Cannot flash the Jetson AGX Orin using eMMC or Micro-SD card for JetPack 6.0 revision 2
When I try to flash the 36.3 (JetPack 6.0 rev 2) using a formatted MicroSD card (ext4), after putting Jetson in recovery mode, I get this error:
When I try doing it using SDK Manager, I get timeout error too. The OS screen never shows up/never boots up.
Further, when I use “internal/eMMC”, the flash is successful but it doesn’t boot up to it.
Could you please help with this inquiry?
I formatted my SD card using Disk utility in Ubuntu 22.04 (host machine).
Everytime I am going to recovery mode, I see:
(base) mona@DOS:~/Linux_for_Tegra$ lsusb
Bus 003 Device 046: ID 0955:7223 NVIDIA Corp. APX
Also, when I used SDK Manager, here is the setup
(base) mona@DOS:~/Linux_for_Tegra$ sudo ./flash.sh jetson-agx-orin-devkit internal
[ 775.1809 ] Writing partition BCT-boot-chain_backup with bct_backup.img [ 32768 bytes ]
[ 775.1815 ] [................................................] 100%
[ 775.5975 ] tegradevflash_v2 --write A_MB1_BCT mb1_cold_boot_bct_MB1_sigheader.bct.encrypt
[ 775.5977 ] Bootloader version 01.00.0000
[ 775.6275 ] Writing partition A_MB1_BCT with mb1_cold_boot_bct_MB1_sigheader.bct.encrypt [ 18432 bytes ]
[ 775.6277 ] [................................................] 100%
[ 775.8640 ] tegradevflash_v2 --write B_MB1_BCT mb1_cold_boot_bct_MB1_sigheader.bct.encrypt
[ 775.8644 ] Bootloader version 01.00.0000
[ 775.8926 ] Writing partition B_MB1_BCT with mb1_cold_boot_bct_MB1_sigheader.bct.encrypt [ 18432 bytes ]
[ 775.8927 ] [................................................] 100%
[ 776.1305 ] tegradevflash_v2 --write A_MEM_BCT mem_coldboot_sigheader.bct.encrypt
[ 776.1307 ] Bootloader version 01.00.0000
[ 776.1604 ] Writing partition A_MEM_BCT with mem_coldboot_sigheader.bct.encrypt [ 243712 bytes ]
[ 776.1606 ] [................................................] 100%
[ 779.2096 ] tegradevflash_v2 --write B_MEM_BCT mem_coldboot_sigheader.bct.encrypt
[ 779.2098 ] Bootloader version 01.00.0000
[ 779.2404 ] Writing partition B_MEM_BCT with mem_coldboot_sigheader.bct.encrypt [ 243712 bytes ]
[ 779.2406 ] [................................................] 100%
[ 782.2894 ] Flashing completed
[ 782.2895 ] Coldbooting the device
[ 782.2904 ] tegrarcm_v2 --chip 0x23 0 --ismb2
[ 782.2911 ] MB2 version 01.00.0000
[ 782.3213 ] Coldbooting the device
[ 782.3221 ] tegrarcm_v2 --chip 0x23 0 --reboot coldboot
[ 782.3228 ] MB2 version 01.00.0000
*** The target generic has been flashed successfully. ***
Reset the board to boot from internal eMMC.
(base) mona@DOS:~/Linux_for_Tegra$ sudo chmod 646 /sys/module/usbcore/parameters/autosuspend
(base) mona@DOS:~/Linux_for_Tegra$ ls -l /sys/module/usbcore/parameters/autosuspend
-rw-r--rw- 1 root root 4.0K Jul  9 14:45 /sys/module/usbcore/parameters/autosuspend
(base) mona@DOS:~/Linux_for_Tegra$ sudo  -s echo -1 > /sys/module/usbcore/parameters/autosuspend
(base) mona@DOS:~/Linux_for_Tegra$ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device mmcblk0p1   -c tools/kernel_flash/flash_l4t_t234_nvme.xml   --showlogs --network usb0 jetson-agx-orin-devkit external
*** no-flash flag enabled. Exiting now... ***
User can run above saved command in factory environment without
providing pkc and sbk keys to flash a device
Example:
    $ cd bootloader
    $ sudo bash ./flashcmd.txt
Save initrd flashing command parameters to /home/mona/Linux_for_Tegra/tools/kernel_flash/initrdflashparam.txt
/tmp/tmp.Xq8BjQhjNW /home/mona/Linux_for_Tegra
writing boot image config in bootimg.cfg
extracting kernel in zImage
extracting ramdisk in initrd.img
/tmp/tmp.Xq8BjQhjNW/initrd /tmp/tmp.Xq8BjQhjNW /home/mona/Linux_for_Tegra
77459 blocks
130266 blocks
flashimg0=boot0.img
Success
Cleaning up...
Finish generating flash package.
/home/mona/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh --network usb0 --usb-instance 3-1 --device-instance 0 --flash-only --external-device mmcblk0p1 -c "tools/kernel_flash/flash_l4t_t234_nvme.xml" --network usb0 jetson-agx-orin-devkit external
# Entry added by NVIDIA initrd flash tool
/home/mona/Linux_for_Tegra/tools/kernel_flash/tmp 127.0.0.1(rw,nohide,insecure,no_subtree_check,async,no_root_squash)
Export list for localhost:
*  Step 1: Build the flashing environment    *
Create flash environment 0
/home/mona/Linux_for_Tegra/bootloader /home/mona/Linux_for_Tegra
Finish creating flash environment 0.
*  Step 2: Boot the device with flash initrd image *
/home/mona/Linux_for_Tegra/temp_initrdflash/bootloader0 /home/mona/Linux_for_Tegra
./tegraflash.py --bl uefi_jetson_with_dtb_sigheader.bin.encrypt --bct br_bct_BR.bct --securedev  --bldtb tegra234-p3737-0000+p3701-0004-nv.dtb --applet rcm_2_encrypt.rcm --applet_softfuse rcm_1_encrypt.rcm --cmd "rcmboot"  --cfg secureflash.xml --chip 0x23 --mb1_bct mb1_bct_MB1_sigheader.bct.encrypt --mem_bct mem_rcm_sigheader.bct.encrypt --mb1_cold_boot_bct mb1_cold_boot_bct_MB1_sigheader.bct.encrypt --mb1_bin mb1_t234_prod_aligned_sigheader.bin.encrypt --psc_bl1_bin psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --mem_bct_cold_boot mem_coldboot_sigheader.bct.encrypt  --bins "psc_fw pscfw_t234_prod_sigheader.bin.encrypt; mts_mce mce_flash_o10_cr_prod_sigheader.bin.encrypt; tsec_fw tsec_t234_sigheader.bin.encrypt; mb2_applet applet_t234_sigheader.bin.encrypt; mb2_bootloader mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt; xusb_fw xusb_t234_prod_sigheader.bin.encrypt; pva_fw nvpva_020_sigheader.fw.encrypt; dce_fw display-t234-dce_sigheader.bin.encrypt; nvdec nvdec_t234_prod_sigheader.fw.encrypt; bpmp_fw bpmp_t234-TE990M-A1_prod_sigheader.bin.encrypt; bpmp_fw_dtb tegra234-bpmp-3701-0004-3737-0000_with_odm_sigheader.dtb.encrypt; rce_fw camera-rtcpu-t234-rce_sigheader.img.encrypt; ape_fw adsp-fw_sigheader.bin.encrypt; spe_fw spe_t234_sigheader.bin.encrypt; tos tos-optee_t234_sigheader.img.encrypt; eks eks_t234_sigheader.img.encrypt; kernel boot0.img; kernel_dtb tegra234-p3737-0000+p3701-0004-nv.dtb"    --bct_backup  --instance 3-1
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
 Entering RCM boot
[   0.0289 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from --mb1_bin
[   0.0289 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from --psc_bl1_bin
[   0.0289 ] rcm boot with presigned binaries
[   0.0291 ] tegrarcm_v2 --instance 3-1 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[   0.0294 ] BR_CID: 0x80012344705DD7972C00000015FF8040
[   0.0400 ] Sending bct_br
[   0.0490 ] Sending mb1
[   0.0494 ] Sending psc_bl1
[   0.0606 ] Sending bct_mb1
[   0.0668 ] Generating blob for T23x
[   0.0678 ] tegrahost_v2 --chip 0x23 0 --generateblob blob.xml blob.bin
[   0.0680 ] The number of images in blob is 19
[   0.0682 ] blobsize is 96718389
[   0.0683 ] Added binary blob_uefi_jetson_with_dtb_sigheader.bin.encrypt of size 3657792
[   0.0972 ] Added binary blob_pscfw_t234_prod_sigheader.bin.encrypt of size 310768
[   0.0975 ] Added binary blob_mce_flash_o10_cr_prod_sigheader.bin.encrypt of size 187120
[   0.0977 ] Added binary blob_tsec_t234_sigheader.bin.encrypt of size 176128
[   0.0979 ] Added binary blob_applet_t234_sigheader.bin.encrypt of size 279616
[   0.0981 ] Not supported type: mb2_applet
[   0.0981 ] Added binary blob_mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt of size 439968
[   0.0984 ] Added binary blob_xusb_t234_prod_sigheader.bin.encrypt of size 164864
[   0.0985 ] Added binary blob_nvpva_020_sigheader.fw.encrypt of size 2164640
[   0.0991 ] Added binary blob_display-t234-dce_sigheader.bin.encrypt of size 12070512
[   0.1044 ] Added binary blob_nvdec_t234_prod_sigheader.fw.encrypt of size 294912
[   0.1061 ] Added binary blob_bpmp_t234-TE990M-A1_prod_sigheader.bin.encrypt of size 1027008
[   0.1066 ] Added binary blob_tegra234-bpmp-3701-0004-3737-0000_with_odm_sigheader.dtb.encrypt of size 384768
[   0.1068 ] Added binary blob_camera-rtcpu-t234-rce_sigheader.img.encrypt of size 458096
[   0.1070 ] Added binary blob_adsp-fw_sigheader.bin.encrypt of size 414960
[   0.1072 ] Added binary blob_spe_t234_sigheader.bin.encrypt of size 270336
[   0.1073 ] Added binary blob_tos-optee_t234_sigheader.img.encrypt of size 1633344
[   0.1077 ] Added binary blob_eks_t234_sigheader.img.encrypt of size 9232
[   0.1079 ] Added binary blob_boot0.img of size 72523776
[   0.1384 ] Added binary blob_tegra234-p3737-0000+p3701-0004-nv.dtb of size 249445
[   0.1928 ] tegrarcm_v2 --instance 3-1 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
[   0.1930 ] BL: version 1.4.0.2-t234-54845784-08a4de08 last_boot_error: 0
[   0.3365 ] Sending bct_mem
[   0.3610 ] Sending blob
[   5.4225 ] RCM-boot started
*  Step 3: Start the flashing process *
Waiting for target to boot-up...
Timeout
Device failed to boot to the initrd flash kernel. Please retrive the serial log during flashing to debug further.
Cleaning up...
You should first make sure you are using a DevKit, or the device is unable to be flashed with SDKM.
Also, you should be running:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device mmcblk1p1 \
  -c tools/kernel_flash/flash_l4t_t234_nvme.xml -p "-c bootloader/generic/cfg/flash_t234_qspi.xml" \
  --showlogs --network usb0 jetson-agx-orin-devkit internal
I don’t know why you think --external-device nvme0n1p1 is going to work…
Hi Dave, thanks for bringing that mistake to my attention and your time going through my issue. I removed it from the post so we can focus on the actual problem. Our board is a AAEON AGX ORIN BOXER (I don’t know the boxer number but it is 32GB).
I have contacted AAEON via various forms of communications but didn’t hear back.
Is the error before something that there’s a fix from it on NVIDIA side?
Board ID(3701) version(500) sku(0004) revision(F.0)
Chip SKU(00:00:00:D2) ramcode(00:00:00:00) fuselevel(fuselevel_production) board_FAB(500)
Copy /home/mona/Linux_for_Tegra/kernel/dtb/tegra234-p3737-0000+p3701-0004-nv.dtb to /home/mona/Linux_for_Tegra/kernel/dtb/tegra234-p3737-0000+p3701-0004-nv.dtb.rec
copying bctfile(/home/mona/Linux_for_Tegra/bootloader/generic/BCT/tegra234-p3701-0000-sdram-l4t.dts)... done.
copying minratchet_config(/home/mona/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-ratchet-p3701-0000.dts)... done.
copying device_config(/home/mona/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-device-p3701-0000.dts)... done.
copying misc_config(/home/mona/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-misc-p3701-0000.dts)... done.
copying pinmux_config(/home/mona/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-pinmux-p3701-0000-a04.dtsi)... done.
copying gpioint_config(/home/mona/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-gpioint-p3701-0000.dts)... done.
copying pmic_config(/home/mona/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-pmic-p3701-0005.dts)... done.
copying pmc_config(/home/mona/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-padvoltage-p3701-0000-a04.dtsi)... done.
copying deviceprod_config(/home/mona/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-cprod-p3701-0000.dts)... done.
copying prod_config(/home/mona/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-prod-p3701-0000.dts)... done.
copying scr_config(/home/mona/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb2-bct-scr-p3701-0000.dts)... done.
copying wb0sdram(/home/mona/Linux_for_Tegra/bootloader/generic/BCT/tegra234-p3701-0000-wb0sdram-l4t.dts)... done.
copying bootrom_config(/home/mona/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-reset-p3701-0000.dts)... done.
Existing uphylane_config(/home/mona/Linux_for_Tegra/bootloader/tegra234-mb1-bct-uphylane-si.dtsi) reused.
copying dev_params(/home/mona/Linux_for_Tegra/bootloader/generic/BCT/tegra234-br-bct-p3701-0000.dts)... done.
copying dev_params_b(/home/mona/Linux_for_Tegra/bootloader/generic/BCT/tegra234-br-bct_b-p3701-0000.dts)... done.
copying mb2bct_cfg(/home/mona/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb2-bct-misc-p3701-0000.dts)... done.
Existing pscfwfile(/home/mona/Linux_for_Tegra/bootloader/pscfw_t234_prod.bin) reused.
Existing pscbl1file(/home/mona/Linux_for_Tegra/bootloader/psc_bl1_t234_prod.bin) reused.
Existing mtsmcefile(/home/mona/Linux_for_Tegra/bootloader/mce_flash_o10_cr_prod.bin) reused.
Existing tscfwfile(/home/mona/Linux_for_Tegra/bootloader/tsec_t234.bin) reused.
Existing mb2applet(/home/mona/Linux_for_Tegra/bootloader/applet_t234.bin) reused.
Existing bootloader(/home/mona/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
copying initrd(/home/mona/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
bl is uefi
Making Boot image... done.
Not signing of boot.img
Making recovery ramdisk for recovery image...
Re-generating recovery ramdisk for recovery image...
/home/mona/Linux_for_Tegra/bootloader/ramdisk_tmp /home/mona/Linux_for_Tegra/bootloader /home/mona/Linux_for_Tegra
53899 blocks
gzip: /home/mona/Linux_for_Tegra/kernel/Image: not in gzip format
_BASE_KERNEL_VERSION=5.15.136-tegra
77459 blocks
Making Recovery image...
copying recdtbfile(/home/mona/Linux_for_Tegra/kernel/dtb/tegra234-p3737-0000+p3701-0004-nv.dtb.rec)... done.
20+0 records in
20+0 records out
20 bytes copied, 0.00013088 s, 153 kB/s
Existing sosfile(/home/mona/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
Existing tegraboot(/home/mona/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing cpu_bootloader(/home/mona/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing mb2blfile(/home/mona/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing xusbfile(/home/mona/Linux_for_Tegra/bootloader/xusb_t234_prod.bin) reused.
Existing pvafile(/home/mona/Linux_for_Tegra/bootloader/nvpva_020.fw) reused.
Existing dcefile(/home/mona/Linux_for_Tegra/bootloader/display-t234-dce.bin) reused.
Existing nvdecfile(/home/mona/Linux_for_Tegra/bootloader/nvdec_t234_prod.fw) reused.
Existing psc_rf(/home/mona/Linux_for_Tegra/bootloader/psc_rf_t234_prod.bin) reused.
Existing mb2_rf(/home/mona/Linux_for_Tegra/bootloader/mb2rf_t234.bin) reused.
Existing mb1file(/home/mona/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
Existing bpffile(/home/mona/Linux_for_Tegra/bootloader/bpmp_t234-TE990M-A1_prod.bin) reused.
copying bpfdtbfile(/home/mona/Linux_for_Tegra/bootloader/generic/tegra234-bpmp-3701-0004-3737-0000.dtb)... done.
Existing camerafw(/home/mona/Linux_for_Tegra/bootloader/camera-rtcpu-t234-rce.img) reused.
Existing apefile(/home/mona/Linux_for_Tegra/bootloader/adsp-fw.bin) reused.
Existing spefile(/home/mona/Linux_for_Tegra/bootloader/spe_t234.bin) reused.
Existing wb0boot(/home/mona/Linux_for_Tegra/bootloader/sc7_t234_prod.bin) reused.
Existing tosfile(/home/mona/Linux_for_Tegra/bootloader/tos-optee_t234.img) reused.
Existing eksfile(/home/mona/Linux_for_Tegra/bootloader/eks_t234.img) reused.
copying dtbfile(/home/mona/Linux_for_Tegra/kernel/dtb/tegra234-p3737-0000+p3701-0004-nv.dtb)... done.
Copying nv_boot_control.conf to rootfs
Skip generating system.img
Not signing of kernel-dtb
Existing tbcfile(/home/mona/Linux_for_Tegra/bootloader/uefi_jetson.bin) reused.
131072+0 records in
131072+0 records out
67108864 bytes (67 MB, 64 MiB) copied, 0.145158 s, 462 MB/s
	Sync'ing esp.img ... done.
copying tbcdtbfile(/home/mona/Linux_for_Tegra/kernel/dtb/tegra234-p3737-0000+p3701-0004-nv.dtb)... done.
copying cfgfile(/home/mona/Linux_for_Tegra/bootloader/generic/cfg/flash_t234_qspi_sdmmc.xml) to flash.xml... done.
Existing flashapp(/home/mona/Linux_for_Tegra/bootloader/tegraflash.py) reused.
copying overlay_dtb(/home/mona/Linux_for_Tegra/kernel/dtb/L4TConfiguration.dtbo)... done.
copying overlay_dtb(/home/mona/Linux_for_Tegra/kernel/dtb/tegra234-p3737-0000+p3701-0000-dynamic.dtbo)... done.
copying overlay_dtb(/home/mona/Linux_for_Tegra/kernel/dtb/tegra234-carveouts.dtbo)... done.
copying overlay_dtb(/home/mona/Linux_for_Tegra/kernel/dtb/tegra-optee.dtbo)... done.
copying overlay_dtb(/home/mona/Linux_for_Tegra/kernel/dtb/tegra234-p3737-camera-dual-imx274-overlay.dtbo)... done.
copying overlay_dtb(/home/mona/Linux_for_Tegra/kernel/dtb/tegra234-p3737-camera-e3331-overlay.dtbo)... done.
copying overlay_dtb(/home/mona/Linux_for_Tegra/kernel/dtb/tegra234-p3737-camera-e3333-overlay.dtbo)... done.
copying overlay_dtb(/home/mona/Linux_for_Tegra/kernel/dtb/tegra234-p3737-camera-imx185-overlay.dtbo)... done.
/home/mona/Linux_for_Tegra/bootloader/L4TConfiguration_updated.dts: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
/home/mona/Linux_for_Tegra/bootloader/L4TConfiguration.dtbo: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
./tegraflash.py --bl uefi_jetson_with_dtb.bin --odmdata gbe-uphy-config-22,hsstp-lane-map-3,nvhs-uphy-config-0,hsio-uphy-config-0,gbe0-enable-10g --overlay_dtb L4TConfiguration.dtbo,tegra234-p3737-0000+p3701-0000-dynamic.dtbo,tegra234-carveouts.dtbo,tegra-optee.dtbo,tegra234-p3737-camera-dual-imx274-overlay.dtbo,tegra234-p3737-camera-e3331-overlay.dtbo,tegra234-p3737-camera-e3333-overlay.dtbo,tegra234-p3737-camera-imx185-overlay.dtbo, --bldtb tegra234-p3737-0000+p3701-0004-nv.dtb --applet mb1_t234_prod.bin --cmd "sign" --cfg flash.xml --chip "0x23" --concat_cpubl_bldtb --cpubl uefi_jetson.bin --minratchet_config tegra234-mb1-bct-ratchet-p3701-0000.dts --device_config tegra234-mb1-bct-device-p3701-0000.dts --misc_config tegra234-mb1-bct-misc-p3701-0000.dts --pinmux_config tegra234-mb1-bct-pinmux-p3701-0000-a04.dtsi --gpioint_config tegra234-mb1-bct-gpioint-p3701-0000.dts --pmic_config tegra234-mb1-bct-pmic-p3701-0005.dts --pmc_config tegra234-mb1-bct-padvoltage-p3701-0000-a04.dtsi --deviceprod_config tegra234-mb1-bct-cprod-p3701-0000.dts --prod_config tegra234-mb1-bct-prod-p3701-0000.dts --scr_config tegra234-mb2-bct-scr-p3701-0000.dts --wb0sdram_config tegra234-p3701-0000-wb0sdram-l4t.dts --br_cmd_config tegra234-mb1-bct-reset-p3701-0000.dts --uphy tegra234-mb1-bct-uphylane-si.dtsi --dev_params tegra234-br-bct-p3701-0000.dts,tegra234-br-bct_b-p3701-0000.dts --mb2bct_cfg tegra234-mb2-bct-misc-p3701-0000.dts --bins "psc_fw pscfw_t234_prod.bin; mts_mce mce_flash_o10_cr_prod.bin; tsec_fw tsec_t234.bin; mb2_applet applet_t234.bin; mb2_bootloader mb2_t234.bin; xusb_fw xusb_t234_prod.bin; pva_fw nvpva_020.fw; dce_fw display-t234-dce.bin; nvdec nvdec_t234_prod.fw; bpmp_fw bpmp_t234-TE990M-A1_prod.bin; bpmp_fw_dtb tegra234-bpmp-3701-0004-3737-0000.dtb; rce_fw camera-rtcpu-t234-rce.img; ape_fw adsp-fw.bin; spe_fw spe_t234.bin; tos tos-optee_t234.img; eks eks_t234.img; kernel boot.img; kernel_dtb tegra234-p3737-0000+p3701-0004-nv.dtb" --sdram_config tegra234-p3701-0000-sdram-l4t.dts --cust_info custinfo_out.bin --bct_backup --boot_chain A
version 1.0.0
[   0.0153 ] tegrasign_v3.py --key None --getmode mode.txt
[   0.0153 ] Assuming zero filled SBK key
[   0.0148 ] Parsing partition layout
[   0.0151 ] tegraparser_v2 --pt flash.xml.tmp
[   0.0188 ] Change tegra234-bpmp-3701-0004-3737-0000.dtb to tegra234-bpmp-3701-0004-3737-0000_with_odm.dtb
[   0.0189 ] Change tegra234-bpmp-3701-0004-3737-0000.dtb to tegra234-bpmp-3701-0004-3737-0000_with_odm.dtb
[   0.0669 ] /usr/bin/python3 dtbcheck.py -c t234 -o tegra234-bpmp-3701-0004-3737-0000_with_odm.dtb tegra234-bpmp-3701-0004-3737-0000_with_odm_tmp.dtb
[   0.2530 ] Concatenating L4TConfiguration.dtbo,tegra234-p3737-0000+p3701-0000-dynamic.dtbo,tegra234-carveouts.dtbo,tegra-optee.dtbo,tegra234-p3737-camera-dual-imx274-overlay.dtbo,tegra234-p3737-camera-e3331-overlay.dtbo,tegra234-p3737-camera-e3333-overlay.dtbo,tegra234-p3737-camera-imx185-overlay.dtbo to tegra234-p3737-0000+p3701-0004-nv_with_odm_overlay.dtb.updated
[   0.2532 ] Concatenating bl dtb to cpubl binary
[   0.2556 ] MB2 binary: mb2_t234.bin
[   0.2556 ] Pre-processing mb2bct config: tegra234-mb2-bct-misc-p3701-0000.dts
[   0.2650 ] Pre-processing mb2bct config: tegra234-mb2-bct-scr-p3701-0000.dts
[   0.5303 ] Generating coldboot mb2-bct
[   0.5303 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_cold_boot_bct.cfg --mb2bctcfg tegra234-mb2-bct-misc-p3701-0000_cpp.dtb --scr tegra234-mb2-bct-scr-p3701-0000_cpp.dtb
[   0.5307 ] ERROR: value 0x31 is out of range
[   0.5319 ] ERROR: value 0x31 is out of range
[   0.5321 ] ERROR: value 0x31 is out of range
[   0.5323 ] ERROR: value 0x31 is out of range
[   0.5325 ] WARNING: unknown property 'tfc_version'
[   0.5327 ] WARNING: unknown property 'addr_header_version'
[   0.5400 ] Updating mb2-bct with storage information
[   0.5403 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_cold_boot_bct_MB2.bct --updatestorageinfo flash.xml.bin
[   0.5496 ] Concatenating mb2-bct to mb2 binary
[   0.5496 ] mb2_bin_file = mb2_t234.bin
[   0.5496 ] mb2_bct_file = mb2_cold_boot_bct_MB2.bct
[   0.5519 ] DCE binary: display-t234-dce.bin
[   0.5520 ] Kernel DTB used: kernel_tegra234-p3737-0000+p3701-0004-nv.dtb
[   0.5520 ] Concatenating kernel-dtb to dce-fw binary
[   0.5520 ] dce_bin = display-t234-dce.bin
[   0.5520 ] kernel_dtb = kernel_tegra234-p3737-0000+p3701-0004-nv.dtb
[   0.5520 ] dce_with_dtb = display-t234-dce_with_kernel_tegra234-p3737-0000+p3701-0004-nv.bin
[   0.5573 ] Update display-t234-dce_with_kernel_tegra234-p3737-0000+p3701-0004-nv.bin to dce_fw partitions
[   0.5593 ] Parsing partition layout
[   0.5597 ] tegraparser_v2 --pt flash.xml.tmp
[   0.5607 ] Creating list of images to be signed
[   0.5609 ] Generating ratchet blob
[   0.5610 ] Pre-processing config: tegra234-mb1-bct-reset-p3701-0000.dts
[   0.5658 ] Pre-processing config: tegra234-mb1-bct-device-p3701-0000.dts
[   0.5709 ] Pre-processing config: tegra234-mb1-bct-cprod-p3701-0000.dts
[   0.5765 ] Pre-processing config: tegra234-mb1-bct-gpioint-p3701-0000.dts
[   0.5817 ] Pre-processing config: tegra234-mb1-bct-misc-p3701-0000.dts
[   0.5886 ] Pre-processing config: tegra234-mb1-bct-pinmux-p3701-0000-a04.dtsi
[   0.5982 ] Pre-processing config: tegra234-mb1-bct-padvoltage-p3701-0000-a04.dtsi
[   0.6032 ] Pre-processing config: tegra234-mb1-bct-pmic-p3701-0005.dts
[   0.6091 ] Pre-processing config: tegra234-mb1-bct-prod-p3701-0000.dts
[   0.6138 ] Pre-processing config: tegra234-p3701-0000-sdram-l4t.dts
[   2.0008 ] Pre-processing config: tegra234-mb1-bct-uphylane-si.dtsi
[   2.0057 ] Pre-processing config: tegra234-p3701-0000-wb0sdram-l4t.dts
[   3.4225 ] Pre-processing config: tegra234-mb1-bct-ratchet-p3701-0000.dts
[   3.4295 ] Generating coldboot mb1-bct
[   3.4297 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --wb0sdram tegra234-p3701-0000-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3701-0000-a04_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3701-0000-a04_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3701-0005_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3701-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3701-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3701-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3701-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3701-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[   3.4299 ] MB1-BCT version: 0.13
[   3.4314 ] Parsing config file :tegra234-mb1-bct-pinmux-p3701-0000-a04_cpp.dtb
[   3.4316 ] Added Platform Config 0 data with size :- 2936
[   3.4336 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3701-0000-a04_cpp.dtb
[   3.4338 ] WARNING: unknown node 'g2'
[   3.4340 ] WARNING: unknown node 'g2'
[   3.4340 ] WARNING: unknown node 'g9'
[   3.4340 ] Added Platform Config 2 data with size :- 24
[   3.4340 ]
[   3.4340 ] Parsing config file :tegra234-mb1-bct-pmic-p3701-0005_cpp.dtb
[   3.4340 ] Added Platform Config 4 data with size :- 580
[   3.4340 ]
[   3.4340 ] Parsing config file :tegra234-mb1-bct-reset-p3701-0000_cpp.dtb
[   3.4340 ] Added Platform Config 3 data with size :- 52
[   3.4340 ]
[   3.4340 ] Parsing config file :tegra234-mb1-bct-prod-p3701-0000_cpp.dtb
[   3.4340 ] WARNING: unknown property 'major'
[   3.4340 ] WARNING: unknown property 'minor'
[   3.4340 ] Added Platform Config 5 data with size :- 524
[   3.4340 ]
[   3.4340 ] Parsing config file :tegra234-mb1-bct-gpioint-p3701-0000_cpp.dtb
[   3.4340 ] Added Platform Config 7 data with size :- 380
[   3.4340 ]
[   3.4340 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[   3.4340 ] Added Platform Config 8 data with size :- 24
[   3.4340 ]
[   3.4340 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   3.4340 ] Added Platform Config 9 data with size :- 100
[   3.4340 ]
[   3.4340 ] Parsing config file :tegra234-mb1-bct-cprod-p3701-0000_cpp.dtb
[   3.4340 ] ModuleCount 0 NumProdNames 0
[   3.4340 ] Added Platform Config 6 data with size :- 16
[   3.4340 ]
[   3.4340 ] Parsing config file :tegra234-mb1-bct-ratchet-p3701-0000_cpp.dtb
[   3.4341 ]
[   3.4341 ] Updating mb1-bct with firmware information
[   3.4343 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[   3.4441 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[   3.4444 ] Generating SHA2 Hash for mb1bct
[   3.4458 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[   3.4466 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[   3.4463 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   3.4465 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   3.4479 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   3.4480 ] Assuming zero filled SBK key
[   3.4487 ] Warning: pub_key.key is not found
[   3.4482 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   3.4488 ] tegrahost_v2 --chip 0x23 0 --partitionlayout flash.xml.bin --ratchet_blob ratchet_blob.bin --list images_list.xml zerosbk
[   3.4490 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   3.4498 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   3.4500 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   3.4534 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   3.4536 ] Header already present for tsec_t234_aligned.bin
[   3.4551 ] Header already present for nvdec_t234_prod_aligned.fw
[   3.4579 ] adding BCH for mb2_t234_with_mb2_cold_boot_bct_MB2_aligned.bin
[   3.4618 ] adding BCH for xusb_t234_prod_aligned.bin
[   3.4723 ] Header already present for bpmp_t234-TE990M-A1_prod_aligned.bin
[   3.4774 ] adding BCH for tegra234-bpmp-3701-0004-3737-0000_with_odm_aligned.dtb
[   3.4892 ] Header already present for pscfw_t234_prod_aligned.bin
[   3.4987 ] Header already present for mce_flash_o10_cr_prod_aligned.bin
[   3.5025 ] Header already present for sc7_t234_prod.bin
[   3.5045 ] Header already present for psc_rf_t234_prod_aligned.bin
[   3.5074 ] adding BCH for mb2rf_t234_aligned.bin
[   3.5088 ] INFO: compressing uefi_jetson_with_dtb_aligned.bin
[   3.5558 ] INFO: complete compression, uefi_jetson_with_dtb_aligned.bin, ratio = 89%
[   3.5609 ] adding BCH for uefi_jetson_with_dtb_aligned_blob_w_bin_aligned.bin
[   3.6013 ] adding BCH for tos-optee_t234_aligned.img
[   3.6413 ] adding BCH for eks_t234_aligned.img
[   3.6781 ] INFO: compressing display-t234-dce_with_kernel_tegra234-p3737-0000+p3701-0004-nv_aligned.bin
[   3.8259 ] INFO: complete compression, display-t234-dce_with_kernel_tegra234-p3737-0000+p3701-0004-nv_aligned.bin, ratio = 6%
[   3.8419 ] adding BCH for display-t234-dce_with_kernel_tegra234-p3737-0000+p3701-0004-nv_aligned_blob_w_bin_aligned.bin
[   3.8560 ] adding BCH for spe_t234_aligned.bin
[   3.8650 ] adding BCH for camera-rtcpu-t234-rce_aligned.img
[   3.8733 ] adding BCH for adsp-fw_aligned.bin
[   3.8839 ] INFO: compressing nvpva_020_aligned.fw
[   3.9193 ] INFO: complete compression, nvpva_020_aligned.fw, ratio = 2%
[   3.9216 ] adding BCH for nvpva_020_aligned_blob_w_bin_aligned.fw
[   3.9227 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   3.9240 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   3.9242 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   3.9329 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   3.9331 ] Header already present for tsec_t234_aligned.bin
[   3.9347 ] Header already present for nvdec_t234_prod_aligned.fw
[   3.9371 ] adding BCH for mb2_t234_with_mb2_cold_boot_bct_MB2_aligned.bin
[   3.9409 ] adding BCH for xusb_t234_prod_aligned.bin
[   3.9511 ] Header already present for bpmp_t234-TE990M-A1_prod_aligned.bin
[   3.9561 ] adding BCH for tegra234-bpmp-3701-0004-3737-0000_with_odm_aligned.dtb
[   3.9688 ] Header already present for pscfw_t234_prod_aligned.bin
[   3.9777 ] Header already present for mce_flash_o10_cr_prod_aligned.bin
[   3.9817 ] Header already present for sc7_t234_prod.bin
[   3.9835 ] Header already present for psc_rf_t234_prod_aligned.bin
[   3.9860 ] adding BCH for mb2rf_t234_aligned.bin
[   3.9876 ] INFO: compressing uefi_jetson_with_dtb_aligned.bin
[   4.0350 ] INFO: complete compression, uefi_jetson_with_dtb_aligned.bin, ratio = 89%
[   4.0399 ] adding BCH for uefi_jetson_with_dtb_aligned_blob_w_bin_aligned.bin
[   4.0841 ] adding BCH for tos-optee_t234_aligned.img
[   4.1278 ] adding BCH for eks_t234_aligned.img
[   4.1662 ] INFO: compressing display-t234-dce_with_kernel_tegra234-p3737-0000+p3701-0004-nv_aligned.bin
[   4.3146 ] INFO: complete compression, display-t234-dce_with_kernel_tegra234-p3737-0000+p3701-0004-nv_aligned.bin, ratio = 6%
[   4.3305 ] adding BCH for display-t234-dce_with_kernel_tegra234-p3737-0000+p3701-0004-nv_aligned_blob_w_bin_aligned.bin
[   4.3443 ] adding BCH for spe_t234_aligned.bin
[   4.3533 ] adding BCH for camera-rtcpu-t234-rce_aligned.img
[   4.3598 ] adding BCH for adsp-fw_aligned.bin
[   4.3703 ] INFO: compressing nvpva_020_aligned.fw
[   4.4050 ] INFO: complete compression, nvpva_020_aligned.fw, ratio = 2%
[   4.4071 ] adding BCH for nvpva_020_aligned_blob_w_bin_aligned.fw
[   4.4093 ] Filling MB1 storage info
[   4.4093 ] Parsing dev params for multi chains
[   4.4142 ] Generating br-bct
[   4.4144 ] Updating dev and MSS params in BR BCT
[   4.4145 ] tegrabct_v2 --dev_param tegra234-br-bct-p3701-0000_cpp.dtb --sdram tegra234-p3701-0000-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   4.4864 ] Updating bl info
[   4.4869 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin
[   4.4932 ] Generating br-bct
[   4.4938 ] Updating dev and MSS params in BR BCT
[   4.4939 ] tegrabct_v2 --dev_param tegra234-br-bct_b-p3701-0000_cpp.dtb --sdram tegra234-p3701-0000-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   4.5658 ] Updating bl info
[   4.5662 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin
[   4.5673 ] Generating BCT backup image
[   4.5673 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[   4.5679 ] 32768+0 records in
[   4.5963 ] 32768+0 records out
[   4.5963 ] 32768 bytes (33 kB, 32 KiB) copied, 0.027873 s, 1.2 MB/s
[   4.5963 ]
[   4.5964 ] Concatenating BCT for chain A to bct_backup.img
[   4.5964 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[   4.5967 ] 8192+0 records in
[   4.6013 ] 8192+0 records out
[   4.6013 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.00413479 s, 2.0 MB/s
[   4.6013 ]
[   4.6013 ] Concatenating BCT for chain B to bct_backup.img
[   4.6013 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[   4.6023 ] 8192+0 records in
[   4.6070 ] 8192+0 records out
[   4.6070 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.00431579 s, 1.9 MB/s
[   4.6070 ]
[   4.6070 ] Generating signatures
[   4.6078 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[   4.6079 ] Assuming zero filled SBK key
[   4.6671 ] Warning: pub_key.key is not found
[   4.6683 ] Parsing dev params for multi chains
[   4.6683 ] Generating br-bct
[   4.6684 ] Updating dev and MSS params in BR BCT
[   4.6685 ] tegrabct_v2 --dev_param tegra234-br-bct-p3701-0000_cpp.dtb --sdram tegra234-p3701-0000-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   4.7397 ] Updating customer data section
[   4.7401 ] tegrabct_v2 --chip 0x23 0 --brbct br_bct_BR.bct --update_custinfo custinfo_out.bin
[   4.7406 ] Updating bl info
[   4.7407 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[   4.7423 ] Generating SHA2 Hash
[   4.7441 ] Sha saved in br_bct_BR.sha
[   4.7435 ] Get Signed section of bct
[   4.7438 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[   4.7441 ] Signing BCT
[   4.7448 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   4.7449 ] Assuming zero filled SBK key
[   4.7463 ] Sha saved in br_bct_BR.sha
[   4.7465 ] Warning: pub_key.key is not found
[   4.7458 ] Updating BCT with signature
[   4.7461 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[   4.7466 ] Offset :4608 Len :3584
[   4.7469 ] Generating SHA2 Hash
[   4.7476 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[   4.7477 ] Assuming zero filled SBK key
[   4.7500 ] Sha saved in br_bct_BR.sha
[   4.7495 ] Updating BCT with SHA2 Hash
[   4.7499 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[   4.7504 ] Offset :4608 Len :3584
[   4.7505 ] Offset :68 Len :8124
[   4.7506 ] Generating br-bct
[   4.7508 ] Updating dev and MSS params in BR BCT
[   4.7509 ] tegrabct_v2 --dev_param tegra234-br-bct_b-p3701-0000_cpp.dtb --sdram tegra234-p3701-0000-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   4.8221 ] Updating customer data section
[   4.8225 ] tegrabct_v2 --chip 0x23 0 --brbct br_bct_BR.bct --update_custinfo custinfo_out.bin
[   4.8231 ] Updating bl info
[   4.8237 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[   4.8250 ] Generating SHA2 Hash
[   4.8268 ] Sha saved in br_bct_BR.sha
[   4.8261 ] Get Signed section of bct
[   4.8263 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[   4.8267 ] Signing BCT
[   4.8274 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   4.8275 ] Assuming zero filled SBK key
[   4.8290 ] Sha saved in br_bct_BR.sha
[   4.8291 ] Warning: pub_key.key is not found
[   4.8284 ] Updating BCT with signature
[   4.8286 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[   4.8288 ] Offset :4608 Len :3584
[   4.8290 ] Generating SHA2 Hash
[   4.8297 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[   4.8298 ] Assuming zero filled SBK key
[   4.8318 ] Sha saved in br_bct_BR.sha
[   4.8312 ] Updating BCT with SHA2 Hash
[   4.8313 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[   4.8316 ] Offset :4608 Len :3584
[   4.8321 ] Offset :68 Len :8124
[   4.8322 ] Generating BCT backup image
[   4.8322 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[   4.8325 ] 32768+0 records in
[   4.8604 ] 32768+0 records out
[   4.8604 ] 32768 bytes (33 kB, 32 KiB) copied, 0.0274451 s, 1.2 MB/s
[   4.8604 ]
[   4.8604 ] Concatenating BCT for chain A to bct_backup.img
[   4.8604 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[   4.8608 ] 8192+0 records in
[   4.8653 ] 8192+0 records out
[   4.8653 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.00405279 s, 2.0 MB/s
[   4.8653 ]
[   4.8653 ] Concatenating BCT for chain B to bct_backup.img
[   4.8653 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[   4.8658 ] 8192+0 records in
[   4.8703 ] 8192+0 records out
[   4.8703 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.00415882 s, 2.0 MB/s
[   4.8703 ]
[   4.8703 ] Generating coldboot mb1-bct
[   4.8708 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --wb0sdram tegra234-p3701-0000-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3701-0000-a04_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3701-0000-a04_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3701-0005_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3701-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3701-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3701-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3701-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3701-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[   4.8712 ] MB1-BCT version: 0.13
[   4.8731 ] Parsing config file :tegra234-mb1-bct-pinmux-p3701-0000-a04_cpp.dtb
[   4.8733 ] Added Platform Config 0 data with size :- 2936
[   4.8752 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3701-0000-a04_cpp.dtb
[   4.8754 ] WARNING: unknown node 'g2'
[   4.8755 ] WARNING: unknown node 'g2'
[   4.8755 ] WARNING: unknown node 'g9'
[   4.8756 ] WARNING: unknown node 'g9'
[   4.8757 ] Added Platform Config 2 data with size :- 24
[   4.8757 ]
[   4.8757 ] Parsing config file :tegra234-mb1-bct-pmic-p3701-0005_cpp.dtb
[   4.8757 ] Added Platform Config 4 data with size :- 580
[   4.8757 ]
[   4.8757 ] Parsing config file :tegra234-mb1-bct-reset-p3701-0000_cpp.dtb
[   4.8757 ] Added Platform Config 3 data with size :- 52
[   4.8757 ]
[   4.8757 ] Parsing config file :tegra234-mb1-bct-prod-p3701-0000_cpp.dtb
[   4.8758 ] WARNING: unknown property 'major'
[   4.8758 ] WARNING: unknown property 'minor'
[   4.8758 ] Added Platform Config 5 data with size :- 524
[   4.8758 ]
[   4.8758 ] Parsing config file :tegra234-mb1-bct-gpioint-p3701-0000_cpp.dtb
[   4.8758 ] Added Platform Config 7 data with size :- 380
[   4.8758 ]
[   4.8758 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[   4.8758 ] Added Platform Config 8 data with size :- 24
[   4.8758 ]
[   4.8758 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   4.8758 ] Added Platform Config 9 data with size :- 100
[   4.8758 ]
[   4.8758 ] Parsing config file :tegra234-mb1-bct-cprod-p3701-0000_cpp.dtb
[   4.8758 ] ModuleCount 0 NumProdNames 0
[   4.8758 ] Added Platform Config 6 data with size :- 16
[   4.8758 ]
[   4.8758 ] Parsing config file :tegra234-mb1-bct-ratchet-p3701-0000_cpp.dtb
[   4.8758 ]
[   4.8758 ] Updating mb1-bct with firmware information
[   4.8760 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[   4.8768 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[   4.8772 ] Generating SHA2 Hash for mb1bct
[   4.8790 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[   4.8798 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[   4.8794 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   4.8796 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   4.8820 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   4.8822 ] Assuming zero filled SBK key
[   4.8838 ] Warning: pub_key.key is not found
[   4.8834 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   4.8843 ] Generating recovery mb1-bct
[   4.8845 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --wb0sdram tegra234-p3701-0000-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3701-0000-a04_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3701-0000-a04_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3701-0005_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3701-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3701-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3701-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3701-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3701-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[   4.8847 ] MB1-BCT version: 0.13
[   4.8866 ] Parsing config file :tegra234-mb1-bct-pinmux-p3701-0000-a04_cpp.dtb
[   4.8869 ] Added Platform Config 0 data with size :- 2936
[   4.8886 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3701-0000-a04_cpp.dtb
[   4.8888 ] WARNING: unknown node 'g2'
[   4.8889 ] WARNING: unknown node 'g9'
[   4.8890 ] Added Platform Config 2 data with size :- 24
[   4.8891 ]
[   4.8891 ] Parsing config file :tegra234-mb1-bct-pmic-p3701-0005_cpp.dtb
[   4.8891 ] Added Platform Config 4 data with size :- 580
[   4.8891 ]
[   4.8891 ] Parsing config file :tegra234-mb1-bct-reset-p3701-0000_cpp.dtb
[   4.8891 ] Added Platform Config 3 data with size :- 52
[   4.8891 ]
[   4.8891 ] Parsing config file :tegra234-mb1-bct-prod-p3701-0000_cpp.dtb
[   4.8892 ] WARNING: unknown property 'major'
[   4.8892 ] WARNING: unknown property 'minor'
[   4.8892 ] Added Platform Config 5 data with size :- 524
[   4.8892 ]
[   4.8892 ] Parsing config file :tegra234-mb1-bct-gpioint-p3701-0000_cpp.dtb
[   4.8892 ] Added Platform Config 7 data with size :- 380
[   4.8892 ]
[   4.8892 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[   4.8892 ] Added Platform Config 8 data with size :- 24
[   4.8892 ]
[   4.8892 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   4.8892 ] Added Platform Config 9 data with size :- 100
[   4.8892 ]
[   4.8892 ] Parsing config file :tegra234-mb1-bct-cprod-p3701-0000_cpp.dtb
[   4.8892 ] ModuleCount 0 NumProdNames 0
[   4.8892 ] Added Platform Config 6 data with size :- 16
[   4.8892 ]
[   4.8892 ] Parsing config file :tegra234-mb1-bct-ratchet-p3701-0000_cpp.dtb
[   4.8892 ]
[   4.8892 ] Updating mb1-bct with firmware information
[   4.8893 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo flash.xml.bin
[   4.8902 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[   4.8904 ] Generating SHA2 Hash for mb1bct
[   4.8918 ] Sha saved in mb1_bct_MB1_aligned.sha
[   4.8924 ] Sha saved in mb1_bct_MB1.sha
[   4.8918 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[   4.8920 ] adding BCH for mb1_bct_MB1_aligned.bct
[   4.8934 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   4.8935 ] Assuming zero filled SBK key
[   4.8941 ] Warning: pub_key.key is not found
[   4.8937 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   4.8949 ] Generating coldboot mem-bct
[   4.8951 ] tegrabct_v2 --chip 0x23 0 --sdram tegra234-p3701-0000-sdram-l4t_cpp.dtb --wb0sdram tegra234-p3701-0000-wb0sdram-l4t_cpp.dtb --membct tegra234-p3701-0000-sdram-l4t_cpp_1.bct tegra234-p3701-0000-sdram-l4t_cpp_2.bct tegra234-p3701-0000-sdram-l4t_cpp_3.bct tegra234-p3701-0000-sdram-l4t_cpp_4.bct
[   4.8953 ]  packing sdram params with Wb0 file tegra234-p3701-0000-wb0sdram-l4t_cpp.dtb
[   4.9668 ] Packing sdram param for instance[0]
[   4.9669 ] Packing sdram param for instance[1]
[   4.9670 ] Packing sdram param for instance[2]
[   4.9671 ] Packing sdram param for instance[3]
[   4.9672 ] Packing sdram param for instance[4]
[   4.9673 ] Packing sdram param for instance[5]
[   4.9674 ] Packing sdram param for instance[6]
[   4.9675 ] Packing sdram param for instance[7]
[   4.9676 ] Packing sdram param for instance[8]
[   4.9677 ] Packing sdram param for instance[9]
[   4.9678 ] Packing sdram param for instance[10]
[   4.9679 ] Packing sdram param for instance[11]
[   4.9680 ] Packing sdram param for instance[12]
[   4.9681 ] Packing sdram param for instance[13]
[   4.9682 ] Packing sdram param for instance[14]
[   4.9683 ] Packing sdram param for instance[15]
[   5.0384 ] Getting sector size from pt
[   5.0391 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[   5.0396 ] BlockSize read from layout is 0x200
[   5.0398 ] tegrahost_v2 --chip 0x23 0 --blocksize 512 --magicid MEMB --addsigheader_multi tegra234-p3701-0000-sdram-l4t_cpp_1.bct tegra234-p3701-0000-sdram-l4t_cpp_2.bct tegra234-p3701-0000-sdram-l4t_cpp_3.bct tegra234-p3701-0000-sdram-l4t_cpp_4.bct
[   5.0401 ] Binary 0 length is 58752
[   5.0402 ] Binary 0 align length is 58880
[   5.0410 ] Binary 1 length is 58752
[   5.0410 ] Binary 1 align length is 58880
[   5.0419 ] Binary 2 length is 58752
[   5.0420 ] Binary 2 align length is 58880
[   5.0427 ] Binary 3 length is 58752
[   5.0427 ] Binary 3 align length is 58880
[   5.0433 ] Buffer length is 235520
[   5.0434 ] adding BCH for tegra234-p3701-0000-sdram-l4t_cpp_1.bct
[   5.0435 ] new length is 243712
[   5.0441 ] tegrahost_v2 --chip 0x23 0 --align mem_coldboot_aligned.bct
[   5.0446 ] tegrahost_v2 --chip 0x23 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_coldboot_aligned.bct zerosbk
[   5.0448 ] Header already present for mem_coldboot_aligned.bct
[   5.0464 ] tegrasign_v3.py --key None --list mem_coldboot_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   5.0465 ] Assuming zero filled SBK key
[   5.0478 ] Warning: pub_key.key is not found
[   5.0476 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_coldboot_aligned_sigheader.bct.encrypt mem_coldboot_aligned_sigheader.bct.hash zerosbk
[   5.0488 ] Generating recovery mem-bct
[   5.0491 ] tegrabct_v2 --chip 0x23 0 --sdram tegra234-p3701-0000-sdram-l4t_cpp.dtb --wb0sdram tegra234-p3701-0000-wb0sdram-l4t_cpp.dtb --membct tegra234-p3701-0000-sdram-l4t_cpp_1.bct tegra234-p3701-0000-sdram-l4t_cpp_2.bct tegra234-p3701-0000-sdram-l4t_cpp_3.bct tegra234-p3701-0000-sdram-l4t_cpp_4.bct
[   5.0492 ]  packing sdram params with Wb0 file tegra234-p3701-0000-wb0sdram-l4t_cpp.dtb
[   5.1242 ] Packing sdram param for instance[0]
[   5.1243 ] Packing sdram param for instance[1]
[   5.1244 ] Packing sdram param for instance[2]
[   5.1245 ] Packing sdram param for instance[3]
[   5.1246 ] Packing sdram param for instance[4]
[   5.1246 ] Packing sdram param for instance[5]
[   5.1247 ] Packing sdram param for instance[6]
[   5.1248 ] Packing sdram param for instance[7]
[   5.1249 ] Packing sdram param for instance[8]
[   5.1249 ] Packing sdram param for instance[9]
[   5.1250 ] Packing sdram param for instance[10]
[   5.1251 ] Packing sdram param for instance[11]
[   5.1252 ] Packing sdram param for instance[12]
[   5.1253 ] Packing sdram param for instance[13]
[   5.1253 ] Packing sdram param for instance[14]
[   5.1254 ] Packing sdram param for instance[15]
[   5.1988 ] Reading ramcode from backup chip_info.bin file
[   5.1989 ] RAMCODE Read from Device: 0
[   5.1989 ] Using ramcode 0
[   5.1989 ] Disabled BPMP dtb trim, using default dtb
[   5.1989 ]
[   5.1995 ] tegrahost_v2 --chip 0x23 0 --align mem_rcm_aligned.bct
[   5.2000 ] tegrahost_v2 --chip 0x23 0 --magicid MEM0 --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm_aligned.bct zerosbk
[   5.2004 ] adding BCH for mem_rcm_aligned.bct
[   5.2033 ] tegrasign_v3.py --key None --list mem_rcm_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   5.2034 ] Assuming zero filled SBK key
[   5.2044 ] Warning: pub_key.key is not found
[   5.2041 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_rcm_aligned_sigheader.bct.encrypt mem_rcm_aligned_sigheader.bct.hash zerosbk
[   5.2048 ] Copying signatures
[   5.2050 ] tegrahost_v2 --chip 0x23 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[   5.2377 ] tegraparser_v2 --generategpt --pt flash.xml.bin
[   5.2383 ] gpt_secondary_3_0.bin:
[   5.2387 ] partition_id	partition_name			      StartingLba	EndingLba
[   5.2389 ]            1	BCT                                 	       0	    2047
[   5.2391 ]            2	A_mb1                               	    2048	    3071
[   5.2393 ]            3	A_psc_bl1                           	    3072	    3583
[   5.2395 ]            4	A_MB1_BCT                           	    3584	    3839
[   5.2397 ]            5	A_MEM_BCT                           	    3840	    4351
[   5.2400 ]            6	A_tsec-fw                           	    4352	    6399
[   5.2402 ]            7	A_nvdec                             	    6400	    8447
[   5.2404 ]            8	A_mb2                               	    8448	    9471
[   5.2406 ]            9	A_xusb-fw                           	    9472	    9983
[   5.2407 ]           10	A_bpmp-fw                           	    9984	   13055
[   5.2407 ]           11	A_bpmp-fw-dtb                       	   13056	   21247
[   5.2407 ]           12	A_psc-fw                            	   21248	   22783
[   5.2407 ]           13	A_mts-mce                           	   22784	   23807
[   5.2407 ]           14	A_sc7                               	   23808	   24191
[   5.2407 ]           15	A_pscrf                             	   24192	   24575
[   5.2407 ]           16	A_mb2rf                             	   24576	   24831
[   5.2407 ]           17	A_cpu-bootloader                    	   24832	   31999
[   5.2407 ]           18	A_secure-os                         	   32000	   40191
[   5.2408 ]           19	A_smm-fw                            	   40192	   44287
[   5.2408 ]           20	A_eks                               	   44288	   44799
[   5.2408 ]           21	A_dce-fw                            	   44800	   55039
[   5.2408 ]           22	A_spe-fw                            	   55040	   56191
[   5.2408 ]           23	A_rce-fw                            	   56192	   58239
[   5.2408 ]           24	A_adsp-fw                           	   58240	   62335
[   5.2408 ]           25	A_pva-fw                            	   62336	   62847
[   5.2408 ]           26	A_reserved_on_boot                  	   62848	   65023
[   5.2408 ]           27	B_mb1                               	   65024	   66047
[   5.2408 ]           28	B_psc_bl1                           	   66048	   66559
[   5.2408 ]           29	B_MB1_BCT                           	   66560	   66815
[   5.2408 ]           30	B_MEM_BCT                           	   66816	   67327
[   5.2408 ]           31	B_tsec-fw                           	   67328	   69375
[   5.2408 ]           32	B_nvdec                             	   69376	   71423
[   5.2408 ]           33	B_mb2                               	   71424	   72447
[   5.2408 ]           34	B_xusb-fw                           	   72448	   72959
[   5.2408 ]           35	B_bpmp-fw                           	   72960	   76031
[   5.2408 ]           36	B_bpmp-fw-dtb                       	   76032	   84223
[   5.2408 ]           37	B_psc-fw                            	   84224	   85759
[   5.2408 ]           38	B_mts-mce                           	   85760	   86783
[   5.2408 ]           39	B_sc7                               	   86784	   87167
[   5.2408 ]           40	B_pscrf                             	   87168	   87551
[   5.2408 ]           41	B_mb2rf                             	   87552	   87807
[   5.2409 ]           42	B_cpu-bootloader                    	   87808	   94975
[   5.2409 ]           43	B_secure-os                         	   94976	  103167
[   5.2409 ]           44	B_smm-fw                            	  103168	  107263
[   5.2409 ]           45	B_eks                               	  107264	  107775
[   5.2409 ]           46	B_dce-fw                            	  107776	  118015
[   5.2409 ]           47	B_spe-fw                            	  118016	  119167
[   5.2409 ]           48	B_rce-fw                            	  119168	  121215
[   5.2409 ]           49	B_adsp-fw                           	  121216	  125311
[   5.2409 ]           50	B_pva-fw                            	  125312	  125823
[   5.2409 ]           51	B_reserved_on_boot                  	  125824	  127999
[   5.2409 ]           52	uefi_variables                      	  128000	  128511
[   5.2409 ]           53	uefi_ftw                            	  128512	  129535
[   5.2409 ]           54	reserved                            	  129536	  129919
[   5.2409 ]           55	worm                                	  129920	  130303
[   5.2409 ]           56	BCT-boot-chain_backup               	  130304	  130431
[   5.2409 ]           57	reserved_partition                  	  130432	  130559
[   5.2409 ]           58	secondary_gpt_backup                	  130560	  130687
[   5.2409 ]           59	B_VER                               	  130688	  130815
[   5.2409 ]           60	A_VER                               	  130816	  130943
[   5.2409 ] gpt_primary_1_3.bin:
[   5.2409 ] partition_id	partition_name			      StartingLba	EndingLba
[   5.2409 ]            1	APP                                 	 3050048	119537623
[   5.2409 ]            2	A_kernel                            	      40	  262183
[   5.2410 ]            3	A_kernel-dtb                        	  262184	  263719
[   5.2410 ]            4	A_reserved_on_user                  	  263720	  328487
[   5.2410 ]            5	B_kernel                            	  328488	  590631
[   5.2410 ]            6	B_kernel-dtb                        	  590632	  592167
[   5.2410 ]            7	B_reserved_on_user                  	  592168	  656935
[   5.2410 ]            8	recovery                            	  656936	  820775
[   5.2410 ]            9	recovery-dtb                        	  820776	  821799
[   5.2410 ]           10	esp                                 	  821800	  952871
[   5.2410 ]           11	recovery_alt                        	  952872	 1116711
[   5.2410 ]           12	recovery-dtb_alt                    	 1116712	 1117735
[   5.2410 ]           13	esp_alt                             	 1117736	 1248807
[   5.2410 ]           14	UDA                                 	 1248832	 2068031
[   5.2410 ]           15	reserved                            	 2068032	 3050047
[   5.2410 ] gpt_secondary_1_3.bin:
[   5.2410 ] partition_id	partition_name			      StartingLba	EndingLba
[   5.2410 ]            1	APP                                 	 3050048	119537623
[   5.2410 ]            2	A_kernel                            	      40	  262183
[   5.2411 ]            9	recovery-dtb                        	  820776	  821799
[   5.2411 ]           10	esp                                 	  821800	  952871
[   5.2411 ]           11	recovery_alt                        	  952872	 1116711
[   5.2411 ]           12	recovery-dtb_alt                    	 1116712	 1117735
[   5.2411 ]           13	esp_alt                             	 1117736	 1248807
[   5.2411 ]           14	UDA                                 	 1248832	 2068031
[   5.2411 ]           15	reserved                            	 2068032	 3050047
[   5.2411 ]
[   5.2424 ] Get magic id
[   5.2428 ] tegraparser_v2 --get_magic psc_fw
[   5.2431 ] PFWP
[   5.2432 ] partition type psc_fw, magic id = PFWP
[   5.2437 ] tegrahost_v2 --chip 0x23 0 --align pscfw_t234_prod_aligned.bin
[   5.2441 ] tegrahost_v2 --chip 0x23 0 --magicid PFWP --ratchet_blob ratchet_blob.bin --appendsigheader pscfw_t234_prod_aligned.bin zerosbk
[   5.2443 ] Header already present for pscfw_t234_prod_aligned.bin
[   5.2490 ] tegrasign_v3.py --key None --list pscfw_t234_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   5.2491 ] Assuming zero filled SBK key
[   5.2501 ] Warning: pub_key.key is not found
[   5.2496 ] tegrahost_v2 --chip 0x23 0 --updatesigheader pscfw_t234_prod_aligned_sigheader.bin.encrypt pscfw_t234_prod_aligned_sigheader.bin.hash zerosbk
[   5.2509 ] Get magic id
[   5.2511 ] tegraparser_v2 --get_magic mts_mce
[   5.2512 ] MTSM
[   5.2513 ] partition type mts_mce, magic id = MTSM
[   5.2518 ] tegrahost_v2 --chip 0x23 0 --align mce_flash_o10_cr_prod_aligned.bin
[   5.2524 ] tegrahost_v2 --chip 0x23 0 --magicid MTSM --ratchet_blob ratchet_blob.bin --appendsigheader mce_flash_o10_cr_prod_aligned.bin zerosbk
[   5.2525 ] Header already present for mce_flash_o10_cr_prod_aligned.bin
[   5.2563 ] tegrasign_v3.py --key None --list mce_flash_o10_cr_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   5.2565 ] Assuming zero filled SBK key
[   5.2580 ] Warning: pub_key.key is not found
[   5.2578 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mce_flash_o10_cr_prod_aligned_sigheader.bin.encrypt mce_flash_o10_cr_prod_aligned_sigheader.bin.hash zerosbk
[   5.2591 ] Get magic id
[   5.2593 ] tegraparser_v2 --get_magic tsec_fw
[   5.2595 ] TSEC
[   5.2596 ] partition type tsec_fw, magic id = TSEC
[   5.2600 ] tegrahost_v2 --chip 0x23 0 --align tsec_t234_aligned.bin
[   5.2606 ] tegrahost_v2 --chip 0x23 0 --magicid TSEC --ratchet_blob ratchet_blob.bin --appendsigheader tsec_t234_aligned.bin zerosbk
[   5.2609 ] Header already present for tsec_t234_aligned.bin
[   5.2644 ] tegrasign_v3.py --key None --list tsec_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   5.2644 ] Assuming zero filled SBK key
[   5.2656 ] Warning: pub_key.key is not found
[   5.2651 ] tegrahost_v2 --chip 0x23 0 --updatesigheader tsec_t234_aligned_sigheader.bin.encrypt tsec_t234_aligned_sigheader.bin.hash zerosbk
[   5.2661 ] Get magic id
[   5.2665 ] tegraparser_v2 --get_magic mb2_applet
[   5.2667 ] MB2A
[   5.2668 ] partition type mb2_applet, magic id = MB2A
[   5.2674 ] tegrahost_v2 --chip 0x23 0 --align applet_t234_aligned.bin
[   5.2680 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --ratchet_blob ratchet_blob.bin --appendsigheader applet_t234_aligned.bin zerosbk
[   5.2682 ] adding BCH for applet_t234_aligned.bin
[   5.2753 ] tegrasign_v3.py --key None --list applet_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   5.2754 ] Assuming zero filled SBK key
[   5.2764 ] Warning: pub_key.key is not found
[   5.2761 ] tegrahost_v2 --chip 0x23 0 --updatesigheader applet_t234_aligned_sigheader.bin.encrypt applet_t234_aligned_sigheader.bin.hash zerosbk
[   5.2779 ] Generating recovery mb2-bct
[   5.2779 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_bct.cfg --recov --mb2bctcfg tegra234-mb2-bct-misc-p3701-0000_cpp.dtb --scr tegra234-mb2-bct-scr-p3701-0000_cpp.dtb
[   5.2782 ] ERROR: value 0x31 is out of range
[   5.2789 ] ERROR: value 0x31 is out of range
[   5.2790 ] ERROR: value 0x31 is out of range
[   5.2791 ] WARNING: unknown property 'tfc_version'
[   5.2793 ] WARNING: unknown property 'addr_header_version'
[   5.2873 ] Updating mb2-bct with storage information for RCM
[   5.2877 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_bct_MB2.bct --updatestorageinfo flash.xml.bin
[   5.2889 ] Concatenating mb2-bct to mb2 binary
[   5.2889 ] mb2_bin_file = mb2_t234.bin
[   5.2889 ] mb2_bct_file = mb2_bct_MB2.bct
[   5.2892 ] Get magic id
[   5.2894 ] tegraparser_v2 --get_magic mb2_bootloader
[   5.2896 ] MB2B
[   5.2901 ] partition type mb2_bootloader, magic id = MB2B
[   5.2906 ] tegrahost_v2 --chip 0x23 0 --align mb2_t234_with_mb2_bct_MB2_aligned.bin
[   5.2913 ] tegrahost_v2 --chip 0x23 0 --magicid MB2B --ratchet_blob ratchet_blob.bin --appendsigheader mb2_t234_with_mb2_bct_MB2_aligned.bin zerosbk
[   5.2914 ] adding BCH for mb2_t234_with_mb2_bct_MB2_aligned.bin
[   5.3030 ] tegrasign_v3.py --key None --list mb2_t234_with_mb2_bct_MB2_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   5.3031 ] Assuming zero filled SBK key
[   5.3045 ] Warning: pub_key.key is not found
[   5.3040 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb2_t234_with_mb2_bct_MB2_aligned_sigheader.bin.encrypt mb2_t234_with_mb2_bct_MB2_aligned_sigheader.bin.hash zerosbk
[   5.3064 ] Get magic id
[   5.3066 ] tegraparser_v2 --get_magic xusb_fw
[   5.3068 ] XUSB
[   5.3069 ] partition type xusb_fw, magic id = XUSB
[   5.3073 ] tegrahost_v2 --chip 0x23 0 --align xusb_t234_prod_aligned.bin
[   5.3080 ] tegrahost_v2 --chip 0x23 0 --magicid XUSB --ratchet_blob ratchet_blob.bin --appendsigheader xusb_t234_prod_aligned.bin zerosbk
[   5.3082 ] adding BCH for xusb_t234_prod_aligned.bin
[   5.3140 ] tegrasign_v3.py --key None --list xusb_t234_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   5.3142 ] Assuming zero filled SBK key
[   5.3155 ] Warning: pub_key.key is not found
[   5.3150 ] tegrahost_v2 --chip 0x23 0 --updatesigheader xusb_t234_prod_aligned_sigheader.bin.encrypt xusb_t234_prod_aligned_sigheader.bin.hash zerosbk
[   5.3168 ] Get magic id
[   5.3171 ] tegraparser_v2 --get_magic pva_fw
[   5.3176 ] PVAF
[   5.3178 ] partition type pva_fw, magic id = PVAF
[   5.3195 ] tegrahost_v2 --chip 0x23 0 --align nvpva_020_aligned.fw
[   5.3203 ] tegrahost_v2 --chip 0x23 0 --magicid PVAF --ratchet_blob ratchet_blob.bin --appendsigheader nvpva_020_aligned.fw zerosbk
[   5.3204 ] adding BCH for nvpva_020_aligned.fw
[   5.3709 ] tegrasign_v3.py --key None --list nvpva_020_aligned_sigheader.fw_list.xml --pubkeyhash pub_key.key --sha sha512
[   5.3711 ] Assuming zero filled SBK key
[   5.3747 ] Warning: pub_key.key is not found
[   5.3746 ] tegrahost_v2 --chip 0x23 0 --updatesigheader nvpva_020_aligned_sigheader.fw.encrypt nvpva_020_aligned_sigheader.fw.hash zerosbk
[   5.3799 ] Kernel DTB used: kernel_tegra234-p3737-0000+p3701-0004-nv.dtb
[   5.3799 ] Concatenating kernel-dtb to dce-fw binary
[   5.3800 ] dce_bin = display-t234-dce.bin
[   5.3800 ] kernel_dtb = kernel_tegra234-p3737-0000+p3701-0004-nv.dtb
[   5.3800 ] dce_with_dtb = display-t234-dce_with_kernel_tegra234-p3737-0000+p3701-0004-nv.bin
[   5.3885 ] Get magic id
[   5.3891 ] tegraparser_v2 --get_magic dce_fw
[   5.3894 ] DCEF
[   5.3897 ] partition type dce_fw, magic id = DCEF
[   5.3975 ] tegrahost_v2 --chip 0x23 0 --align display-t234-dce_with_kernel_tegra234-p3737-0000+p3701-0004-nv_aligned.bin
[   5.3986 ] tegrahost_v2 --chip 0x23 0 --magicid DCEF --ratchet_blob ratchet_blob.bin --appendsigheader display-t234-dce_with_kernel_tegra234-p3737-0000+p3701-0004-nv_aligned.bin zerosbk
[   5.3989 ] adding BCH for display-t234-dce_with_kernel_tegra234-p3737-0000+p3701-0004-nv_aligned.bin
[   5.6697 ] tegrasign_v3.py --key None --list display-t234-dce_with_kernel_tegra234-p3737-0000+p3701-0004-nv_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   5.6700 ] Assuming zero filled SBK key
[   5.6889 ] Warning: pub_key.key is not found
[   5.6887 ] tegrahost_v2 --chip 0x23 0 --updatesigheader display-t234-dce_with_kernel_tegra234-p3737-0000+p3701-0004-nv_aligned_sigheader.bin.encrypt display-t234-dce_with_kernel_tegra234-p3737-0000+p3701-0004-nv_aligned_sigheader.bin.hash zerosbk
[   5.7155 ] Get magic id
[   5.7160 ] tegraparser_v2 --get_magic nvdec
[   5.7163 ] NDEC
[   5.7164 ] partition type nvdec, magic id = NDEC
[   5.7172 ] tegrahost_v2 --chip 0x23 0 --align nvdec_t234_prod_aligned.fw
[   5.7181 ] tegrahost_v2 --chip 0x23 0 --magicid NDEC --ratchet_blob ratchet_blob.bin --appendsigheader nvdec_t234_prod_aligned.fw zerosbk
[   5.7183 ] Header already present for nvdec_t234_prod_aligned.fw
[   5.7234 ] tegrasign_v3.py --key None --list nvdec_t234_prod_aligned_sigheader.fw_list.xml --pubkeyhash pub_key.key --sha sha512
[   5.7234 ] Assuming zero filled SBK key
[   5.7245 ] Warning: pub_key.key is not found
[   5.7243 ] tegrahost_v2 --chip 0x23 0 --updatesigheader nvdec_t234_prod_aligned_sigheader.fw.encrypt nvdec_t234_prod_aligned_sigheader.fw.hash zerosbk
[   5.7259 ] Get magic id
[   5.7263 ] tegraparser_v2 --get_magic bpmp_fw
[   5.7266 ] BPMF
[   5.7267 ] partition type bpmp_fw, magic id = BPMF
[   5.7277 ] tegrahost_v2 --chip 0x23 0 --align bpmp_t234-TE990M-A1_prod_aligned.bin
[   5.7282 ] tegrahost_v2 --chip 0x23 0 --magicid BPMF --ratchet_blob ratchet_blob.bin --appendsigheader bpmp_t234-TE990M-A1_prod_aligned.bin zerosbk
[   5.7283 ] Header already present for bpmp_t234-TE990M-A1_prod_aligned.bin
[   5.7406 ] tegrasign_v3.py --key None --list bpmp_t234-TE990M-A1_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   5.7407 ] Assuming zero filled SBK key
[   5.7436 ] Warning: pub_key.key is not found
[   5.7433 ] tegrahost_v2 --chip 0x23 0 --updatesigheader bpmp_t234-TE990M-A1_prod_aligned_sigheader.bin.encrypt bpmp_t234-TE990M-A1_prod_aligned_sigheader.bin.hash zerosbk
[   5.7456 ] Using bpmp-dtb concatenated with odmdata
[   5.7456 ] Get magic id
[   5.7459 ] tegraparser_v2 --get_magic bpmp_fw_dtb
[   5.7464 ] BPMD
[   5.7465 ] partition type bpmp_fw_dtb, magic id = BPMD
[   5.7470 ] tegrahost_v2 --chip 0x23 0 --align tegra234-bpmp-3701-0004-3737-0000_with_odm_aligned.dtb
[   5.7476 ] tegrahost_v2 --chip 0x23 0 --magicid BPMD --ratchet_blob ratchet_blob.bin --appendsigheader tegra234-bpmp-3701-0004-3737-0000_with_odm_aligned.dtb zerosbk
[   5.7478 ] adding BCH for tegra234-bpmp-3701-0004-3737-0000_with_odm_aligned.dtb
[   5.7576 ] tegrasign_v3.py --key None --list tegra234-bpmp-3701-0004-3737-0000_with_odm_aligned_sigheader.dtb_list.xml --pubkeyhash pub_key.key --sha sha512
[   5.7576 ] Assuming zero filled SBK key
[   5.7595 ] Warning: pub_key.key is not found
[   5.7592 ] tegrahost_v2 --chip 0x23 0 --updatesigheader tegra234-bpmp-3701-0004-3737-0000_with_odm_aligned_sigheader.dtb.encrypt tegra234-bpmp-3701-0004-3737-0000_with_odm_aligned_sigheader.dtb.hash zerosbk
[   5.7604 ] Get magic id
[   5.7606 ] tegraparser_v2 --get_magic rce_fw
[   5.7608 ] RCEF
[   5.7609 ] partition type rce_fw, magic id = RCEF
[   5.7618 ] tegrahost_v2 --chip 0x23 0 --align camera-rtcpu-t234-rce_aligned.img
[   5.7626 ] tegrahost_v2 --chip 0x23 0 --magicid RCEF --ratchet_blob ratchet_blob.bin --appendsigheader camera-rtcpu-t234-rce_aligned.img zerosbk
[   5.7630 ] adding BCH for camera-rtcpu-t234-rce_aligned.img
[   5.7744 ] tegrasign_v3.py --key None --list camera-rtcpu-t234-rce_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[   5.7745 ] Assuming zero filled SBK key
[   5.7761 ] Warning: pub_key.key is not found
[   5.7758 ] tegrahost_v2 --chip 0x23 0 --updatesigheader camera-rtcpu-t234-rce_aligned_sigheader.img.encrypt camera-rtcpu-t234-rce_aligned_sigheader.img.hash zerosbk
[   5.7773 ] Get magic id
[   5.7776 ] tegraparser_v2 --get_magic ape_fw
[   5.7781 ] APEF
[   5.7783 ] partition type ape_fw, magic id = APEF
[   5.7788 ] tegrahost_v2 --chip 0x23 0 --align adsp-fw_aligned.bin
[   5.7793 ] tegrahost_v2 --chip 0x23 0 --magicid APEF --ratchet_blob ratchet_blob.bin --appendsigheader adsp-fw_aligned.bin zerosbk
[   5.7797 ] adding BCH for adsp-fw_aligned.bin
[   5.7905 ] tegrasign_v3.py --key None --list adsp-fw_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   5.7907 ] Assuming zero filled SBK key
[   5.7928 ] Warning: pub_key.key is not found
[   5.7925 ] tegrahost_v2 --chip 0x23 0 --updatesigheader adsp-fw_aligned_sigheader.bin.encrypt adsp-fw_aligned_sigheader.bin.hash zerosbk
[   5.7938 ] Get magic id
[   5.7942 ] tegraparser_v2 --get_magic spe_fw
[   5.7944 ] SPEF
[   5.7945 ] partition type spe_fw, magic id = SPEF
[   5.7949 ] tegrahost_v2 --chip 0x23 0 --align spe_t234_aligned.bin
[   5.7954 ] tegrahost_v2 --chip 0x23 0 --magicid SPEF --ratchet_blob ratchet_blob.bin --appendsigheader spe_t234_aligned.bin zerosbk
[   5.7956 ] adding BCH for spe_t234_aligned.bin
[   5.8038 ] tegrasign_v3.py --key None --list spe_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   5.8039 ] Assuming zero filled SBK key
[   5.8051 ] Warning: pub_key.key is not found
[   5.8047 ] tegrahost_v2 --chip 0x23 0 --updatesigheader spe_t234_aligned_sigheader.bin.encrypt spe_t234_aligned_sigheader.bin.hash zerosbk
[   5.8062 ] Get magic id
[   5.8064 ] tegraparser_v2 --get_magic tos
[   5.8067 ] TOSB
[   5.8068 ] partition type tos, magic id = TOSB
[   5.8085 ] tegrahost_v2 --chip 0x23 0 --align tos-optee_t234_aligned.img
[   5.8089 ] tegrahost_v2 --chip 0x23 0 --magicid TOSB --ratchet_blob ratchet_blob.bin --appendsigheader tos-optee_t234_aligned.img zerosbk
[   5.8091 ] adding BCH for tos-optee_t234_aligned.img
[   5.8467 ] tegrasign_v3.py --key None --list tos-optee_t234_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[   5.8469 ] Assuming zero filled SBK key
[   5.8497 ] Warning: pub_key.key is not found
[   5.8493 ] tegrahost_v2 --chip 0x23 0 --updatesigheader tos-optee_t234_aligned_sigheader.img.encrypt tos-optee_t234_aligned_sigheader.img.hash zerosbk
[   5.8527 ] Get magic id
[   5.8531 ] tegraparser_v2 --get_magic eks
[   5.8535 ] EKSB
[   5.8535 ] partition type eks, magic id = EKSB
[   5.8539 ] tegrahost_v2 --chip 0x23 0 --align eks_t234_aligned.img
[   5.8553 ] tegrahost_v2 --chip 0x23 0 --magicid EKSB --ratchet_blob ratchet_blob.bin --appendsigheader eks_t234_aligned.img zerosbk
[   5.8555 ] adding BCH for eks_t234_aligned.img
[   5.8566 ] tegrasign_v3.py --key None --list eks_t234_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[   5.8567 ] Assuming zero filled SBK key
[   5.8575 ] Warning: pub_key.key is not found
[   5.8571 ] tegrahost_v2 --chip 0x23 0 --updatesigheader eks_t234_aligned_sigheader.img.encrypt eks_t234_aligned_sigheader.img.hash zerosbk
[   5.8606 ] tegrahost_v2 --chip 0x23 0 --align uefi_jetson_with_dtb_aligned.bin
[   5.8614 ] tegrahost_v2 --chip 0x23 0 --magicid CPBL --ratchet_blob ratchet_blob.bin --appendsigheader uefi_jetson_with_dtb_aligned.bin zerosbk
[   5.8618 ] adding BCH for uefi_jetson_with_dtb_aligned.bin
[   5.9458 ] tegrasign_v3.py --key None --list uefi_jetson_with_dtb_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   5.9459 ] Assuming zero filled SBK key
[   5.9514 ] Warning: pub_key.key is not found
[   5.9512 ] tegrahost_v2 --chip 0x23 0 --updatesigheader uefi_jetson_with_dtb_aligned_sigheader.bin.encrypt uefi_jetson_with_dtb_aligned_sigheader.bin.hash zerosbk
[   5.9585 ] Copying enc\/signed file in /home/mona/Linux_for_Tegra/bootloader/signed
[   5.9720 ] Copying br bct for multi chains
[   5.9720 ] Signed BCT for boot chain A is copied to /home/mona/Linux_for_Tegra/bootloader/signed/br_bct_BR.bct
[   5.9721 ] Signed BCT for boot chain B is copied to /home/mona/Linux_for_Tegra/bootloader/signed/br_bct_b_BR.bct
[   5.9721 ] Copying BCT backup image bct_backup.img to /home/mona/Linux_for_Tegra/bootloader/signed/bct_backup.img
[   5.9751 ] Copying pscfw_t234_prod_sigheader.bin.encrypt to /home/mona/Linux_for_Tegra/bootloader/signed
[   5.9753 ] Signed file: /home/mona/Linux_for_Tegra/bootloader/signed/pscfw_t234_prod_sigheader.bin.encrypt
[   5.9753 ] Copying mce_flash_o10_cr_prod_sigheader.bin.encrypt to /home/mona/Linux_for_Tegra/bootloader/signed
[   5.9755 ] Signed file: /home/mona/Linux_for_Tegra/bootloader/signed/mce_flash_o10_cr_prod_sigheader.bin.encrypt
[   5.9755 ] Copying tsec_t234_sigheader.bin.encrypt to /home/mona/Linux_for_Tegra/bootloader/signed
[   5.9757 ] Signed file: /home/mona/Linux_for_Tegra/bootloader/signed/tsec_t234_sigheader.bin.encrypt
[   5.9757 ] Copying applet_t234_sigheader.bin.encrypt to /home/mona/Linux_for_Tegra/bootloader/signed
[   5.9759 ] Signed file: /home/mona/Linux_for_Tegra/bootloader/signed/applet_t234_sigheader.bin.encrypt
[   5.9759 ] Copying mb2_t234_with_mb2_bct_MB2_sigheader.bin.encrypt to /home/mona/Linux_for_Tegra/bootloader/signed
[   5.9762 ] Signed file: /home/mona/Linux_for_Tegra/bootloader/signed/mb2_t234_with_mb2_bct_MB2_sigheader.bin.encrypt
[   5.9762 ] Copying xusb_t234_prod_sigheader.bin.encrypt to /home/mona/Linux_for_Tegra/bootloader/signed
[   5.9763 ] Signed file: /home/mona/Linux_for_Tegra/bootloader/signed/xusb_t234_prod_sigheader.bin.encrypt
[   5.9763 ] Copying nvpva_020_sigheader.fw.encrypt to /home/mona/Linux_for_Tegra/bootloader/signed
[   5.9775 ] Signed file: /home/mona/Linux_for_Tegra/bootloader/signed/nvpva_020_sigheader.fw.encrypt
[   5.9775 ] Copying display-t234-dce_sigheader.bin.encrypt to /home/mona/Linux_for_Tegra/bootloader/signed
[   5.9828 ] Signed file: /home/mona/Linux_for_Tegra/bootloader/signed/display-t234-dce_sigheader.bin.encrypt
[   5.9828 ] Copying display-t234-dce_with_kernel_tegra234-p3737-0000+p3701-0004-nv_sigheader.bin.encrypt to /home/mona/Linux_for_Tegra/bootloader/signed
[   5.9883 ] Signed file: /home/mona/Linux_for_Tegra/bootloader/signed/display-t234-dce_with_kernel_tegra234-p3737-0000+p3701-0004-nv_sigheader.bin.encrypt
[   5.9883 ] Copying nvdec_t234_prod_sigheader.fw.encrypt to /home/mona/Linux_for_Tegra/bootloader/signed
[   5.9886 ] Signed file: /home/mona/Linux_for_Tegra/bootloader/signed/nvdec_t234_prod_sigheader.fw.encrypt
[   5.9886 ] Copying bpmp_t234-TE990M-A1_prod_sigheader.bin.encrypt to /home/mona/Linux_for_Tegra/bootloader/signed
[   5.9892 ] Signed file: /home/mona/Linux_for_Tegra/bootloader/signed/bpmp_t234-TE990M-A1_prod_sigheader.bin.encrypt
[   5.9893 ] Copying tegra234-bpmp-3701-0004-3737-0000_with_odm_sigheader.dtb.encrypt to /home/mona/Linux_for_Tegra/bootloader/signed
[   5.9895 ] Signed file: /home/mona/Linux_for_Tegra/bootloader/signed/tegra234-bpmp-3701-0004-3737-0000_with_odm_sigheader.dtb.encrypt
[   5.9895 ] Copying camera-rtcpu-t234-rce_sigheader.img.encrypt to /home/mona/Linux_for_Tegra/bootloader/signed
[   5.9904 ] Signed file: /home/mona/Linux_for_Tegra/bootloader/signed/camera-rtcpu-t234-rce_sigheader.img.encrypt
[   5.9904 ] Copying adsp-fw_sigheader.bin.encrypt to /home/mona/Linux_for_Tegra/bootloader/signed
[   5.9908 ] Signed file: /home/mona/Linux_for_Tegra/bootloader/signed/adsp-fw_sigheader.bin.encrypt
[   5.9908 ] Copying spe_t234_sigheader.bin.encrypt to /home/mona/Linux_for_Tegra/bootloader/signed
[   5.9910 ] Signed file: /home/mona/Linux_for_Tegra/bootloader/signed/spe_t234_sigheader.bin.encrypt
[   5.9910 ] Copying tos-optee_t234_sigheader.img.encrypt to /home/mona/Linux_for_Tegra/bootloader/signed
[   5.9921 ] Signed file: /home/mona/Linux_for_Tegra/bootloader/signed/tos-optee_t234_sigheader.img.encrypt
[   5.9921 ] Copying eks_t234_sigheader.img.encrypt to /home/mona/Linux_for_Tegra/bootloader/signed
[   5.9922 ] Signed file: /home/mona/Linux_for_Tegra/bootloader/signed/eks_t234_sigheader.img.encrypt
[   5.9922 ] Copying uefi_jetson_with_dtb_sigheader.bin.encrypt to /home/mona/Linux_for_Tegra/bootloader/signed
[   5.9939 ] Signed file: /home/mona/Linux_for_Tegra/bootloader/signed/uefi_jetson_with_dtb_sigheader.bin.encrypt
[   5.9956 ] tegraparser_v2 --pt flash.xml.bin --generateflashindex /home/mona/Linux_for_Tegra/bootloader/signed/flash.xml.tmp flash.idx
Using bpmp-dtb concatenated with odmdata in blob for t23x
./tegraflash.py --bl uefi_jetson_with_dtb_sigheader.bin.encrypt --bct br_bct_BR.bct --securedev  --bldtb tegra234-p3737-0000+p3701-0004-nv.dtb --applet rcm_2_encrypt.rcm --applet_softfuse rcm_1_encrypt.rcm --cmd "rcmboot"  --cfg secureflash.xml --chip 0x23 --mb1_bct mb1_bct_MB1_sigheader.bct.encrypt --mem_bct mem_rcm_sigheader.bct.encrypt --mb1_cold_boot_bct mb1_cold_boot_bct_MB1_sigheader.bct.encrypt --mb1_bin mb1_t234_prod_aligned_sigheader.bin.encrypt --psc_bl1_bin psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --mem_bct_cold_boot mem_coldboot_sigheader.bct.encrypt  --bins "psc_fw pscfw_t234_prod_sigheader.bin.encrypt; mts_mce mce_flash_o10_cr_prod_sigheader.bin.encrypt; tsec_fw tsec_t234_sigheader.bin.encrypt; mb2_applet applet_t234_sigheader.bin.encrypt; mb2_bootloader mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt; xusb_fw xusb_t234_prod_sigheader.bin.encrypt; pva_fw nvpva_020_sigheader.fw.encrypt; dce_fw display-t234-dce_sigheader.bin.encrypt; nvdec nvdec_t234_prod_sigheader.fw.encrypt; bpmp_fw bpmp_t234-TE990M-A1_prod_sigheader.bin.encrypt; bpmp_fw_dtb tegra234-bpmp-3701-0004-3737-0000_with_odm_sigheader.dtb.encrypt; rce_fw camera-rtcpu-t234-rce_sigheader.img.encrypt; ape_fw adsp-fw_sigheader.bin.encrypt; spe_fw spe_t234_sigheader.bin.encrypt; tos tos-optee_t234_sigheader.img.encrypt; eks eks_t234_sigheader.img.encrypt; kernel boot.img; kernel_dtb tegra234-p3737-0000+p3701-0004-nv.dtb"    --bct_backup
saving flash command in flashcmd.txt
no_flash ...; prepare rcm blob
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
 Entering RCM boot
[   0.0146 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from --mb1_bin
[   0.0146 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from --psc_bl1_bin
[   0.0146 ] rcm boot with presigned binaries
[   0.0150 ] Generating blob for T23x
[   0.0158 ] tegrahost_v2 --chip 0x23 0 --generateblob blob.xml blob.bin
[   0.0161 ] The number of images in blob is 19
[   0.0163 ] blobsize is 78482997
[   0.0164 ] Added binary blob_uefi_jetson_with_dtb_sigheader.bin.encrypt of size 3657792
[   0.0398 ] Added binary blob_pscfw_t234_prod_sigheader.bin.encrypt of size 310768
[   0.0403 ] Added binary blob_mce_flash_o10_cr_prod_sigheader.bin.encrypt of size 187120
[   0.0404 ] Added binary blob_tsec_t234_sigheader.bin.encrypt of size 176128
[   0.0406 ] Added binary blob_applet_t234_sigheader.bin.encrypt of size 279616
[   0.0407 ] Not supported type: mb2_applet
[   0.0408 ] Added binary blob_mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt of size 439968
[   0.0409 ] Added binary blob_xusb_t234_prod_sigheader.bin.encrypt of size 164864
[   0.0411 ] Added binary blob_nvpva_020_sigheader.fw.encrypt of size 2164640
[   0.0419 ] Added binary blob_display-t234-dce_sigheader.bin.encrypt of size 12070512
[   0.0478 ] Added binary blob_nvdec_t234_prod_sigheader.fw.encrypt of size 294912
[   0.0492 ] Added binary blob_bpmp_t234-TE990M-A1_prod_sigheader.bin.encrypt of size 1027008
[   0.0497 ] Added binary blob_tegra234-bpmp-3701-0004-3737-0000_with_odm_sigheader.dtb.encrypt of size 384768
[   0.0501 ] Added binary blob_camera-rtcpu-t234-rce_sigheader.img.encrypt of size 458096
[   0.0505 ] Added binary blob_adsp-fw_sigheader.bin.encrypt of size 414960
[   0.0506 ] Added binary blob_spe_t234_sigheader.bin.encrypt of size 270336
[   0.0508 ] Added binary blob_tos-optee_t234_sigheader.img.encrypt of size 1633344
[   0.0514 ] Added binary blob_eks_t234_sigheader.img.encrypt of size 9232
[   0.0516 ] Added binary blob_boot.img of size 54288384
[   0.0739 ] Added binary blob_tegra234-p3737-0000+p3701-0004-nv.dtb of size 249445
[   0.1580 ] All RCM required files are saved in rcm_blob folder
done.
*** no-flash flag enabled. Exiting now... ***
User can run above saved command in factory environment without
providing pkc and sbk keys to flash a device
Example:
    $ cd bootloader
    $ sudo bash ./flashcmd.txt
Save initrd flashing command parameters to /home/mona/Linux_for_Tegra/tools/kernel_flash/initrdflashparam.txt
/tmp/tmp.la5gqRGgHh /home/mona/Linux_for_Tegra
writing boot image config in bootimg.cfg
extracting kernel in zImage
extracting ramdisk in initrd.img
/tmp/tmp.la5gqRGgHh/initrd /tmp/tmp.la5gqRGgHh /home/mona/Linux_for_Tegra
77459 blocks
130303 blocks
flashimg0=boot0.img
Success
Cleaning up...
Finish generating flash package.
/home/mona/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh --network usb0 --usb-instance 3-1 --device-instance 0 --flash-only --external-device mmcblk1p1 -c "tools/kernel_flash/flash_l4t_t234_nvme.xml" --network usb0 jetson-agx-orin-devkit internal
# Entry added by NVIDIA initrd flash tool
/home/mona/Linux_for_Tegra/tools/kernel_flash/tmp 127.0.0.1(rw,nohide,insecure,no_subtree_check,async,no_root_squash)
Export list for localhost:
*  Step 1: Build the flashing environment    *
Create flash environment 0
/home/mona/Linux_for_Tegra/bootloader /home/mona/Linux_for_Tegra
Finish creating flash environment 0.
*  Step 2: Boot the device with flash initrd image *
/home/mona/Linux_for_Tegra/temp_initrdflash/bootloader0 /home/mona/Linux_for_Tegra
./tegraflash.py --bl uefi_jetson_with_dtb_sigheader.bin.encrypt --bct br_bct_BR.bct --securedev  --bldtb tegra234-p3737-0000+p3701-0004-nv.dtb --applet rcm_2_encrypt.rcm --applet_softfuse rcm_1_encrypt.rcm --cmd "rcmboot"  --cfg secureflash.xml --chip 0x23 --mb1_bct mb1_bct_MB1_sigheader.bct.encrypt --mem_bct mem_rcm_sigheader.bct.encrypt --mb1_cold_boot_bct mb1_cold_boot_bct_MB1_sigheader.bct.encrypt --mb1_bin mb1_t234_prod_aligned_sigheader.bin.encrypt --psc_bl1_bin psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --mem_bct_cold_boot mem_coldboot_sigheader.bct.encrypt  --bins "psc_fw pscfw_t234_prod_sigheader.bin.encrypt; mts_mce mce_flash_o10_cr_prod_sigheader.bin.encrypt; tsec_fw tsec_t234_sigheader.bin.encrypt; mb2_applet applet_t234_sigheader.bin.encrypt; mb2_bootloader mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt; xusb_fw xusb_t234_prod_sigheader.bin.encrypt; pva_fw nvpva_020_sigheader.fw.encrypt; dce_fw display-t234-dce_sigheader.bin.encrypt; nvdec nvdec_t234_prod_sigheader.fw.encrypt; bpmp_fw bpmp_t234-TE990M-A1_prod_sigheader.bin.encrypt; bpmp_fw_dtb tegra234-bpmp-3701-0004-3737-0000_with_odm_sigheader.dtb.encrypt; rce_fw camera-rtcpu-t234-rce_sigheader.img.encrypt; ape_fw adsp-fw_sigheader.bin.encrypt; spe_fw spe_t234_sigheader.bin.encrypt; tos tos-optee_t234_sigheader.img.encrypt; eks eks_t234_sigheader.img.encrypt; kernel boot0.img; kernel_dtb tegra234-p3737-0000+p3701-0004-nv.dtb"    --bct_backup  --instance 3-1
version 1.0.0
 Entering RCM boot
[   0.0273 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from --mb1_bin
[   0.0273 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from --psc_bl1_bin
[   0.0273 ] rcm boot with presigned binaries
[   0.0276 ] tegrarcm_v2 --instance 3-1 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[   0.0278 ] BR_CID: 0x80012344705DD7972C00000015FF8040
[   0.0390 ] Sending bct_br
[   0.0479 ] Sending mb1
[   0.0484 ] Sending psc_bl1
[   0.0594 ] Sending bct_mb1
[   0.0659 ] Generating blob for T23x
[   0.0672 ] tegrahost_v2 --chip 0x23 0 --generateblob blob.xml blob.bin
[   0.0675 ] The number of images in blob is 19
[   0.0680 ] blobsize is 96732725
[   0.0681 ] Added binary blob_uefi_jetson_with_dtb_sigheader.bin.encrypt of size 3657792
[   0.0964 ] Added binary blob_pscfw_t234_prod_sigheader.bin.encrypt of size 310768
[   0.0965 ] Added binary blob_mce_flash_o10_cr_prod_sigheader.bin.encrypt of size 187120
[   0.0968 ] Added binary blob_tsec_t234_sigheader.bin.encrypt of size 176128
[   0.0969 ] Added binary blob_applet_t234_sigheader.bin.encrypt of size 279616
[   0.0970 ] Not supported type: mb2_applet
[   0.0971 ] Added binary blob_mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt of size 439968
[   0.0972 ] Added binary blob_xusb_t234_prod_sigheader.bin.encrypt of size 164864
[   0.0973 ] Added binary blob_nvpva_020_sigheader.fw.encrypt of size 2164640
[   0.0987 ] Added binary blob_display-t234-dce_sigheader.bin.encrypt of size 12070512
[   0.1040 ] Added binary blob_nvdec_t234_prod_sigheader.fw.encrypt of size 294912
[   0.1055 ] Added binary blob_bpmp_t234-TE990M-A1_prod_sigheader.bin.encrypt of size 1027008
[   0.1060 ] Added binary blob_tegra234-bpmp-3701-0004-3737-0000_with_odm_sigheader.dtb.encrypt of size 384768
[   0.1063 ] Added binary blob_camera-rtcpu-t234-rce_sigheader.img.encrypt of size 458096
[   0.1064 ] Added binary blob_adsp-fw_sigheader.bin.encrypt of size 414960
[   0.1065 ] Added binary blob_spe_t234_sigheader.bin.encrypt of size 270336
[   0.1066 ] Added binary blob_tos-optee_t234_sigheader.img.encrypt of size 1633344
[   0.1072 ] Added binary blob_eks_t234_sigheader.img.encrypt of size 9232
[   0.1073 ] Added binary blob_boot0.img of size 72538112
[   0.1371 ] Added binary blob_tegra234-p3737-0000+p3701-0004-nv.dtb of size 249445
[   0.1912 ] tegrarcm_v2 --instance 3-1 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
[   0.1916 ] BL: version 1.4.0.2-t234-54845784-08a4de08 last_boot_error: 0
[   0.3329 ] Sending bct_mem
[   0.3431 ] Sending blob
[   5.6982 ] RCM-boot started
*  Step 3: Start the flashing process *
Waiting for target to boot-up...
^C
(base) mona@DOS:~/Linux_for_Tegra$
I have attached the complete log in txt file
microsd_flashing_log.txt (254.3 KB)
Also, whenever I see
67108864 bytes (67 MB, 64 MiB) copied, 0.153187 s, 438 MB/s
	Sync'ing esp.img ... done.
a window pops up with 67 MB in it.
You should dump device log from serial console.
So far you only shared the host side log.
Also, your previous host side said the flash to emmc is successful… If you cannot boot up, you also need to share serial console log to clarify…
And most important point. This is not NV devkit. NV image does not guarantee this would work.
Hi Wayne,
How should I do this if the OS Screen is not booting up? Could you please guide me with this?
What is needed for this? Is there a link or tutorial in this respect?
Again, this step is only for NV devkit. If your carrier board cannot do this, then please contact the board vendor.
Also, could you please tell why in the log file I have attached we get value out of range errors?
Which file are you talking about?
Checked. Do not matter. Please just focus on dumping the serial console log.
Anything you saw in the host side log won’t give you any useful hint.
