-0000-p3737-0000.dtb)… done.
copying cfgfile(/home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/t186ref/cfg/flash_t234_qspi_sdmmc.xml) to flash.xml… done.
Existing flashapp(/home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py) reused.
Existing overlay_dtb(/home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/tegra234-p3737-overlay-pcie.dtbo) reused.
Existing overlay_dtb(/home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/tegra234-p3737-audio-codec-rt5658-40pin.dtbo) reused.
Existing overlay_dtb(/home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/tegra234-p3737-a04-overlay.dtbo) reused.
Existing overlay_dtb(/home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/tegra234-p3737-camera-dual-imx274-overlay.dtbo) reused.
Existing overlay_dtb(/home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/tegra234-p3737-camera-e3331-overlay.dtbo) reused.
Existing overlay_dtb(/home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/tegra234-p3737-camera-e3333-overlay.dtbo) reused.
Existing overlay_dtb(/home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/tegra234-p3737-camera-imx185-overlay.dtbo) reused.
Existing overlay_dtb(/home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/tegra234-p3737-camera-imx390-overlay.dtbo) reused.
./tegraflash.py --bl uefi_jetson_with_dtb.bin --odmdata gbe-uphy-config-22,hsstp-lane-map-3,nvhs-uphy-config-0,hsio-uphy-config-0,gbe0-enable-10g --overlay_dtb tegra234-p3737-overlay-pcie.dtbo,tegra234-p3737-audio-codec-rt5658-40pin.dtbo,tegra234-p3737-a04-overlay.dtbo,tegra234-p3737-camera-dual-imx274-overlay.dtbo,tegra234-p3737-camera-e3331-overlay.dtbo,tegra234-p3737-camera-e3333-overlay.dtbo,tegra234-p3737-camera-imx185-overlay.dtbo,tegra234-p3737-camera-imx390-overlay.dtbo --bldtb tegra234-p3701-0000-p3737-0000.dtb --applet mb1_t234_prod.bin --cmd “flash; reboot” --cfg flash.xml --chip 0x23 --concat_cpubl_bldtb --cpubl uefi_jetson.bin --device_config tegra234-mb1-bct-device-p3701-0000.dts --misc_config tegra234-mb1-bct-misc-p3701-0000.dts --pinmux_config tegra234-mb1-bct-pinmux-p3701-0000.dtsi --gpioint_config tegra234-mb1-bct-gpioint-p3701-0000.dts --pmic_config tegra234-mb1-bct-pmic-p3701-0000.dts --pmc_config tegra234-mb1-bct-padvoltage-p3701-0000.dtsi --deviceprod_config tegra234-mb1-bct-cprod-p3701-0000.dts --prod_config tegra234-mb1-bct-prod-p3701-0000.dts --wb0sdram_config tegra234-p3701-0000-p3737-0000-TE990M-wb0sdram.dts --br_cmd_config tegra234-mb1-bct-reset-p3701-0000.dts --dev_params tegra234-br-bct-p3701-0000.dts --mb2bct_cfg tegra234-mb2-bct-misc-p3701-0000.dts --bins “psc_fw pscfw_t234_prod.bin; mts_mce mce_flash_o10_cr_prod.bin; mb2_applet applet_t234.bin; mb2_bootloader mb2_t234.bin; xusb_fw xusb_t234_prod.bin; dce_fw dce.bin; nvdec nvdec_t234_prod.fw; bpmp_fw bpmp_t234-TE990M-A1_prod.bin; bpmp_fw_dtb tegra234-bpmp-3701-0000-3737-0000.dtb; sce_fw camera-rtcpu-sce.img; rce_fw camera-rtcpu-t234-rce.img; ape_fw adsp-fw.bin; spe_fw spe_t234.bin; tlk tos-mon-only_t234.img; eks eks.img” --sdram_config tegra234-p3701-0000-p3737-0000-TE990M-sdram.dts --cust_info custinfo_out.bin
saving flash command in /home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /home/nvidia/nvidia/nvidia_sdk/JetPack_5.0_DP_Linux_DP_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/bootloader/flash_win.bat
*** Flashing target device started. ***
version 1.0.0
[ 0.0087 ] tegrasign_v3.py --key None --getmode mode.txt
[ 0.0087 ] Assuming zero filled SBK key
[ 0.0083 ] Parsing partition layout
[ 0.0091 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.0104 ]
[ 0.0143 ] Change tegra234-bpmp-3701-0000-3737-0000.dtb to tegra234-bpmp-3701-0000-3737-0000_with_odm.dtb
[ 0.0356 ] /usr/bin/python3 dtbcheck.py -c t234 -o tegra234-bpmp-3701-0000-3737-0000_with_odm.dtb tegra234-bpmp-3701-0000-3737-0000_with_odm_tmp.dtb
[ 0.0695 ]
[ 0.0717 ] Change kernel_tegra234-p3701-0000-p3737-0000.dtb to kernel_tegra234-p3701-0000-p3737-0000_with_odm.dtb
[ 0.0732 ] Change kernel_tegra234-p3701-0000-p3737-0000.dtb to kernel_tegra234-p3701-0000-p3737-0000_with_odm.dtb
[ 0.4808 ] Concatenating tegra234-p3737-overlay-pcie.dtbo,tegra234-p3737-audio-codec-rt5658-40pin.dtbo,tegra234-p3737-a04-overlay.dtbo,tegra234-p3737-camera-dual-imx274-overlay.dtbo,tegra234-p3737-camera-e3331-overlay.dtbo,tegra234-p3737-camera-e3333-overlay.dtbo,tegra234-p3737-camera-imx185-overlay.dtbo,tegra234-p3737-camera-imx390-overlay.dtbo to tegra234-p3701-0000-p3737-0000_with_odm.dtb
[ 0.4811 ] Concatenating bl dtb to cpubl binary
[ 0.4830 ] MB2 binary: mb2_t234.bin
[ 0.4830 ] Pre-processing mb2bct config: tegra234-mb2-bct-misc-p3701-0000.dts
[ 0.4921 ] Generating coldboot mb2-bct
[ 0.4921 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_cold_boot_bct.cfg --mb2bctcfg tegra234-mb2-bct-misc-p3701-0000_cpp.dtb
[ 0.4935 ]
[ 0.4935 ] Updating mb2-bct with storage information
[ 0.4943 ] tegrabct_v2 --chip 0x23 --mb2bct mb2_cold_boot_bct_MB2.bct --updatestorageinfo flash.xml.bin
[ 0.4952 ]
[ 0.4952 ] Concatenating mb2-bct to mb2 binary
[ 0.4952 ] mb2_bin_file = mb2_t234.bin
[ 0.4952 ] mb2_bct_file = mb2_cold_boot_bct_MB2.bct
[ 0.4982 ] DCE binary: dce.bin
[ 0.4982 ] Kernel DTB: kernel_tegra234-p3701-0000-p3737-0000.dtb
[ 0.4982 ] Concatenate dce with kernel dtb
[ 0.4983 ] Concatenating kernel-dtb to dce-fw binary
[ 0.4983 ] dce_bin = dce.bin
[ 0.4983 ] kernel_dtb = kernel_tegra234-p3701-0000-p3737-0000.dtb
[ 0.4983 ] dce_with_dtb = dce_with_kernel_tegra234-p3701-0000-p3737-0000.bin
[ 0.5035 ] Parsing partition layout
[ 0.5043 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.5055 ]
[ 0.5055 ] Creating list of images to be signed
[ 0.5065 ] tegrahost_v2 --chip 0x23 0 --partitionlayout flash.xml.bin --list images_list.xml zerosbk
[ 0.5071 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.5076 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.5079 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.5112 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.5114 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.5143 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.5145 ] Header already present for nvdec_t234_prod_aligned.fw
[ 0.5163 ] adding BCH for mb2_t234_with_mb2_cold_boot_bct_MB2_aligned.bin
[ 0.5198 ] adding BCH for xusb_t234_prod_aligned.bin
[ 0.5313 ] Header already present for bpmp_t234-TE990M-A1_prod_aligned.bin
[ 0.5368 ] adding BCH for tegra234-bpmp-3701-0000-3737-0000_with_odm_aligned.dtb
[ 0.5497 ] Header already present for pscfw_t234_prod_aligned.bin
[ 0.5533 ] Header already present for mce_flash_o10_cr_prod_aligned.bin
[ 0.5585 ] Header already present for sc7_t234_prod.bin
[ 0.5611 ] Header already present for psc_rf_t234_prod_aligned.bin
[ 0.5620 ] adding BCH for nvtboot_cpurf_t234_aligned.bin
[ 0.5639 ] adding BCH for uefi_jetson_with_dtb_aligned.bin
[ 0.5694 ] adding BCH for tos-mon-only_t234_aligned.img
[ 0.6481 ] adding BCH for eks_aligned.img
[ 0.6508 ] adding BCH for dce_with_kernel_tegra234-p3701-0000-p3737-0000_aligned.bin
[ 0.6637 ] adding BCH for spe_t234_aligned.bin
[ 0.8999 ] adding BCH for camera-rtcpu-t234-rce_aligned.img
[ 0.9074 ] adding BCH for adsp-fw_aligned.bin
[ 0.9206 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.9308 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.9310 ] Header already present for nvdec_t234_prod_aligned.fw
[ 0.9340 ] adding BCH for mb2_t234_with_mb2_cold_boot_bct_MB2_aligned.bin
[ 0.9374 ] adding BCH for xusb_t234_prod_aligned.bin
[ 0.9488 ] Header already present for bpmp_t234-TE990M-A1_prod_aligned.bin
[ 0.9540 ] adding BCH for tegra234-bpmp-3701-0000-3737-0000_with_odm_aligned.dtb
[ 0.9672 ] Header already present for pscfw_t234_prod_aligned.bin
[ 0.9710 ] Header already present for mce_flash_o10_cr_prod_aligned.bin
[ 0.9761 ] Header already present for sc7_t234_prod.bin
[ 0.9785 ] Header already present for psc_rf_t234_prod_aligned.bin
[ 0.9794 ] adding BCH for nvtboot_cpurf_t234_aligned.bin
[ 0.9812 ] adding BCH for uefi_jetson_with_dtb_aligned.bin
[ 0.9875 ] adding BCH for tos-mon-only_t234_aligned.img
[ 1.0689 ] adding BCH for eks_aligned.img
[ 1.0719 ] adding BCH for dce_with_kernel_tegra234-p3701-0000-p3737-0000_aligned.bin
[ 1.0862 ] adding BCH for spe_t234_aligned.bin
[ 1.3217 ] adding BCH for camera-rtcpu-t234-rce_aligned.img
[ 1.3289 ] adding BCH for adsp-fw_aligned.bin
[ 1.3425 ] adding BCH for recovery_aligned.img
[ 1.4290 ] adding BCH for tegra234-p3701-0000-p3737-0000.dtb_aligned.rec
[ 2.5863 ]
[ 2.5863 ] Filling MB1 storage info
[ 2.5863 ] Generating br-bct
[ 2.8989 ] Updating dev and MSS params in BR BCT
[ 2.8989 ] tegrabct_v2 --dev_param tegra234-br-bct-p3701-0000_cpp.dtb --sdram tegra234-p3701-0000-p3737-0000-TE990M-sdram_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 2.9118 ]
[ 2.9118 ] Updating bl info
[ 2.9125 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin
[ 2.9135 ]
[ 2.9135 ] Generating signatures
[ 2.9140 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[ 2.9142 ] Assuming zero filled SBK key
[ 3.0618 ] Warning: pub_key.key is not found
[ 3.0614 ] Pre-processing config: tegra234-mb1-bct-reset-p3701-0000.dts
[ 3.0655 ] Pre-processing config: tegra234-mb1-bct-device-p3701-0000.dts
[ 3.0694 ] Pre-processing config: tegra234-mb1-bct-cprod-p3701-0000.dts
[ 3.0734 ] Pre-processing config: tegra234-mb1-bct-gpioint-p3701-0000.dts
[ 3.0777 ] Pre-processing config: tegra234-mb1-bct-misc-p3701-0000.dts
[ 3.0832 ] Pre-processing config: tegra234-mb1-bct-pinmux-p3701-0000.dtsi
[ 3.0918 ] Pre-processing config: tegra234-mb1-bct-padvoltage-p3701-0000.dtsi
[ 3.0956 ] Pre-processing config: tegra234-mb1-bct-pmic-p3701-0000.dts
[ 3.0998 ] Pre-processing config: tegra234-mb1-bct-prod-p3701-0000.dts
[ 3.1038 ] Pre-processing config: tegra234-p3701-0000-p3737-0000-TE990M-wb0sdram.dts
[ 3.4197 ] Generating br-bct
[ 3.4208 ] Updating dev and MSS params in BR BCT
[ 3.4209 ] tegrabct_v2 --dev_param tegra234-br-bct-p3701-0000_cpp.dtb --sdram tegra234-p3701-0000-p3737-0000-TE990M-sdram_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 3.4336 ]
[ 3.4336 ] Updating customer data section
[ 3.4344 ] tegrabct_v2 --chip 0x23 0 --brbct br_bct_BR.bct --update_custinfo custinfo_out.bin
[ 3.4365 ]
[ 3.4366 ] Updating bl info
[ 3.4373 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 3.4388 ]
[ 3.4388 ] Get Signed section of bct
[ 3.4394 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[ 3.4401 ]
[ 3.4402 ] Signing BCT
[ 3.4407 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 3.4408 ] Assuming zero filled SBK key
[ 3.4428 ] Sha saved in br_bct_BR.sha
[ 3.4431 ] Warning: pub_key.key is not found
[ 3.4426 ] Updating BCT with signature
[ 3.4433 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[ 3.4440 ]
[ 3.4440 ] Generating SHA2 Hash
[ 3.4445 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[ 3.4447 ] Assuming zero filled SBK key
[ 3.4467 ] Sha saved in br_bct_BR.sha
[ 3.4464 ] Updating BCT with SHA2 Hash
[ 3.4471 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 --updatesha bct_list_signed.xml
[ 3.4477 ] Offset :68 Len :8124
[ 3.4480 ]
[ 3.4480 ] Generating coldboot mb1-bct
[ 3.4486 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --wb0sdram tegra234-p3701-0000-p3737-0000-TE990M-wb0sdram_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3701-0000_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3701-0000_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3701-0000_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3701-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3701-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3701-0000_cpp.dtb
[ 3.4492 ] MB1-BCT version: 0.7
[ 3.4494 ] ERROR: /misc/axi_ap_virtual_client is not supported
[ 3.4501 ] Parsing config file :tegra234-mb1-bct-pinmux-p3701-0000_cpp.dtb
[ 3.4504 ] WARNING: unknown property ‘linux,phandle’
[ 3.4508 ] WARNING: unknown property ‘linux,phandle’
[ 3.4510 ] WARNING: unknown property ‘linux,phandle’
[ 3.4512 ] WARNING: unknown property ‘linux,phandle’
[ 3.4513 ] WARNING: unknown property ‘linux,phandle’
[ 3.4521 ] WARNING: unknown property ‘linux,phandle’
[ 3.4524 ] Added Platform Config 0 data with size :- 3744
[ 3.4526 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3701-0000_cpp.dtb
[ 3.4527 ] WARNING: unknown node ‘g2’
[ 3.4527 ] WARNING: unknown node ‘g9’
[ 3.4527 ] Added Platform Config 2 data with size :- 24
[ 3.4527 ]
[ 3.4527 ] Parsing config file :tegra234-mb1-bct-pmic-p3701-0000_cpp.dtb
[ 3.4527 ] Added Platform Config 4 data with size :- 476
[ 3.4527 ]
[ 3.4528 ] Parsing config file :tegra234-mb1-bct-reset-p3701-0000_cpp.dtb
[ 3.4528 ] Added Platform Config 3 data with size :- 52
[ 3.4528 ]
[ 3.4528 ] Parsing config file :tegra234-mb1-bct-prod-p3701-0000_cpp.dtb
[ 3.4528 ] WARNING: unknown property ‘major’
[ 3.4528 ] WARNING: unknown property ‘minor’
[ 3.4528 ] Added Platform Config 5 data with size :- 500
[ 3.4528 ]
[ 3.4528 ] Parsing config file :tegra234-mb1-bct-gpioint-p3701-0000_cpp.dtb
[ 3.4528 ] Added Platform Config 7 data with size :- 380
[ 3.4528 ]
[ 3.4528 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 3.4528 ] Added Platform Config 9 data with size :- 80
[ 3.4528 ]
[ 3.4528 ] Parsing config file :tegra234-mb1-bct-cprod-p3701-0000_cpp.dtb
[ 3.4528 ] ModuleCount 0 NumProdNames 0
[ 3.4528 ] Added Platform Config 6 data with size :- 16
[ 3.4528 ]
[ 3.4529 ] Updating mb1-bct with firmware information
[ 3.4535 ] tegrabct_v2 --chip 0x23 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 3.4545 ]
[ 3.4553 ] tegrahost_v2 --chip 0x23 --align mb1_cold_boot_bct_MB1_aligned.bct
[ 3.4560 ]
[ 3.4566 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[ 3.4572 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[ 3.4577 ]
[ 3.4584 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --sha sha512
[ 3.4585 ] Assuming zero filled SBK key
[ 3.4599 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 3.4608 ]
[ 3.4609 ] Generating recovery mb1-bct
[ 3.4616 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --wb0sdram tegra234-p3701-0000-p3737-0000-TE990M-wb0sdram_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3701-0000_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3701-0000_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3701-0000_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3701-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3701-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3701-0000_cpp.dtb
[ 3.4622 ] MB1-BCT version: 0.7
[ 3.4623 ] ERROR: /misc/axi_ap_virtual_client is not supported
[ 3.4630 ] Parsing config file :tegra234-mb1-bct-pinmux-p3701-0000_cpp.dtb
[ 3.4634 ] WARNING: unknown property ‘linux,phandle’
[ 3.4640 ] WARNING: unknown property ‘linux,phandle’
[ 3.4642 ] WARNING: unknown property ‘linux,phandle’
[ 3.4643 ] WARNING: unknown property ‘linux,phandle’
[ 3.4645 ] WARNING: unknown property ‘linux,phandle’
[ 3.4653 ] WARNING: unknown property ‘linux,phandle’
[ 3.4657 ] Added Platform Config 0 data with size :- 3744
[ 3.4660 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3701-0000_cpp.dtb
[ 3.4661 ] WARNING: unknown node ‘g2’
[ 3.4661 ] WARNING: unknown node ‘g9’
[ 3.4661 ] Added Platform Config 2 data with size :- 24
[ 3.4661 ]
[ 3.4661 ] Parsing config file :tegra234-mb1-bct-pmic-p3701-0000_cpp.dtb
[ 3.4661 ] Added Platform Config 4 data with size :- 476
[ 3.4661 ]
[ 3.4661 ] Parsing config file :tegra234-mb1-bct-reset-p3701-0000_cpp.dtb
[ 3.4661 ] Added Platform Config 3 data with size :- 52
[ 3.4662 ]
[ 3.4662 ] Parsing config file :tegra234-mb1-bct-prod-p3701-0000_cpp.dtb
[ 3.4662 ] WARNING: unknown property ‘major’
[ 3.4662 ] WARNING: unknown property ‘minor’
[ 3.4662 ] Added Platform Config 5 data with size :- 500
[ 3.4662 ]
[ 3.4662 ] Parsing config file :tegra234-mb1-bct-gpioint-p3701-0000_cpp.dtb
[ 3.4662 ] Added Platform Config 7 data with size :- 380
[ 3.4662 ]
[ 3.4662 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 3.4662 ] Added Platform Config 9 data with size :- 80
[ 3.4662 ]
[ 3.4662 ] Parsing config file :tegra234-mb1-bct-cprod-p3701-0000_cpp.dtb
[ 3.4662 ] ModuleCount 0 NumProdNames 0
[ 3.4662 ] Added Platform Config 6 data with size :- 16
[ 3.4662 ]
[ 3.4663 ] Updating mb1-bct with firmware information
[ 3.4669 ] tegrabct_v2 --chip 0x23 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo flash.xml.bin
[ 3.4678 ]
[ 3.4686 ] tegrahost_v2 --chip 0x23 --align mb1_bct_MB1_aligned.bct
[ 3.4692 ]
[ 3.4699 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[ 3.4707 ] adding BCH for mb1_bct_MB1_aligned.bct
[ 3.4714 ]
[ 3.4721 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --sha sha512
[ 3.4722 ] Assuming zero filled SBK key
[ 3.4735 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 3.4748 ]
[ 3.4749 ] Generating coldboot mem-bct
[ 3.4756 ] tegrabct_v2 --chip 0x23 0 --sdram tegra234-p3701-0000-p3737-0000-TE990M-sdram_cpp.dtb --wb0sdram tegra234-p3701-0000-p3737-0000-TE990M-wb0sdram_cpp.dtb --membct tegra234-p3701-0000-p3737-0000-TE990M-sdram_cpp_1.bct tegra234-p3701-0000-p3737-0000-TE990M-sdram_cpp_2.bct tegra234-p3701-0000-p3737-0000-TE990M-sdram_cpp_3.bct tegra234-p3701-0000-p3737-0000-TE990M-sdram_cpp_4.bct
[ 3.4762 ] packing sdram params with Wb0 file tegra234-p3701-0000-p3737-0000-TE990M-wb0sdram_cpp.dtb
[ 3.4891 ] Packing sdram param for instance[0]
[ 3.4892 ] Packing sdram param for instance[1]
[ 3.4894 ] Packing sdram param for instance[2]
[ 3.4895 ] Packing sdram param for instance[3]
[ 3.4896 ] Packing sdram param for instance[4]
[ 3.4898 ] Packing sdram param for instance[5]
[ 3.4900 ] Packing sdram param for instance[6]
[ 3.4902 ] Packing sdram param for instance[7]
[ 3.4904 ] Packing sdram param for instance[8]
[ 3.4906 ] Packing sdram param for instance[9]
[ 3.4908 ] Packing sdram param for instance[10]
[ 3.4910 ] Packing sdram param for instance[11]
[ 3.4912 ] Packing sdram param for instance[12]
[ 3.4913 ] Packing sdram param for instance[13]
[ 3.4914 ] Packing sdram param for instance[14]
[ 3.4915 ] Packing sdram param for instance[15]
[ 3.5021 ]
[ 3.5022 ] Getting sector size from pt
[ 3.5028 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[ 3.5036 ]
[ 3.5037 ] BlockSize read from layout is 0x200
[ 3.5045 ] tegrahost_v2 --chip 0x23 0 --blocksize 512 --magicid MEMB --addsigheader_multi tegra234-p3701-0000-p3737-0000-TE990M-sdram_cpp_1.bct tegra234-p3701-0000-p3737-0000-TE990M-sdram_cpp_2.bct tegra234-p3701-0000-p3737-0000-TE990M-sdram_cpp_3.bct tegra234-p3701-0000-p3737-0000-TE990M-sdram_cpp_4.bct
[ 3.5051 ] Binary 0 length is 58752
[ 3.5053 ] Binary 0 align length is 58880
[ 3.5061 ] Binary 1 length is 58752
[ 3.5062 ] Binary 1 align length is 58880
[ 3.5069 ] Binary 2 length is 58752
[ 3.5070 ] Binary 2 align length is 58880
[ 3.5078 ] Binary 3 length is 58752
[ 3.5080 ] Binary 3 align length is 58880
[ 3.5088 ] Buffer length is 235520
[ 3.5089 ] adding BCH for tegra234-p3701-0000-p3737-0000-TE990M-sdram_cpp_1.bct
[ 3.5092 ] new length is 243712
[ 3.5092 ]
[ 3.5102 ] tegrahost_v2 --chip 0x23 --align mem_coldboot_aligned.bct
[ 3.5110 ]
[ 3.5117 ] tegrahost_v2 --chip 0x23 0 --magicid MEMB --appendsigheader mem_coldboot_aligned.bct zerosbk
[ 3.5123 ] Header already present for mem_coldboot_aligned.bct
[ 3.5128 ]
[ 3.5135 ] tegrasign_v3.py --key None --list mem_coldboot_aligned_sigheader.bct_list.xml --sha sha512
[ 3.5136 ] Assuming zero filled SBK key
[ 3.5152 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_coldboot_aligned_sigheader.bct.encrypt mem_coldboot_aligned_sigheader.bct.hash zerosbk
[ 3.5163 ]
[ 3.5165 ] Generating recovery mem-bct
[ 3.5172 ] tegrabct_v2 --chip 0x23 0 --sdram tegra234-p3701-0000-p3737-0000-TE990M-sdram_cpp.dtb --wb0sdram tegra234-p3701-0000-p3737-0000-TE990M-wb0sdram_cpp.dtb --membct tegra234-p3701-0000-p3737-0000-TE990M-sdram_cpp_1.bct tegra234-p3701-0000-p3737-0000-TE990M-sdram_cpp_2.bct tegra234-p3701-0000-p3737-0000-TE990M-sdram_cpp_3.bct tegra234-p3701-0000-p3737-0000-TE990M-sdram_cpp_4.bct
[ 3.5177 ] packing sdram params with Wb0 file tegra234-p3701-0000-p3737-0000-TE990M-wb0sdram_cpp.dtb
[ 3.5306 ] Packing sdram param for instance[0]
[ 3.5307 ] Packing sdram param for instance[1]
[ 3.5308 ] Packing sdram param for instance[2]
[ 3.5309 ] Packing sdram param for instance[3]
[ 3.5311 ] Packing sdram param for instance[4]
[ 3.5312 ] Packing sdram param for instance[5]
[ 3.5313 ] Packing sdram param for instance[6]
[ 3.5315 ] Packing sdram param for instance[7]
[ 3.5316 ] Packing sdram param for instance[8]
[ 3.5317 ] Packing sdram param for instance[9]
[ 3.5319 ] Packing sdram param for instance[10]
[ 3.5320 ] Packing sdram param for instance[11]
[ 3.5321 ] Packing sdram param for instance[12]
[ 3.5323 ] Packing sdram param for instance[13]
[ 3.5324 ] Packing sdram param for instance[14]
[ 3.5325 ] Packing sdram param for instance[15]
[ 3.5441 ]
[ 3.5442 ] Reading ramcode from backup chip_info.bin file
[ 3.5442 ] RAMCODE Read from Device: 0
[ 3.5442 ] Using ramcode 0
[ 3.5442 ] Disabled BPMP dtb trim, using default dtb
[ 3.5442 ]
[ 3.5452 ] tegrahost_v2 --chip 0x23 --align mem_rcm_aligned.bct
[ 3.5460 ]
[ 3.5467 ] tegrahost_v2 --chip 0x23 0 --magicid MEM0 --appendsigheader mem_rcm_aligned.bct zerosbk
[ 3.5474 ] adding BCH for mem_rcm_aligned.bct
[ 3.5491 ]
[ 3.5498 ] tegrasign_v3.py --key None --list mem_rcm_aligned_sigheader.bct_list.xml --sha sha512
[ 3.5500 ] Assuming zero filled SBK key
[ 3.5514 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_rcm_aligned_sigheader.bct.encrypt mem_rcm_aligned_sigheader.bct.hash zerosbk
[ 3.5523 ]
[ 3.5525 ] Copying signatures
[ 3.5531 ] tegrahost_v2 --chip 0x23 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 3.6597 ]
[ 3.6615 ] Boot Rom communication
[ 3.6699 ] tegrarcm_v2 --new_session --chip 0x23 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 3.6707 ] BR_CID: 0x80012344705DD10F2000000005030100
[ 5.6920 ] Sending bct_br
[ 6.2155 ] Sending mb1
[ 6.2159 ] Sending psc_bl1
[ 6.2241 ] Sending bct_mb1
[ 6.2296 ]
[ 6.2297 ] Boot Rom communication completed
[ 6.2297 ] Generating blob for T23x
[ 6.2321 ] tegrahost_v2 --chip 0x23 --align blob_uefi_jetson_with_dtb_aligned.bin
[ 6.2328 ]
[ 6.2335 ] tegrahost_v2 --chip 0x23 0 --magicid CPBL --appendsigheader blob_uefi_jetson_with_dtb_aligned.bin zerosbk
[ 6.2341 ] adding BCH for blob_uefi_jetson_with_dtb_aligned.bin
[ 6.3138 ]
[ 6.3146 ] tegrasign_v3.py --key None --list blob_uefi_jetson_with_dtb_aligned_sigheader.bin_list.xml --sha sha512
[ 6.3147 ] Assuming zero filled SBK key
[ 6.3198 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_uefi_jetson_with_dtb_aligned_sigheader.bin.encrypt blob_uefi_jetson_with_dtb_aligned_sigheader.bin.hash zerosbk
[ 6.3235 ]
[ 6.3263 ] tegrahost_v2 --chip 0x23 --align blob_pscfw_t234_prod_aligned.bin
[ 6.3271 ]
[ 6.3280 ] tegrahost_v2 --chip 0x23 0 --magicid DATA --appendsigheader blob_pscfw_t234_prod_aligned.bin zerosbk
[ 6.3287 ] Header already present for blob_pscfw_t234_prod_aligned.bin
[ 6.3333 ]
[ 6.3340 ] tegrasign_v3.py --key None --list blob_pscfw_t234_prod_aligned_sigheader.bin_list.xml --sha sha512
[ 6.3341 ] Assuming zero filled SBK key
[ 6.3362 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_pscfw_t234_prod_aligned_sigheader.bin.encrypt blob_pscfw_t234_prod_aligned_sigheader.bin.hash zerosbk
[ 6.3377 ]
[ 6.3391 ] tegrahost_v2 --chip 0x23 --align blob_mce_flash_o10_cr_prod_aligned.bin
[ 6.3398 ]
[ 6.3406 ] tegrahost_v2 --chip 0x23 0 --magicid MTSM --appendsigheader blob_mce_flash_o10_cr_prod_aligned.bin zerosbk
[ 6.3413 ] Header already present for blob_mce_flash_o10_cr_prod_aligned.bin
[ 6.3438 ]
[ 6.3445 ] tegrasign_v3.py --key None --list blob_mce_flash_o10_cr_prod_aligned_sigheader.bin_list.xml --sha sha512
[ 6.3446 ] Assuming zero filled SBK key
[ 6.3465 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_mce_flash_o10_cr_prod_aligned_sigheader.bin.encrypt blob_mce_flash_o10_cr_prod_aligned_sigheader.bin.hash zerosbk
[ 6.3476 ]
[ 6.3485 ] Generating recovery mb2-bct
[ 6.3486 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_bct.cfg --recov --mb2bctcfg tegra234-mb2-bct-misc-p3701-0000_cpp.dtb
[ 6.3501 ]
[ 6.3501 ] Updating mb2-bct with storage information
[ 6.3509 ] tegrabct_v2 --chip 0x23 --mb2bct mb2_bct_MB2.bct --updatestorageinfo flash.xml.bin
[ 6.3518 ]
[ 6.3518 ] Concatenating mb2-bct to mb2 binary
[ 6.3518 ] mb2_bin_file = mb2_t234.bin
[ 6.3518 ] mb2_bct_file = mb2_bct_MB2.bct
[ 6.3532 ] tegrahost_v2 --chip 0x23 --align blob_mb2_t234_with_mb2_bct_MB2_aligned.bin
[ 6.3543 ]
[ 6.3550 ] tegrahost_v2 --chip 0x23 0 --magicid MB2B --appendsigheader blob_mb2_t234_with_mb2_bct_MB2_aligned.bin zerosbk
[ 6.3557 ] adding BCH for blob_mb2_t234_with_mb2_bct_MB2_aligned.bin
[ 6.3667 ]
[ 6.3674 ] tegrasign_v3.py --key None --list blob_mb2_t234_with_mb2_bct_MB2_aligned_sigheader.bin_list.xml --sha sha512
[ 6.3676 ] Assuming zero filled SBK key
[ 6.3693 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_mb2_t234_with_mb2_bct_MB2_aligned_sigheader.bin.encrypt blob_mb2_t234_with_mb2_bct_MB2_aligned_sigheader.bin.hash zerosbk
[ 6.3708 ]
[ 6.3720 ] tegrahost_v2 --chip 0x23 --align blob_xusb_t234_prod_aligned.bin
[ 6.3727 ]
[ 6.3734 ] tegrahost_v2 --chip 0x23 0 --magicid XUSB --appendsigheader blob_xusb_t234_prod_aligned.bin zerosbk
[ 6.3741 ] adding BCH for blob_xusb_t234_prod_aligned.bin
[ 6.3785 ]
[ 6.3792 ] tegrasign_v3.py --key None --list blob_xusb_t234_prod_aligned_sigheader.bin_list.xml --sha sha512
[ 6.3793 ] Assuming zero filled SBK key
[ 6.3810 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_xusb_t234_prod_aligned_sigheader.bin.encrypt blob_xusb_t234_prod_aligned_sigheader.bin.hash zerosbk
[ 6.3821 ]
[ 6.3824 ] Concatenating kernel-dtb to dce-fw binary
[ 6.3824 ] dce_bin = dce.bin
[ 6.3824 ] kernel_dtb = kernel_tegra234-p3701-0000-p3737-0000.dtb
[ 6.3824 ] dce_with_dtb = dce_with_kernel_tegra234-p3701-0000-p3737-0000.bin
[ 6.3922 ] tegrahost_v2 --chip 0x23 --align blob_dce_with_kernel_tegra234-p3701-0000-p3737-0000_aligned.bin
[ 6.3930 ]
[ 6.3942 ] tegrahost_v2 --chip 0x23 0 --magicid DCEF --appendsigheader blob_dce_with_kernel_tegra234-p3701-0000-p3737-0000_aligned.bin zerosbk
[ 6.3950 ] adding BCH for blob_dce_with_kernel_tegra234-p3701-0000-p3737-0000_aligned.bin
[ 6.6326 ]
[ 6.6334 ] tegrasign_v3.py --key None --list blob_dce_with_kernel_tegra234-p3701-0000-p3737-0000_aligned_sigheader.bin_list.xml --sha sha512
[ 6.6336 ] Assuming zero filled SBK key
[ 6.6473 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_dce_with_kernel_tegra234-p3701-0000-p3737-0000_aligned_sigheader.bin.encrypt blob_dce_with_kernel_tegra234-p3701-0000-p3737-0000_aligned_sigheader.bin.hash zerosbk
[ 6.6560 ]
[ 6.6607 ] tegrahost_v2 --chip 0x23 --align blob_nvdec_t234_prod_aligned.fw
[ 6.6615 ]
[ 6.6622 ] tegrahost_v2 --chip 0x23 0 --magicid NDEC --appendsigheader blob_nvdec_t234_prod_aligned.fw zerosbk
[ 6.6629 ] Header already present for blob_nvdec_t234_prod_aligned.fw
[ 6.6657 ]
[ 6.6665 ] tegrasign_v3.py --key None --list blob_nvdec_t234_prod_aligned_sigheader.fw_list.xml --sha sha512
[ 6.6666 ] Assuming zero filled SBK key
[ 6.6681 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_nvdec_t234_prod_aligned_sigheader.fw.encrypt blob_nvdec_t234_prod_aligned_sigheader.fw.hash zerosbk
[ 6.6690 ]
[ 6.6704 ] tegrahost_v2 --chip 0x23 --align blob_bpmp_t234-TE990M-A1_prod_aligned.bin
[ 6.6712 ]
[ 6.6719 ] tegrahost_v2 --chip 0x23 0 --magicid BPMF --appendsigheader blob_bpmp_t234-TE990M-A1_prod_aligned.bin zerosbk
[ 6.6725 ] Header already present for blob_bpmp_t234-TE990M-A1_prod_aligned.bin
[ 6.6856 ]
[ 6.6864 ] tegrasign_v3.py --key None --list blob_bpmp_t234-TE990M-A1_prod_aligned_sigheader.bin_list.xml --sha sha512
[ 6.6865 ] Assuming zero filled SBK key
[ 6.6894 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_bpmp_t234-TE990M-A1_prod_aligned_sigheader.bin.encrypt blob_bpmp_t234-TE990M-A1_prod_aligned_sigheader.bin.hash zerosbk
[ 6.6912 ]
[ 6.6926 ] tegrahost_v2 --chip 0x23 --align blob_tegra234-bpmp-3701-0000-3737-0000_aligned.dtb
[ 6.6933 ]
[ 6.6941 ] tegrahost_v2 --chip 0x23 0 --magicid BPMD --appendsigheader blob_tegra234-bpmp-3701-0000-3737-0000_aligned.dtb zerosbk
[ 6.6948 ] adding BCH for blob_tegra234-bpmp-3701-0000-3737-0000_aligned.dtb
[ 6.6987 ]
[ 6.6995 ] tegrasign_v3.py --key None --list blob_tegra234-bpmp-3701-0000-3737-0000_aligned_sigheader.dtb_list.xml --sha sha512
[ 6.6996 ] Assuming zero filled SBK key
[ 6.7012 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_tegra234-bpmp-3701-0000-3737-0000_aligned_sigheader.dtb.encrypt blob_tegra234-bpmp-3701-0000-3737-0000_aligned_sigheader.dtb.hash zerosbk
[ 6.7023 ]
[ 6.7034 ] tegrahost_v2 --chip 0x23 --align blob_camera-rtcpu-sce_aligned.img
[ 6.7045 ]
[ 6.7052 ] tegrahost_v2 --chip 0x23 0 --magicid SCEF --appendsigheader blob_camera-rtcpu-sce_aligned.img zerosbk
[ 6.7060 ] adding BCH for blob_camera-rtcpu-sce_aligned.img
[ 6.7105 ]
[ 6.7112 ] tegrasign_v3.py --key None --list blob_camera-rtcpu-sce_aligned_sigheader.img_list.xml --sha sha512
[ 6.7113 ] Assuming zero filled SBK key
[ 6.7130 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_camera-rtcpu-sce_aligned_sigheader.img.encrypt blob_camera-rtcpu-sce_aligned_sigheader.img.hash zerosbk
[ 6.7142 ]
[ 6.7154 ] tegrahost_v2 --chip 0x23 --align blob_camera-rtcpu-t234-rce_aligned.img
[ 6.7162 ]
[ 6.7168 ] tegrahost_v2 --chip 0x23 0 --magicid RCEF --appendsigheader blob_camera-rtcpu-t234-rce_aligned.img zerosbk
[ 6.7175 ] adding BCH for blob_camera-rtcpu-t234-rce_aligned.img
[ 6.7314 ]
[ 6.7321 ] tegrasign_v3.py --key None --list blob_camera-rtcpu-t234-rce_aligned_sigheader.img_list.xml --sha sha512
[ 6.7322 ] Assuming zero filled SBK key
[ 6.7345 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_camera-rtcpu-t234-rce_aligned_sigheader.img.encrypt blob_camera-rtcpu-t234-rce_aligned_sigheader.img.hash zerosbk
[ 6.7358 ]
[ 6.7371 ] tegrahost_v2 --chip 0x23 --align blob_adsp-fw_aligned.bin
[ 6.7380 ]
[ 6.7387 ] tegrahost_v2 --chip 0x23 0 --magicid APEF --appendsigheader blob_adsp-fw_aligned.bin zerosbk
[ 6.7395 ] adding BCH for blob_adsp-fw_aligned.bin
[ 6.7501 ]
[ 6.7508 ] tegrasign_v3.py --key None --list blob_adsp-fw_aligned_sigheader.bin_list.xml --sha sha512
[ 6.7509 ] Assuming zero filled SBK key
[ 6.7528 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_adsp-fw_aligned_sigheader.bin.encrypt blob_adsp-fw_aligned_sigheader.bin.hash zerosbk
[ 6.7542 ]
[ 6.7554 ] tegrahost_v2 --chip 0x23 --align blob_spe_t234_aligned.bin
[ 6.7560 ]
[ 6.7566 ] tegrahost_v2 --chip 0x23 0 --magicid SPEF --appendsigheader blob_spe_t234_aligned.bin zerosbk
[ 6.7573 ] adding BCH for blob_spe_t234_aligned.bin
[ 6.7640 ]
[ 6.7647 ] tegrasign_v3.py --key None --list blob_spe_t234_aligned_sigheader.bin_list.xml --sha sha512
[ 6.7648 ] Assuming zero filled SBK key
[ 6.7665 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_spe_t234_aligned_sigheader.bin.encrypt blob_spe_t234_aligned_sigheader.bin.hash zerosbk
[ 6.7676 ]
[ 6.7685 ] tegrahost_v2 --chip 0x23 --align blob_tos-mon-only_t234_aligned.img
[ 6.7692 ]
[ 6.7699 ] tegrahost_v2 --chip 0x23 0 --magicid TOSB --appendsigheader blob_tos-mon-only_t234_aligned.img zerosbk
[ 6.7710 ] adding BCH for blob_tos-mon-only_t234_aligned.img
[ 6.7741 ]
[ 6.7748 ] tegrasign_v3.py --key None --list blob_tos-mon-only_t234_aligned_sigheader.img_list.xml --sha sha512
[ 6.7749 ] Assuming zero filled SBK key
[ 6.7766 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_tos-mon-only_t234_aligned_sigheader.img.encrypt blob_tos-mon-only_t234_aligned_sigheader.img.hash zerosbk
[ 6.7776 ]
[ 6.7786 ] tegrahost_v2 --chip 0x23 --align blob_eks_aligned.img
[ 6.7793 ]
[ 6.7801 ] tegrahost_v2 --chip 0x23 0 --magicid EKSB --appendsigheader blob_eks_aligned.img zerosbk
[ 6.7807 ] adding BCH for blob_eks_aligned.img
[ 6.7810 ]
[ 6.7817 ] tegrasign_v3.py --key None --list blob_eks_aligned_sigheader.img_list.xml --sha sha512
[ 6.7819 ] Assuming zero filled SBK key
[ 6.7836 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_eks_aligned_sigheader.img.encrypt blob_eks_aligned_sigheader.img.hash zerosbk
[ 6.7844 ]
[ 6.7853 ] tegrahost_v2 --chip 0x23 --generateblob blob.xml blob.bin
[ 6.7859 ] The number of images in blob is 16
[ 6.7862 ] blobsize is 16747296
[ 6.7863 ] Added binary blob_uefi_jetson_with_dtb_sigheader.bin.encrypt of size 3144640
[ 6.7918 ] Added binary blob_pscfw_t234_prod_sigheader.bin.encrypt of size 366592
[ 6.7922 ] Added binary blob_mce_flash_o10_cr_prod_sigheader.bin.encrypt of size 179856
[ 6.7926 ] Added binary blob_applet_t234.bin of size 269184
[ 6.7929 ] Not supported type: mb2_applet
[ 6.7931 ] Added binary blob_mb2_t234_with_mb2_bct_MB2_sigheader.bin.encrypt of size 440640
[ 6.7936 ] Added binary blob_xusb_t234_prod_sigheader.bin.encrypt of size 164352
[ 6.7940 ] Added binary blob_dce_with_kernel_tegra234-p3701-0000-p3737-0000_sigheader.bin.encrypt of size 9335056
[ 6.7962 ] Added binary blob_nvdec_t234_prod_sigheader.fw.encrypt of size 225280
[ 6.7971 ] Added binary blob_bpmp_t234-TE990M-A1_prod_sigheader.bin.encrypt of size 1005888
[ 6.7977 ] Added binary blob_tegra234-bpmp-3701-0000-3737-0000_sigheader.dtb.encrypt of size 140160
[ 6.7983 ] Added binary blob_camera-rtcpu-sce_sigheader.img.encrypt of size 166192
[ 6.7986 ] Added binary blob_camera-rtcpu-t234-rce_sigheader.img.encrypt of size 521568
[ 6.7990 ] Added binary blob_adsp-fw_sigheader.bin.encrypt of size 399328
[ 6.7993 ] Added binary blob_spe_t234_sigheader.bin.encrypt of size 270336
[ 6.7996 ] Added binary blob_tos-mon-only_t234_sigheader.img.encrypt of size 107888
[ 6.8000 ] Added binary blob_eks_sigheader.img.encrypt of size 9232
[ 6.8049 ]
[ 6.8050 ] Sending membct and RCM blob
[ 6.8060 ] tegrarcm_v2 --chip 0x23 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
[ 6.8067 ] BL: version 0.11.0.0-t234-54845784-7fb1fa27 last_boot_error: 0
[ 7.5400 ] Sending bct_mem
[ 8.0634 ] Sending blob
[ 9.2158 ]
[ 9.2158 ] completed
[ 9.2158 ] Retrieving storage infomation
[ 9.2167 ] tegrarcm_v2 --chip 0x23 --oem platformdetails storage storage_info.bin
[ 9.2174 ] MB2 version 01.00.0000
[ 10.1524 ] Saved platform info in storage_info.bin
[ 10.1560 ]
[ 11.1582 ] tegrarcm_v2 --chip 0x23 --ismb2applet
[ 11.6944 ]
[ 11.6954 ] tegrarcm_v2 --chip 0x23 --ismb2
[ 11.6961 ] MB2 version 01.00.0000
[ 12.4412 ]
[ 12.4412 ] Flashing the device
[ 12.4421 ] tegraparser_v2 --storageinfo storage_info.bin --generategpt --pt flash.xml.bin
[ 12.4432 ]
[ 12.4432 ] Start flashing
[ 12.4501 ] tegradevflash_v2 --pt flash.xml.bin --create
[ 12.4507 ] Bootloader version 01.00.0000
[ 12.9767 ] Erasing spi: 0 … [Done]
[ 181.9895 ] Writing partition secondary_gpt with gpt_secondary_3_0.bin [ 16896 bytes ]
[ 181.9898 ] […] 100%
[ 182.2086 ] Erasing sdmmc_user: 3 … [Done]
[ 184.2282 ] Writing partition master_boot_record with mbr_1_3.bin [ 512 bytes ]
[ 184.2286 ] […] 100%
[ 184.2313 ] Writing partition primary_gpt with gpt_primary_1_3.bin [ 16896 bytes ]
[ 184.2331 ] […] 100%
[ 184.2363 ] Writing partition secondary_gpt with gpt_secondary_1_3.bin [ 16896 bytes ]
[ 184.2433 ] […] 100%
[ 184.2531 ] Writing partition A_mb1 with mb1_t234_prod_aligned_sigheader.bin.encrypt [ 223184 bytes ]
[ 184.2535 ] […] 100%
[ 184.2623 ] Writing partition B_mb1 with mb1_t234_prod_aligned_sigheader.bin.encrypt [ 223184 bytes ]
[ 187.0041 ] […] 100%
[ 187.0129 ] Writing partition A_psc_bl1 with psc_bl1_t234_prod_aligned_sigheader.bin.encrypt [ 118640 bytes ]
[ 189.7549 ] […] 100%
[ 189.7624 ] Writing partition A_nvdec with nvdec_t234_prod_sigheader.fw.encrypt [ 225280 bytes ]
[ 191.2242 ] […] 100%
[ 191.2336 ] Writing partition A_mb2 with mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt [ 440640 bytes ]
[ 193.9982 ] […] 100%
[ 194.0124 ] Writing partition A_xusb-fw with xusb_t234_prod_sigheader.bin.encrypt [ 164352 bytes ]
[ 199.4218 ] […] 100%
[ 199.4298 ] Writing partition A_bpmp-fw with bpmp_t234-TE990M-A1_prod_sigheader.bin.encrypt [ 1005888 bytes ]
[ 201.4481 ] […] 100%
[ 201.4777 ] Writing partition A_bpmp-fw-dtb with tegra234-bpmp-3701-0000-3737-0000_with_odm_sigheader.dtb.encrypt [ 140160 bytes ]
[ 213.8159 ] […] 100%
[ 213.8236 ] Writing partition A_psc-fw with pscfw_t234_prod_sigheader.bin.encrypt [ 366592 bytes ]
[ 215.5485 ] […] 100%
[ 215.5618 ] Writing partition A_mts-mce with mce_flash_o10_cr_prod_sigheader.bin.encrypt [ 179856 bytes ]
[ 220.0596 ] […] 100%
[ 220.0677 ] Writing partition A_sc7 with sc7_t234_prod_sigheader.bin.encrypt [ 50400 bytes ]
[ 222.2821 ] […] 100%
[ 222.2865 ] Writing partition A_pscrf with psc_rf_t234_prod_sigheader.bin.encrypt [ 118640 bytes ]
[ 222.9133 ] […] 100%
[ 222.9198 ] Writing partition A_mb2rf with nvtboot_cpurf_t234_sigheader.bin.encrypt [ 62304 bytes ]
[ 224.3811 ] […] 100%
[ 224.3858 ] Writing partition A_cpu-bootloader with uefi_jetson_with_dtb_sigheader.bin.encrypt [ 3144640 bytes ]
[ 225.1567 ] […] 100%
[ 250.9632 ] Writing partition A_secure-os with tos-mon-only_t234_sigheader.img.encrypt [ 107888 bytes ]
[ 263.8110 ] […] 100%
[ 263.8174 ] Writing partition A_eks with eks_sigheader.img.encrypt [ 9232 bytes ]
[ 265.1473 ] […] 100%
[ 265.1508 ] Writing partition A_dce-fw with dce_with_kernel_tegra234-p3701-0000-p3737-0000_sigheader.bin.encrypt [ 9335056 bytes ]
[ 265.2758 ] […] 100%
[ 368.4029 ] Writing partition A_spe-fw with spe_t234_sigheader.bin.encrypt [ 270336 bytes ]
[ 380.0137 ] […] 100%
[ 380.0244 ] Writing partition A_rce-fw with camera-rtcpu-t234-rce_sigheader.img.encrypt [ 521568 bytes ]
[ 383.3423 ] […] 100%
[ 383.3589 ] Writing partition A_adsp-fw with adsp-fw_sigheader.bin.encrypt [ 399328 bytes ]
[ 389.7600 ] […] 100%
[ 389.7741 ] Writing partition B_psc_bl1 with psc_bl1_t234_prod_aligned_sigheader.bin.encrypt [ 118640 bytes ]
[ 394.6751 ] […] 100%
[ 394.6815 ] Writing partition B_nvdec with nvdec_t234_prod_sigheader.fw.encrypt [ 225280 bytes ]
[ 396.1432 ] […] 100%
[ 396.1521 ] Writing partition B_mb2 with mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt [ 440640 bytes ]
[ 398.9173 ] […] 100%
[ 398.9316 ] Writing partition B_xusb-fw with xusb_t234_prod_sigheader.bin.encrypt [ 164352 bytes ]
[ 404.3420 ] […] 100%
[ 404.3492 ] Writing partition B_bpmp-fw with bpmp_t234-TE990M-A1_prod_sigheader.bin.encrypt [ 1005888 bytes ]
[ 406.3673 ] […] 100%
[ 406.3966 ] Writing partition B_bpmp-fw-dtb with tegra234-bpmp-3701-0000-3737-0000_with_odm_sigheader.dtb.encrypt [ 140160 bytes ]
[ 418.7360 ] […] 100%
[ 418.7431 ] Writing partition B_psc-fw with pscfw_t234_prod_sigheader.bin.encrypt [ 366592 bytes ]
[ 420.4690 ] […] 100%
[ 420.4819 ] Writing partition B_mts-mce with mce_flash_o10_cr_prod_sigheader.bin.encrypt [ 179856 bytes ]
[ 424.9791 ] […] 100%
[ 424.9871 ] Writing partition B_sc7 with sc7_t234_prod_sigheader.bin.encrypt [ 50400 bytes ]
[ 427.2016 ] […] 100%
[ 427.2061 ] Writing partition B_pscrf with psc_rf_t234_prod_sigheader.bin.encrypt [ 118640 bytes ]
[ 427.8327 ] […] 100%
[ 427.8394 ] Writing partition B_mb2rf with nvtboot_cpurf_t234_sigheader.bin.encrypt [ 62304 bytes ]
[ 429.3025 ] […] 100%
[ 429.3073 ] Writing partition B_cpu-bootloader with uefi_jetson_with_dtb_sigheader.bin.encrypt [ 3144640 bytes ]
[ 430.0782 ] […] 100%
[ 455.8981 ] Writing partition B_secure-os with tos-mon-only_t234_sigheader.img.encrypt [ 107888 bytes ]
[ 468.7465 ] […] 100%
[ 468.7524 ] Writing partition B_eks with eks_sigheader.img.encrypt [ 9232 bytes ]
[ 470.0825 ] […] 100%
[ 470.0859 ] Writing partition B_dce-fw with dce_with_kernel_tegra234-p3701-0000-p3737-0000_sigheader.bin.encrypt [ 9335056 bytes ]
[ 470.2110 ] […] 100%
[ 573.3423 ] Writing partition B_spe-fw with spe_t234_sigheader.bin.encrypt [ 270336 bytes ]
[ 584.9543 ] […] 100%
[ 584.9656 ] Writing partition B_rce-fw with camera-rtcpu-t234-rce_sigheader.img.encrypt [ 521568 bytes ]
[ 588.2829 ] […] 100%
[ 588.2997 ] Writing partition B_adsp-fw with adsp-fw_sigheader.bin.encrypt [ 399328 bytes ]
[ 594.7016 ] […] 100%
[ 594.7159 ] Writing partition mb2-applet with applet_t234.bin [ 269184 bytes ]
[ 599.6176 ] […] 100%
[ 599.6280 ] Writing partition VER_b with qspi_bootblob_ver.txt [ 101 bytes ]
[ 602.9353 ] […] 100%
[ 602.9452 ] Writing partition VER with qspi_bootblob_ver.txt [ 101 bytes ]
[ 602.9544 ] […] 100%
[ 602.9575 ] Writing partition master_boot_record with mbr_1_3.bin [ 512 bytes ]
[ 602.9665 ] […] 100%
[ 602.9695 ] Writing partition A_kernel with boot.img [ 42098688 bytes ]
[ 602.9753 ] […] 100%
[ 604.3600 ] Writing partition A_kernel-dtb with kernel_tegra234-p3701-0000-p3737-0000_with_odm.dtb [ 307630 bytes ]
[ 604.3624 ] […] 100%
[ 604.3733 ] Writing partition B_kernel with boot.img [ 42098688 bytes ]
[ 604.3768 ] […] 100%
[ 605.7913 ] Writing partition B_kernel-dtb with kernel_tegra234-p3701-0000-p3737-0000_with_odm.dtb [ 307630 bytes ]
[ 605.7934 ] […] 100%
[ 605.8045 ] Writing partition recovery with recovery_sigheader.img.encrypt [ 45756416 bytes ]
[ 605.8081 ] […] 100%
[ 607.3014 ] Writing partition recovery-dtb with tegra234-p3701-0000-p3737-0000.dtb_sigheader.rec.encrypt [ 315664 bytes ]
[ 607.3064 ] […] 100%
[ 607.3181 ] Writing partition esp with esp.img [ 67108864 bytes ]
[ 607.3213 ] […] 100%
[ 609.4881 ] Writing partition APP with system.img [ 5495314556 bytes ]
[ 609.4936 ] […] 100%
[ 795.9047 ]
[ 795.9057 ] tegradevflash_v2 --write BCT br_bct_BR.bct
[ 795.9064 ] Bootloader version 01.00.0000
[ 797.9168 ] Writing partition BCT with br_bct_BR.bct [ 8192 bytes ]
[ 797.9170 ] […] 100%
[ 798.1256 ]
[ 798.1276 ] tegradevflash_v2 --write A_MB1_BCT mb1_cold_boot_bct_MB1_sigheader.bct.encrypt
[ 798.1283 ] Bootloader version 01.00.0000
[ 798.8693 ] Writing partition A_MB1_BCT with mb1_cold_boot_bct_MB1_sigheader.bct.encrypt [ 18128 bytes ]
[ 798.8697 ] […] 100%
[ 799.1045 ]
[ 799.1055 ] tegradevflash_v2 --write B_MB1_BCT mb1_cold_boot_bct_MB1_sigheader.bct.encrypt
[ 799.1063 ] Bootloader version 01.00.0000
[ 799.8415 ] Writing partition B_MB1_BCT with mb1_cold_boot_bct_MB1_sigheader.bct.encrypt [ 18128 bytes ]
[ 799.8418 ] […] 100%
[ 800.0772 ]
[ 800.0789 ] tegradevflash_v2 --write A_MEM_BCT mem_coldboot_sigheader.bct.encrypt
[ 800.0798 ] Bootloader version 01.00.0000
[ 800.8214 ] Writing partition A_MEM_BCT with mem_coldboot_sigheader.bct.encrypt [ 243712 bytes ]
[ 800.8217 ] […] 100%
[ 803.8221 ]
[ 803.8229 ] tegradevflash_v2 --write B_MEM_BCT mem_coldboot_sigheader.bct.encrypt
[ 803.8237 ] Bootloader version 01.00.0000
[ 804.3541 ] Writing partition B_MEM_BCT with mem_coldboot_sigheader.bct.encrypt [ 243712 bytes ]
[ 804.3553 ] […] 100%
[ 807.3552 ]
[ 807.3553 ] Flashing completed
[ 807.3553 ] Coldbooting the device
[ 807.3563 ] tegrarcm_v2 --chip 0x23 --ismb2
[ 807.3570 ] MB2 version 01.00.0000
[ 807.8892 ]
[ 807.8893 ] Coldbooting the device
[ 807.8902 ] tegrarcm_v2 --chip 0x23 --reboot coldboot
[ 807.8910 ] MB2 version 01.00.0000
[ 808.4262 ]
*** The target t186ref has been flashed successfully. ***
Reset the board to boot from internal eMMC.
I should add that I am connected via Display Port - which was working on the version of the OS that shipped on the Orin dev kit prior to me attempting to flash the device.
Please open /dev/ttyACM0 on your host to check if the board is able to boot.
This is UART log as old platofrm (TX2/NX/Nano). The hardware port is the usb flash port.
Could you please tell me the commands to enter?
ok… 7th or 8th time of trying, it worked. only difference this time is I left it on the setting where you pre-enter username and password. n previous attempts I had been selecting the ‘run time’ option, which sounded similar to the previous systems where the user would have to enter a username and password on first boot.
Looks like it works now, but just FYI on serial console setup (the part of opening “/dev/ttyACM0”), you’d connect the micro-B USB cable from Jetson to host PC, and then use a serial console program (such as gtkterm or minicom or PuTTYy) with settings:
  • speed 115200
  • 8-bit
  • No stop bit
  • 1 parity
  • Shorthand: 115200 8N1
Thanks for the info, yes issue is resolved. The problem was selecting the ‘run time’ option during the flashing instead of the default currently gives you a dead device until you flash it again and select the option where you pre enter the username and password for the OS
