Jetson AGX Orin 32GB couldn't flash image
Hi teams,
我们手上有一批 Jetson AGX Orin 32GB 的SOM,在Linux 36.4.3下无法通过 flash.sh 刷机,报错信息might be timeout in USB write.。以下是详细日志信息:
flash log:
# L4T BSP Information:
# R36 , REVISION: 4.3
# User release: 0.0
ECID is 0x80012344705DF19B7C000000120180C0
# Target Board Information:
# Name: jetson-agx-orin-devkit, Board Family: generic, SoC: Tegra 234,
# OpMode: production, Boot Authentication: NS,
# Disk encryption: disabled ,
copying device_config(/home/cbpm/Nvidia/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-device-p3701-0000.dts)... done.
copying misc_config(/home/cbpm/Nvidia/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-misc-p3701-0000.dts)... done.
copying emc_fuse_dev_params(/home/cbpm/Nvidia/Linux_for_Tegra/bootloader/generic/BCT/tegra234-br-bct-diag-boot.dts)... done.
copying minratchet_config(/home/cbpm/Nvidia/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-ratchet-p3701-0000.dts)... done.
Existing emcfuse(/home/cbpm/Nvidia/Linux_for_Tegra/bootloader/fuse_t234.xml) reused.
./tegraflash.py --chip "0x23" --applet "/home/cbpm/Nvidia/Linux_for_Tegra/bootloader/mb1_t234_prod.bin" --skipuid --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3701-0000.dts --misc_config tegra234-mb1-bct-misc-p3701-0000.dts --bins "mb2_applet applet_t234.bin" --minratchet_config tegra234-mb1-bct-ratchet-p3701-0000.dts --cmd "readfuses fuse_t234.bin fuse_t234.xml; dump eeprom cvm cvm.bin; dump try_custinfo custinfo_out.bin; reboot recovery"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[   0.3105 ] Reading fuses
[   0.3137 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.3182 ] File rcm_state open failed
[   0.3183 ] ERROR: failed to read rcm_state
[   0.3183 ]
[   0.3281 ] tegrasign_v3.py --key None --getmode mode.txt
[   0.3288 ] Assuming zero filled SBK key
[   0.3196 ] Pre-processing config: tegra234-mb1-bct-device-p3701-0000.dts
[   0.5666 ] Pre-processing config: tegra234-mb1-bct-misc-p3701-0000.dts
[   0.6743 ] Pre-processing config: tegra234-mb1-bct-ratchet-p3701-0000.dts
[   0.7183 ] Parsing partition layout
[   0.7235 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[   0.7394 ] Kernel DTB used: None
[   0.7395 ] WARNING: dce base dtb is not provided
[   0.7395 ] Parsing partition layout
[   0.7420 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[   0.7462 ] Creating list of images to be signed
[   0.7500 ] Generating ratchet blob
[   0.7502 ] Generating coldboot mb1-bct
[   0.7538 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3701-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[   0.7556 ] MB1-BCT version: 0.13
[   0.7863 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   0.7876 ] Added Platform Config 9 data with size :- 100
[   0.7882 ] Parsing config file :tegra234-mb1-bct-ratchet-p3701-0000_cpp.dtb
[   0.7894 ] Updating mb1-bct with firmware information
[   0.7920 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[   0.8051 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[   0.8083 ] Generating SHA2 Hash for mb1bct
[   0.8399 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[   0.8440 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[   0.8372 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   0.8408 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   0.8556 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.8559 ] Assuming zero filled SBK key
[   0.8637 ] Warning: pub_key.key is not found
[   0.8582 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   0.8641 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --ratchet_blob ratchet_blob.bin --list images_list.xml zerosbk
[   0.8668 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.8864 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.8886 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.9053 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.9065 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.9233 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   0.9240 ] adding BCH for mb2_t234_aligned.bin
[   0.9412 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.9800 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   0.9814 ] adding BCH for mb2_t234_aligned.bin
[   1.0186 ] Filling MB1 storage info
[   1.0188 ] Parsing dev params for multi chains
[   1.1036 ] Generating br-bct
[   1.1068 ] Updating dev and MSS params in BR BCT
[   1.1070 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   1.1115 ] Updating bl info
[   1.1133 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin
[   1.1150 ] WARNING: boot chain is not completed. set to 0
[   1.1203 ] Generating signatures
[   1.1301 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[   1.1305 ] Assuming zero filled SBK key
[   1.1948 ] Warning: pub_key.key is not found
[   1.1857 ] Parsing dev params for multi chains
[   1.1857 ] Generating br-bct
[   1.1879 ] Updating dev and MSS params in BR BCT
[   1.1881 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   1.1926 ] Updating bl info
[   1.1952 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[   1.1991 ] WARNING: boot chain is not completed. set to 0
[   1.2060 ] Generating SHA2 Hash
[   1.2204 ] Sha saved in br_bct_BR.sha
[   1.2112 ] Get Signed section of bct
[   1.2150 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[   1.2182 ] Signing BCT
[   1.2281 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   1.2286 ] Assuming zero filled SBK key
[   1.2367 ] Sha saved in br_bct_BR.sha
[   1.2376 ] Warning: pub_key.key is not found
[   1.2279 ] Updating BCT with signature
[   1.2302 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[   1.2311 ] Offset :4608 Len :3584
[   1.2339 ] Generating SHA2 Hash
[   1.2437 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[   1.2440 ] Assuming zero filled SBK key
[   1.2529 ] Sha saved in br_bct_BR.sha
[   1.2452 ] Updating BCT with SHA2 Hash
[   1.2469 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[   1.2506 ] Offset :4608 Len :3584
[   1.2520 ] Offset :68 Len :8124
[   1.2531 ] Generating coldboot mb1-bct
[   1.2562 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3701-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[   1.2594 ] MB1-BCT version: 0.13
[   1.2649 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   1.2660 ] Added Platform Config 9 data with size :- 100
[   1.2660 ]
[   1.2660 ] Parsing config file :tegra234-mb1-bct-ratchet-p3701-0000_cpp.dtb
[   1.2661 ]
[   1.2662 ] Updating mb1-bct with firmware information
[   1.2686 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[   1.2755 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[   1.2787 ] Generating SHA2 Hash for mb1bct
[   1.2941 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[   1.2980 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[   1.2913 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   1.2941 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   1.3056 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   1.3063 ] Assuming zero filled SBK key
[   1.3143 ] Warning: pub_key.key is not found
[   1.3072 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   1.3114 ] Generating recovery mb1-bct
[   1.3154 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3701-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[   1.3180 ] MB1-BCT version: 0.13
[   1.3214 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[   1.3224 ] Added Platform Config 9 data with size :- 100
[   1.3229 ]
[   1.3229 ] Parsing config file :tegra234-mb1-bct-ratchet-p3701-0000_cpp.dtb
[   1.3229 ]
[   1.3229 ] Updating mb1-bct with firmware information
[   1.3254 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[   1.3347 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[   1.3371 ] Generating SHA2 Hash for mb1bct
[   1.3507 ] Sha saved in mb1_bct_MB1_aligned.sha
[   1.3554 ] Sha saved in mb1_bct_MB1.sha
[   1.3495 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[   1.3525 ] adding BCH for mb1_bct_MB1_aligned.bct
[   1.3648 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   1.3651 ] Assuming zero filled SBK key
[   1.3753 ] Warning: pub_key.key is not found
[   1.3683 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   1.3713 ] Info: Skip generating mem_bct because sdram_config is not defined
[   1.3713 ] Copying signatures
[   1.3721 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[   1.4016 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[   1.4021 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[   1.4021 ] Boot Rom communication
[   1.4050 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[   1.4074 ] BR_CID: 0x80012344705DF19B7C000000120180C0
[   1.5784 ] Sending bct_br
[   1.6762 ] Sending mb1
[   1.6839 ] Sending psc_bl1
[   1.7222 ] Sending bct_mb1
[   1.7459 ] Boot Rom communication completed
[   1.7619 ] tegrahost_v2 --chip 0x23 0 --align applet_t234_aligned.bin
[   1.7653 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --ratchet_blob ratchet_blob.bin --appendsigheader applet_t234_aligned.bin zerosbk
[   1.7689 ] adding BCH for applet_t234_aligned.bin
[   1.7996 ] tegrasign_v3.py --key None --list applet_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   1.7998 ] Assuming zero filled SBK key
[   1.8107 ] Warning: pub_key.key is not found
[   1.8040 ] tegrahost_v2 --chip 0x23 0 --updatesigheader applet_t234_aligned_sigheader.bin.encrypt applet_t234_aligned_sigheader.bin.hash zerosbk
[   1.8106 ] Sending mb2_applet...
[   1.8124 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download applet applet_t234_sigheader.bin.encrypt
[   1.8143 ] BL: version 1.4.0.4-t234-54845784-e89ea9bc last_boot_error: 0
[   1.9702 ] Sending applet
[   2.1138 ] completed
[   2.1180 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   2.1219 ] MB2 Applet version 01.00.0000
[   2.3490 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   2.3510 ] MB2 Applet version 01.00.0000
[   2.4875 ] Parsing fuse info as per xml file
[   2.4901 ] tegraparser_v2 --chip 0x23 0 --get_fuse_names fuse_t234.xml read_fuse_names.txt
[   2.4932 ] MagicId=0x45535546 version=0x2
[   2.4952 ] trying to read fuse with MB2 Applet
[   2.4973 ] tegraparser_v2 --chip 0x23 0 --read_fusetype PublicKeyHash read_fuse.bin
[   2.5024 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   2.5055 ] MB2 Applet version 01.00.0000
[   2.6335 ] Saved read fuses in file __fuse_read_scatter.bin
[   2.6753 ] Fuse read successful
[   2.7094 ] tegraparser_v2 --chip 0x23 0 --read_fusetype PkcPubkeyHash1 read_fuse.bin
[   2.7141 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   2.7160 ] MB2 Applet version 01.00.0000
[   2.8483 ] Saved read fuses in file __fuse_read_scatter.bin
[   2.8935 ] Fuse read successful
[   2.9200 ] tegraparser_v2 --chip 0x23 0 --read_fusetype PkcPubkeyHash2 read_fuse.bin
[   2.9264 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   2.9285 ] MB2 Applet version 01.00.0000
[   3.0619 ] Saved read fuses in file __fuse_read_scatter.bin
[   3.1080 ] Fuse read successful
[   3.1378 ] tegraparser_v2 --chip 0x23 0 --read_fusetype BootSecurityInfo read_fuse.bin
[   3.1411 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   3.1432 ] MB2 Applet version 01.00.0000
[   3.2681 ] Saved read fuses in file __fuse_read_scatter.bin
[   3.3152 ] Fuse read successful
[   3.3436 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ArmJtagDisable read_fuse.bin
[   3.3492 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   3.3513 ] MB2 Applet version 01.00.0000
[   3.4873 ] Saved read fuses in file __fuse_read_scatter.bin
[   3.5369 ] Fuse read successful
[   3.5679 ] tegraparser_v2 --chip 0x23 0 --read_fusetype SecurityMode read_fuse.bin
[   3.5732 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   3.5771 ] MB2 Applet version 01.00.0000
[   3.7089 ] Saved read fuses in file __fuse_read_scatter.bin
[   3.7743 ] Fuse read successful
[   3.8002 ] tegraparser_v2 --chip 0x23 0 --read_fusetype SwReserved read_fuse.bin
[   3.8051 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   3.8067 ] MB2 Applet version 01.00.0000
[   3.9423 ] Saved read fuses in file __fuse_read_scatter.bin
[   4.0006 ] Fuse read successful
[   4.0358 ] tegraparser_v2 --chip 0x23 0 --read_fusetype DebugAuthentication read_fuse.bin
[   4.0406 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   4.0429 ] MB2 Applet version 01.00.0000
[   4.1823 ] Saved read fuses in file __fuse_read_scatter.bin
[   4.2276 ] Fuse read successful
[   4.2532 ] tegraparser_v2 --chip 0x23 0 --read_fusetype OdmInfo read_fuse.bin
[   4.2590 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   4.2616 ] MB2 Applet version 01.00.0000
[   4.3970 ] Saved read fuses in file __fuse_read_scatter.bin
[   4.4449 ] Fuse read successful
[   4.4711 ] tegraparser_v2 --chip 0x23 0 --read_fusetype OdmId read_fuse.bin
[   4.4761 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   4.4777 ] MB2 Applet version 01.00.0000
[   4.6213 ] Saved read fuses in file __fuse_read_scatter.bin
[   4.6812 ] Fuse read successful
[   4.7084 ] tegraparser_v2 --chip 0x23 0 --read_fusetype OdmLock read_fuse.bin
[   4.7148 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   4.7171 ] MB2 Applet version 01.00.0000
[   4.8375 ] Saved read fuses in file __fuse_read_scatter.bin
[   4.8880 ] Fuse read successful
[   4.9117 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm0 read_fuse.bin
[   4.9148 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   4.9179 ] MB2 Applet version 01.00.0000
[   5.0432 ] Saved read fuses in file __fuse_read_scatter.bin
[   5.0965 ] Fuse read successful
[   5.1243 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm1 read_fuse.bin
[   5.1298 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   5.1309 ] MB2 Applet version 01.00.0000
[   5.2538 ] Saved read fuses in file __fuse_read_scatter.bin
[   5.2984 ] Fuse read successful
[   5.3253 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm2 read_fuse.bin
[   5.3332 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   5.3355 ] MB2 Applet version 01.00.0000
[   5.4636 ] Saved read fuses in file __fuse_read_scatter.bin
[   5.5093 ] Fuse read successful
[   5.5332 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm3 read_fuse.bin
[   5.5371 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   5.5390 ] MB2 Applet version 01.00.0000
[   5.6634 ] Saved read fuses in file __fuse_read_scatter.bin
[   5.7124 ] Fuse read successful
[   5.7389 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm4 read_fuse.bin
[   5.7432 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   5.7451 ] MB2 Applet version 01.00.0000
[   5.8719 ] Saved read fuses in file __fuse_read_scatter.bin
[   5.9159 ] Fuse read successful
[   5.9416 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm5 read_fuse.bin
[   5.9476 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   5.9503 ] MB2 Applet version 01.00.0000
[   6.0832 ] Saved read fuses in file __fuse_read_scatter.bin
[   6.1315 ] Fuse read successful
[   6.1626 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm6 read_fuse.bin
[   6.1682 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   6.1710 ] MB2 Applet version 01.00.0000
[   6.2982 ] Saved read fuses in file __fuse_read_scatter.bin
[   6.3476 ] Fuse read successful
[   6.3792 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm7 read_fuse.bin
[   6.3842 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   6.3859 ] MB2 Applet version 01.00.0000
[   6.5277 ] Saved read fuses in file __fuse_read_scatter.bin
[   6.5743 ] Fuse read successful
[   6.6053 ] tegraparser_v2 --chip 0x23 0 --read_fusetype Sku read_fuse.bin
[   6.6099 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   6.6120 ] MB2 Applet version 01.00.0000
[   6.7583 ] Saved read fuses in file __fuse_read_scatter.bin
[   6.8194 ] Fuse read successful
[   6.8631 ] tegraparser_v2 --chip 0x23 0 --read_fusetype Uid read_fuse.bin
[   6.8680 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   6.8711 ] MB2 Applet version 01.00.0000
[   7.0095 ] Saved read fuses in file __fuse_read_scatter.bin
[   7.0572 ] Fuse read successful
[   7.0974 ] tegraparser_v2 --chip 0x23 0 --read_fusetype OptEmcDisable read_fuse.bin
[   7.1036 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   7.1051 ] MB2 Applet version 01.00.0000
[   7.2345 ] Saved read fuses in file __fuse_read_scatter.bin
[   7.2906 ] Fuse read successful
[   7.3166 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   7.3189 ] MB2 Applet version 01.00.0000
[   7.4455 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   7.4476 ] MB2 Applet version 01.00.0000
[   7.5775 ] Retrieving board information
[   7.5793 ] tegrarcm_v2 --chip 0x23 0 --oem platformdetails chip chip_info.bin
[   7.5816 ] MB2 Applet version 01.00.0000
[   7.7103 ] Saved platform info in chip_info.bin
[   7.7442 ] Chip minor revision: 1
[   7.7443 ] Bootrom revision: 0x7
[   7.7444 ] Ram code: 0x1
[   7.7444 ] Chip sku: 0xd2
[   7.7445 ] Chip Sample: prod
[   7.7788 ] Retrieving EEPROM data
[   7.7790 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/cbpm/Nvidia/Linux_for_Tegra/bootloader/cvm.bin --chip 0x23 0
[   7.7802 ] MB2 Applet version 01.00.0000
[   7.9160 ] Saved platform info in /home/cbpm/Nvidia/Linux_for_Tegra/bootloader/cvm.bin
[   8.0126 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   8.0144 ] MB2 Applet version 01.00.0000
[   8.1449 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   8.1469 ] MB2 Applet version 01.00.0000
[   8.2718 ] Dumping customer Info
[   8.2742 ] tegrarcm_v2 --chip 0x23 0 --oem dump bct tmp.bct
[   8.2753 ] MB2 Applet version 01.00.0000
[   8.4006 ] 0000000054220302: E> NV3P_SERVER: Failed to get address for br bct from nv3p helper.
[   8.5085 ]
[   8.5085 ]
[   8.5085 ] Error: try getting custinfo fail. Moving on
[   8.5086 ] Rebooting to recovery mode
[   8.5250 ] tegrarcm_v2 --chip 0x23 0 --ismb2
[   8.6532 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   8.6559 ] MB2 Applet version 01.00.0000
[   8.7923 ] Booting to recovery mode
[   8.7950 ] tegrarcm_v2 --chip 0x23 0 --reboot recovery
[   8.7974 ] MB2 Applet version 01.00.0000
Board ID(3701) version(501) sku(0004) revision(E.0)
Preset RAMCODE is 1
Chip SKU(00:00:00:D2) ramcode(1) fuselevel(fuselevel_production) board_FAB(501)
Copy /home/cbpm/Nvidia/Linux_for_Tegra/kernel/dtb/tegra234-p3737-0000+p3701-0004-nv.dtb to /home/cbpm/Nvidia/Linux_for_Tegra/kernel/dtb/tegra234-p3737-0000+p3701-0004-nv.dtb.rec
Using UUID c6104ab3-f71f-4579-b220-256255488656 for mounting root APP partition.
copying bctfile(/home/cbpm/Nvidia/Linux_for_Tegra/bootloader/generic/BCT/tegra234-p3701-0000-sdram-l4t.dts)... done.
copying pinmux_config(/home/cbpm/Nvidia/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-pinmux-p3701-0000-a04.dtsi)... done.
copying gpioint_config(/home/cbpm/Nvidia/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-gpioint-p3701-0000.dts)... done.
copying pmic_config(/home/cbpm/Nvidia/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-pmic-p3701-0005.dts)... done.
copying pmc_config(/home/cbpm/Nvidia/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-padvoltage-p3701-0000-a04.dtsi)... done.
copying deviceprod_config(/home/cbpm/Nvidia/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-cprod-p3701-0000.dts)... done.
copying prod_config(/home/cbpm/Nvidia/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-prod-p3701-0000.dts)... done.
copying scr_config(/home/cbpm/Nvidia/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb2-bct-scr-p3701-0000.dts)... done.
copying wb0sdram(/home/cbpm/Nvidia/Linux_for_Tegra/bootloader/generic/BCT/tegra234-p3701-0000-wb0sdram-l4t.dts)... done.
copying bootrom_config(/home/cbpm/Nvidia/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-reset-p3701-0000.dts)... done.
Existing uphylane_config(/home/cbpm/Nvidia/Linux_for_Tegra/bootloader/tegra234-mb1-bct-uphylane-si.dtsi) reused.
copying dev_params(/home/cbpm/Nvidia/Linux_for_Tegra/bootloader/generic/BCT/tegra234-br-bct-p3701-0000.dts)... done.
copying dev_params_b(/home/cbpm/Nvidia/Linux_for_Tegra/bootloader/generic/BCT/tegra234-br-bct_b-p3701-0000.dts)... done.
copying mb2bct_cfg(/home/cbpm/Nvidia/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb2-bct-misc-p3701-0000.dts)... done.
Existing pscfwfile(/home/cbpm/Nvidia/Linux_for_Tegra/bootloader/pscfw_t234_prod.bin) reused.
Existing pscbl1file(/home/cbpm/Nvidia/Linux_for_Tegra/bootloader/psc_bl1_t234_prod.bin) reused.
Existing mtsmcefile(/home/cbpm/Nvidia/Linux_for_Tegra/bootloader/mce_flash_o10_cr_prod.bin) reused.
Existing tscfwfile(/home/cbpm/Nvidia/Linux_for_Tegra/bootloader/tsec_t234.bin) reused.
Existing mb2applet(/home/cbpm/Nvidia/Linux_for_Tegra/bootloader/applet_t234.bin) reused.
Existing bootloader(/home/cbpm/Nvidia/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
copying initrd(/home/cbpm/Nvidia/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
bl is uefi
Making Boot image... done.
Not signing of boot.img
Making recovery ramdisk for recovery image...
Re-generating recovery ramdisk for recovery image...
/home/cbpm/Nvidia/Linux_for_Tegra/bootloader/ramdisk_tmp /home/cbpm/Nvidia/Linux_for_Tegra/bootloader /home/cbpm/Nvidia/Linux_for_Tegra
72720 blocks
gzip: /home/cbpm/Nvidia/Linux_for_Tegra/kernel/Image: not in gzip format
_BASE_KERNEL_VERSION=5.15.148-tegra
96739 blocks
Making Recovery image...
copying recdtbfile(/home/cbpm/Nvidia/Linux_for_Tegra/kernel/dtb/tegra234-p3737-0000+p3701-0004-nv.dtb.rec)... done.
20+0 records in
20+0 records out
20 bytes copied, 0.00191356 s, 10.5 kB/s
Existing sosfile(/home/cbpm/Nvidia/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
Existing tegraboot(/home/cbpm/Nvidia/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing cpu_bootloader(/home/cbpm/Nvidia/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing mb2blfile(/home/cbpm/Nvidia/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing xusbfile(/home/cbpm/Nvidia/Linux_for_Tegra/bootloader/xusb_t234_prod.bin) reused.
Existing pvafile(/home/cbpm/Nvidia/Linux_for_Tegra/bootloader/nvpva_020.fw) reused.
Existing dcefile(/home/cbpm/Nvidia/Linux_for_Tegra/bootloader/display-t234-dce.bin) reused.
Existing nvdecfile(/home/cbpm/Nvidia/Linux_for_Tegra/bootloader/nvdec_t234_prod.fw) reused.
Existing psc_rf(/home/cbpm/Nvidia/Linux_for_Tegra/bootloader/psc_rf_t234_prod.bin) reused.
Existing mb2_rf(/home/cbpm/Nvidia/Linux_for_Tegra/bootloader/mb2rf_t234.bin) reused.
Existing mb1file(/home/cbpm/Nvidia/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
Existing bpffile(/home/cbpm/Nvidia/Linux_for_Tegra/bootloader/bpmp_t234-TE990M-A1_prod.bin) reused.
copying bpfdtbfile(/home/cbpm/Nvidia/Linux_for_Tegra/bootloader/generic/tegra234-bpmp-3701-0004-3737-0000.dtb)... done.
Existing camerafw(/home/cbpm/Nvidia/Linux_for_Tegra/bootloader/camera-rtcpu-t234-rce.img) reused.
Existing apefile(/home/cbpm/Nvidia/Linux_for_Tegra/bootloader/adsp-fw.bin) reused.
Existing spefile(/home/cbpm/Nvidia/Linux_for_Tegra/bootloader/spe_t234.bin) reused.
Existing wb0boot(/home/cbpm/Nvidia/Linux_for_Tegra/bootloader/sc7_t234_prod.bin) reused.
Existing tosfile(/home/cbpm/Nvidia/Linux_for_Tegra/bootloader/tos-optee_t234.img) reused.
Existing eksfile(/home/cbpm/Nvidia/Linux_for_Tegra/bootloader/eks_t234.img) reused.
copying dtbfile(/home/cbpm/Nvidia/Linux_for_Tegra/kernel/dtb/tegra234-p3737-0000+p3701-0004-nv.dtb)... done.
Copying nv_boot_control.conf to rootfs
Reusing existing system.img...
done.
Not signing of kernel-dtb
Existing tbcfile(/home/cbpm/Nvidia/Linux_for_Tegra/bootloader/uefi_jetson.bin) reused.
Existing rcm_tbcfile(/home/cbpm/Nvidia/Linux_for_Tegra/bootloader/uefi_jetson_minimal.bin) reused.
Skip generating EFI system partition image.
copying tbcdtbfile(/home/cbpm/Nvidia/Linux_for_Tegra/kernel/dtb/tegra234-p3737-0000+p3701-0004-nv.dtb)... done.
copying cfgfile(/home/cbpm/Nvidia/Linux_for_Tegra/bootloader/generic/cfg/flash_t234_qspi_sdmmc.xml) to flash.xml... done.
Existing flashapp(/home/cbpm/Nvidia/Linux_for_Tegra/bootloader/tegraflash.py) reused.
copying overlay_dtb(/home/cbpm/Nvidia/Linux_for_Tegra/kernel/dtb/L4TConfiguration.dtbo)... done.
copying overlay_dtb(/home/cbpm/Nvidia/Linux_for_Tegra/kernel/dtb/tegra234-carveouts.dtbo)... done.
copying overlay_dtb(/home/cbpm/Nvidia/Linux_for_Tegra/kernel/dtb/tegra-optee.dtbo)... done.
copying overlay_dtb(/home/cbpm/Nvidia/Linux_for_Tegra/kernel/dtb/tegra234-dcb-p3737-0000-hdmi.dtbo)... done.
/home/cbpm/Nvidia/Linux_for_Tegra/bootloader/L4TConfiguration_updated.dts: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
/home/cbpm/Nvidia/Linux_for_Tegra/bootloader/L4TConfiguration.dtbo: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
Existing overlay_dtb(/home/cbpm/Nvidia/Linux_for_Tegra/bootloader/tegra234-dcb-p3737-0000-hdmi.dtbo) reused.
./tegraflash.py  --bl uefi_jetson_minimal_with_dtb.bin  --odmdata gbe-uphy-config-22,hsstp-lane-map-3,nvhs-uphy-config-0,hsio-uphy-config-0,gbe0-enable-10g  --overlay_dtb L4TConfiguration.dtbo,tegra234-carveouts.dtbo,tegra-optee.dtbo,tegra234-dcb-p3737-0000-hdmi.dtbo,  --dce_overlay_dtb tegra234-dcb-p3737-0000-hdmi.dtbo  --bldtb tegra234-p3737-0000+p3701-0004-nv.dtb --applet mb1_t234_prod.bin --cmd "flash; reboot"  --cfg flash.xml --chip "0x23" --concat_cpubl_bldtb --cpubl uefi_jetson.bin --cpubl_rcm uefi_jetson_minimal.bin --minratchet_config tegra234-mb1-bct-ratchet-p3701-0000.dts --device_config tegra234-mb1-bct-device-p3701-0000.dts --misc_config tegra234-mb1-bct-misc-p3701-0000.dts --pinmux_config tegra234-mb1-bct-pinmux-p3701-0000-a04.dtsi --gpioint_config tegra234-mb1-bct-gpioint-p3701-0000.dts --pmic_config tegra234-mb1-bct-pmic-p3701-0005.dts --pmc_config tegra234-mb1-bct-padvoltage-p3701-0000-a04.dtsi --deviceprod_config tegra234-mb1-bct-cprod-p3701-0000.dts --prod_config tegra234-mb1-bct-prod-p3701-0000.dts --scr_config tegra234-mb2-bct-scr-p3701-0000.dts --wb0sdram_config tegra234-p3701-0000-wb0sdram-l4t.dts --br_cmd_config tegra234-mb1-bct-reset-p3701-0000.dts --uphy tegra234-mb1-bct-uphylane-si.dtsi --dev_params tegra234-br-bct-p3701-0000.dts,tegra234-br-bct_b-p3701-0000.dts --mb2bct_cfg tegra234-mb2-bct-misc-p3701-0000.dts  --bins "psc_fw pscfw_t234_prod.bin; mts_mce mce_flash_o10_cr_prod.bin; tsec_fw tsec_t234.bin; mb2_applet applet_t234.bin; mb2_bootloader mb2_t234.bin; xusb_fw xusb_t234_prod.bin; pva_fw nvpva_020.fw; dce_fw display-t234-dce.bin; nvdec nvdec_t234_prod.fw; bpmp_fw bpmp_t234-TE990M-A1_prod.bin; bpmp_fw_dtb tegra234-bpmp-3701-0004-3737-0000.dtb; rce_fw camera-rtcpu-t234-rce.img; ape_fw adsp-fw.bin; spe_fw spe_t234.bin; tos tos-optee_t234.img; eks eks_t234.img"  --sdram_config tegra234-p3701-0000-sdram-l4t.dts  --cust_info custinfo_out.bin  --bct_backup  --boot_chain A  --ramcode 1
saving flash command in /home/cbpm/Nvidia/Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /home/cbpm/Nvidia/Linux_for_Tegra/bootloader/flash_win.bat
*** Flashing target device started. ***
version 1.0.0
[   0.1092 ] tegrasign_v3.py --key None --getmode mode.txt
[   0.1101 ] Assuming zero filled SBK key
[   0.1082 ] Parsing partition layout
[   0.1108 ] tegraparser_v2 --pt flash.xml.tmp
[   0.1257 ] Change tegra234-bpmp-3701-0004-3737-0000.dtb to tegra234-bpmp-3701-0004-3737-0000_with_odm.dtb
[   0.1269 ] Change tegra234-bpmp-3701-0004-3737-0000.dtb to tegra234-bpmp-3701-0004-3737-0000_with_odm.dtb
[   0.3375 ] /usr/bin/python3 dtbcheck.py -c t234 -o tegra234-bpmp-3701-0004-3737-0000_with_odm.dtb tegra234-bpmp-3701-0004-3737-0000_with_odm_tmp.dtb
[   1.3302 ] Concatenating L4TConfiguration.dtbo,tegra234-carveouts.dtbo,tegra-optee.dtbo,tegra234-dcb-p3737-0000-hdmi.dtbo to tegra234-p3737-0000+p3701-0004-nv_with_odm_overlay.dtb.updated
[   1.3310 ] Concatenating bl dtb to cpubl binary
[   1.3388 ] Concatenating bl dtb:(tegra234-p3737-0000+p3701-0004-nv_with_odm_overlay.dtb.updated), to cpubl binary: uefi_jetson_minimal.bin
[   1.3459 ] MB2 binary: mb2_t234.bin
[   1.3461 ] Pre-processing mb2bct config: tegra234-mb2-bct-misc-p3701-0000.dts
[   1.4002 ] Pre-processing mb2bct config: tegra234-mb2-bct-scr-p3701-0000.dts
[   2.0480 ] Generating coldboot mb2-bct
[   2.0482 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_cold_boot_bct.cfg --mb2bctcfg tegra234-mb2-bct-misc-p3701-0000_cpp.dtb --scr tegra234-mb2-bct-scr-p3701-0000_cpp.dtb
[   2.0500 ] WARNING: unknown property 'tfc_version'
[   2.0559 ] WARNING: unknown property 'addr_header_version'
[   2.0783 ] Updating mb2-bct with storage information
[   2.0802 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_cold_boot_bct_MB2.bct --updatestorageinfo flash.xml.bin
[   2.0852 ] Concatenating mb2-bct to mb2 binary
[   2.0853 ] mb2_bin_file = mb2_t234.bin
[   2.0853 ] mb2_bct_file = mb2_cold_boot_bct_MB2.bct
[   2.1259 ] DCE binary: display-t234-dce.bin
[   2.1260 ] Kernel DTB used: kernel_tegra234-p3737-0000+p3701-0004-nv.dtb
[   2.1260 ] Concatenating kernel_tegra234-p3737-0000+p3701-0004-nv.dtb to fdtoverlay(tegra234-dcb-p3737-0000-hdmi.dtbo)
[   2.1793 ] Concatenating kernel-dtb to dce-fw binary
[   2.1794 ] dce_bin = display-t234-dce.bin
[   2.1794 ] kernel_dtb = kernel_tegra234-p3737-0000+p3701-0004-nv_with_dce_overlay.dtb
[   2.1794 ] dce_with_dtb = display-t234-dce_with_kernel_tegra234-p3737-0000+p3701-0004-nv_with_dce_overlay.bin
[   2.2565 ] Update display-t234-dce_with_kernel_tegra234-p3737-0000+p3701-0004-nv_with_dce_overlay.bin to dce_fw partitions
[   2.2618 ] Parsing partition layout
[   2.2640 ] tegraparser_v2 --pt flash.xml.tmp
[   2.2686 ] Creating list of images to be signed
[   2.2707 ] Generating ratchet blob
[   2.2708 ] Pre-processing config: tegra234-mb1-bct-reset-p3701-0000.dts
[   2.3066 ] Pre-processing config: tegra234-mb1-bct-device-p3701-0000.dts
[   2.3423 ] Pre-processing config: tegra234-mb1-bct-cprod-p3701-0000.dts
[   2.3808 ] Pre-processing config: tegra234-mb1-bct-gpioint-p3701-0000.dts
[   2.4657 ] Pre-processing config: tegra234-mb1-bct-misc-p3701-0000.dts
[   2.5135 ] Pre-processing config: tegra234-mb1-bct-pinmux-p3701-0000-a04.dtsi
[   2.5860 ] Pre-processing config: tegra234-mb1-bct-padvoltage-p3701-0000-a04.dtsi
[   2.6223 ] Pre-processing config: tegra234-mb1-bct-pmic-p3701-0005.dts
[   2.6924 ] Pre-processing config: tegra234-mb1-bct-prod-p3701-0000.dts
[   2.7217 ] Pre-processing config: tegra234-p3701-0000-sdram-l4t.dts
[   7.6037 ] Pre-processing config: tegra234-mb1-bct-uphylane-si.dtsi
[   7.6412 ] Pre-processing config: tegra234-p3701-0000-wb0sdram-l4t.dts
[  12.4216 ] Pre-processing config: tegra234-mb1-bct-ratchet-p3701-0000.dts
[  12.4600 ] Generating coldboot mb1-bct
[  12.4624 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --wb0sdram tegra234-p3701-0000-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3701-0000-a04_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3701-0000-a04_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3701-0005_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3701-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3701-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3701-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3701-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3701-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[  12.4654 ] MB1-BCT version: 0.13
[  12.4695 ] Parsing config file :tegra234-mb1-bct-pinmux-p3701-0000-a04_cpp.dtb
[  12.4705 ] Added Platform Config 0 data with size :- 3040
[  12.4864 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3701-0000-a04_cpp.dtb
[  12.4871 ] WARNING: unknown node 'g2'
[  12.4876 ] WARNING: unknown node 'g2'
[  12.4882 ] WARNING: unknown node 'g9'
[  12.4882 ] Added Platform Config 2 data with size :- 24
[  12.4883 ]
[  12.4883 ] Parsing config file :tegra234-mb1-bct-pmic-p3701-0005_cpp.dtb
[  12.4883 ] WARNING: unknown property 'i2c-update-only'
[  12.4883 ] WARNING: unknown property 'i2c-verify-only'
[  12.4884 ] WARNING: unknown property 'i2c-update-verify'
[  12.4884 ] WARNING: unknown property 'i2c-update-only'
[  12.4884 ] WARNING: unknown property 'i2c-verify-only'
[  12.4885 ] WARNING: unknown property 'i2c-update-only'
[  12.4885 ] WARNING: unknown property 'i2c-verify-only'
[  12.4885 ] Added Platform Config 4 data with size :- 844
[  12.4886 ]
[  12.4886 ] Parsing config file :tegra234-mb1-bct-reset-p3701-0000_cpp.dtb
[  12.4886 ] Added Platform Config 3 data with size :- 52
[  12.4886 ]
[  12.4886 ] Parsing config file :tegra234-mb1-bct-prod-p3701-0000_cpp.dtb
[  12.4886 ] WARNING: unknown property 'major'
[  12.4886 ] WARNING: unknown property 'minor'
[  12.4887 ] Added Platform Config 5 data with size :- 524
[  12.4887 ]
[  12.4887 ] Parsing config file :tegra234-mb1-bct-gpioint-p3701-0000_cpp.dtb
[  12.4887 ] WARNING: unknown property 'major'
[  12.4887 ] WARNING: unknown property 'minor'
[  12.4887 ] Added Platform Config 7 data with size :- 380
[  12.4887 ]
[  12.4887 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[  12.4887 ] Added Platform Config 8 data with size :- 24
[  12.4888 ]
[  12.4888 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[  12.4888 ] Added Platform Config 9 data with size :- 100
[  12.4888 ]
[  12.4889 ] Parsing config file :tegra234-mb1-bct-cprod-p3701-0000_cpp.dtb
[  12.4889 ] ModuleCount 0 NumProdNames 0
[  12.4889 ] Added Platform Config 6 data with size :- 16
[  12.4889 ]
[  12.4889 ] Parsing config file :tegra234-mb1-bct-ratchet-p3701-0000_cpp.dtb
[  12.4889 ]
[  12.4890 ] Updating mb1-bct with firmware information
[  12.4908 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[  12.4981 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[  12.5008 ] Generating SHA2 Hash for mb1bct
[  12.5071 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[  12.5106 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[  12.5108 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[  12.5126 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[  12.5177 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[  12.5184 ] Assuming zero filled SBK key
[  12.5233 ] Warning: pub_key.key is not found
[  12.5228 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[  12.5268 ] tegrahost_v2 --chip 0x23 0 --partitionlayout flash.xml.bin --ratchet_blob ratchet_blob.bin --list images_list.xml zerosbk
[  12.5289 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[  12.5328 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[  12.5334 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[  12.5439 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[  12.5449 ] Header already present for tsec_t234_aligned.bin
[  12.5501 ] Header already present for nvdec_t234_prod_aligned.fw
[  12.5582 ] adding BCH for mb2_t234_with_mb2_cold_boot_bct_MB2_aligned.bin
[  12.5895 ] adding BCH for xusb_t234_prod_aligned.bin
[  12.6130 ] Header already present for bpmp_t234-TE990M-A1_prod_aligned.bin
[  12.6309 ] adding BCH for tegra234-bpmp-3701-0004-3737-0000_with_odm_aligned.dtb
[  12.6612 ] Header already present for pscfw_t234_prod_aligned.bin
[  12.6865 ] Header already present for mce_flash_o10_cr_prod_aligned.bin
[  12.6976 ] Header already present for sc7_t234_prod.bin
[  12.7044 ] Header already present for psc_rf_t234_prod_aligned.bin
[  12.7122 ] adding BCH for mb2rf_t234_aligned.bin
[  12.7147 ] INFO: compressing uefi_jetson_with_dtb_aligned.bin
[  12.8470 ] INFO: complete compression, uefi_jetson_with_dtb_aligned.bin, ratio = 92%
[  12.8724 ] adding BCH for uefi_jetson_with_dtb_aligned_blob_w_bin_aligned.bin
[  13.0039 ] adding BCH for tos-optee_t234_aligned.img
[  13.1925 ] adding BCH for eks_t234_aligned.img
[  13.3114 ] INFO: compressing display-t234-dce_with_kernel_tegra234-p3737-0000+p3701-0004-nv_with_dce_overlay_aligned.bin
[  14.2140 ] INFO: complete compression, display-t234-dce_with_kernel_tegra234-p3737-0000+p3701-0004-nv_with_dce_overlay_aligned.bin, ratio = 6%
[  14.2802 ] adding BCH for display-t234-dce_with_kernel_tegra234-p3737-0000+p3701-0004-nv_with_dce_overlay_aligned_blob_w_bin_aligned.bin
[  14.3633 ] adding BCH for spe_t234_aligned.bin
[  14.3878 ] adding BCH for camera-rtcpu-t234-rce_aligned.img
[  14.4065 ] adding BCH for adsp-fw_aligned.bin
[  14.4367 ] INFO: compressing nvpva_020_aligned.fw
[  14.5387 ] INFO: complete compression, nvpva_020_aligned.fw, ratio = 2%
[  14.5486 ] adding BCH for nvpva_020_aligned_blob_w_bin_aligned.fw
[  14.5566 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[  14.5615 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[  14.5637 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[  14.5748 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[  14.5759 ] Header already present for tsec_t234_aligned.bin
[  14.5830 ] Header already present for nvdec_t234_prod_aligned.fw
[  14.5940 ] adding BCH for mb2_t234_with_mb2_cold_boot_bct_MB2_aligned.bin
[  14.6106 ] adding BCH for xusb_t234_prod_aligned.bin
[  14.6376 ] Header already present for bpmp_t234-TE990M-A1_prod_aligned.bin
[  14.6623 ] adding BCH for tegra234-bpmp-3701-0004-3737-0000_with_odm_aligned.dtb
[  14.6999 ] Header already present for pscfw_t234_prod_aligned.bin
[  14.7271 ] Header already present for mce_flash_o10_cr_prod_aligned.bin
[  14.7387 ] Header already present for sc7_t234_prod.bin
[  14.7453 ] Header already present for psc_rf_t234_prod_aligned.bin
[  14.7531 ] adding BCH for mb2rf_t234_aligned.bin
[  14.7594 ] INFO: compressing uefi_jetson_with_dtb_aligned.bin
[  14.8998 ] INFO: complete compression, uefi_jetson_with_dtb_aligned.bin, ratio = 92%
[  14.9211 ] adding BCH for uefi_jetson_with_dtb_aligned_blob_w_bin_aligned.bin
[  15.0658 ] adding BCH for tos-optee_t234_aligned.img
[  15.2040 ] adding BCH for eks_t234_aligned.img
[  15.3296 ] INFO: compressing display-t234-dce_with_kernel_tegra234-p3737-0000+p3701-0004-nv_with_dce_overlay_aligned.bin
[  15.8229 ] INFO: complete compression, display-t234-dce_with_kernel_tegra234-p3737-0000+p3701-0004-nv_with_dce_overlay_aligned.bin, ratio = 6%
[  15.8881 ] adding BCH for display-t234-dce_with_kernel_tegra234-p3737-0000+p3701-0004-nv_with_dce_overlay_aligned_blob_w_bin_aligned.bin
[  15.9365 ] adding BCH for spe_t234_aligned.bin
[  15.9656 ] adding BCH for camera-rtcpu-t234-rce_aligned.img
[  15.9886 ] adding BCH for adsp-fw_aligned.bin
[  16.0205 ] INFO: compressing nvpva_020_aligned.fw
[  16.1266 ] INFO: complete compression, nvpva_020_aligned.fw, ratio = 2%
[  16.1349 ] adding BCH for nvpva_020_aligned_blob_w_bin_aligned.fw
[  16.1471 ] Filling MB1 storage info
[  16.1473 ] Parsing dev params for multi chains
[  16.1854 ] Generating br-bct
[  16.1867 ] Updating dev and MSS params in BR BCT
[  16.1868 ] tegrabct_v2 --dev_param tegra234-br-bct-p3701-0000_cpp.dtb --sdram tegra234-p3701-0000-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[  16.5269 ] Updating bl info
[  16.5297 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin
[  16.5677 ] Generating br-bct
[  16.5693 ] Updating dev and MSS params in BR BCT
[  16.5695 ] tegrabct_v2 --dev_param tegra234-br-bct_b-p3701-0000_cpp.dtb --sdram tegra234-p3701-0000-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[  16.8944 ] Updating bl info
[  16.9115 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin
[  16.9171 ] Generating BCT backup image
[  16.9174 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[  16.9199 ] 32768+0 records in
[  17.0658 ] 32768+0 records out
[  17.0658 ] 32768 bytes (33 kB, 32 KiB) copied, 0.136834 s, 239 kB/s
[  17.0658 ]
[  17.0659 ] Concatenating BCT for chain A to bct_backup.img
[  17.0659 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[  17.0675 ] 8192+0 records in
[  17.1070 ] 8192+0 records out
[  17.1071 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.034451 s, 238 kB/s
[  17.1072 ]
[  17.1073 ] Concatenating BCT for chain B to bct_backup.img
[  17.1074 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[  17.1094 ] 8192+0 records in
[  17.1447 ] 8192+0 records out
[  17.1447 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.0308462 s, 266 kB/s
[  17.1448 ]
[  17.1448 ] Generating signatures
[  17.1471 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[  17.1474 ] Assuming zero filled SBK key
[  17.6836 ] Warning: pub_key.key is not found
[  17.6894 ] Parsing dev params for multi chains
[  17.6896 ] Generating br-bct
[  17.6926 ] Updating dev and MSS params in BR BCT
[  17.6928 ] tegrabct_v2 --dev_param tegra234-br-bct-p3701-0000_cpp.dtb --sdram tegra234-p3701-0000-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[  18.0187 ] Updating customer data section
[  18.0222 ] tegrabct_v2 --chip 0x23 0 --brbct br_bct_BR.bct --update_custinfo custinfo_out.bin
[  18.0264 ] Updating bl info
[  18.0281 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[  18.0401 ] Generating SHA2 Hash
[  18.0472 ] Sha saved in br_bct_BR.sha
[  18.0454 ] Get Signed section of bct
[  18.0468 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[  18.0502 ] Signing BCT
[  18.0525 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[  18.0528 ] Assuming zero filled SBK key
[  18.0607 ] Sha saved in br_bct_BR.sha
[  18.0616 ] Warning: pub_key.key is not found
[  18.0594 ] Updating BCT with signature
[  18.0625 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[  18.0639 ] Offset :4608 Len :3584
[  18.0673 ] Generating SHA2 Hash
[  18.0697 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[  18.0699 ] Assuming zero filled SBK key
[  18.0700 ] Assuming zero filled SBK key
[  18.0780 ] Sha saved in br_bct_BR.sha
[  18.0766 ] Updating BCT with SHA2 Hash
[  18.0784 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[  18.0807 ] Offset :4608 Len :3584
[  18.0812 ] Offset :68 Len :8124
[  18.0816 ] Generating br-bct
[  18.0834 ] Updating dev and MSS params in BR BCT
[  18.0836 ] tegrabct_v2 --dev_param tegra234-br-bct_b-p3701-0000_cpp.dtb --sdram tegra234-p3701-0000-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[  18.4129 ] Updating customer data section
[  18.4148 ] tegrabct_v2 --chip 0x23 0 --brbct br_bct_BR.bct --update_custinfo custinfo_out.bin
[  18.4190 ] Updating bl info
[  18.4213 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[  18.4283 ] Generating SHA2 Hash
[  18.4348 ] Sha saved in br_bct_BR.sha
[  18.4328 ] Get Signed section of bct
[  18.4349 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[  18.4380 ] Signing BCT
[  18.4404 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[  18.4410 ] Assuming zero filled SBK key
[  18.4616 ] Sha saved in br_bct_BR.sha
[  18.4623 ] Warning: pub_key.key is not found
[  18.4601 ] Updating BCT with signature
[  18.4624 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[  18.4644 ] Offset :4608 Len :3584
[  18.4665 ] Generating SHA2 Hash
[  18.4689 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[  18.4694 ] Assuming zero filled SBK key
[  18.4695 ] Assuming zero filled SBK key
[  18.4768 ] Sha saved in br_bct_BR.sha
[  18.4754 ] Updating BCT with SHA2 Hash
[  18.4775 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[  18.4800 ] Offset :4608 Len :3584
[  18.4812 ] Offset :68 Len :8124
[  18.4829 ] Generating BCT backup image
[  18.4832 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[  18.4856 ] 32768+0 records in
[  18.6099 ] 32768+0 records out
[  18.6100 ] 32768 bytes (33 kB, 32 KiB) copied, 0.119295 s, 275 kB/s
[  18.6100 ]
[  18.6100 ] Concatenating BCT for chain A to bct_backup.img
[  18.6100 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[  18.6115 ] 8192+0 records in
[  18.6513 ] 8192+0 records out
[  18.6514 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.0351525 s, 233 kB/s
[  18.6519 ] Concatenating BCT for chain B to bct_backup.img
[  18.6519 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[  18.6537 ] 8192+0 records in
[  18.6906 ] 8192+0 records out
[  18.6908 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.0318841 s, 257 kB/s
[  18.6909 ]
[  18.6909 ] Generating coldboot mb1-bct
[  18.6924 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --wb0sdram tegra234-p3701-0000-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3701-0000-a04_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3701-0000-a04_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3701-0005_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3701-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3701-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3701-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3701-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3701-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[  18.7099 ] MB1-BCT version: 0.13
[  18.7133 ] Parsing config file :tegra234-mb1-bct-pinmux-p3701-0000-a04_cpp.dtb
[  18.7140 ] Added Platform Config 0 data with size :- 3040
[  18.7198 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3701-0000-a04_cpp.dtb
[  18.7207 ] WARNING: unknown node 'g2'
[  18.7212 ] WARNING: unknown node 'g2'
[  18.7213 ] WARNING: unknown node 'g9'
[  18.7215 ] WARNING: unknown node 'g9'
[  18.7216 ] Added Platform Config 2 data with size :- 24
[  18.7217 ]
[  18.7217 ] Parsing config file :tegra234-mb1-bct-pmic-p3701-0005_cpp.dtb
[  18.7217 ] WARNING: unknown property 'i2c-update-only'
[  18.7217 ] WARNING: unknown property 'i2c-verify-only'
[  18.7217 ] WARNING: unknown property 'i2c-update-verify'
[  18.7217 ] Added Platform Config 4 data with size :- 844
[  18.7217 ]
[  18.7217 ] Parsing config file :tegra234-mb1-bct-reset-p3701-0000_cpp.dtb
[  18.7217 ] Added Platform Config 3 data with size :- 52
[  18.7217 ]
[  18.7217 ] Parsing config file :tegra234-mb1-bct-prod-p3701-0000_cpp.dtb
[  18.7217 ] WARNING: unknown property 'major'
[  18.7217 ] WARNING: unknown property 'minor'
[  18.7217 ] Added Platform Config 5 data with size :- 524
[  18.7217 ]
[  18.7217 ] Parsing config file :tegra234-mb1-bct-gpioint-p3701-0000_cpp.dtb
[  18.7217 ] Added Platform Config 7 data with size :- 380
[  18.7217 ]
[  18.7217 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[  18.7218 ] Added Platform Config 8 data with size :- 24
[  18.7218 ]
[  18.7218 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[  18.7219 ] Added Platform Config 9 data with size :- 100
[  18.7219 ]
[  18.7219 ] Parsing config file :tegra234-mb1-bct-cprod-p3701-0000_cpp.dtb
[  18.7219 ] ModuleCount 0 NumProdNames 0
[  18.7219 ] Added Platform Config 6 data with size :- 16
[  18.7219 ]
[  18.7219 ] Parsing config file :tegra234-mb1-bct-ratchet-p3701-0000_cpp.dtb
[  18.7225 ]
[  18.7225 ] Updating mb1-bct with firmware information
[  18.7235 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[  18.7296 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[  18.7315 ] Generating SHA2 Hash for mb1bct
[  18.7378 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[  18.7420 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[  18.7414 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[  18.7427 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[  18.7477 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[  18.7483 ] Assuming zero filled SBK key
[  18.7534 ] Warning: pub_key.key is not found
[  18.7534 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[  18.7576 ] Generating recovery mb1-bct
[  18.7593 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --wb0sdram tegra234-p3701-0000-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3701-0000-a04_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3701-0000-a04_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3701-0005_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3701-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3701-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3701-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3701-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3701-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[  18.7610 ] MB1-BCT version: 0.13
[  18.7648 ] Parsing config file :tegra234-mb1-bct-pinmux-p3701-0000-a04_cpp.dtb
[  18.7658 ] Added Platform Config 0 data with size :- 3040
[  18.7708 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3701-0000-a04_cpp.dtb
[  18.7715 ] WARNING: unknown node 'g2'
[  18.7717 ] WARNING: unknown node 'g2'
[  18.7726 ] WARNING: unknown node 'g9'
[  18.7727 ] WARNING: unknown node 'g9'
[  18.7727 ] Added Platform Config 2 data with size :- 24
[  18.7727 ]
[  18.7727 ] Parsing config file :tegra234-mb1-bct-pmic-p3701-0005_cpp.dtb
[  18.7727 ] WARNING: unknown property 'i2c-update-only'
[  18.7727 ] WARNING: unknown property 'i2c-verify-only'
[  18.7728 ] WARNING: unknown property 'i2c-update-verify'
[  18.7728 ] WARNING: unknown property 'i2c-update-only'
[  18.7728 ] WARNING: unknown property 'i2c-verify-only'
[  18.7728 ] Added Platform Config 4 data with size :- 844
[  18.7728 ]
[  18.7728 ] Parsing config file :tegra234-mb1-bct-reset-p3701-0000_cpp.dtb
[  18.7728 ] Added Platform Config 3 data with size :- 52
[  18.7728 ]
[  18.7728 ] Parsing config file :tegra234-mb1-bct-prod-p3701-0000_cpp.dtb
[  18.7729 ] WARNING: unknown property 'major'
[  18.7729 ] WARNING: unknown property 'minor'
[  18.7729 ] Added Platform Config 5 data with size :- 524
[  18.7729 ]
[  18.7729 ] Parsing config file :tegra234-mb1-bct-gpioint-p3701-0000_cpp.dtb
[  18.7729 ] Added Platform Config 7 data with size :- 380
[  18.7729 ]
[  18.7730 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[  18.7730 ] Added Platform Config 8 data with size :- 24
[  18.7730 ]
[  18.7730 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[  18.7730 ] Added Platform Config 9 data with size :- 100
[  18.7730 ]
[  18.7730 ] Parsing config file :tegra234-mb1-bct-cprod-p3701-0000_cpp.dtb
[  18.7730 ] ModuleCount 0 NumProdNames 0
[  18.7730 ] Added Platform Config 6 data with size :- 16
[  18.7730 ]
[  18.7730 ] Parsing config file :tegra234-mb1-bct-ratchet-p3701-0000_cpp.dtb
[  18.7730 ]
[  18.7732 ] Updating mb1-bct with firmware information
[  18.7756 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo flash.xml.bin
[  18.7830 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[  18.7854 ] Generating SHA2 Hash for mb1bct
[  18.7909 ] Sha saved in mb1_bct_MB1_aligned.sha
[  18.7951 ] Sha saved in mb1_bct_MB1.sha
[  18.7944 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[  18.7961 ] adding BCH for mb1_bct_MB1_aligned.bct
[  18.8009 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[  18.8016 ] Assuming zero filled SBK key
[  18.8065 ] Warning: pub_key.key is not found
[  18.8066 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[  18.8103 ] Generating coldboot mem-bct
[  18.8123 ] tegrabct_v2 --chip 0x23 0 --sdram tegra234-p3701-0000-sdram-l4t_cpp.dtb --wb0sdram tegra234-p3701-0000-wb0sdram-l4t_cpp.dtb --membct tegra234-p3701-0000-sdram-l4t_cpp_1.bct tegra234-p3701-0000-sdram-l4t_cpp_2.bct tegra234-p3701-0000-sdram-l4t_cpp_3.bct tegra234-p3701-0000-sdram-l4t_cpp_4.bct
[  18.8138 ]  packing sdram params with Wb0 file tegra234-p3701-0000-wb0sdram-l4t_cpp.dtb
[  19.1424 ] Packing sdram param for instance[0]
[  19.1427 ] Packing sdram param for instance[1]
[  19.1583 ] Packing sdram param for instance[2]
[  19.1586 ] Packing sdram param for instance[3]
[  19.1593 ] Packing sdram param for instance[4]
[  19.1596 ] Packing sdram param for instance[5]
[  19.1600 ] Packing sdram param for instance[6]
[  19.1603 ] Packing sdram param for instance[7]
[  19.1607 ] Packing sdram param for instance[8]
[  19.1612 ] Packing sdram param for instance[9]
[  19.1618 ] Packing sdram param for instance[10]
[  19.1624 ] Packing sdram param for instance[11]
[  19.1628 ] Packing sdram param for instance[12]
[  19.1631 ] Packing sdram param for instance[13]
[  19.1634 ] Packing sdram param for instance[14]
[  19.1637 ] Packing sdram param for instance[15]
[  19.4974 ] Getting sector size from pt
[  19.4990 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[  19.5023 ] BlockSize read from layout is 0x200
[  19.5046 ] tegrahost_v2 --chip 0x23 0 --blocksize 512 --magicid MEMB --addsigheader_multi tegra234-p3701-0000-sdram-l4t_cpp_1.bct tegra234-p3701-0000-sdram-l4t_cpp_2.bct tegra234-p3701-0000-sdram-l4t_cpp_3.bct tegra234-p3701-0000-sdram-l4t_cpp_4.bct --ratchet_blob ratchet_blob.bin
[  19.5064 ] Binary 0 length is 58752
[  19.5076 ] Binary 0 align length is 58880
[  19.5087 ] Binary 1 length is 58752
[  19.5089 ] Binary 1 align length is 58880
[  19.5105 ] Binary 2 length is 58752
[  19.5108 ] Binary 2 align length is 58880
[  19.5126 ] Binary 3 length is 58752
[  19.5128 ] Binary 3 align length is 58880
[  19.5152 ] Buffer length is 235520
[  19.5154 ] adding BCH for tegra234-p3701-0000-sdram-l4t_cpp_1.bct
[  19.5159 ] new length is 243712
[  19.5210 ] tegrahost_v2 --chip 0x23 0 --align mem_coldboot_aligned.bct
[  19.5244 ] tegrahost_v2 --chip 0x23 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_coldboot_aligned.bct zerosbk
[  19.5262 ] Header already present for mem_coldboot_aligned.bct
[  19.5305 ] tegrasign_v3.py --key None --list mem_coldboot_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[  19.5318 ] Assuming zero filled SBK key
[  19.5366 ] Warning: pub_key.key is not found
[  19.5365 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_coldboot_aligned_sigheader.bct.encrypt mem_coldboot_aligned_sigheader.bct.hash zerosbk
[  19.5435 ] Generating recovery mem-bct
[  19.5460 ] tegrabct_v2 --chip 0x23 0 --sdram tegra234-p3701-0000-sdram-l4t_cpp.dtb --wb0sdram tegra234-p3701-0000-wb0sdram-l4t_cpp.dtb --membct tegra234-p3701-0000-sdram-l4t_cpp_1.bct tegra234-p3701-0000-sdram-l4t_cpp_2.bct tegra234-p3701-0000-sdram-l4t_cpp_3.bct tegra234-p3701-0000-sdram-l4t_cpp_4.bct
[  19.5483 ]  packing sdram params with Wb0 file tegra234-p3701-0000-wb0sdram-l4t_cpp.dtb
[  19.8649 ] Packing sdram param for instance[0]
[  19.8653 ] Packing sdram param for instance[1]
[  19.8656 ] Packing sdram param for instance[2]
[  19.8659 ] Packing sdram param for instance[3]
[  19.8666 ] Packing sdram param for instance[4]
[  19.8672 ] Packing sdram param for instance[5]
[  19.8677 ] Packing sdram param for instance[6]
[  19.8680 ] Packing sdram param for instance[7]
[  19.8684 ] Packing sdram param for instance[8]
[  19.8687 ] Packing sdram param for instance[9]
[  19.8690 ] Packing sdram param for instance[10]
[  19.8697 ] Packing sdram param for instance[11]
[  19.8700 ] Packing sdram param for instance[12]
[  19.8703 ] Packing sdram param for instance[13]
[  19.8708 ] Packing sdram param for instance[14]
[  19.8714 ] Packing sdram param for instance[15]
[  20.2243 ] Generating mem_bct based on ramcode group number
[  20.2244 ] Got ramcode 1 from the command line
[  20.2244 ] Using ramcode group number 0
[  20.2245 ] Disabled BPMP dtb trim, using default dtb
[  20.2245 ]
[  20.2277 ] tegrahost_v2 --chip 0x23 0 --align mem_rcm_aligned.bct
[  20.2472 ] tegrahost_v2 --chip 0x23 0 --magicid MEM0 --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm_aligned.bct zerosbk
[  20.2495 ] adding BCH for mem_rcm_aligned.bct
[  20.2570 ] tegrasign_v3.py --key None --list mem_rcm_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[  20.2576 ] Assuming zero filled SBK key
[  20.2631 ] Warning: pub_key.key is not found
[  20.2625 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_rcm_aligned_sigheader.bct.encrypt mem_rcm_aligned_sigheader.bct.hash zerosbk
[  20.2663 ] Generating all 4 mem_bct for ramcode group (0..3)
[  20.2664 ] Disabled BPMP dtb trim, using default dtb
[  20.2664 ]
[  20.2693 ] tegrahost_v2 --chip 0x23 0 --align mem_rcm_0_aligned.bct
[  20.2739 ] tegrahost_v2 --chip 0x23 0 --magicid MEM0 --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm_0_aligned.bct zerosbk
[  20.2755 ] adding BCH for mem_rcm_0_aligned.bct
[  20.2832 ] tegrasign_v3.py --key None --list mem_rcm_0_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[  20.2837 ] Assuming zero filled SBK key
[  20.2884 ] Warning: pub_key.key is not found
[  20.2880 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_rcm_0_aligned_sigheader.bct.encrypt mem_rcm_0_aligned_sigheader.bct.hash zerosbk
[  20.2917 ] Disabled BPMP dtb trim, using default dtb
[  20.2918 ]
[  20.2951 ] tegrahost_v2 --chip 0x23 0 --align mem_rcm_1_aligned.bct
[  20.3006 ] tegrahost_v2 --chip 0x23 0 --magicid MEM1 --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm_1_aligned.bct zerosbk
[  20.3014 ] adding BCH for mem_rcm_1_aligned.bct
[  20.3102 ] tegrasign_v3.py --key None --list mem_rcm_1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[  20.3107 ] Assuming zero filled SBK key
[  20.3168 ] Warning: pub_key.key is not found
[  20.3170 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_rcm_1_aligned_sigheader.bct.encrypt mem_rcm_1_aligned_sigheader.bct.hash zerosbk
[  20.3213 ] Disabled BPMP dtb trim, using default dtb
[  20.3214 ]
[  20.3247 ] tegrahost_v2 --chip 0x23 0 --align mem_rcm_2_aligned.bct
[  20.3288 ] tegrahost_v2 --chip 0x23 0 --magicid MEM2 --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm_2_aligned.bct zerosbk
[  20.3305 ] adding BCH for mem_rcm_2_aligned.bct
[  20.3382 ] tegrasign_v3.py --key None --list mem_rcm_2_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[  20.3389 ] Assuming zero filled SBK key
[  20.3427 ] Warning: pub_key.key is not found
[  20.3433 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_rcm_2_aligned_sigheader.bct.encrypt mem_rcm_2_aligned_sigheader.bct.hash zerosbk
[  20.3473 ] Disabled BPMP dtb trim, using default dtb
[  20.3474 ]
[  20.3503 ] tegrahost_v2 --chip 0x23 0 --align mem_rcm_3_aligned.bct
[  20.3538 ] tegrahost_v2 --chip 0x23 0 --magicid MEM3 --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm_3_aligned.bct zerosbk
[  20.3556 ] adding BCH for mem_rcm_3_aligned.bct
[  20.3639 ] tegrasign_v3.py --key None --list mem_rcm_3_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[  20.3642 ] Assuming zero filled SBK key
[  20.3691 ] Warning: pub_key.key is not found
[  20.3685 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_rcm_3_aligned_sigheader.bct.encrypt mem_rcm_3_aligned_sigheader.bct.hash zerosbk
[  20.3727 ] Copying signatures
[  20.3741 ] tegrahost_v2 --chip 0x23 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[  20.5783 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[  20.5798 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[  20.5799 ] Boot Rom communication
[  20.5813 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[  20.5829 ] BR_CID: 0x80012344705DF19B7C000000120180C0
[  20.9216 ] Sending bct_br
[  21.0035 ] Sending mb1
[  21.0198 ] Sending psc_bl1
[  21.0594 ] Sending bct_mb1
[  21.0828 ] Boot Rom communication completed
[  21.0829 ] Generating blob for T23x
[  21.0934 ] tegrahost_v2 --chip 0x23 0 --align blob_uefi_jetson_minimal_with_dtb_aligned.bin
[  21.0983 ] tegrahost_v2 --chip 0x23 0 --magicid CPBL --ratchet_blob ratchet_blob.bin --appendsigheader blob_uefi_jetson_minimal_with_dtb_aligned.bin zerosbk
[  21.1005 ] adding BCH for blob_uefi_jetson_minimal_with_dtb_aligned.bin
[  21.2507 ] tegrasign_v3.py --key None --list blob_uefi_jetson_minimal_with_dtb_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[  21.2509 ] Assuming zero filled SBK key
[  21.2588 ] Warning: pub_key.key is not found
[  21.2586 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_uefi_jetson_minimal_with_dtb_aligned_sigheader.bin.encrypt blob_uefi_jetson_minimal_with_dtb_aligned_sigheader.bin.hash zerosbk
[  21.2936 ] Get magic id
[  21.2951 ] tegraparser_v2 --get_magic psc_fw
[  21.2977 ] PFWP
[  21.2977 ]
[  21.2978 ] partition type psc_fw, magic id = PFWP
[  21.3012 ] tegrahost_v2 --chip 0x23 0 --align blob_pscfw_t234_prod_aligned.bin
[  21.3055 ] tegrahost_v2 --chip 0x23 0 --magicid PFWP --ratchet_blob ratchet_blob.bin --appendsigheader blob_pscfw_t234_prod_aligned.bin zerosbk
[  21.3071 ] Header already present for blob_pscfw_t234_prod_aligned.bin
[  21.3214 ] tegrasign_v3.py --key None --list blob_pscfw_t234_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[  21.3217 ] Assuming zero filled SBK key
[  21.3270 ] Warning: pub_key.key is not found
[  21.3266 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_pscfw_t234_prod_aligned_sigheader.bin.encrypt blob_pscfw_t234_prod_aligned_sigheader.bin.hash zerosbk
[  21.3344 ] Get magic id
[  21.3370 ] tegraparser_v2 --get_magic mts_mce
[  21.3384 ] MTSM
[  21.3386 ] partition type mts_mce, magic id = MTSM
[  21.3415 ] tegrahost_v2 --chip 0x23 0 --align blob_mce_flash_o10_cr_prod_aligned.bin
[  21.3446 ] tegrahost_v2 --chip 0x23 0 --magicid MTSM --ratchet_blob ratchet_blob.bin --appendsigheader blob_mce_flash_o10_cr_prod_aligned.bin zerosbk
[  21.3464 ] Header already present for blob_mce_flash_o10_cr_prod_aligned.bin
[  21.3552 ] tegrasign_v3.py --key None --list blob_mce_flash_o10_cr_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[  21.3556 ] Assuming zero filled SBK key
[  21.3615 ] Warning: pub_key.key is not found
[  21.3604 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_mce_flash_o10_cr_prod_aligned_sigheader.bin.encrypt blob_mce_flash_o10_cr_prod_aligned_sigheader.bin.hash zerosbk
[  21.3646 ] Get magic id
[  21.3664 ] tegraparser_v2 --get_magic tsec_fw
[  21.3683 ] TSEC
[  21.3684 ]
[  21.3685 ] partition type tsec_fw, magic id = TSEC
[  21.3705 ] tegrahost_v2 --chip 0x23 0 --align blob_tsec_t234_aligned.bin
[  21.3736 ] tegrahost_v2 --chip 0x23 0 --magicid TSEC --ratchet_blob ratchet_blob.bin --appendsigheader blob_tsec_t234_aligned.bin zerosbk
[  21.3755 ] Header already present for blob_tsec_t234_aligned.bin
[  21.3841 ] tegrasign_v3.py --key None --list blob_tsec_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[  21.3845 ] Assuming zero filled SBK key
[  21.3881 ] Warning: pub_key.key is not found
[  21.3880 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_tsec_t234_aligned_sigheader.bin.encrypt blob_tsec_t234_aligned_sigheader.bin.hash zerosbk
[  21.3939 ] Get magic id
[  21.3955 ] tegraparser_v2 --get_magic mb2_applet
[  21.3970 ] MB2A
[  21.3976 ] partition type mb2_applet, magic id = MB2A
[  21.4003 ] tegrahost_v2 --chip 0x23 0 --align blob_applet_t234_aligned.bin
[  21.4036 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --ratchet_blob ratchet_blob.bin --appendsigheader blob_applet_t234_aligned.bin zerosbk
[  21.4066 ] adding BCH for blob_applet_t234_aligned.bin
[  21.4284 ] tegrasign_v3.py --key None --list blob_applet_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[  21.4288 ] Assuming zero filled SBK key
[  21.4358 ] Warning: pub_key.key is not found
[  21.4357 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_applet_t234_aligned_sigheader.bin.encrypt blob_applet_t234_aligned_sigheader.bin.hash zerosbk
[  21.4438 ] Generating recovery mb2-bct
[  21.4439 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_bct.cfg --recov --mb2bctcfg tegra234-mb2-bct-misc-p3701-0000_cpp.dtb --scr tegra234-mb2-bct-scr-p3701-0000_cpp.dtb
[  21.4455 ] WARNING: unknown property 'tfc_version'
[  21.4489 ] WARNING: unknown property 'addr_header_version'
[  21.4769 ] Updating mb2-bct with storage information
[  21.4796 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_bct_MB2.bct --updatestorageinfo flash.xml.bin
[  21.4854 ] Concatenating mb2-bct to mb2 binary
[  21.4855 ] mb2_bin_file = mb2_t234.bin
[  21.4855 ] mb2_bct_file = mb2_bct_MB2.bct
[  21.4878 ] Get magic id
[  21.4903 ] tegraparser_v2 --get_magic mb2_bootloader
[  21.4927 ] MB2B
[  21.4928 ]
[  21.4928 ] partition type mb2_bootloader, magic id = MB2B
[  21.4964 ] tegrahost_v2 --chip 0x23 0 --align blob_mb2_t234_with_mb2_bct_MB2_aligned.bin
[  21.4995 ] tegrahost_v2 --chip 0x23 0 --magicid MB2B --ratchet_blob ratchet_blob.bin --appendsigheader blob_mb2_t234_with_mb2_bct_MB2_aligned.bin zerosbk
[  21.5013 ] adding BCH for blob_mb2_t234_with_mb2_bct_MB2_aligned.bin
[  21.5318 ] tegrasign_v3.py --key None --list blob_mb2_t234_with_mb2_bct_MB2_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[  21.5321 ] Assuming zero filled SBK key
[  21.5372 ] Warning: pub_key.key is not found
[  21.5377 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_mb2_t234_with_mb2_bct_MB2_aligned_sigheader.bin.encrypt blob_mb2_t234_with_mb2_bct_MB2_aligned_sigheader.bin.hash zerosbk
[  21.5449 ] Get magic id
[  21.5470 ] tegraparser_v2 --get_magic xusb_fw
[  21.5486 ] XUSB
[  21.5492 ] partition type xusb_fw, magic id = XUSB
[  21.5518 ] tegrahost_v2 --chip 0x23 0 --align blob_xusb_t234_prod_aligned.bin
[  21.5556 ] tegrahost_v2 --chip 0x23 0 --magicid XUSB --ratchet_blob ratchet_blob.bin --appendsigheader blob_xusb_t234_prod_aligned.bin zerosbk
[  21.5572 ] adding BCH for blob_xusb_t234_prod_aligned.bin
[  21.5709 ] tegrasign_v3.py --key None --list blob_xusb_t234_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[  21.5713 ] Assuming zero filled SBK key
[  21.5791 ] Warning: pub_key.key is not found
[  21.5786 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_xusb_t234_prod_aligned_sigheader.bin.encrypt blob_xusb_t234_prod_aligned_sigheader.bin.hash zerosbk
[  21.5862 ] Get magic id
[  21.5873 ] tegraparser_v2 --get_magic pva_fw
[  21.5891 ] PVAF
[  21.5892 ]
[  21.5892 ] partition type pva_fw, magic id = PVAF
[  21.6196 ] tegrahost_v2 --chip 0x23 0 --align blob_nvpva_020_aligned.fw
[  21.6224 ] tegrahost_v2 --chip 0x23 0 --magicid PVAF --ratchet_blob ratchet_blob.bin --appendsigheader blob_nvpva_020_aligned.fw zerosbk
[  21.6241 ] adding BCH for blob_nvpva_020_aligned.fw
[  21.7991 ] tegrasign_v3.py --key None --list blob_nvpva_020_aligned_sigheader.fw_list.xml --pubkeyhash pub_key.key --sha sha512
[  21.7995 ] Assuming zero filled SBK key
[  21.8087 ] Warning: pub_key.key is not found
[  21.8082 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_nvpva_020_aligned_sigheader.fw.encrypt blob_nvpva_020_aligned_sigheader.fw.hash zerosbk
[  21.8307 ] Kernel DTB used: kernel_tegra234-p3737-0000+p3701-0004-nv.dtb
[  21.8308 ] Concatenating kernel_tegra234-p3737-0000+p3701-0004-nv.dtb to fdtoverlay(tegra234-dcb-p3737-0000-hdmi.dtbo)
[  21.8745 ] Concatenating kernel-dtb to dce-fw binary
[  21.8748 ] dce_bin = display-t234-dce.bin
[  21.8748 ] kernel_dtb = kernel_tegra234-p3737-0000+p3701-0004-nv_with_dce_overlay.dtb
[  21.8749 ] dce_with_dtb = display-t234-dce_with_kernel_tegra234-p3737-0000+p3701-0004-nv_with_dce_overlay.bin
[  21.9159 ] Get magic id
[  21.9186 ] tegraparser_v2 --get_magic dce_fw
[  21.9199 ] DCEF
[  21.9206 ] partition type dce_fw, magic id = DCEF
[  21.9564 ] tegrahost_v2 --chip 0x23 0 --align blob_display-t234-dce_with_kernel_tegra234-p3737-0000+p3701-0004-nv_with_dce_overlay_aligned.bin
[  21.9605 ] tegrahost_v2 --chip 0x23 0 --magicid DCEF --ratchet_blob ratchet_blob.bin --appendsigheader blob_display-t234-dce_with_kernel_tegra234-p3737-0000+p3701-0004-nv_with_dce_overlay_aligned.bin zerosbk
[  21.9644 ] adding BCH for blob_display-t234-dce_with_kernel_tegra234-p3737-0000+p3701-0004-nv_with_dce_overlay_aligned.bin
[  23.3042 ] tegrasign_v3.py --key None --list blob_display-t234-dce_with_kernel_tegra234-p3737-0000+p3701-0004-nv_with_dce_overlay_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[  23.3045 ] Assuming zero filled SBK key
[  24.0017 ] Warning: pub_key.key is not found
[  24.0022 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_display-t234-dce_with_kernel_tegra234-p3737-0000+p3701-0004-nv_with_dce_overlay_aligned_sigheader.bin.encrypt blob_display-t234-dce_with_kernel_tegra234-p3737-0000+p3701-0004-nv_with_dce_overlay_aligned_sigheader.bin.hash zerosbk
[  24.1968 ] Get magic id
[  24.1987 ] tegraparser_v2 --get_magic nvdec
[  24.2005 ] NDEC
[  24.2014 ] partition type nvdec, magic id = NDEC
[  24.2056 ] tegrahost_v2 --chip 0x23 0 --align blob_nvdec_t234_prod_aligned.fw
[  24.2095 ] tegrahost_v2 --chip 0x23 0 --magicid NDEC --ratchet_blob ratchet_blob.bin --appendsigheader blob_nvdec_t234_prod_aligned.fw zerosbk
[  24.2108 ] Header already present for blob_nvdec_t234_prod_aligned.fw
[  24.2232 ] tegrasign_v3.py --key None --list blob_nvdec_t234_prod_aligned_sigheader.fw_list.xml --pubkeyhash pub_key.key --sha sha512
[  24.2237 ] Assuming zero filled SBK key
[  24.2300 ] Warning: pub_key.key is not found
[  24.2305 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_nvdec_t234_prod_aligned_sigheader.fw.encrypt blob_nvdec_t234_prod_aligned_sigheader.fw.hash zerosbk
[  24.2377 ] Get magic id
[  24.2408 ] tegraparser_v2 --get_magic bpmp_fw
[  24.2432 ] BPMF
[  24.2433 ]
[  24.2433 ] partition type bpmp_fw, magic id = BPMF
[  24.2469 ] tegrahost_v2 --chip 0x23 0 --align blob_bpmp_t234-TE990M-A1_prod_aligned.bin
[  24.2507 ] tegrahost_v2 --chip 0x23 0 --magicid BPMF --ratchet_blob ratchet_blob.bin --appendsigheader blob_bpmp_t234-TE990M-A1_prod_aligned.bin zerosbk
[  24.2528 ] Header already present for blob_bpmp_t234-TE990M-A1_prod_aligned.bin
[  24.2737 ] tegrasign_v3.py --key None --list blob_bpmp_t234-TE990M-A1_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[  24.2740 ] Assuming zero filled SBK key
[  24.2862 ] Warning: pub_key.key is not found
[  24.2867 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_bpmp_t234-TE990M-A1_prod_aligned_sigheader.bin.encrypt blob_bpmp_t234-TE990M-A1_prod_aligned_sigheader.bin.hash zerosbk
[  24.2980 ] Using bpmp-dtb concatenated with odmdata in blob
[  24.2990 ] Get magic id
[  24.3005 ] tegraparser_v2 --get_magic bpmp_fw_dtb
[  24.3021 ] BPMD
[  24.3024 ] partition type bpmp_fw_dtb, magic id = BPMD
[  24.3057 ] tegrahost_v2 --chip 0x23 0 --align blob_tegra234-bpmp-3701-0004-3737-0000_with_odm_aligned.dtb
[  24.3089 ] tegrahost_v2 --chip 0x23 0 --magicid BPMD --ratchet_blob ratchet_blob.bin --appendsigheader blob_tegra234-bpmp-3701-0004-3737-0000_with_odm_aligned.dtb zerosbk
[  24.3106 ] adding BCH for blob_tegra234-bpmp-3701-0004-3737-0000_with_odm_aligned.dtb
[  24.3376 ] tegrasign_v3.py --key None --list blob_tegra234-bpmp-3701-0004-3737-0000_with_odm_aligned_sigheader.dtb_list.xml --pubkeyhash pub_key.key --sha sha512
[  24.3380 ] Assuming zero filled SBK key
[  24.3463 ] Warning: pub_key.key is not found
[  24.3470 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_tegra234-bpmp-3701-0004-3737-0000_with_odm_aligned_sigheader.dtb.encrypt blob_tegra234-bpmp-3701-0004-3737-0000_with_odm_aligned_sigheader.dtb.hash zerosbk
[  24.3542 ] Get magic id
[  24.3564 ] tegraparser_v2 --get_magic rce_fw
[  24.3573 ] RCEF
[  24.3579 ] partition type rce_fw, magic id = RCEF
[  24.3626 ] tegrahost_v2 --chip 0x23 0 --align blob_camera-rtcpu-t234-rce_aligned.img
[  24.3673 ] tegrahost_v2 --chip 0x23 0 --magicid RCEF --ratchet_blob ratchet_blob.bin --appendsigheader blob_camera-rtcpu-t234-rce_aligned.img zerosbk
[  24.3685 ] adding BCH for blob_camera-rtcpu-t234-rce_aligned.img
[  24.4018 ] tegrasign_v3.py --key None --list blob_camera-rtcpu-t234-rce_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[  24.4021 ] Assuming zero filled SBK key
[  24.4077 ] Warning: pub_key.key is not found
[  24.4074 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_camera-rtcpu-t234-rce_aligned_sigheader.img.encrypt blob_camera-rtcpu-t234-rce_aligned_sigheader.img.hash zerosbk
[  24.4158 ] Get magic id
[  24.4174 ] tegraparser_v2 --get_magic ape_fw
[  24.4190 ] APEF
[  24.4201 ] partition type ape_fw, magic id = APEF
[  24.4234 ] tegrahost_v2 --chip 0x23 0 --align blob_adsp-fw_aligned.bin
[  24.4265 ] tegrahost_v2 --chip 0x23 0 --magicid APEF --ratchet_blob ratchet_blob.bin --appendsigheader blob_adsp-fw_aligned.bin zerosbk
[  24.4284 ] adding BCH for blob_adsp-fw_aligned.bin
[  24.4602 ] tegrasign_v3.py --key None --list blob_adsp-fw_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[  24.4606 ] Assuming zero filled SBK key
[  24.4671 ] Warning: pub_key.key is not found
[  24.4666 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_adsp-fw_aligned_sigheader.bin.encrypt blob_adsp-fw_aligned_sigheader.bin.hash zerosbk
[  24.4743 ] Get magic id
[  24.4764 ] tegraparser_v2 --get_magic spe_fw
[  24.4798 ] SPEF
[  24.4809 ] partition type spe_fw, magic id = SPEF
[  24.4829 ] tegrahost_v2 --chip 0x23 0 --align blob_spe_t234_aligned.bin
[  24.4870 ] tegrahost_v2 --chip 0x23 0 --magicid SPEF --ratchet_blob ratchet_blob.bin --appendsigheader blob_spe_t234_aligned.bin zerosbk
[  24.4894 ] adding BCH for blob_spe_t234_aligned.bin
[  24.5122 ] tegrasign_v3.py --key None --list blob_spe_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[  24.5129 ] Assuming zero filled SBK key
[  24.5190 ] Warning: pub_key.key is not found
[  24.5187 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_spe_t234_aligned_sigheader.bin.encrypt blob_spe_t234_aligned_sigheader.bin.hash zerosbk
[  24.5255 ] Get magic id
[  24.5276 ] tegraparser_v2 --get_magic tos
[  24.5290 ] TOSB
[  24.5295 ] partition type tos, magic id = TOSB
[  24.5352 ] tegrahost_v2 --chip 0x23 0 --align blob_tos-optee_t234_aligned.img
[  24.5393 ] tegrahost_v2 --chip 0x23 0 --magicid TOSB --ratchet_blob ratchet_blob.bin --appendsigheader blob_tos-optee_t234_aligned.img zerosbk
[  24.5407 ] adding BCH for blob_tos-optee_t234_aligned.img
[  24.6631 ] tegrasign_v3.py --key None --list blob_tos-optee_t234_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[  24.6634 ] Assuming zero filled SBK key
[  24.7317 ] Warning: pub_key.key is not found
[  24.7309 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_tos-optee_t234_aligned_sigheader.img.encrypt blob_tos-optee_t234_aligned_sigheader.img.hash zerosbk
[  24.7729 ] Get magic id
[  24.7745 ] tegraparser_v2 --get_magic eks
[  24.7759 ] EKSB
[  24.7765 ] partition type eks, magic id = EKSB
[  24.7794 ] tegrahost_v2 --chip 0x23 0 --align blob_eks_t234_aligned.img
[  24.7840 ] tegrahost_v2 --chip 0x23 0 --magicid EKSB --ratchet_blob ratchet_blob.bin --appendsigheader blob_eks_t234_aligned.img zerosbk
[  24.7854 ] adding BCH for blob_eks_t234_aligned.img
[  24.7905 ] tegrasign_v3.py --key None --list blob_eks_t234_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[  24.7908 ] Assuming zero filled SBK key
[  24.7951 ] Warning: pub_key.key is not found
[  24.7944 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_eks_t234_aligned_sigheader.img.encrypt blob_eks_t234_aligned_sigheader.img.hash zerosbk
[  24.8004 ] tegrahost_v2 --chip 0x23 0 --generateblob blob.xml blob.bin
[  24.8021 ] The number of images in blob is 17
[  24.8029 ] blobsize is 22608352
[  24.8031 ] Added binary blob_uefi_jetson_minimal_with_dtb_sigheader.bin.encrypt of size 2060352
[  25.1825 ] Added binary blob_pscfw_t234_prod_sigheader.bin.encrypt of size 310768
[  25.1842 ] Added binary blob_mce_flash_o10_cr_prod_sigheader.bin.encrypt of size 187120
[  25.1848 ] Added binary blob_tsec_t234_sigheader.bin.encrypt of size 176128
[  25.1854 ] Added binary blob_applet_t234_sigheader.bin.encrypt of size 279808
[  25.1860 ] Not supported type: mb2_applet
[  25.1865 ] Added binary blob_mb2_t234_with_mb2_bct_MB2_sigheader.bin.encrypt of size 440944
[  25.1882 ] Added binary blob_xusb_t234_prod_sigheader.bin.encrypt of size 164864
[  25.1892 ] Added binary blob_nvpva_020_sigheader.fw.encrypt of size 2164640
[  25.1972 ] Added binary blob_display-t234-dce_with_kernel_tegra234-p3737-0000+p3701-0004-nv_with_dce_overlay_sigheader.bin.encrypt of size 12075888
[  25.3490 ] Added binary blob_nvdec_t234_prod_sigheader.fw.encrypt of size 294912
[  25.3551 ] Added binary blob_bpmp_t234-TE990M-A1_prod_sigheader.bin.encrypt of size 1027008
[  25.3582 ] Added binary blob_tegra234-bpmp-3701-0004-3737-0000_with_odm_sigheader.dtb.encrypt of size 384832
[  25.3591 ] Added binary blob_camera-rtcpu-t234-rce_sigheader.img.encrypt of size 458096
[  25.3598 ] Added binary blob_adsp-fw_sigheader.bin.encrypt of size 415008
[  25.3604 ] Added binary blob_spe_t234_sigheader.bin.encrypt of size 270336
[  25.3610 ] Added binary blob_tos-optee_t234_sigheader.img.encrypt of size 1887312
[  25.3634 ] Added binary blob_eks_t234_sigheader.img.encrypt of size 9232
[  25.5445 ] Sending membct and RCM blob
[  25.5467 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
[  25.5485 ] BL: version 1.4.0.4-t234-54845784-e89ea9bc last_boot_error: 0
[  25.7838 ] Sending bct_mem
[  25.8691 ] Sending blob
[  26.2408 ] ERROR: might be timeout in USB write.
Error: Return value 3
Command tegrarcm_v2 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
Failed flashing generic.
uart log:
[0027.340] I> MB1 (version: 1.4.0.4-t234-54845784-e89ea9bc)
[0027.345] I> t234-A01-1-Silicon (0x12347) Prod
[0027.349] I> Boot-mode : BPMP Diagnostic
[0027.353] I> Entry timestamp: 0x00000000
[0027.357] I> last_boot_error: 0x0
[0027.360] I> BR-BCT: preprod_dev_sign: 0
[0027.364] I> rst_source: 0x0, rst_level: 0x0
[0027.368] I> Task: Initialize MB2 params
[0027.372] I> MB2-params @ 0x40060000
[0027.376] I> Task: Crypto init
[0027.378] I> Task: Perform MB1 KAT tests
[0027.382] I> Task: NVRNG health check
[0027.386] I> NVRNG: Health check success
[0027.390] I> Task: Secure debug controls
[0027.394] I> Task: strap war set
[0027.397] I> Task: Program NV master stream id
[0027.401] I> Task: Verify boot mode
[0027.407] I> Task: Alias fuses
[0027.410] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0027.418] I> Task: Print SKU type
[0027.421] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c0
[0027.426] I> FUSE_OPT_GPC_DISABLE = 0x00000000
[0027.430] I> FUSE_OPT_TPC_DISABLE = 0x00000080
[0027.435] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0027.439] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0027.443] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0027.448] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0027.452] I> FUSE_OPT_FSI_DISABLE = 0x00000000
[0027.456] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0027.461] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0027.465] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0027.469] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0027.473] I> FUSE_SKU_INFO_0 = 0xd2
[0027.476] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0027.480] I> FUSE_PACKAGE_INFO_0 = 0x2
[0027.484] I> SKU: Prod
[0027.486] I> Task: Boost clocks
[0027.489] I> Initializing NAFLL for BPMP_CPU_NIC.
[0027.494] I> BPMP NAFLL: fll_lock = 1, dvco_min_reached = 0
[0027.500] I> BPMP NAFLL lock success.
[0027.503] I> BPMP_CPU_NIC : src = 42, divisor = 0
[0027.508] I> Initializing PLLC2 for AXI_CBB.
[0027.512] I> AXI_CBB : src = 35, divisor = 0
[0027.516] I> Task: Voltage monitor
[0027.519] I> VMON: Vmon re-calibration and fine tuning done
[0027.525] I> Task: UPHY init
[0027.528] W> UPHY: UPHY lane info table is empty in MB1 BCT.
[0027.533] I> Task: Boot device init
[0027.537] I> Boot_device: RCM
[0027.540] I> USB configuration success
[0027.543] I> Task: TSC init
[0027.546] I> Task: Enable WDT 5th expiry
[0027.550] I> Task: I2C register
[0027.553] I> Task: Set I2C bus freq
[0027.556] I> Task: Reset FSI
[0027.559] I> Task: Enable clock-mon
[0027.573] I> FMON: Fmon re-programming done
[0027.577] I> Task: Mapper init
[0027.580] I> Task: MB1 fixed firewalls
[0027.587] W> Firewall readback mismatch
[0027.592] I> Task: Load MB2/Applet/FSKP
[0027.595] I> Loading MB2 Applet
[0027.598] I> Slot: 0
[0027.600] I> Binary[21] block-352321536 (partition size: 0x50000)
[0027.606] I> Binary name: MB2-Applet
[0027.610] I> Size of crypto header is 8192
[0027.614] I> Size of crypto header is 8192
[0027.620] I> BCH of MB2-Applet read from storage
[0027.624] I> BCH address is : 0x4004e000
[0027.628] I> MB2-Applet header integrity check is success
[0027.633] I> Binary magic in BCH component 0 is MB2A
[0027.638] I> component binary type is 21
[0027.642] I> Size of crypto header is 8192
[0027.688] I> MB2-Applet binary is read from storage
[0027.693] I> MB2-Applet binary integrity check is success
[0027.698] I> Binary MB2-Applet loaded successfully at 0x40000000 (0x42500)
[0027.705] I> Task: Prepare MB2 params
[0027.709] I> Task: Misc NV security settings
[0027.713] I> NVDEC sticky bits programming done
[0027.717] I> Successfully powergated NVDEC
[0027.721] I> Task: Disable/Reload WDT
[0027.725] I> Task: Program misc carveouts
[0027.729] I> Task: Disable SCPM/POD reset
[0027.733] I> SLCG Global override status := 0x0
[0027.737] I> MB1: MSS reconfig completed
[0027.741] W> Firewall readback mismatch
[0027.745] W> Firewall readback mismatch
[0027.748] W> Firewall readback mismatch
[0027.752] W> Firewall readback mismatch
[0027.756] W> Firewall readback mismatch
[0027.759] W> Firewall readback mismatch
[0027.763] W> Firewall readback mismatch
[0027.767] W> Firewall readback mismatch
[0027.770] W> Firewall readback mismatch
[0027.774] W> Firewall readback mismatch
I> Applet (version: 0.0.0.0-t234-54845784-9fa9acb5)
I> Emulation:
I> Task: Pinmux init
I> Applet do storage init
I> Boot_device: QSPI_FLASH instance: 0
I> Qspi clock source : clk_m
I> QSPI Flash: Macronix 64MB
I> QSPI-0l initialized successfully
I> Secondary storage device: SDMMC_BOOT instance: 3
I> sdmmc DDR50 mode
I> Secondary storage device: SDMMC_USER instance: 3
I> sdmmc bdev is already initialized
I> Secondary storage device: QSPI_FLASH instance: 0
I> Task: Register exit handlers
I> Task: Enter 3p server
I> Reading fuses
I> Read fuse successfully
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Reading fuses
I> Populate chip info
I> RAM_CODE 0x4000011
I> Populate eeprom info
I> Populate eeprom info for module cvm
I> dump bct
I> strt_pg_num(0) num_of_pgs(16) read_buf(0x400719f8)
E> LOADER: Invalid value Header magic.
E> Validation failed for 1 copy of BRBCT @ 0
I> strt_pg_num(512) num_of_pgs(16) read_buf(0x400719f8)
E> Validation failed for 2 copy of BRBCT @ 262144
I> strt_pg_num(1024) num_of_pgs(16) read_buf(0x400719f8)
E> Validation failed for 3 copy of BRBCT @ 524288
I> strt_pg_num(1536) num_of_pgs(16) read_buf(0x400719f8)
E> Validation failed for 4 copy of BRBCT @ 786432
E> NV3P_SERVER: Failed to get address for br bct from nv3p helper.
I> Rebooting : reboot-recovery
[0071.947] I> MB1 (version: 1.4.0.4-t234-54845784-e89ea9bc)
[0071.952] I> t234-A01-1-Silicon (0x12347) Prod
[0071.956] I> Boot-mode : Coldboot
[0071.960] I> Entry timestamp: 0x00000000
[0071.963] I> last_boot_error: 0x0
[0071.967] I> BR-BCT: preprod_dev_sign: 0
[0071.970] I> rst_source: 0xb, rst_level: 0x1
[0071.974] I> Task: SE error check
[0071.978] I> Task: Bootchain select WAR set
[0071.982] I> Task: Enable SLCG
[0071.984] I> Task: CRC check
[0071.987] I> Task: Initialize MB2 params
[0071.992] I> MB2-params @ 0x40060000
[0071.995] I> Task: Crypto init
[0071.998] I> Task: Perform MB1 KAT tests
[0072.002] I> Task: NVRNG health check
[0072.005] I> NVRNG: Health check success
[0072.009] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0072.015] I> Task: Enabling and initialization of Bandwidth limiter
[0072.021] I> No request to configure MBWT settings for any PC!
[0072.027] I> Task: Secure debug controls
[0072.031] I> Task: strap war set
[0072.034] I> Task: Initialize SOC Therm
[0072.038] I> Task: Program NV master stream id
[0072.042] I> Task: Verify boot mode
[0072.048] I> Task: Alias fuses
[0072.051] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0072.059] I> Task: Print SKU type
[0072.062] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x000001c0
[0072.067] I> FUSE_OPT_GPC_DISABLE = 0x00000000
[0072.071] I> FUSE_OPT_TPC_DISABLE = 0x00000080
[0072.076] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0072.080] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0072.084] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0072.089] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0072.093] I> FUSE_OPT_FSI_DISABLE = 0x00000000
[0072.097] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0072.102] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0072.106] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0072.110] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0072.114] I> FUSE_SKU_INFO_0 = 0xd2
[0072.117] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0072.121] I> FUSE_PACKAGE_INFO_0 = 0x2
[0072.125] I> SKU: Prod
[0072.127] I> Task: Boost clocks
[0072.130] I> Initializing NAFLL for BPMP_CPU_NIC.
[0072.135] I> BPMP NAFLL: fll_lock = 1, dvco_min_reached = 0
[0072.141] I> BPMP NAFLL lock success.
[0072.144] I> BPMP_CPU_NIC : src = 42, divisor = 0
[0072.149] I> Initializing PLLC2 for AXI_CBB.
[0072.153] I> AXI_CBB : src = 35, divisor = 0
[0072.157] I> Task: Voltage monitor
[0072.160] I> VMON: Vmon re-calibration and fine tuning done
[0072.166] I> Task: UPHY init
[0072.171] I> HSIO UPHY init done
[0072.174] W> Skipping GBE UPHY config
[0072.177] I> Task: Boot device init
[0072.181] I> Boot_device: RCM
[0072.184] I> USB configuration success
[0076.627] I> Task: TSC init
[0076.629] I> Task: Load membct
[0076.632] I> RAM_CODE 0x4000011
[0076.635] I> Loading MEMBCT
[0076.638] I> Slot: 0
[0076.640] I> Binary[0] block-0 (partition size: 0x40000)
[0076.645] I> Binary name: MEM-BCT-0
[0076.649] I> Size of crypto header is 8192
[0076.653] I> Size of crypto header is 8192
[0076.714] I> BCH of MEM-BCT-0 read from storage
[0076.718] I> BCH address is : 0x40050000
[0076.722] I> MEM-BCT-0 header integrity check is success
[0076.727] I> Binary magic in BCH component 0 is MEM0
[0076.732] I> component binary type is 0
[0076.743] I> MEM-BCT-0 binary is read from storage
[0076.748] I> MEM-BCT-0 binary integrity check is success
[0076.753] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0076.760] I> RAM_CODE 0x4000011
[0076.765] I> RAM_CODE 0x4000011
[0076.769] I> Task: Load Page retirement list
[0076.773] I> Task: SDRAM params override
[0076.777] I> Task: Save mem-bct info
[0076.781] I> Task: Carveout allocate
[0076.784] I> Update CCPLEX IST carveout from MB1-BCT
[0076.789] I> ECC region[0]: Start:0x0, End:0x0
[0076.793] I> ECC region[1]: Start:0x0, End:0x0
[0076.798] I> ECC region[2]: Start:0x0, End:0x0
[0076.802] I> ECC region[3]: Start:0x0, End:0x0
[0076.806] I> ECC region[4]: Start:0x0, End:0x0
[0076.810] I> Non-ECC region[0]: Start:0x80000000, End:0x880000000
[0076.816] I> Non-ECC region[1]: Start:0x0, End:0x0
[0076.821] I> Non-ECC region[2]: Start:0x0, End:0x0
[0076.826] I> Non-ECC region[3]: Start:0x0, End:0x0
[0076.830] I> Non-ECC region[4]: Start:0x0, End:0x0
[0076.841] I> allocated(CO:44) base:0x849800000 size:0x36800000 align: 0x100000
[0076.848] I> allocated(CO:31) base:0x840000000 size:0x8000000 align: 0x8000000
[0076.855] I> allocated(CO:43) base:0x83c000000 size:0x4000000 align: 0x200000
[0076.862] I> allocated(CO:39) base:0x839e00000 size:0x2200000 align: 0x10000
[0076.869] I> allocated(CO:20) base:0x836000000 size:0x2000000 align: 0x2000000
[0076.876] I> allocated(CO:24) base:0x834000000 size:0x2000000 align: 0x2000000
[0076.883] I> allocated(CO:28) base:0x832000000 size:0x2000000 align: 0x2000000
[0076.891] I> allocated(CO:29) base:0x830000000 size:0x2000000 align: 0x2000000
[0076.898] I> allocated(CO:22) base:0x848000000 size:0x1000000 align: 0x1000000
[0076.905] I> allocated(CO:35) base:0x838e00000 size:0x1000000 align: 0x100000
[0076.912] I> allocated(CO:41) base:0x82f000000 size:0x1000000 align: 0x100000
[0076.919] I> allocated(CO:02) base:0x849000000 size:0x800000 align: 0x800000
[0076.926] I> allocated(CO:03) base:0x838000000 size:0x800000 align: 0x800000
[0076.933] I> allocated(CO:06) base:0x82e800000 size:0x800000 align: 0x800000
[0076.940] I> allocated(CO:56) base:0x82e000000 size:0x800000 align: 0x200000
[0076.947] I> allocated(CO:07) base:0x838800000 size:0x400000 align: 0x400000
[0076.954] I> allocated(CO:33) base:0x82dc00000 size:0x400000 align: 0x200000
[0076.961] I> allocated(CO:19) base:0x82d980000 size:0x280000 align: 0x10000
[0076.967] I> allocated(CO:23) base:0x838c00000 size:0x200000 align: 0x200000
[0076.974] I> allocated(CO:01) base:0x82d800000 size:0x100000 align: 0x100000
[0076.981] I> allocated(CO:05) base:0x82d700000 size:0x100000 align: 0x100000
[0076.988] I> allocated(CO:08) base:0x82d600000 size:0x100000 align: 0x100000
[0076.995] I> allocated(CO:09) base:0x82d500000 size:0x100000 align: 0x100000
[0077.002] I> allocated(CO:12) base:0x82d400000 size:0x100000 align: 0x100000
[0077.009] I> allocated(CO:15) base:0x82d300000 size:0x100000 align: 0x100000
[0077.016] I> allocated(CO:17) base:0x82d200000 size:0x100000 align: 0x100000
[0077.023] I> allocated(CO:27) base:0x82d100000 size:0x100000 align: 0x100000
[0077.030] I> allocated(CO:42) base:0x82d000000 size:0x100000 align: 0x100000
[0077.037] I> allocated(CO:54) base:0x82d900000 size:0x80000 align: 0x80000
[0077.044] I> allocated(CO:34) base:0x82cff0000 size:0x10000 align: 0x10000
[0077.050] I> allocated(CO:72) base:0x82cdf0000 size:0x200000 align: 0x10000
[0077.057] I> allocated(CO:46) base:0x800000000 size:0x20000000 align: 0x20000000
[0077.065] I> allocated(CO:47) base:0x82c800000 size:0x400000 align: 0x200000
[0077.072] I> allocated(CO:50) base:0x82c600000 size:0x200000 align: 0x100000
[0077.079] I> allocated(CO:52) base:0x82cdc0000 size:0x30000 align: 0x10000
[0077.085] I> allocated(CO:48) base:0x82cda0000 size:0x20000 align: 0x10000
[0077.092] I> allocated(CO:69) base:0x82cd80000 size:0x20000 align: 0x10000
[0077.099] I> allocated(CO:49) base:0x82cd70000 size:0x10000 align: 0x10000
[0077.106] I> NSDRAM base: 0x80000000, end: 0x82cdf0000, size: 0x7acdf0000
[0077.112] I> Task: Thermal check
[0077.115] I> Using min_chip_limit as min_tmon_limit
[0077.120] I> Using max_chip_limit as max_tmon_limit
[0077.125] I> BCT max_tmon_limit = 105
[0077.128] I> BCT min_tmon_limit = -28
[0077.132] I> BCT max_tmon_limit = 105
[0077.135] I> BCT min_tmon_limit = -28
[0077.139] I> SKU specific max_chip_limit = 105
[0077.143] I> SKU specific min_chip_limit = -28
[0077.147] I> BCT max_chip_limit = 105
[0077.151] I> BCT min_chip_limit = -28
[0077.154] I> enable_soctherm_polling = 0
[0077.158] I> max temp read = 32
[0077.161] I> min temp read = 31
[0077.164] I> Enabling thermtrip
[0077.167] I> Task: Update FSI SCR with thermal fuse data
[0077.172] I> Task: Enable WDT 5th expiry
[0077.176] I> Task: I2C register
[0077.179] I> Task: Set I2C bus freq
[0077.182] I> Task: Reset FSI
[0077.185] I> Task: Pinmux init
Hi guanhongfeng1069,
For “might be timeout in USB write” related issue, please switch the USB cable or port on your host to verify.
Please share the exact command you used to flash the board and the flash log as file for further check.
我换了typec线,也换了host,36.4.3版本还是无法刷机,但是35.6.1可以正常刷,刷机命令是
sudo ./flash jetson-agx-orin-devkit internal
So, are you using the devkit or custom board?
Do you mean sudo ./flash.sh jetson-agx-orin-devkit internal?
我们自己的载板,一直都是使用的这条flash指令,64G的SOM使用我们自己的载板,在R35.6.1和R36.4.3两个版本上都能通过 “sudo ./flash.sh jetson-agx-orin-devkit internal” 这条指令刷成功。而32G的SOM使用我们的载板,通过同样的刷机指令只有R35.6.1能成功,R36.4.3则会报usb timeout错误。
AGX Orin 64G + custom carrier + r35.6.1 => PASS
AGX Orin 64G + custom carrier + r36.4.3 => PASS
AGX Orin 32G + custom carrier + r35.6.1 => PASS
AGX Orin 32G + custom carrier + r36.4.3 => FAIL (USB timeout)
Is my understanding correct as above?
If so, have you tried verifying on the devkit board with AGX Orin 32G+r36.4.3?
理解非常正确,我们将尝试在套件上使用32G的SOM,看看是否能刷r36.4.3
问题找到了,是我们载板的问题,谢谢。
